NO SOUND
NO SOUND
Post by Vista on Thu Feb 25, 2010 6:46 pm
I have no sound on my PC. A pop up came up and said I needed to install a Media Player. I am not sure if that has anything to do with it. Please advise. Thanks Smile
Vista
Gender : Female
OS : Windows 8
Re: NO SOUND
Post by Dr Jay on Fri Feb 26, 2010 2:57 pm
Please download the latest version of Kaspersky GetSystemInfo (GSI) from Kaspersky.fr and save it to your Desktop.
  • Please close all other applications running on your system.
  • Please double click GetSystemInfo.exe to open it.
  • Click the Settings button.
  • Set it to Maximum
  • IMPORTANT! Then please click Customize - choose Driver / Ports tab and
  • Uncheck Scan Ports.
  • Click Create Report to run it.
  • It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop. Please upload the folder to Kaspersky GSI Parser and click the Submit button.
OS : Windows 10 Home & Pro
Re: NO SOUND
Post by Vista on Fri Mar 05, 2010 9:03 pm
Vista
Gender : Female
OS : Windows 8
Re: NO SOUND
Post by Dr Jay on Sat Mar 06, 2010 8:32 am
Are you able to reinstall the sound driver?
Re: NO SOUND
Post by Vista on Sat Mar 13, 2010 1:18 am
I am not able to reinstall the driver. Followed the directions and did not install. Please advise.
Vista
Gender : Female
OS : Windows 8
Re: NO SOUND
Post by Vista on Sat Mar 13, 2010 1:28 am
No, I can not install the sound driver. Please advise.
Vista
Gender : Female
OS : Windows 8
Re: NO SOUND
Post by Dr Jay on Sat Mar 13, 2010 6:17 pm
Did you remove it first, then install it again?
Re: NO SOUND
Post by Vista on Wed Apr 28, 2010 12:54 am
Vista
Gender : Female
OS : Windows 8
