malware and key logger issues
Post by bottocino on 21st March 2010, 5:21 pm
I have been infected with a keylogger and some other malware on my pc. I tried to activate malware malwarebytes that I previously loaded and it would not open up. I downloaded the latest version of malrware malwarebytes to see if that would help and it won't install the new version. It asks me what program to use to install the program. I also can't use add/remove programs in the control panel. When I tried to click on add/ remove programs. I get the error message "application not found" My firefox browser has been made unoperable but my explorer still works. I hope I have given you enough info to get me started on the recovery road. If not, ask away I will get you all the info I can.
Thanks you guys are the best!
bottocino
Posts Posts : 38
Joined Joined : 2009-01-07
OS OS : windows xp
Points Points : 29256
Re: malware and key logger issues
Post by Dr Jay on 21st March 2010, 8:46 pm
Download [You must be registered and logged in to see this link.] to your Desktop
    netsvcs
    msconfig
    safebootminimal
    safebootnetwork
    activex
    drivers32
    %SYSTEMDRIVE%\*.exe
    %systemroot%\*. /mp /s
    c:\$recycle.bin\*.* /s
    /md5start
    eventlog.dll
    scecli.dll
    netlogon.dll
    cngaudit.dll
    sceclt.dll
    ntelogon.dll
    logevent.dll
    iaStor.sys
    nvstor.sys
    nvstor32.sys
    atapi.sys
    IdeChnDr.sys
    viasraid.sys
    AGP440.sys
    vaxscsi.sys
    nvatabus.sys
    viamraid.sys
    nvata.sys
    nvgts.sys
    iastorv.sys
    ViPrt.sys
    eNetHook.dll
    explorer.exe
    svchost.exe
    userinit.exe
    qmgr.dll
    ws2_32.dll
    proquota.exe
    imm32.dll
    kernel32.dll
    ndis.sys
    autochk.exe
    spoolsv.exe
    xmlprov.dll
    ntmssvc.dll
    mswsock.dll
    Beep.SYS
    ntfs.sys
    termsrv.dll
    sfcfiles.dll
    st3shark.sys
    ahcix86.sys
    srsvc.dll
    nvrd32.sys
    /md5stop
  • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
Posts Posts : 14317
Points Points : 303008
Post by bottocino on 22nd March 2010, 3:18 am
DMJ, I was able to download the OTL program. i am unable to run it. I believe the reason is that the program has an unknown publisher. When i click on the icon and hit run, it asks me what program to open the file with. I have tried various ones with no luck. anything else I can try?
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 22nd March 2010, 2:30 pm
RKill by Grinler
  • Download Link #1.
    If you are using Vista please right click and run as Admin!
  • A black screen will briefly flash indicating a successful run.
  • If this does not occur please delete that application and download Link #2.
  • Continue process until the tool runs.
  • If the tool does not run from any of the links tell me about it.
Then, please try again.
Posts Posts : 14317
Post by bottocino on 22nd March 2010, 11:33 pm
DMJ,
I ran it off of the first link and it flashed the black dos screen. then it showed some processes that were stopped in a note pad window. I could assume to go back to step 1 that you originally stated but i will wait for your instruction to do so.
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 22nd March 2010, 11:53 pm
Please try OTL now.
Posts Posts : 14317
Post by bottocino on 23rd March 2010, 1:46 am
OTL logfile created on: 3/22/2010 8:34:28 PM - Run 1
OTL by OldTimer - Version 3.1.37.3 Folder = C:\Documents and Settings\Administrator\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
3.00 Gb Total Physical Memory | 3.00 Gb Available Physical Memory | 86.00% Memory free
5.00 Gb Paging File | 5.00 Gb Available in Paging File | 93.00% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 127.99 Gb Total Space | 17.70 Gb Free Space | 13.83% Space Free | Partition Type: NTFS
Computer Name: T-3D7D0F55343C4
Current User Name: Administrator
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: On
Skip Microsoft Files: On
File Age = 14 Days
Output = Standard
Quick Scan
PRC - [2010/03/21 22:13:19 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
PRC - [2010/01/31 12:41:45 | 002,326,920 | ---- | M] (Acronis) -- C:\Program Files\Common Files\Acronis\CDP\afcdpsrv.exe
PRC - [2009/11/12 14:48:56 | 000,071,096 | ---- | M] () -- C:\Program Files\CDBurnerXP\NMSAccessU.exe
PRC - [2009/10/29 07:54:44 | 001,218,008 | ---- | M] (McAfee, Inc.) -- c:\Program Files\McAfee.com\Agent\mcagent.exe
PRC - [2009/10/27 12:19:46 | 000,895,696 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\MPF\MpfSrv.exe
PRC - [2009/09/16 10:22:08 | 000,144,704 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\VirusScan\Mcshield.exe
PRC - [2009/09/16 09:28:38 | 000,606,736 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\VirusScan\mcsysmon.exe
PRC - [2009/09/12 17:31:36 | 000,357,384 | ---- | M] (Acronis) -- C:\Program Files\Common Files\Acronis\Schedule2\schedhlp.exe
PRC - [2009/07/10 00:26:20 | 000,865,832 | ---- | M] (McAfee, Inc.) -- C:\Program Files\McAfee\MSC\mcmscsvc.exe
PRC - [2009/07/08 11:54:34 | 000,359,952 | ---- | M] (McAfee, Inc.) -- c:\Program Files\Common Files\McAfee\McProxy\McProxy.exe
PRC - [2009/07/07 19:10:02 | 002,482,848 | ---- | M] (McAfee, Inc.) -- c:\Program Files\Common Files\McAfee\MNA\McNASvc.exe
PRC - [2008/09/24 20:35:14 | 000,068,136 | ---- | M] () -- C:\Program Files\GIGABYTE\EnergySaver\GSvr.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
MOD - [2010/03/21 22:13:19 | 000,555,520 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
SRV - File not found [Disabled | Stopped] -- -- (ASKUpgrade)
SRV - File not found [Disabled | Stopped] -- -- (ASKService)
SRV - [2010/01/31 12:41:45 | 002,326,920 | ---- | M] (Acronis) [Auto | Running] -- C:\Program Files\Common Files\Acronis\CDP\afcdpsrv.exe -- (afcdpsrv)
SRV - [2009/11/12 14:48:56 | 000,071,096 | ---- | M] () [Auto | Running] -- C:\Program Files\CDBurnerXP\NMSAccessU.exe -- (NMSAccessU)
SRV - [2009/10/27 12:19:46 | 000,895,696 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\MPF\MPFSrv.exe -- (mpfservice)
SRV - [2009/09/16 11:23:32 | 000,365,072 | ---- | M] (McAfee, Inc.) [On_Demand | Stopped] -- C:\Program Files\McAfee\VirusScan\mcods.exe -- (mcods)
SRV - [2009/09/16 10:22:08 | 000,144,704 | ---- | M] (McAfee, Inc.) [Unknown | Running] -- C:\Program Files\McAfee\VirusScan\Mcshield.exe -- (mcshield)
SRV - [2009/09/16 09:28:38 | 000,606,736 | ---- | M] (McAfee, Inc.) [On_Demand | Running] -- C:\Program Files\McAfee\VirusScan\mcsysmon.exe -- (mcsysmon)
SRV - [2009/09/12 17:31:30 | 000,660,520 | ---- | M] (Acronis) [Auto | Stopped] -- C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe -- (AcrSch2Svc)
SRV - [2009/07/10 00:26:20 | 000,865,832 | ---- | M] (McAfee, Inc.) [Auto | Running] -- C:\Program Files\McAfee\MSC\mcmscsvc.exe -- (mcmscsvc)
SRV - [2009/07/08 11:54:34 | 000,359,952 | ---- | M] (McAfee, Inc.) [Auto | Running] -- c:\Program Files\Common Files\McAfee\McProxy\McProxy.exe -- (mcproxy)
SRV - [2009/07/07 19:10:02 | 002,482,848 | ---- | M] (McAfee, Inc.) [Auto | Running] -- c:\Program Files\Common Files\McAfee\MNA\McNASvc.exe -- (mcnasvc)
SRV - [2009/03/03 14:53:32 | 000,033,176 | ---- | M] (NOS Microsystems Ltd.) [On_Demand | Stopped] -- C:\Program Files\NOS\bin\getPlus_HelperSvc.exe -- (getPlus(R) Helper) getPlus(R)
SRV - [2008/09/24 20:35:14 | 000,068,136 | ---- | M] () [Auto | Running] -- C:\Program Files\GIGABYTE\EnergySaver\GSvr.exe -- (GEST Service)
SRV - [2005/10/06 21:12:30 | 000,855,552 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Media Connect 2\wmccds.exe -- (WMConnectCDS)
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,AlwaysUseDefaultPrinter = yes
========== FireFox ==========
FF - prefs.js..browser.search.defaultenginename: "Ask"
FF - prefs.js..browser.search.order.1: "Ask"
FF - prefs.js..browser.search.selectedEngine: "Wikipedia (en)"
FF - prefs.js..browser.startup.homepage: "[You must be registered and logged in to see this link.]
FF - prefs.js..extensions.enabledItems: {E9A1DEE0-C623-4439-8932-001E7D17607D}:2.1.0.5
FF - prefs.js..extensions.enabledItems: {B2327FA5-6D21-49BE-99EF-FA323C3954E2}:1.0
FF - prefs.js..keyword.URL: "http://toolbar.ask.com/toolbarv/askRedirect?o=10607&gct=&gc=1&q="
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/02/21 12:38:28 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.8\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/02/21 12:38:28 | 000,000,000 | ---D | M]
[2009/03/29 15:06:15 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Extensions
[2009/03/22 08:18:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Extensions\mozswing@mozswing.org
[2010/03/21 07:41:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions
[2009/12/31 22:16:48 | 000,000,000 | ---D | M] (Microsoft .NET Framework Assistant) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{20a82645-c095-46ed-80e3-08825760534b}
[2009/03/22 02:08:26 | 000,000,000 | ---D | M] (Yahoo! Toolbar) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{635abd67-4fe9-1b23-4f01-e679fa7484c1}
[2009/05/16 17:27:03 | 000,000,000 | ---D | M] (Adobe DLM (powered by getPlus(R))) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{CF40ACC5-E1BB-4aff-AC72-04C2F616BCA7}
[2009/03/27 10:40:51 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}
[2009/03/27 11:57:23 | 000,000,681 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\searchplugins\ask.xml
[2010/03/20 21:14:53 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2009/05/16 21:24:40 | 000,000,000 | ---D | M] (XUL Cache) -- C:\Program Files\Mozilla Firefox\extensions\{B2327FA5-6D21-49BE-99EF-FA323C3954E2}
O1 HOSTS File: ([2009/05/26 22:28:26 | 000,000,027 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (Groove GFS Browser Helper) - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O2 - BHO: (scriptproxy) - {7db2d5a0-7241-4e79-b68d-6309f01c5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll (McAfee, Inc.)
O4 - HKLM..\Run: [36X Raid Configurer] C:\WINDOWS\System32\xRaidSetup.exe (Gigabyte Technology Corp.)
O4 - HKLM..\Run: [Acronis Scheduler2 Service] C:\Program Files\Common Files\Acronis\Schedule2\schedhlp.exe (Acronis)
O4 - HKLM..\Run: [Adobe Reader Speed Launcher] C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [AlcWzrd] C:\WINDOWS\alcwzrd.exe (RealTek Semicoductor Corp.)
O4 - HKLM..\Run: [googletalk] C:\Program Files\Google\Google Talk\googletalk.exe (Google)
O4 - HKLM..\Run: [JMB36X IDE Setup] C:\WINDOWS\RaidTool\xInsIDE.exe ()
O4 - HKLM..\Run: [KernelFaultCheck] File not found
O4 - HKLM..\Run: [MBBalloon] C:\Program Files\HOTALBUMMyBOX\MBBalloon.exe (PLANNING Co., Ltd.)
O4 - HKLM..\Run: [mcagent_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe (McAfee, Inc.)
O4 - HKLM..\Run: [Samsung PanelMgr] C:\WINDOWS\Samsung\PanelMgr\SSMMgr.exe ()
O4 - HKLM..\Run: [SoundMan] C:\WINDOWS\SoundMan.exe (Realtek Semiconductor Corp.)
O4 - HKLM..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe (Advanced Micro Devices, Inc.)
O4 - HKLM..\Run: [TrueImageMonitor.exe] C:\Program Files\Acronis\TrueImageHome\TrueImageMonitor.exe (Acronis)
O4 - HKCU..\Run: [SansaDispatch] C:\Documents and Settings\Administrator\Application Data\SanDisk\Sansa Updater\SansaDispatch.exe (SanDisk Corporation)
O4 - Startup: C:\Documents and Settings\Administrator\Start Menu\Programs\Startup\Check for TWS Updates.lnk = C:\Jts\WiseUpdt.exe ()
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\MediaChecker.lnk = C:\Program Files\HOTALBUMMyBOX\MediaChecker.exe (PLANNING Co., Ltd)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\TransactNOW Monitor.lnk = C:\Program Files\AMS Services\TransactNOW\OALaunch.exe (Vertafore Inc. d/b/a AMS Services)
O7 - HKCU\Software\Policies\Microsoft\Internet Explorer\control panel present
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoResolveTrack = 1
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: LinkResolveIgnoreLinkInfo = 1
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoResolveSearch = 1
O7 - HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoLowDiskSpaceChecks = 1
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra Button: PokerStars.net - {FA9B9510-9FCB-4ca0-818C-5D0987B47C4D} - C:\Program Files\PokerStars.NET\PokerStarsUpdate.exe (PokerStars)
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} [You must be registered and logged in to see this link.] (WUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_12)
O16 - DPF: {CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_12)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_12)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 68.87.72.134 68.87.77.134
O18 - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll (Microsoft Corporation)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
O24 - Desktop WallPaper: C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O28 - HKLM ShellExecuteHooks: {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2009/03/21 23:35:24 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O37 - HKLM\...com [@ = ComFile] -- "%1" %*
NetSvcs: 6to4 - File not found
NetSvcs: Ias - C:\WINDOWS\system32\ias [2009/03/21 23:34:50 | 000,000,000 | ---D | M]
NetSvcs: Iprip - File not found
NetSvcs: Irmon - File not found
SafeBootMin: mcmscsvc - C:\Program Files\McAfee\MSC\mcmscsvc.exe (McAfee, Inc.)
SafeBootMin: mcods - C:\Program Files\McAfee\VirusScan\mcods.exe (McAfee, Inc.)
SafeBootMin: sermouse.sys - Driver
SafeBootMin: vds - Service
SafeBootMin: vga.sys - Driver
SafeBootMin: {533C5B84-EC70-11D2-9505-00C04F79DEAF} - Volume shadow copy
SafeBootNet: mcmscsvc - C:\Program Files\McAfee\MSC\mcmscsvc.exe (McAfee, Inc.)
SafeBootNet: mcods - C:\Program Files\McAfee\VirusScan\mcods.exe (McAfee, Inc.)
SafeBootNet: mpfservice - C:\Program Files\McAfee\MPF\MPFSrv.exe (McAfee, Inc.)
SafeBootNet: sermouse.sys - Driver
SafeBootNet: vga.sys - Driver
ActiveX: {08B0E5C0-4FCB-11CF-AAA5-00401C608500} - Java (Sun)
ActiveX: {10072CEC-8CC1-11D1-986E-00A0C955B42F} - Vector Graphics Rendering (VML)
ActiveX: {2179C5D3-EBFF-11CF-B6FD-00AA00B4E220} - NetShow
ActiveX: {22d6f312-b0f6-11d0-94ab-0080c74c7e95} - Microsoft Windows Media Player 6.4
ActiveX: {283807B5-2C60-11D0-A31D-00AA00B92C03} - DirectAnimation
ActiveX: {36f8ec70-c29a-11d1-b5c7-0000f8051515} - Dynamic HTML Data Binding for Java
ActiveX: {3bf42070-b3b1-11d1-b5c5-0000f8051515} - Uniscribe
ActiveX: {4278c270-a269-11d1-b5bf-0000f8051515} - Advanced Authoring
ActiveX: {44BBA840-CC51-11CF-AAFA-00AA00B6015C} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:OE /CALLER:WINNT /user /install
ActiveX: {44BBA842-CC51-11CF-AAFA-00AA00B6015B} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msnetmtg.inf,NetMtg.Install.PerUser.NT
ActiveX: {44BBA848-CC51-11CF-AAFA-00AA00B6015C} - DirectShow
ActiveX: {4f216970-c90c-11d1-b5c7-0000f8051515} - DirectAnimation Java Classes
ActiveX: {4f645220-306d-11d2-995d-00c04f98bbc9} - Microsoft Windows script 5.6
ActiveX: {5945c046-1e7d-11d1-bc44-00c04fd912be} - rundll32.exe advpack.dll,LaunchINFSection C:\WINDOWS\INF\msmsgs.inf,BLC.QuietInstall.PerUser
ActiveX: {5A8D6EE0-3E18-11D0-821E-444553540000} - ICW
ActiveX: {6BF52A52-394A-11d3-B153-00C04F79FAA6} - Microsoft Windows Media Player
ActiveX: {7131646D-CD3C-40F4-97B9-CD9E4E6262EF} - .NET Framework
ActiveX: {73fa19d0-2d75-11d2-995d-00c04f98bbc9} - Web Folders
ActiveX: {7790769C-0471-11d2-AF11-00C04FA35D02} - "%ProgramFiles%\Outlook Express\setup50.exe" /APP:WAB /CALLER:WINNT /user /install
ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} - C:\WINDOWS\system32\ie4uinit.exe -BaseSettings
ActiveX: {89B4C1CD-B018-4511-B0A1-5476DBF70820} - c:\WINDOWS\system32\Rundll32.exe c:\WINDOWS\system32\mscories.dll,Install
ActiveX: {C09FB3CD-3D0C-3F2D-899A-6A1D67F2073F} - .NET Framework
ActiveX: {CC2A9BA0-3BDD-11D0-821E-444553540000} - Task Scheduler
ActiveX: {D27CDB6E-AE6D-11CF-96B8-444553540000} - Macromedia Shockwave Flash
ActiveX: {EF289A85-8E57-408d-BE47-73B55609861A} - RootsUpdate
ActiveX: <{12d0ed0d-0ee0-4f90-8827-78cefb8f4988} - C:\WINDOWS\system32\ieudinit.exe
ActiveX: >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} - C:\WINDOWS\inf\unregmp2.exe /ShowWMP
ActiveX: >{26923b43-4d38-484f-9b9e-de460746276c} - C:\WINDOWS\system32\ie4uinit.exe -UserIconConfig
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF} - "C:\WINDOWS\system32\rundll32.exe" "C:\WINDOWS\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
ActiveX: >{60B49E34-C7CC-11D0-8953-00A0C90347FF}MICROS - RunDLL32 IEDKCS32.DLL,BrandIE4 SIGNUP
ActiveX: >{881dd1c5-3dcf-431b-b061-f3f88e8be88a} - %systemroot%\system32\shmgrate.exe OCInstallUserConfigOE
Drivers32: msacm.ac3filter - C:\WINDOWS\System32\ac3filter.acm ()
Drivers32: msacm.iac2 - C:\WINDOWS\system32\iac25_32.ax (Intel Corporation)
Drivers32: msacm.l3acm - C:\WINDOWS\system32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
Drivers32: msacm.sl_anet - C:\WINDOWS\System32\sl_anet.acm (Sipro Lab Telecom Inc.)
Drivers32: msacm.trspch - C:\WINDOWS\System32\tssoft32.acm (DSP GROUP, INC.)
Drivers32: vidc.cvid - C:\WINDOWS\System32\iccvid.dll (Radius Inc.)
Drivers32: vidc.iv31 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv32 - C:\WINDOWS\System32\ir32_32.dll ()
Drivers32: vidc.iv41 - C:\WINDOWS\System32\ir41_32.ax (Intel Corporation)
Drivers32: vidc.iv50 - C:\WINDOWS\System32\ir50_32.dll (Intel Corporation)
========== Files/Folders - Created Within 14 Days ==========
File not found -- C:\Documents and Settings\Administrator\Local Settings\Application Data\MSASCui.exe
[2010/03/21 22:13:09 | 000,555,520 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Administrator\Desktop\OTL.exe
[2010/03/21 11:54:57 | 000,908,248 | ---- | C] (Mozilla Corporation) -- C:\Documents and Settings\Administrator\Desktop\firefox.exe
[2010/03/18 19:23:34 | 005,115,824 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\Administrator\Desktop\mbam-setup.exe
[2010/03/17 21:36:41 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\XoftSpySE
[2010/03/17 21:22:16 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Administrator\Recent
[2010/03/17 21:21:17 | 000,000,000 | -HSD | C] -- C:\Documents and Settings\Administrator\IECompatCache
[2010/01/21 21:56:55 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2009/03/21 23:41:25 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2009/03/21 23:35:21 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[2009/03/21 23:35:21 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[5 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[2 C:\Documents and Settings\Administrator\*.tmp files -> C:\Documents and Settings\Administrator\*.tmp -> ]
[1 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
========== Files - Modified Within 14 Days ==========
[2010/03/22 18:31:20 | 000,363,008 | ---- | M] () -- C:\Documents and Settings\Administrator\Desktop\rkill.pif
[2010/03/22 18:28:23 | 000,011,657 | ---- | M] () -- C:\WINDOWS\System32\Config.MPF
[2010/03/22 18:27:57 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/03/22 18:27:55 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/03/22 18:27:53 | 000,151,824 | ---- | M] () -- C:\WINDOWS\System32\ativvaxx.cap
[2010/03/22 18:26:45 | 003,407,872 | -H-- | M] () -- C:\Documents and Settings\Administrator\NTUSER.DAT
[2010/03/22 18:26:45 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Administrator\ntuser.ini
[2010/03/22 12:35:04 | 000,002,206 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/03/21 22:10:00 | 000,002,521 | ---- | M] () -- C:\Documents and Settings\Administrator\Desktop\Microsoft Office Outlook 2007.lnk
[2010/03/21 22:09:29 | 000,034,275 | ---- | M] () -- C:\Documents and Settings\Administrator\Desktop\NCAA2010.xlsx
[2010/03/21 11:55:06 | 000,908,248 | ---- | M] (Mozilla Corporation) -- C:\Documents and Settings\Administrator\Desktop\firefox.exe
[2010/03/21 11:54:03 | 000,435,800 | ---- | M] () -- C:\WINDOWS\System32\perfh009.dat
[2010/03/21 11:54:03 | 000,068,428 | ---- | M] () -- C:\WINDOWS\System32\perfc009.dat
[2010/03/21 11:54:02 | 000,513,426 | ---- | M] () -- C:\WINDOWS\System32\PerfStringBackup.INI
[2010/03/21 11:51:00 | 000,012,694 | -HS- | M] () -- C:\Documents and Settings\All Users\Application Data\QB5w8agaB3
[2010/03/21 11:51:00 | 000,012,694 | -HS- | M] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\QB5w8agaB3
[2010/03/21 11:48:10 | 005,115,824 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\Administrator\Desktop\mbam-setup.exe
[2010/03/21 11:41:04 | 000,201,216 | -HS- | M] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\211876838.dll
[2010/03/17 21:20:01 | 000,208,912 | ---- | M] () -- C:\Documents and Settings\Administrator\My Documents\cc_20100317_211941.reg
[2010/03/15 01:11:21 | 000,000,356 | ---- | M] () -- C:\WINDOWS\tasks\McDefragTask.job
[2010/03/22 18:31:12 | 000,363,008 | ---- | C] () -- C:\Documents and Settings\Administrator\Desktop\rkill.pif
[2010/03/17 21:19:44 | 000,208,912 | ---- | C] () -- C:\Documents and Settings\Administrator\My Documents\cc_20100317_211941.reg
[2010/03/17 20:03:00 | 000,201,216 | -HS- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\211876838.dll
[2010/03/17 20:02:17 | 000,012,694 | -HS- | C] () -- C:\Documents and Settings\All Users\Application Data\QB5w8agaB3
[2010/03/17 20:02:17 | 000,012,694 | -HS- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\QB5w8agaB3
[2010/03/16 20:09:06 | 000,034,275 | ---- | C] () -- C:\Documents and Settings\Administrator\Desktop\NCAA2010.xlsx
[2010/01/31 11:06:16 | 000,007,168 | ---- | C] () -- C:\WINDOWS\System32\drivers\StarOpen.sys
[2010/01/31 10:52:14 | 000,000,348 | ---- | C] () -- C:\Documents and Settings\Administrator\Application Data\burnaware.ini
[2009/11/15 20:24:31 | 000,000,000 | ---- | C] () -- C:\WINDOWS\VM.INI
[2009/05/23 19:28:08 | 000,045,056 | ---- | C] () -- C:\Documents and Settings\Administrator\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2009/05/20 07:21:23 | 000,001,338 | ---- | C] () -- C:\WINDOWS\wininit.ini
[2009/03/24 18:23:06 | 000,691,696 | ---- | C] () -- C:\WINDOWS\System32\drivers\sptd.sys
[2009/03/23 11:00:56 | 000,000,042 | ---- | C] () -- C:\WINDOWS\ib.ini
[2009/03/23 11:00:55 | 000,026,624 | ---- | C] () -- C:\WINDOWS\GetIe.dll
[2009/03/22 02:10:25 | 000,022,723 | ---- | C] () -- C:\WINDOWS\System32\ml163sl3.dll
[2008/10/07 10:13:30 | 000,197,912 | ---- | C] () -- C:\WINDOWS\System32\physxcudart_20.dll
[2008/10/07 10:13:22 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelTraditionalChinese.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSwedish.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSpanish.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelSimplifiedChinese.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelPortugese.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelKorean.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelJapanese.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelGerman.dll
[2008/10/07 10:13:20 | 000,058,648 | ---- | C] () -- C:\WINDOWS\System32\AgCPanelFrench.dll
[2007/10/12 23:20:06 | 000,151,417 | ---- | C] () -- C:\WINDOWS\System32\xlive.dll.cat
[2004/08/03 17:56:44 | 000,071,680 | ---- | C] () -- C:\WINDOWS\System32\iesetup.dll
[1996/04/03 14:33:26 | 000,005,248 | ---- | C] () -- C:\WINDOWS\System32\giveio.sys
[2009/05/26 22:28:30 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\AMS Services
[2010/01/31 14:35:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Azureus
[2010/01/31 11:06:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Canneverbe Limited
[2009/03/24 18:27:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\DAEMON Tools
[2009/12/07 23:46:32 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\DAEMON Tools Lite
[2009/03/24 18:27:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\DAEMON Tools Pro
[2009/03/22 08:43:11 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\InfraRecorder
[2009/05/22 22:51:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Leadertech
[2010/02/15 15:07:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\LimeWire
[2010/03/21 11:50:59 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\OA
[2009/04/01 12:35:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\SanDisk
[2009/03/22 00:21:31 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Administrator\Application Data\Thunderbird
[2010/01/31 12:43:50 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Acronis
[2009/03/27 10:40:52 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Azureus
[2010/01/31 11:06:26 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\Canneverbe Limited
[2009/12/07 23:39:45 | 000,000,000 | ---D | M] -- C:\Documents and Settings\All Users\Application Data\DAEMON Tools Lite
[2010/03/15 01:11:21 | 000,000,356 | ---- | M] () -- C:\WINDOWS\Tasks\McDefragTask.job
[2010/03/01 02:00:04 | 000,000,348 | ---- | M] () -- C:\WINDOWS\Tasks\McQcTask.job
< %SYSTEMDRIVE%\*.exe >
< %systemroot%\*. /mp /s >
< c:\$recycle.bin\*.* /s >
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install\\LastSuccessTime: 2010-01-31 19:37:06
< MD5 for: AGP440.SYS >
[2010/01/20 22:57:49 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:AGP440.sys
[2010/01/20 22:57:49 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:AGP440.sys
[2008/04/13 13:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\ServicePackFiles\i386\agp440.sys
[2008/04/13 13:36:38 | 000,042,368 | ---- | M] (Microsoft Corporation) MD5=08FD04AA961BDC77FB983F328334E3D7 -- C:\WINDOWS\system32\drivers\agp440.sys
< MD5 for: ATAPI.SYS >
[2010/01/20 22:57:49 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\Driver Cache\i386\sp3.cab:atapi.sys
[2010/01/20 22:57:49 | 023,852,652 | ---- | M] () .cab file -- C:\WINDOWS\ServicePackFiles\i386\sp3.cab:atapi.sys
[2008/04/13 13:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\ServicePackFiles\i386\atapi.sys
[2008/04/13 13:40:30 | 000,096,512 | ---- | M] (Microsoft Corporation) MD5=9F3A2F5AA6875C72BF062C712CFA2674 -- C:\WINDOWS\system32\drivers\atapi.sys
[2004/08/04 01:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\$NtServicePackUninstall$\atapi.sys
[2004/08/03 15:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\system32\ReinstallBackups\0007\DriverFiles\i386\atapi.sys
[2004/08/04 01:59:44 | 000,095,360 | ---- | M] (Microsoft Corporation) MD5=CDFE4411A69C224BD1D11B2DA92DAC51 -- C:\WINDOWS\system32\ReinstallBackups\0008\DriverFiles\i386\atapi.sys
< MD5 for: AUTOCHK.EXE >
[2008/04/13 19:12:12 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=23043C91A0F9DFB4B9E9F87B680863B4 -- C:\WINDOWS\ServicePackFiles\i386\autochk.exe
[2008/04/13 19:12:12 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=23043C91A0F9DFB4B9E9F87B680863B4 -- C:\WINDOWS\system32\autochk.exe
[2004/08/03 17:56:48 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=B3415B9D6026F65E43089ABED096C38C -- C:\cmdcons\autochk.exe
[2004/08/03 17:56:48 | 000,588,800 | ---- | M] (Microsoft Corporation) MD5=B3415B9D6026F65E43089ABED096C38C -- C:\WINDOWS\$NtServicePackUninstall$\autochk.exe
< MD5 for: BEEP.SYS >
[2001/08/23 06:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) MD5=DA1F27D85E0D1525F6621372E7B685E9 -- C:\WINDOWS\system32\dllcache\beep.sys
[2001/08/23 06:00:00 | 000,004,224 | ---- | M] (Microsoft Corporation) MD5=DA1F27D85E0D1525F6621372E7B685E9 -- C:\WINDOWS\system32\drivers\beep.sys
< MD5 for: EVENTLOG.DLL >
[2009/05/22 11:26:08 | 000,028,672 | ---- | M] (AMS Services, Inc.) MD5=225B41778D1D3F07F44A3E95D9F37BFD -- C:\Documents and Settings\Administrator\Local Settings\Application Data\AMS Services, Inc\AMS 360\bin\EventLog.dll
[2008/04/13 19:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\ServicePackFiles\i386\eventlog.dll
[2008/04/13 19:11:53 | 000,056,320 | ---- | M] (Microsoft Corporation) MD5=6D4FEB43EE538FC5428CC7F0565AA656 -- C:\WINDOWS\system32\eventlog.dll
[2004/08/03 17:56:44 | 000,055,808 | ---- | M] (Microsoft Corporation) MD5=82B24CB70E5944E6E34662205A2A5B78 -- C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll
< MD5 for: EXPLORER.EXE >
[2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\explorer.exe
[2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) MD5=12896823FB95BFB3DC9B46BCAEDC9923 -- C:\WINDOWS\ServicePackFiles\i386\explorer.exe
[2007/03/04 16:16:25 | 001,033,216 | ---- | M] (Microsoft Corporation) MD5=42D32722B805D7DF42D30487A0BCBD78 -- C:\WINDOWS\$NtServicePackUninstall$\explorer.exe
< MD5 for: IMM32.DLL >
[2008/04/13 19:11:54 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=0DA85218E92526972A821587E6A8BF8F -- C:\WINDOWS\ServicePackFiles\i386\imm32.dll
[2008/04/13 19:11:54 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=0DA85218E92526972A821587E6A8BF8F -- C:\WINDOWS\system32\imm32.dll
[2004/08/03 17:56:44 | 000,110,080 | ---- | M] (Microsoft Corporation) MD5=87CA7CE6469577F059297B9D6556D66D -- C:\WINDOWS\$NtServicePackUninstall$\imm32.dll
< MD5 for: KERNEL32.DLL >
[2007/03/04 16:16:39 | 000,985,600 | ---- | M] (Microsoft Corporation) MD5=16F21882C96EE0136A92E867DA94215C -- C:\WINDOWS\$NtUninstallKB959426_0$\kernel32.dll
[2009/03/21 08:54:07 | 000,989,184 | ---- | M] (Microsoft Corporation) MD5=80202858D245FF07DAA1739C57A3E19B -- C:\WINDOWS\$NtServicePackUninstall$\kernel32.dll
[2009/03/21 09:06:58 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=B921FB870C9AC0D509B2CCABBBBE95F3 -- C:\WINDOWS\$hf_mig$\KB959426\SP3GDR\kernel32.dll
[2009/03/21 09:06:58 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=B921FB870C9AC0D509B2CCABBBBE95F3 -- C:\WINDOWS\system32\dllcache\kernel32.dll
[2009/03/21 09:06:58 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=B921FB870C9AC0D509B2CCABBBBE95F3 -- C:\WINDOWS\system32\kernel32.dll
[2008/04/13 19:11:56 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=C24B983D211C34DA8FCC1AC38477971D -- C:\WINDOWS\$NtUninstallKB959426$\kernel32.dll
[2008/04/13 19:11:56 | 000,989,696 | ---- | M] (Microsoft Corporation) MD5=C24B983D211C34DA8FCC1AC38477971D -- C:\WINDOWS\ServicePackFiles\i386\kernel32.dll
[2009/03/21 20:29:24 | 000,991,744 | ---- | M] (Microsoft Corporation) MD5=DA11D9D6ECBDF0F93436A4B7C13F7BEC -- C:\WINDOWS\$hf_mig$\KB959426\SP3QFE\kernel32.dll
< MD5 for: MSWSOCK.DLL >
[2008/06/20 12:36:11 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=1DFCA7713EA5A70D5D93B436AEA0317A -- C:\WINDOWS\$NtServicePackUninstall$\mswsock.dll
[2004/08/03 17:56:46 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=4E74AF063C3271FBEA20DD940CFD1184 -- C:\WINDOWS\$NtUninstallKB951748_0$\mswsock.dll
[2008/06/20 12:46:57 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=832E4DD8964AB7ACC880B2837CB1ED20 -- C:\WINDOWS\$hf_mig$\KB951748\SP3GDR\mswsock.dll
[2008/06/20 12:46:57 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=832E4DD8964AB7ACC880B2837CB1ED20 -- C:\WINDOWS\system32\dllcache\mswsock.dll
[2008/06/20 12:46:57 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=832E4DD8964AB7ACC880B2837CB1ED20 -- C:\WINDOWS\system32\mswsock.dll
[2008/04/13 19:12:01 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=B4138E99236F0F57D4CF49BAE98A0746 -- C:\WINDOWS\$NtUninstallKB951748$\mswsock.dll
[2008/04/13 19:12:01 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=B4138E99236F0F57D4CF49BAE98A0746 -- C:\WINDOWS\ServicePackFiles\i386\mswsock.dll
[2008/06/20 12:43:05 | 000,245,248 | ---- | M] (Microsoft Corporation) MD5=FCEE5FCB99F7C724593365C706D28388 -- C:\WINDOWS\$hf_mig$\KB951748\SP3QFE\mswsock.dll
< MD5 for: NDIS.SYS >
[2008/04/13 14:20:37 | 000,182,656 | ---- | M] (Microsoft Corporation) MD5=1DF7F42665C94B825322FAE71721130D -- C:\WINDOWS\ServicePackFiles\i386\ndis.sys
[2008/04/13 14:20:37 | 000,182,656 | ---- | M] (Microsoft Corporation) MD5=1DF7F42665C94B825322FAE71721130D -- C:\WINDOWS\system32\drivers\ndis.sys
[2004/08/03 16:14:30 | 000,182,912 | ---- | M] (Microsoft Corporation) MD5=558635D3AF1C7546D26067D5D9B6959E -- C:\WINDOWS\$NtServicePackUninstall$\ndis.sys
< MD5 for: NETLOGON.DLL >
[2008/04/13 19:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\ServicePackFiles\i386\netlogon.dll
[2008/04/13 19:12:01 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=1B7F071C51B77C272875C3A23E1E4550 -- C:\WINDOWS\system32\netlogon.dll
[2009/02/06 13:46:09 | 000,408,064 | ---- | M] (Microsoft Corporation) MD5=6C476D33D82F1054849790181E8F7772 -- C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll
[2009/02/06 13:46:09 | 000,408,064 | ---- | M] (Microsoft Corporation) MD5=6C476D33D82F1054849790181E8F7772 -- C:\WINDOWS\$NtUninstallKB975467_0$\netlogon.dll
[2004/08/03 17:56:46 | 000,407,040 | ---- | M] (Microsoft Corporation) MD5=96353FCECBA774BB8DA74A1C6507015A -- C:\WINDOWS\$NtUninstallKB968389_0$\netlogon.dll
< MD5 for: NTFS.SYS >
[2008/04/13 14:15:53 | 000,574,976 | ---- | M] (Microsoft Corporation) MD5=78A08DD6A8D65E697C18E1DB01C5CDCA -- C:\WINDOWS\ServicePackFiles\i386\ntfs.sys
[2008/04/13 14:15:53 | 000,574,976 | ---- | M] (Microsoft Corporation) MD5=78A08DD6A8D65E697C18E1DB01C5CDCA -- C:\WINDOWS\system32\drivers\ntfs.sys
[2004/08/03 23:15:10 | 000,574,592 | ---- | M] (Microsoft Corporation) MD5=B78BE402C3F63DD55521F73876951CDD -- C:\cmdcons\NTFS.SYS
[2004/08/03 16:15:10 | 000,574,592 | ---- | M] (Microsoft Corporation) MD5=B78BE402C3F63DD55521F73876951CDD -- C:\WINDOWS\$NtServicePackUninstall$\ntfs.sys
< MD5 for: NTMSSVC.DLL >
[2008/04/13 19:12:02 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=156F64A3345BD23C600655FB4D10BC08 -- C:\WINDOWS\ServicePackFiles\i386\ntmssvc.dll
[2008/04/13 19:12:02 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=156F64A3345BD23C600655FB4D10BC08 -- C:\WINDOWS\system32\ntmssvc.dll
[2004/08/03 17:56:46 | 000,435,200 | ---- | M] (Microsoft Corporation) MD5=B62F29C00AC55A761B2E45877D85EA0F -- C:\WINDOWS\$NtServicePackUninstall$\ntmssvc.dll
< MD5 for: PROQUOTA.EXE >
[2004/08/03 17:56:56 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=4D9D45A4370E0C2AD00C362B7118E2A4 -- C:\WINDOWS\$NtServicePackUninstall$\proquota.exe
[2008/04/13 19:12:32 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=F6465A2EEF75468988A4FCF124148FA8 -- C:\WINDOWS\ServicePackFiles\i386\proquota.exe
[2008/04/13 19:12:32 | 000,050,176 | ---- | M] (Microsoft Corporation) MD5=F6465A2EEF75468988A4FCF124148FA8 -- C:\WINDOWS\system32\proquota.exe
< MD5 for: QMGR.DLL >
[2004/08/03 17:56:46 | 000,382,464 | ---- | M] (Microsoft Corporation) MD5=2C69EC7E5A311334D10DD95F338FCCEA -- C:\WINDOWS\$NtServicePackUninstall$\qmgr.dll
[2008/04/13 19:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\ServicePackFiles\i386\qmgr.dll
[2008/04/13 19:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\system32\bits\qmgr.dll
[2008/04/13 19:12:03 | 000,409,088 | ---- | M] (Microsoft Corporation) MD5=574738F61FCA2935F5265DC4E5691314 -- C:\WINDOWS\system32\qmgr.dll
< MD5 for: SCECLI.DLL >
[2004/08/03 17:56:46 | 000,180,224 | ---- | M] (Microsoft Corporation) MD5=0F78E27F563F2AAF74B91A49E2ABF19A -- C:\WINDOWS\$NtServicePackUninstall$\scecli.dll
[2008/04/13 19:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\ServicePackFiles\i386\scecli.dll
[2008/04/13 19:12:05 | 000,181,248 | ---- | M] (Microsoft Corporation) MD5=A86BB5E61BF3E39B62AB4C7E7085A084 -- C:\WINDOWS\system32\scecli.dll
< MD5 for: SFCFILES.DLL >
[2007/03/04 16:25:25 | 001,580,544 | ---- | M] (Microsoft Corporation) MD5=1F62F1428A93F805C7C7E579099564A1 -- C:\WINDOWS\$NtServicePackUninstall$\sfcfiles.dll
[2008/04/13 19:12:05 | 001,614,848 | ---- | M] (Microsoft Corporation) MD5=9DD07AF82244867CA36681EA2D29CE79 -- C:\WINDOWS\ServicePackFiles\i386\sfcfiles.dll
[2008/04/13 19:12:05 | 001,614,848 | ---- | M] (Microsoft Corporation) MD5=9DD07AF82244867CA36681EA2D29CE79 -- C:\WINDOWS\system32\sfcfiles.dll
< MD5 for: SPOOLSV.EXE >
[2007/03/04 16:18:03 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=AD3D9D191AEA7B5445FE1D82FFBB4788 -- C:\WINDOWS\$NtServicePackUninstall$\spoolsv.exe
[2008/04/13 19:12:36 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=D8E14A61ACC1D4A6CD0D38AEBAC7FA3B -- C:\WINDOWS\ServicePackFiles\i386\spoolsv.exe
[2008/04/13 19:12:36 | 000,057,856 | ---- | M] (Microsoft Corporation) MD5=D8E14A61ACC1D4A6CD0D38AEBAC7FA3B -- C:\WINDOWS\system32\spoolsv.exe
< MD5 for: SRSVC.DLL >
[2008/04/13 19:12:07 | 000,171,008 | ---- | M] (Microsoft Corporation) MD5=3805DF0AC4296A34BA4BF93B346CC378 -- C:\WINDOWS\ServicePackFiles\i386\srsvc.dll
[2008/04/13 19:12:07 | 000,171,008 | ---- | M] (Microsoft Corporation) MD5=3805DF0AC4296A34BA4BF93B346CC378 -- C:\WINDOWS\system32\srsvc.dll
[2004/08/03 17:56:46 | 000,170,496 | ---- | M] (Microsoft Corporation) MD5=92BDF74F12D6CBEC43C94D4B7F804838 -- C:\WINDOWS\$NtServicePackUninstall$\srsvc.dll
< MD5 for: SVCHOST.EXE >
[2008/04/13 19:12:36 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=27C6D03BCDB8CFEB96B716F3D8BE3E18 -- C:\WINDOWS\ServicePackFiles\i386\svchost.exe
[2008/04/13 19:12:36 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=27C6D03BCDB8CFEB96B716F3D8BE3E18 -- C:\WINDOWS\system32\svchost.exe
[2004/08/03 17:56:58 | 000,014,336 | ---- | M] (Microsoft Corporation) MD5=8F078AE4ED187AAABC0A305146DE6716 -- C:\WINDOWS\$NtServicePackUninstall$\svchost.exe
< MD5 for: TERMSRV.DLL >
[2007/03/04 16:18:10 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=C29A5286E64D97385178452D5F307B98 -- C:\WINDOWS\$NtServicePackUninstall$\termsrv.dll
[2008/04/13 19:12:07 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=FF3477C03BE7201C294C35F684B3479F -- C:\WINDOWS\ServicePackFiles\i386\termsrv.dll
[2008/04/13 19:12:07 | 000,295,424 | ---- | M] (Microsoft Corporation) MD5=FF3477C03BE7201C294C35F684B3479F -- C:\WINDOWS\system32\termsrv.dll
< MD5 for: USERINIT.EXE >
[2004/08/03 17:56:58 | 000,024,576 | ---- | M] (Microsoft Corporation) MD5=39B1FFB03C2296323832ACBAE50D2AFF -- C:\WINDOWS\$NtServicePackUninstall$\userinit.exe
[2008/04/13 19:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\ServicePackFiles\i386\userinit.exe
[2008/04/13 19:12:38 | 000,026,112 | ---- | M] (Microsoft Corporation) MD5=A93AEE1928A9D7CE3E16D24EC7380F89 -- C:\WINDOWS\system32\userinit.exe
< MD5 for: WS2_32.DLL >
[2008/04/13 19:12:10 | 000,082,432 | ---- | M] (Microsoft Corporation) MD5=2CCC474EB85CEAA3E1FA1726580A3E5A -- C:\WINDOWS\ServicePackFiles\i386\ws2_32.dll
[2008/04/13 19:12:10 | 000,082,432 | ---- | M] (Microsoft Corporation) MD5=2CCC474EB85CEAA3E1FA1726580A3E5A -- C:\WINDOWS\system32\ws2_32.dll
[2004/08/03 17:56:48 | 000,082,944 | ---- | M] (Microsoft Corporation) MD5=2ED0B7F12A60F90092081C50FA0EC2B2 -- C:\WINDOWS\$NtServicePackUninstall$\ws2_32.dll
< MD5 for: XMLPROV.DLL >
[2008/04/13 19:12:11 | 000,129,024 | ---- | M] (Microsoft Corporation) MD5=295D21F14C335B53CB8154E5B1F892B9 -- C:\WINDOWS\ServicePackFiles\i386\xmlprov.dll
[2008/04/13 19:12:11 | 000,129,024 | ---- | M] (Microsoft Corporation) MD5=295D21F14C335B53CB8154E5B1F892B9 -- C:\WINDOWS\system32\xmlprov.dll
[2004/08/03 17:56:48 | 000,129,536 | ---- | M] (Microsoft Corporation) MD5=EEF46DAB68229A14DA3D8E73C99E2959 -- C:\WINDOWS\$NtServicePackUninstall$\xmlprov.dll
< %systemroot%\system32\*.dll /lockedfiles >
[1 C:\WINDOWS\system32\*.tmp files -> C:\WINDOWS\system32\*.tmp -> ]
bottocino
Posts Posts : 38
OS OS : windows xp
OTL Extras logfile created on: 3/22/2010 8:34:28 PM - Run 1
File Age = 14 Days
Output = Standard
Quick Scan
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
http [open] -- Reg Error: Key error.
https [open] -- "C:\Program Files\Mozilla Firefox\firefox.exe" -requestPending -osint -url "%1" (Mozilla Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [OneNote.Open] -- C:\PROGRA~1\MICROS~3\Office12\ONENOTE.EXE "%L" (Microsoft Corporation)
"FirstRunDisabled" = 1
"FirewallDisableNotify" = 1
"AntiVirusOverride" = 1
"FirewallOverride" = 1
"UpdatesDisableNotify" = 1
"AntiVirusDisableNotify" = 1
"DisableMonitoring" = 1
"EnableFirewall" = 0
"DoNotAllowExceptions" = 0
"DisableNotifications" = 1
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"10280:UDP" = 10280:UDP:LocalSubNet:Enabled:Windows Media Connect
"10281:UDP" = 10281:UDP:LocalSubNet:Enabled:Windows Media Connect
"10282:UDP" = 10282:UDP:LocalSubNet:Enabled:Windows Media Connect
"10283:UDP" = 10283:UDP:LocalSubNet:Enabled:Windows Media Connect
"10284:UDP" = 10284:UDP:LocalSubNet:Enabled:Windows Media Connect
"10243:TCP" = 10243:TCP:LocalSubNet:Enabled:Windows Media Connect
"C:\Program Files\LimeWire\LimeWire.exe" = C:\Program Files\LimeWire\LimeWire.exe:*:Enabled:LimeWire -- (Lime Wire, LLC)
"C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" = C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE:*:Enabled:Microsoft Office Outlook -- (Microsoft Corporation)
"C:\Program Files\Microsoft Office\Office12\GROOVE.EXE" = C:\Program Files\Microsoft Office\Office12\GROOVE.EXE:*:Enabled:Microsoft Office Groove -- (Microsoft Corporation)
"C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE" = C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE:*:Enabled:Microsoft Office OneNote -- (Microsoft Corporation)
"C:\Program Files\Google\Google Talk\googletalk.exe" = C:\Program Files\Google\Google Talk\googletalk.exe:*:Enabled:Google Talk -- (Google)
"C:\Program Files\Vuze\Azureus.exe" = C:\Program Files\Vuze\Azureus.exe:*:Enabled:Azureus -- (Vuze Inc.)
"C:\Program Files\Sierra\FEARCombat\FEARMP.exe" = C:\Program Files\Sierra\FEARCombat\FEARMP.exe:*:Enabled:FEAR Combat -- (Monolith Productions, Inc.)
"C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe" = C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe:*:Enabled:McAfee Network Agent -- (McAfee, Inc.)
"{055EE59D-217B-43A7-ABFF-507B966405D8}" = ATI Catalyst Control Center
"{064DC64E-7A2F-4FDF-B598-E3C0747BBB9C}" = Call of Duty(R) - World at War(TM) 1.6 Patch
"{0EE11800-A1BD-11D3-BFEB-005004AF2D32}" = Risk II
"{1F61E0B1-1AB8-F15E-07C4-46D100A1D3F7}" = Borderlands
"{226b64e8-dc75-4eea-a6c8-abcb496320f2}-Google Talk" = Google Talk (remove only)
"{26A24AE4-039D-4CA4-87B4-2F83216012FF}" = Java(TM) 6 Update 12
"{3016F4D6-A41E-42EE-A70F-CD69F38D47C8}" = HOT ALBUM MYBOX
"{36CDA33B-909B-4719-97D1-C4B99309BDC7}" = ATI Parental Control & Encoder
"{3A1B5D40-41E9-43FA-8C7B-A8667F5586EF}" = Gigabyte Raid Configurer
"{3EA9D975-BFDC-4E8E-B88B-0446FBC8CA66}" = ATI HYDRAVISION
"{4324BC93-C82F-ED16-BA86-5E34B9E05303}" = ccc-core-static
"{451F8269-D775-4D3E-BE6E-D55011E3FFBA}" = AMS 360 Client Rev 2
"{4ED118EE-785C-CC18-5D2E-D5CA4BAA03F0}" = Catalyst Control Center Graphics Full New
"{539475B7-44B7-8B0A-134C-F01B9C8B7569}" = ccc-core-preinstall
"{5AC7AE54-55DF-1126-076C-623F008D40B6}" = Catalyst Control Center Graphics Full Existing
"{5DA6F06A-B389-407B-BF8C-1548767914D8}" = ATI Problem Report Wizard
"{6351D217-3EE3-1967-29BE-6A77635FE485}" = Skins
"{6AB9CD3A-F91F-233B-923B-6C59BA63524D}" = Catalyst Control Center HydraVision Full
"{75E607CF-7BAE-4B88-84B3-97F3DF44BA28}" = FEARCombat
"{7CCEBC24-62DB-4280-A8EC-BFA49F167920}" = Software Update for Web Folders
"{7E265513-8CDA-4631-B696-F40D983F3B07}_is1" = CDBurnerXP
"{7ED169D4-5053-4166-93DF-53B12AE6C539}" = Energy Saver Advance B8.1015.1
"{85A91C22-C369-FCFB-5F1F-D59EB21AD0E1}" = CCC Help English
"{89DE67AD-08B8-4699-A55D-CA5C0AF82BF3}" = ATI AVIVO Codecs
"{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_ENTERPRISE_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_ENTERPRISE_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_ENTERPRISE_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{97C82B44-D408-4F14-9252-47FC1636D23E}_is1" = IZArc 3.7
"{A6D0140F-E62F-9D1E-2408-9CFF91FF6FC8}" = ccc-utility
"{AC76BA86-7AD7-1033-7B44-A81300000003}" = Adobe Reader 8.1.3
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{BFBF3E8D-8C47-45E2-A5A4-01E8B763BE20}" = AMS TransactNOW Client
"{C2F1F96A-057E-5819-B52E-FEA1D1D2933B}" = Acronis True Image Home
"{C44A7422-E380-44BE-79FE-1C032D8A03A7}" = Catalyst Control Center Core Implementation
"{C9BED750-1211-4480-B1A5-718A3BE15525}" = REALTEK GbE & FE Ethernet PCI-E NIC Driver
"{D1B01DC9-CBAF-45F9-A387-7D00C11B630E}" = Microsoft Games for Windows - LIVE Redistributable
"{D3B1C799-CB73-42DE-BA0F-2344793A095C}" = Catalyst Control Center - Branding
"{D56B0E27-4A3E-46C9-B5C1-D93D580C099C}" = NVIDIA PhysX v8.10.29
"{E5D24929-91A4-B0A1-DE00-AFC453921EF7}" = Catalyst Control Center Graphics Light
"{E6C09BFB-BA75-15C7-5B18-A2CE31C4F42B}" = Catalyst Control Center Graphics Previews Common
"{E8AEA11B-E60A-455E-B008-E4E763604612}" = Browser Configuration Utility
"53F13DB4D9611FD63BE580F06F0729BF236ABE68" = Windows Driver Package - Advanced Micro Devices (AmdK8) Processor (05/27/2006 1.3.2.0)
"AC3Filter_is1" = AC3Filter 1.60b
"All ATI Software" = ATI - Software Uninstall Utility
"ATI Display Driver" = ATI Display Driver
"CCleaner" = CCleaner (remove only)
"Complete Italian" = Complete Italian
"DriverAgent.exe" = DriverAgent by eSupport.com
"DVD Decrypter" = DVD Decrypter (Remove Only)
"ENTERPRISE" = Microsoft Office Enterprise 2007
"EVEREST Ultimate Edition_is1" = EVEREST Ultimate Edition v3.50
"ffdshow" = ffdshow (remove only)
"HijackThis" = HijackThis 2.0.2
"InstallShield_{2BF0AE92-C3BC-4112-9066-1546342B1FAE}" = Call of Duty(R) - World at War(TM) 1.2 Patch
"InstallShield_{3016F4D6-A41E-42EE-A70F-CD69F38D47C8}" = HOT ALBUM MYBOX
"InstallShield_{9F01A67B-7D67-482F-9D4F-D5980A440FD4}" = Call of Duty(R) - World at War(TM) 1.4 Patch
"InstallShield_{C3DC2DF5-EFAC-4055-9010-31F7C545DD9E}" = Call of Duty(R) - World at War(TM) 1.5 Patch
"jv16 PowerTools_is1" = jv16 PowerTools 1.3
"LimeWire" = LimeWire 5.1.2
"Mozilla Firefox (3.5.8)" = Mozilla Firefox (3.5.8)
"msc" = McAfee SecurityCenter
"OpenAL" = OpenAL
"PokerStars.net" = PokerStars.net
"RocketDock_is1" = RocketDock 1.3.0
"Samsung ML-1630 Series" = Samsung ML-1630 Series
"SpeedFan" = SpeedFan (remove only)
"Trader Workstation 4.0" = Trader Workstation 4.0
"Vocabulary Master" = Vocabulary Master
"Vuze" = Vuze
"WIC" = Windows Imaging Component
"GoToMeeting" = GoToMeeting 4.0.0.320
"Sansa Updater" = Sansa Updater
"Trader Workstation" = Trader Workstation
[ AMS 360 Events ]
Error - 5/22/2009 12:15:05 PM | Computer Name = T-3D7D0F55343C4 | Source = AMS 360 | ID = 1
Description = Source: Customer Agency: 2037628-1, Login Id: Phoenix Tree UserName:Administrator
PID:1724
Application:
Client Application Directory: C:\Documents and Settings\Administrator\Local Settings\Application
Data\AMS Services, Inc\AMS 360\ Item has already been added. Key in dictionary:
'Color [LightSkyBlue]' Key being added: 'Color [LightSkyBlue]' at System.Collections.Hashtable.Insert(Object
key, Object nvalue, Boolean add) at System.Collections.Hashtable.Add(Object key,
Object value) at DevExpress.XtraEditors.Controls.BrushSetCollection.GetItem(Color
color) at DevExpress.XtraEditors.ViewInfo.BaseEditViewInfo.CalcBrushes() at
DevExpress.XtraEditors.ViewInfo.BaseEditViewInfo.set_Style(ViewStyle value) at
DevExpress.XtraGrid.Views.Base.ViewInfo.ColumnViewInfo.CalcMinRowHeight(ViewStyle[]
styles) at DevExpress.XtraGrid.Views.Grid.ViewInfo.GridViewInfo.CalcMinRowHeight()
at DevExpress.XtraGrid.Views.Grid.ViewInfo.GridViewInfo.CalcViewRects(GridView
gridView, Rectangle ViewRect, Boolean callClear) at DevExpress.XtraGrid.Views.Grid.GridView.DoInternalLayout()
at DevExpress.XtraGrid.Views.Grid.GridView.LayoutChanged() at DevExpress.XtraGrid.Views.Base.BaseView.EndUpdate()
at DevExpress.XtraGrid.Views.Grid.GridView.~[Filtered JS Events]~() at DevExpress.XtraGrid.Views.Base.BaseView.EndInit()
at AMSBothell.WinForms.Customer.frmCustomer.InitializeComponent() at AMSBothell.WinForms.Customer.frmCustomer..ctor(NameValueCollection
oNVC)
Error - 5/22/2009 12:15:05 PM | Computer Name = T-3D7D0F55343C4 | Source = AMS 360 | ID = 1007
Description = Source: ServerObjects Agency: 2037628-1, Login Id: Phoenix Tree UserName:Administrator
PID:1724
Application:
Data\AMS Services, Inc\AMS 360\ Unable to create an instance of the Assembly: Customer.dll,
Type: AMSBothell.WinForms.Customer.frmCustomer Item has already been added. Key
in dictionary: 'Color [LightSkyBlue]' Key being added: 'Color [LightSkyBlue]'
at AMSBothell.WinForms.Customer.frmCustomer..ctor(NameValueCollection oNVC)
Error - 5/24/2009 8:05:36 PM | Computer Name = T-3D7D0F55343C4 | Source = AMS 360 | ID = 1018
PID:1724
Application:
Data\AMS Services, Inc\AMS 360\ Fire Invoke or BeginInvoke cannot be called on a
control until the window handle has been created. at System.Windows.Forms.Control.MarshaledInvoke(Control
caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate
method, Object[] args) at AMSBothell.Components.Controls.FormBase.OnNotificationReceivedInternal(String
strEventType, ListDictionary oLD, Object oData) at AMSBothell.Components.WorkstationCoordinator.ClientObject.DataChanged(String
strEventType, ListDictionary e, Object oData) at AMSBothell.Components.WorkstationCoordinator.Notification.Server.Fire(String
[ Application Events ]
Error - 6/16/2009 11:19:50 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
Description = A thread in process C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe took
longer than 90000 ms to complete a request. The process will be terminated. Thread
id : 2848 (0xb20) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.349
/ 5301.4018 Object being scanned = \Device\HarddiskVolume1\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP117\A0017874.exe
by C:\WINDOWS\System32\svchost.exe 4(0)(0) 4(0)(0) 7200(0)(0) 7595(0)(0) 7005(0)(0)
7004(0)(0) 5006(0)(0) 5004(0)(0)
Error - 7/4/2009 12:09:11 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 4092 (0xffc) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.349
/ 5301.4018 Object being scanned = \Device\HarddiskVolume1\Recycler\S-1-5-21-1229272821-1275210071-725345543-500\Dc6.exe
by C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe 4(0)(0) 4(0)(0) 7200(0)(0)
7595(0)(0) 7005(0)(0) 7004(0)(0) 5006(0)(0) 5004(0)(0)
Error - 7/18/2009 8:04:12 PM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 568 (0x238) Thread address : 0x01FE5D4C Thread message : Build VSCORE.14.0.0.349
/ 5301.4018 Object being scanned = \Device\HarddiskVolume1\RECYCLER\S-1-5-21-1229272821-1275210071-725345543-500\Dc6.exe
Error - 8/13/2009 8:37:48 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 1192 (0x4a8) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.349
Error - 8/19/2009 8:39:59 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 3076 (0xc04) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.349
Error - 9/6/2009 9:34:10 AM | Computer Name = T-3D7D0F55343C4 | Source = Microsoft Office 12 | ID = 1000
Description = Faulting application outlook.exe, version 12.0.4518.1014, stamp 4542840f,
faulting module wwlib.dll, version 12.0.4518.1014, stamp 454285fb, debug? 0, fault
address 0x0007c1d5.
Error - 10/30/2009 7:46:50 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 4012 (0xfac) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.435
Error - 11/15/2009 9:26:48 PM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 3920 (0xf50) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.435
/ 5301.4018 Object being scanned = \Device\CdRom0\Common\IE0694D.SU8 by C:\Program
Files\TLI\Complete Italian V2\CompleteItalian.exe 4(0)(0) 4(0)(0) 7200(0)(0) 7595(0)(0)
Error - 12/9/2009 12:51:21 AM | Computer Name = T-3D7D0F55343C4 | Source = McLogEvent | ID = 5051
id : 3640 (0xe38) Thread address : 0x7C90EB94 Thread message : Build VSCORE.14.0.0.435
/ 5301.4018 Object being scanned = \Device\HarddiskVolume1\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP302\A0036604.exe
by C:\WINDOWS\system32\cleanmgr.exe 4(0)(0) 4(0)(0) 7200(0)(0) 7595(0)(0) 7005(0)(0)
Error - 12/20/2009 9:05:02 PM | Computer Name = T-3D7D0F55343C4 | Source = Microsoft Office 12 | ID = 1000
Description = Faulting application outlook.exe, version 12.0.6316.5000, stamp 4833a470,
faulting module kernel32.dll, version 5.1.2600.3541, stamp 49c4f17f, debug? 0,
fault address 0x00012aab.
[ OSession Events ]
Error - 9/6/2009 9:34:08 AM | Computer Name = T-3D7D0F55343C4 | Source = Microsoft Office 12 Sessions | ID = 7001
Description = ID: 6, Application Name: Microsoft Office Outlook, Application Version:
12.0.4518.1014, Microsoft Office Version: 12.0.4518.1014. This session lasted 52569
seconds with 360 seconds of active time. This session ended with a crash.
[ System Events ]
Error - 3/22/2010 9:38:40 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Description = The device, \Device\Harddisk0\D, has a bad block.
Error - 3/22/2010 9:38:41 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:42 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:44 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:45 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:47 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:48 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:49 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:51 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
Error - 3/22/2010 9:38:52 PM | Computer Name = T-3D7D0F55343C4 | Source = Disk | ID = 262151
bottocino
Posts Posts : 38
Joined Joined : 2009-01-07
OS OS : windows xp
Points Points : 29256
Re: malware and key logger issues
Post by bottocino on 23rd March 2010, 1:47 am
I had to post it in two pieces. the file was too big.
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 23rd March 2010, 4:01 am
I see you are running Vuze, Limewire, etc.
I suggest to read the following, and then decided whether you want to keep it or not: [You must be registered and logged in to see this link.]
This is a two part processes on OTL. Please do both of them separately, and post both logs.
Please run OTL
  • Under the Custom Scans/Fixes box at the bottom, paste in the following:
    :otl
    SRV - File not found [Disabled | Stopped] -- -- (ASKUpgrade)
    SRV - File not found [Disabled | Stopped] -- -- (ASKService)
    [2009/03/27 10:40:51 | 000,000,000 | ---D | M] (No name found) -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}
    [2009/03/27 11:57:23 | 000,000,681 | ---- | M] () -- C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\searchplugins\ask.xml
    :files
    :Commands
    [purity]
    [resethosts]
    [emptytemp]
    [EMPTYFLASH]
    [CREATERESTOREPOINT]
    [Reboot]
  • Then click the Run Fix button at the top
  • Let the program run unhindered, reboot the PC when it is done. Post the fix log. Then, move on to the next part below.
Please open OTL -- Click None and paste this in the Custom Scans box:
C:\Documents and Settings\Administrator\Application Data\QB5w8agaB3
Then click Run Scan. It shall launch a log. Please post it in your next reply.
Posts Posts : 14317
Points Points : 303008
Post by bottocino on 24th March 2010, 3:18 am
All processes killed
========== OTL ==========
Service ASKUpgrade stopped successfully!
Service ASKUpgrade deleted successfully!
Service ASKService stopped successfully!
Service ASKService deleted successfully!
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}\META-INF folder moved successfully.
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}\defaults\preferences folder moved successfully.
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}\defaults folder moved successfully.
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D}\chrome folder moved successfully.
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\extensions\{E9A1DEE0-C623-4439-8932-001E7D17607D} folder moved successfully.
C:\Documents and Settings\Administrator\Application Data\Mozilla\Firefox\Profiles\9ujw7fip.default\searchplugins\ask.xml moved successfully.
C:\Documents and Settings\Administrator\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini moved successfully.
========== FILES ==========
C:\Documents and Settings\Administrator\Local Settings\Application Data\211876838.dll moved successfully.
C:\WINDOWS\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
[EMPTYTEMP]
User: Administrator
->Temp folder emptied: 17508781 bytes
->Temporary Internet Files folder emptied: 66659955 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 94753166 bytes
->Flash cache emptied: 1922311 bytes
User: All Users
User: Default User
->Temporary Internet Files folder emptied: 67 bytes
User: LocalService
->Temporary Internet Files folder emptied: 164041 bytes
User: NetworkService
->Temporary Internet Files folder emptied: 33170 bytes
%systemroot% .tmp files removed: 2162283 bytes
%systemroot%\System32 .tmp files removed: 2577 bytes
Windows Temp folder emptied: 36864 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temp folder emptied: 0 bytes
%systemroot%\system32\config\systemprofile\Local Settings\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 14398616 bytes
Total Files Cleaned = 189.00 mb
[EMPTYFLASH]
User: Administrator
User: All Users
User: Default User
User: LocalService
Total Flash Files Cleaned = 0.00 mb
Restore point Set: OTL Restore Point (64424509440)
OTL by OldTimer - Version 3.1.37.3 log created on 03232010_221140
OTL logfile created on: 3/23/2010 10:16:42 PM - Run 2
OTL by OldTimer - Version 3.1.37.3 Folder = C:\Documents and Settings\Administrator\Desktop
Windows XP Professional Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
3.00 Gb Total Physical Memory | 3.00 Gb Available Physical Memory | 81.00% Memory free
5.00 Gb Paging File | 5.00 Gb Available in Paging File | 89.00% Paging File free
Paging file location(s): C:\pagefile.sys 2046 4092 [binary data]
Drive C: | 127.99 Gb Total Space | 17.77 Gb Free Space | 13.89% Space Free | Partition Type: NTFS
Computer Name: T-3D7D0F55343C4
Current User Name: Administrator
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
< C:\Documents and Settings\All Users\Application Data\QB5w8agaB3 >
< C:\Documents and Settings\Administrator\Application Data\QB5w8agaB3 >
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 24th March 2010, 3:55 am
Please run OTL
    :otl
  • Post the fix log.
Posts Posts : 14317
Post by bottocino on 25th March 2010, 12:27 pm
File C:\Documents and Settings\All Users\Application Data\QB5w8agaB3 not found.
OTL by OldTimer - Version 3.1.37.3 log created on 03252010_072658
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 25th March 2010, 2:56 pm
  • Click Start
  • Click Start
Posts Posts : 14317
Post by bottocino on 26th March 2010, 9:32 pm
all ok
# version=7
# api_version=3.0.2
# EOSSerial=dedae468a9e14c4099225c2a12bfcbc1
# end=stopped
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-03-26 02:00:15
# local_time=2010-03-25 09:00:15 (-0600, Central Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=512 16777215 100 0 25436365 25436365 0 0
# compatibility_mode=5121 16776533 100 96 1457655 21573931 0 0
# scanned=163
# found=0
# cleaned=0
# scan_time=9
all ok
esets_scanner_update returned -1 esets_gle=53251
# version=7
# api_version=3.0.2
# end=stopped
# archives_checked=true
# utc_time=2010-03-26 02:51:58
# local_time=2010-03-25 09:51:58 (-0600, Central Daylight Time)
# lang=1033
# compatibility_mode=512 16777215 100 0 25436481 25436481 0 0
# compatibility_mode=5121 16776533 100 96 1457771 21574047 0 0
# scanned=1843
# found=0
# cleaned=0
# scan_time=2993
all ok
# version=7
# api_version=3.0.2
# end=finished
# utc_time=2010-03-26 05:33:14
# local_time=2010-03-26 12:33:14 (-0600, Central Daylight Time)
# lang=1033
# compatibility_mode=512 16777215 100 0 25439619 25439619 0 0
# compatibility_mode=5121 16776533 100 96 1460909 21577185 0 0
# scanned=57313
# found=8
# cleaned=8
# scan_time=9533
C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy\Recovery\CoolWWWSearchAffMadfinder1.zip Win32/Bagle.gen.zip worm (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy\Recovery\Virtumondesdn16.zip Win32/Bagle.gen.zip worm (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy\Recovery\Virtumondesdn8.zip Win32/Bagle.gen.zip worm (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP407\A0060943.dll a variant of Win32/Kryptik.AXL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP408\A0060946.dll a variant of Win32/Kryptik.AXL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP409\A0060950.dll a variant of Win32/Kryptik.AXL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\System Volume Information\_restore{30140B2C-EB3C-4886-9BEF-0A292002F5BB}\RP410\A0060961.dll a variant of Win32/Kryptik.AXL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
C:\_OTL\MovedFiles\03232010_221140\C_Documents and Settings\Administrator\Local Settings\Application Data\211876838.dll a variant of Win32/Kryptik.AXL trojan (cleaned by deleting - quarantined) 00000000000000000000000000000000 C
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 27th March 2010, 2:36 am
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 14317
Post by bottocino on 29th March 2010, 2:21 am
Here is the results of security check.
Results of screen317's Security Check version 0.99.2
Internet Explorer 8
Antivirus/Firewall Check:
ESET Online Scanner v3
Antivirus up to date!
HijackThis 2.0.2
Out of date Java installed!
Adobe Reader 8.1.3
Process Check:
objlist.exe by Laurent
McAfee VIRUSS~1 mcshield.exe
DNS Vulnerability Check:
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 29th March 2010, 3:01 am
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Posts Posts : 14317
Post by bottocino on 30th March 2010, 2:28 am
loaded java version 18
loaded adobe 9.3
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 30th March 2010, 2:40 am
Good. Any more issues or questions?
Posts Posts : 14317
Post by bottocino on 2nd April 2010, 12:04 am
no..... thank you for your help you guys are the best
bottocino
Posts Posts : 38
OS OS : windows xp
Post by Dr Jay on 2nd April 2010, 3:13 am
You're welcome.
Posts Posts : 14317
