Need help removing Antivirus Suite/BankerFox/etc.
Post by TheMaskedLemon on 8th April 2010, 11:32 pm
Hello GeekPolice forums. I got successful help here sometime last year with a different fake Antivirus program, so I thought I'd come back here for help once again.
This time it's the Antivirus Suite virus, along with the fake alerts about BankerFox, random Viagra ads ( No way! ), porn ads, etc. You probably already know the deal. I always keep Malwarebytes and Spybot on my PC because of the last issue. This virus is preventing me from opening .exe programs, but I can still open Firefox. The weird thing is, I rebooted my PC at first and then I managed to get Malwarebytes up and running RIGHT before the Antivirus Suite thing went into effect. Malwarebytes completed a full scan and found 23 infections, so I removed them all and rebooted. I thought that would solve the problem, but it didn't. It just came right back. So I figured maybe it was something that Spybot had to get rid of that was leftover. The thing is, I can't get Spybot open, even before Antivirus opens up. So I'm kinda in a spot where I don't know what to do. All help is appreciated, I know you guys can help me. Thanks.
TheMaskedLemon
Posts Posts : 14
Joined Joined : 2009-09-17
OS OS : Microsoft XP
Points Points : 26474
Re: Need help removing Antivirus Suite/BankerFox/etc.
Post by Belahzur on 9th April 2010, 12:38 am
Points Points : 245101
Post by TheMaskedLemon on 9th April 2010, 12:59 am
I tried opening it up, but the same error that comes up for all the other .exe files comes up. It says the application is infected and asks me if I want to run the antivirus program (the fake one). I tried renaming it to ".exe", because it was just "OTL", but that didn't work either.
TheMaskedLemon
Posts Posts : 14
Post by Belahzur on 9th April 2010, 8:46 pm
Post by TheMaskedLemon on 11th April 2010, 11:31 pm
Neither of them can run. The same exact thing popped up for both of those that did with the OldTimer program. It's the same error that keeps popping up over and over again on the screen. "Application cannot be executed. The file _______ is infected. Would you like to run your antivirus program now?"
TheMaskedLemon
Posts Posts : 14
Post by TheMaskedLemon on 12th April 2010, 4:42 pm
bump
TheMaskedLemon
Posts Posts : 14
Post by Metalmusk on 12th April 2010, 4:53 pm
Hope you would have downloaded OTL.exe . If not, download it again from the link posted by Belahzur. Save it in the Desktop. Rename OTL.exe as iexplore.exe
It should open. Once, its executed,
Metalmusk
Posts Posts : 43
Joined Joined : 2009-06-21
Points Points : 27940
Post by TheMaskedLemon on 12th April 2010, 5:03 pm
Hey, I actually just figured out how to do the System Restore where you go to another state in a point of time, so I went back to when the virus wasn't there and I no longer have the problem at all. Now I'm going to run Spyware and Malwarebytes just for the heck of it. Is this a safe thing to do or will any problems return or still remain?
TheMaskedLemon
Posts Posts : 14
Post by Belahzur on 12th April 2010, 8:20 pm
Dunno, run MBAM and see what that log says.
