Weird Net connection problem
Post by EmceeCoast on Sat 20 Mar - 17:19
So until a few days ago my internet was working fine. Now all of a sudden i cant connect to the internet unless I'm using firefox. Itunes, online games, other browsers, doesnt matter what ever i try that needs a net connection doesnt work only mozilla. I dont use a proxy server or anything i havent made any major changes to my computer. Please help :sad: I just want my net to be normal again
I did a virus scan and cleared all and any viruses cleaned my comp too. Using CCleaner nothing works :sad: help please and thanks
EmceeCoast
Joined Joined : 2010-03-20
OS OS : Windows Vista
Points Points : 24533
Re: Weird Net connection problem
Post by Nazzgull on Sun 21 Mar - 3:05
Do you want to say - You are attached to the internet but you can not surf ?
Joined Joined : 2008-08-04
Points Points : 40445
Post by EmceeCoast on Sun 21 Mar - 3:45
I can surf but only on mozilla. IE doesn't work and anything else that requires an internet connection wont connect.
EmceeCoast
Post by Nazzgull on Sun 21 Mar - 3:51
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restartyour PC.
If it doesn't work, download Winsock XP Fix from here,
save it to your Desktop.
See if you can connect now.
