HELP with BankerFox.A and Nuqel.exe
Post by belisa33 on Fri Feb 26, 2010 7:07 pm
I keep getting popups for viagra porn and two virus remover programs? I can't download anything because a box pops up that says the file _____.exe is infected for any file i try to open. It won't let me run any of my anti virus software. I am at a loss as to what to do next....
belisa33
OS : Windows XP
# Likes : 0
Re: HELP with BankerFox.A and Nuqel.exe
Post by Dr Jay on Fri Feb 26, 2010 7:08 pm
OS : Windows 10 Home & Pro
# Likes : 10
