mbam problem
mbam problem
Post by 3dsoundz on Mon Mar 29, 2010 1:10 am
all of a sudden i started nitecing that computer is running slow not too much but slower than it should be so tried to run mbam but keep gettin msg mbam.exe not found or cannot run tried to reinstall but not working than tried to install avg just to see what happens but it is not getting isntalled so please help
3dsoundz
Posts Posts : 127
Joined Joined : 2009-10-26
OS OS : win xp sp3
Points Points : 27678
Re: mbam problem
Post by Dr Jay on Mon Mar 29, 2010 2:34 pm
Please visit this webpage for a tutorial on downloading and running ComboFix:
See the area: Using ComboFix, and when done, post the log back here.
Posts Posts : 13717
Points Points : 302127
Re: mbam problem
Post by 3dsoundz on Tue Mar 30, 2010 12:44 am
Here is the log from combofix
ComboFix 10-03-29.02 - Amit 03/29/2010 18:55:34.9.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2038.1519 [GMT -5:00]
Running from: c:\documents and settings\Amit\My Documents\ComboFx.exe
AV: avast! Antivirus *On-access scanning disabled* (Updated) {7591DB91-41F0-48A3-B128-1A293FD8233D}
((((((((((((((((((((((((( Files Created from 2010-02-28 to 2010-03-30 )))))))))))))))))))))))))))))))
2010-03-28 23:27 . 2010-03-28 23:27 -------- d-sh--w- c:\documents and settings\Darshana\IETldCache
2010-03-28 23:20 . 2010-01-07 21:07 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-03-28 23:20 . 2010-03-28 23:20 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-03-28 23:20 . 2010-01-07 21:07 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-03-28 22:58 . 2010-03-28 23:13 -------- d-----w- C:\ComboFx
2010-03-28 22:42 . 2010-03-28 22:42 -------- d-----w- c:\documents and settings\Amit\Application Data\AVG8
2010-03-27 14:14 . 2010-03-27 14:16 20846064 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\rp\RealPlayerSPGold.exe
2010-03-20 22:04 . 2010-03-20 22:04 72488 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 9.0.3.15\SetupAdmin.exe
2010-03-20 21:38 . 2010-03-20 21:38 -------- d-----w- c:\program files\Western Digital Corporation
2010-03-17 00:15 . 2010-03-17 00:15 8405312 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\gtb\GOOGLE_TOOLBAR\GoogleToolbarInstaller.exe
2010-03-17 00:14 . 2010-03-17 00:14 149000 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\chr_helper\LaunchHelper.exe
2010-03-17 00:13 . 2010-03-17 00:14 10309448 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\chr\ChromeInstaller.exe
2010-03-17 00:12 . 2010-03-17 00:12 283280 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\carb\CarboniteSetupLiteRealPreinstaller.exe
2010-03-17 00:12 . 2010-03-17 00:12 181768 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\carb\LaunchHelper.exe
2010-03-17 00:12 . 2010-03-17 00:12 79368 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\vista.exe
2010-03-17 00:12 . 2010-03-17 00:12 52288 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\inst_config\gtapi.dll
2010-03-17 00:12 . 2010-03-17 00:12 64000 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\inst_config\gcapi_dll.dll
2010-03-17 00:12 . 2010-03-17 00:12 50688 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\inst_config\fftbapi.dll
2010-03-17 00:12 . 2010-03-17 00:12 49152 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\inst_config\CarboniteCompatibility.dll
2010-03-17 00:12 . 2010-03-17 00:12 118784 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\RUP\inst_config\compat.dll
2010-03-16 00:23 . 2010-03-27 14:17 439816 ----a-w- c:\documents and settings\Amit\Application Data\Real\Update\setup3.10\setup.exe
2010-03-11 02:33 . 2009-10-23 15:28 3558912 ------w- c:\windows\system32\dllcache\moviemk.exe
2010-03-05 19:21 . 2010-03-05 19:21 -------- d-----w- c:\program files\Seagate
2010-03-05 19:20 . 2010-03-05 19:20 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2010-02-28 02:36 . 2010-02-28 02:41 -------- d-----w- c:\documents and settings\Amit\Application Data\ImgBurn
2010-02-28 02:34 . 2010-02-28 02:34 -------- d-----w- c:\program files\ImgBurn
2010-03-29 08:01 . 2008-10-03 04:25 -------- d-----w- c:\program files\IDrive
2010-03-29 00:45 . 2006-04-08 21:19 -------- d-----w- c:\documents and settings\Amit\Application Data\Azureus
2010-03-24 00:20 . 2005-03-04 17:06 -------- d-----w- c:\program files\Dell AIO Printer A920
2010-03-21 03:01 . 2010-01-30 21:23 1474832 ----a-w- c:\windows\system32\drivers\sfi.dat
2010-03-21 01:15 . 2009-11-28 16:33 -------- d-----w- c:\documents and settings\Amit\Application Data\Skype
2010-03-21 00:28 . 2009-11-28 16:38 -------- d-----w- c:\documents and settings\Amit\Application Data\skypePM
2010-03-20 22:18 . 2009-07-28 14:33 -------- d-----w- c:\program files\iTunes
2010-03-20 22:17 . 2006-08-18 19:05 -------- d-----w- c:\program files\iPod
2010-03-20 22:17 . 2007-11-02 22:43 -------- d-----w- c:\program files\Common Files\Apple
2010-03-20 18:16 . 2007-09-12 17:34 -------- d-----w- c:\program files\PaRav
2010-03-14 20:29 . 2006-12-25 04:28 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2010-02-19 20:45 . 2009-05-23 01:53 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
2010-02-15 04:18 . 2010-02-15 02:55 -------- d-----w- c:\program files\ffdshow
2010-02-15 04:18 . 2010-02-15 02:55 -------- d-----w- c:\program files\AviSynth 2.5
2010-02-15 04:17 . 2010-02-15 04:17 -------- d-----w- c:\program files\Common Files\SourceTec
2010-02-15 04:17 . 2010-02-15 04:17 -------- d-----w- c:\program files\SourceTec
2010-02-15 03:48 . 2007-06-19 02:05 -------- d-----w- c:\documents and settings\Amit\Application Data\Vso
2010-02-15 03:47 . 2007-06-19 02:05 47360 -c--a-w- c:\documents and settings\Amit\Application Data\pcouffin.sys
2010-02-15 03:47 . 2006-04-05 02:25 47360 ----a-w- c:\windows\system32\drivers\pcouffin.sys
2010-02-15 03:47 . 2010-02-15 03:47 -------- d-----w- c:\program files\DVDFab 6
2010-02-15 03:01 . 2005-08-28 03:28 -------- d-----w- c:\documents and settings\All Users\Application Data\DVD Shrink
2010-02-15 02:55 . 2010-02-15 02:55 -------- d-----w- c:\program files\Haali
2010-02-11 18:53 . 2010-01-29 22:34 38848 ----a-w- c:\windows\system32\avastSS.scr
2010-02-11 18:53 . 2010-01-29 22:34 153184 ----a-w- c:\windows\system32\aswBoot.exe
2010-02-11 18:42 . 2010-01-29 22:35 46672 ----a-w- c:\windows\system32\drivers\aswTdi.sys
2010-02-11 18:42 . 2010-01-29 22:35 162512 ----a-w- c:\windows\system32\drivers\aswSP.sys
2010-02-11 18:39 . 2010-01-29 22:35 23376 ----a-w- c:\windows\system32\drivers\aswRdr.sys
2010-02-11 18:38 . 2010-01-29 22:35 100432 ----a-w- c:\windows\system32\drivers\aswmon2.sys
2010-02-11 18:38 . 2010-01-29 22:35 94800 ----a-w- c:\windows\system32\drivers\aswmon.sys
2010-02-11 18:38 . 2010-01-29 22:35 19024 ----a-w- c:\windows\system32\drivers\aswFsBlk.sys
2010-02-11 18:38 . 2010-01-29 22:35 28880 ----a-w- c:\windows\system32\drivers\aavmker4.sys
2010-02-10 02:40 . 2010-02-07 21:04 -------- d-----w- c:\documents and settings\Amit\Application Data\Malwarebytes
2010-02-10 02:40 . 2010-02-07 21:04 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2010-01-30 22:01 . 2010-01-30 22:01 55192 ----a-w- c:\documents and settings\Amit\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2010-01-29 22:57 . 2004-12-09 06:40 -------- d-----w- c:\documents and settings\All Users\Application Data\QuickTime
2010-01-29 22:34 . 2010-01-29 22:34 -------- d-----w- c:\program files\Alwil Software
2010-01-29 22:34 . 2010-01-29 22:34 -------- d-----w- c:\documents and settings\All Users\Application Data\Alwil Software
2010-01-29 21:01 . 2010-01-29 21:01 2747440 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_17.0.0.136\Definitions\VirusDefs\20100129.006\CCERASER.DLL
2010-01-29 21:01 . 2010-01-29 21:01 259440 ----a-w- c:\documents and settings\All Users\Application Data\Norton\{0C55C096-0F1D-4F28-AAA2-85EF591126E7}\NIS_17.0.0.136\Definitions\VirusDefs\20100129.006\ECMSVR32.DLL
2010-01-29 20:25 . 2010-01-29 20:25 -------- d-----w- c:\program files\Windows Sidebar
2009-12-31 16:50 . 2004-08-04 11:00 353792 ----a-w- c:\windows\system32\drivers\srv.sys
2008-10-29 23:25 . 2008-10-29 23:25 13706 -c--a-w- c:\program files\Common Files\vasosicuv.scr
2007-03-09 14:37 . 2007-03-09 14:37 57792 -c--a-w- c:\program files\MC
2006-07-01 12:46 . 2006-07-01 12:46 73 -c--a-w- c:\program files\cdboot.phx
2006-07-01 12:46 . 2006-07-01 12:46 389 -c--a-w- c:\program files\proginfo.txt
2006-07-01 12:46 . 2006-07-01 12:46 167936 -c--a-w- c:\program files\diskinst.exe
2006-07-01 12:46 . 2006-07-01 12:46 113 -c--a-w- c:\program files\instruct.ini
1601-01-01 00:03 . 1601-01-01 00:03 71168 --sha-w- c:\windows\SYSTEM32\nunupofa.dll
1601-01-01 00:03 . 1601-01-01 00:03 71168 --sha-w- c:\windows\SYSTEM32\zasulege.dll
2009-11-01 16:54 . 2009-10-31 16:22 45223968 --sha-w- c:\windows\SYSTEM32\DRIVERS\fidbox.dat
((((((((((((((((((((((((((((( SnapShot_2010-02-12_17.11.19 )))))))))))))))))))))))))))))))))))))))))
+ 2010-03-30 00:03 . 2010-03-30 00:03 40960 c:\windows\temp\rtdrvmon.exe
+ 2010-03-30 00:03 . 2010-03-30 00:03 16384 c:\windows\temp\Perflib_Perfdata_308.dat
- 2007-01-29 08:58 . 2009-10-28 15:07 46080 c:\windows\SYSTEM32\tzchange.exe
+ 2007-01-29 08:58 . 2010-01-23 08:11 46080 c:\windows\SYSTEM32\tzchange.exe
- 2009-12-09 02:50 . 2009-05-26 11:40 17272 c:\windows\SYSTEM32\spmsg.dll
+ 2009-12-09 02:50 . 2008-07-08 13:02 17272 c:\windows\SYSTEM32\spmsg.dll
+ 2010-02-15 02:55 . 2008-06-09 04:58 60273 c:\windows\SYSTEM32\pthreadGC2.dll
+ 2004-12-09 06:24 . 2010-03-14 17:02 75726 c:\windows\SYSTEM32\PERFC009.DAT
- 2004-12-09 06:24 . 2009-12-10 01:31 75726 c:\windows\SYSTEM32\PERFC009.DAT
- 2008-08-22 12:33 . 2009-12-20 02:57 84507 c:\windows\SYSTEM32\Macromed\Flash\uninstall_activeX.exe
+ 2008-08-22 12:33 . 2010-03-17 00:17 84507 c:\windows\SYSTEM32\Macromed\Flash\uninstall_activeX.exe
+ 2010-02-15 02:55 . 2008-12-08 18:53 57344 c:\windows\SYSTEM32\ff_vfw.dll
+ 2007-04-25 11:20 . 2007-04-25 11:20 62592 c:\windows\SYSTEM32\DLLCACHE\cdrom.sys
+ 2004-12-17 11:33 . 2010-03-28 13:31 98304 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
- 2004-12-17 11:33 . 2009-12-10 01:27 98304 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
- 2004-12-17 11:33 . 2009-12-10 01:27 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2004-12-17 11:33 . 2010-03-28 13:31 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2010-03-05 19:22 . 2010-03-05 19:22 11264 c:\windows\Installer\{98613C99-1399-416C-A07C-1EE1C585D872}\Icon98613C992.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 90112 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\xlicons.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 90112 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\xlicons.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 45056 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\wordicon.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 45056 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\wordicon.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 22528 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\unbndico.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 22528 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\unbndico.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 30720 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\pptico.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 30720 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\pptico.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 16384 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\PEicons.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 16384 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\PEicons.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 34304 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 34304 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\misc.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 81920 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\fpicon.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 81920 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\fpicon.exe
+ 2010-02-26 18:54 . 2009-10-28 15:07 46080 c:\windows\$NtUninstallKB979306$\tzchange.exe
+ 2010-02-26 18:54 . 2010-01-23 10:40 16896 c:\windows\$NtUninstallKB979306$\spuninst\tzchange.dll
+ 2010-02-26 18:59 . 2008-07-08 13:02 26488 c:\windows\$hf_mig$\KB976662-IE8\update\spcustom.dll
+ 2010-02-26 18:59 . 2008-07-08 13:02 17272 c:\windows\$hf_mig$\KB976662-IE8\spmsg.dll
+ 2005-06-15 22:04 . 2010-03-11 03:21 3584 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\opwicon.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 3584 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\opwicon.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 8192 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\mspicons.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 8192 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\mspicons.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 2560 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\cagicon.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 2560 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\cagicon.exe
+ 2004-12-09 06:24 . 2010-03-14 17:02 451968 c:\windows\SYSTEM32\PERFH009.DAT
- 2004-12-09 06:24 . 2009-12-10 01:31 451968 c:\windows\SYSTEM32\PERFH009.DAT
+ 2010-01-27 00:58 . 2010-01-27 00:58 256280 c:\windows\SYSTEM32\Macromed\Flash\FlashUtil10e.exe
+ 2004-08-04 11:00 . 2009-12-09 05:53 726528 c:\windows\SYSTEM32\jscript.dll
- 2004-08-04 11:00 . 2009-06-22 06:44 726528 c:\windows\SYSTEM32\jscript.dll
+ 2008-10-30 22:37 . 2008-10-30 22:37 922112 c:\windows\SYSTEM32\imapi2fs.dll
+ 2008-10-30 22:37 . 2008-10-30 22:37 426496 c:\windows\SYSTEM32\imapi2.dll
+ 2008-05-09 10:53 . 2009-12-09 05:53 726528 c:\windows\SYSTEM32\DLLCACHE\jscript.dll
- 2008-05-09 10:53 . 2009-06-22 06:44 726528 c:\windows\SYSTEM32\DLLCACHE\jscript.dll
+ 2008-10-30 22:37 . 2008-10-30 22:37 922112 c:\windows\SYSTEM32\DLLCACHE\imapi2fs.dll
+ 2008-10-30 22:37 . 2008-10-30 22:37 426496 c:\windows\SYSTEM32\DLLCACHE\imapi2.dll
+ 2004-05-26 12:37 . 2004-05-26 12:37 719872 c:\windows\SYSTEM32\devil.dll
+ 2008-12-21 21:46 . 2008-12-21 21:46 351744 c:\windows\SYSTEM32\avisynth.dll
+ 2010-03-05 19:22 . 2010-03-05 19:22 584704 c:\windows\Installer\d9fcc6.msi
+ 2010-03-20 21:38 . 2010-03-20 21:38 200192 c:\windows\Installer\1636526.msi
- 2005-06-15 22:04 . 2010-02-10 03:55 114688 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\outicon.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 114688 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\outicon.exe
- 2005-06-15 22:04 . 2010-02-10 03:55 167936 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\accicons.exe
+ 2005-06-15 22:04 . 2010-03-11 03:21 167936 c:\windows\Installer\{90280409-6000-11D3-8CFE-0050048383C9}\accicons.exe
+ 2010-03-20 22:19 . 2010-03-20 22:19 102400 c:\windows\Installer\{81063354-9060-42B2-A000-1EBE96778AA9}\iTunesIco.exe
+ 2010-02-26 18:59 . 2008-07-08 13:02 382840 c:\windows\ie8updates\KB976662-IE8\spuninst\updspapi.dll
+ 2010-02-26 18:59 . 2008-07-08 13:02 231288 c:\windows\ie8updates\KB976662-IE8\spuninst\spuninst.exe
+ 2010-02-26 18:59 . 2009-06-22 06:44 726528 c:\windows\ie8updates\KB976662-IE8\jscript.dll
+ 2010-02-26 18:54 . 2009-05-26 11:40 382840 c:\windows\$NtUninstallKB979306$\spuninst\updspapi.dll
+ 2010-02-26 18:54 . 2009-05-26 11:40 231288 c:\windows\$NtUninstallKB979306$\spuninst\spuninst.exe
+ 2010-02-15 02:57 . 2008-07-09 17:32 379184 c:\windows\$NtUninstallKB952011$\spuninst\updspapi.dll
+ 2010-02-15 02:57 . 2008-07-09 17:32 221488 c:\windows\$NtUninstallKB952011$\spuninst\spuninst.exe
+ 2010-02-26 18:59 . 2008-07-08 13:02 382840 c:\windows\$hf_mig$\KB976662-IE8\update\updspapi.dll
+ 2010-02-26 18:59 . 2008-07-08 13:02 755576 c:\windows\$hf_mig$\KB976662-IE8\update\update.exe
+ 2010-02-26 18:59 . 2008-07-08 13:02 231288 c:\windows\$hf_mig$\KB976662-IE8\spuninst.exe
+ 2010-02-26 16:09 . 2009-12-09 05:51 726528 c:\windows\$hf_mig$\KB976662-IE8\SP3QFE\jscript.dll
+ 2010-02-15 04:17 . 2009-08-17 15:54 1184984 c:\windows\SYSTEM32\wvc1dmod.dll
+ 2005-06-09 20:50 . 2010-03-28 22:42 5148540 c:\windows\SYSTEM32\Restore\rstrlog.dat
+ 2010-03-20 22:19 . 2010-03-20 22:19 4449280 c:\windows\Installer\180a61a.msi
+ 2010-01-28 12:17 . 2010-01-28 12:17 17510400 c:\windows\Installer\dda47d.msp
-- Snapshot reset to current date --
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{9c79fc4a-256b-424a-9362-2bcb36b93b7b}]
"{3041d03e-fd4b-44e0-b742-2d9b88305f98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2009-04-02 333192]
[HKEY_CLASSES_ROOT\clsid\{3041d03e-fd4b-44e0-b742-2d9b88305f98}]
[HKEY_CLASSES_ROOT\TypeLib\{4b1c1e16-6b34-430e-b074-5928eca4c150}]
"{3041D03E-FD4B-44E0-B742-2D9B88305F98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2009-04-02 333192]
"ares"="c:\program files\Ares\Ares.exe" [2009-02-03 1004544]
"DMXLauncher"="c:\program files\Dell\Media Experience\DMXLauncher.exe" [2004-09-15 86016]
"igfxtray"="c:\windows\system32\igfxtray.exe" [2005-10-14 94208]
"igfxhkcmd"="c:\windows\system32\hkcmd.exe" [2005-10-14 77824]
"igfxpers"="c:\windows\system32\igfxpers.exe" [2005-10-14 114688]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-05-26 185896]
"VX3000"="c:\windows\vVX3000.exe" [2009-07-24 762208]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-11-11 417792]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2010-02-15 141608]
"penekelasu"="hatutiza.dll" [BU]
"DWQueuedReporting"="c:\progra~1\COMMON~1\MICROS~1\DW\dwtrig20.exe" [2007-03-13 39264]
c:\documents and settings\Amit\Start Menu\Programs\Startup\
avast.lnk - c:\program files\Alwil Software\Avast5\AvastUI.exe [2010-1-29 2756488]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2004-12-9 24576]
BootExecute REG_MULTI_SZ \0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\SymEFA.sys]
@="FSFilter Activity Monitor"
path=
backup=
backupExtension=Common Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^802.11b+g USB Wireless LAN Utility.lnk]
backup=c:\windows\pss\802.11b+g USB Wireless LAN Utility.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Acrobat Speed Launcher.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Acrobat Speed Launcher.lnk
backup=c:\windows\pss\Adobe Acrobat Speed Launcher.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Gamma Loader.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Gamma Loader.lnk
backup=c:\windows\pss\Adobe Gamma Loader.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Amit^Start Menu^Programs^Startup^IDrive Tray.lnk]
backup=c:\windows\pss\IDrive Tray.lnkStartup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Acrobat Assistant 7.0]
2008-04-23 07:08 483328 ----a-w- c:\program files\Adobe\Acrobat 7.0\Distillr\acrotray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ares]
2009-02-03 13:22 1004544 ----a-w- c:\program files\Ares\Ares.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Dell AIO Printer A920]
2004-04-15 08:32 270336 ----a-w- c:\program files\Dell AIO Printer A920\dlbkbmgr.exe
2010-02-15 23:07 141608 ----a-w- c:\program files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LifeCam]
2009-07-24 21:05 118640 ----a-w- c:\program files\Microsoft LifeCam\LifeExp.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
2001-07-09 16:50 155648 ----a-w- c:\windows\SYSTEM32\NeroCheck.exe
2009-11-11 05:08 417792 ----a-w- c:\program files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Samsung PanelMgr]
2008-08-08 05:03 524288 ----a-w- c:\windows\Samsung\PanelMgr\SSMMgr.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Skype]
2009-10-09 19:11 25623336 ----a-r- c:\program files\Skype\Phone\Skype.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\VX3000]
2009-07-24 21:05 762208 ----a-w- c:\windows\vVX3000.exe
"c:\\WINDOWS\\system32\\sessmgr.exe"=
"c:\\WINDOWS\\kdx\\KHost.exe"=
"c:\\WINDOWS\\SYSTEM32\\LEXPPS.EXE"=
"c:\\Program Files\\IDrive\\IDriveEClassic.exe"=
"c:\\Program Files\\IDrive\\IDriveETray.exe"=
"c:\\Program Files\\BitTornado\\btdownloadgui.exe"=
"c:\\Program Files\\WLAN\\802.11b+g USB WLAN\\ZDWlan.exe"=
"c:\\Program Files\\Microsoft LifeCam\\LifeCam.exe"=
"c:\\Program Files\\Microsoft LifeCam\\LifeEnC2.exe"=
"c:\\Program Files\\Microsoft LifeCam\\LifeExp.exe"=
"c:\\Program Files\\Microsoft LifeCam\\LifeTray.exe"=
"c:\\Program Files\\Skype\\Plugin Manager\\skypePM.exe"=
"c:\\Program Files\\Ares\\Ares.exe"=
"c:\\Program Files\\Vuze\\Azureus.exe"=
"c:\\WINDOWS\\SYSTEM32\\hkcmd.exe"=
"3389:TCP"= 3389:TCP:@xpsp2res.dll,-22009
"14238:TCP"= 14238:TCP:darshmeet
"1755:TCP"= 1755:TCP:windows media player
R1 aswSP;aswSP;c:\windows\SYSTEM32\DRIVERS\aswSP.sys [1/29/2010 5:35 PM 162512]
R2 ASKService;ASKService;c:\program files\AskBarDis\bar\bin\AskService.exe [11/13/2009 9:12 PM 464264]
R2 ASKUpgrade;ASKUpgrade;c:\program files\AskBarDis\bar\bin\ASKUpgrade.exe [11/13/2009 9:13 PM 234888]
R2 aswFsBlk;aswFsBlk;c:\windows\SYSTEM32\DRIVERS\aswFsBlk.sys [1/29/2010 5:35 PM 19024]
R2 IDriveE Service;IDriveE Service;c:\program files\IDrive\IDriveE Service.exe [10/2/2008 11:25 PM 136656]
R2 IDrivePlugin;IDrivePlugin;c:\program files\IDrive\IDriveWebM.exe [10/2/2008 11:25 PM 58832]
S0 Lbd;Lbd;c:\windows\system32\DRIVERS\Lbd.sys --> c:\windows\system32\DRIVERS\Lbd.sys [?]
S0 TfFsMon;TfFsMon;c:\windows\system32\drivers\TfFsMon.sys --> c:\windows\system32\drivers\TfFsMon.sys [?]
S0 TfSysMon;TfSysMon;c:\windows\system32\drivers\TfSysMon.sys --> c:\windows\system32\drivers\TfSysMon.sys [?]
S2 SSPORT;SSPORT;\??\c:\windows\system32\Drivers\SSPORT.sys --> c:\windows\system32\Drivers\SSPORT.sys [?]
S3 TfNetMon;TfNetMon;\??\c:\windows\system32\drivers\TfNetMon.sys --> c:\windows\system32\drivers\TfNetMon.sys [?]
S3 WLAN(WLAN);802.11b+g USB Wireless LAN Adapter Driver(WLAN);c:\windows\SYSTEM32\DRIVERS\ZD1211U.sys [6/5/2005 6:18 PM 258560]
S3 ZD1201U;ZyDAS ZD1201 IEEE 802.11b Wireless LAN Driver (USB);c:\windows\system32\DRIVERS\zd1201u.sys --> c:\windows\system32\DRIVERS\zd1201u.sys [?]
S3 ZDBRGSYS;ZDBRGSYS NDIS Protocol Driver;c:\windows\SYSTEM32\ZDBRGSYS.sys [6/5/2005 6:18 PM 19200]
S3 ZDNDIS5;ZDNDIS5 NDIS Protocol Driver;\??\c:\windows\system32\ZDNDIS5.SYS --> c:\windows\system32\ZDNDIS5.SYS [?]
2009-08-04 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 18:34]
2010-02-15 c:\windows\Tasks\McDefragTask.job
- c:\windows\system32\DEFRAG.EXE [2004-08-04 00:12]
mSearch Bar =
uInternet Connection Wizard,ShellNext = [You must be registered and logged in to see this link.]
IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
IE: Convert link target to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert link target to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert selected links to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
IE: Convert selected links to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
IE: Convert selection to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert selection to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert to Adobe PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert to existing PDF - c:\program files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office10\EXCEL.EXE/3000
IE: Yahoo! &SMS - [You must be registered and logged in to see this link.] files\Yahoo!\Common/ycsms.htm
TCP: {6876C54C-08AF-4D30-8DB2-CA7CBADD2463} = 192.168.1.254,192.168.2.254
DPF: Garmin Communicator Plug-In - [You must be registered and logged in to see this link.]
Rootkit scan 2010-03-29 19:39
[HKEY_USERS\S-1-5-21-3018035710-715601661-13499995-1007\Software\Microsoft\SystemCertificates\AddressBook*]
- - - - - - - > 'explorer.exe'(2452)
c:\program files\Alwil Software\Avast5\AvastSvc.exe
c:\program files\Microsoft LifeCam\MSCamS32.exe
Completion time: 2010-03-29 19:44:00 - machine was rebooted
ComboFix-quarantined-files.txt 2010-03-30 00:43
ComboFix2.txt 2010-03-28 23:13
Pre-Run: 133,024,346,112 bytes free
Post-Run: 133,304,475,648 bytes free
- - End Of File - - 51EB7D30B5C4B9D6D136938477903390
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Tue Mar 30, 2010 2:34 am
P2P
I see you are running Ares and Vuze. I suggest to read the following, and then decided whether you want to keep it or not: [You must be registered and logged in to see this link.]
Ask Toolbar
I also recommend to uninstall Ask Toolbar, because of its bad reputation and potential adware.
ComboFix Script
  • Close any open browsers.
  • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
  • Open notepad and copy/paste the text in the box below into it:
    killall::
    File::
    Registry::
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{9c79fc4a-256b-424a-9362-2bcb36b93b7b}]
    "penekelasu"=-
    DDS::
    Rootkit::
    Reboot::
  • Save this as CFScript.txt, in the same location as ComboFix.exe
  • Referring to the picture above, drag CFScript into ComboFix.exe
  • When finished, it shall produce a log for you at C:\ComboFix.txt
  • Please post the contents of the log in your next reply.
Posts Posts : 13717
Re: mbam problem
Post by 3dsoundz on Tue Mar 30, 2010 3:12 am
Thanx for the tip about p2p but i need the 1 i have n i exactly know where this bad 1 got in from so i m doing it very carefully n slowly, i was clickin a file link n all of a sudden a pop-up came in, so by mistake hit on it n thats how got infected i m also very carefull about unwanted toolbars i thought i deleted askbar but i guess i was not gone 100% but took care of that too
below is the copy paste from combofix
ComboFix 10-03-29.02 - Amit 03/29/2010 21:54:31.10.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.2038.1528 [GMT -5:00]
Command switches used :: c:\documents and settings\Amit\My Documents\CFscript.txt
FILE ::
"c:\windows\SYSTEM32\nunupofa.dll"
"c:\windows\SYSTEM32\zasulege.dll"
2010-03-29 23:54 . 2010-03-30 00:44 -------- d-----w- C:\ComboFx25596C
2010-02-28 02:41 . 2010-02-28 02:36 -------- d-----w- c:\documents and settings\Amit\Application Data\ImgBurn
((((((((((((((((((((((((((((( SnapShot_2010-03-30_00.39.30 )))))))))))))))))))))))))))))))))))))))))
+ 2010-03-30 03:01 . 2010-03-30 03:01 40960 c:\windows\temp\rtdrvmon.exe
- 2010-03-30 00:03 . 2010-03-30 00:03 40960 c:\windows\temp\rtdrvmon.exe
+ 2010-03-30 03:01 . 2010-03-30 03:01 16384 c:\windows\temp\Perflib_Perfdata_244.dat
path=
backup=
"c:\\Program Files\\Alwil Software\\Avast5\\AvastUI.exe"=
mSearch Bar =
hidden files:
- - - - - - - > 'explorer.exe'(3348)
Completion time: 2010-03-29 22:05:42 - machine was rebooted
ComboFix-quarantined-files.txt 2010-03-30 03:05
ComboFix2.txt 2010-03-30 00:44
ComboFix3.txt 2010-03-28 23:13
Pre-Run: 132,615,516,160 bytes free
Post-Run: 132,636,561,408 bytes free
- - End Of File - - B26FB1191E2E27683CB027ADF2823DF9
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Tue Mar 30, 2010 3:33 am
Download [You must be registered and logged in to see this link.] to your Desktop
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    /md5start
    %SYSTEMDRIVE%\*.exe
    %systemroot%\system32\eventlog.dll
    %systemroot%\system32\scecli.dll
    %systemroot%\netlogon.dll
    %systemroot%\system32\cngaudit.dll
    %systemroot%\system32\sceclt.dll
    %systemroot%\ntelogon.dll
    %systemroot%\system32\logevent.dll
    %systemroot%\system32\drivers\iaStor.sys
    %systemroot%\System32\drivers\nvstor.sys
    %systemroot%\system32\drivers\atapi.sys
    /md5stop
  • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
Posts Posts : 13717
Re: mbam problem
Post by 3dsoundz on Tue Mar 30, 2010 3:41 am
log from otl.txt
OTL logfile created on: 3/29/2010 10:37:08 PM - Run 2
OTL by OldTimer - Version 3.1.37.3 Folder = C:\Documents and Settings\Amit\Desktop
2.00 Gb Total Physical Memory | 1.00 Gb Available Physical Memory | 72.00% Memory free
3.00 Gb Paging File | 2.00 Gb Available in Paging File | 86.00% Paging File free
Paging file location(s): C:\pagefile.sys 756 1512 [binary data]
Drive C: | 146.21 Gb Total Space | 123.29 Gb Free Space | 84.32% Space Free | Partition Type: NTFS
Drive F: | 465.76 Gb Total Space | 258.88 Gb Free Space | 55.58% Space Free | Partition Type: NTFS
Drive G: | 465.76 Gb Total Space | 212.52 Gb Free Space | 45.63% Space Free | Partition Type: NTFS
Computer Name: DARSHMEET
Current User Name: Amit
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: On
Skip Microsoft Files: On
File Age = 14 Days
Output = Standard
Quick Scan
PRC - [2010/03/28 20:16:07 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Amit\Desktop\OTL.exe
PRC - [2010/02/11 13:53:42 | 002,756,488 | ---- | M] (ALWIL Software) -- C:\Program Files\Alwil Software\Avast5\AvastUI.exe
PRC - [2010/02/11 13:53:39 | 000,040,384 | ---- | M] (ALWIL Software) -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
PRC - [2009/07/24 16:05:24 | 000,139,120 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft LifeCam\MSCamS32.exe
PRC - [2009/02/03 08:22:18 | 001,004,544 | ---- | M] (Ares Development Group) -- C:\Program Files\Ares\Ares.exe
PRC - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
PRC - [2008/09/30 18:36:08 | 000,136,656 | ---- | M] (Pro Softnet Corporation) -- C:\Program Files\IDrive\IDriveE Service.exe
PRC - [2008/07/01 18:52:22 | 000,058,832 | ---- | M] ( Pro-Softnet) -- C:\Program Files\IDrive\IDriveWebM.exe
PRC - [2008/05/26 10:08:26 | 000,185,896 | ---- | M] (RealNetworks, Inc.) -- C:\Program Files\Common Files\Real\Update_OB\realsched.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2004/09/15 02:01:00 | 000,086,016 | ---- | M] () -- C:\Program Files\Dell\Media Experience\DMXLauncher.exe
PRC - [2003/10/29 03:06:00 | 000,024,576 | R--- | M] (BVRP Software) -- C:\Program Files\Digital Line Detect\DLG.exe
MOD - [2010/03/28 20:16:07 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Amit\Desktop\OTL.exe
SRV - File not found [On_Demand | Stopped] -- -- (SQLAgent$SONY_MEDIAMGR)
SRV - File not found [On_Demand | Stopped] -- -- (MSSQL$SONY_MEDIAMGR)
SRV - File not found [Auto | Stopped] -- -- (KService)
SRV - File not found [Auto | Stopped] -- -- (CLTNetCnService)
SRV - File not found [Auto | Stopped] -- -- (AOL ACS)
SRV - [2010/02/11 13:53:39 | 000,040,384 | ---- | M] (ALWIL Software) [On_Demand | Running] -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe -- (avast! Web Scanner)
SRV - [2010/02/11 13:53:39 | 000,040,384 | ---- | M] (ALWIL Software) [On_Demand | Running] -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe -- (avast! Mail Scanner)
SRV - [2010/02/11 13:53:39 | 000,040,384 | ---- | M] (ALWIL Software) [Auto | Running] -- C:\Program Files\Alwil Software\Avast5\AvastSvc.exe -- (avast! Antivirus)
SRV - [2009/07/24 16:05:24 | 000,139,120 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Microsoft LifeCam\MSCamS32.exe -- (MSCamSvc)
SRV - [2008/11/09 15:48:14 | 000,602,392 | ---- | M] (Yahoo! Inc.) [Auto | Running] -- C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe -- (YahooAUService)
SRV - [2008/09/30 18:36:08 | 000,136,656 | ---- | M] (Pro Softnet Corporation) [Auto | Running] -- C:\Program Files\IDrive\IDriveE Service.exe -- (IDriveE Service)
SRV - [2008/07/01 18:52:22 | 000,058,832 | ---- | M] ( Pro-Softnet) [Auto | Running] -- C:\Program Files\IDrive\IDriveWebM.exe -- (IDrivePlugin)
SRV - [2007/10/25 15:27:54 | 000,266,240 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Live\installer\WLSetupSvc.exe -- (WLSetupSvc)
SRV - [2007/03/07 15:47:46 | 000,076,848 | ---- | M] () [On_Demand | Stopped] -- C:\Program Files\DellSupport\brkrsvc.exe -- (DSBrokerService)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,CustomSearch = [You must be registered and logged in to see this link.]
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultName = Yahoo! Search
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchMigratedDefaultURL = [You must be registered and logged in to see this link.]
O1 HOSTS File: ([2010/03/29 22:01:26 | 000,000,027 | ---- | M]) - C:\WINDOWS\SYSTEM32\DRIVERS\ETC\hosts
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKLM\..\Toolbar: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKLM\..\Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - No CLSID value found.
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {472734EA-242A-422B-ADF8-83D1E48CC825} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (Adobe PDF) - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O3 - HKCU\..\Toolbar\WebBrowser: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll (Yahoo! Inc.)
O4 - HKLM..\Run: [DMXLauncher] C:\Program Files\Dell\Media Experience\DMXLauncher.exe ()
O4 - HKLM..\Run: [TkBellExe] C:\Program Files\Common Files\Real\Update_OB\realsched.exe (RealNetworks, Inc.)
O4 - HKLM..\Run: [VX3000] C:\WINDOWS\vVX3000.exe (Microsoft Corporation)
O4 - HKCU..\Run: [ares] C:\Program Files\Ares\Ares.exe (Ares Development Group)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Digital Line Detect.lnk = C:\Program Files\Digital Line Detect\DLG.exe (BVRP Software)
O4 - Startup: C:\Documents and Settings\Amit\Start Menu\Programs\Startup\avast.lnk = C:\Program Files\Alwil Software\Avast5\AvastUI.exe (ALWIL Software)
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Main present
O8 - Extra context menu item: Convert link target to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert link target to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selected links to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selected links to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selection to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert selection to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to Adobe PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: Convert to existing PDF - C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroIEFavClient.dll (Adobe Systems Incorporated)
O8 - Extra context menu item: E&xport to Microsoft Excel - C:\Program Files\Microsoft Office\Office10\EXCEL.EXE (Microsoft Corporation)
O8 - Extra context menu item: Yahoo! &SMS - C:\Program Files\Yahoo!\Common [2009/12/19 21:57:59 | 000,000,000 | ---D | M]
O15 - HKCU\..Trusted Domains: aol.com ([objects] * is out of zone range - 5)
O16 - DPF: {01A88BB1-1174-41EC-ACCB-963509EAE56B} [You must be registered and logged in to see this link.] (SysProWmi Class)
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} [You must be registered and logged in to see this link.] (Windows Genuine Advantage Validation Tool)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} C:\Program Files\Yahoo!\Common\Yinsthelper.dll (Installation Support)
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} [You must be registered and logged in to see this link.] (Snapfish Activia)
O16 - DPF: {427273CC-764E-11D3-823D-006097F90453} [You must be registered and logged in to see this link.] (Pixami Image Editor Control)
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} [You must be registered and logged in to see this link.] (MSN Photo Upload Tool)
O16 - DPF: {5C6698D9-7BE4-4122-8EC5-291D84DBD4A0} [You must be registered and logged in to see this link.] (Facebook Photo Uploader 4 Control)
O16 - DPF: {67DABFBF-D0AB-41FA-9C46-CC0F21721616} [You must be registered and logged in to see this link.] (DivXBrowserPlugin Object)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} [You must be registered and logged in to see this link.] (Shutterfly Picture Upload Plugin)
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} [You must be registered and logged in to see this link.] (MsnMessengerSetupDownloadControl Class)
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {D4323BF2-006A-4440-A2F5-27E3E7AB25F8} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} [You must be registered and logged in to see this link.] (GpcContainer Class)
O16 - DPF: {E9A7F56F-C40F-4928-8C6F-7A72F2A25222} [You must be registered and logged in to see this link.] (AxRUploadControl Object)
O16 - DPF: Garmin Communicator Plug-In [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: Microsoft XML Parser for Java [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O18 - Protocol\Handler\skype4com {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\Program Files\Common Files\Skype\Skype4COM.dll (Skype Technologies)
O18 - Protocol\Handler\wlmailhtml {03C514A3-1EFB-4856-9F99-10D7BE1653C0} - C:\Program Files\Windows Live\Mail\mailcomm.dll (Microsoft Corporation)
O20 - Winlogon\Notify\igfxcui: DllName - igfxdev.dll - C:\WINDOWS\System32\igfxdev.dll (Intel Corporation)
O24 - Desktop WallPaper: C:\Documents and Settings\Amit\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Amit\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2010/03/27 09:35:19 | 000,000,000 | ---D | M] - F:\autorun -- [ NTFS ]
O32 - AutoRun File - [2010/03/19 17:07:18 | 000,000,000 | ---D | M] - G:\autorun -- [ NTFS ]
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
NetSvcs: 6to4 - File not found
NetSvcs: Ias - C:\WINDOWS\SYSTEM32\IAS [2004/12/09 01:09:26 | 000,000,000 | ---D | M]
NetSvcs: Iprip - File not found
NetSvcs: Irmon - File not found
NetSvcs: Wmi - C:\WINDOWS\SYSTEM32\wmi.dll (Microsoft Corporation)
MsConfig - StartUpFolder: C:^Documents and Settings^All Users^Start Menu^Programs^Startup^802.11b+g USB Wireless LAN Utility.lnk - C:\Program Files\WLAN\802.11b+g USB WLAN\ZDWlan.exe - ()
MsConfig - StartUpFolder: C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Acrobat Speed Launcher.lnk - C:\WINDOWS\Installer\{AC76BA86-1033-0000-7760-000000000002}\SC_Acrobat.exe - ()
MsConfig - StartUpFolder: C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Gamma Loader.lnk - C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe - (Adobe Systems, Inc.)
MsConfig - StartUpFolder: C:^Documents and Settings^Amit^Start Menu^Programs^Startup^IDrive Tray.lnk - C:\Program Files\IDrive\IDriveEReg2ini.exe - (Pro Softnet Corp.)
MsConfig - StartUpReg: Acrobat Assistant 7.0 - hkey= - key= - C:\Program Files\Adobe\Acrobat 7.0\Distillr\Acrotray.exe (Adobe Systems Inc.)
MsConfig - StartUpReg: ares - hkey= - key= - C:\Program Files\Ares\Ares.exe (Ares Development Group)
MsConfig - StartUpReg: Dell AIO Printer A920 - hkey= - key= - C:\Program Files\Dell AIO Printer A920\dlbkbmgr.exe (Dell Computer Corporation)
MsConfig - StartUpReg: iTunesHelper - hkey= - key= - C:\Program Files\iTunes\iTunesHelper.exe (Apple Inc.)
MsConfig - StartUpReg: LifeCam - hkey= - key= - C:\Program Files\Microsoft LifeCam\LifeExp.exe (Microsoft Corporation)
MsConfig - StartUpReg: NeroFilterCheck - hkey= - key= - File not found
MsConfig - StartUpReg: QuickTime Task - hkey= - key= - C:\Program Files\QuickTime\qttask.exe (Apple Inc.)
MsConfig - StartUpReg: Samsung PanelMgr - hkey= - key= - C:\WINDOWS\Samsung\PanelMgr\SSMMgr.exe ()
MsConfig - StartUpReg: Skype - hkey= - key= - C:\Program Files\Skype\Phone\Skype.exe (Skype Technologies S.A.)
MsConfig - StartUpReg: VX3000 - hkey= - key= - C:\WINDOWS\vVX3000.exe (Microsoft Corporation)
MsConfig - State: "system.ini" - 0
MsConfig - State: "win.ini" - 0
MsConfig - State: "bootini" - 0
MsConfig - State: "services" - 0
MsConfig - State: "startup" - 0
SafeBootMin: sermouse.sys - Driver
SafeBootMin: SymEFA.sys - FSFilter Activity Monitor
SafeBootMin: vds - Service
SafeBootMin: vga.sys - Driver
SafeBootMin: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootNet: sermouse.sys - Driver
SafeBootNet: SymEFA.sys - FSFilter Activity Monitor
SafeBootNet: vga.sys - Driver
SafeBootNet: {1a3e09be-1e45-494b-9174-d7385b45bbf5} - Reg Error: Value error.
ActiveX: {0291E591-EA41-4c82-8106-3DC6CE7F7664} - Reg Error: Value error.
ActiveX: {0430454D-47EA-11D6-AD58-00010333D0AD} - Reg Error: Value error.
ActiveX: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} - Microsoft VM
ActiveX: {10072CEC-8CC1-11D1-986E-00A0C955B42F} - Vector Graphics Rendering (VML)
ActiveX: {166B1BCA-3F9C-11CF-8075-444553540000} - Macromedia Shockwave Director 10.1
ActiveX: {1803B9EF-9905-4F34-AFC4-05D1BAB28801} - Reg Error: Value error.
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} - NetShow
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - Microsoft Windows Media Player 6.4
ActiveX: {231B1C6E-F934-42A2-92B6-C2FEFEC24276} - Reg Error: Value error.
ActiveX: {283807B5-2C60-11D0-A31D-00AA00B92C03} - DirectAnimation
ActiveX: {2A202491-F00D-11cf-87CC-0020AFEECF20} - Macromedia Shockwave Director 10.1
ActiveX: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} - Reg Error: Value error.
ActiveX: {347B0667-C7ED-429B-BDE3-CC8D3BACAA31} - Reg Error: Value error.
ActiveX: {36f8ec70-c29a-11d1-b5c7-0000f8051515} - Dynamic HTML Data Binding for Java
ActiveX: {3bf42070-b3b1-11d1-b5c5-0000f8051515} - Uniscribe
ActiveX: {4278c270-a269-11d1-b5bf-0000f8051515} - Advanced Authoring
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
ActiveX: {44BBA842-CC51-11CF-AAFA-00AA00B6015B} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} - DirectShow
ActiveX: {4EC8E993-32C1-47F5-A07A-5B0574655AD4} - Reg Error: Value error.
ActiveX: {4f216970-c90c-11d1-b5c7-0000f8051515} - DirectAnimation Java Classes
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows script 5.8
ActiveX: {573B61E6-FE24-525A-63CF-197D11B7E9C7} - Microsoft Windows Media Player
ActiveX: {5945c046-1e7d-11d1-bc44-00c04fd912be} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
ActiveX: {5A8D6EE0-3E18-11D0-821E-444553540000} - ICW
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - Microsoft Windows Media Player
ActiveX: {7131646D-CD3C-40F4-97B9-CD9E4E6262EF} - .NET Framework
ActiveX: {73FA19D0-2D75-11D2-995D-00C04F98BBC9} - Web Folders
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - c:\WINDOWS\system32\Rundll32.exe c:\WINDOWS\system32\mscories.dll,Install
ActiveX: {8b15971b-5355-4c82-8c07-7e181ea07608} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\fxsocm.inf,Fax.Install.PerUser
ActiveX: {924C1588-90C3-4910-B6CA-D57A1C0418FE} - Reg Error: Value error.
ActiveX: {94de52c8-2d59-4f1b-883e-79663d2d9a8c} - Fax Provider
ActiveX: {C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F} - .NET Framework
ActiveX: {CC2A9BA0-3BDD-11D0-821E-444553540000} - Task Scheduler
ActiveX: {D27CDB6E-AE6D-11cf-96B8-444553540000} - Adobe Flash Player
ActiveX: {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - Yahoo! Messenger
ActiveX: <{12d0ed0d-0ee0-4f90-8827-78cefb8f4988} - C:\WINDOWS\system32\ieudinit.exe
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\WINDOWS\inf\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - "C:\WINDOWS\system32\rundll32.exe" "C:\WINDOWS\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF}MICROS - RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
ActiveX: >{881dd1c5-3dcf-431b-b061-f3f88e8be88a} - %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
Drivers32: msacm.ac3acm - C:\WINDOWS\System32\AC3ACM.acm (fccHandler)
Drivers32: msacm.alf2cd - C:\WINDOWS\System32\alf2cd.acm (NCT Company)
Drivers32: msacm.iac2 - C:\WINDOWS\SYSTEM32\iac25_32.ax (Intel Corporation)
Drivers32: msacm.l3acm - C:\WINDOWS\SYSTEM32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.scg726 - C:\WINDOWS\System32\Scg726.acm (SHARP Corporation)
Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
Drivers32: msacm.trspch - C:\WINDOWS\System32\TSSOFT32.ACM (DSP GROUP, INC.)
Drivers32: msacm.voxacm160 - C:\WINDOWS\System32\vct3216.acm (Voxware, Inc.)
Drivers32: MSVideo8 - C:\WINDOWS\System32\vfwwdm32.dll (Microsoft Corporation)
Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
Drivers32: vidc.DIVX - C:\WINDOWS\System32\divx.dll (DivXNetworks, Inc.)
Drivers32: vidc.dvsd - C:\WINDOWS\System32\mcdvd_32.dll (MainConcept)
Drivers32: VIDC.FFDS - C:\WINDOWS\System32\ff_vfw.dll ()
Drivers32: vidc.iv31 - C:\WINDOWS\System32\IR32_32.DLL ()
Drivers32: vidc.iv32 - C:\WINDOWS\System32\IR32_32.DLL ()
Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
Drivers32: VIDC.MP42 - C:\WINDOWS\System32\mpg4c32.dll (Microsoft Corporation)
Drivers32: vidc.mp43 - C:\WINDOWS\System32\mpg4c32.dll (Microsoft Corporation)
Drivers32: VIDC.MPG4 - C:\WINDOWS\System32\mpg4c32.dll (Microsoft Corporation)
Drivers32: vidc.xvid - C:\WINDOWS\System32\xvidvfw.dll ()
Drivers32: wave - C:\WINDOWS\System32\SERWVDRV.DLL (Microsoft Corporation)
========== Files/Folders - Created Within 14 Days ==========
File not found -- C:\Documents and Settings\Amit\My Documents\CAUY77P4.
File not found -- C:\Documents and Settings\Amit\My Documents\CA43VRQW.
[2010/03/29 22:36:56 | 000,000,000 | -HSD | C] -- C:\RECYCLER
[2010/03/29 21:58:39 | 000,000,000 | ---D | C] -- C:\WINDOWS\temp
[2010/03/29 21:53:10 | 000,000,000 | ---D | C] -- C:\ComboFx12737C
[2010/03/29 18:54:39 | 000,000,000 | ---D | C] -- C:\ComboFx25596C
[2010/03/28 20:16:43 | 000,555,520 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Amit\Desktop\OTL.exe
[2010/03/28 18:40:24 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[2010/03/28 18:40:24 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[2010/03/28 18:40:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2010/03/28 18:40:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2010/03/28 18:20:05 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/03/28 18:20:01 | 000,019,160 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/03/28 18:20:01 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2010/03/28 17:58:01 | 000,000,000 | ---D | C] -- C:\ComboFx
[2010/03/28 17:42:09 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Amit\Application Data\AVG8
[2010/03/23 19:08:44 | 000,000,000 | --SD | C] -- C:\Documents and Settings\Amit\My Documents\My Data Sources
[2010/03/20 16:38:48 | 000,000,000 | ---D | C] -- C:\Program Files\Western Digital Corporation
[2009/10/26 22:15:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Adobe
[2009/10/26 22:15:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Threat Expert
[2007/11/09 09:10:00 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Apple
[2007/06/18 21:05:32 | 000,047,360 | ---- | C] (VSO Software) -- C:\Documents and Settings\Amit\Application Data\pcouffin.sys
[2007/05/10 12:36:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\PCHealth
[2007/04/11 11:07:46 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\McAfee.com Personal Firewall
[2007/04/11 11:07:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\SiteAdvisor
[2007/01/08 15:24:14 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Yahoo!
[2006/11/05 15:53:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Help
[2006/11/05 15:53:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Help
[2005/07/15 16:15:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\AdobeUM
[2005/07/15 16:15:33 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Adobe
[2004/12/18 15:58:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Macromedia
[1 C:\WINDOWS\System32\drivers\*.tmp files -> C:\WINDOWS\System32\drivers\*.tmp -> ]
[1 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[1 C:\*.tmp files -> C:\*.tmp -> ]
========== Files - Modified Within 14 Days ==========
[2010/03/29 22:01:53 | 000,000,227 | ---- | M] () -- C:\WINDOWS\system.ini
[2010/03/29 22:01:48 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\WPA.DBL
[2010/03/29 22:01:26 | 000,000,027 | ---- | M] () -- C:\WINDOWS\System32\drivers\ETC\hosts
[2010/03/29 22:00:57 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/03/29 22:00:49 | 000,002,048 | --S- | M] () -- C:\WINDOWS\BOOTSTAT.DAT
[2010/03/29 21:59:52 | 013,631,488 | ---- | M] () -- C:\Documents and Settings\Amit\ntuser.dat
[2010/03/29 21:59:49 | 000,000,278 | -HS- | M] () -- C:\Documents and Settings\Amit\NTUSER.INI
[2010/03/29 21:58:34 | 000,006,456 | -H-- | M] () -- C:\WINDOWS\System32\seyuliru
[2010/03/29 18:53:20 | 003,905,917 | R--- | M] () -- C:\Documents and Settings\Amit\My Documents\ComboFx.exe
[2010/03/28 19:44:43 | 000,016,555 | ---- | M] () -- C:\Documents and Settings\Amit\My Documents\0A8A4F73B9AA7482C0F8352C4E3C2522C5D190D5.torrent
[2010/03/28 18:20:07 | 000,000,696 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/03/28 17:47:46 | 000,002,137 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/03/28 13:39:08 | 000,015,534 | ---- | M] () -- C:\Documents and Settings\Amit\My Documents\[Rp] Babbu Maan - Ekam(Son Of Soil)[Cleans Covers](By.ReshamMahal)[320-VBR] Mar.2k10.torrent
[2010/03/28 10:14:46 | 000,013,312 | ---- | M] () -- C:\Documents and Settings\Amit\My Documents\EEA54D46C171621BC9E9320F29D613B5F6605080.torrent
[2010/03/27 11:02:28 | 000,029,696 | ---- | M] () -- C:\Documents and Settings\Amit\My Documents\A list of songs for Dance.doc
[2010/03/23 19:06:58 | 000,084,992 | ---- | M] () -- C:\Documents and Settings\Amit\My Documents\Panchal, Amit - 2567B - 4G-730-0039-10.doc
[2010/03/20 22:01:58 | 001,474,832 | ---- | M] () -- C:\WINDOWS\System32\drivers\sfi.dat
[2010/03/20 20:15:28 | 003,781,926 | -H-- | M] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\IconCache.db
[2010/03/20 20:08:48 | 000,002,265 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Skype.lnk
[2010/03/20 20:08:02 | 000,000,130 | ---- | M] () -- C:\WINDOWS\cfplogvw.INI
[2010/03/20 16:29:00 | 000,002,329 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\SeaTools for Windows.lnk
[2010/03/20 13:16:41 | 000,045,568 | ---- | M] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2010/03/20 13:16:41 | 000,000,116 | ---- | M] () -- C:\WINDOWS\NeroDigital.ini
[2010/03/16 20:18:27 | 000,000,824 | ---- | M] () -- C:\Documents and Settings\Amit\Start Menu\Programs\Startup\avast.lnk
[2010/03/28 19:44:41 | 000,016,555 | ---- | C] () -- C:\Documents and Settings\Amit\My Documents\0A8A4F73B9AA7482C0F8352C4E3C2522C5D190D5.torrent
[2010/03/28 18:20:07 | 000,000,696 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/03/28 13:39:19 | 000,015,534 | ---- | C] () -- C:\Documents and Settings\Amit\My Documents\[Rp] Babbu Maan - Ekam(Son Of Soil)[Cleans Covers](By.ReshamMahal)[320-VBR] Mar.2k10.torrent
[2010/03/28 10:14:45 | 000,013,312 | ---- | C] () -- C:\Documents and Settings\Amit\My Documents\EEA54D46C171621BC9E9320F29D613B5F6605080.torrent
[2010/03/27 11:02:30 | 000,029,696 | ---- | C] () -- C:\Documents and Settings\Amit\My Documents\A list of songs for Dance.doc
[2010/03/23 19:06:58 | 000,084,992 | ---- | C] () -- C:\Documents and Settings\Amit\My Documents\Panchal, Amit - 2567B - 4G-730-0039-10.doc
[2010/03/20 17:18:41 | 000,002,137 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/03/16 20:18:27 | 000,000,824 | ---- | C] () -- C:\Documents and Settings\Amit\Start Menu\Programs\Startup\avast.lnk
[2010/02/14 21:55:30 | 000,000,547 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll.manifest
[2010/02/14 21:55:29 | 000,057,344 | ---- | C] () -- C:\WINDOWS\System32\ff_vfw.dll
[2010/01/30 16:42:59 | 000,000,130 | ---- | C] () -- C:\WINDOWS\cfplogvw.INI
[2010/01/29 17:32:38 | 000,000,120 | ---- | C] () -- C:\WINDOWS\CIS_Setup_3.13.126709.581_XP_Vista_x32.INI
[2009/12/03 21:34:31 | 000,767,952 | ---- | C] () -- C:\WINDOWS\BDTSupport.dll
[2009/11/28 21:55:34 | 000,271,512 | ---- | C] () -- C:\Documents and Settings\LocalService\Local Settings\Application Data\FontCache3.0.0.0.dat
[2009/11/27 21:11:39 | 000,015,498 | ---- | C] () -- C:\WINDOWS\VX3000.ini
[2009/09/15 21:46:29 | 000,009,885 | ---- | C] () -- C:\WINDOWS\cdplayer.ini
[2009/07/30 15:11:06 | 000,176,235 | ---- | C] () -- C:\WINDOWS\System32\Primomonnt.dll
[2009/05/20 17:35:55 | 000,005,184 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\N360BUOptions.ini
[2009/03/27 08:43:05 | 000,000,295 | ---- | C] () -- C:\WINDOWS\IfoEdit.INI
[2008/11/30 19:12:48 | 000,022,723 | ---- | C] () -- C:\WINDOWS\System32\cl31cl3.dll
[2008/11/05 12:21:29 | 000,524,288 | ---- | C] () -- C:\WINDOWS\System32\xvidcore.dll
[2008/11/05 12:21:29 | 000,139,264 | ---- | C] () -- C:\WINDOWS\System32\xvidvfw.dll
[2008/10/29 18:25:09 | 000,011,700 | ---- | C] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\fyte.ban
[2008/10/29 18:25:08 | 000,017,723 | ---- | C] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\zosyqi._sy
[2008/10/29 18:25:08 | 000,014,156 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\utofiv.dll
[2008/10/29 18:25:08 | 000,014,092 | ---- | C] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\puxytaqaj.exe
[2008/10/29 18:25:08 | 000,013,706 | ---- | C] () -- C:\Program Files\Common Files\vasosicuv.scr
[2008/10/29 18:25:08 | 000,012,515 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\xonemo.db
[2008/10/29 18:25:08 | 000,011,886 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\itihelymy.com
[2008/10/02 23:25:09 | 000,055,808 | ---- | C] () -- C:\WINDOWS\System32\zlib1.dll
[2008/01/11 17:57:24 | 000,000,055 | ---- | C] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\is_downloader.txt
[2007/06/18 21:05:34 | 000,000,034 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\pcouffin.log
[2007/06/18 21:05:32 | 000,007,887 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\pcouffin.cat
[2007/06/18 21:05:32 | 000,001,144 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\pcouffin.inf
[2007/03/09 09:37:48 | 000,057,792 | ---- | C] () -- C:\Program Files\MC
[2007/02/13 22:57:08 | 000,000,040 | -HS- | C] () -- C:\Documents and Settings\Amit\Application Data\.zreglib
[2007/01/18 23:08:14 | 000,000,080 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\.zreglib
[2006/10/12 20:51:44 | 000,000,206 | ---- | C] () -- C:\WINDOWS\System32\MRT.INI
[2006/07/18 21:48:00 | 000,065,536 | ---- | C] () -- C:\WINDOWS\System32\YCRWin32.dll
[2006/07/01 07:46:58 | 000,167,936 | ---- | C] () -- C:\Program Files\diskinst.exe
[2006/07/01 07:46:58 | 000,000,389 | ---- | C] () -- C:\Program Files\proginfo.txt
[2006/07/01 07:46:58 | 000,000,113 | ---- | C] () -- C:\Program Files\instruct.ini
[2006/07/01 07:46:58 | 000,000,073 | ---- | C] () -- C:\Program Files\cdboot.phx
[2006/04/22 15:40:18 | 000,001,755 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\QTSBandwidthCache
[2006/02/02 08:39:08 | 000,210,944 | ---- | C] () -- C:\WINDOWS\System32\Msvcrt10.dll
[2005/12/21 21:10:27 | 000,765,952 | ---- | C] () -- C:\WINDOWS\System32\tvqenc.dll
[2005/12/21 21:10:26 | 000,233,472 | ---- | C] () -- C:\WINDOWS\System32\lame_enc.dll
[2005/12/10 20:12:11 | 000,000,026 | ---- | C] () -- C:\WINDOWS\dvdSanta.INI
[2005/12/09 17:48:40 | 000,000,116 | ---- | C] () -- C:\WINDOWS\NeroDigital.ini
[2005/09/25 11:16:55 | 000,000,000 | ---- | C] () -- C:\WINDOWS\MusicEditor.INI
[2005/07/07 12:24:27 | 000,045,568 | ---- | C] () -- C:\Documents and Settings\Amit\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2005/06/25 13:02:00 | 000,000,000 | ---- | C] () -- C:\WINDOWS\AudStu.INI
[2005/06/25 12:57:36 | 000,000,000 | ---- | C] () -- C:\WINDOWS\netMedic.INI
[2005/06/25 12:48:34 | 000,012,499 | ---- | C] () -- C:\WINDOWS\System32\EONSYSREV_1.DLL
[2005/06/23 20:39:04 | 000,000,024 | ---- | C] () -- C:\WINDOWS\magix.ini
[2005/06/21 20:05:47 | 000,000,210 | ---- | C] () -- C:\WINDOWS\CleaningLab.INI
[2005/06/21 18:02:31 | 000,019,968 | ---- | C] () -- C:\WINDOWS\System32\cpuinf32.dll
[2005/06/21 18:00:14 | 000,000,919 | ---- | C] () -- C:\WINDOWS\mgxoschk.ini
[2005/06/15 17:04:35 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2005/06/13 20:16:08 | 000,000,004 | ---- | C] () -- C:\WINDOWS\msoffice.ini
[2005/06/05 18:18:38 | 000,028,672 | ---- | C] () -- C:\WINDOWS\System32\InsDrvZD.dll
[2005/03/04 12:54:02 | 000,000,049 | ---- | C] () -- C:\WINDOWS\lexstat.ini
[2005/03/04 12:07:46 | 000,000,456 | ---- | C] () -- C:\WINDOWS\dellstat.ini
[2004/12/19 19:41:10 | 000,061,678 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\PFP120JPR.{PB
[2004/12/19 19:41:10 | 000,012,358 | ---- | C] () -- C:\Documents and Settings\Amit\Application Data\PFP120JCM.{PB
[2004/12/17 18:44:47 | 000,001,233 | ---- | C] () -- C:\WINDOWS\winamp.ini
[2004/12/09 01:42:09 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2004/12/09 01:37:34 | 000,000,138 | ---- | C] () -- C:\WINDOWS\wininit.ini
[2004/12/09 01:11:28 | 000,000,520 | ---- | C] () -- C:\WINDOWS\System32\OEMINFO.INI
[2004/09/15 23:03:14 | 000,000,000 | ---- | C] () -- C:\WINDOWS\System32\px.ini
[2004/08/10 14:13:12 | 000,000,780 | ---- | C] () -- C:\WINDOWS\ORUN32.INI
[2004/08/04 06:00:00 | 000,001,793 | ---- | C] () -- C:\WINDOWS\System32\FXSPERF.INI
[2003/01/07 16:15:26 | 000,000,255 | ---- | C] () -- C:\WINDOWS\System32\dlbkcoin.ini
[2002/11/13 14:40:22 | 000,040,960 | ---- | C] () -- C:\WINDOWS\System32\dlbkvs.dll
[1980/01/01 01:00:00 | 000,012,288 | ---- | C] () -- C:\WINDOWS\System32\e100bmsg.dll
[2009/08/21 09:44:03 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\3F
[2010/01/29 17:34:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Alwil Software
[2009/08/29 19:16:37 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Azureus
[2009/09/15 21:45:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\FreeRIP
[2006/05/01 09:32:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\HotSync
[2009/11/28 21:33:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Native Instruments
[2006/08/26 20:09:56 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Sony
[2010/03/14 15:29:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\TEMP
[2007/06/20 16:00:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\vsosdk
[2008/10/06 18:59:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{3276BE95_AF08_429F_A64F_CA64CB79BCF6}
[2009/11/29 13:52:06 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{3689B77C-90FA-4663-91AB-5AB34383CD81}
[2009/11/28 21:33:14 | 000,000,000 | -H-D | M] -- C:\Documents and Settings\All Users\Application Data\{442B6EC3-77A0-4817-825F-67F47D7A2E54}
[2009/10/20 20:29:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
[2009/04/14 11:13:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{8CD7F5AF-ECFA-4793-BF40-D8F42DBFF906}
[2009/03/20 07:58:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\{92E7A367-8E12-4830-AA70-29C32E331A81}
[2005/07/13 21:54:16 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\.ABC 3.01
[2009/11/21 23:45:24 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\.BitTornado
[2009/12/04 10:28:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Auslogics
[2010/03/28 19:45:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Azureus
[2008/12/18 12:09:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
[2006/05/01 09:30:18 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\HotSync
[2010/02/27 21:41:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\ImgBurn
[2004/12/17 17:21:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Leadertech
[2010/01/10 21:39:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Mp3tag
[2007/04/11 17:19:09 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\MSNInstaller
[2007/04/11 18:20:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Musicmatch
[2006/08/19 21:19:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\NetMedia Providers
[2005/06/16 07:09:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\ParkerVision
[2006/08/19 21:19:38 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Publish Providers
[2009/10/03 10:30:02 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Sony
[2009/12/04 13:05:39 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\TweakNow PowerPack 2009
[2006/04/04 20:58:51 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Video DVD Maker FREE
[2010/02/14 22:48:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Amit\Application Data\Vso
[2010/02/15 02:00:00 | 000,000,262 | -H-- | M] () -- C:\WINDOWS\Tasks\McDefragTask.job
@Alternate Data Stream - 300 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:DFC5A2B2
@Alternate Data Stream - 141 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:2D6E5D55
@Alternate Data Stream - 114 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:A8ADE5D8
@Alternate Data Stream - 109 bytes -> C:\Documents and Settings\All Users\Application Data\TEMP:3EFB0FE0
3dsoundz
Posts Posts : 127
Joined Joined : 2009-10-26
OS OS : win xp sp3
Points Points : 27678
Re: mbam problem
Post by 3dsoundz on Tue Mar 30, 2010 3:44 am
i didnt get any extra.txt log ?
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Tue Mar 30, 2010 3:56 am
  • Click Start
  • Click Start
Posts Posts : 13717
Points Points : 302127
Re: mbam problem
Post by 3dsoundz on Wed Mar 31, 2010 2:43 am
bellow is the copyy paste of eset log i didnt get any popup notepad log but i did copy from list at end of scan and i asked the software to delete from qurantine list
C:\Documents and Settings\Amit\My Documents\Acid Pro 6.0 + Keygen\keygen.exe probably a variant of Win32/Agent trojan cleaned by deleting - quarantined
C:\Documents and Settings\Amit\My Documents\Setup files\freeripmp3.exe a variant of Win32/Adware.ADON application deleted - quarantined
C:\Qoobox\Quarantine\C\WINDOWS\SYSTEM32\hatutiza.dll.vir a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\WINDOWS\SYSTEM32\nunupofa.dll.vir a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\WINDOWS\SYSTEM32\sofodowi.dll.vir a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\Qoobox\Quarantine\C\WINDOWS\SYSTEM32\zasulege.dll.vir a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP92\A0037694.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP92\A0037695.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP93\A0038096.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP93\A0038099.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP95\A0038481.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP95\A0038484.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP95\A0039209.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
C:\System Volume Information\_restore{202550A8-7A33-4BCA-9586-051D24DDBF8F}\RP95\A0039210.dll a variant of Win32/Kryptik.DCP trojan cleaned by deleting - quarantined
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Wed Mar 31, 2010 3:57 am
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 13717
Re: mbam problem
Post by 3dsoundz on Thu Apr 01, 2010 2:28 am
here is the final log
Results of screen317's Security Check version 0.99.2
Windows XP Service Pack 3
Internet Explorer 8
Antivirus/Firewall Check:
Windows Firewall Enabled!
avast! Free Antivirus
ESET Online Scanner v3
CCleaner
Advanced Disk Cleaner
Java(TM) 6 Update 17
Out of date Java installed!
Adobe Flash Player 10
Process Check:
objlist.exe by Laurent
Alwil Software Avast5 AvastSvc.exe
Alwil Software Avast5 AvastUI.exe
DNS Vulnerability Check:
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Thu Apr 01, 2010 4:09 am
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13717
Re: mbam problem
Post by 3dsoundz on Fri Apr 02, 2010 1:31 pm
Thanx for all the tips i have removed old java and got the new 1. About the firewall and aniviruses or adware malware etc is ok if i use avast or avg (both free versions) i have mbam i had comodo but its seemed too complicated unless u suggest to get reed of avast and avg and just go with comodo please reply as a second opinion. i dont go crazy with surffing so i dont run across many bad situations i m a DJ so sometimes customers ask for certain songs n thats when i have to surf around to look for those songs THANX
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Fri Apr 02, 2010 1:40 pm
Go with Avast for antivirus. Not AVG.
For a firewall, go with Online Armor. Tallemu.com
Posts Posts : 13717
Re: mbam problem
Post by 3dsoundz on Fri Apr 02, 2010 2:09 pm
thanx again i guess we r done here so u can close this thread
3dsoundz
Posts Posts : 127
OS OS : win xp sp3
Re: mbam problem
Post by Dr Jay on Fri Apr 02, 2010 2:57 pm
ok
Posts Posts : 13717
