Linksys USB Adapter with signal, but no connection
Post by runner7* on Mon Mar 15, 2010 12:08 am
I have a new wifi set up that works, and I purchased a Linksys USB Nework Adapter. I successfully connected it, and it shows that I have a strong signal, but it won't allow me to get on the internet via internet explorer. I am not very savvy, but if you could give me directions, I am hoping I could fix it. Thanks in advance.
runner7*
Joined Joined : 2010-03-15
Points Points : 24573
Re: Linksys USB Adapter with signal, but no connection
Post by makxp77 on Tue Mar 16, 2010 4:46 pm
Which version of Windows are you using? Do youh ave DSL, Cable or Dialup?
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29044
Post by runner7* on Tue Mar 16, 2010 7:06 pm
I have Windows XP and I have wireless using a MiFi connection from Verizon. (Would that be the same as DSL?) Two laptops in the house work fine with the wireless. Thanks!
runner7*
