MagicDisc Driver Problems
Post by wath56 on Sun 11 Apr 2010, 1:15 am
Hi, recently I have uninstalled Magic Disc ( a mounting software, for disc images) I was using 4 drives for it to mount various things, but something went wrong during uninstall and now I'm stuck with the drives, but the Magic Disc files are gone. Its really annoying - i have tried reinstalling the program and uninstalling to see if it would take drivers off- i tried uninstalling the drivers in device manager, it uninstalled apparently, but still is there. Below is a scrn ..
https://i69.servimg.com/u/f69/15/09/14/15/untitl10.jpg
As you can see the removable disc drives are stuck there w.o and program managing it, and its prooved impossible for me to remove.
Thank You!
Windows 7 Ultimate (32bit)
2Gb Ram
Nvidia Gforce 8500gt
Emachines T5048
wath56
Posts Posts : 19
Joined Joined : 2009-07-23
OS OS : 7
Points Points : 27083
Re: MagicDisc Driver Problems
Post by Doctor Inferno on Sun 11 Apr 2010, 5:52 am
Does it work if you right click >> eject?
Points Points : 104630
Post by wath56 on Sun 11 Apr 2010, 11:38 pm
nope, doesnt work, it just says safe to remove hardware - i've tried system restore aswell
wath56
Posts Posts : 19
OS OS : 7
Post by Gabethebabe on Mon 12 Apr 2010, 11:53 am
What do you see if you open disk manager ? Start ==> Run ==> diskmgmt.msc (I hope in WIN7 it is the same as WINXP Big Grin)
Maybe you can kick them out from there?
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38248
Post by wath56 on Mon 12 Apr 2010, 11:27 pm
Thanks for trying gabe, but it only shows my primary partitions (c,d,e) im guessing i really did uninstall them and its just a visual error? Im using 7 so its probably an bug...
wath56
Posts Posts : 19
OS OS : 7
Post by xald on Wed 14 Apr 2010, 10:04 am
okay ui know what you have to do install megic disc again and then *disable* all the drives in the taskbar then check if the drives are gone if so then uninstall
xald
Posts Posts : 154
Joined Joined : 2009-10-30
OS OS : windows xp home sp3,
Protection Protection : malwarebytes anti-malware, avg free 9.0
Points Points : 27092
Post by wath56 on Sun 25 Apr 2010, 10:13 pm
@xald wrote:okay ui know what you have to do install megic disc again and then *disable* all the drives in the taskbar then check if the drives are gone if so then uninstall
doesnt work sry
wath56
Posts Posts : 19
OS OS : 7
Post by wath56 on Sun 25 Apr 2010, 10:14 pm
bump
wath56
Posts Posts : 19
OS OS : 7
Post by Gabethebabe on Mon 26 Apr 2010, 8:44 am
Tough problem.
Try this
Gabethebabe
Posts Posts : 1568
OS OS : Win7
