wireless home network
Post by Angelyne on 23rd February 2010, 12:36 am
ive been trying to set up a home wireless network. My satellite internet service, connects to a desktop. The printer is usually connected to the desktop, but I would like to be able to print from the laptop since thats usually what I use the most. I have a wireless router and thought if I connected the printer to the router it might work, but wondering if its necessary to have a wireless printer. My printer is an older one, so I doubt that its wireless. Does it need to be? Thanx everyone
Angelyne
Posts Posts : 5
Joined Joined : 2009-09-27
OS OS : vista
Points Points : 26339
Re: wireless home network
Post by amir20001 on 24th February 2010, 10:57 pm
no it dose not need to be wireless, it might makethings easyer but not nessary. if it has a network connection such as an ethernet cable port it would also work. even if has non of these it will still work ur just gonna have to use the desktop as a print server i witch means u need to keep that desktop on when ever u wanna print from it
amir20001
Posts Posts : 83
Joined Joined : 2008-08-08
Points Points : 30861
Post by Angelyne on 25th February 2010, 1:02 am
thank you for replying and for your help. Do I need to use a cable to connect the printer to the desktop, or, do I need to do anything else. Again, thank you.
Angelyne
Posts Posts : 5
OS OS : vista
Post by makxp77 on 1st March 2010, 10:47 pm
If you go wireless - NO
You will need a usb cable if you want to plug it into your Computer (Desktop)
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29104
