Website connection problems - res://ieframe.dll/acr_error
Post by Dean63 on 16th February 2010, 12:58 pm
I am having a problem, when i logo on to certain website including ebay, the page loads but then quickly disappears, i then get a recovery message but then lose the page with the message - we are unable to return you to ebay.co.uk, the tab reads - website restore error and in the address bar - res://ieframe.dll/acr_error.htm#ebay.co.uk,http://www.ebay.co.uk/
I am unable to down load anything from microsoft or some other websites including tools to fix the registry, have run malware which removed some items, nothing turned up on AVG scan. Also down loaded the latest Adobe Flash player 10 ActiveX to see if this would solve the problem but nothing, anyone got a solution please
Dean63
Joined Joined : 2010-01-15
OS OS : windows xp
Points Points : 25213
Re: Website connection problems - res://ieframe.dll/acr_error
Post by DoctorAcid on 16th February 2010, 5:20 pm
Check your Internet Connection
Go To Control Panel > Network Connections and try to create another connection.
If you are Connected
Renew IP
Start > Run > ipconfig /renew.
~Acid
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
Joined Joined : 2010-02-12
OS OS : Windows XP, Windows 7 Ultimate
Points Points : 25691
Post by makxp77 on 27th February 2010, 5:07 am
Which browser version are you using?
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29094
