wuauclt.exe problem
Re: wuauclt.exe problem
Post by ianmc on 29th March 2010, 6:54 am
I'm having the same issue and it's driving me crazy, every time I try and download a program that might help, according to other forum's solutions the file is automatically deleted upon download.
ianmc
Posts Posts : 16
Joined Joined : 2010-03-29
OS OS : Windows Vista
Points Points : 24676
Post by Dr Jay on 29th March 2010, 2:36 pm
Please visit this webpage for a tutorial on downloading and running ComboFix:
See the area: Using ComboFix, and when done, post the log back here.
Posts Posts : 13810
Points Points : 302437
Post by ianmc on 29th March 2010, 4:23 pm
Hi, I tried downloading the ComboFix and running it, but as soon as I ran it I was prompted for an authorization name and password. I am the only user on my computer, so I don't know what's up with that, but after I entered the info I got another "Application cannot be executed." message and ComboFix was deleted from my Desktop.
I really appreciate your help with this,
Ian
ianmc
Posts Posts : 16
Post by Dr Jay on 29th March 2010, 8:35 pm
Ouch.
Ok. Download ComboFix to your Desktop again, but do not run it. Both of these items must be saved to the Desktop.
Then, after it is downloaded, open Notepad and enter in the following by copying and pasting the text:
@echo off
@set winlogon.exe="%desktop%\winlogon.bat"
RENAME ComboFix.exe winlogon.bat
pause
echo ComboFix alternate log > winlogon.txt
start /high /wait "%winlogon.exe%" /stepdel >> winlogon.txt
exit
Then save the file to your Desktop as winlogon.cmd
choose Save as type... All Files. Then, click Save.
Exit Notepad. Then, double-click on winlogon.cmd
It will rename ComboFix, and then start ComboFix. ComboFix will run and a log will be saved to your Desktop. Then, ComboFix will reboot the computer. After reboot, it will finish itself and launch its own log.
Please post the contents of the ComboFix log that launches, and the contents of winlogon.txt.
Posts Posts : 13810
Post by ianmc on 29th March 2010, 8:43 pm
Ok, so I'm trying to open and paste the text into Notepad, but it closes notepad before I can do anything with it. Is there any way to do the same thing with word?
ianmc
Posts Posts : 16
Post by ianmc on 30th March 2010, 12:34 am
Alright, I just put the computer in safe mode and followed your directions. I have just restarted and currently the virus messages have not started up...
Sorry if this serves no purpose except to spam the hell out of you, but here is my log after the winlogon/combofix ran:
ComboFix 10-03-29.02 - ian 03/29/2010 19:50:08.1.2 - x86 MINIMAL
Microsoft® Windows Vista™ Home Premium 6.0.6000.0.1252.1.1033.18.3061.2541 [GMT -4:00]
Running from: c:\users\ian\Desktop\ComboFix.exe
AV: AVG Anti-Virus Free *On-access scanning enabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
SP: AVG Anti-Virus Free *enabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
SP: McAfee VirusScan *enabled* (Updated) {C78B3C70-4777-4742-BB91-9D615CC575E6}
* Created a new restore point
c:\$recycle.bin\S-1-5-21-1126384393-4124308364-2450743494-500
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
c:\program files\ShoppingReport
c:\program files\ShoppingReport\Bin\2.5.0\ShoppingReport.dll
c:\program files\ShoppingReport\Uninst.exe
c:\programdata\Microsoft\Windows\Start Menu\Programs\Startup\Bluetooth.lnk
c:\users\ian\AppData\Local\krcdbp
c:\users\ian\AppData\Local\krcdbp\bgelsftav.exe
c:\windows\system32\oem7.inf
((((((((((((((((((((((((( Files Created from 2010-02-28 to 2010-03-29 )))))))))))))))))))))))))))))))
2010-03-29 23:58 . 2010-03-29 23:58 -------- d-----w- c:\users\ian\AppData\Local\temp
2010-03-29 23:58 . 2010-03-29 23:58 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-03-19 18:00 . 2010-03-19 18:00 509552 ----a-w- c:\programdata\Google\Google Toolbar\Update\gtb6793.tmp.exe
2010-03-17 18:44 . 2010-03-17 18:44 50354 ----a-w- c:\users\ian\AppData\Roaming\Facebook\uninstall.exe
2010-03-17 18:44 . 2010-03-17 18:44 -------- d-----w- c:\users\ian\AppData\Roaming\Facebook
2010-03-11 08:01 . 2010-02-20 23:54 24064 ----a-w- c:\windows\system32\nshhttp.dll
2010-03-11 08:01 . 2010-02-20 21:30 396800 ----a-w- c:\windows\system32\drivers\http.sys
2010-03-11 08:01 . 2010-02-20 23:51 31232 ----a-w- c:\windows\system32\httpapi.dll
2010-03-06 05:30 . 2010-03-06 05:30 847040 ----a-w- c:\users\ian\AppData\Roaming\Facebook\axfbootloader.dll
2010-03-06 05:30 . 2010-03-06 05:30 5582848 ----a-w- c:\users\ian\AppData\Roaming\Facebook\npfbplugin_1_0_3.dll
2010-03-29 23:45 . 2008-05-27 06:08 12 ----a-w- c:\windows\bthservsdp.dat
2010-03-29 05:22 . 2009-01-03 02:04 5972 ----a-w- c:\users\ian\AppData\Local\d3d9caps.dat
2010-03-29 05:09 . 2008-06-09 00:21 -------- d-----w- c:\users\ian\AppData\Roaming\LimeWire
2010-03-28 21:27 . 2008-06-07 02:44 32706 ----a-w- c:\users\ian\AppData\Roaming\wklnhst.dat
2010-03-23 09:29 . 2008-07-19 03:49 -------- d-----w- c:\users\ian\AppData\Roaming\WeatherBug
2010-03-19 18:09 . 2008-05-27 06:30 -------- d-----w- c:\program files\Google
2010-03-18 04:39 . 2008-06-24 02:41 -------- d-----w- c:\users\ian\AppData\Roaming\Skype
2010-03-18 04:06 . 2008-07-19 02:06 -------- d-----w- c:\users\ian\AppData\Roaming\skypePM
2010-03-11 08:24 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2010-03-11 08:06 . 2009-10-27 05:18 -------- d-----w- c:\programdata\Microsoft Help
2010-02-24 09:47 . 2008-06-03 21:57 73440 ----a-w- c:\users\ian\AppData\Local\GDIPFONTCACHEV1.DAT
2010-02-18 00:18 . 2009-10-22 18:57 217088 ----a-w- c:\users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\browserhighlighter@ebay.com\components\Shim.dll
2010-01-30 19:41 . 2010-01-30 19:41 -------- d-----w- c:\users\ian\AppData\Roaming\AnvSoft
2010-01-30 19:41 . 2010-01-30 19:41 -------- d-----w- c:\program files\AnvSoft
2010-01-25 12:58 . 2010-02-23 20:04 473088 ----a-w- c:\windows\system32\secproc_isv.dll
2010-01-25 12:58 . 2010-02-23 20:04 154624 ----a-w- c:\windows\system32\secproc_ssp_isv.dll
2010-01-25 12:58 . 2010-02-23 20:04 154112 ----a-w- c:\windows\system32\secproc_ssp.dll
2010-01-25 12:58 . 2010-02-23 20:04 472576 ----a-w- c:\windows\system32\secproc.dll
2010-01-25 12:56 . 2010-02-23 20:04 312320 ----a-w- c:\windows\system32\msdrm.dll
2010-01-25 08:36 . 2010-02-23 20:04 435712 ----a-w- c:\windows\system32\RMActivate_ssp.exe
2010-01-25 08:36 . 2010-02-23 20:04 515584 ----a-w- c:\windows\system32\RMActivate.exe
2010-01-25 08:36 . 2010-02-23 20:04 431104 ----a-w- c:\windows\system32\RMActivate_ssp_isv.exe
2010-01-25 08:35 . 2010-02-23 20:04 523776 ----a-w- c:\windows\system32\RMActivate_isv.exe
2010-01-23 08:05 . 2010-02-23 20:31 2048 ----a-w- c:\windows\system32\tzres.dll
2010-01-05 18:38 . 2008-10-01 20:26 130834 ----a-w- c:\windows\hpoins18.dat
2009-11-24 09:22 . 2009-11-24 09:22 119808 ----a-w- c:\program files\mozilla firefox\components\GoogleDesktopMozilla.dll
2008-05-27 06:26 . 2008-05-27 06:26 76 --sh--r- c:\windows\CT4CET.bin
2008-05-27 13:54 . 2008-05-27 13:41 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2009-07-26 3883856]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-05-27 68856]
"ehTray.exe"="c:\windows\ehome\ehTray.exe" [2006-11-02 125440]
"Weather"="c:\program files\AWS\WeatherBug\Weather.exe" [2006-04-07 1343488]
"Aim6"="c:\program files\AIM6\aim6.exe" [2009-05-19 49968]
"Messenger (Yahoo!)"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2008-11-06 4347120]
"ccleaner"="c:\program files\CCleaner\ccleaner.exe" [2008-06-25 1209584]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-05-27 1006264]
"ECenter"="c:\dell\E-Center\EULALauncher.exe" [2008-02-29 17920]
"Apoint"="c:\program files\DellTPad\Apoint.exe" [2007-09-24 159744]
"OEM02Mon.exe"="c:\windows\OEM02Mon.exe" [2007-12-03 36864]
"SigmatelSysTrayApp"="c:\program files\SigmaTel\C-Major Audio\WDM\sttray.exe" [2008-01-02 405504]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2008-03-28 141848]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2008-03-28 166424]
"Persistence"="c:\windows\system32\igfxpers.exe" [2008-03-28 133656]
"DELL Webcam Manager"="c:\program files\Dell\Dell Webcam Manager\DellWMgr.exe" [2007-07-27 118784]
"Broadcom Wireless Manager UI"="c:\windows\system32\WLTRAY.exe" [2007-12-12 3444736]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2009-11-24 30192]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2007-11-02 582992]
"dscactivate"="c:\program files\Dell Support Center\gs_agent\custom\dsca.exe" [2008-03-11 16384]
"PCMService"="c:\program files\Dell\MediaDirect\PCMService.exe" [2007-12-21 184320]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2010-03-18 2046816]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2006-12-11 49152]
"Adobe Acrobat Speed Launcher"="c:\program files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe" [2009-02-27 38768]
"Acrobat Assistant 8.0"="c:\program files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe" [2009-02-27 640376]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-02-27 35696]
"tbhSystray"="c:\program files\tbh\base\bin\tbhSystray.exe" [2010-03-29 492840]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-08-13 177440]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-11-11 417792]
"iTunesHelper"="c:\program files\iTunes12\iTunesHelper.exe" [2009-11-12 141600]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce]
"GrpConv"="grpconv -o" [X]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2008-5-27 50688]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2007-1-2 210520]
QuickSet.lnk - c:\program files\Dell\QuickSet\quickset.exe [2007-7-20 1180952]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\GoToAssist]
2008-05-27 06:39 10536 ----a-w- c:\program files\Citrix\GoToAssist\514\g2awinlogon.dll
"AppInit_DLLs"=AVGRSSTX.DLL c:\progra~1\GOOGLE\GOOGLE~2\GOEC62~1.DLL
"mixer2"=wdmaud.drv
@="Driver"
R1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\System32\Drivers\avgldx86.sys [2009-08-20 335240]
R1 AvgTdiX;AVG8 Network Redirector;c:\windows\System32\Drivers\avgtdix.sys [2009-05-11 108552]
R2 AESTFilters;Andrea ST Filters Service;c:\windows\system32\aestsrv.exe [2008-01-02 73728]
R2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [2009-08-20 908056]
R2 avg8wd;AVG8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [2009-08-20 297752]
R2 gupdate;Google Update Service (gupdate);c:\program files\Google\Update\GoogleUpdate.exe [2010-03-19 135664]
R2 tbhMonitor.exe;The Browser Highlighter Monitor;c:\program files\tbh\monitor\bin\tbhMonitor.exe [2009-10-22 70952]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [2007-01-04 24652]
R3 GoogleDesktopManager-110309-193829;Google Desktop Manager 5.9.911.3589;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [2009-11-24 30192]
*NewlyCreated* - ECACHE
bthsvcs REG_MULTI_SZ BthServ
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
2010-03-29 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2010-03-19 18:08]
2010-03-29 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2010-03-15 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2008-05-27 18:32]
2010-03-01 c:\windows\Tasks\McQcTask.job
IE: &AIM Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
IE: Append Link Target to Existing PDF - c:\program files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
IE: Append to Existing PDF - c:\program files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert Link Target to Adobe PDF - c:\program files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
IE: Convert to Adobe PDF - c:\program files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECapture.html
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_96D6FF0C6D236BF8.dll/cmsidewiki.html
IE: Send image to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
IE: Send page to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
FF - ProfilePath - c:\users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\
FF - prefs.js: browser.search.selectedEngine - Google
FF - component: c:\program files\Mozilla Firefox\components\GoogleDesktopMozilla.dll
FF - component: c:\users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{9ee802e8-c931-47ab-b570-aa8f791598ca}\components\FFAlert.dll
FF - component: c:\users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\browserhighlighter@ebay.com\components\Shim.dll
FF - plugin: c:\program files\Google\Update\1.2.183.23\npGoogleOneClick8.dll
FF - plugin: c:\program files\iTunes12\Mozilla Plugins\npitunes.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava11.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava12.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava13.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava14.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjava32.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npjpi160.dll
FF - plugin: c:\program files\Java\jre1.6.0\bin\npoji610.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\Viewpoint\Viewpoint Media Player\npViewpoint.dll
FF - plugin: c:\users\ian\AppData\Roaming\Facebook\npfbplugin_1_0_3.dll
FF - plugin: c:\users\ian\Desktop\eMusic\eMusic Download Manager\plugin\npemusic.dll
HKCU-Run-ioywigny - c:\users\ian\AppData\Local\krcdbp\bgelsftav.exe
HKLM-RunOnce- - (no file)
Rootkit scan 2010-03-29 19:58
Windows 6.0.6000 NTFS
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
Completion time: 2010-03-29 19:59:57
ComboFix-quarantined-files.txt 2010-03-29 23:59
Pre-Run: 75,815,706,624 bytes free
Post-Run: 75,700,334,592 bytes free
- - End Of File - - 05F467E76616941C923574F85AFBDA77
ianmc
Posts Posts : 16
Post by Dr Jay on 30th March 2010, 1:56 am
Download [You must be registered and logged in to see this link.] to your Desktop
    %systemroot%\*. /mp /s
    %SYSTEMDRIVE%\*.*
    %PROGRAMFILES%\*.
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    ahcix86.sys
    KR10N.sys
    nvstor32.sys
    ahcix86s.sys
    nvrd32.sys
    symmpi.sys
    adp3132.sys
    mv61xx.sys
    /md5stop
    CREATERESTOREPOINT
Posts Posts : 13810
OTL.Txt PART 1
Post by ianmc on 30th March 2010, 3:30 am
OTL logfile created on: 3/29/2010 10:34:56 PM - Run 1
OTL by OldTimer - Version 3.1.37.3 Folder = C:\Users\ian\Desktop
Windows Vista Home Premium Edition (Version = 6.0.6000) - Type = NTWorkstation
Internet Explorer (Version = 7.0.6000.16982)
3.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 47.00% Memory free
6.00 Gb Paging File | 4.00 Gb Available in Paging File | 72.00% Paging File free
Drive C: | 285.50 Gb Total Space | 67.38 Gb Free Space | 23.60% Space Free | Partition Type: NTFS
Drive D: | 10.00 Gb Total Space | 5.60 Gb Free Space | 55.98% Space Free | Partition Type: NTFS
Computer Name: IAN-PC
Current User Name: ian
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/03/29 22:34:17 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Users\ian\Desktop\OTL.exe
PRC - [2010/03/29 20:26:42 | 000,492,840 | ---- | M] (eBay) -- C:\Program Files\tbh\base\bin\tbhSystray.exe
PRC - [2010/03/29 20:26:42 | 000,062,760 | ---- | M] () -- c:\Program Files\tbh\base\bin\tbhDaemon.exe
PRC - [2010/03/18 12:44:55 | 002,046,816 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgtray.exe
PRC - [2010/01/01 06:05:00 | 000,761,600 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgscanx.exe
PRC - [2009/11/24 05:22:26 | 000,030,192 | ---- | M] (Google) -- C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe
PRC - [2009/11/12 17:33:10 | 000,141,600 | ---- | M] (Apple Inc.) -- C:\Program Files\iTunes12\iTunesHelper.exe
PRC - [2009/10/22 14:57:44 | 000,070,952 | ---- | M] () -- C:\Program Files\tbh\monitor\bin\tbhMonitor.exe
PRC - [2009/09/30 20:58:42 | 000,026,464 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Windows Live\Contacts\wlcomm.exe
PRC - [2009/08/20 09:40:05 | 000,486,680 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgrsx.exe
PRC - [2009/08/20 09:40:03 | 000,693,016 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgcsrvx.exe
PRC - [2009/08/20 09:39:52 | 000,595,736 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgnsx.exe
PRC - [2009/08/20 09:39:46 | 000,908,056 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgemc.exe
PRC - [2009/08/20 09:39:29 | 000,297,752 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG8\avgwdsvc.exe
PRC - [2009/02/27 12:14:26 | 000,640,376 | ---- | M] (Adobe Systems Inc.) -- C:\Program Files\Adobe\Acrobat 9.0\Acrobat\acrotray.exe
PRC - [2008/10/29 02:20:29 | 002,923,520 | ---- | M] (Microsoft Corporation) -- C:\Windows\explorer.exe
PRC - [2008/05/27 02:30:09 | 000,068,856 | ---- | M] (Google Inc.) -- C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
PRC - [2008/01/25 02:38:12 | 002,458,128 | ---- | M] (McAfee, Inc.) -- c:\Program Files\Common Files\McAfee\MNA\McNASvc.exe
PRC - [2008/01/09 17:50:22 | 000,767,976 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\MSC\mcmscsvc.exe
PRC - [2008/01/02 00:37:16 | 000,405,504 | ---- | M] (IDT, Inc.) -- C:\Program Files\Sigmatel\C-Major Audio\WDM\sttray.exe
PRC - [2008/01/02 00:37:08 | 000,102,400 | ---- | M] (IDT, Inc.) -- C:\Windows\System32\stacsv.exe
PRC - [2008/01/02 00:37:02 | 000,073,728 | ---- | M] (Andrea Electronics Corporation) -- C:\Windows\System32\AEstSrv.exe
PRC - [2007/12/21 11:58:06 | 000,184,320 | ---- | M] (CyberLink Corp.) -- C:\Program Files\Dell\MediaDirect\PCMService.exe
PRC - [2007/12/11 13:33:42 | 000,358,224 | ---- | M] (McAfee, Inc.) -- c:\Program Files\Common Files\McAfee\McProxy\McProxy.exe
PRC - [2007/12/05 11:04:10 | 000,695,624 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\VirusScan\mcsysmon.exe
PRC - [2007/12/03 01:58:54 | 000,036,864 | ---- | M] (Creative Technology Ltd.) -- C:\Windows\OEM02Mon.exe
PRC - [2007/11/26 11:46:14 | 000,023,880 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\MSK\msksrver.exe
PRC - [2007/11/01 20:12:38 | 000,582,992 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\Agent\mcagent.exe
PRC - [2007/11/01 20:12:38 | 000,265,040 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee\MSC\mcuimgr.exe
PRC - [2007/09/24 05:27:38 | 000,040,960 | ---- | M] (Alps Electric Co., Ltd.) -- C:\Program Files\DellTPad\hidfind.exe
PRC - [2007/09/24 05:27:30 | 000,159,744 | ---- | M] (Alps Electric Co., Ltd.) -- C:\Program Files\DellTPad\Apoint.exe
PRC - [2007/09/24 05:27:28 | 000,050,736 | ---- | M] (Alps Electric Co., Ltd.) -- C:\Program Files\DellTPad\ApMsgFwd.exe
PRC - [2007/09/24 05:27:28 | 000,049,152 | ---- | M] (Alps Electric Co., Ltd.) -- C:\Program Files\DellTPad\ApntEx.exe
PRC - [2007/07/24 13:02:14 | 000,144,704 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\VirusScan\Mcshield.exe
PRC - [2007/07/20 19:13:26 | 001,180,952 | ---- | M] (Dell Inc.) -- C:\Program Files\Dell\QuickSet\quickset.exe
PRC - [2007/07/18 16:54:42 | 000,856,864 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\MPF\MpfSrv.exe
PRC - [2007/01/04 17:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) -- C:\Program Files\Viewpoint\Common\ViewpointService.exe
PRC - [2006/11/03 19:02:14 | 000,050,688 | ---- | M] (Avanquest Software ) -- C:\Program Files\Digital Line Detect\DLG.exe
PRC - [2006/04/07 15:02:24 | 001,343,488 | ---- | M] (AWS Convergence Technologies, Inc.) -- C:\Program Files\AWS\WeatherBug\Weather.exe
MOD - [2010/03/29 22:34:17 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Users\ian\Desktop\OTL.exe
MOD - [2006/11/02 05:38:57 | 001,648,128 | ---- | M] (Microsoft Corporation) -- C:\Windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6000.16386_none_5d07289e07e1d100\comctl32.dll
SRV - [2009/11/24 05:22:26 | 000,030,192 | ---- | M] (Google) [On_Demand | Stopped] -- C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe -- (GoogleDesktopManager-110309-193829)
SRV - [2009/10/22 14:57:44 | 000,070,952 | ---- | M] () [Auto | Running] -- C:\Program Files\tbh\monitor\bin\tbhMonitor.exe -- (tbhMonitor.exe)
SRV - [2009/08/20 09:39:46 | 000,908,056 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG8\avgemc.exe -- (avg8emc)
SRV - [2009/08/20 09:39:29 | 000,297,752 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG8\avgwdsvc.exe -- (avg8wd)
SRV - [2009/04/01 13:02:56 | 000,651,720 | ---- | M] (Macrovision Europe Ltd.) [On_Demand | Stopped] -- C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe -- (FLEXnet Licensing Service)
SRV - [2008/05/27 09:47:41 | 000,265,912 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
SRV - [2008/05/27 02:39:19 | 000,016,680 | ---- | M] (Citrix Online, a division of Citrix Systems, Inc.) [On_Demand | Stopped] -- C:\Program Files\Citrix\GoToAssist\514\g2aservice.exe -- (GoToAssist)
SRV - [2008/01/25 02:38:12 | 002,458,128 | ---- | M] (McAfee, Inc.) [Auto | Running] -- c:\Program Files\Common Files\McAfee\MNA\McNASvc.exe -- (McNASvc)
SRV - [2008/01/09 17:50:22 | 000,767,976 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\MSC\mcmscsvc.exe -- (mcmscsvc)
SRV - [2008/01/02 00:37:08 | 000,102,400 | ---- | M] (IDT, Inc.) [Auto | Running] -- C:\Windows\System32\stacsv.exe -- (STacSV)
SRV - [2008/01/02 00:37:02 | 000,073,728 | ---- | M] (Andrea Electronics Corporation) [Auto | Running] -- C:\Windows\System32\AEstSrv.exe -- (AESTFilters)
SRV - [2007/12/11 13:33:42 | 000,358,224 | ---- | M] (McAfee, Inc.) [Auto | Running] -- c:\Program Files\Common Files\McAfee\McProxy\McProxy.exe -- (McProxy)
SRV - [2007/12/05 11:04:10 | 000,695,624 | ---- | M] (McAfee, Inc.) [On_Demand | Running] -- C:\Program Files\McAfee\VirusScan\mcsysmon.exe -- (McSysmon)
SRV - [2007/11/26 11:46:14 | 000,023,880 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\MSK\MskSrver.exe -- (MSK80Service)
SRV - [2007/11/07 10:35:40 | 000,378,184 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (McODS)
SRV - [2007/07/24 13:02:14 | 000,144,704 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\Program Files\McAfee\VirusScan\Mcshield.exe -- (McShield)
SRV - [2007/07/18 16:54:42 | 000,856,864 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\MPF\MPFSrv.exe -- (MpfService)
SRV - [2007/01/04 17:38:08 | 000,024,652 | ---- | M] (Viewpoint Corporation) [Auto | Running] -- C:\Program Files\Viewpoint\Common\ViewpointService.exe -- (Viewpoint Manager Service)
DRV - [2009/08/20 09:40:04 | 000,027,784 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\Windows\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2009/08/20 09:40:03 | 000,335,240 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\Windows\System32\Drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2009/05/11 08:37:31 | 000,108,552 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\Windows\System32\Drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2008/05/27 09:54:23 | 000,020,024 | ---- | M] (VIA Technologies, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\viaide.sys -- (viaide)
DRV - [2008/05/27 09:54:23 | 000,019,000 | ---- | M] (CMD Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\cmdide.sys -- (cmdide)
DRV - [2008/05/27 09:54:23 | 000,017,464 | ---- | M] (Acer Laboratories Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\aliide.sys -- (aliide)
DRV - [2008/03/28 04:53:30 | 002,016,256 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\igdkmd32.sys -- (igfx)
DRV - [2008/01/02 00:37:18 | 000,330,240 | ---- | M] (IDT, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\stwrt.sys -- (STHDA)
DRV - [2007/12/12 02:02:00 | 001,044,984 | ---- | M] (Broadcom Corp.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\BCMWL6.SYS -- (BCM43XX)
DRV - [2007/12/03 01:59:06 | 000,007,424 | ---- | M] (EyePower Games Pte. Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\OEM02Vfx.sys -- (OEM02Vfx)
DRV - [2007/12/03 01:58:50 | 000,235,648 | ---- | M] (Creative Technology Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\OEM02Dev.sys -- (OEM02Dev)
DRV - [2007/12/02 13:51:42 | 000,040,488 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\mfesmfk.sys -- (mfesmfk)
DRV - [2007/11/22 07:44:08 | 000,201,320 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\Windows\System32\drivers\mfehidk.sys -- (mfehidk)
DRV - [2007/11/22 07:44:08 | 000,079,304 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\mfeavfk.sys -- (mfeavfk)
DRV - [2007/11/22 07:44:08 | 000,035,240 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\mfebopk.sys -- (mfebopk)
DRV - [2007/11/22 07:44:04 | 000,033,832 | ---- | M] (McAfee, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\mferkdk.sys -- (mferkdk)
DRV - [2007/09/24 05:27:26 | 000,155,136 | ---- | M] (Alps Electric Co., Ltd.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\Apfiltr.sys -- (ApfiltrService)
DRV - [2007/07/13 07:21:12 | 000,125,728 | ---- | M] (McAfee, Inc.) [Kernel | System | Running] -- C:\Windows\System32\drivers\Mpfp.sys -- (MPFP)
DRV - [2007/02/12 17:36:54 | 000,277,784 | ---- | M] (Intel Corporation) [Kernel | Boot | Running] -- C:\Windows\system32\drivers\iastor.sys -- (iaStor)
DRV - [2006/11/27 03:48:46 | 000,037,376 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\rixdptsk.sys -- (rismxdp)
DRV - [2006/11/27 03:48:44 | 000,043,520 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\rimsptsk.sys -- (rimsptsk)
DRV - [2006/11/27 03:48:44 | 000,032,256 | ---- | M] (REDC) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\rimmptsk.sys -- (rimmptsk)
DRV - [2006/11/21 08:25:44 | 000,045,568 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\bcm4sbxp.sys -- (bcm4sbxp)
DRV - [2006/11/06 21:37:16 | 000,078,128 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\btwaudio.sys -- (btwaudio)
DRV - [2006/11/06 19:13:52 | 000,016,560 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\btwrchid.sys -- (btwrchid)
DRV - [2006/11/06 19:13:50 | 000,080,176 | ---- | M] (Broadcom Corporation.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\btwavdt.sys -- (btwavdt)
DRV - [2006/11/02 22:43:30 | 000,986,624 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSX_DPV.sys -- (HSF_DPV)
DRV - [2006/11/02 22:42:18 | 000,206,848 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSXHWAZL.sys -- (HSXHWAZL)
DRV - [2006/11/02 22:42:08 | 000,659,968 | ---- | M] (Conexant Systems, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\System32\drivers\HSX_CNXT.sys -- (winachsf)
DRV - [2006/11/02 05:51:45 | 000,900,712 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ql2300.sys -- (ql2300)
DRV - [2006/11/02 05:51:38 | 000,420,968 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adp94xx.sys -- (adp94xx)
DRV - [2006/11/02 05:51:34 | 000,316,520 | ---- | M] (Emulex) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\elxstor.sys -- (elxstor)
DRV - [2006/11/02 05:51:32 | 000,297,576 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpahci.sys -- (adpahci)
DRV - [2006/11/02 05:51:25 | 000,235,112 | ---- | M] (ULi Electronics Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\uliahci.sys -- (uliahci)
DRV - [2006/11/02 05:51:25 | 000,232,040 | ---- | M] (Intel Corporation) [Kernel | Boot | Running] -- C:\Windows\system32\drivers\iastorv.sys -- (iaStorV)
DRV - [2006/11/02 05:51:00 | 000,147,048 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpu320.sys -- (adpu320)
DRV - [2006/11/02 05:50:45 | 000,115,816 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ulsata2.sys -- (ulsata2)
DRV - [2006/11/02 05:50:41 | 000,112,232 | ---- | M] (VIA Technologies Inc.,Ltd) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\vsmraid.sys -- (vsmraid)
DRV - [2006/11/02 05:50:35 | 000,106,088 | ---- | M] (QLogic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ql40xx.sys -- (ql40xx)
DRV - [2006/11/02 05:50:35 | 000,098,408 | ---- | M] (Promise Technology, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ulsata.sys -- (UlSata)
DRV - [2006/11/02 05:50:35 | 000,098,408 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\adpu160m.sys -- (adpu160m)
DRV - [2006/11/02 05:50:24 | 000,088,680 | ---- | M] (NVIDIA Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nvraid.sys -- (nvraid)
DRV - [2006/11/02 05:50:19 | 000,045,160 | ---- | M] (IBM Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nfrd960.sys -- (nfrd960)
DRV - [2006/11/02 05:50:17 | 000,041,576 | ---- | M] (Intel Corp./ICP vortex GmbH) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iirsp.sys -- (iirsp)
DRV - [2006/11/02 05:50:16 | 000,071,784 | ---- | M] (Silicon Integrated Systems) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sisraid4.sys -- (SiSRaid4)
DRV - [2006/11/02 05:50:13 | 000,040,040 | ---- | M] (NVIDIA Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\nvstor.sys -- (nvstor)
DRV - [2006/11/02 05:50:11 | 000,071,272 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\djsvs.sys -- (aic78xx)
DRV - [2006/11/02 05:50:10 | 000,067,688 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\arcsas.sys -- (arcsas)
DRV - [2006/11/02 05:50:10 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_scsi.sys -- (LSI_SCSI)
DRV - [2006/11/02 05:50:10 | 000,038,504 | ---- | M] (Silicon Integrated Systems Corp.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sisraid2.sys -- (SiSRaid2)
DRV - [2006/11/02 05:50:10 | 000,037,480 | ---- | M] (Hewlett-Packard Company) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\hpcisss.sys -- (HpCISSs)
DRV - [2006/11/02 05:50:09 | 000,067,688 | ---- | M] (Adaptec, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\arc.sys -- (arc)
DRV - [2006/11/02 05:50:09 | 000,035,944 | ---- | M] (Integrated Technology Express, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iteraid.sys -- (iteraid)
DRV - [2006/11/02 05:50:07 | 000,035,944 | ---- | M] (Integrated Technology Express, Inc.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\iteatapi.sys -- (iteatapi)
DRV - [2006/11/02 05:50:05 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_sas.sys -- (LSI_SAS)
DRV - [2006/11/02 05:50:05 | 000,035,944 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\symc8xx.sys -- (Symc8xx)
DRV - [2006/11/02 05:50:04 | 000,065,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\lsi_fc.sys -- (LSI_FC)
DRV - [2006/11/02 05:50:03 | 000,034,920 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sym_u3.sys -- (Sym_u3)
DRV - [2006/11/02 05:49:59 | 000,033,384 | ---- | M] (LSI Logic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\mraid35x.sys -- (Mraid35x)
DRV - [2006/11/02 05:49:56 | 000,031,848 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\sym_hi.sys -- (Sym_hi)
DRV - [2006/11/02 05:49:53 | 000,028,776 | ---- | M] (LSI Logic Corporation) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\megasas.sys -- (megasas)
DRV - [2006/11/02 04:25:24 | 000,071,808 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brserid.sys -- (Brserid) Brother MFC Serial Port Interface Driver (WDM)
DRV - [2006/11/02 04:24:47 | 000,011,904 | ---- | M] (Brother Industries Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brusbser.sys -- (BrUsbSer)
DRV - [2006/11/02 04:24:46 | 000,005,248 | ---- | M] (Brother Industries, Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brfiltup.sys -- (BrFiltUp)
DRV - [2006/11/02 04:24:45 | 000,013,568 | ---- | M] (Brother Industries, Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\system32\drivers\brfiltlo.sys -- (BrFiltLo)
DRV - [2006/11/02 04:24:44 | 000,062,336 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brserwdm.sys -- (BrSerWdm)
DRV - [2006/11/02 04:24:44 | 000,012,160 | ---- | M] (Brother Industries Ltd.) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\brusbmdm.sys -- (BrUsbMdm)
DRV - [2006/11/02 03:36:50 | 000,020,608 | ---- | M] (N-trig Innovative Technologies) [Kernel | Disabled | Stopped] -- C:\Windows\system32\drivers\ntrigdigi.sys -- (ntrigdigi)
DRV - [2006/11/02 03:36:43 | 002,028,032 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\atikmdag.sys -- (R300)
DRV - [2006/11/02 03:30:55 | 000,200,704 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\e1e6032.sys -- (e1express) Intel(R)
DRV - [2006/11/02 03:30:54 | 000,117,760 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\drivers\E1G60I32.sys -- (E1G60) Intel(R)
DRV - [2006/08/04 20:39:10 | 000,008,192 | ---- | M] (Conexant Systems, Inc.) [Kernel | Auto | Running] -- C:\Windows\System32\drivers\XAudio.sys -- (XAudio)
DRV - [2005/07/17 23:20:16 | 000,366,736 | ---- | M] (Zone Labs, LLC) [Kernel | On_Demand | Stopped] -- C:\Windows\System32\vsdatant.sys -- (vsdatant)
IE - HKLM\..\URLSearchHook: {EA756889-2338-43DB-8F07-D1CA6FB9C90D} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,StartPageCache = 1
IE - HKCU\..\URLSearchHook: {EA756889-2338-43DB-8F07-D1CA6FB9C90D} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = http=127.0.0.1:5555
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "AOL Search"
FF - prefs.js..browser.search.defaulturl: "http://search.aol.com/aolcom/search?invocationType=tb50-ff-aol-chromesbox-en-us&query="
FF - prefs.js..browser.search.selectedEngine: "Google"
FF - prefs.js..browser.startup.homepage: "[You must be registered and logged in to see this link.]
FF - prefs.js..extensions.enabledItems: {7affbfae-c4e2-4915-8c0f-00fa3ec610a1}:5.74.1.1
FF - prefs.js..extensions.enabledItems: {9ee802e8-c931-47ab-b570-aa8f791598ca}:1.5.46.0
FF - prefs.js..extensions.enabledItems: {AE93811A-5C9A-4d34-8462-F7B864FC4696}:3.63
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:1.0.17641
FF - prefs.js..extensions.enabledItems: {635abd67-4fe9-1b23-4f01-e679fa7484c1}:1.6.5.200812101546
FF - prefs.js..keyword.URL: "http://search.aol.com/aolcom/search?invocationType=tb50-ff-aol-ab-en-us&query="
FF - HKLM\software\mozilla\eMusic Download Manager\Extensions\\Components: C:\Users\ian\Desktop\eMusic\eMusic Download Manager\xulrunner\components [2009/12/16 01:31:05 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\eMusic Download Manager\Extensions\\Plugins: C:\Users\ian\Desktop\eMusic\eMusic Download Manager\xulrunner\plugins [2009/12/16 01:31:04 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/02/21 22:47:14 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/02/21 22:47:14 | 000,000,000 | ---D | M]
[2009/12/14 02:32:15 | 000,000,000 | ---D | M] -- C:\Users\ian\AppData\Roaming\Mozilla\Extensions
[2009/12/02 13:14:02 | 000,000,000 | ---D | M] -- C:\Users\ian\AppData\Roaming\Mozilla\Extensions\mozswing@mozswing.org
[2010/03/29 20:37:37 | 000,000,000 | ---D | M] -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions
[2009/09/09 10:09:38 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2009/09/12 13:31:33 | 000,000,000 | ---D | M] (Yahoo! Toolbar) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2009/09/12 13:31:32 | 000,000,000 | ---D | M] (No name found) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{7affbfae-c4e2-4915-8c0f-00fa3ec610a1}
[2008/10/22 19:48:02 | 000,000,000 | ---D | M] (eMusic Toolbar) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{9ee802e8-c931-47ab-b570-aa8f791598ca}
[2010/02/14 18:02:41 | 000,000,000 | ---D | M] (No name found) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{AE93811A-5C9A-4d34-8462-F7B864FC4696}
[2008/07/06 02:21:42 | 000,000,000 | ---D | M] (No name found) -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\{AE93811A-5C9A-4d34-8462-F7B864FC4696}(65)
[2010/03/29 21:10:55 | 000,000,000 | ---D | M] -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\extensions\browserhighlighter@ebay.com
[2008/08/18 20:57:18 | 000,001,901 | ---- | M] () -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\searchplugins\aimsearch.xml
[2009/09/12 13:31:35 | 000,001,736 | ---- | M] () -- C:\Users\ian\AppData\Roaming\Mozilla\Firefox\Profiles\ihla3ipy.default\searchplugins\aol-search.xml
[2009/12/14 02:24:41 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2007/04/16 13:07:12 | 000,180,293 | ---- | M] () -- C:\Program Files\Mozilla Firefox\plugins\npViewpoint.dll
O1 HOSTS File: ([2006/09/18 17:41:30 | 000,000,761 | ---- | M]) - C:\Windows\System32\drivers\etc\hosts
O1 - Hosts: ::1 localhost
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
O2 - BHO: (Skype add-on (mastermind)) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O2 - BHO: (McAfee Phishing Filter) - {377C180E-6F0E-4D4C-980F-F45BD3D40CF4} - c:\Program Files\McAfee\MSK\mcapbho.dll ()
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG8\avgssie.dll (AVG Technologies CZ, s.r.o.)
O2 - BHO: (SSVHelper Class) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (AOL Toolbar Launcher) - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
O2 - BHO: (scriptproxy) - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll (McAfee, Inc.)
O2 - BHO: (Google Toolbar Helper) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll (Google Inc.)
O2 - BHO: (Adobe PDF Conversion Toolbar Helper) - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O2 - BHO: (Google Toolbar Notifier BHO) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.4723.1820\swg.dll (Google Inc.)
O2 - BHO: (CBrowserHelperObject Object) - {CA6319C0-31B7-401E-A518-A07C3DB8F777} - C:\Program Files\Dell\BAE\BAE.dll (Dell Inc.)
O2 - BHO: (SmartSelect Class) - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O2 - BHO: (SingleInstance Class) - {FDAD4DA1-61A2-4FD8-9C17-86F7AC245081} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\YTSingleInstance.dll (Yahoo! Inc)
O3 - HKLM\..\Toolbar: (no name) - - No CLSID value found.
O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKLM\..\Toolbar: (AIM Toolbar) - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKCU\..\Toolbar\WebBrowser: (AIM Toolbar) - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
O4 - HKLM..\Run: [Acrobat Assistant 8.0] C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe (Adobe Systems Inc.)
O4 - HKLM..\Run: [Adobe Acrobat Speed Launcher] C:\Program Files\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [Apoint] C:\Program Files\DellTPad\Apoint.exe (Alps Electric Co., Ltd.)
O4 - HKLM..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe (Apple Inc.)
O4 - HKLM..\Run: [AVG8_TRAY] C:\Program Files\AVG\AVG8\avgtray.exe (AVG Technologies CZ, s.r.o.)
O4 - HKLM..\Run: [DELL Webcam Manager] C:\Program Files\Dell\Dell Webcam Manager\DellWMgr.exe (Creative Technology Ltd.)
O4 - HKLM..\Run: [dscactivate] C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe ( )
O4 - HKLM..\Run: [ECenter] C:\DELL\E-Center\EULALauncher.exe ( )
O4 - HKLM..\Run: [Google Desktop Search] C:\Program Files\Google\Google Desktop Search\GoogleDesktop.exe (Google)
O4 - HKLM..\Run: [iTunesHelper] C:\Program Files\iTunes12\iTunesHelper.exe (Apple Inc.)
O4 - HKLM..\Run: [mcagent_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
O4 - HKLM..\Run: [OEM02Mon.exe] C:\Windows\OEM02Mon.exe (Creative Technology Ltd.)
O4 - HKLM..\Run: [PCMService] C:\Program Files\Dell\MediaDirect\PCMService.exe (CyberLink Corp.)
O4 - HKLM..\Run: [SigmatelSysTrayApp] C:\Program Files\Sigmatel\C-Major Audio\WDM\sttray.exe (IDT, Inc.)
O4 - HKLM..\Run: [tbhSystray] C:\Program Files\tbh\base\bin\tbhSystray.exe (eBay)
O4 - HKCU..\Run: [Aim6] C:\Program Files\AIM6\aim6.exe (AOL LLC)
O4 - HKCU..\Run: [ccleaner] C:\Program Files\CCleaner\ccleaner.exe (Piriform Ltd)
O4 - HKCU..\Run: [Messenger (Yahoo!)] C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe (Yahoo! Inc.)
O4 - HKCU..\Run: [Weather] C:\Program Files\AWS\WeatherBug\Weather.exe (AWS Convergence Technologies, Inc.)
O8 - Extra context menu item: &AIM Search - c:\Program Files\AOL\AIM Toolbar 5.0\resources\en-us\local\search.html ()
O8 - Extra context menu item: Append Link Target to Existing PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Append to Existing PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert Link Target to Adobe PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Google Sidewiki... - C:\Program Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_96D6FF0C6D236BF8.dll (Google Inc.)
O8 - Extra context menu item: Send image to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm ()
O8 - Extra context menu item: Send page to &Bluetooth Device... - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
O9 - Extra 'Tools' menuitem : Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll (Sun Microsystems, Inc.)
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: AIM Toolbar - {3369AF0D-62E9-4bda-8103-B4C75499B578} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll (AOL LLC)
O9 - Extra 'Tools' menuitem : Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O9 - Extra Button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll (Skype Technologies S.A.)
O9 - Extra Button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
O9 - Extra 'Tools' menuitem : @btrez.dll,-12650 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm ()
O10 - NameSpace_Catalog5\Catalog_Entries\000000000008 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
O12 - Plugin for: .spop - C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll (Intertrust Technologies, Inc.)
O15 - HKCU\..Trusted Domains: localhost ([]http in Local intranet)
O15 - HKCU\..Trusted Ranges: GD ([http] in Local intranet)
O16 - DPF: {10093E98-C073-4C75-8D0E-FB5CD3A71D33} [You must be registered and logged in to see this link.] (ZoneUpwords Object)
O16 - DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} [You must be registered and logged in to see this link.] (Checkers Class)
O16 - DPF: {4A85DBE0-BFB2-4119-8401-186A7C6EB653} [You must be registered and logged in to see this link.] ()
O16 - DPF: {5D6F45B3-9043-443D-A792-115447494D24} [You must be registered and logged in to see this link.] (UnoCtrl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0)
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} [You must be registered and logged in to see this link.] (MSN Games - Installer)
O16 - DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} [You must be registered and logged in to see this link.] (MessengerStatsClient Class)
O16 - DPF: {CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0)
O16 - DPF: {DA758BB1-5F89-4465-975F-8D7179A4BCF3} [You must be registered and logged in to see this link.] (WheelofFortune Object)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.2.1 68.87.77.134 68.87.72.134
O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll (AVG Technologies CZ, s.r.o.)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\microsoft shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files\Common Files\Skype\Skype4COM.dll (Skype Technologies)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\microsoft shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20 - AppInit_DLLs: (AVGRSSTX.DLL) - C:\Windows\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
O20 - AppInit_DLLs: (C:\PROGRA~1\GOOGLE\GOOGLE~2\GOEC62~1.DLL) - C:\Program Files\Google\Google Desktop Search\GoogleDesktopNetwork3.dll (Google)
O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
O20 - Winlogon\Notify\GoToAssist: DllName - C:\Program Files\Citrix\GoToAssist\514\G2AWinLogon.dll - C:\Program Files\Citrix\GoToAssist\514\g2awinlogon.dll (Citrix Online, a division of Citrix Systems, Inc.)
O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\Windows\System32\igfxdev.dll (Intel Corporation)
O24 - Desktop WallPaper: C:\Users\ian\Pictures\01407_harboursunset_1600x1200.jpg
O24 - Desktop BackupWallPaper: C:\Users\ian\Pictures\01407_harboursunset_1600x1200.jpg
O28 - HKLM ShellExecuteHooks: {AEB6717E-7E19-11d0-97EE-00C04FD91972} - Reg Error: Key error. File not found
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2006/09/18 17:43:36 | 000,000,024 | ---- | M] () - C:\autoexec.bat -- [ NTFS ]
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
NetSvcs: FastUserSwitchingCompatibility - File not found
NetSvcs: Ias - C:\Windows\System32\ias [2006/11/02 07:18:47 | 000,000,000 | ---D | M]
NetSvcs: Nla - File not found
NetSvcs: Ntmssvc - File not found
NetSvcs: SRService - File not found
NetSvcs: Wmi - C:\Windows\System32\wmi.dll (Microsoft Corporation)
NetSvcs: LogonHours - File not found
NetSvcs: PCAudit - File not found
NetSvcs: helpsvc - File not found
NetSvcs: uploadmgr - File not found
SafeBootMin: HelpSvc - Service
SafeBootMin: mcmscsvc - C:\Program Files\McAfee\MSC\mcmscsvc.exe (McAfee, Inc.)
SafeBootMin: MCODS - C:\Program Files\McAfee\VirusScan\mcods.exe (McAfee, Inc.)
SafeBootMin: NTDS - File not found
SafeBootMin: sacsvr - Service
SafeBootMin: WinDefend - C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SafeBootMin: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootMin: {6BDD1FC1-810F-11D0-BEC7-08002BE2092F} - IEEE 1394 Bus host controllers
SafeBootMin: {D48179BE-EC20-11D1-B6B8-00C04FA372A7} - SBP2 IEEE 1394 Devices
SafeBootMin: {D94EE5D8-D189-4994-83D2-F68D7D41B0E6} - SecurityDevices
SafeBootNet: GoToAssist - C:\Program Files\Citrix\GoToAssist\514\g2aservice.exe (Citrix Online, a division of Citrix Systems, Inc.)
SafeBootNet: HelpSvc - Service
SafeBootNet: mcmscsvc - C:\Program Files\McAfee\MSC\mcmscsvc.exe (McAfee, Inc.)
SafeBootNet: MCODS - C:\Program Files\McAfee\VirusScan\mcods.exe (McAfee, Inc.)
SafeBootNet: Messenger - Service
SafeBootNet: MpfService - C:\Program Files\McAfee\MPF\MPFSrv.exe (McAfee, Inc.)
SafeBootNet: NTDS - File not found
SafeBootNet: rdsessmgr - Service
SafeBootNet: sacsvr - Service
SafeBootNet: WinDefend - C:\Program Files\Windows Defender\MpSvc.dll (Microsoft Corporation)
SafeBootNet: {50DD5230-BA8A-11D1-BF5D-0000F805F530} - Smart card readers
SafeBootNet: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootNet: {6BDD1FC1-810F-11D0-BEC7-08002BE2092F} - IEEE 1394 Bus host controllers
SafeBootNet: {D48179BE-EC20-11D1-B6B8-00C04FA372A7} - SBP2 IEEE 1394 Devices
SafeBootNet: {D94EE5D8-D189-4994-83D2-F68D7D41B0E6} - SecurityDevices
ActiveX: {03F998B2-0E00-11D3-A498-00104B6EB52E} - Viewpoint Media Player
ActiveX: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} - Java (Sun)
ActiveX: {18D0F386-A1A9-5B8A-BEE0-8F73D7601471} - Microsoft Windows Media Player 11.0
ActiveX: {1B00725B-C455-4DE6-BFB6-AD540AD427CD} - Viewpoint Media Player
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} -
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - Microsoft Windows Media Player 11.0
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Windows Mail\WinMail.exe" OCInstallUserConfigOE
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} -
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows script 5.7
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - Microsoft Windows Media Player
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - Address Book 7
ActiveX: {7C028AF8-F614-47B3-82DA-BA94E41B1089} - .NET Framework
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\Windows\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - C:\Windows\system32\Rundll32.exe C:\Windows\system32\mscories.dll,Install
ActiveX: {D27CDB6E-AE6D-11CF-96B8-444553540000} - Adobe Flash Player
ActiveX: {D650A6DC-7022-E464-E933-346612C5F59D} - Microsoft Windows Media Player
ActiveX: {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - Reg Error: Value error.
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\Windows\system32\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\Windows\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
Drivers32: msacm.ac3acm - C:\Windows\System32\ac3acm.acm (fccHandler)
Drivers32: msacm.l3acm - C:\Windows\System32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.lameacm - C:\Windows\System32\lameACM.acm (http://www.mp3dev.org/)
Drivers32: msacm.siren - C:\Windows\System32\sirenacm.dll (Microsoft Corporation)
Drivers32: MSVideo8 - C:\Windows\System32\vfwwdm32.dll (Microsoft Corporation)
Drivers32: vidc.cvid - C:\Windows\System32\iccvid.dll (Radius Inc.)
Drivers32: VIDC.DIVX - C:\Windows\System32\divx.dll (DivX, Inc.)
Drivers32: VIDC.FFDS - C:\Windows\System32\ff_vfw.dll ()
Drivers32: VIDC.XVID - C:\Windows\System32\xvidvfw.dll ()
Drivers32: VIDC.YV12 - C:\Windows\System32\yv12vfw.dll ([You must be registered and logged in to see this link.]
OTL cannot create restorepoints on Vista OSs!
ianmc
Posts Posts : 16
Joined Joined : 2010-03-29
OS OS : Windows Vista
Points Points : 24676
Re: wuauclt.exe problem
Post by ianmc on 30th March 2010, 3:31 am
OTL.Txt PART 2
[2010/03/29 22:33:10 | 000,555,520 | ---- | C] (OldTimer Tools) -- C:\Users\ian\Desktop\OTL.exe
[2010/03/29 19:59:58 | 000,000,000 | ---D | C] -- C:\Users\ian\AppData\Local\temp
[2010/03/29 19:59:34 | 000,000,000 | -HSD | C] -- C:\$RECYCLE.BIN
[2010/03/29 19:49:33 | 000,212,480 | ---- | C] (SteelWerX) -- C:\Windows\SWXCACLS.exe
[2010/03/29 19:49:33 | 000,161,792 | ---- | C] (SteelWerX) -- C:\Windows\SWREG.exe
[2010/03/29 19:49:33 | 000,136,704 | ---- | C] (SteelWerX) -- C:\Windows\SWSC.exe
[2010/03/29 19:49:33 | 000,031,232 | ---- | C] (NirSoft) -- C:\Windows\NIRCMD.exe
[2010/03/29 19:49:28 | 000,000,000 | ---D | C] -- C:\Windows\ERDNT
[2010/03/29 19:49:28 | 000,000,000 | ---D | C] -- C:\ComboFix
[2010/03/29 19:48:08 | 000,000,000 | ---D | C] -- C:\Qoobox
[2010/03/29 19:47:54 | 000,000,000 | ---D | C] -- C:\32788R22FWJFW
[2010/03/17 14:44:23 | 000,000,000 | ---D | C] -- C:\Users\ian\AppData\Roaming\Facebook
[2010/03/16 15:43:53 | 000,000,000 | ---D | C] -- C:\Users\ian\Desktop\EclipsePhase_QuickStartRules_WorkFiles
[2010/03/12 13:29:17 | 000,000,000 | ---D | C] -- C:\Users\ian\Desktop\Rob Kelly - Best_Of_Bobby_Bars
[2010/03/11 04:01:59 | 000,024,064 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\nshhttp.dll
[2010/03/11 04:01:50 | 000,031,232 | ---- | C] (Microsoft Corporation) -- C:\Windows\System32\httpapi.dll
[2010/03/05 03:53:25 | 000,000,000 | ---D | C] -- C:\Users\ian\Desktop\Sway - The Delivery Mix-Tape
[1 C:\Windows\*.tmp files -> C:\Windows\*.tmp -> ]
[2010/03/29 22:45:02 | 002,621,440 | -HS- | M] () -- C:\Users\ian\ntuser.dat
[2010/03/29 22:31:04 | 000,000,886 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2010/03/29 22:25:48 | 000,003,472 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-1.C7483456-A289-439d-8115-601632D005A0
[2010/03/29 22:25:48 | 000,003,472 | -H-- | M] () -- C:\Windows\System32\7B296FB0-376B-497e-B012-9C450E1B7327-2P-0.C7483456-A289-439d-8115-601632D005A0
[2010/03/29 21:40:31 | 000,027,648 | ---- | M] () -- C:\Users\ian\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/03/29 21:04:19 | 058,222,658 | ---- | M] () -- C:\Windows\System32\drivers\Avg\incavi.avm
[2010/03/29 20:32:45 | 000,716,948 | ---- | M] () -- C:\Windows\System32\PerfStringBackup.INI
[2010/03/29 20:32:45 | 000,618,648 | ---- | M] () -- C:\Windows\System32\perfh009.dat
[2010/03/29 20:32:45 | 000,104,024 | ---- | M] () -- C:\Windows\System32\perfc009.dat
[2010/03/29 20:30:12 | 000,007,378 | ---- | M] () -- C:\Windows\System32\Config.MPF
[2010/03/29 20:26:56 | 000,000,882 | ---- | M] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2010/03/29 20:25:49 | 000,000,006 | -H-- | M] () -- C:\Windows\tasks\SA.DAT
[2010/03/29 20:25:45 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
[2010/03/29 20:25:43 | 3210,784,768 | -HS- | M] () -- C:\hiberfil.sys
[2010/03/29 19:58:34 | 000,000,215 | ---- | M] () -- C:\Windows\system.ini
[2010/03/29 19:45:42 | 000,000,012 | ---- | M] () -- C:\Windows\bthservsdp.dat
[2010/03/29 19:34:00 | 003,905,917 | R--- | M] () -- C:\Users\ian\Desktop\ComboFix.exe
[2010/03/29 19:29:31 | 000,000,205 | ---- | M] () -- C:\Users\ian\Desktop\winlogon.cmd
[2010/03/29 19:16:48 | 000,000,205 | ---- | M] () -- C:\Users\ian\Documents\winlogon.cmd
[2010/03/29 01:22:23 | 000,005,972 | ---- | M] () -- C:\Users\ian\AppData\Local\d3d9caps.dat
[2010/03/28 17:27:32 | 000,032,706 | ---- | M] () -- C:\Users\ian\AppData\Roaming\wklnhst.dat
[2010/03/28 17:27:30 | 000,016,896 | ---- | M] () -- C:\Users\ian\Desktop\Recipe Ideas.wps
[2010/03/25 13:39:29 | 006,245,928 | ---- | M] () -- C:\Users\ian\Desktop\Plan B - 10 Darkest Place.mp3
[2010/03/22 01:59:59 | 000,071,206 | ---- | M] () -- C:\Users\ian\Desktop\batman.jpg
[2010/03/20 23:59:25 | 000,037,337 | ---- | M] () -- C:\Users\ian\Desktop\Me and Maizie.jpg
[2010/03/18 12:44:57 | 006,061,540 | ---- | M] () -- C:\Windows\System32\drivers\Avg\avi7.avg
[2010/03/18 12:44:57 | 000,492,629 | ---- | M] () -- C:\Windows\System32\drivers\Avg\miniavi.avg
[2010/03/18 12:44:57 | 000,142,495 | ---- | M] () -- C:\Windows\System32\drivers\Avg\microavi.avg
[2010/03/15 01:00:00 | 000,000,356 | ---- | M] () -- C:\Windows\tasks\McDefragTask.job
[2010/03/14 18:35:18 | 000,018,944 | ---- | M] () -- C:\Users\ian\Desktop\Michigan and Celtic Restaurant.wps
[2010/03/12 18:02:38 | 000,261,632 | ---- | M] () -- C:\Windows\PEV.exe
[2010/03/09 01:19:20 | 000,060,277 | ---- | M] () -- C:\Users\ian\Desktop\Amanda Teresa Tracy - 1.jpg
[2010/03/09 01:18:10 | 000,054,251 | ---- | M] () -- C:\Users\ian\Desktop\Tracy - 01.jpg
[2010/03/01 21:18:14 | 000,085,884 | ---- | M] () -- C:\Users\ian\Documents\cc_20100301_2018.reg
[2010/03/01 02:00:03 | 000,000,348 | ---- | M] () -- C:\Windows\tasks\McQcTask.job
[2010/03/29 20:25:43 | 3210,784,768 | -HS- | C] () -- C:\hiberfil.sys
[2010/03/29 19:49:33 | 000,261,632 | ---- | C] () -- C:\Windows\PEV.exe
[2010/03/29 19:49:33 | 000,098,816 | ---- | C] () -- C:\Windows\sed.exe
[2010/03/29 19:49:33 | 000,080,412 | ---- | C] () -- C:\Windows\grep.exe
[2010/03/29 19:49:33 | 000,077,312 | ---- | C] () -- C:\Windows\MBR.exe
[2010/03/29 19:49:33 | 000,068,096 | ---- | C] () -- C:\Windows\zip.exe
[2010/03/29 19:33:27 | 003,905,917 | R--- | C] () -- C:\Users\ian\Desktop\ComboFix.exe
[2010/03/29 19:29:31 | 000,000,205 | ---- | C] () -- C:\Users\ian\Desktop\winlogon.cmd
[2010/03/29 19:16:48 | 000,000,205 | ---- | C] () -- C:\Users\ian\Documents\winlogon.cmd
[2010/03/25 13:39:19 | 006,245,928 | ---- | C] () -- C:\Users\ian\Desktop\Plan B - 10 Darkest Place.mp3
[2010/03/22 01:59:36 | 000,071,206 | ---- | C] () -- C:\Users\ian\Desktop\batman.jpg
[2010/03/20 23:59:15 | 000,037,337 | ---- | C] () -- C:\Users\ian\Desktop\Me and Maizie.jpg
[2010/03/19 14:09:33 | 000,000,886 | ---- | C] () -- C:\Windows\tasks\GoogleUpdateTaskMachineUA.job
[2010/03/19 14:09:27 | 000,000,882 | ---- | C] () -- C:\Windows\tasks\GoogleUpdateTaskMachineCore.job
[2010/03/09 01:19:17 | 000,060,277 | ---- | C] () -- C:\Users\ian\Desktop\Amanda Teresa Tracy - 1.jpg
[2010/03/09 01:18:00 | 000,054,251 | ---- | C] () -- C:\Users\ian\Desktop\Tracy - 01.jpg
[2010/03/08 03:12:50 | 000,018,944 | ---- | C] () -- C:\Users\ian\Desktop\Michigan and Celtic Restaurant.wps
[2010/03/01 21:18:07 | 000,085,884 | ---- | C] () -- C:\Users\ian\Documents\cc_20100301_2018.reg
[2009/01/02 22:04:50 | 000,005,972 | ---- | C] () -- C:\Users\ian\AppData\Local\d3d9caps.dat
[2008/10/01 16:27:00 | 000,001,829 | ---- | C] () -- C:\ProgramData\hpzinstall.log
[2008/07/18 22:06:05 | 000,000,056 | -H-- | C] () -- C:\ProgramData\ezsidmv.dat
[2008/06/27 18:05:26 | 000,029,239 | ---- | C] () -- C:\Users\ian\AppData\Roaming\UserTile.png
[2008/06/07 19:32:16 | 000,164,352 | ---- | C] () -- C:\Windows\System32\unrar.dll
[2008/06/07 19:32:09 | 000,755,027 | ---- | C] () -- C:\Windows\System32\xvidcore.dll
[2008/06/07 19:32:09 | 000,159,839 | ---- | C] () -- C:\Windows\System32\xvidvfw.dll
[2008/06/07 19:32:08 | 003,596,288 | ---- | C] () -- C:\Windows\System32\qt-dx331.dll
[2008/06/07 19:32:07 | 000,007,680 | ---- | C] () -- C:\Windows\System32\ff_vfw.dll
[2008/06/07 19:32:07 | 000,000,547 | ---- | C] () -- C:\Windows\System32\ff_vfw.dll.manifest
[2008/06/06 22:44:35 | 000,032,706 | ---- | C] () -- C:\Users\ian\AppData\Roaming\wklnhst.dat
[2008/06/03 20:11:48 | 000,027,648 | ---- | C] () -- C:\Users\ian\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2008/05/27 10:01:00 | 001,953,696 | ---- | C] () -- C:\Windows\System32\igklg400.dll
[2008/05/27 10:01:00 | 001,533,360 | ---- | C] () -- C:\Windows\System32\igklg450.dll
[2008/05/27 10:01:00 | 000,147,456 | ---- | C] () -- C:\Windows\System32\igfxCoIn_v1409.dll
[2008/05/27 10:01:00 | 000,104,636 | ---- | C] () -- C:\Windows\System32\igmedcompkrn.dll
[2008/05/27 10:00:54 | 000,016,480 | ---- | C] () -- C:\Windows\System32\rixdicon.dll
[2008/05/27 02:26:52 | 000,054,784 | ---- | C] () -- C:\Windows\System32\bcmwlrmt.dll
[2006/11/03 18:25:56 | 000,389,120 | ---- | C] () -- C:\Windows\System32\btwhidcs.dll
[2006/11/02 08:35:32 | 000,005,632 | ---- | C] () -- C:\Windows\System32\sysprepMCE.dll
[2006/11/02 06:25:44 | 000,159,744 | ---- | C] () -- C:\Windows\System32\atitmmxx.dll
[2006/11/02 03:40:29 | 000,013,750 | ---- | C] () -- C:\Windows\System32\pacerprf.ini
[2001/11/14 13:56:00 | 001,802,240 | ---- | C] () -- C:\Windows\System32\lcppn21.dll
< %systemroot%\*. /mp /s >
< %systemroot%\system32\*.dll /lockedfiles >
[2007/12/12 02:01:24 | 000,054,784 | ---- | M] () Unable to obtain MD5 -- C:\Windows\System32\bcmwlrmt.dll
[2006/11/02 05:47:18 | 000,228,968 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\Windows\System32\rsaenh.dll
[2008/05/27 09:54:44 | 000,223,232 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\Windows\System32\SLC.dll
< %systemroot%\system32\*.exe /lockedfiles >
[2006/11/02 03:10:37 | 000,053,536 | ---- | M] () Unable to obtain MD5 -- C:\Windows\System32\dosx.exe
[2006/11/02 05:45:32 | 000,120,320 | ---- | M] (Microsoft Corporation) Unable to obtain MD5 -- C:\Windows\System32\perfmon.exe
[2007/12/12 02:02:12 | 003,444,736 | ---- | M] (Dell Inc.) Unable to obtain MD5 -- C:\Windows\System32\WLTRAY.EXE
< %systemroot%\system32\drivers\*.sys /lockedfiles >
< %systemroot%\System32\config\*.sav >
[2006/11/02 06:34:05 | 000,008,192 | ---- | M] () -- C:\Windows\System32\config\COMPONENTS.SAV
[2006/11/02 06:34:05 | 000,020,480 | ---- | M] () -- C:\Windows\System32\config\DEFAULT.SAV
[2006/11/02 06:34:05 | 000,008,192 | ---- | M] () -- C:\Windows\System32\config\SECURITY.SAV
[2006/11/02 06:34:08 | 010,133,504 | ---- | M] () -- C:\Windows\System32\config\SOFTWARE.SAV
[2006/11/02 06:34:08 | 001,826,816 | ---- | M] () -- C:\Windows\System32\config\SYSTEM.SAV
< %SYSTEMDRIVE%\*.* >
[2006/09/18 17:43:36 | 000,000,024 | ---- | M] () -- C:\autoexec.bat
[2006/11/02 05:53:57 | 000,438,840 | RHS- | M] () -- C:\bootmgr
[2010/03/29 19:59:57 | 000,015,865 | ---- | M] () -- C:\ComboFix.txt
[2006/09/18 17:43:37 | 000,000,010 | ---- | M] () -- C:\config.sys
[2008/05/27 10:01:07 | 000,005,026 | RH-- | M] () -- C:\dell.sdr
[2009/05/14 16:44:14 | 000,000,486 | ---- | M] () -- C:\INSTALL.LOG
[2009/06/19 16:20:29 | 000,000,711 | -H-- | M] () -- C:\IPH.PH
[2008/05/27 02:26:47 | 000,022,729 | ---- | M] () -- C:\newfile.enc
[2008/05/27 02:26:47 | 000,022,729 | ---- | M] () -- C:\newkey
[2010/03/29 20:25:42 | 3524,710,400 | -HS- | M] () -- C:\pagefile.sys
[2008/05/27 02:26:45 | 000,002,229 | ---- | M] () -- C:\SetWiFiBT.txt
[2008/11/20 20:35:38 | 000,000,156 | ---- | M] () -- C:\YServer.txt
< %PROGRAMFILES%\*. >
[2009/05/14 16:33:09 | 000,000,000 | ---D | M] -- C:\Program Files\Adobe
[2009/06/19 16:20:10 | 000,000,000 | ---D | M] -- C:\Program Files\AIM6
[2010/01/30 15:41:01 | 000,000,000 | ---D | M] -- C:\Program Files\AnvSoft
[2008/08/18 20:57:04 | 000,000,000 | ---D | M] -- C:\Program Files\AOL
[2008/12/02 15:54:56 | 000,000,000 | ---D | M] -- C:\Program Files\Apple Software Update
[2009/07/31 00:58:42 | 000,000,000 | ---D | M] -- C:\Program Files\Audacity
[2008/06/30 18:56:08 | 000,000,000 | ---D | M] -- C:\Program Files\AVG
[2008/07/18 23:49:28 | 000,000,000 | ---D | M] -- C:\Program Files\AWS
[2009/03/07 16:27:50 | 000,000,000 | ---D | M] -- C:\Program Files\Bonjour
[2008/05/27 02:24:45 | 000,000,000 | ---D | M] -- C:\Program Files\Broadcom
[2008/06/30 19:00:42 | 000,000,000 | ---D | M] -- C:\Program Files\CCleaner
[2008/05/27 02:27:06 | 000,000,000 | ---D | M] -- C:\Program Files\Cisco
[2008/05/27 02:39:19 | 000,000,000 | ---D | M] -- C:\Program Files\Citrix
[2010/03/29 19:55:06 | 000,000,000 | ---D | M] -- C:\Program Files\Common Files
[2008/05/27 02:07:08 | 000,000,000 | ---D | M] -- C:\Program Files\CONEXANT
[2008/05/27 02:26:07 | 000,000,000 | ---D | M] -- C:\Program Files\Creative
[2008/05/27 02:25:22 | 000,000,000 | ---D | M] -- C:\Program Files\Creative Live! Cam
[2008/05/27 02:35:01 | 000,000,000 | ---D | M] -- C:\Program Files\CyberLink
[2008/05/27 02:43:35 | 000,000,000 | ---D | M] -- C:\Program Files\Dell
[2008/05/27 02:29:18 | 000,000,000 | ---D | M] -- C:\Program Files\Dell DataSafe Online
[2008/05/27 02:33:41 | 000,000,000 | ---D | M] -- C:\Program Files\Dell Support Center
[2008/05/27 10:00:50 | 000,000,000 | ---D | M] -- C:\Program Files\DellTPad
[2008/05/27 02:24:36 | 000,000,000 | ---D | M] -- C:\Program Files\Digital Line Detect
[2010/03/19 14:09:04 | 000,000,000 | ---D | M] -- C:\Program Files\Google
[2008/10/01 16:35:07 | 000,000,000 | ---D | M] -- C:\Program Files\Hewlett-Packard
[2008/10/01 16:38:56 | 000,000,000 | ---D | M] -- C:\Program Files\HP
[2009/09/23 15:00:40 | 000,000,000 | -H-D | M] -- C:\Program Files\InstallShield Installation Information
[2010/01/22 04:21:25 | 000,000,000 | ---D | M] -- C:\Program Files\Internet Explorer
[2009/12/16 01:46:54 | 000,000,000 | ---D | M] -- C:\Program Files\iPod
[2009/07/12 22:02:46 | 000,000,000 | ---D | M] -- C:\Program Files\iPod(78)
[2008/10/17 13:52:20 | 000,000,000 | ---D | M] -- C:\Program Files\iriver
[2009/07/11 21:12:35 | 000,000,000 | ---D | M] -- C:\Program Files\iTunes(79)
[2009/12/16 01:47:58 | 000,000,000 | ---D | M] -- C:\Program Files\iTunes12
[2008/05/27 02:18:44 | 000,000,000 | ---D | M] -- C:\Program Files\Java
[2008/06/07 19:32:09 | 000,000,000 | ---D | M] -- C:\Program Files\K-Lite Codec Pack
[2009/12/06 01:47:58 | 000,000,000 | ---D | M] -- C:\Program Files\LimeWire
[2009/09/23 15:00:21 | 000,000,000 | ---D | M] -- C:\Program Files\MasterCook 7
[2008/09/14 08:45:00 | 000,000,000 | ---D | M] -- C:\Program Files\McAfee
[2008/05/27 02:31:06 | 000,000,000 | ---D | M] -- C:\Program Files\McAfee.com
[2009/11/05 20:01:16 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft
[2006/11/02 08:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Games
[2009/10/27 01:22:12 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Office
[2010/01/22 04:23:04 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Silverlight
[2009/06/11 03:08:43 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft Works
[2009/10/27 01:21:15 | 000,000,000 | ---D | M] -- C:\Program Files\Microsoft.NET
[2008/05/27 02:23:38 | 000,000,000 | ---D | M] -- C:\Program Files\Modem Diagnostic Tool
[2010/03/11 04:24:25 | 000,000,000 | ---D | M] -- C:\Program Files\Movie Maker
[2010/03/29 16:49:39 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox
[2006/11/02 08:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\MSBuild
[2006/11/02 08:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\MSN
[2008/10/03 03:02:07 | 000,000,000 | ---D | M] -- C:\Program Files\MSXML 4.0
[2008/05/27 02:24:07 | 000,000,000 | ---D | M] -- C:\Program Files\NetWaiting
[2009/12/16 01:31:03 | 000,000,000 | ---D | M] -- C:\Program Files\QuickTime
[2006/11/02 08:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Reference Assemblies
[2008/05/27 02:39:00 | 000,000,000 | ---D | M] -- C:\Program Files\Roxio
[2009/12/16 01:26:36 | 000,000,000 | ---D | M] -- C:\Program Files\Safari
[2008/05/27 02:06:51 | 000,000,000 | ---D | M] -- C:\Program Files\Sigmatel
[2009/11/17 22:36:33 | 000,000,000 | R--D | M] -- C:\Program Files\Skype
[2009/11/17 22:36:53 | 000,000,000 | ---D | M] -- C:\Program Files\tbh
[2006/11/02 09:01:55 | 000,000,000 | -H-D | M] -- C:\Program Files\Uninstall Information
[2008/08/18 20:56:56 | 000,000,000 | ---D | M] -- C:\Program Files\Viewpoint
[2008/05/27 02:27:23 | 000,000,000 | ---D | M] -- C:\Program Files\WIDCOMM
[2008/06/20 13:51:13 | 000,000,000 | ---D | M] -- C:\Program Files\WinAce
[2008/05/27 09:53:04 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Calendar
[2006/11/02 08:42:32 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Collaboration
[2008/05/27 09:47:51 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Defender
[2006/11/02 08:42:32 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Journal
[2009/11/05 20:00:39 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live
[2009/11/05 20:01:00 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Live SkyDrive
[2010/03/11 04:24:24 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Mail
[2009/10/28 16:18:21 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Media Player
[2006/11/02 08:37:34 | 000,000,000 | ---D | M] -- C:\Program Files\Windows NT
[2006/11/02 08:42:32 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Photo Gallery
[2008/05/27 09:45:14 | 000,000,000 | ---D | M] -- C:\Program Files\Windows Sidebar
[2008/09/09 23:24:11 | 000,000,000 | ---D | M] -- C:\Program Files\Yahoo!
[2008/06/23 22:30:42 | 000,000,000 | ---D | M] -- C:\Program Files\Zone Labs
< MD5 for: AGP440.SYS >
[2008/01/19 03:42:25 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_machine.inf_31bf3856ad364e35_6.0.6001.18000_none_ba12ed3bbeb0d97a\AGP440.sys
[2008/01/19 03:42:25 | 000,056,376 | ---- | M] (Microsoft Corporation) MD5=13F9E33747E6B41A3FF305C37DB0D360 -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_machine.inf_31bf3856ad364e35_6.0.6001.18000_none_ba12ed3bbeb0d97a\AGP440.sys
[2008/05/27 09:41:20 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=8B10CE1C1F9F1D47E4DEB1A547A00CD4 -- C:\Windows\ERDNT\cache\AGP440.sys
[2008/05/27 09:41:20 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=8B10CE1C1F9F1D47E4DEB1A547A00CD4 -- C:\Windows\System32\drivers\AGP440.sys
[2008/05/27 09:41:20 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=8B10CE1C1F9F1D47E4DEB1A547A00CD4 -- C:\Windows\System32\DriverStore\FileRepository\machine.inf_8ed06b47\AGP440.sys
[2008/05/27 09:41:20 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=8B10CE1C1F9F1D47E4DEB1A547A00CD4 -- C:\Windows\winsxs\x86_machine.inf_31bf3856ad364e35_6.0.6000.16400_none_b82caac9c18a4e3b\AGP440.sys
[2008/05/27 09:41:20 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=BF34B4A0E0B64440C5389AA6B902F4AD -- C:\Windows\winsxs\x86_machine.inf_31bf3856ad364e35_6.0.6000.20496_none_b85af81edaeb8461\AGP440.sys
[2006/11/02 05:49:52 | 000,053,864 | ---- | M] (Microsoft Corporation) MD5=EF23439CDD587F64C2C1B8825CEAD7D8 -- C:\Windows\System32\DriverStore\FileRepository\machine.inf_920a2c1f\AGP440.sys
< MD5 for: ATAPI.SYS >
[2008/01/19 03:41:30 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_mshdc.inf_31bf3856ad364e35_6.0.6001.18000_none_dd38281a2189ce9c\atapi.sys
[2008/01/19 03:41:30 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=2D9C903DC76A66813D350A562DE40ED9 -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_mshdc.inf_31bf3856ad364e35_6.0.6001.18000_none_dd38281a2189ce9c\atapi.sys
[2008/05/27 09:42:03 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=3E39E69F31F95D056703212E94320899 -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_e6b2949c\atapi.sys
[2008/05/27 09:42:03 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=3E39E69F31F95D056703212E94320899 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.20544_none_dbb443eb3d9db847\atapi.sys
[2006/11/02 05:49:36 | 000,019,048 | ---- | M] (Microsoft Corporation) MD5=4F4FCB8B6EA06784FB6D475B7EC7300F -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_c6c2e699\atapi.sys
[2008/05/27 09:41:51 | 000,019,048 | ---- | M] (Microsoft Corporation) MD5=5653737BAD8C6C10136451C195C19881 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.20485_none_db8a029f3dbd443b\atapi.sys
[2008/05/27 10:00:30 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=61CA2C1E145809813C28752298CF9843 -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_5da5d093\atapi.sys
[2008/05/27 10:00:30 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=61CA2C1E145809813C28752298CF9843 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.20580_none_db8503133dc1c2af\atapi.sys
[2008/05/27 10:00:30 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=7EB55F6BEFB392BD312CD0CD5263305D -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_6c3af7d3\atapi.sys
[2008/05/27 10:00:30 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=7EB55F6BEFB392BD312CD0CD5263305D -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.16470_none_db063634249c06f4\atapi.sys
[2008/05/27 09:41:18 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=9E7E85EC61D1C9C3171CC08427108863 -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_5a9555b4\atapi.sys
[2008/05/27 09:41:18 | 000,021,688 | ---- | M] (Microsoft Corporation) MD5=9E7E85EC61D1C9C3171CC08427108863 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.20509_none_dbe4850d3d78c736\atapi.sys
[2008/05/27 09:41:51 | 000,019,048 | ---- | M] (Microsoft Corporation) MD5=A779CA2C76DA4FCB595E692C05E8E4EB -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_82339ef2\atapi.sys
[2008/05/27 09:41:51 | 000,019,048 | ---- | M] (Microsoft Corporation) MD5=A779CA2C76DA4FCB595E692C05E8E4EB -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.16391_none_daf194c024ab5b06\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=B35CFCEF838382AB6490B321C87EDF17 -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_7de13c21\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=B35CFCEF838382AB6490B321C87EDF17 -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.16632_none_db337a442479c42c\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=E03E8C99D15D0381E02743C36AFC7C6F -- C:\Windows\ERDNT\cache\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=E03E8C99D15D0381E02743C36AFC7C6F -- C:\Windows\System32\drivers\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=E03E8C99D15D0381E02743C36AFC7C6F -- C:\Windows\System32\DriverStore\FileRepository\mshdc.inf_64dfd8ea\atapi.sys
[2008/05/27 09:54:23 | 000,021,560 | ---- | M] (Microsoft Corporation) MD5=E03E8C99D15D0381E02743C36AFC7C6F -- C:\Windows\winsxs\x86_mshdc.inf_31bf3856ad364e35_6.0.6000.20757_none_dbac78a93da31a8b\atapi.sys
< MD5 for: CNGAUDIT.DLL >
[2006/11/02 05:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\ERDNT\cache\cngaudit.dll
[2006/11/02 05:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\System32\cngaudit.dll
[2006/11/02 05:46:03 | 000,011,776 | ---- | M] (Microsoft Corporation) MD5=7F15B4953378C8B5161D65C26D5FED4D -- C:\Windows\winsxs\x86_microsoft-windows-cngaudit-dll_31bf3856ad364e35_6.0.6000.16386_none_e62d292932a96ce6\cngaudit.dll
< MD5 for: IASTOR.SYS >
[2007/02/12 17:36:54 | 000,277,784 | ---- | M] (Intel Corporation) MD5=FD7F9D74C2B35DBDA400804A3F5ED5D8 -- C:\Drivers\storage\R154200\iastor.sys
[2007/02/12 17:36:54 | 000,277,784 | ---- | M] (Intel Corporation) MD5=FD7F9D74C2B35DBDA400804A3F5ED5D8 -- C:\Windows\System32\drivers\iaStor.sys
[2007/02/12 17:36:54 | 000,277,784 | ---- | M] (Intel Corporation) MD5=FD7F9D74C2B35DBDA400804A3F5ED5D8 -- C:\Windows\System32\DriverStore\FileRepository\iaahci.inf_1cb29a96\iaStor.sys
[2007/02/12 17:36:54 | 000,277,784 | ---- | M] (Intel Corporation) MD5=FD7F9D74C2B35DBDA400804A3F5ED5D8 -- C:\Windows\System32\DriverStore\FileRepository\iastor.inf_8f0cb06b\iaStor.sys
< MD5 for: IASTORV.SYS >
[2008/01/19 03:42:51 | 000,235,064 | ---- | M] (Intel Corporation) MD5=54155EA1B0DF185878E0FC9EC3AC3A14 -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_iastorv.inf_31bf3856ad364e35_6.0.6001.18000_none_af11527887c7fa8f\iaStorV.sys
[2008/01/19 03:42:51 | 000,235,064 | ---- | M] (Intel Corporation) MD5=54155EA1B0DF185878E0FC9EC3AC3A14 -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_iastorv.inf_31bf3856ad364e35_6.0.6001.18000_none_af11527887c7fa8f\iaStorV.sys
[2006/11/02 05:51:25 | 000,232,040 | ---- | M] (Intel Corporation) MD5=C957BF4B5D80B46C5017BF0101E6C906 -- C:\Windows\System32\drivers\iaStorV.sys
[2006/11/02 05:51:25 | 000,232,040 | ---- | M] (Intel Corporation) MD5=C957BF4B5D80B46C5017BF0101E6C906 -- C:\Windows\System32\DriverStore\FileRepository\iastorv.inf_37cdafa4\iaStorV.sys
< MD5 for: NETLOGON.DLL >
[2006/11/02 05:46:11 | 000,559,616 | ---- | M] (Microsoft Corporation) MD5=889A2C9F2AACCD8F64EF50AC0B3D553B -- C:\Windows\ERDNT\cache\netlogon.dll
[2006/11/02 05:46:11 | 000,559,616 | ---- | M] (Microsoft Corporation) MD5=889A2C9F2AACCD8F64EF50AC0B3D553B -- C:\Windows\System32\netlogon.dll
[2006/11/02 05:46:11 | 000,559,616 | ---- | M] (Microsoft Corporation) MD5=889A2C9F2AACCD8F64EF50AC0B3D553B -- C:\Windows\winsxs\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.0.6000.16386_none_fb80f5473b0ed783\netlogon.dll
[2008/01/19 03:35:36 | 000,592,384 | ---- | M] (Microsoft Corporation) MD5=A8EFC0B6E75B789F7FD3BA5025D4E37F -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.0.6001.18000_none_fdb7b74337f9e857\netlogon.dll
[2008/01/19 03:35:36 | 000,592,384 | ---- | M] (Microsoft Corporation) MD5=A8EFC0B6E75B789F7FD3BA5025D4E37F -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_microsoft-windows-security-netlogon_31bf3856ad364e35_6.0.6001.18000_none_fdb7b74337f9e857\netlogon.dll
< MD5 for: NVSTOR.SYS >
[2006/11/02 05:50:13 | 000,040,040 | ---- | M] (NVIDIA Corporation) MD5=9E0BA19A28C498A6D323D065DB76DFFC -- C:\Windows\System32\drivers\nvstor.sys
[2006/11/02 05:50:13 | 000,040,040 | ---- | M] (NVIDIA Corporation) MD5=9E0BA19A28C498A6D323D065DB76DFFC -- C:\Windows\System32\DriverStore\FileRepository\nvraid.inf_733654ff\nvstor.sys
[2008/01/19 03:42:09 | 000,045,112 | ---- | M] (NVIDIA Corporation) MD5=ABED0C09758D1D97DB0042DBB2688177 -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_nvraid.inf_31bf3856ad364e35_6.0.6001.18000_none_39dac327befea467\nvstor.sys
[2008/01/19 03:42:09 | 000,045,112 | ---- | M] (NVIDIA Corporation) MD5=ABED0C09758D1D97DB0042DBB2688177 -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_nvraid.inf_31bf3856ad364e35_6.0.6001.18000_none_39dac327befea467\nvstor.sys
< MD5 for: SCECLI.DLL >
[2008/01/19 03:36:19 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=28B84EB538F7E8A0FE8B9299D591E0B9 -- C:\Windows\SoftwareDistribution\Download\a58fa8f1a78b89e6c2a670e288053b8b\x86_microsoft-windows-s..urationengineclient_31bf3856ad364e35_6.0.6001.18000_none_380de25bd91b6f12\scecli.dll
[2008/01/19 03:36:19 | 000,177,152 | ---- | M] (Microsoft Corporation) MD5=28B84EB538F7E8A0FE8B9299D591E0B9 -- C:\Windows\SoftwareDistribution\Download\c91af43e301542f65a88d59517636d32\x86_microsoft-windows-s..urationengineclient_31bf3856ad364e35_6.0.6001.18000_none_380de25bd91b6f12\scecli.dll
[2006/11/02 05:46:12 | 000,176,640 | ---- | M] (Microsoft Corporation) MD5=80E2839D05CA5970A86D7BE2A08BFF61 -- C:\Windows\ERDNT\cache\scecli.dll
[2006/11/02 05:46:12 | 000,176,640 | ---- | M] (Microsoft Corporation) MD5=80E2839D05CA5970A86D7BE2A08BFF61 -- C:\Windows\System32\scecli.dll
[2006/11/02 05:46:12 | 000,176,640 | ---- | M] (Microsoft Corporation) MD5=80E2839D05CA5970A86D7BE2A08BFF61 -- C:\Windows\winsxs\x86_microsoft-windows-s..urationengineclient_31bf3856ad364e35_6.0.6000.16386_none_35d7205fdc305e3e\scecli.dll
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install\\LastSuccessTime: 2010-03-29 16:10:12
< End of rep
ianmc
Posts Posts : 16
Post by ianmc on 30th March 2010, 3:32 am
Extras.Txt
OTL Extras logfile created on: 3/29/2010 10:34:56 PM - Run 1
OTL by OldTimer - Version 3.1.37.3 Folder = C:\Users\ian\Desktop
Windows Vista Home Premium Edition (Version = 6.0.6000) - Type = NTWorkstation
Internet Explorer (Version = 7.0.6000.16982)
3.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 47.00% Memory free
6.00 Gb Paging File | 4.00 Gb Available in Paging File | 72.00% Paging File free
Drive C: | 285.50 Gb Total Space | 67.38 Gb Free Space | 23.60% Space Free | Partition Type: NTFS
Drive D: | 10.00 Gb Total Space | 5.60 Gb Free Space | 55.98% Space Free | Partition Type: NTFS
Computer Name: IAN-PC
Current User Name: ian
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
.hlp [@ = hlpfile] -- C:\Windows\winhlp32.exe (Microsoft Corporation)
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
hlpfile [open] -- %SystemRoot%\winhlp32.exe %1 (Microsoft Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [OneNote.Open] -- C:\PROGRA~1\MICROS~2\Office12\ONENOTE.EXE "%L" (Microsoft Corporation)
"cval" = 1
"FirewallDisableNotify" = 0
"AntiVirusDisableNotify" = 0
"UpdatesDisableNotify" = 0
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring\McAfeeAntiSpyware]
"DisableMonitoring" = 1
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
"AntiVirusOverride" = 0
"AntiSpywareOverride" = 0
"FirewallOverride" = 0
"DisableNotifications" = 0
"EnableFirewall" = 1
"DisableNotifications" = 1
"DoNotAllowExceptions" = 0
========== Vista Active Open Ports Exception List ==========
"{69D87065-9518-4256-8ABC-EFF5D9C5188F}" = lport=1900 | protocol=17 | dir=in | svc=ssdpsrv | app=svchost.exe |
"{E0BFBBCF-68FB-4046-BC6B-CF2881453C8B}" = lport=2869 | protocol=6 | dir=in | app=system |
"{FA2EBCDE-5F22-47DA-A4A4-EBDA665094A2}" = lport=5191 | protocol=6 | dir=in | name=the browser highlighter xcom |
========== Vista Active Application Exception List ==========
"{041C47B1-BC6C-47A2-B843-54C01BEE867A}" = dir=in | app=c:\program files\dell\mediadirect\mediadirect.exe |
"{0A85E229-C36D-49A2-B0D9-B3F7B6B44B4C}" = protocol=6 | dir=in | app=c:\program files\limewire\limewire.exe |
"{0D58CBB8-1C44-4060-B78F-4FA1F3756BD6}" = dir=in | app=c:\program files\dell\mediadirect\kernel\dms\clmsservice.exe |
"{11A20A7B-5591-44BC-AC96-996BACED4E1E}" = protocol=6 | dir=in | app=c:\program files\yahoo!\messenger\yserver.exe |
"{12EA6883-16A8-480A-B94A-B0957C5F5C60}" = dir=in | app=c:\program files\common files\mcafee\mna\mcnasvc.exe |
"{13AFED2B-D421-4BBB-B4ED-E5B5445742E9}" = dir=in | app=c:\program files\avg\avg8\avgemc.exe |
"{1F0D29AE-25A3-4346-90BB-0F5048C29C57}" = protocol=17 | dir=in | app=c:\program files\aim6\aim6.exe |
"{406CB391-DD23-4BDF-B6CC-D0E968B74461}" = protocol=17 | dir=in | app=c:\program files\tbh\base\bin\tbhdaemon.exe |
"{412FA4DC-E39D-4205-9D1B-534C73424EA3}" = protocol=17 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
"{44FF6F00-AB94-4E3D-99A0-6B448B4F8FD6}" = protocol=17 | dir=in | app=c:\program files\windows media player\wmplayer.exe |
"{46061C59-55B4-49DA-8BC9-D976ADDFEDF9}" = protocol=6 | dir=out | app=c:\program files\windows media player\wmplayer.exe |
"{4C77DFD5-2776-4395-9FEB-C3737B53FE84}" = protocol=17 | dir=in | app=c:\program files\limewire\limewire.exe |
"{5960281F-2D64-4C12-AC09-B464F284A1B1}" = protocol=17 | dir=in | app=c:\program files\common files\aol\loader\aolload.exe |
"{634508E8-A388-4504-BC4F-C42F5452797B}" = protocol=6 | dir=in | app=c:\program files\itunes12\itunes.exe |
"{67998077-5732-4262-9607-6F8EC05B6DEF}" = protocol=17 | dir=in | app=c:\program files\tbh\monitor\bin\tbhmonitor.exe |
"{883084E1-537C-4F40-964B-6C5D80577F40}" = protocol=17 | dir=out | app=c:\program files\windows media player\wmplayer.exe |
"{8AA72D78-AFEF-497B-A1A0-42D923B6FC28}" = protocol=6 | dir=in | app=c:\program files\aim6\aim6.exe |
"{9C19E9FE-5811-49FF-89DF-59FCABF2A690}" = protocol=17 | dir=in | app=c:\program files\yahoo!\messenger\yahoomessenger.exe |
"{9C5FF88C-F10B-4AAF-8E11-C4C8B41EB3D7}" = protocol=6 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{A309BFB2-43A6-45EF-A580-767D9D5F1346}" = protocol=6 | dir=in | app=c:\program files\tbh\monitor\bin\tbhmonitor.exe |
"{A5FE67EF-AF81-4ED7-80A6-157680BBE36D}" = protocol=6 | dir=in | app=c:\program files\common files\aol\loader\aolload.exe |
"{A8D1D82C-CB7E-4F8C-8A49-42BBC46A5714}" = dir=in | app=c:\program files\dell\mediadirect\pcmservice.exe |
"{AF23A758-0E55-4FD8-9569-50E693579850}" = protocol=17 | dir=in | app=c:\program files\itunes12\itunes.exe |
"{BC4667A2-67EF-4EEC-8203-67788B99CD35}" = protocol=6 | dir=in | app=c:\program files\yahoo!\messenger\yahoomessenger.exe |
"{C14264AE-485F-4D62-9554-D6C23DE265DD}" = protocol=6 | dir=in | app=c:\program files\tbh\base\bin\tbhdaemon.exe |
"{C54147BB-1820-40F6-A01B-9C21AEFFBFCD}" = protocol=6 | dir=in | app=c:\program files\microsoft office\office12\onenote.exe |
"{D3ED4606-21FC-4572-B9A6-C12E90704F47}" = protocol=6 | dir=in | app=c:\program files\itunes\itunes.exe |
"{D963A2D9-3DC1-49AA-A73D-7A3B62819A83}" = dir=in | app=c:\program files\dell\mediadirect\kernel\dmp\clbrowserengine.exe |
"{E29CB23D-AEA1-4624-A5AA-125597C96279}" = protocol=17 | dir=in | app=c:\program files\yahoo!\messenger\yserver.exe |
"{E51E79DF-62BD-4680-99A1-3BCDE7C8A157}" = protocol=17 | dir=in | app=c:\program files\bonjour\mdnsresponder.exe |
"{E5AE3C48-A9C7-45C5-BE23-E4D27F3747AB}" = dir=in | app=c:\program files\skype\phone\skype.exe |
"{E8635216-9AFF-4D9A-9A2B-594A871806D7}" = dir=in | app=c:\program files\windows live\messenger\msnmsgr.exe |
"{EA238C9D-E605-4CAA-BBDD-0F79C58A147D}" = protocol=17 | dir=in | app=c:\program files\itunes\itunes.exe |
"{FBB2B739-748B-4D1C-845A-F6556911BF2A}" = dir=in | app=c:\program files\avg\avg8\avgupd.exe |
"TCP Query User{2F3A6C8F-4C30-4A29-A16B-8E52A806D8C2}C:\program files\mozilla firefox\firefox.exe" = protocol=6 | dir=in | app=c:\program files\mozilla firefox\firefox.exe |
"TCP Query User{7AF19B11-31D6-4198-AC18-1C2E7B23DFE4}C:\program files\yahoo!\messenger\yahoomessenger.exe" = protocol=6 | dir=in | app=c:\program files\yahoo!\messenger\yahoomessenger.exe |
"TCP Query User{9EA220CC-2149-4974-B54C-A628BBADB8C3}C:\program files\aim6\aim6.exe" = protocol=6 | dir=in | app=c:\program files\aim6\aim6.exe |
"TCP Query User{F4F10BA0-B039-4811-92C1-F569B85A4DB2}C:\program files\limewire\limewire.exe" = protocol=6 | dir=in | app=c:\program files\limewire\limewire.exe |
"UDP Query User{925A1E31-346D-4A9F-B373-3571AB6B4817}C:\program files\aim6\aim6.exe" = protocol=17 | dir=in | app=c:\program files\aim6\aim6.exe |
"UDP Query User{CC781C5C-FEDD-48B5-ACD6-C4F7D49D3B70}C:\program files\limewire\limewire.exe" = protocol=17 | dir=in | app=c:\program files\limewire\limewire.exe |
"UDP Query User{EDE61635-125B-43F5-A2A5-4E91092D7B84}C:\program files\yahoo!\messenger\yahoomessenger.exe" = protocol=17 | dir=in | app=c:\program files\yahoo!\messenger\yahoomessenger.exe |
"UDP Query User{FAD3844A-3259-4609-A73C-B80CC64C882F}C:\program files\mozilla firefox\firefox.exe" = protocol=17 | dir=in | app=c:\program files\mozilla firefox\firefox.exe |
"{02E89EFC-7B07-4D5A-AA03-9EC0902914EE}" = VC 9.0 Runtime
"{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
"{08E81ABD-79F7-49C2-881F-FD6CB0975693}" = Roxio Creator Data
"{09760D42-E223-42AD-8C3E-55B47D0DDAC3}" = Roxio Creator DE
"{0D2E9DCB-9938-475E-B4DD-8851738852FF}" = AIO_Scan
"{0F95AA42-0FF6-4D48-9CA1-64C8D0777500}" = QuickSet
"{1451DE6B-ABE1-4F62-BE9A-B363A17588A2}" = QuickTime
"{15BC8CD0-A65B-47D0-A2DD-90A824590FA8}" = Microsoft Works
"{1746EA69-DCB6-4408-B5A5-E75F55439CDF}" = Scan
"{179C56A4-F57F-4561-8BBF-F911D26EB435}" = WebReg
"{197A3012-8C85-4FD3-AB66-9EC7E13DB92E}" = Adobe AIR
"{1AE3E621-E0C0-4aa1-B10B-B3E353A8D110}" = c3100_Help
"{1D5E29AD-39A9-4D0A-A8B6-46A6FCD8C995}" = Live! Cam Avatar v1.0
"{1F54DAFA-9261-4A62-B59D-6C9F26B48FE4}" = Roxio Creator Tools
"{282E5AB2-8E47-4571-B6FA-6B512555B557}" = HP Photosmart.All-In-One Driver Software 8.0 .A
"{30465B6C-B53F-49A1-9EBA-A3F187AD502E}" = Roxio Update Manager
"{3248F0A8-6813-11D6-A77B-00B0D0160000}" = Java(TM) SE Runtime Environment 6
"{3AC54383-31D1-4907-961B-B12CBB1D0AE8}" = MobileMe Control Panel
"{3B62CF95-5E25-4720-A3D6-B4A2B0501961}" = Browser Highlighter - Firefox
"{3F92ABBB-6BBF-11D5-B229-002078017FBF}" = NetWaiting
"{3FA365DF-2D68-45ED-8F83-8C8A33E65143}" = Apple Application Support
"{42D68A86-DB1C-4256-B8C9-5D0D92919AF5}" = Banctec Service Agreement
"{44F5A980-8A6B-4aca-8D85-EFCE5D67D379}" = AIO_CDA_ProductContext
"{49F2B650-2D7B-4F59-B33D-346F63776BD3}" = DocProc
"{4D3C9F4B-4B7D-4E5D-99B9-0123AB0D51ED}" = Dell DataSafe Online
"{4E5386F5-C0F6-4532-A54A-374865AEAB71}" = Cisco PEAP Module
"{541DEAC0-5F3D-45E6-B7CB-94ECF3B96748}" = Skype web features
"{62230596-37E5-4618-A329-0D21F529A86F}" = Browser Address Error Redirector
"{65D0C510-D7B6-4438-9FC8-E6B91115AB0D}" = Live! Cam Avatar Creator
"{6675CA7F-E51B-4F6A-99D4-F8F0124C6EAA}" = Roxio Express Labeler 3
"{66E6CE0C-5A1E-430C-B40A-0C90FF1804A8}" = eSupportQFolder
"{67D3F1A0-A1F2-49b7-B9EE-011277B170CD}" = HPProductAssistant
"{6B7B6D4D-8F9B-4CB3-8CA4-BCA9CC4C1A22}" = EDocs
"{73A4F29F-31AC-4EBD-AA1B-0CC5F18C8F83}" = Roxio Creator Audio
"{76F9CF97-FC4B-4E20-B363-D127C888448F}" = Cisco LEAP Module
"{7A7DC702-DEDE-42A8-8722-B3BA724D546F}" = Fax
"{7DB9F1E5-9ACB-410D-A7DC-7A3D023CE045}" = Dell Getting Started Guide
"{81128EE8-8EAD-4DB0-85C6-17C2CE50FF71}" = Windows Live Essentials
"{87E2B986-07E8-477a-93DC-AF0B6758B192}" = DocProcQFolder
"{89CEAE14-DD0F-448E-9554-15781EC9DB24}" = Product Documentation Launcher
"{8C6027FD-53DC-446D-BB75-CACD7028A134}" = HP Update
"{90120000-0016-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_HOMESTUDENTR_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_HOMESTUDENTR_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_HOMESTUDENTR_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_HOMESTUDENTR_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_HOMESTUDENTR_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{91120000-002F-0000-0000-0000000FF1CE}_HOMESTUDENTR_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{9422C8EA-B0C6-4197-B8FC-DC797658CA00}" = Windows Live Sign-in Assistant
"{95D08F4E-DFC2-4ce3-ACB7-8C8E206217E9}" = MarketResearch
"{978C25EE-5777-46e4-8988-732C297CBDBD}" = Status
"{9B1FD9CE-0776-4f0b-A6F5-C6AB7B650CDF}" = Destinations
"{9BDEF074-020E-458D-ADC5-8FF68E0C9B56}" = OutlookAddinSetup
"{9C6978E8-B6D0-4AB7-A7A0-D81A74FBF745}" = MediaDirect
"{9F72EF8B-AEC9-4CA5-B483-143980AFD6FD}" = Dell Touchpad
"{A13E07E1-A423-44FB-9DEE-B24C75C1BAF2}" = WIDCOMM Bluetooth Software 6.0.1.3100
"{A36CD345-625C-4d6c-B3E2-76E1248CB451}" = SolutionCenter
"{A3B7C670-4A1E-4EE2-950E-C875BC1965D0}" = Copy
"{A6FDF86A-F541-4E7B-AEA0-8849A2A700D5}" = iTunes
"{A85FD55B-891B-4314-97A5-EA96C0BD80B5}" = Windows Live Messenger
"{A88867F8-8034-3299-337D-C8F5BCF1B469}" = aiCountdownCalendar
"{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}" = Apple Mobile Device Support
"{AB5D51AE-EBC3-438D-872C-705C7C2084B0}" = DeviceManagementQFolder
"{AB61E316-F10B-43eb-B47F-42095835F9CC}" = C3100
"{AC76BA86-1033-F400-7760-000000000004}" = Adobe Acrobat 9 Pro - English, Français, Deutsch
"{AC76BA86-1033-F400-7760-000000000004}_911" = Adobe Acrobat 9.1.1 - CPSID_49013
"{AC76BA86-1033-F400-7760-000000000004}{AC76BA86-1033-F400-7760-000000000004}" = Adobe Acrobat 9 Pro - English, Français, Deutsch
"{AC76BA86-7AD7-1033-7B44-A91000000001}" = Adobe Reader 9.1.1
"{AF1C9345-B53D-4110-BFBF-A0DD83AEAB83}" = AIO_CDA_Software
"{B6A26DE5-F2B5-4D58-9570-4FC760E00FCD}" = Roxio Creator Copy
"{BE77A81F-B315-4666-9BF3-AE70C0ADB057}" = BufferChm
"{BF53252E-4AB2-4C7F-A0FD-6100755745E3}" = Cisco EAP-FAST Module
"{C4124E95-5061-4776-8D5D-E3D931C778E1}" = Microsoft VC9 runtime libraries
"{C716522C-3731-4667-8579-40B098294500}" = Toolbox
"{C99C0593-3B48-41D9-B42F-6E035B320449}" = Broadcom Management Programs
"{D103C4BA-F905-437A-8049-DB24763BBE36}" = Skype™ 4.1
"{D6E4E5D6-7693-4BB4-95BA-21F38FAFEE90}" = Safari
"{D7769185-9A7C-48D4-8874-5388743A1DE2}" = Music, Photos & Videos Launcher
"{E06F04B9-45E6-4AC0-8083-85F7515F40F7}" = UnloadSupport
"{E3BFEE55-39E2-4BE0-B966-89FE583822C1}" = Dell Support Center
"{E646DCF0-5A68-11D5-B229-002078017FBF}" = Digital Line Detect
"{EB21A812-671B-4D08-B974-2A347F0D8F70}" = HP Photosmart Essential
"{EB75DE50-5754-4F6F-875D-126EDF8E4CB3}" = HPSSupply
"{ED00D08A-3C5F-488D-93A0-A04F21F23956}" = Windows Live Communications Platform
"{ED439A64-F018-4DD4-8BA5-328D85AB09AB}" = Roxio Creator DE
"{F1E63043-54FC-429B-AB2C-31AF9FBA4BC7}" = 32 Bit HP CIO Components Installer
"{F63A3748-B93D-4360-9AD4-B064481A5C7B}" = Modem Diagnostic Tool
"{F6BD194C-4190-4D73-B1B1-C48C99921BFE}" = Windows Live Call
"{FF075778-6E50-47ed-991D-3B07FD4E3250}" = TrayApp
"Adobe Acrobat 5.0" = Adobe Acrobat 5.0
"Advanced Audio FX Engine" = Advanced Audio FX Engine
"Advanced Video FX Engine" = Advanced Video FX Engine
"AIM Toolbar" = AIM Toolbar 5.0
"AIM_6" = AIM 6
"Any Video Converter_is1" = Any Video Converter 3.0.2
"Audacity_is1" = Audacity 1.2.6
"AVG8Uninstall" = AVG Free 8.5
"Broadcom 802.11b Network Adapter" = Dell Wireless WLAN Card
"CCleaner" = CCleaner (remove only)
"CNXT_MODEM_HDAUDIO_VEN_14F1&DEV_2C06&SUBSYS_14F1000F" = Conexant HDA D330 MDC V.92 Modem
"Creative OEM002" = Laptop Integrated Webcam Driver (1.04.01.1011)
"Dell Webcam Center" = Dell Webcam Center
"Dell Webcam Manager" = Dell Webcam Manager
"EDMC.LockIn.Web.AIR.aiCountdownCalendar.0B79F3AA8BA7B28571920BBC33ADF06D54740292.1" = Ai Countdown Calendar
"eMusic Download Manager" = eMusic Download Manager 4.0.0.2
"Google Desktop" = Google Desktop
"GoToAssist" = GoToAssist 8.0.0.514
"HP Imaging Device Functions" = HP Imaging Device Functions 8.0
"HP Solution Center & Imaging Support Tools" = HP Solution Center 8.0
"HPExtendedCapabilities" = HP Customer Participation Program 8.0
"HPOCR" = HP OCR Software 8.0
"KLiteCodecPack_is1" = K-Lite Codec Pack 3.9.5 (Full)
"LimeWire" = LimeWire 4.18.2
"Mozilla Firefox (3.5.8)" = Mozilla Firefox (3.5.8)
"MSC" = McAfee SecurityCenter
"WeatherBug" = WeatherBug
"WinAce Archiver" = WinAce Archiver
"Yahoo! Companion" = Yahoo! Toolbar
"Yahoo! Messenger" = Yahoo! Messenger
"Facebook Plug-In" = Facebook Plug-In
[ Application Events ]
Error - 3/29/2010 2:20:36 AM | Computer Name = ian-PC | Source = Application Hang | ID = 1002
Description = The program iexplore.exe version 7.0.6000.16982 stopped interacting
with Windows and was closed. To see if more information about the problem is available,
check the problem history in the Problem Reports and Solutions control panel. Process
ID: 1c38 Start Time: 01cacf07d5935123 Termination Time: 16
Error - 3/29/2010 1:03:51 PM | Computer Name = ian-PC | Source = Application Error | ID = 1000
Description = Faulting application iexplore.exe, version 7.0.6000.16982, time stamp
0x4b2b56f5, faulting module ntdll.dll, version 6.0.6000.16386, time stamp 0x4549bdc9,
exception code 0xc0000005, fault offset 0x00022b45, process id 0x135c, application
start time 0x01cacf60ecd00102.
Error - 3/29/2010 1:11:30 PM | Computer Name = ian-PC | Source = EventSystem | ID = 4621
Description =
Error - 3/29/2010 4:48:47 PM | Computer Name = ian-PC | Source = EventSystem | ID = 4609
Description =
Error - 3/29/2010 7:32:28 PM | Computer Name = ian-PC | Source = Application Error | ID = 1000
Description = Faulting application bcmwltry.exe, version 4.170.25.12, time stamp
0x46f3437a, faulting module unknown, version 0.0.0.0, time stamp 0x00000000, exception
code 0xc0000005, fault offset 0x03cc948a, process id 0x66c, application start time
0x01cacf97f80821cf.
Error - 3/29/2010 7:37:08 PM | Computer Name = ian-PC | Source = Application Error | ID = 1000
code 0xc0000005, fault offset 0x015892ba, process id 0x654, application start time
0x01cacf9899b0885d.
Error - 3/29/2010 7:47:14 PM | Computer Name = ian-PC | Source = EventSystem | ID = 4609
Description =
Error - 3/29/2010 7:49:35 PM | Computer Name = ian-PC | Source = System Restore | ID = 8193
Description =
Error - 3/29/2010 7:58:10 PM | Computer Name = ian-PC | Source = EventSystem | ID = 4609
Description =
Error - 3/29/2010 7:59:39 PM | Computer Name = ian-PC | Source = EventSystem | ID = 4609
Description =
[ Broadcom Wireless LAN Events ]
Error - 7/25/2009 9:59:34 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 21:59:30, Sat, Jul 25, 09 Error - Unable to gain access to user store
Error - 9/28/2009 6:04:53 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 18:04:53, Mon, Sep 28, 09 Error - Unable to gain access to user store
Error - 10/4/2009 3:01:46 AM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 03:01:44, Sun, Oct 04, 09 Error - Unable to gain access to user store
Error - 12/9/2009 7:02:04 AM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 06:01:48, Wed, Dec 09, 09 Error - Unable to gain access to user store
Error - 12/15/2009 11:50:02 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 22:50:02, Tue, Dec 15, 09 Error - Unable to gain access to user store
Error - 1/6/2010 12:45:40 AM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 23:45:40, Tue, Jan 05, 10 Error - Unable to gain access to user store
Error - 2/10/2010 12:32:45 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 11:32:38, Wed, Feb 10, 10 Error - Unable to gain access to user store
Error - 2/10/2010 12:36:52 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 11:36:52, Wed, Feb 10, 10 Error - Unable to gain access to user store
Error - 3/29/2010 7:11:05 PM | Computer Name = ian-PC | Source = WLAN-Tray | ID = 0
Description = 19:11:04, Mon, Mar 29, 10 Error - Unable to gain access to user store
[ System Events ]
Error - 3/29/2010 7:47:27 PM | Computer Name = ian-PC | Source = DCOM | ID = 10005
Description =
Error - 3/29/2010 7:47:48 PM | Computer Name = ian-PC | Source = DCOM | ID = 10005
Description =
Error - 3/29/2010 7:47:54 PM | Computer Name = ian-PC | Source = DCOM | ID = 10005
Description =
Error - 3/29/2010 7:48:53 PM | Computer Name = ian-PC | Source = DCOM | ID = 10005
Description =
Error - 3/29/2010 8:27:28 PM | Computer Name = ian-PC | Source = Service Control Manager | ID = 7000
Description =
Description =
Description =
Description =
Description =
Description =
ianmc
Posts Posts : 16
Post by ianmc on 30th March 2010, 3:33 am
Again man, I'm sorry this is taking up so much space. Thanks for the help, it's helping.
ianmc
Posts Posts : 16
Post by Dr Jay on 30th March 2010, 3:49 am
Optional Removals
I see you are running WeatherBug and ViewPoint. They are known for their bad reputation. I recommend to remove them.
I see you are running LimeWire, a P2P application. I suggest to read the following, and then decided whether you want to keep it or not: [You must be registered and logged in to see this link.]
OTL Fixes
Please run OTL
  • Under the Custom Scans/Fixes box at the bottom, copy and paste in the following:
    :reg
    [HKCU\Software\Microsoft\Windows\CurrentVersion\Internet
    Settings]
    "ProxyOverride" = *.local
    [HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings] "ProxyServer" = http=127.0.0.1
    :commands
    [emptytemp]
    [purity]
    [reboot]
  • Then click the Run Fix button at the top.
  • Note: The fix for OTL automatically hides your Desktop and Start menu so the fix can be completed. Do not be alerted, this is normal.
  • Please do not exit the program. It might take a while to fix, but allow it to run. If it asks to reboot the computer, allow it to reboot. If the program freezes, and the computer fails to reboot - let me know.
    Lastly, post the contents of the log. (Located at C:\_OTL\Moved Files)
Posts Posts : 13810
Points Points : 302437
