Monitor shakes, flickers, then no signal
Solved Monitor shakes, flickers, then no signal
Post by StangLoveR on Mon Apr 12, 2010 3:50 am
I'm stumped as to what is wrong with my computer. Out of nowhere, it started doing this:
The output on screen starts shaking (the entire desktop), then the monitor starts turning black, then coming back on, and on and off quickly a few times, and then finally it just goes black and reads "no signal" (as if the computer was off).
If I turn the computer off for some time, and then start it back up, it works for a while and then the problem begins again.
Suspecting an overheating issue, I checked the video card fan and it was fine. Therefore, I swapped video cards in case the video card was faulty, and, no difference.
And that is where I stand now. If I restart the computer after the screen finally flickers off and stays off, nothing comes on screen upon startup.
This makes me think it's clearly a hardware problem/heating problem, so I'm wondering if it is the motherboard, since the video card doesnt appear to be the problem.
Any ideas?? Your suggestions are appreciated.
StangLoveR
Posts Posts : 15
Joined Joined : 2009-05-02
Points Points : 27779
Solved Re: Monitor shakes, flickers, then no signal
Post by Doctor Inferno on Mon Apr 12, 2010 5:04 am
What type of monitor are you using? LCD or CRT?
Post by StangLoveR on Mon Apr 12, 2010 5:44 am
Hello Doctor Inferno. I am using an LCD.
StangLoveR
Posts Posts : 15
Post by makxp77 on Tue Apr 13, 2010 10:41 pm
What is the make of the LCD? If its a dell they have a huge issue with capacitors.
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29054
Post by StangLoveR on Wed Apr 14, 2010 4:18 pm
I switched the output over to my TV and realized indeed my 4 year old Viewsonic LCD is failing.
Solution? Went out and bought an LG E2350V LED.
Problem solved! Thanks!
StangLoveR
Posts Posts : 15
