Hijackthis Problems
Page 1 of 2 1, 2  Next
Re: Hijackthis Problems
Post by Dr Jay on 22nd March 2010, 9:04 pm
Please go to Start > Control Panel > Add or Remove Programs and remove the following (if present):
  • Kiwee Toolbar
Please run OTL.exe.
    :files
    C:\Users\Broadcast\AppData\Local\23755159.dll
    :folders
    C:\Users\Broadcast\AppData\Local\QJyrk5wvCU1
    C:\ProgramData\QJyrk5wvCU1
    :commands
    [purity]
    [emptytemp]
    [reboot]
  • Close OTL.exe
Posts Posts : 14317
Points Points : 303008
Post by Kirbie on 22nd March 2010, 10:52 pm
I don't have Add/ Remove in my Control Panel so I chose "Programs" and then Programs and Features which gave me a list of programs on my pc that I could change or uninstall.
In that listing, I did not see Kiwee Toolbar but I am pretty sure it's on here because I see the window pop out of the bottom right corner and I can see the toolbar in my webpage at this very moment.
Kirbie
Posts Posts : 51
Joined Joined : 2010-03-17
OS OS : Windows Vista
Points Points : 25173
Post by Kirbie on 22nd March 2010, 10:55 pm
I see Kiwee Toolbar checked when I click View, then Toolbars in my web browser.
Kirbie
Posts Posts : 51
Post by Dr Jay on 22nd March 2010, 11:48 pm
After doing the above fix, do this fix, please.
Please run OTL.exe.
    :otl
    FF - prefs.js..browser.search.selectedEngine: "Kiwee Live Search"
    FF - prefs.js..keyword.URL: "http://kwtb.search.imgag.com/?c=GNKIW29193&sbs=1&sc=2&f=web&vernum=1.0&uid=&did=f8d4a70c-98e2-4081-901d-01bf93043ede&q="
    FF - HKLM\software\mozilla\Firefox\Extensions\\toolbar@kiwee.com: C:\Program Files (x86)\Kiwee Toolbar\2.9.201\firefox [2009/07/07 12:55:45 | 000,000,000 | ---D | M]
    O2 - BHO: (Kiwee Toolbar) - {6638A9DE-0745-4292-8A2E-AE530E7B9B3F} - C:\Program Files (x86)\Kiwee Toolbar\2.9.201\KiweeIEToolbar.dll (AG Interactive)
    O3 - HKLM\..\Toolbar: (Kiwee Toolbar) - {6638A9DE-0745-4292-8A2E-AE530E7B9B3F} - C:\Program Files (x86)\Kiwee Toolbar\2.9.201\KiweeIEToolbar.dll (AG Interactive)
    O3 - HKCU\..\Toolbar\WebBrowser: (Kiwee Toolbar) - {6638A9DE-0745-4292-8A2E-AE530E7B9B3F} - C:\Program Files (x86)\Kiwee Toolbar\2.9.201\KiweeIEToolbar.dll (AG Interactive)
    :files
    C:\Users\Broadcast\AppData\Roaming\Mozilla\FireFox\Profiles\07vm14rp.default\searchplugins\kiwee-live-search.xml
    :commands
    [emptytemp]
    [reboot]
  • Close OTL.exe
Posts Posts : 14317
Post by Kirbie on 24th March 2010, 2:33 pm
The 1st fix that I was running said that a problem cause OTL to close and it had to stop the program. After it closed, I clicked to open it again and the notepad that popped up basically said to reboot. There were two sentences there about problems and errors I think that would fix upon reboot. So that is what I did. I'm not sure if that was the notepad that I should have pasted here or not, because the program did stop running and it did not create itself like it usually does after a scan is complete. Please advise. Upon reboot, I am still getting this window everytime about Windows Defender(is that a virus?).
Kirbie
Posts Posts : 51
Post by Dr Jay on 24th March 2010, 5:35 pm
If OTL will not work, then please go to Control Panel > Programs and Features and uninstall Kiwee Toolbar. It is spyware/adware.
For Windows Defender error, let's do this.
Please open Notepad and enter in the following:
@echo off
echo Now doing DLL cleanup. If you do not want this, exit now...
pause
echo DLL Cleanup > dllcleanup.txt
regsvr32 /u wuapi.dll >> dllcleanup.txt
regsvr32 /u wuaueng.dll >> dllcleanup.txt
regsvr32 /u wucltui.dll >> dllcleanup.txt
regsvr32 /u wups.dll >> dllcleanup.txt
regsvr32 /u wuweb.dll >> dllcleanup.txt
regsvr32 /u atl.dll >> dllcleanup.txt
regsvr32 /u softpub.dll >> dllcleanup.txt
regsvr32 /u wintrust.dll >> dllcleanup.txt
regsvr32 /u initpki.dll >> dllcleanup.txt
regsvr32 /u mssip32.dll >> dllcleanup.txt
pause
regsvr32 /s wuapi.dll >> dllcleanup.txt
regsvr32 /s wuaueng.dll >> dllcleanup.txt
regsvr32 /s wucltui.dll >> dllcleanup.txt
regsvr32 /s wups.dll >> dllcleanup.txt
regsvr32 /s wuweb.dll >> dllcleanup.txt
regsvr32 /s atl.dll >> dllcleanup.txt
regsvr32 /s softpub.dll >> dllcleanup.txt
regsvr32 /s wintrust.dll >> dllcleanup.txt
regsvr32 /s initpki.dll >> dllcleanup.txt
regsvr32 /s mssip32.dll >> dllcleanup.txt
echo (((((( EOF )))))) >> dllcleanup.txt
start dllcleanup.txt
pause
delete dllcleanup.bat
Then, click File > Save as...
Save as dllcleanup.bat to your Desktop.
Choose Save as type... All Files.
Click Save.
Then, exit Notepad.
Double-click on dllcleanup.bat, and it will finish quickly and launch a log.
Please post that in your next reply.
Last edited by DragonMaster Jay on 25th March 2010, 7:07 pm; edited 1 time in total
Posts Posts : 14317
Post by Kirbie on 25th March 2010, 5:45 pm
I do not have "Programs and Features" in my control panel, nor do I have "Add/Remove" Programs. So I typically go to control panel and choose "Programs".
Unfortunately, Kiwee does not show up in that list no matter how many times I view it. I went to their website using the toolbar above and found their uninstall instructions, which are basically what you told me to do, but using Add/Remove. There is a second option that they provided in event that the first doesn't work. I have pasted that below. Do you suggest I go that route?
Kiwee Toolbar : Updating / Removing the Kiwee Toolbar
How do I uninstall the Toolbar?
To uninstall the Kiwee Toolbar simply follow these steps:
1. Open the Windows Control Panel
2. Select "Add / Remove Programs" (Vista/Win 7-Programs, and then Programs and Features)
3. Select the Kiwee Toolbar from the list of installed applications
4. Click on the "Remove" button
5. Once the Kiwee Toolbar Uninstaller launches, follow the on screen prompts
If that doesn't work, here's Plan B:
1. close your Internet Explorer and Mozilla Firefox sessions and your messenger applications; hit CTRL+SHIFT+ESC to open Task Manager, highlight the kwtbaim.exe process and click "end process". Then close the task manager.
2. check your Control Panel for any Kiwee entries and delete all the ones you find
3. go to C:\Program Files and delete the AGI folder
4. go to C:\Documents and Settings\All Users\Application Data\agi (it may be located under C:\Users\(your PC name)and make sure that no folders exist for Kiwee; if one does, delete it. If you don't see an entry for Application Data, you will need to do the following go to Tools -> Folder Options-> View tab and make sure that the first 7 options under Files and Folders are checked. Then go to the Hidden Files and Folders menu and make sure that the radio button for "Show Hidden Files and Folders" is clicked and that the Hide extensions for known file types and Hide protected operating system files (Recommended) are not checked.
Once you follow these steps, you should be able to see all Application Folders.
5. go to C:\Documents and Settings\Guest\Application Data\AGI (it may be located under C:\Users\(your PC name) and make sure that no folder exists for Kiwee; if one does, delete it.
For Windows Vista and Windows 7 you need to make sure you're logged in as Admin and click continue when the system asks for permissions to proceed. Only as Admin you have rights to access and modify files and folders on drive C.
This will remove Kiwee toolbar completely from your computer. The toolbar we provide is both spyware and malware free and there is no virus associated with it, so it's perfectly safe to use on a computer that meets the minimal system requirements. We hope you'll join us again in the future.
Kirbie
Posts Posts : 51
Post by Dr Jay on 25th March 2010, 5:50 pm
You can try it if you like.
Posts Posts : 14317
Post by Kirbie on 25th March 2010, 6:05 pm
DLL Cleanup gave me these responses in this order.
Then it produced a notepad called DLL cleanup which only said : "DLL Cleanup" and another document titled dllcleanup.txtv
Kirbie
Posts Posts : 51
Post by Dr Jay on 25th March 2010, 7:13 pm
Please download [You must be registered and logged in to see this link.] and save to your Desktop.
  • Extract it to your Desktop.
  • Then, double-click on the program and click the Fix Windows Update button.
  • Reboot your computer and see if it will work now.
Posts Posts : 14317
Post by Kirbie on 25th March 2010, 9:56 pm
Did that and I went the same thing as last time, but when I clicked "ok" through all the errors that kept popping up like before, the end result was a notepad document with this:
DLL Cleanup
(((((( EOF ))))))
Kirbie
Posts Posts : 51
Post by Dr Jay on 26th March 2010, 1:16 am
Now, test to see if it will update.
Posts Posts : 14317
Post by Kirbie on 26th March 2010, 4:41 am
Excuse me if I seem a little slow, but I have gotten confused in the midst of all of my issues popping up. What exactly am I checking now?
Kirbie
Posts Posts : 51
Post by Dr Jay on 26th March 2010, 2:32 pm
Whether Windows Defender will update or not?
Posts Posts : 14317
Post by Kirbie on 26th March 2010, 3:15 pm
Same windows defender message upon start-up Sad tearing The uninstall for Kiwee couldn't be done because that process was not found in the task manager either.
Kirbie
Posts Posts : 51
Post by Dr Jay on 26th March 2010, 6:04 pm
Would you like to use a different anti-spyware program?
Posts Posts : 14317
Post by Kirbie on 26th March 2010, 7:00 pm
I don't care at all. I didn't install anything on this computer in the beginning. Those things are typically done by my husband or step-son, however neither of them are in town, so whatever you tell me to do that is going to make this thing virus free and safe is what is going to happen. And there will be no complaints from anyone! This is my means of work and communication; even my phone is attached to my computer, so PLEASE fire away! (Gunsmoke) If it works, let's do it.
Kirbie
Posts Posts : 51
Post by Dr Jay on 26th March 2010, 7:03 pm
Try to download and install Ad-Aware: [You must be registered and logged in to see this link.]
Posts Posts : 14317
Post by Kirbie on 29th March 2010, 3:03 pm
The Ad-Aware Plus that is on their site seems like it may be good. Both the Ad-Aware Free and Plus require me to complete some form of financial offer on their site to get the software for free. Since that is the case, is the Plus a better candidate to do the financial offer for or is the regular one better for my computer?
Kirbie
Posts Posts : 51
Post by Dr Jay on 29th March 2010, 3:21 pm
Just the free version will work well.
But, that is up to you.
Posts Posts : 14317
Post by Kirbie on 30th March 2010, 4:19 am
My confusion lies in the fact that BOTH are "free", but according to the site, I must make a purchase by completing an offer first.
Kirbie
Posts Posts : 51
Post by Dr Jay on 30th March 2010, 4:49 am
The gray download button is for the "real" free version.
The Ad-Aware Plus is on a "Trial-Pay" marketing technique. It is quite weird.
Here is a better download link for only the free version:
Posts Posts : 14317
Post by Kirbie on 30th March 2010, 5:56 am
All done!
Kirbie
Posts Posts : 51
Post by Dr Jay on 30th March 2010, 7:01 pm
Good. Right On!
Posts Posts : 14317
Post by Kirbie on 31st March 2010, 2:34 am
Anything I'm supposed to do now?
Kirbie
Posts Posts : 51
Post by Dr Jay on 31st March 2010, 4:03 am
  • Click Start
  • Click Start
Posts Posts : 14317
Post by Kirbie on 1st April 2010, 12:42 am
OnlineScanner64.ocx - registred OK
Kirbie
Posts Posts : 51
Post by Dr Jay on 1st April 2010, 4:18 am
To manually create a new Restore Point
  • Go to Control Panel and select System and Maintenance
  • Select System
  • On the left select Advance System Settings and accept the warning if you get one
  • Select System Protection Tab
  • Select Create at the bottom
  • Type in a name i.e. Clean
  • Select Create
Now we can purge the infected ones
  • Go back to the System and Maintenance page
  • Select Performance Information and Tools
  • On the left select Open Disk Cleanup
  • Select Files from all users and accept the warning if you get one
  • In the drop down box select your main drive i.e. C
  • For a few moments the system will make some calculations
  • Select the More Options tab
  • In the System Restore and Shadow Backups select Clean up
  • Select Delete on the pop up
  • Select OK
  • Select Delete
You are now done
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 14317
Post by Kirbie on 1st April 2010, 2:38 pm
I Just ran the OTC.exe by OldTimer and there are a few programs left after reboot. I'm not sure which of these I should keep for protection. I have Ad-Aware, Ad-Aware Installer, A-squared Hijack Free, Vtool folder, FIX WU Folder, Malware Bytes and AntiMalware, and Win32KDiag.
Should any of these things be kept for the protection of my pc?
Kirbie
Posts Posts : 51
Post by Dr Jay on 1st April 2010, 2:51 pm
Delete all of those except for Ad-Aware and Malwarebytes. Smile
Posts Posts : 14317
Post by Kirbie on 1st April 2010, 3:21 pm
My recycle bin is missing...lol Shocking Whoa I typed it in the search of my start menu and still got nothing.
Kirbie
Posts Posts : 51
Post by Kirbie on 1st April 2010, 3:24 pm
Last edited by Kirbie on 1st April 2010, 3:25 pm; edited 1 time in total (Reason for editing : Wrong image was posted!)
Kirbie
Posts Posts : 51
Post by Dr Jay on 1st April 2010, 6:27 pm
Right click on your Desktop and choose Personalize.
Then, on the left, click Change Desktop Icons.
When the window pops up, make sure there is a check next to Recycle Bin, and hit OK.
Return to your Desktop, and it should be there.
Posts Posts : 14317
Post by Kirbie on 1st April 2010, 9:03 pm
Everything has been run. This is the log you requested:
Results of screen317's Security Check version 0.99.2
Windows Vista (UAC is enabled)
Out of date service pack!!
Internet Explorer 8
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 8.5
ESET Online Scanner v3
WMI entry may not exist for antivirus; attempting automatic update.
Ad-Aware
Malwarebytes' Anti-Malware
AVS Registry Cleaner version 1.1
Java(TM) 6 Update 18
Java(TM) SE Development Kit 6 Update 18
Adobe Flash Player 10
Adobe Reader 8.1.3
Process Check:
objlist.exe by Laurent
Ad-Aware AAWService.exe
Ad-Aware AAWTray.exe
AVG avgwdsvc.exe
AVG avgtray.exe
DNS Vulnerability Check:
Kirbie
Posts Posts : 51
Post by Dr Jay on 2nd April 2010, 3:12 am
Please consider updating to Windows Vista Service Packs 1 & 2.
Windows Vista Service Packs 1 & 2 contain all the updates released since the first release plus support for new types of hardware and emerging hardware standards.
It is now available via [You must be registered and logged in to see this link.] or as a standalone installation [You must be registered and logged in to see this link.].
Go to the Control Panel and enter Add or Remove Programs (Programs and Features in Vista/7).
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 14317
Post by Kirbie on 4th April 2010, 4:03 am
1. As far as antispyware and firewall suggestions above, do I need all of those or do I just need to have at least one of them?
2. I followed the directions via Windows update, etc. to get Vista Service Packs 1&2 and my computer does not even show an update failed/successful for 1. For 2, it seems to always fail, with about 12+ other updates. According to the site, I shouldn't do the direct download for just a single computer. Is there anything I can do about this? My husband told me over the phone that there has been an issue with those updates for a long time now and it is going to require some disk to repair. Is there another way?
3. The same Windows Defender error keeps popping up upon restart of my system. Can I delete this program from my computer without messing up anything else?
4. I am trying to update Adobe Reader but i cannot uninstall it. Do you know what this means?
Kirbie
Posts Posts : 51
Post by Dr Jay on 5th April 2010, 3:12 am
1. No, just one of each.
2. Since it is more of a technical issue, I would recommend to post in the following section: [You must be registered and logged in to see this link.]
3. You can disable it.
4. Try to install the new version, then attempt to uninstall the old version after.
Posts Posts : 14317
Post by Kirbie on 6th April 2010, 7:41 am
Helpful is a complete understatement. I am very grateful for this site and all that you all provide. My very livelihood depends on this machine at this point in life and you have kept that afloat. Thank you, thank you, thank you!
Thank You! You are indeed a jewel.
Kirbie
Posts Posts : 51
Post by Dr Jay on 6th April 2010, 4:32 pm
You're welcome.
Posts Posts : 14317
