anti virus pro 2010...help
Post by traintrackmaniac on Thu Feb 18, 2010 9:58 pm
Yesterday I got this trojan and it has been a pain in the ass. It won't let me browse the internet without using internet explore without addons. I've tried every recommended spyware removal tool, ie: spybot, malware bytes, ad aware, and I even went out and bought spyware doctor, which did pick it up and removed it, however, on reboot, my computer did not work at all. I could not open any .exe files at all, and when trying to re install them, it would say the file could not be found. I managed to use system restore and restore my computer back to it's infected state, which is better than no computer at all. I am at wits end with this and I hope you guys can help me. Thanks.
traintrackmaniac
Posts Posts : 4
Joined Joined : 2010-02-18
OS OS : vista
Points Points : 24842
Re: anti virus pro 2010...help
Post by Dr Jay on Thu Feb 18, 2010 10:20 pm
Posts Posts : 13713
Points Points : 302069
Post by traintrackmaniac on Thu Feb 18, 2010 10:37 pm
It seems to have left my computer...here is the log:
ComboFix 10-02-18.05 - steve 18/02/2010 17:28:50.1.2 - x86
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.2.1033.18.2814.1467 [GMT -5]
Running from: c:\users\steve\Desktop\commy.exe
SP: Lavasoft Ad-Watch Live! *disabled* (Updated) {67844DAE-4F77-4D69-9457-98E8CFFDAA22}
c:\program files\temp
c:\windows\expert
c:\users\steve\AppData\Local\av.exe
c:\users\steve\AppData\Local\Microsoft\Windows\Temporary Internet Files\1bayx7A.jpg
c:\users\steve\AppData\Local\Microsoft\Windows\Temporary Internet Files\41Ma1YPy.jpg
c:\users\steve\AppData\Local\Microsoft\Windows\Temporary Internet Files\B6pOox.jpg
c:\users\steve\AppData\Local\Microsoft\Windows\Temporary Internet Files\BBpKa.jpg
c:\windows\expert\XSNCR.INI
c:\windows\msnimport.exe
((((((((((((((((((((((((( Files Created from 2010-01-18 to 2010-02-18 )))))))))))))))))))))))))))))))
2010-02-18 22:33 . 2010-02-18 22:33 -------- d-----w- c:\users\steve\AppData\Local\temp
2010-02-18 22:33 . 2010-02-18 22:33 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-02-18 20:45 . 2010-02-18 21:20 -------- d-----w- c:\program files\Spyware Doctor
2010-02-18 20:45 . 2010-02-18 20:50 -------- d-----w- c:\program files\Common Files\PC Tools
2010-02-18 20:45 . 2010-02-18 20:45 -------- d-----w- c:\users\steve\AppData\Roaming\PC Tools
2010-02-18 20:45 . 2010-02-18 20:45 -------- d-----w- c:\programdata\PC Tools
2010-02-18 18:41 . 2010-02-18 18:44 -------- d-----w- c:\programdata\Spybot - Search & Destroy
2010-02-18 18:41 . 2010-02-18 18:41 -------- d-----w- c:\program files\Spybot - Search & Destroy
2010-02-18 07:32 . 2010-02-18 07:32 5115824 ----a-w- c:\programdata\Malwarebytes\Malwarebytes' Anti-Malware\mbam-setup.exe
2010-02-18 07:31 . 2010-02-18 07:31 -------- d-----w- c:\users\steve\AppData\Roaming\Malwarebytes
2010-02-18 07:31 . 2009-12-30 19:55 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-02-18 07:31 . 2010-02-19 00:24 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-02-18 07:31 . 2010-02-19 00:24 -------- d-----w- c:\programdata\Malwarebytes
2010-02-18 07:31 . 2009-12-30 19:54 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-02-18 07:05 . 2009-12-31 16:21 -------- d-----w- C:\Malwarebytes Anti-Malware 1.43
2010-02-12 01:19 . 2010-02-19 00:23 -------- d-----w- c:\program files\Microsoft
2010-02-10 01:35 . 2010-02-10 01:35 15880 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\lsdelete.exe
2010-02-10 01:35 . 2010-02-10 01:35 163728 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\ShellExt.dll
2010-02-10 01:35 . 2010-02-10 01:35 327000 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\RPAPI.dll
2010-02-10 01:35 . 2010-02-10 01:35 87496 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\PrivacyClean.dll
2010-02-09 19:52 . 2009-12-11 11:43 302080 ----a-w- c:\windows\system32\drivers\srv.sys
2010-02-09 19:52 . 2009-12-11 11:43 98816 ----a-w- c:\windows\system32\drivers\srvnet.sys
2010-02-09 19:52 . 2009-12-08 20:01 904776 ----a-w- c:\windows\system32\drivers\tcpip.sys
2010-02-09 19:52 . 2009-12-08 17:26 30720 ----a-w- c:\windows\system32\drivers\tcpipreg.sys
2010-01-23 00:09 . 2010-01-23 00:09 -------- d-----w- c:\users\steve\AppData\Roaming\DivX
2010-01-23 00:09 . 2010-01-23 00:09 -------- d-----w- c:\program files\Common Files\PX Storage Engine
2010-01-23 00:08 . 2010-01-23 00:09 -------- d-----w- c:\program files\DivX
2010-01-23 00:08 . 2010-01-23 00:09 -------- d-----w- c:\program files\Common Files\DivX Shared
2010-01-20 19:35 . 2010-02-10 01:35 3803208 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\AutoLaunch.exe
2010-02-19 00:24 . 2009-09-08 20:10 -------- d-----w- c:\programdata\HP Product Assistant
2010-02-18 21:04 . 2009-12-19 05:14 -------- d-----w- c:\program files\Windows Live
2010-02-14 02:58 . 2009-09-23 17:26 -------- d-----w- c:\users\steve\AppData\Roaming\Azureus
2010-02-10 08:18 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2010-02-10 01:35 . 2009-12-21 19:36 862040 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\threatwork.exe
2010-02-10 01:35 . 2009-12-21 19:36 206944 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\lavamessage.dll
2010-02-10 01:35 . 2009-12-21 19:36 390288 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\lavalicense.dll
2010-02-10 01:35 . 2009-12-21 19:36 537576 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\aawapi.dll
2010-02-10 01:35 . 2009-12-21 19:36 389784 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\UpdateManager.dll
2010-02-10 01:35 . 2009-12-21 19:36 6296864 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\Resources.dll
2010-02-10 01:35 . 2009-12-21 19:36 933120 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\CEAPI.dll
2010-02-10 01:35 . 2009-12-21 19:36 816784 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\Ad-AwareCommand.exe
2010-02-10 01:35 . 2009-12-21 19:36 823928 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\Ad-AwareAdmin.exe
2010-02-10 01:35 . 2009-12-21 19:36 1643272 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\Ad-Aware.exe
2010-02-10 01:35 . 2009-12-21 19:36 788880 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\AAWTray.exe
2010-02-10 01:35 . 2009-12-21 19:36 1181328 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\AAWService.exe
2010-01-14 16:12 . 2009-10-02 18:42 181120 ------w- c:\windows\system32\MpSigStub.exe
2010-01-03 04:36 . 2010-01-03 04:36 356352 ----a-w- c:\windows\eSellerateEngine.dll
2010-01-03 04:32 . 2010-01-03 04:32 -------- d-----w- c:\program files\MSN Content Plus Inc
2010-01-03 04:32 . 2008-04-30 17:43 -------- d--h--w- c:\program files\InstallShield Installation Information
2010-01-02 06:38 . 2010-01-22 13:25 916480 ----a-w- c:\windows\system32\wininet.dll
2010-01-02 06:32 . 2010-01-22 13:25 109056 ----a-w- c:\windows\system32\iesysprep.dll
2010-01-02 06:32 . 2010-01-22 13:25 71680 ----a-w- c:\windows\system32\iesetup.dll
2010-01-02 04:57 . 2010-01-22 13:25 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-12-21 19:36 . 2009-12-21 19:36 194104 ----a-w- c:\programdata\Lavasoft\Ad-Aware\Update\Savapibridge.dll
2009-12-13 08:18 . 2006-11-02 10:25 665600 ----a-w- c:\windows\inf\drvindex.dat
2009-12-08 20:01 . 2010-02-09 19:51 3600456 ----a-w- c:\windows\system32\ntkrnlpa.exe
2009-12-08 20:01 . 2010-02-09 19:51 3548216 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-12-07 14:10 . 2009-12-11 19:30 2953352 -c--a-w- c:\programdata\{BC9FCCF7-E686-494B-8C9B-55C9A39A7CA9}\Ad-AwareInstallation.exe
2009-12-04 22:32 . 2009-10-19 02:43 175 ----a-w- c:\users\steve\AppData\Roaming\Azureus\restart.bat
2009-12-04 18:30 . 2010-02-09 19:51 12288 ----a-w- c:\windows\system32\tsbyuv.dll
2009-12-04 18:29 . 2010-02-09 19:51 1314816 ----a-w- c:\windows\system32\quartz.dll
2009-12-04 18:28 . 2010-02-09 19:51 22528 ----a-w- c:\windows\system32\msyuv.dll
2009-12-04 18:28 . 2010-02-09 19:51 31744 ----a-w- c:\windows\system32\msvidc32.dll
2009-12-04 18:28 . 2010-02-09 19:51 123904 ----a-w- c:\windows\system32\msvfw32.dll
2009-12-04 18:28 . 2010-02-09 19:51 13312 ----a-w- c:\windows\system32\msrle32.dll
2009-12-04 18:28 . 2010-02-09 19:51 82944 ----a-w- c:\windows\system32\mciavi32.dll
2009-12-04 18:28 . 2010-02-09 19:51 50176 ----a-w- c:\windows\system32\iyuv_32.dll
2009-12-04 18:27 . 2010-02-09 19:51 91136 ----a-w- c:\windows\system32\avifil32.dll
2009-12-04 15:56 . 2010-02-09 19:51 212992 ----a-w- c:\windows\system32\drivers\mrxsmb10.sys
2009-12-04 15:56 . 2010-02-09 19:51 105984 ----a-w- c:\windows\system32\drivers\mrxsmb.sys
2009-12-02 13:19 . 2009-12-11 19:35 64288 ----a-w- c:\windows\system32\drivers\Lbd.sys
2009-12-02 13:19 . 2009-12-11 21:27 15880 ----a-w- c:\windows\system32\lsdelete.exe
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{A3BC75A2-1F87-4686-AA43-5347D756017C}"= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-07-24 1090816]
[HKEY_CLASSES_ROOT\clsid\{a3bc75a2-1f87-4686-aa43-5347d756017c}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}]
2009-07-24 13:55 1090816 ----a-w- c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll
"{CCC7A320-B3CA-4199-B1A6-9F516DD69829}"= "c:\program files\AVG\AVG8\Toolbar\IEToolbar.dll" [2009-07-24 1090816]
[HKEY_CLASSES_ROOT\clsid\{ccc7a320-b3ca-4199-b1a6-9f516dd69829}]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\egisPSDP]
@="{30A0A3F6-38AC-4C53-BB8B-0D95238E25BA}"
[HKEY_CLASSES_ROOT\CLSID\{30A0A3F6-38AC-4C53-BB8B-0D95238E25BA}]
2008-03-05 06:38 121392 ----a-w- c:\program files\Acer\Empowering Technology\eDataSecurity\x86\PSDProtect.dll
"WindowsWelcomeCenter"="oobefldr.dll" [2009-04-11 2153472]
"msnmsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2009-07-26 3883856]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-21 202240]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-21 1008184]
"Acer Empowering Technology Monitor"="c:\program files\Acer\Empowering Technology\SysMonitor.exe" [2008-04-25 319488]
"EmpoweringTechnology"="c:\program files\Acer\Empowering Technology\Framework.Launcher.exe" [2008-04-25 319488]
"eDataSecurity Loader"="c:\program files\Acer\Empowering Technology\eDataSecurity\x86\eDSloader.exe" [2008-03-05 526896]
"PCMMediaSharing"="c:\program files\Acer Arcade Live\Acer HomeMedia Connect\Kernel\DMS\PCMMediaSharing.exe" [2008-01-26 204908]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2007-03-08 40048]
"BkupTray"="c:\program files\NewTech Infosystems\NTI Backup Now 5\BkupTray.exe" [2008-04-26 28672]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-04-22 13535776]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-04-22 92704]
"Acer Product Registration"="c:\program files\Acer\Acer Registration\ACE1.exe" [2007-11-26 3387392]
"Acer Assist Launcher"="c:\program files\Acer\Acer Assist\launcher.exe" [2007-11-19 1261568]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-12-11 2043160]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2008-03-26 49152]
"hpqSRMon"="c:\program files\HP\Digital Imaging\bin\hpqSRMon.exe" [2008-03-13 81920]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-07-25 149280]
"Malwarebytes Anti-Malware (reboot)"="c:\program files\Malwarebytes' Anti-Malware\mbam.exe" [2009-12-30 1389904]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2008-3-25 214360]
WinZip Quick Pick.lnk - c:\program files\WinZip\WZQKPICK.EXE [2009-6-19 525640]
"AppInit_DLLs"=c:\windows\System32\avgrsstx.dll
"aux"=wdmaud.drv
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Lavasoft Ad-Aware Service]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc]
"VistaSp2"=hex(b):a6,bf,c1,d6,02,7b,ca,01
R0 Lbd;Lbd;c:\windows\System32\drivers\Lbd.sys [11/12/2009 2:35 PM 64288]
R1 AvgLdx86;AVG Free AVI Loader Driver x86;c:\windows\System32\drivers\avgldx86.sys [16/08/2009 1:19 AM 335240]
R1 AvgTdiX;AVG Free8 Network Redirector;c:\windows\System32\drivers\avgtdix.sys [16/08/2009 1:19 AM 108552]
R2 Acer HomeMedia Connect Service;Acer HomeMedia Connect Service;c:\program files\Acer Arcade Live\Acer HomeMedia Connect\Kernel\DMS\CLMSServer.exe [30/04/2008 1:12 PM 269448]
R2 avg8emc;AVG Free8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [16/08/2009 1:18 AM 908056]
R2 avg8wd;AVG Free8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [16/08/2009 1:18 AM 297752]
R2 BUNAgentSvc;NTI Backup Now 5 Agent Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\Client\Agentsvc.exe [03/03/2008 12:11 PM 16384]
R2 ETService;Empowering Technology Service;c:\program files\Acer\Empowering Technology\Service\ETService.exe [30/04/2008 1:02 PM 24576]
R2 Lavasoft Ad-Aware Service;Lavasoft Ad-Aware Service;c:\program files\Lavasoft\Ad-Aware\AAWService.exe [02/12/2009 8:19 AM 1181328]
R2 NTIBackupSvc;NTI Backup Now 5 Backup Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\BackupSvc.exe [25/04/2008 8:36 PM 45056]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [15/07/2009 1:06 PM 24652]
R3 NVHDA;Service for NVIDIA High Definition Audio Driver;c:\windows\System32\drivers\nvhda32v.sys [29/04/2008 9:28 PM 43552]
S2 NTISchedulerSvc;NTI Backup Now 5 Scheduler Service;c:\program files\NewTech Infosystems\NTI Backup Now 5\SchedulerSvc.exe [25/04/2008 8:36 PM 131072]
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
LocalServiceAndNoImpersonation REG_MULTI_SZ FontCache
LSP: %SYSTEMROOT%\system32\nvLsp.dll
WebBrowser-{D4027C7F-154A-4066-A1AD-4243D8127440} - (no file)
HKCU-Run-Aim6 - (no file)
HKLM-Run-eRecoveryService - (no file)
Rootkit scan 2010-02-18 17:33
Windows 6.0.6002 Service Pack 2 NTFS
Completion time: 2010-02-18 17:34:57
ComboFix-quarantined-files.txt 2010-02-18 22:34
Pre-Run: 69,868,949,504 bytes free
Post-Run: 70,244,511,744 bytes free
- - End Of File - - 62A21453905924540F29D44836C0DF89
traintrackmaniac
Posts Posts : 4
OS OS : vista
Post by Dr Jay on Thu Feb 18, 2010 11:19 pm
Hi again. Please do these steps in order.
1. Please download [You must be registered and logged in to see this link.] to your desktop
  • Click the Start
2. Please download Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.].
Alternate link: [You must be registered and logged in to see this link.].
3. Please visit this webpage for instructions for downloading and running SUPERAntiSpyware (SAS) to scan and remove malware from your computer:
Post the log from SUPERAntiSpyware when you've accomplished that.
4. Please run a free online scan with the [You must be registered and logged in to see this link.]
  • Click Start
  • Click Start
5. Post the following in your next reply:
  • MBAM log
  • SAS log
  • ESET log
And, please tell me how your computer is doing.
Posts Posts : 13713
Post by Dr Jay on Wed Feb 24, 2010 6:17 pm
Still with us?
Posts Posts : 13713
