System freeze when drag and drop
Post by Voods on Sat Apr 03, 2010 1:39 pm
Hi
Every time when I try and Drag and drop files into a folder either on the desktop or in Explorer, my system freezes.
I can terminate the Explorer process and re-load it from the task manager, but not everything loads up properly, so I tend to do a re-boot.
I have run all the usual scans advised..
Any info would be appreciated.
Regards
Voods
Posts Posts : 229
Joined Joined : 2008-12-07
Protection Protection : Eset Smart Security 4
Points Points : 31434
Re: System freeze when drag and drop
Post by Gabethebabe on Sat Apr 03, 2010 8:09 pm
If you think you have malware problems, please read this and after that post here.
Gabethebabe
Posts Posts : 1568
Joined Joined : 2010-03-07
OS OS : Win7
Points Points : 38198
