Malware-Search Engine Hijacked
Re: Malware-Search Engine Hijacked
Post by Dr Jay on 7th March 2010, 2:58 am
Now, how is your computer running? Still search engine hijacks?
Posts Posts : 14309
Points Points : 302970
Post by bigbadjonv on 8th March 2010, 1:16 am
Doesn't seem to be, but I'm not sure what fixed it.
bigbadjonv
Posts Posts : 14
Joined Joined : 2010-02-24
Points Points : 25008
Post by Dr Jay on 8th March 2010, 4:33 am
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
Posts Posts : 14309
