XP Antivirus - partial fix but problems remain
Post by tokenwelshman on 2nd April 2010, 11:51 pm
Hi
I picked up an infection by XP Antivirus 2010 today - I appeared to have the usual symptoms for this infection - my normal (AVG) antivirus software was over-ridden, and warnings kept appearing every 20 seconds or so telling me my PC was infected.
I did a search on the subject, found a forum which advised downloading Malwarebytes' Anti-Malware software. I did this (had to do so in Safe Mode as I could not install the file in normal mode). The program scanned my PC, found 1 file and 5 registry entries, which looked as though they were indeed XP Antivirus (av.exe was mentioned). The files were removed, I rebooted my PC.... and now I am not able to run the majority of .exe files.
For example I cannot run Firefox, cannot run System Restore, cannot open Notebook... strangely I can open Internet Explorer which is why I'm able to type this.
I've looked at your "read this before posting" page, I tried downloading a Java update (the first instruction on your list) but could not run the exe file, and could not copy the instructions to a notepad file as notepad will not open!
So - what would you suggest I do?
By the way - before we get into this - thank you very very much for any advice you can give - it is hugely appreciated.
tokenwelshman
tokenwelshman
Posts Posts : 12
Joined Joined : 2010-04-02
Points Points : 24618
Re: XP Antivirus - partial fix but problems remain
Post by Belahzur on 3rd April 2010, 12:35 am
Points Points : 245121
Post by tokenwelshman on 3rd April 2010, 9:32 am
Hi
I have downloaded OTL to my desktop, but cannot execute it - I get the same problem as when I try to execute Firefox, Notepad, etc. The message is "Open with: choose the program you want to use to open this file OTL.exe" followed by the usual list.
tokenwelshman
tokenwelshman
Posts Posts : 12
Post by Belahzur on 3rd April 2010, 9:32 pm
Right click on OTL.exe and select Rename. Rename OTL.exe to explorer.exe
Post by tokenwelshman on 4th April 2010, 10:17 am
Hi
Makes no difference - I am still prompted to choose the program I want to use to run the exe file...
tokenwelshman
tokenwelshman
Posts Posts : 12
Post by Belahzur on 4th April 2010, 10:20 pm
  • Restart your computer
  • Select the first option, to run Windows in Safe Mode, then press Enter.
  • Choose your usual account.
Try OTL.exe now.
Post by tokenwelshman on 5th April 2010, 10:27 am
Hi
STILL won't let me run the exe file!
tokenwelshman
tokenwelshman
Posts Posts : 12
Post by Belahzur on 5th April 2010, 7:17 pm
Okay, try this.
Rename OTL again, remove the .exe extension and add .scr, try running it now.
Post by tokenwelshman on 5th April 2010, 9:19 pm
Hi
Couldn't rename the existing exe file, but I downloaded again and specified ".scr" as the extension. Worked fine this time. So - here's the
"OTL.txt" output. Extras.txt to follow in another reply.
tokenwelshman
OTL logfile created on: 05/04/2010 21:33:43 - Run 1
OTL by OldTimer - Version 3.2.1.0 Folder = C:\Documents and Settings\admin\Desktop
Locale: 00000809 | Country: United Kingdom | Language: ENG | Date Format: dd/MM/yyyy
2.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 74.00% Memory free
3.00 Gb Paging File | 3.00 Gb Available in Paging File | 89.00% Paging File free
Paging file location(s): C:\pagefile.sys 1524 3048 [binary data]
Drive C: | 71.04 Gb Total Space | 54.14 Gb Free Space | 76.20% Space Free | Partition Type: NTFS
Drive D: | 72.00 Gb Total Space | 71.90 Gb Free Space | 99.87% Space Free | Partition Type: NTFS
Computer Name: NETBOOK
Current User Name: admin
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/04/05 21:33:32 | 000,561,664 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\admin\Desktop\OTL.scr
PRC - [2010/04/02 09:06:02 | 001,101,152 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgchsvx.exe
PRC - [2010/04/02 09:05:32 | 001,038,688 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgupd.exe
PRC - [2010/03/27 12:38:57 | 000,617,752 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgnsx.exe
PRC - [2010/03/27 12:38:54 | 000,508,184 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgrsx.exe
PRC - [2010/03/27 12:38:49 | 000,710,424 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgcsrvx.exe
PRC - [2010/03/27 12:37:45 | 000,308,064 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgwdsvc.exe
PRC - [2009/04/30 13:23:26 | 000,090,112 | ---- | M] () -- C:\Program Files\Sony Ericsson\Sony Ericsson PC Suite\SupServ.exe
PRC - [2008/04/14 13:00:00 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2006/10/30 22:29:28 | 000,036,864 | ---- | M] () -- C:\Program Files\Samsung\Samsung Network Manager\SNMWLANService.exe
MOD - [2010/04/05 21:33:32 | 000,561,664 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\admin\Desktop\OTL.scr
SRV - [2010/03/27 12:37:45 | 000,308,064 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgwdsvc.exe -- (avg9wd)
SRV - [2009/06/02 10:10:08 | 000,637,952 | ---- | M] (Nokia.) [On_Demand | Stopped] -- C:\Program Files\PC Connectivity Solution\ServiceLayer.exe -- (ServiceLayer)
SRV - [2009/04/30 13:23:26 | 000,090,112 | ---- | M] () [Auto | Running] -- C:\Program Files\Sony Ericsson\Sony Ericsson PC Suite\SupServ.exe -- (OMSI download service)
SRV - [2006/10/30 22:29:28 | 000,036,864 | ---- | M] () [Auto | Running] -- C:\Program Files\samsung\Samsung Network Manager\SNMWLANService.exe -- (SNM WLAN Service)
DRV - [2010/03/27 12:40:08 | 000,242,696 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2010/03/27 12:40:04 | 000,216,200 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2010/03/27 12:40:03 | 000,029,512 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2009/02/09 08:37:56 | 000,007,808 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\usbser_lowerfltj.sys -- (UsbserFilt)
DRV - [2009/02/09 08:37:48 | 000,007,808 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\usbser_lowerflt.sys -- (upperdev)
DRV - [2009/02/09 08:37:46 | 000,022,016 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ccdcmbo.sys -- (nmwcdc)
DRV - [2009/02/09 08:37:46 | 000,017,664 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ccdcmb.sys -- (nmwcd)
DRV - [2008/10/21 10:22:48 | 000,114,600 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017mdm.sys -- (s0017mdm)
DRV - [2008/10/21 10:22:48 | 000,109,736 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017unic.sys -- (s0017unic) Sony Ericsson Device 0017 USB Ethernet Emulation SEMC0017 (WDM)
DRV - [2008/10/21 10:22:48 | 000,108,328 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017mgmt.sys -- (s0017mgmt) Sony Ericsson Device 0017 USB WMC Device Management Drivers (WDM)
DRV - [2008/10/21 10:22:48 | 000,104,616 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017obex.sys -- (s0017obex)
DRV - [2008/10/21 10:22:48 | 000,086,824 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017bus.sys -- (s0017bus) Sony Ericsson Device 0017 driver (WDM)
DRV - [2008/10/21 10:22:48 | 000,026,024 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017nd5.sys -- (s0017nd5) Sony Ericsson Device 0017 USB Ethernet Emulation SEMC0017 (NDIS)
DRV - [2008/10/21 10:22:48 | 000,015,016 | ---- | M] (MCCI Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\s0017mdfl.sys -- (s0017mdfl)
DRV - [2008/09/04 09:05:34 | 000,238,464 | ---- | M] (Vimicro Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\VMC326.sys -- (VMC326)
DRV - [2008/08/30 19:46:56 | 001,318,784 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\athw.sys -- (AR5416)
DRV - [2008/08/28 19:18:14 | 000,224,736 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
DRV - [2008/08/27 00:35:00 | 004,753,920 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2008/08/26 10:26:12 | 000,018,816 | ---- | M] (Nokia) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\pccsmcfd.sys -- (pccsmcfd)
DRV - [2008/06/27 09:02:00 | 000,289,024 | ---- | M] (Marvell) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\yk51x86.sys -- (yukonwxp)
DRV - [2008/04/14 13:00:00 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2008/04/14 00:15:14 | 000,060,032 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\USBAUDIO.sys -- (usbaudio) USB Audio Driver (WDM)
DRV - [2008/02/15 21:12:06 | 005,854,752 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\igxpmp32.sys -- (ialm)
DRV - [2008/01/15 03:01:02 | 000,030,208 | ---- | M] (Samsung Electronics,.LTD) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SamsungEDS.SYS -- (DNSeFilter)
DRV - [2008/01/09 13:28:34 | 000,027,632 | ---- | M] (Sony Ericsson Mobile Communications) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\seehcri.sys -- (seehcri)
DRV - [2007/03/31 21:02:42 | 000,876,384 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btkrnl.sys -- (BTKRNL)
DRV - [2007/03/23 18:50:42 | 000,067,960 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btwusb.sys -- (BTWUSB)
DRV - [2007/03/23 18:50:08 | 000,037,424 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\btport.sys -- (BTDriver)
DRV - [2005/10/27 05:18:05 | 000,004,300 | ---- | M] () [Kernel | Auto | Running] -- C:\WINDOWS\system32\MEMIO.SYS -- (DOSMEMIO)
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Yahoo! Search"
FF - prefs.js..browser.search.selectedEngine: "Yahoo! Search"
FF - prefs.js..browser.startup.homepage: "http://www.google.co.uk/"
FF - prefs.js..extensions.enabledItems: {3f963a5b-e555-4543-90e2-c3908898db71}:9.0.0.783
FF - prefs.js..keyword.URL: "http://uk.yhs.search.yahoo.com/avg/search?fr=yhs-avg&type=yahoo_avg_hs2-tb-web_uk&p="
FF - HKLM\software\mozilla\Firefox\Extensions\\{3f963a5b-e555-4543-90e2-c3908898db71}: C:\Program Files\AVG\AVG9\Firefox [2010/03/27 12:37:24 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\{ABDE892B-13A8-4d1b-88E6-365A6E755758}: C:\Program Files\Real\RealPlayer\browserrecord [2009/06/21 11:14:32 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Firefox\Extensions\\bkmrksync@nokia.com: C:\Program Files\Nokia\Nokia PC Suite 7\bkmrksync\ [2009/07/09 19:46:18 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/04/03 00:20:08 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6.3\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/04/03 00:20:08 | 000,000,000 | ---D | M]
[2009/01/07 22:00:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\admin\Application Data\Mozilla\Extensions
[2009/01/07 22:00:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\admin\Application Data\Mozilla\Firefox\Profiles\kdrhg8o1.default\extensions
[2010/04/02 21:20:52 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2010/01/16 01:55:13 | 000,001,538 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\amazon-en-GB.xml
[2010/01/16 01:55:13 | 000,000,947 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\chambers-en-GB.xml
[2010/01/16 01:55:13 | 000,000,769 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\eBay-en-GB.xml
[2010/01/16 01:55:13 | 000,001,135 | ---- | M] () -- C:\Program Files\Mozilla Firefox\searchplugins\yahoo-en-GB.xml
O1 HOSTS File: ([2008/04/14 13:00:00 | 000,000,734 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (RealPlayer Download and Record Plugin for Internet Explorer) - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\Program Files\Real\RealPlayer\rpbrowserrecordplugin.dll (RealPlayer)
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll (AVG Technologies CZ, s.r.o.)
O3 - HKLM\..\Toolbar: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {A057A204-BACC-4D26-9990-79A187E2698E} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - No CLSID value found.
O4 - HKLM..\Run: [Adobe Reader Speed Launcher] C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [Alcmtr] C:\WINDOWS\ALCMTR.EXE (Realtek Semiconductor Corp.)
O4 - HKLM..\Run: [AVG9_TRAY] C:\Program Files\AVG\AVG9\avgtray.exe (AVG Technologies CZ, s.r.o.)
O4 - HKLM..\Run: [BatteryManager] C:\Program Files\Samsung\Samsung Battery Manager\BatteryManager.exe ()
O4 - HKLM..\Run: [DMHotKey] C:\Program Files\Samsung\Easy Display Manager\DMLoader.exe (SAMSUNG Electronics)
O4 - HKLM..\Run: [EDS] C:\Program Files\Samsung\Samsung EDS\EDSAgent.exe (Samsung Electronics,.LTD)
O4 - HKLM..\Run: [MagicKeyboard] C:\Program Files\Samsung\MagicKBD\PreMKbd.exe ()
O4 - HKLM..\Run: [Malwarebytes Anti-Malware (reboot)] C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe (Malwarebytes Corporation)
O4 - HKLM..\Run: [SUPBackGround] C:\Program Files\Samsung\Samsung Update Plus\SUPBackGround.exe ()
O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
O4 - HKCU..\Run: [PC Suite Tray] C:\Program Files\Nokia\Nokia PC Suite 7\PCSuite.exe (Nokia)
O4 - HKCU..\Run: [Sony Ericsson PC Suite] C:\Program Files\Sony Ericsson\Sony Ericsson PC Suite\SEPCSuite.exe (Sony Ericsson Mobile Communications AB)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk = C:\Program Files\WIDCOMM\Bluetooth Software\BTTray.exe (Broadcom Corporation.)
O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm ()
O9 - Extra Button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
O9 - Extra 'Tools' menuitem : @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_15)
O16 - DPF: {CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.5.0)
O16 - DPF: {CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_15)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_15)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.254
O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll (AVG Technologies CZ, s.r.o.)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\WINDOWS\System32\igfxdev.dll (Intel Corporation)
O24 - Desktop WallPaper: C:\Documents and Settings\admin\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\admin\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2008/10/06 22:40:51 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O33 - MountPoints2\{6b0861a6-e58d-11dd-96fc-001377af6ffb}\Shell\AutoRun\command - "" = F:\SETUP.EXE -- File not found
O33 - MountPoints2\{6b0861a6-e58d-11dd-96fc-001377af6ffb}\Shell\configure\command - "" = F:\SETUP.EXE -- File not found
O33 - MountPoints2\{6b0861a6-e58d-11dd-96fc-001377af6ffb}\Shell\install\command - "" = F:\SETUP.EXE -- File not found
O33 - MountPoints2\{cac38898-dcfc-11de-bc7d-001377af6ffb}\Shell - "" = AutoRun
O33 - MountPoints2\{cac38898-dcfc-11de-bc7d-001377af6ffb}\Shell\AutoRun - "" = Auto&Play
O33 - MountPoints2\{cac38898-dcfc-11de-bc7d-001377af6ffb}\Shell\AutoRun\command - "" = E:\TotalLock.exe -- File not found
O37 - HKCU\...exe [@ = secfile] -- "C:\Documents and Settings\admin\Local Settings\Application Data\ave.exe" /START "%1" %* File not found
[2010/04/05 21:33:21 | 000,561,664 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\admin\Desktop\OTL.scr
[2010/04/03 10:29:06 | 000,555,520 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\admin\Desktop\explorer.scr.exe
[2010/04/03 00:39:44 | 016,291,616 | ---- | C] (Sun Microsystems, Inc.) -- C:\Documents and Settings\admin\My Documents\jre-6u19-windows-i586.exe
[2010/04/02 23:57:40 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/04/02 23:57:36 | 000,020,824 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/04/02 23:57:36 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
[2010/04/02 23:57:35 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2010/04/02 23:45:58 | 005,918,720 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\admin\My Documents\mbam-setup-1.45.exe
[2010/04/01 19:23:28 | 000,000,000 | ---D | C] -- C:\Documents and Settings\admin\My Documents\Imogen's Stories
[2010/03/27 12:40:14 | 000,000,000 | -H-D | C] -- C:\$AVG
[2010/03/27 12:34:41 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\avg9
[2010/03/27 12:06:50 | 002,131,808 | ---- | C] (AVG Technologies) -- C:\Documents and Settings\admin\My Documents\avg_free_stb_all_9_114_cnet.exe
[2010/03/21 15:46:05 | 000,000,000 | ---D | C] -- C:\Documents and Settings\admin\My Documents\Bookings
[2010/03/13 10:56:57 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Real
[2010/03/13 10:53:17 | 008,152,912 | ---- | C] (Mozilla) -- C:\Documents and Settings\admin\My Documents\Firefox Setup 3.6(2).exe
[2010/02/07 21:52:30 | 000,148,736 | ---- | C] (Avanquest Software) -- C:\Documents and Settings\All Users\Application Data\hpe8.dll
[2009/03/11 20:49:04 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2009/01/07 22:18:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2008/10/06 22:44:07 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[2008/10/06 22:44:05 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[9 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[2010/04/05 21:33:51 | 058,576,358 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
[2010/04/05 21:29:28 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/04/05 21:29:24 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/04/05 21:29:21 | 2137,444,352 | -HS- | M] () -- C:\hiberfil.sys
[2010/04/05 10:35:06 | 004,718,592 | -H-- | M] () -- C:\Documents and Settings\admin\NTUSER.DAT
[2010/04/05 10:35:06 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\admin\ntuser.ini
[2010/04/05 10:34:05 | 001,656,336 | -H-- | M] () -- C:\Documents and Settings\admin\Local Settings\Application Data\IconCache.db
[2010/04/03 10:29:19 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\admin\Desktop\explorer.scr.exe
[2010/04/03 00:39:49 | 016,291,616 | ---- | M] (Sun Microsystems, Inc.) -- C:\Documents and Settings\admin\My Documents\jre-6u19-windows-i586.exe
[2010/04/02 23:57:44 | 000,000,696 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/04/02 23:53:06 | 000,001,790 | -HS- | M] () -- C:\Documents and Settings\All Users\Application Data\Wv7V1mEL4UH
[2010/04/02 23:53:06 | 000,001,790 | -HS- | M] () -- C:\Documents and Settings\admin\Local Settings\Application Data\Wv7V1mEL4UH
[2010/04/02 23:52:29 | 000,001,060 | -HS- | M] () -- C:\Documents and Settings\All Users\Application Data\834061123
[2010/04/02 23:52:29 | 000,001,060 | -HS- | M] () -- C:\Documents and Settings\admin\Local Settings\Application Data\834061123
[2010/04/02 23:47:45 | 000,181,760 | -HS- | M] () -- C:\Documents and Settings\admin\Local Settings\Application Data\1633618601.dll
[2010/04/02 23:46:56 | 005,918,720 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\admin\My Documents\mbam-setup-1.45.exe
[2010/03/30 11:06:04 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/03/29 15:24:58 | 000,038,224 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/03/29 15:24:46 | 000,020,824 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/03/29 10:37:39 | 000,439,376 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
[2010/03/29 10:37:39 | 000,380,918 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2010/03/29 10:37:39 | 000,053,166 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2010/03/28 21:51:52 | 001,439,645 | ---- | M] () -- C:\Documents and Settings\admin\My Documents\Members_News_Nov09_Clickable.pdf
[2010/03/27 12:40:08 | 000,242,696 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/03/27 12:40:04 | 000,216,200 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgldx86.sys
[2010/03/27 12:40:03 | 000,029,512 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/03/27 12:39:50 | 000,001,507 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\AVG Free 9.0.lnk
[2010/03/27 12:39:48 | 000,012,464 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgrsstx.dll
[2010/03/27 12:37:49 | 000,113,461 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\iavichjw.avm
[2010/03/27 12:07:05 | 002,131,808 | ---- | M] (AVG Technologies) -- C:\Documents and Settings\admin\My Documents\avg_free_stb_all_9_114_cnet.exe
[2010/03/27 01:39:24 | 011,727,483 | ---- | M] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (Richard X Eight Four Remix).mp3
[2010/03/27 01:36:11 | 009,451,960 | ---- | M] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (Grum Remix).mp3
[2010/03/27 01:33:07 | 006,725,798 | ---- | M] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (richard x one zero remix).djnakai.blogspot.com.mp3
[2010/03/13 21:09:06 | 000,117,711 | ---- | M] () -- C:\Documents and Settings\admin\My Documents\ilovesaab_papercraft_saab900turbo.pdf
[2010/03/13 15:30:08 | 000,002,473 | ---- | M] () -- C:\Documents and Settings\admin\Desktop\Microsoft Office Excel 2007.lnk
[2010/03/13 10:55:35 | 000,001,602 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Mozilla Firefox.lnk
[2010/03/13 10:53:58 | 008,152,912 | ---- | M] (Mozilla) -- C:\Documents and Settings\admin\My Documents\Firefox Setup 3.6(2).exe
[2010/03/12 11:34:33 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/04/05 21:29:21 | 2137,444,352 | -HS- | C] () -- C:\hiberfil.sys
[2010/04/02 23:57:44 | 000,000,696 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/04/02 23:52:29 | 000,001,060 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\834061123
[2010/04/02 23:52:29 | 000,001,060 | -HS- | C] () -- C:\Documents and Settings\admin\Local Settings\Application Data\834061123
[2010/04/02 23:25:03 | 000,181,760 | -HS- | C] () -- C:\Documents and Settings\admin\Local Settings\Application Data\1633618601.dll
[2010/04/02 23:20:46 | 000,001,790 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\Wv7V1mEL4UH
[2010/04/02 23:20:46 | 000,001,790 | -HS- | C] () -- C:\Documents and Settings\admin\Local Settings\Application Data\Wv7V1mEL4UH
[2010/03/28 21:51:52 | 001,439,645 | ---- | C] () -- C:\Documents and Settings\admin\My Documents\Members_News_Nov09_Clickable.pdf
[2010/03/27 12:39:50 | 000,001,507 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\AVG Free 9.0.lnk
[2010/03/27 01:37:10 | 011,727,483 | ---- | C] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (Richard X Eight Four Remix).mp3
[2010/03/27 01:34:23 | 009,451,960 | ---- | C] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (Grum Remix).mp3
[2010/03/27 01:32:35 | 006,725,798 | ---- | C] () -- C:\Documents and Settings\admin\My Documents\Goldfrapp - Rocket (richard x one zero remix).djnakai.blogspot.com.mp3
[2010/03/13 21:09:06 | 000,117,711 | ---- | C] () -- C:\Documents and Settings\admin\My Documents\ilovesaab_papercraft_saab900turbo.pdf
[2009/07/06 21:07:39 | 000,010,834 | ---- | C] () -- C:\WINDOWS\hpdj5100.ini
[2009/04/25 13:43:40 | 000,012,800 | ---- | C] () -- C:\Documents and Settings\admin\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/01/08 18:41:34 | 000,000,128 | ---- | C] () -- C:\Documents and Settings\admin\Local Settings\Application Data\fusioncache.dat
[2009/01/04 21:27:24 | 000,001,520 | ---- | C] () -- C:\WINDOWS\System32\admin_KBD.ini
[2009/01/04 21:26:52 | 004,718,592 | -H-- | C] () -- C:\Documents and Settings\admin\NTUSER.DAT
[2009/01/04 21:26:52 | 000,001,024 | -H-- | C] () -- C:\Documents and Settings\admin\ntuser.dat.LOG
[2009/01/04 21:26:52 | 000,000,178 | -HS- | C] () -- C:\Documents and Settings\admin\ntuser.ini
[2008/11/26 03:33:52 | 000,001,520 | ---- | C] () -- C:\WINDOWS\System32\Umu Zubairu-White_KBD.ini
[2008/11/26 03:32:18 | 000,262,144 | ---- | C] () -- C:\Documents and Settings\All Users\NTUSER.DAT
[2008/11/26 03:32:18 | 000,001,024 | -H-- | C] () -- C:\Documents and Settings\All Users\NTUSER.DAT.LOG
[2008/11/07 21:41:37 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2008/10/06 22:53:53 | 000,001,522 | ---- | C] () -- C:\WINDOWS\System32\MagicKBD.INI
[2008/10/06 22:53:53 | 000,001,520 | ---- | C] () -- C:\WINDOWS\System32\Owner_KBD.ini
[2008/10/06 22:53:51 | 000,003,425 | ---- | C] () -- C:\WINDOWS\System32\KBDR.INI
[2008/10/06 22:53:51 | 000,002,741 | ---- | C] () -- C:\WINDOWS\System32\KBDD.INI
[2008/10/06 22:53:51 | 000,002,699 | ---- | C] () -- C:\WINDOWS\System32\KBDO.INI
[2008/10/06 22:53:51 | 000,002,699 | ---- | C] () -- C:\WINDOWS\System32\KBDC.INI
[2008/10/06 22:53:51 | 000,002,606 | ---- | C] () -- C:\WINDOWS\System32\KBDB.INI
[2008/10/06 22:53:51 | 000,002,236 | ---- | C] () -- C:\WINDOWS\System32\KBDQ.INI
[2008/10/06 22:53:51 | 000,001,956 | ---- | C] () -- C:\WINDOWS\System32\KBDE.INI
[2008/10/06 22:53:51 | 000,001,885 | ---- | C] () -- C:\WINDOWS\System32\KBDP.INI
[2008/10/06 22:53:51 | 000,001,857 | ---- | C] () -- C:\WINDOWS\System32\KBDUU.INI
[2008/10/06 22:53:51 | 000,001,835 | ---- | C] () -- C:\WINDOWS\System32\KBDG.INI
[2008/10/06 22:53:51 | 000,001,835 | ---- | C] () -- C:\WINDOWS\System32\KBDA.INI
[2008/10/06 22:53:51 | 000,001,834 | ---- | C] () -- C:\WINDOWS\System32\KBDU.INI
[2008/10/06 22:53:51 | 000,001,819 | ---- | C] () -- C:\WINDOWS\System32\KBDN.INI
[2008/10/06 22:53:51 | 000,001,699 | ---- | C] () -- C:\WINDOWS\System32\KBDT.INI
[2008/10/06 22:53:51 | 000,001,697 | ---- | C] () -- C:\WINDOWS\System32\KBDV.INI
[2008/10/06 22:53:51 | 000,001,522 | ---- | C] () -- C:\WINDOWS\System32\KBDS.INI
[2008/10/06 22:53:51 | 000,001,476 | ---- | C] () -- C:\WINDOWS\System32\KBDF.INI
[2008/10/06 22:51:19 | 000,000,135 | R--- | C] () -- C:\WINDOWS\System32\lngEng.ini
[2008/10/06 22:51:19 | 000,000,117 | ---- | C] () -- C:\WINDOWS\System32\lngKor.ini
[2008/10/06 22:47:52 | 000,147,456 | ---- | C] () -- C:\WINDOWS\System32\igfxCoIn_v4926.dll
[2008/10/06 22:45:10 | 000,004,300 | ---- | C] () -- C:\WINDOWS\System32\MEMIO.SYS
[2008/10/06 17:36:05 | 000,000,416 | ---- | C] () -- C:\WINDOWS\System32\oeminfo.ini
[2007/04/01 10:00:28 | 002,842,624 | ---- | C] () -- C:\WINDOWS\System32\btwicons.dll
[2007/04/01 09:41:52 | 000,090,112 | ---- | C] () -- C:\WINDOWS\System32\btprn2k.dll
[2005/02/17 13:41:32 | 000,000,603 | ---- | C] () -- C:\WINDOWS\System32\BTNeighborhood.dll.manifest
[2005/02/17 13:41:30 | 000,000,593 | ---- | C] () -- C:\WINDOWS\System32\btcss.dll.manifest
[2001/11/14 14:56:00 | 001,802,240 | ---- | C] () -- C:\WINDOWS\System32\lcppn21.dll
tokenwelshman
Posts Posts : 12
Post by tokenwelshman on 5th April 2010, 9:20 pm
Hi
Here is "extras.txt".
Thanks!
tokenwelshman
OTL Extras logfile created on: 05/04/2010 21:33:43 - Run 1
File Age = 30 Days
Output = Standard
.exe [@ = secfile] -- C:\Documents and Settings\admin\Local Settings\Application Data\ave.exe File not found
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [print] -- "C:\Program Files\Microsoft Office\Office12\msohtmed.exe" /p %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
"FirstRunDisabled" = 1
"AntiVirusOverride" = 1
"FirewallOverride" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"DisableNotifications" = 1
"C:\WINDOWS\system32\dpvsetup.exe" = C:\WINDOWS\system32\dpvsetup.exe:*:Enabled:Microsoft DirectPlay Voice Test -- (Microsoft Corporation)
"C:\Program Files\Mozilla Firefox\firefox.exe" = C:\Program Files\Mozilla Firefox\firefox.exe:*:Enabled:Firefox -- (Mozilla Corporation)
"C:\Program Files\Real\RealPlayer\realplay.exe" = C:\Program Files\Real\RealPlayer\realplay.exe:*:Disabled:RealPlayer -- (RealNetworks, Inc.)
"C:\Program Files\AVG\AVG9\avgupd.exe" = C:\Program Files\AVG\AVG9\avgupd.exe:*:Enabled:avgupd.exe -- (AVG Technologies CZ, s.r.o.)
"C:\Program Files\AVG\AVG9\avgnsx.exe" = C:\Program Files\AVG\AVG9\avgnsx.exe:*:Enabled:avgnsx.exe -- (AVG Technologies CZ, s.r.o.)
"{00AF10C1-44BD-4862-9D7F-24E6BA3E87FD}" = imagine digital freedom - Samsung
"{0C34B801-6AEC-4667-B053-03A67E2D0415}" = Apple Application Support
"{0C973594-7DDF-4BD0-84ED-3517F7622037}" = PC Connectivity Solution
"{145DE957-0679-4A2A-BB5C-1D3E9808FAB2}" = Samsung Recovery Solution III
"{17283B95-21A8-4996-97DA-547A48DB266F}" = Easy Display Manager
"{212748BB-0DA5-46DE-82A1-403736DC9F27}" = MSVC80_x86
"{26A24AE4-039D-4CA4-87B4-2F83216015FF}" = Java(TM) 6 Update 15
"{2E5A5B57-57FC-4C79-A239-9DB280ADEC2A}" = Microsoft RAW Image Thumbnailer and Viewer for Windows XP Version 1.0 (Build 50)
"{2FFE93F0-BB72-4E52-8761-354D1AAA9387}" = Sony Ericsson PC Suite 6.009.00
"{3248F0A8-6813-11D6-A77B-00B0D0150000}" = J2SE Runtime Environment 5.0
"{32D6A58F-9659-446C-BBFC-E6F2B41F24DC}" = Samsung Magic Doctor
"{3D39E775-DDDA-4327-B747-0BDC5F191331}" = Nokia PC Suite
"{52D02A2B-03D2-4E34-A358-DC5D951FD296}" = Nokia Connectivity Cable Driver
"{5CBB720F-08E6-4043-B83F-76C277AF6DE7}" = Samsung Wallpaper
"{6F730513-8688-4C3C-90A3-6B9792CE2EF3}" = Samsung Battery Manager
"{716E0306-8318-4364-8B8F-0CC4E9376BAC}" = MSXML 4.0 SP2 Parser and SDK
"{71A51B59-E7D3-11DB-A386-005056C00008}" = Namuga 1.3M Webcam
"{76E41F43-59D2-4F30-BA42-9A762EE1E8DE}" = Avanquest update
"{7B46F9CF-CF60-492E-816E-95EB1A9D1BB4}" = Play Camera
"{84814E6B-2581-46EC-926A-823BD1C670F6}" = WIDCOMM Bluetooth Software
"{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_ENTERPRISER_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_ENTERPRISER_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_ENTERPRISER_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_ENTERPRISER_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_ENTERPRISER_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISER_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{91120000-0030-0000-0000-0000000FF1CE}_ENTERPRISER_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-0030-0000-0000-0000000FF1CE}_ENTERPRISER_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{A429C2AE-EBF1-4F81-A221-1C115CAADDAD}" = QuickTime
"{A5F483F0-2D79-4FCA-AE09-D0D96E23EBF7}" = Samsung Update Plus
"{ABB14904-A11B-4F42-996C-80FD608A0F17}" = Samsung EDS
"{AC76BA86-7AD7-1033-7B44-A81300000003}" = Adobe Reader 8.1.4
"{BAE68339-B0F6-4D33-9554-5A3DB2DFF5DA}" = User Guide
"{BD723E53-A42C-4702-AA04-1D74A0311590}" = Magic Keyboard
"{DEA48EFD-22C1-4CD6-B887-EB2E6B2E4735}" = Samsung Network Manager 2.0
"{F4F41D14-E0DD-4FB4-AA09-A14225C769BD}" = Atheros WLAN Client
"504244733D18C8F63FF584AEB290E3904E791693" = Windows Driver Package - Nokia pccsmcfd (08/22/2008 7.0.0.0)
"Adobe Flash Player ActiveX" = Adobe Flash Player ActiveX
"AVG9Uninstall" = AVG Free 9.0
"E8A6D621B6D3FC5D43C68C549D959DE76EEF5D84" = Windows Driver Package - Nokia Modem (06/01/2009 4.1)
"ENTERPRISER" = Microsoft Office Enterprise 2007
"F779F5541ABD99C95C03B0FD5E3C058B22DA0FF7" = Windows Driver Package - Nokia Modem (06/01/2009 7.01.0.3)
"HDMI" = Intel(R) Graphics Media Accelerator Driver
"ie7" = Windows Internet Explorer 7
"InstallShield_{7B46F9CF-CF60-492E-816E-95EB1A9D1BB4}" = Play Camera
"InstallShield_{A5F483F0-2D79-4FCA-AE09-D0D96E23EBF7}" = Samsung Update Plus
"InstallShield_{DEA48EFD-22C1-4CD6-B887-EB2E6B2E4735}" = Samsung Network Manager 2.0
"Juice" = Juice 2.2
"Marvell Miniport Driver" = Marvell Miniport Driver
"Mozilla Firefox (3.6.3)" = Mozilla Firefox (3.6.3)
"Nokia PC Suite" = Nokia PC Suite
"RealPlayer 6.0" = RealPlayer
"SynTPDeinstKey" = Synaptics Pointing Device Driver
"Wdf01005" = Microsoft Kernel-Mode Driver Framework Feature Pack 1.5
"Wdf01007" = Microsoft Kernel-Mode Driver Framework Feature Pack 1.7
"Wudf01007" = Microsoft User-Mode Driver Framework Feature Pack 1.7
[ Application Events ]
Error - 03/02/2010 18:03:03 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Description = Hanging application firefox.exe, version 1.9.1.3642, hang module hungapp,
version 0.0.0.0, hang address 0x00000000.
Error - 12/02/2010 08:28:50 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Description = Hanging application iexplore.exe, version 8.0.6001.18702, hang module
hungapp, version 0.0.0.0, hang address 0x00000000.
Error - 15/02/2010 18:45:45 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Error - 17/02/2010 04:46:14 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Error - 17/02/2010 04:47:02 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Error - 06/03/2010 06:14:10 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Error - 21/03/2010 09:30:04 | Computer Name = NETBOOK | Source = Application Error | ID = 1000
Description = Faulting application iexplore.exe, version 8.0.6001.18702, faulting
module flash9f.ocx, version 9.0.124.0, fault address 0x0009c1d5.
Error - 26/03/2010 07:47:52 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Description = Hanging application firefox.exe, version 1.9.2.3667, hang module hungapp,
Error - 29/03/2010 06:15:23 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Error - 30/03/2010 19:05:40 | Computer Name = NETBOOK | Source = Application Hang | ID = 1002
Description = Hanging application firefox.exe, version 1.9.2.3727, hang module hungapp,
[ System Events ]
Error - 03/04/2010 15:24:50 | Computer Name = NETBOOK | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service netman with
arguments "" in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
Description = DCOM got error "%1084" attempting to start the service EventSystem
with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
Error - 03/04/2010 15:25:09 | Computer Name = NETBOOK | Source = DCOM | ID = 10005
Error - 05/04/2010 05:32:04 | Computer Name = NETBOOK | Source = DCOM | ID = 10005
Error - 05/04/2010 05:32:24 | Computer Name = NETBOOK | Source = Service Control Manager | ID = 7001
Description = The DHCP Client service depends on the NetBios over Tcpip service
which failed to start because of the following error: %%31
Description = The DNS Client service depends on the TCP/IP Protocol Driver service
Description = The TCP/IP NetBIOS Helper service depends on the AFD service which
Description = The IPSEC Services service depends on the IPSEC driver service which
Error - 05/04/2010 05:32:24 | Computer Name = NETBOOK | Source = Service Control Manager | ID = 7026
AFD AvgLdx86 AvgMfx86 AvgTdiX Fips intelppm IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip
Error - 05/04/2010 05:35:04 | Computer Name = NETBOOK | Source = DCOM | ID = 10005
tokenwelshman
Posts Posts : 12
Post by Belahzur on 5th April 2010, 9:30 pm
Please run OTL.exe.
    :OTL
  • Close OTL.exe
Post by tokenwelshman on 6th April 2010, 10:19 pm
Hi
Here's the output.
tokenwelshman
tokenwelshman
Posts Posts : 12
Post by tokenwelshman on 6th April 2010, 10:20 pm
Try again!
========== OTL ==========
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{A057A204-BACC-4D26-9990-79A187E2698E} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}\ not found.
Registry value HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} deleted successfully.
Registry key HKEY_CURRENT_USER\Software\Classes\.exe\ deleted successfully.
HKEY_LOCAL_MACHINE\Software\Classes\.exe\\|exefile /E : value set successfully!
C:\Documents and Settings\All Users\Application Data\834061123 moved successfully.
C:\Documents and Settings\admin\Local Settings\Application Data\834061123 moved successfully.
File C:\Documents and Settings\admin\Local Settings\Application Data\1633618601.dll not found.
C:\Documents and Settings\All Users\Application Data\Wv7V1mEL4UH moved successfully.
C:\Documents and Settings\admin\Local Settings\Application Data\Wv7V1mEL4UH moved successfully.
OTL by OldTimer - Version 3.2.1.0 log created on 04062010_231914
tokenwelshman
Posts Posts : 12
Post by tokenwelshman on 6th April 2010, 10:21 pm
PS No problems with this process or requests to reboot the machine.
tokenwelshman
Posts Posts : 12
Post by Belahzur on 7th April 2010, 12:57 am
Post by tokenwelshman on 7th April 2010, 9:32 pm
Hi
Attached below is the log from MBAM. It only found one malicious item. I should explain again that I previously ran MBAM when I first discovered this virus.
When I downloaded MBAM the first time around, I could not download the latest update, not sure why - so the virus database used by MBAM first time around was somewhat out of date. However it did identify and remove (I think?) the XP Antivirus malware. Unfortunately I didn't retain the log file from the previous scan so I can't share the output of that scan with you. As I said in my original post, the problem now is that I cannot open .exe files for whatever reason.
However, MBAM was able to update this time, and did find a further malicious item, so here's the log file which has been produced as a result of the quick scan.
Thanks again for your help so far
tokenwelshman
Malwarebytes' Anti-Malware 1.45
Database version: 3966
07/04/2010 21:29:03
mbam-log-2010-04-07 (21-29-03).txt
Scan type: Quick scan
Objects scanned: 125248
Time elapsed: 16 minute(s), 14 second(s)
Registry Values Infected: 1
HKEY_CLASSES_ROOT\secfile\shell\open\command\(default) (Rogue.MultipleAV) -> Quarantined and deleted successfully.
tokenwelshman
Posts Posts : 12
Post by Belahzur on 8th April 2010, 12:09 am
One more scan to do.
Run ESET Online Scan
Please do an online scan with [You must be registered and logged in to see this link.]. Please use Internet Explorer as it uses ActiveX.
  • Click on Scan.
Post by tokenwelshman on 8th April 2010, 9:24 pm
Hi
Quite a boring outcome for this one! Log copied below.
tokenwelshman
# version=7
# iexplore.exe=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# EOSSerial=616ce700cc84c94baaa960aae8e268ae
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-04-08 08:07:52
# local_time=2010-04-08 09:07:52 (+0000, GMT Daylight Time)
# country="United Kingdom"
# lang=1033
# compatibility_mode=1024 16777175 100 0 1063809 1063809 0 0
# compatibility_mode=8192 67108863 100 0 245 245 0 0
# scanned=71389
# found=0
# cleaned=0
# scan_time=7055
tokenwelshman
Posts Posts : 12
Post by Belahzur on 9th April 2010, 12:30 am
Post by tokenwelshman on 9th April 2010, 6:41 am
I'm able to open the things I couldn't open previously, eg Firefox, notepad, System Restore, etc, and there are no anti-virus pop-ups. I notice most of the icons on the bottom right of the screen have disappeared - eg I'd expect to see an AVG logo near the clock to show it is running - there is nothing there - but opening AVG shows that it is enabled. Is there something I need to do to bring those icons back?
tokenwelshman
tokenwelshman
Posts Posts : 12
