I Need Help
I Need Help
Post by lenitas on Sat Feb 20, 2010 10:22 pm
One of my computers on my network is infected with Win32/Nutel.E and BankerFox.A. Can I use safely the other computer on the network to go online and change my account passwords? I have the infected computer disconnected from the network.
lenitas
Posts Posts : 13
Joined Joined : 2010-02-20
Points Points : 24973
Re: I Need Help
Post by lenitas on Sat Feb 20, 2010 10:25 pm
I had a typo in my first message. It's Win32/Nugel.E and BankerFox.A viruses.
lenitas
Posts Posts : 13
Re: I Need Help
Post by Belahzur on Sat Feb 20, 2010 11:46 pm
Points Points : 245049
I Need Help
Post by lenitas on Sun Feb 21, 2010 12:03 am
I d/loaded OTL, Avenger, Commy & IceSword on this computer. I transferred OTL & Avenger to the infected computer via USB, and it won't let me use either one of them. It says everything I click on is infected. It won't open anything programs. I have it disconnected from my network and the internet.
lenitas
Posts Posts : 13
Re: I Need Help
Post by Belahzur on Sun Feb 21, 2010 12:09 am
Rename IceSword.exe to explorer.exe and see if it runs.
If not, keep trying, it will eventually work, IceSword renames itself when run.
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 12:21 am
Ok, I'll have to transfer it by USB and try it next. Thanks.
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 12:40 am
It won't let me rename anything but the zipped file. It says it has unzipped the files, but they are still named IceSword. It won't let me run it. I get a popup that says: "Application cannot be executed. The file wscntfy.exe is infected. Do you want to activate your antivirus software now?" (software they are trying to sell me...not what's on my computer).
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 12:47 am
Now an IceSword box has opened with the logo in it and a list of icons on the left side. Do I click on any of them? It's not doing anything.
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 1:02 am
I clicked on Process and saved the log. Then I clicked on Startup and saved that log too. When I go to the next step and click on process again, I don't find a file named fllnsysguard.exe.
I was reading your instructions to someone else, so they may not apply to me.
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 1:19 am
Here's the first log I saved:
Process:
System Idle Process
System
C:\WINDOWS\system32\WDBtnMgr.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
C:\WINDOWS\wt\updater\wcmdmgr.exe
C:\WINDOWS\system\hpsysdrv.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\Unload\HpqCmon.exe
C:\Program Files\WDC\CR\SetIcon.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\hp\KBD\kbd.exe
C:\WINDOWS\system32\smss.exe
C:\PROGRA~1\HPINST~1\plugin\bin\PCHButton.exe
C:\Documents and Settings\Owner\Local Settings\Application Data\rdxjba\etgmsftav.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\brss01a.exe
C:\WINDOWS\explorer.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\system32\Brmfrmps.exe
C:\Program Files\CA\SharedComponents\CA_LIC\lic98rmt.exe
C:\Program Files\CA\SharedComponents\CA_LIC\LogWatNT.exe
C:\Program Files\Common Files\McAfee\MNA\McNASvc.exe
C:\PROGRA~1\COMMON~1\McAfee\McProxy\McProxy.exe
C:\PROGRA~1\McAfee\VIRUSS~1\Mcshield.exe
C:\Program Files\McAfee\MPF\MpfSrv.exe
C:\PROGRA~1\Dantz\RETROS~1\wdsvc.exe
C:\WINDOWS\system32\wbem\wmiprvse.exe
C:\WINDOWS\system32\alg.exe
C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
C:\DOCUME~1\Owner\LOCALS~1\Temp\Temporary Directory 5 for explorer.exe.zip\IceSword122en\IceSword.exe
C:\WINDOWS\system32\rundll32.exe
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 1:20 am
Here's the second log:
Startup:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
WD Button Manager
"C:\WINDOWS\system32\WDBtnMgr.exe"
wcmdmgr
C:\WINDOWS\wt\updater\wcmdmgrl.exe -launch
UpdateManager
"C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
Recguard
"C:\WINDOWS\SMINST\RECGUARD.EXE"
NvCplDaemon
"C:\WINDOWS\system32\RUNDLL32.EXE" NvQTwk,NvCplDaemon initialize
IgfxTray
"C:\WINDOWS\system32\igfxtray.exe"
hpsysdrv
"c:\windows\system\hpsysdrv.exe"
HPDJ Taskbar Utility
"C:\WINDOWS\System32\spool\drivers\w32x86\3\hpztsb04.exe"
HotKeysCmds
"C:\WINDOWS\system32\hkcmd.exe"
dla
"C:\WINDOWS\system32\dla\tfswctrl.exe"
checktime
"c:\program files\HPSelect\Frontend\ct.exe"
CamMonitor
"c:\Program Files\Hewlett-Packard\Digital Imaging\Unload\hpqcmon.exe"
AlcxMonitor
"C:\WINDOWS\ALCXMNTR.EXE"
SetIcon
"\Program Files\WDC\CR\SetIcon.exe"
nwiz
"C:\WINDOWS\system32\nwiz.exe" /install
mcagent_exe
"C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
KBD
"C:\HP\KBD\KBD.EXE"
ewhvngif
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
ctfmon.exe
Acme.PCHButton
"C:\PROGRA~1\HPINST~1\plugin\bin\pchbutton.exe"
ewhvngif
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
desktop.ini
C:\Documents and Settings\Owner\Start Menu\Programs\Startup
desktop.ini
lenitas
Posts Posts : 13
Re: I Need Help
Post by Belahzur on Sun Feb 21, 2010 1:50 am
  • Open IceSword again.
  • Go into the Process list again, and right click on the following filename:
    etgmsftav.exe
  • Select Terminate Process.
  • Close Icesword.
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 1:57 am
I already have Malwarebytes on the infected computer. It says it's scanning now. I did the quick scan. Do I need to reinstall it?
lenitas
Posts Posts : 13
Re: I Need Help
Post by Belahzur on Sun Feb 21, 2010 1:59 am
No, quick scan will do fine.
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 2:22 am
Mbam can't update on the infected computer because I have it offline. I read on here to take it offline, so I did.
Pls tell me what to do now....do you think the one I downloaded is up-to-date? Thanks.
lenitas
Posts Posts : 13
Re: I Need Help
Post by lenitas on Sun Feb 21, 2010 2:55 am
I installed the mbam file I d/loaded on here and re-scanned. Here's the log for the second scan: Still says nothing infected.
Database version: 3510
2/20/2010 8:49:55 PM
mbam-log-2010-02-20 (20-49-55).txt
Objects scanned: 123170
Time elapsed: 13 minute(s), 55 second(s)
lenitas
Posts Posts : 13
Re: I Need Help
Post by Belahzur on Sun Feb 21, 2010 4:32 pm
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan.
Re: I Need Help
Post by lenitas on Mon Feb 22, 2010 11:53 pm
The viruses kept getting worse, or multiplying. It got so bad nothing would open. I have a computer tech here looking at it now. Will get back to you if necessary. Thanks much for all your assistance.
lenitas
Posts Posts : 13
