Hijackthis Problems
Page 2 of 2 Previous  1, 2
Re: Hijackthis Problems
Post by Dr Jay on 31st March 2010, 4:03 am
  • Click Start
  • Click Start
Posts Posts : 14310
Points Points : 302971
Post by Kirbie on 1st April 2010, 12:42 am
OnlineScanner64.ocx - registred OK
Kirbie
Posts Posts : 51
Joined Joined : 2010-03-17
OS OS : Windows Vista
Points Points : 25163
Post by Dr Jay on 1st April 2010, 4:18 am
To manually create a new Restore Point
  • Go to Control Panel and select System and Maintenance
  • Select System
  • On the left select Advance System Settings and accept the warning if you get one
  • Select System Protection Tab
  • Select Create at the bottom
  • Type in a name i.e. Clean
  • Select Create
Now we can purge the infected ones
  • Go back to the System and Maintenance page
  • Select Performance Information and Tools
  • On the left select Open Disk Cleanup
  • Select Files from all users and accept the warning if you get one
  • In the drop down box select your main drive i.e. C
  • For a few moments the system will make some calculations
  • Select the More Options tab
  • In the System Restore and Shadow Backups select Clean up
  • Select Delete on the pop up
  • Select OK
  • Select Delete
You are now done
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 14310
Post by Kirbie on 1st April 2010, 2:38 pm
I Just ran the OTC.exe by OldTimer and there are a few programs left after reboot. I'm not sure which of these I should keep for protection. I have Ad-Aware, Ad-Aware Installer, A-squared Hijack Free, Vtool folder, FIX WU Folder, Malware Bytes and AntiMalware, and Win32KDiag.
Should any of these things be kept for the protection of my pc?
Kirbie
Posts Posts : 51
Post by Dr Jay on 1st April 2010, 2:51 pm
Delete all of those except for Ad-Aware and Malwarebytes. Smile
Posts Posts : 14310
Post by Kirbie on 1st April 2010, 3:21 pm
My recycle bin is missing...lol Shocking Whoa I typed it in the search of my start menu and still got nothing.
Kirbie
Posts Posts : 51
Post by Kirbie on 1st April 2010, 3:24 pm
Last edited by Kirbie on 1st April 2010, 3:25 pm; edited 1 time in total (Reason for editing : Wrong image was posted!)
Kirbie
Posts Posts : 51
Post by Dr Jay on 1st April 2010, 6:27 pm
Right click on your Desktop and choose Personalize.
Then, on the left, click Change Desktop Icons.
When the window pops up, make sure there is a check next to Recycle Bin, and hit OK.
Return to your Desktop, and it should be there.
Posts Posts : 14310
Post by Kirbie on 1st April 2010, 9:03 pm
Everything has been run. This is the log you requested:
Results of screen317's Security Check version 0.99.2
Windows Vista (UAC is enabled)
Out of date service pack!!
Internet Explorer 8
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 8.5
ESET Online Scanner v3
WMI entry may not exist for antivirus; attempting automatic update.
Ad-Aware
Malwarebytes' Anti-Malware
AVS Registry Cleaner version 1.1
Java(TM) 6 Update 18
Java(TM) SE Development Kit 6 Update 18
Adobe Flash Player 10
Adobe Reader 8.1.3
Process Check:
objlist.exe by Laurent
Ad-Aware AAWService.exe
Ad-Aware AAWTray.exe
AVG avgwdsvc.exe
AVG avgtray.exe
DNS Vulnerability Check:
Kirbie
Posts Posts : 51
Post by Dr Jay on 2nd April 2010, 3:12 am
Please consider updating to Windows Vista Service Packs 1 & 2.
Windows Vista Service Packs 1 & 2 contain all the updates released since the first release plus support for new types of hardware and emerging hardware standards.
It is now available via [You must be registered and logged in to see this link.] or as a standalone installation [You must be registered and logged in to see this link.].
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 14310
Post by Kirbie on 4th April 2010, 4:03 am
1. As far as antispyware and firewall suggestions above, do I need all of those or do I just need to have at least one of them?
2. I followed the directions via Windows update, etc. to get Vista Service Packs 1&2 and my computer does not even show an update failed/successful for 1. For 2, it seems to always fail, with about 12+ other updates. According to the site, I shouldn't do the direct download for just a single computer. Is there anything I can do about this? My husband told me over the phone that there has been an issue with those updates for a long time now and it is going to require some disk to repair. Is there another way?
3. The same Windows Defender error keeps popping up upon restart of my system. Can I delete this program from my computer without messing up anything else?
4. I am trying to update Adobe Reader but i cannot uninstall it. Do you know what this means?
Kirbie
Posts Posts : 51
Post by Dr Jay on 5th April 2010, 3:12 am
1. No, just one of each.
2. Since it is more of a technical issue, I would recommend to post in the following section: [You must be registered and logged in to see this link.]
3. You can disable it.
4. Try to install the new version, then attempt to uninstall the old version after.
Posts Posts : 14310
Post by Kirbie on 6th April 2010, 7:41 am
Helpful is a complete understatement. I am very grateful for this site and all that you all provide. My very livelihood depends on this machine at this point in life and you have kept that afloat. Thank you, thank you, thank you!
Thank You! You are indeed a jewel.
Kirbie
Posts Posts : 51
Post by Dr Jay on 6th April 2010, 4:32 pm
You're welcome.
Posts Posts : 14310
