Viruses? Help
Viruses? Help
Post by DoctorAcid on 15th February 2010, 7:31 pm
I Have a lot of Viruses on my Laptop. HP Pavillion dv6000. I Havn't got around to it and dont have the time.
The Viruses i have. Continuously RUNTIME ERROR and Windows Explorer has encountered a problem and needs to close.
Everytime i log on my TaskManager and CMD is Disabled so i Manually have to enable it.
Dr Postmortem Debugger i think has an error. Dont know if this is the right place but it is Viruses. It isnt my laptop, currently my nephew's and he has asked to remove Viruses from it but i didn't have the time. Hoping for some good help. Also Browsers dont work except Chrome.
I Have a HijackThis Log, Here it is:
Scan saved at 19:32:47, on 15/02/2010
MSIE: Internet Explorer v8.00 SP2 (8.00.6001.18702)
C:\windows\System32\smss.exe
C:\windows\system32\csrss.exe
C:\windows\system32\winlogon.exe
C:\windows\system32\services.exe
C:\windows\system32\lsass.exe
C:\windows\system32\svchost.exe
C:\windows\System32\svchost.exe
C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
c:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
c:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
c:\Program Files\Common Files\Symantec Shared\ccProxy.exe
C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
c:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
c:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\windows\system32\spoolsv.exe
C:\WINDOWS\system32\msdtc.exe
C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
C:\windows\eHome\ehRecvr.exe
C:\windows\eHome\ehSched.exe
C:\Program Files\Google\Update\GoogleUpdate.exe
C:\windows\system32\ctfmon.exe
C:\WINDOWS\mstwain32.exe
c:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
C:\windows\system32\nvsvc32.exe
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\WINDOWS\ehome\mcrdsvc.exe
C:\WINDOWS\system32\dllhost.exe
C:\windows\System32\alg.exe
C:\WINDOWS\system32\bndmss.exe
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Application Data\Google\Chrome\Application\chrome.exe
C:\windows\explorer.exe
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\My Documents\Downloads\winlogon (1).scr
C:\windows\system32\NOTEPAD.EXE
C:\WINDOWS\system32\wbem\wmiprvse.exe
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
R3 - URLSearchHook: (no name) - {00A6FAF6-072E-44cf-8957-5838F569A31D} - (no file)
R3 - URLSearchHook: DefaultSearchHook Class - {C94E154B-1459-4A47-966B-4B843BEFC7DB} - C:\Program Files\AskSearch\bin\DefaultSearch.dll
R3 - URLSearchHook: IObitCom Toolbar - {31c7d459-9cc3-44f2-9dca-fc11795309b4} - C:\Program Files\IObitCom\tbIObi.dll
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe,C:\WINDOWS\system32\bndmss.exe,C:\DOCUME~1\MAHNOO~1.YOU\LOCALS~1\Temp\873.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\332.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\340.exe,C:\DOCUME~1\MAHNOO~1.YOU\LOCALS~1\Temp\813.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\125.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\030.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\109.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\832.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\264.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\933.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\166.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\993.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\327.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\246.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\215.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\984.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\341.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\004.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Temp\336.exe,C:\DOCUME~1\SAH786~1.YOU\LOCALS~1\Tem
O2 - BHO: MyWebSearch Search Assistant BHO - {00A6FAF1-072E-44cf-8957-5838F569A31D} - (no file)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: mwsBar BHO - {07B18EA1-A523-4961-B6BB-170DE4475CCA} - (no file)
O2 - BHO: AskBar BHO - {201f27d4-3704-41d6-89c1-aa35e39143ed} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: IObitCom Toolbar - {31c7d459-9cc3-44f2-9dca-fc11795309b4} - C:\Program Files\IObitCom\tbIObi.dll
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll
O2 - BHO: UrlHelper Class - {74322BF9-DF26-493f-B0DA-6D2FC5E6429E} - C:\Program Files\BearShare Applications\BearShare MediaBar\BearShareIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre6\bin\ssv.dll
O2 - BHO: CNavExtBho Class - {A8F38D8D-E480-4D52-B7A2-731BB6995FDD} - c:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.5.4723.1820\swg.dll
O2 - BHO: TGTSoft Explorer Toolbar Changer - {C333CF63-767F-4831-94AC-E683D962C63C} - C:\Program Files\TGTSoft\StyleXP\TGT_BHO.dll
O2 - BHO: (no name) - {d1687e45-d38e-45a2-907f-348f7a94313d} - (no file)
O3 - Toolbar: Norton AntiVirus - {C4069E3A-68F1-403E-B40E-20066696354B} - c:\Program Files\Norton Internet Security\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: BearShare MediaBar - {D3DEE18F-DB64-4BEB-9FF1-E1F0A5033E4A} - C:\Program Files\BearShare Applications\BearShare MediaBar\BearShareMediaBar.dll
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O3 - Toolbar: IObitCom Toolbar - {31c7d459-9cc3-44f2-9dca-fc11795309b4} - C:\Program Files\IObitCom\tbIObi.dll
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [Windows Network Data Management System Service] "C:\WINDOWS\system32\bndmss.exe" *
O4 - HKCU\..\Run: [mstwain32] C:\WINDOWS\mstwain32.exe
O4 - HKCU\..\Run: [psysnew] C:\RECYCLER\S-1-5-21-0243556031-888888379-781863308-1455\psysnew.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\windows\system32\ctfmon.exe
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background (User 'SYSTEM')
O4 - HKUS\S-1-5-18\..\Run: [Windows Network Data Management System Service] "C:\WINDOWS\system32\bndmss.exe" * (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O8 - Extra context menu item: &Search - [You must be registered and logged in to see this link.]
O8 - Extra context menu item: Google Sidewiki... - [You must be registered and logged in to see this link.] Files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_96D6FF0C6D236BF8.dll/cmsidewiki.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\jp2iexp.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre6\bin\jp2iexp.dll
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\windows\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\windows\Network Diagnostic\xpnetdiag.exe
O14 - IERESET.INF: START_PAGE_URL=http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_GB&c=64&bd=pavilion&pf=laptop
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll
O23 - Service: AddFiltr - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\AddFiltr.exe
O23 - Service: ASKUpgrade - Unknown owner - C:\Program Files\AskBarDis\bar\bin\ASKUpgrade.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
O23 - Service: Windows Network Data Management System Service (BNDMSS) - Unknown owner - C:\WINDOWS\system32\bndmss.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Internet Security Password Validation (ccISPwdSvc) - Symantec Corporation - c:\Program Files\Norton Internet Security\ccPwdSvc.exe
O23 - Service: Symantec Network Proxy (ccProxy) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccProxy.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - c:\Program Files\Norton Internet Security\comHost.exe
O23 - Service: CSNetManagerXp - Unknown owner - C:\WINDOWS\system32\isass.exe (file missing)
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - c:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
O23 - Service: My Web Search Service (MyWebSearchService) - MyWebSearch.com - C:\PROGRA~1\MYWEBS~1\bar\6.bin\mwssvc.exe
O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - c:\Program Files\Norton Internet Security\Norton AntiVirus\navapsvc.exe
O23 - Service: nProtect GameGuard Service (npggsvc) - Unknown owner - C:\WINDOWS\system32\GameMon.des.exe (file missing)
O23 - Service: Norton Protection Center Service (NSCService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Console\NSCSRVCE.EXE
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\windows\system32\nvsvc32.exe
O23 - Service: Symantec AVScan (SAVScan) - Symantec Corporation - c:\Program Files\Norton Internet Security\Norton AntiVirus\SAVScan.exe
O23 - Service: ServiceLayer - Nokia. - C:\Program Files\Nokia\PC Connectivity Solution\ServiceLayer.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - c:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: StyleXPService - Unknown owner - C:\Program Files\TGTSoft\StyleXP\StyleXPService.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
End of file - 15988 bytes
~Acid
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
Joined Joined : 2010-02-12
OS OS : Windows XP, Windows 7 Ultimate
Points Points : 25701
Re: Viruses? Help
Post by Belahzur on 15th February 2010, 8:08 pm
Your system is severly infected. Problem with these infections nowadays is, it causes a lot of damage. Even if we clean the malware off your system, I can't guarantee that your system will be clean afterwards, because these infections/bundles leave a lot of leftovers behind that most scanners won't even recognise and logs won't show.
Also, I can't promise you we can repair all the damage it caused... Even after cleaning the malware, you can still get errors afterwards because of the damage. Solving these is not always possible since it will be searching for a needle in a haystack to find the right cause and solution.
So, we can try to clean this up and do what we can, but keep in mind that we can't solve ALL problems this malware already caused.
Points Points : 245111
Re: Viruses? Help
Post by DoctorAcid on 15th February 2010, 9:10 pm
Took half an hour,
Two Posts. Too Big
The Log:
Database version: 3510
Internet Explorer 6.0.2900.2180
15/02/2010 21:01:56
mbam-log-2010-02-15 (21-01-55).txt
Objects scanned: 204207
Time elapsed: 43 minute(s), 49 second(s)
Memory Modules Infected: 2
Registry Keys Infected: 141
Registry Values Infected: 5
Registry Data Items Infected: 5
Folders Infected: 72
Files Infected: 322
C:\WINDOWS\cmsetac.dll (Backdoor.Turkojan) -> Delete on reboot.
C:\WINDOWS\ntdtcstp.dll (Backdoor.Turkojan) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\bndmss (Trojan.Buzus) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c8cecde3-1ae1-4c4a-ad82-6d5b00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{17de5e5e-bfe3-4e83-8e1f-8755795359ec} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1f52a5fa-a705-4415-b975-88503b291728} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a626cdbd-3d13-4f78-b819-440a28d7e8fc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8ca01f0e-987c-49c3-b852-2f1ac4a7094c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1093995a-ba37-41d2-836e-091067c4ad17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{120927bf-1700-43bc-810f-fab92549b390} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{247a115f-06c2-4fb3-967d-2d62d3cf4f0a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e53e2cb-86db-4a4a-8bd9-ffeb7a64df82} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{90449521-d834-4703-bb4e-d3aa44042ff8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{991aac62-b100-47ce-8b75-253965244f69} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{bbabdc90-f3d5-4801-863a-ee6ae529862d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{d6ff3684-ad3b-48eb-bbb4-b9e6c5a355c1} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{eb9e5c1c-b1f9-4c2b-be8a-27d6446fdaf8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0f8ecf4f-3646-4c3a-8881-8e138ffcaf70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b813095c-81c0-4e40-aa14-67520372b987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9d7be3e-141a-4c85-8cd6-32461f3df2c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{cff4ce82-3aa2-451f-9b77-7165605fb835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e47caee0-deea-464a-9326-3f2801535a4d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e1656ed-f60e-4597-b6aa-b6a58e171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8e6f1830-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2b-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{609f4a95-91fc-a66c-84e3-212bd6761e87} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{8e6f1832-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a9571378-68a1-443d-b082-284f960c6d17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d84a0d34-ebf8-98d5-108b-a9b02b3ad32d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e79dfbc0-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{72ee7f04-15bd-4845-a005-d6711144d86a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbc9-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbcb-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{3e720450-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720451-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720453-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{adb01e81-3c79-4272-a0f1-7b2be7a782dc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{7473d290-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d291-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d293-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d295-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d297-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d292-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d296-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{29d67d3c-509a-4544-903f-c8c1b8236554} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e3537fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{938aa51a-996c-4884-98ce-80dd16a5c9da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eaa-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eac-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6e74766c-4d93-4cc0-96d1-47b8e07ff9ca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{cf54be1c-9359-4395-8533-1657cf209cfe} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{de38c398-b328-4f4c-a3ad-1b5e4ed93477} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25f} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{53ced2d0-5e9a-4761-9005-648404e6f7e5} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{84da4fdf-a1cf-4195-8688-3e961f505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d9fffb27-d62a-4d64-8cec-1ff006528805} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{0d26bc71-a633-4e71-ad31-eadc3a1b6a3a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{07b18ea0-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{d518921a-4a03-425e-9873-b9a71756821e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{f42228fb-e84e-479e-b922-fbbd096e792c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Active Setup\Installed Components\{28abc5c0-4fcb-11cf-aax5-81cx1c635612} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{59c7fc09-1c83-4648-b3e6-003d2bbc7481} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68af847f-6e91-45dd-9b68-d6a12c30e5d7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9170b96c-28d4-4626-8358-27e6caeef907} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{d1a71fa0-ff48-48dd-9b6d-7a13a3e42127} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ddb1968e-ead6-40fd-8dae-ff14757f60c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f138d901-86f0-4383-99b6-9cdd406036da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\RunDll32Policy\f3ScrCtr.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Live-Player (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyWebSearch bar Uninstall (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\ControlSet001\Services\CSNetManagerXp (Worm.Silly) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CSNetManagerXp (Worm.Silly) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\windows network data management system service (Trojan.Buzus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\mstwain32 (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Media\WMSDK\Sources\f3popularscreensavers (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\taskman (Trojan.Agent) -> Delete on reboot.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform\funwebproducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell (Hijack.Shell) -> Bad: (C:\RECYCLER\S-1-5-21-0243556031-888888379-781863308-1455\psysnew.exe,explorer.exe,C:\RECYCLER\S-1-5-21-4886773444-7806156622-248174402-8210\winmap.exe) Good: (Explorer.exe) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\System\DisableCMD (Hijack.CMDPrompt) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableRegistryTools (Hijack.Regedit) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr (Hijack.TaskManager) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\NewCfg (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\bfgtoolbar (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\NetworkService\Application Data\bfgtoolbar (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\NetworkService\Application Data\bfgtoolbar\NewCfg (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\NewCfg (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\db (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\dwld (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\report (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\res1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\db (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\dwld (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\report (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\res1 (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\db (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\dwld (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\report (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\res2 (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA (Adware.Zango) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\MSNBackgrounds (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\setups (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\2.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\3.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\ShoppingReport (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Program Files\ShoppingReport\Bin (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Program Files\ShoppingReport\Bin\2.5.0 (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Program Files\SoftwareRevenue.org (Adware.ActiveSearch) -> Quarantined and deleted successfully.
C:\Program Files\video access activex object (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Registry Helper (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\RelevantKnowledge (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243336035-3055115375-381863305-1553 (Worm.AutoRun) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-1482476501-1644491937-682003330-1013 (Trojan.Agent) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243556031-888888379-781863308-1455 (Worm.AutoRun) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\SmartShopper (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\db (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\dwld (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\report (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\db (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\dwld (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\report (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\res1 (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Program Files\Smart-Shopper (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Program Files\Smart-Shopper\Bin (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Program Files\Smart-Shopper\Bin\2.5.1 (Adware.SmartShopper) -> Quarantined and deleted successfully.
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
Re: Viruses? Help
C:\Documents and Settings\Mahnoor.YOUR-0CDC4F5844\Local Settings\Application Data\awiyg_navps.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mahnoor.YOUR-0CDC4F5844\Local Settings\Application Data\awiyg_nav.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mahnoor.YOUR-0CDC4F5844\Local Settings\Application Data\awiyg.dat (Adware.Navipromo.H) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mahnoor.YOUR-0CDC4F5844\Local Settings\Application Data\awiyg.exe (Adware.Navipromo.H) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\bndmss.exe (Trojan.Buzus) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3MSG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3SCRCTR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3HTTPCT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\Internet Explorer\msimg32.dll (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243336035-3055115375-381863305-1553\vslmq.exe (Trojan.Backdoor) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243556031-888888379-781863308-1455\psysnew.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0635454624-4165627586-600502542-1412\winmap.exe (Worm.Autorun.One Cool Dude -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-4886773444-7806156622-248174402-8210\winmap.exe (Worm.Autorun.One Cool Dude -> Delete on reboot.
C:\WINDOWS\system32\f3PSSavr.scr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\174.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\203.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\215.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\348.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\379.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\427.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\504.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\547.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\640.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\669.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\673.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\781.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\859.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\B3Gg4rZz\Local Settings\Temp\866.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\055.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\688.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\844.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\236.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\239.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\254.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\271.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\745.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\751.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\777.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\511.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\900.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\641.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\661.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\330.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\337.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\347.exe (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\358.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\368.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\Local Settings\Temp\373.exe (Worm.Kolab) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\1.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\10.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\2.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\20off.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\3.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\4.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\5.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\6.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\7.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\8.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\9.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\action.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\atlantis.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\bfgtoolbar.dll (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\bfgtoolbarDLL.zip (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\bfgtoolbartb0500.cfg (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\bfg_greetings.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\card.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\COMBOSEARCH.acs (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\logo.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\mahjong.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\mygames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\mygamestoolbar.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\new.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\newgames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\puzzle.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\search.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\topten.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\webgames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\bfgtoolbar\word.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\1.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\10.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\2.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\20off.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\3.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\4.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\5.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\6.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\7.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\8.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\9.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\action.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\atlantis.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\bfgtoolbarDLL.zip (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\bfgtoolbartb0500.cfg (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\bfg_greetings.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\card.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\COMBOSEARCH.acs (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\ErrorLog.txt (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\logo.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\mahjong.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\mygames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\mygamestoolbar.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\new.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\newgames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\puzzle.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\search.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\topten.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\webgames.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\bfgtoolbar\word.bmp (Adware.OneToolBar) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\Config.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\db\Aliases.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\db\Sites.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\dwld\WhiteList.xip (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\report\aggr_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\report\send_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest\Application Data\ShoppingReport\cs\res1\WhiteList.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\Config.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\db\Aliases.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\db\Sites.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\dwld\WhiteList.xip (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\report\aggr_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\report\send_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\M786\Application Data\ShoppingReport\cs\res1\WhiteList.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\Config.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\db\Aliases.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\db\Sites.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\dwld\WhiteList.xip (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\report\aggr_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\report\send_storage.xml (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\xyaz 4 Mnk786x\Application Data\ShoppingReport\cs\res2\WhiteList.dbs (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA\ZangoSA.dat (Adware.Zango) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA\ZangoSAAbout.mht (Adware.Zango) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA\ZangoSAau.dat (Adware.Zango) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA\ZangoSAEula.mht (Adware.Zango) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\ZangoSA\ZangoSA_kyf.dat (Adware.Zango) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3BROVLY.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SHLLVW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOEMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\5.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3BKGERR.JPG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3HKSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3REGHK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3SCHMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3SPACER.WMV (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3WALLPP.DAT (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\FWPBUDDY.PNG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3FFXTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3FFXTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3HIGHIN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3IMPIPE.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3MEDINT.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3NTSTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3NTSTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\M3SRCHMN.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\MWSSVC.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\6.bin\NPMYWEBS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00039DE7 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0004AB8E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0005C80A (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00073E7E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\000A7108 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\002C5B29 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00325C07 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0039F4F9.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\003A5048.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\003A5F3C.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\003A71F9.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\003AA1B4.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\003B0725 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00432506.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00432A65.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00432BAD.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\004338AD (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0057D99F (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00669990.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00ED74F0 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0133873B (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\01339286 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0133965E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0247897F (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02478B92.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02478E61.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02479084.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\024792E5.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\024793EF.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02718C71.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02718EC2.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02718FDC.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\027190B6.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\02719182.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\04B0E727 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\04B0E949.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\files.ini (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHECKERS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHESS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\REVERSI.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History\search2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History\search3 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\DOG.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\FISH.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\KUNGFU.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\LIFEGARD.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAID.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAILBOX.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\OPERA.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\ROBOT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SEDUCT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SURFER.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\prevcfg2.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\setting2.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\settings.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\2.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\3.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\AdvisorLetters.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\help.chm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\IEHandler.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\letter1.htm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\letter2.htm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\letter3.htm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\letter4.htm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\letter5.htm (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\Registry Helper Screen Saver Setup.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\Registry Helper.url (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelper.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelperActivator.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelperBundle.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelperService.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelperSetupCB.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\RegistryHelperSetupTR.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\Starter.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\Registry Helper\uninst.exe (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rk.bin (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlai.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlls.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rloci.bin (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlph.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlservice.exe (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlvknlg.exe (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\rlxf.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\RelevantKnowledge\sporder.dll (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\home.js (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\readme.html (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\seekeen.dll (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\seekeen.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\skopt.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\Seekeen\uninstall.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files\ShoppingReport\Uninst.exe (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Program Files\ShoppingReport\Bin\2.5.0\ShoppingReport.dll (Adware.ShopperReports) -> Quarantined and deleted successfully.
C:\Program Files\SoftwareRevenue.org\Activeshopper_trim.bmp (Adware.ActiveSearch) -> Quarantined and deleted successfully.
C:\Program Files\SoftwareRevenue.org\googlepage.bmp (Adware.ActiveSearch) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Registry Helper\Registry Helper Help.lnk (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Registry Helper\Registry Helper.lnk (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\Registry Helper\Visit our Website.lnk (Rogue.RegistryHelper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\RelevantKnowledge\About RelevantKnowledge.lnk (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\RelevantKnowledge\Privacy Policy and User License Agreement.lnk (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\RelevantKnowledge\Support.lnk (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\RelevantKnowledge\Uninstall Instructions.lnk (Spyware.MarketScore) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243336035-3055115375-381863305-1553\Desktop.ini (Worm.AutoRun) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-1482476501-1644491937-682003330-1013\Desktop.ini (Trojan.Agent) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-0243556031-888888379-781863308-1455\Desktop.ini (Worm.AutoRun) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\SmartShopper\SmartShopper - Comapre product prices.lnk (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\SmartShopper\SmartShopper - Compare travel rate.lnk (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\SmartShopper\SmartShopper Help.lnk (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\Programs\SmartShopper\Uninstall SmartShopper.lnk (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\Config.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\db\Aliases.dbs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\report\aggr_storage.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Guest.SAH\Application Data\Smart-Shopper\cs\report\send_storage.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\Config.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\db\Aliases.dbs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\db\Sites.dbs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\dwld\Phishinglist.xip (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\dwld\WhiteList.xip (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\report\aggr_storage.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\report\send_storage.xml (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Sah786\Application Data\Smart-Shopper\cs\res1\WhiteList.dbs (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Program Files\Smart-Shopper\Uninst.exe (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\Program Files\Smart-Shopper\Bin\2.5.1\Smrt-Shpr.dll (Adware.SmartShopper) -> Quarantined and deleted successfully.
C:\RECYCLER\ADAPT_Installer.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\winnt_\winnt2.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winnt3.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winnt4.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winnt5.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winnt6.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winntR1.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\winnt_\winntR2.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\livemessenger.com (Backdoor.Bot) -> Quarantined and deleted successfully.
C:\WINDOWS\mstwain32.exe (Trojan.Agent) -> Delete on reboot.
C:\Documents and Settings\Sah786.YOUR-0CDC4F5844\My Documents\downloads\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
Joined Joined : 2010-02-12
OS OS : Windows XP, Windows 7 Ultimate
Points Points : 25701
Re: Viruses? Help
Post by Dr Jay on 15th February 2010, 9:21 pm
Hello, you have a Private Message waiting in your Inbox. Please take time to read it.
~ DragonMaster Jay
Posts Posts : 14310
Points Points : 302971
Re: Viruses? Help
Post by Belahzur on 15th February 2010, 11:05 pm
Your computer has multiple infections, including a backdoor. A backdoor gives intruders complete control of your computer, logs your keystrokes, steal personal information, etc.
You are strongly advised to do the following:
  • Disconnect the computer from the Internet and from any networked computers until it is cleaned.
  • Back up all your important data except programs. The programs can be reinstalled back from the original disc or from the Net.
  • Call all your banks, financial institutions, credit card companies and inform them that you may be a victim of identity theft and put a watch on your accounts. If you don't mind the hassle, change all your account numbers.
  • From a clean computer, change all your passwords (ISP login password, your email address(es) passwords, financial accounts, PayPal, eBay, Amazon, online groups and forums and any other online activities you carry out which require a username and password).
Do NOT change your passwords from this computer as the attacker will be able to get all the new passwords and transaction records.
Due to its backdoor functionality, your computer is very likely to have been compromised and there is no way that it can be trusted again. Many experts in the security community believe that once infected with this type of Trojan, the best course of action would be to do a reformat and reinstallation of the operating system (OS). However, if you do not have the resources to reinstall your OS and would like me to attempt to clean your machine, I will be happy to do so.
To help you understand more, please take some time to read the following articles:
Points Points : 245111
Re: Viruses? Help
Post by DoctorAcid on 15th February 2010, 11:08 pm
Erm So How Can You Reinstall it
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
Re: Viruses? Help
Post by Belahzur on 16th February 2010, 9:59 pm
By using your XP disk, but only if you choose to reformat. Let me know.
Re: Viruses? Help
Post by DoctorAcid on 16th February 2010, 11:13 pm
Hmm ill think about it.
Be The Best!
NotGoodSig
~[Filtered]~
DoctorAcid
Posts Posts : 92
