problems after anti virus soft removal
Re: problems after anti virus soft removal
Post by cob on 2nd March 2010, 6:53 pm
I'll be gone for about 9 hours then I'll be on after that. If theres anything I should do beyond the instructions per your last post maybe I could do all that and then wait for your response. In any case, I really appreciate your help.
cob
Posts Posts : 16
Joined Joined : 2010-03-02
OS OS : xp home
Points Points : 24969
Post by Belahzur on 2nd March 2010, 7:04 pm
Okay, catch ya soon.
Can't really go any further until I know atapi.sys is okay, leaving it to chance isn't worth the damage it will cause.
Points Points : 245101
Post by cob on 3rd March 2010, 12:50 pm
Hi, I'm back now. Could you tell me, given what we did yesterday, what was found on my computer ad what was removed? Thanks.
cob
Posts Posts : 16
OS OS : xp home
Post by Belahzur on 3rd March 2010, 1:29 pm
Follow instructions in this post:
