Antivirus Soft Help!
Post by JaredK511 on 8th February 2010, 2:03 am
Hi, I have just received this virus on my computer out of nowhere...
I read the instructions to remove it, but when I'm in safe mode with networking, I can't log on to the internet to download the removal tool. I did the uncheck of the Proxy Server box but I still can't connect. Please help! Can I just download the tool on my brothers computer and put my flash drive in to install on mine?
JaredK511
Posts Posts : 30
Joined Joined : 2010-02-08
Points Points : 25334
Re: Antivirus Soft Help!
Post by JaredK511 on 8th February 2010, 3:38 am
I've been trying for past 2 hours to get rid of this. No luck Sad tearing I downloaded the removal tool and scanned in safe mode but it didn't find anything. Then I realized it wasn't totally up to date so I downloaded the manual update and I scanned back in safe mode and it only detected one trojan. Just restarted my comp and now I see the virus is still here...
Should I do a full system scan instead of a quick scan?
What can I do??
JaredK511
Posts Posts : 30
Post by Belahzur on 8th February 2010, 8:28 pm
Points Points : 245091
Post by JaredK511 on 9th February 2010, 12:13 am
Hi, I have run the scan and will post the results. But before I do I want to say I think I may have solved the problem? I read online that I can press run -> msconfig -> and go to startup and disable the random exe. files which I did. I wasn't sure which ones could be the virus but i disabled all the ones that said ___.EXE and that didn't say windows/__ etc. Upon restarting my computer the antivirus soft symbol didn't show up and I no longer have popups. My AVG program even detected a trojan and put it in the vault. Everything seems fine now and I was able to run OTL (which I couldn't before).
The EXE files I disabled at startup were: ALCMTR.EXE, HDAShCut.EXE, RTHDCPL.EXE and sm56hlpr.exe. Are those the malicious files messing my computer up? And does my computer still have the virus? Here are the logs:
OTL logfile created on: 2/8/2010 7:01:35 PM - Run 1
OTL by OldTimer - Version 3.1.28.0 Folder = C:\Documents and Settings\Jared Kasan\Desktop
Windows XP Media Center Edition Service Pack 3 (Version = 5.1.2600) - Type = NTWorkstation
1,022.00 Mb Total Physical Memory | 464.00 Mb Available Physical Memory | 45.00% Memory free
2.00 Gb Paging File | 2.00 Gb Available in Paging File | 78.00% Paging File free
Paging file location(s): C:\pagefile.sys 1536 3072 [binary data]
Drive C: | 74.53 Gb Total Space | 15.15 Gb Free Space | 20.33% Space Free | Partition Type: NTFS
Computer Name: JARED
Current User Name: Jared Kasan
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/02/08 19:00:36 | 000,549,376 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jared Kasan\Desktop\OTL.exe
PRC - [2010/02/04 19:38:58 | 001,055,000 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgchsvx.exe
PRC - [2010/02/04 19:38:57 | 000,600,344 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgnsx.exe
PRC - [2010/02/04 19:38:57 | 000,503,576 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgrsx.exe
PRC - [2010/02/04 19:38:55 | 002,033,432 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgtray.exe
PRC - [2010/02/04 19:38:55 | 000,702,744 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgcsrvx.exe
PRC - [2010/02/04 19:38:51 | 000,285,392 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgwdsvc.exe
PRC - [2010/02/04 18:30:26 | 000,910,296 | ---- | M] (Mozilla Corporation) -- C:\Program Files\Mozilla Firefox\firefox.exe
PRC - [2009/10/11 04:17:35 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Java\jre6\bin\jqs.exe
PRC - [2009/07/09 11:22:18 | 000,144,712 | ---- | M] (Apple Inc.) -- C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
PRC - [2008/12/16 20:59:50 | 000,150,040 | ---- | M] (Logitech Inc.) -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe
PRC - [2008/12/12 11:17:38 | 000,238,888 | ---- | M] (Apple Inc.) -- C:\Program Files\Bonjour\mDNSResponder.exe
PRC - [2008/10/25 11:44:34 | 000,031,072 | ---- | M] (Microsoft Corporation) -- C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
PRC - [2008/07/07 07:15:18 | 000,611,664 | ---- | M] (Lavasoft) -- C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2006/06/05 14:17:00 | 000,393,216 | ---- | M] (ATI Technologies Inc.) -- C:\WINDOWS\system32\ati2evxx.exe
PRC - [2006/06/02 20:15:00 | 000,737,369 | ---- | M] (Synaptics, Inc.) -- C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
PRC - [2005/12/05 15:37:40 | 000,667,718 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\ZCfgSvc.exe
PRC - [2005/11/28 14:47:12 | 000,569,413 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\EOUWiz.exe
PRC - [2005/11/28 14:41:50 | 000,602,182 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\iFrmewrk.exe
PRC - [2005/11/28 14:37:52 | 000,397,381 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\Dot1XCfg.exe
PRC - [2005/11/28 14:31:32 | 000,540,745 | ---- | M] (Intel Corporation ) -- C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
PRC - [2005/11/28 14:29:00 | 000,114,753 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
PRC - [2005/11/28 14:28:14 | 000,217,164 | ---- | M] (Intel Corporation) -- C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
PRC - [2005/08/12 14:43:58 | 000,045,056 | ---- | M] (ATI Technologies Inc.) -- C:\Program Files\ATI Technologies\ATI.ACE\CLI.exe
PRC - [2004/11/02 23:24:46 | 000,032,768 | ---- | M] (Cyberlink Corp.) -- C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
MOD - [2010/02/08 19:00:36 | 000,549,376 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jared Kasan\Desktop\OTL.exe
SRV - File not found [Disabled | Stopped] -- -- (YahooAUService)
SRV - File not found [Auto | Stopped] -- -- (CLTNetCnService)
SRV - [2010/02/04 19:38:51 | 000,285,392 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgwdsvc.exe -- (avg9wd)
SRV - [2010/01/22 19:16:30 | 000,545,576 | ---- | M] (Apple Inc.) [On_Demand | Stopped] -- C:\Program Files\iPod\bin\iPodService.exe -- (iPod Service)
SRV - [2009/10/11 04:17:35 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) [Auto | Running] -- C:\Program Files\Java\jre6\bin\jqs.exe -- (JavaQuickStarterService)
SRV - [2009/07/09 11:22:18 | 000,144,712 | ---- | M] (Apple Inc.) [Auto | Running] -- C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe -- (Apple Mobile Device)
SRV - [2008/12/16 20:59:50 | 000,150,040 | ---- | M] (Logitech Inc.) [Auto | Running] -- C:\Program Files\Common Files\LogiShrd\LVMVFM\LVPrcSrv.exe -- (LVPrcSrv)
SRV - [2008/12/12 11:17:38 | 000,238,888 | ---- | M] (Apple Inc.) [Auto | Running] -- C:\Program Files\Bonjour\mDNSResponder.exe -- (Bonjour Service)
SRV - [2008/11/04 01:06:28 | 000,441,712 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Microsoft Shared\OFFICE12\ODSERV.EXE -- (odserv)
SRV - [2008/10/25 11:44:08 | 000,065,888 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Microsoft Office\Office12\GrooveAuditService.exe -- (Microsoft Office Groove Audit Service)
SRV - [2008/07/07 07:15:18 | 000,611,664 | ---- | M] (Lavasoft) [Auto | Running] -- C:\Program Files\Lavasoft\Ad-Aware\aawservice.exe -- (aawservice)
SRV - [2006/10/26 14:03:08 | 000,145,184 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE -- (ose)
SRV - [2006/06/05 14:17:00 | 000,393,216 | ---- | M] (ATI Technologies Inc.) [Auto | Running] -- C:\WINDOWS\system32\ati2evxx.exe -- (Ati HotKey Poller)
SRV - [2005/11/28 14:31:32 | 000,540,745 | ---- | M] (Intel Corporation ) [Auto | Running] -- C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe -- (S24EventMonitor) Intel(R)
SRV - [2005/11/28 14:29:00 | 000,114,753 | ---- | M] (Intel Corporation) [Auto | Running] -- C:\Program Files\Intel\Wireless\Bin\EvtEng.exe -- (EvtEng) Intel(R)
SRV - [2005/11/28 14:28:14 | 000,217,164 | ---- | M] (Intel Corporation) [Auto | Running] -- C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe -- (RegSrvc) Intel(R)
SRV - [2004/07/15 03:49:26 | 000,032,768 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\aspnet_state.exe -- (aspnet_state)
DRV - [2010/02/04 19:39:24 | 000,360,584 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2010/02/04 19:39:17 | 000,333,192 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2010/02/04 19:39:15 | 000,028,424 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2009/05/18 13:17:00 | 000,026,600 | ---- | M] (GEAR Software Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\GEARAspiWDM.sys -- (GEARAspiWDM)
DRV - [2009/04/28 15:20:06 | 000,044,944 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\PxHelp20.sys -- (PxHelp20)
DRV - [2008/12/17 01:02:08 | 000,023,832 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvuvcflt.sys -- (FilterService)
DRV - [2008/12/17 01:01:44 | 006,364,440 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvuvc.sys -- (LVUVC) Logitech QuickCam S5500(UVC)
DRV - [2008/12/17 01:01:22 | 000,041,752 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\LVUSBSta.sys -- (LVUSBSta)
DRV - [2008/12/17 01:00:14 | 000,768,024 | R--- | M] (Logitech Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\lvrs.sys -- (LVRS)
DRV - [2008/12/16 20:58:54 | 000,025,624 | ---- | M] () [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\LVPr2Mon.sys -- (LVPr2Mon)
DRV - [2008/04/13 13:45:12 | 000,060,032 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\USBAUDIO.sys -- (usbaudio) USB Audio Driver (WDM)
DRV - [2008/04/13 11:36:05 | 000,144,384 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\hdaudbus.sys -- (HDAudBus)
DRV - [2007/11/13 05:25:53 | 000,020,480 | ---- | M] (Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\secdrv.sys -- (Secdrv)
DRV - [2007/01/02 07:49:03 | 000,021,275 | ---- | M] (Meetinghouse Data Communications) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\AegisP.sys -- (AegisP) AEGIS Protocol (IEEE 802.1x)
DRV - [2006/06/05 14:17:00 | 001,414,656 | ---- | M] (ATI Technologies Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ati2mtag.sys -- (ati2mtag)
DRV - [2006/06/02 20:14:00 | 000,191,168 | ---- | M] (Synaptics, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\SynTP.sys -- (SynTP)
DRV - [2006/06/02 20:09:00 | 000,846,792 | R--- | M] (Motorola Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\smserial.sys -- (smserial)
DRV - [2006/06/02 20:08:00 | 000,078,720 | ---- | M] (Realtek Semiconductor Corporation ) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\Rtnicxp.sys -- (RTL8023xp)
DRV - [2006/06/02 20:06:00 | 004,123,136 | R--- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\RtkHDAud.Sys -- (IntcAzAudAddService) Service for Realtek HD Audio (WDM)
DRV - [2005/12/05 03:55:30 | 001,428,096 | ---- | M] (Intel® Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\w39n51.sys -- (w39n51) Intel(R)
DRV - [2005/11/28 15:09:26 | 000,013,568 | ---- | M] (Intel Corporation) [Kernel | Auto | Running] -- C:\WINDOWS\system32\drivers\s24trans.sys -- (s24trans)
DRV - [2005/01/07 19:07:16 | 000,145,920 | ---- | M] (Windows (R) Server 2003 DDK provider) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Hdaudio.sys -- (HdAudAddService)
DRV - [2004/08/10 07:00:00 | 000,017,792 | ---- | M] (Parallel Technologies, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ptilink.sys -- (Ptilink)
DRV - [2002/11/20 22:45:50 | 000,002,218 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\vncdrv.sys -- (vncdrv)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,Default_Search_URL =
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant =
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page =
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,SearchDefaultBranded = 1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Search,SearchAssistant =
IE - HKCU\..\URLSearchHook: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll File not found
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 1
========== FireFox ==========
FF - prefs.js..browser.startup.homepage: "http://www.yahoo.com/"
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:7
FF - prefs.js..extensions.enabledItems: {3f963a5b-e555-4543-90e2-c3908898db71}:9.0.0.716
FF - HKLM\software\mozilla\Firefox\extensions\\{3f963a5b-e555-4543-90e2-c3908898db71}: C:\Program Files\AVG\AVG9\Firefox [2010/02/04 19:38:51 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/02/07 20:51:22 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.6\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/02/06 18:22:50 | 000,000,000 | ---D | M]
[2008/08/27 14:56:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jared Kasan\Application Data\Mozilla\Extensions
[2010/02/05 19:33:07 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jared Kasan\Application Data\Mozilla\Firefox\Profiles\ezw11hr8.default\extensions
[2010/02/07 20:51:35 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
[2007/01/07 03:06:04 | 000,364,544 | ---- | M] (Microsoft Corporation (written by Digital Renaissance Inc.)) -- C:\Program Files\Mozilla Firefox\plugins\npdsplay.dll
O1 HOSTS File: ([2006/05/16 10:41:08 | 000,000,736 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\hosts
O2 - BHO: (&Yahoo! Toolbar Helper) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll File not found
O2 - BHO: (no name) - {348FE907-249E-4C65-A838-F34A193FE1D1} - No CLSID value found.
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll (AVG Technologies CZ, s.r.o.)
O2 - BHO: (Groove GFS Browser Helper) - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O2 - BHO: (JQSIEStartDetectorImpl Class) - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll (Sun Microsystems, Inc.)
O3 - HKLM\..\Toolbar: (Yahoo! Toolbar) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll File not found
O4 - HKLM..\Run: [ATICCC] C:\Program Files\ATI Technologies\ATI.ACE\cli.exe (ATI Technologies Inc.)
O4 - HKLM..\Run: [AVG9_TRAY] C:\Program Files\AVG\AVG9\avgtray.exe (AVG Technologies CZ, s.r.o.)
O4 - HKLM..\Run: [EOUApp] C:\Program Files\Intel\Wireless\Bin\EOUWiz.exe (Intel Corporation)
O4 - HKLM..\Run: [EPSON Stylus C86 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I2R1.EXE File not found
O4 - HKLM..\Run: [GrooveMonitor] C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe (Microsoft Corporation)
O4 - HKLM..\Run: [IntelWireless] C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe (Intel Corporation)
O4 - HKLM..\Run: [IntelZeroConfig] C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe (Intel Corporation)
O4 - HKLM..\Run: [jhyygsck] C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\nwhnkp\bxcnsftav.exe File not found
O4 - HKLM..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe (Microsoft Corporation)
O4 - HKLM..\Run: [RemoteControl] C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe (Cyberlink Corp.)
O4 - HKLM..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe (Synaptics, Inc.)
O4 - HKCU..\Run: [EPSON Stylus C86 Series] C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\E_S4I2R1.EXE File not found
O4 - HKCU..\Run: [jhyygsck] C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\nwhnkp\bxcnsftav.exe File not found
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallVisualStyle = C:\WINDOWS\Resources\Themes\Royale\Royale.msstyles (Microsoft)
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: InstallTheme = C:\WINDOWS\Resources\Themes\Royale.theme ()
O9 - Extra Button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O9 - Extra 'Tools' menuitem : S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office\Office12\ONBttnIE.dll (Microsoft Corporation)
O15 - HKLM\..Trusted Domains: 1 domain(s) and sub-domain(s) not assigned to a zone.
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 167.206.254.1 167.206.254.2
O18 - Protocol\Handler\grooveLocalGWS {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\Program Files\Microsoft Office\Office12\GrooveSystemServices.dll (Microsoft Corporation)
O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll (AVG Technologies CZ, s.r.o.)
O18 - Protocol\Handler\ms-help {314111c7-a502-11d2-bbca-00c04f8ec294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll (Microsoft Corporation)
O18 - Protocol\Filter\text/xml {807563E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.DLL (Microsoft Corporation)
O20 - Winlogon\Notify\AtiExtEvent: DllName - Ati2evxx.dll - C:\WINDOWS\System32\ati2evxx.dll (ATI Technologies Inc.)
O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
O20 - Winlogon\Notify\NavLogon: DllName - Reg Error: Value error. - Reg Error: Value error. File not found
O20 - Winlogon\Notify\WB: DllName - C:\Program Files\AlienGUIse\fastload.dll - C:\Program Files\AlienGUIse\fastload.dll (Stardock)
O24 - Desktop WallPaper: C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O28 - HKLM ShellExecuteHooks: {B5A7F190-DDA6-4420-B3BA-52453494E6CD} - C:\Program Files\Microsoft Office\Office12\GrooveShellExtensions.dll (Microsoft Corporation)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2006/07/17 16:42:45 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O34 - HKLM BootExecute: (lsdelete) - C:\WINDOWS\System32\lsdelete.exe ()
O35 - comfile [open] -- "%1" %*
O35 - exefile [open] -- "%1" %*
[2010/02/08 19:00:38 | 000,549,376 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Jared Kasan\Desktop\OTL.exe
[2010/02/07 22:14:52 | 004,363,352 | ---- | C] (Malwarebytes Corporation ) -- C:\Documents and Settings\Jared Kasan\Desktop\mbam-rules.exe
[2010/02/07 21:55:39 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Application Data\Malwarebytes
[2010/02/07 21:55:36 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/02/07 21:55:34 | 000,019,160 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/02/07 21:55:34 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2010/02/07 21:55:34 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
[2010/02/07 21:55:03 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Desktop\Malwarebytes_Anti-Malware_1.44
[2010/02/07 21:28:51 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Desktop\IceSword122en
[2010/02/07 20:21:50 | 000,000,000 | -HSD | C] -- C:\WINDOWS\CSC
[2010/02/07 18:10:33 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\nwhnkp
[2010/02/06 18:26:33 | 000,000,000 | ---D | C] -- C:\Program Files\iPod
[2010/02/06 18:26:08 | 000,000,000 | ---D | C] -- C:\Program Files\iTunes
[2010/02/06 18:23:16 | 000,000,000 | ---D | C] -- C:\Program Files\Bonjour
[2010/02/05 17:54:07 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\AliensVsPredator
[2010/02/04 21:46:35 | 001,974,616 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_42.dll
[2010/02/04 21:46:35 | 000,515,416 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_5.dll
[2010/02/04 21:46:35 | 000,238,936 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_5.dll
[2010/02/04 21:46:34 | 005,501,792 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dcsx_42.dll
[2010/02/04 21:46:33 | 000,453,456 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_42.dll
[2010/02/04 21:46:33 | 000,235,344 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx11_42.dll
[2010/02/04 21:46:32 | 001,892,184 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DX9_42.dll
[2010/02/04 21:46:32 | 001,846,632 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_41.dll
[2010/02/04 21:46:32 | 000,453,456 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_41.dll
[2010/02/04 21:46:31 | 004,178,264 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DX9_41.dll
[2010/02/04 21:46:30 | 000,517,448 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_4.dll
[2010/02/04 21:46:30 | 000,069,464 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAPOFX1_3.dll
[2010/02/04 21:46:29 | 000,235,352 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_4.dll
[2010/02/04 21:46:29 | 000,022,360 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\X3DAudio1_6.dll
[2010/02/04 21:46:25 | 000,514,384 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_3.dll
[2010/02/04 21:46:25 | 000,070,992 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAPOFX1_2.dll
[2010/02/04 21:46:24 | 000,235,856 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_3.dll
[2010/02/04 21:46:24 | 000,023,376 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\X3DAudio1_5.dll
[2010/02/04 21:46:23 | 000,509,448 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_2.dll
[2010/02/04 21:46:23 | 000,068,616 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAPOFX1_1.dll
[2010/02/04 21:46:22 | 001,493,528 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_39.dll
[2010/02/04 21:46:22 | 000,467,984 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_39.dll
[2010/02/04 21:46:22 | 000,238,088 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_2.dll
[2010/02/04 21:46:21 | 003,851,784 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DX9_39.dll
[2010/02/04 21:46:20 | 000,507,400 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_1.dll
[2010/02/04 21:46:20 | 000,238,088 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_1.dll
[2010/02/04 21:46:20 | 000,065,032 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAPOFX1_0.dll
[2010/02/04 21:46:19 | 001,491,992 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_38.dll
[2010/02/04 21:46:19 | 000,467,984 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_38.dll
[2010/02/04 21:46:19 | 000,025,608 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\X3DAudio1_4.dll
[2010/02/04 21:46:18 | 003,850,760 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DX9_38.dll
[2010/02/04 21:46:17 | 000,479,752 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\XAudio2_0.dll
[2010/02/04 21:46:17 | 000,238,088 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine3_0.dll
[2010/02/04 21:46:17 | 000,025,608 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\X3DAudio1_3.dll
[2010/02/04 21:46:16 | 001,420,824 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_37.dll
[2010/02/04 21:46:16 | 000,462,864 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_37.dll
[2010/02/04 21:46:15 | 003,786,760 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DX9_37.dll
[2010/02/04 21:46:15 | 000,267,272 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_10.dll
[2010/02/04 21:46:13 | 003,734,536 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_36.dll
[2010/02/04 21:46:13 | 001,374,232 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_36.dll
[2010/02/04 21:46:13 | 000,444,776 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_36.dll
[2010/02/04 21:46:12 | 000,267,112 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_9.dll
[2010/02/04 21:46:11 | 001,358,192 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_35.dll
[2010/02/04 21:46:11 | 000,444,776 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_35.dll
[2010/02/04 21:46:10 | 003,727,720 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_35.dll
[2010/02/04 21:46:10 | 000,266,088 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_8.dll
[2010/02/04 21:46:10 | 000,017,928 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\X3DAudio1_2.dll
[2010/02/04 21:46:08 | 001,124,720 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_34.dll
[2010/02/04 21:46:08 | 000,443,752 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_34.dll
[2010/02/04 21:46:06 | 003,497,832 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_34.dll
[2010/02/04 21:45:58 | 000,261,480 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_7.dll
[2010/02/04 21:45:52 | 001,123,696 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\D3DCompiler_33.dll
[2010/02/04 21:45:52 | 000,443,752 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx10_33.dll
[2010/02/04 21:45:48 | 003,495,784 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_33.dll
[2010/02/04 21:45:46 | 000,255,848 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_6.dll
[2010/02/04 21:45:45 | 003,426,072 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_32.dll
[2010/02/04 21:45:45 | 000,251,672 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_5.dll
[2010/02/04 21:45:44 | 000,237,848 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_4.dll
[2010/02/04 21:45:44 | 000,015,128 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\x3daudio1_1.dll
[2010/02/04 21:45:43 | 002,414,360 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_31.dll
[2010/02/04 21:45:43 | 000,236,824 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_3.dll
[2010/02/04 21:45:42 | 000,230,168 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_2.dll
[2010/02/04 21:45:42 | 000,062,744 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xinput1_2.dll
[2010/02/04 21:45:41 | 000,229,584 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_1.dll
[2010/02/04 21:45:41 | 000,062,672 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xinput1_1.dll
[2010/02/04 21:45:32 | 002,388,176 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_30.dll
[2010/02/04 21:45:31 | 002,332,368 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_29.dll
[2010/02/04 21:45:31 | 000,230,096 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xactengine2_0.dll
[2010/02/04 21:45:31 | 000,014,032 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\x3daudio1_0.dll
[2010/02/04 21:45:30 | 002,323,664 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_28.dll
[2010/02/04 21:45:30 | 000,061,136 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\xinput9_1_0.dll
[2010/02/04 21:45:29 | 002,319,568 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_27.dll
[2010/02/04 21:45:28 | 002,337,488 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_25.dll
[2010/02/04 21:45:28 | 002,297,552 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_26.dll
[2010/02/04 21:45:25 | 002,222,800 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\d3dx9_24.dll
[2010/02/04 19:39:37 | 000,000,000 | -H-D | C] -- C:\$AVG
[2010/02/04 19:39:24 | 000,360,584 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/02/04 19:39:24 | 000,012,464 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgrsstx.dll
[2010/02/04 19:39:17 | 000,333,192 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgldx86.sys
[2010/02/04 19:39:15 | 000,028,424 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/02/04 19:39:08 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\drivers\Avg
[2010/02/04 19:38:51 | 000,000,000 | ---D | C] -- C:\Program Files\AVG
[2010/02/04 19:38:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\avg9
[2010/02/04 19:36:58 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[2010/02/04 19:36:58 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[2010/02/04 19:36:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2010/02/04 19:36:58 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2010/02/04 18:58:34 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\Cooliris
[2010/01/16 22:59:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\AIM
[2010/01/16 22:59:22 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\AIM
[2010/01/16 22:59:12 | 000,000,000 | ---D | C] -- C:\Program Files\AIM
[2010/01/13 11:35:32 | 000,471,552 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\dllcache\aclayers.dll
[2009/12/23 10:19:40 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Yahoo!
[2008/02/26 11:31:01 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Apple
[5 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[21 C:\Documents and Settings\Jared Kasan\My Documents\*.tmp files -> C:\Documents and Settings\Jared Kasan\My Documents\*.tmp -> ]
[2 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[2010/02/08 18:57:47 | 000,001,158 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/02/08 18:56:36 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/02/08 18:55:34 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/02/08 18:55:33 | 1071,828,992 | -HS- | M] () -- C:\hiberfil.sys
[2010/02/08 18:54:24 | 005,242,880 | -H-- | M] () -- C:\Documents and Settings\Jared Kasan\NTUSER.DAT
[2010/02/08 18:54:24 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Jared Kasan\ntuser.ini
[2010/02/08 18:54:19 | 003,770,332 | -H-- | M] () -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\IconCache.db
[2010/02/08 18:54:11 | 000,000,675 | ---- | M] () -- C:\WINDOWS\win.ini
[2010/02/08 18:54:11 | 000,000,227 | ---- | M] () -- C:\WINDOWS\system.ini
[2010/02/08 18:54:11 | 000,000,209 | RHS- | M] () -- C:\boot.ini
[2010/02/08 18:23:17 | 055,278,728 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
[2010/02/07 22:56:36 | 000,000,552 | ---- | M] () -- C:\WINDOWS\System32\d3d8caps.dat
[2010/02/07 22:15:04 | 004,363,352 | ---- | M] (Malwarebytes Corporation ) -- C:\Documents and Settings\Jared Kasan\Desktop\mbam-rules.exe
[2010/02/07 21:55:38 | 000,000,696 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/02/07 21:40:02 | 008,761,532 | ---- | M] () -- C:\Documents and Settings\Jared Kasan\Desktop\Malwarebytes_Anti-Malware_1.44.zip
[2010/02/07 21:27:38 | 002,205,157 | ---- | M] () -- C:\Documents and Settings\Jared Kasan\Desktop\IceSword122en.zip
[2010/02/06 18:27:48 | 000,001,804 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/02/06 18:11:02 | 000,000,284 | ---- | M] () -- C:\WINDOWS\tasks\AppleSoftwareUpdate.job
[2010/02/04 19:39:24 | 000,360,584 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/02/04 19:39:24 | 000,012,464 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgrsstx.dll
[2010/02/04 19:39:24 | 000,001,507 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\AVG Free 9.0.lnk
[2010/02/04 19:39:17 | 000,333,192 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgldx86.sys
[2010/02/04 19:39:15 | 000,113,461 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\iavichjw.avm
[2010/02/04 19:39:15 | 000,028,424 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/02/04 19:39:08 | 006,061,540 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\avi7.avg
[2010/02/04 19:39:08 | 000,492,629 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\miniavi.avg
[2010/02/04 19:39:08 | 000,142,495 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\microavi.avg
[2010/01/21 19:35:25 | 000,073,851 | ---- | M] () -- C:\WINDOWS\War3Unin.dat
[2010/01/16 22:59:31 | 000,001,086 | -H-- | M] () -- C:\IPH.PH
[2010/01/16 22:59:20 | 000,001,574 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\AIM.lnk
[2010/01/16 14:33:48 | 000,017,529 | ---- | M] () -- C:\Documents and Settings\Jared Kasan\My Documents\JKasanResume2.docx
[2010/01/14 11:36:50 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/01/13 20:13:47 | 000,017,534 | ---- | M] () -- C:\Documents and Settings\Jared Kasan\My Documents\JKasan-Resume.docx
[2010/02/08 18:17:33 | 1071,828,992 | -HS- | C] () -- C:\hiberfil.sys
[2010/02/07 22:56:36 | 000,000,552 | ---- | C] () -- C:\WINDOWS\System32\d3d8caps.dat
[2010/02/07 21:55:38 | 000,000,696 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\Malwarebytes' Anti-Malware.lnk
[2010/02/07 21:38:49 | 008,761,532 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\Desktop\Malwarebytes_Anti-Malware_1.44.zip
[2010/02/07 21:27:01 | 002,205,157 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\Desktop\IceSword122en.zip
[2010/02/06 18:27:48 | 000,001,804 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\iTunes.lnk
[2010/02/04 19:39:24 | 000,001,507 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\AVG Free 9.0.lnk
[2010/02/04 19:39:15 | 000,113,461 | ---- | C] () -- C:\WINDOWS\System32\drivers\Avg\iavichjw.avm
[2010/02/04 19:39:08 | 055,278,728 | ---- | C] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
[2010/02/04 19:39:08 | 006,061,540 | ---- | C] () -- C:\WINDOWS\System32\drivers\Avg\avi7.avg
[2010/02/04 19:39:08 | 000,492,629 | ---- | C] () -- C:\WINDOWS\System32\drivers\Avg\miniavi.avg
[2010/02/04 19:39:08 | 000,142,495 | ---- | C] () -- C:\WINDOWS\System32\drivers\Avg\microavi.avg
[2010/01/16 22:59:20 | 000,001,574 | ---- | C] () -- C:\Documents and Settings\All Users\Desktop\AIM.lnk
[2010/01/13 20:11:19 | 000,017,534 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\My Documents\JKasan-Resume.docx
[2010/01/13 16:19:27 | 000,017,529 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\My Documents\JKasanResume2.docx
[2009/08/31 22:16:55 | 000,081,110 | R--- | C] () -- C:\WINDOWS\System32\lvcoinst.ini
[2008/12/16 20:58:54 | 000,025,624 | ---- | C] () -- C:\WINDOWS\System32\drivers\LVPr2Mon.sys
[2008/12/16 20:50:56 | 000,013,584 | ---- | C] () -- C:\WINDOWS\System32\drivers\iKeyLgFT.dll
[2007/04/20 12:20:52 | 000,000,000 | ---- | C] () -- C:\WINDOWS\vpc32.INI
[2007/03/01 23:04:39 | 000,069,632 | ---- | C] () -- C:\WINDOWS\System32\xmltok.dll
[2007/03/01 23:04:39 | 000,036,864 | ---- | C] () -- C:\WINDOWS\System32\xmlparse.dll
[2007/01/15 18:26:47 | 000,000,376 | ---- | C] () -- C:\WINDOWS\ODBC.INI
[2007/01/05 22:40:43 | 000,001,359 | ---- | C] () -- C:\Documents and Settings\All Users\Application Data\QTSBandwidthCache
[2007/01/05 16:16:24 | 000,122,880 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
[2007/01/05 16:16:24 | 000,000,134 | ---- | C] () -- C:\Documents and Settings\Jared Kasan\Local Settings\Application Data\fusioncache.dat
[2007/01/02 08:14:32 | 000,000,061 | ---- | C] () -- C:\WINDOWS\smscfg.ini
[2007/01/02 07:51:58 | 000,000,056 | ---- | C] () -- C:\WINDOWS\wb.ini
[2006/07/17 16:55:35 | 000,002,340 | ---- | C] () -- C:\WINDOWS\System32\oeminfo.ini
[2006/07/17 16:53:30 | 000,069,632 | R--- | C] () -- C:\WINDOWS\sm56spn.dll
[2006/07/17 16:53:30 | 000,069,632 | R--- | C] () -- C:\WINDOWS\sm56itl.dll
[2006/07/17 16:53:30 | 000,061,440 | R--- | C] () -- C:\WINDOWS\sm56ger.dll
[2006/07/17 16:53:30 | 000,061,440 | R--- | C] () -- C:\WINDOWS\sm56fra.dll
[2006/07/17 16:53:30 | 000,053,248 | R--- | C] () -- C:\WINDOWS\sm56jpn.dll
[2006/07/17 16:53:29 | 000,069,632 | R--- | C] () -- C:\WINDOWS\sm56eng.dll
[2006/07/17 16:53:29 | 000,069,632 | R--- | C] () -- C:\WINDOWS\sm56brz.dll
[2006/07/17 16:53:29 | 000,049,152 | R--- | C] () -- C:\WINDOWS\sm56cht.dll
[2006/07/17 16:53:29 | 000,049,152 | R--- | C] () -- C:\WINDOWS\sm56chs.dll
[2006/07/17 16:51:59 | 000,135,168 | R--- | C] () -- C:\WINDOWS\System32\RtlCPAPI.dll
[2005/08/05 16:01:54 | 000,235,008 | ---- | C] () -- C:\WINDOWS\System32\psisdecd.dll
@Alternate Data Stream - 3552 bytes -> C:\WINDOWS\alienware_logo_slvr.jpg:Q30lsldxJoudresxAaaqpcawXc
@Alternate Data Stream - 3552 bytes -> C:\WINDOWS\alienware logo_slvr.jpg:Q30lsldxJoudresxAaaqpcawXc
JaredK511
Posts Posts : 30
Post by JaredK511 on 9th February 2010, 12:14 am
OTL Extras logfile created on: 2/8/2010 7:01:35 PM - Run 1
File Age = 30 Days
Output = Standard
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [open] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" -nohome (Microsoft Corporation)
htmlfile [opennew] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" %1 (Microsoft Corporation)
http [open] -- "C:\Program Files\Mozilla Firefox\firefox.exe" -requestPending -osint -url "%1" (Mozilla Corporation)
https [open] -- "C:\Program Files\Mozilla Firefox\firefox.exe" -requestPending -osint -url "%1" (Mozilla Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [OneNote.Open] -- C:\PROGRA~1\MICROS~2\Office12\ONENOTE.EXE "%L" (Microsoft Corporation)
Directory [Winamp.Bookmark] -- "C:\Program Files\Winamp\winamp.exe" /BOOKMARK "%1" (Nullsoft)
Directory [Winamp.Enqueue] -- "C:\Program Files\Winamp\winamp.exe" /ADD "%1" (Nullsoft)
Directory [Winamp.Play] -- "C:\Program Files\Winamp\winamp.exe" "%1" (Nullsoft)
Applications\iexplore.exe [open] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" %1 (Microsoft Corporation)
CLSID\{871C5380-42A0-1069-A2EA-08002B30309D} [OpenHomePage] -- "C:\Program Files\Internet Explorer\iexplore.exe" (Microsoft Corporation)
"FirstRunDisabled" = 1
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 1
"FirewallOverride" = 0
"DisableMonitoring" = 1
"EnableFirewall" = 1
"DisableNotifications" = 1
"DoNotAllowExceptions" = 0
"1900:UDP" = 1900:UDP:LocalSubNet:Disabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Disabled:@xpsp2res.dll,-22008
"C:\Program Files\Bizarro\DCPlusPlus.exe" = C:\Program Files\Bizarro\DCPlusPlus.exe:*:Enabled:DC++ -- ()
"C:\Program Files\Warcraft III\Warcraft III.exe" = C:\Program Files\Warcraft III\Warcraft III.exe:*:Enabled:Warcraft III -- (Blizzard Entertainment)
"C:\Program Files\Warcraft III\Frozen Throne.exe" = C:\Program Files\Warcraft III\Frozen Throne.exe:*:Enabled:Warcraft III - The Frozen Throne -- (Blizzard Entertainment)
"C:\Program Files\Common Files\AOL\Loader\aolload.exe" = C:\Program Files\Common Files\AOL\Loader\aolload.exe:*:Enabled:AOL Loader -- (AOL LLC)
"C:\Program Files\AIM6\aim6.exe" = C:\Program Files\AIM6\aim6.exe:*:Enabled:AIM -- File not found
"C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" = C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE:*:Enabled:Microsoft Office Outlook -- (Microsoft Corporation)
"C:\Program Files\Microsoft Office\Office12\GROOVE.EXE" = C:\Program Files\Microsoft Office\Office12\GROOVE.EXE:*:Enabled:Microsoft Office Groove -- (Microsoft Corporation)
"C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE" = C:\Program Files\Microsoft Office\Office12\ONENOTE.EXE:*:Enabled:Microsoft Office OneNote -- (Microsoft Corporation)
"C:\Program Files\AIM\aim.exe" = C:\Program Files\AIM\aim.exe:*:Enabled:AIM -- (AOL LLC)
"C:\Program Files\AVG\AVG9\avgupd.exe" = C:\Program Files\AVG\AVG9\avgupd.exe:*:Enabled:avgupd.exe -- (AVG Technologies CZ, s.r.o.)
"C:\Program Files\AVG\AVG9\avgnsx.exe" = C:\Program Files\AVG\AVG9\avgnsx.exe:*:Enabled:avgnsx.exe -- (AVG Technologies CZ, s.r.o.)
"C:\Program Files\Bonjour\mDNSResponder.exe" = C:\Program Files\Bonjour\mDNSResponder.exe:*:Enabled:Bonjour -- (Apple Inc.)
"{07287123-B8AC-41CE-8346-3D777245C35B}" = Bonjour
"{0E2B0B41-7E08-4F9F-B21F-41C4133F43B7}" = mLogView
"{1451DE6B-ABE1-4F62-BE9A-B363A17588A2}" = QuickTime
"{23FB368F-1399-4EAC-817C-4B83ECBE3D83}" = mProSafe
"{26A24AE4-039D-4CA4-87B4-2F83216010FF}" = Java(TM) 6 Update 17
"{3248F0A8-6813-11D6-A77B-00B0D0150100}" = J2SE Runtime Environment 5.0 Update 10
"{3248F0A8-6813-11D6-A77B-00B0D0150110}" = J2SE Runtime Environment 5.0 Update 11
"{3248F0A8-6813-11D6-A77B-00B0D0160010}" = Java(TM) SE Runtime Environment 6 Update 1
"{3248F0A8-6813-11D6-A77B-00B0D0160020}" = Java(TM) 6 Update 2
"{3248F0A8-6813-11D6-A77B-00B0D0160070}" = Java(TM) 6 Update 7
"{3E9D596A-61D4-4239-BD19-2DB984D2A16F}" = mIWA
"{3FA365DF-2D68-45ED-8F83-8C8A33E65143}" = Apple Application Support
"{5BB653E2-5438-4FAB-841F-662765251FF3}" = ATI Catalyst Control Center
"{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD
"{8B928BA1-EDEC-4227-A2DA-DD83026C36F5}" = mPfMgr
"{8C6BB412-D3A8-4AAE-A01B-35B681789D68}" = mHelp
"{90120000-0015-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0016-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0018-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0019-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001A-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001B-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-001F-0409-0000-0000000FF1CE}_ENTERPRISE_{ABDDE972-355B-4AF1-89A8-DA50B7B5C045}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-040C-0000-0000000FF1CE}_ENTERPRISE_{F580DDD5-8D37-4998-968E-EBB76BB86787}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-001F-0C0A-0000-0000000FF1CE}_ENTERPRISE_{187308AB-5FA7-4F14-9AB9-D290383A10D9}" = Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}" = Microsoft Office Enterprise 2007
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{0B36C6D6-F5D8-4EAF-BF94-4376A230AD5B}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{3D019598-7B59-447A-80AE-815B703B84FF}" = Security Update for Microsoft Office system 2007 (972581)
"{90120000-0030-0000-0000-0000000FF1CE}_ENTERPRISE_{4B94701D-F335-49DE-89DB-7BDDD7282C02}" =
"{90120000-0044-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-006E-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00A1-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-00BA-0409-0000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2007
"{90120000-00BA-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0114-0409-0000-0000000FF1CE}" = Microsoft Office Groove Setup Metadata MUI (English) 2007
"{90120000-0114-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0115-0409-0000-0000000FF1CE}_ENTERPRISE_{DE5A002D-8122-4278-A7EE-3121E7EA254E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90120000-0117-0409-0000-0000000FF1CE}_ENTERPRISE_{2FC4457D-409E-466F-861F-FB0CB796B53E}" = Microsoft Office 2007 Service Pack 2 (SP2)
"{90437E5F-0A9E-4B63-AD8B-D232897D18BF}" = ATI Parental Control & Encoder
"{90B0D222-8C21-4B35-9262-53B042F18AF9}" = mPfWiz
"{937B232D-9776-471E-92BD-D424E514EF14}" = Logitech QuickCam
"{94658027-9F16-4509-BBD7-A59FE57C3023}" = mZConfig
"{94FB906A-CF42-4128-A509-D353026A607E}" = REALTEK Gigabit and Fast Ethernet NIC Driver
"{9CC89556-3578-48DD-8408-04E66EBEF401}" = mXML
"{A0F925BF-5C55-44C2-A4E7-5A4C59791C29}" = mDriver
"{AADEA55D-C834-4BCB-98A3-4B8D1C18F4EE}" = Apple Mobile Device Support
"{AC76BA86-7AD7-1033-7B44-A81300000003}" = Adobe Reader 8.1.6
"{B502B428-3386-40A9-98DB-079AAB72E64F}" = mEoU
"{C4124E95-5061-4776-8D5D-E3D931C778E1}" = Microsoft VC9 runtime libraries
"{DED53B0B-B67C-4244-AE6A-D6FD3C28D1EF}" = Ad-Aware
"{E81667C6-2856-46D6-ABEA-6A2F42166779}" = mCore
"{F0BFC7EF-9CF8-44EE-91B0-158884CD87C5}" = mMHouse
"{F439D7AF-03F3-4F8E-AEC4-571BFE977C61}" = iTunes
"{F6090A17-0967-4A8A-B3C3-422A1B514D49}" = mDrWiFi
"{FCA651F3-5BDA-4DDA-9E4A-5D87D6914CC4}" = mWlsSafe
"Adobe Flash Player ActiveX" = Adobe Flash Player ActiveX
"Adobe Shockwave Player" = Adobe Shockwave Player 11.5
"AIM_7" = AIM 7
"AlienGUIse Theme Manager" = AlienGUIse Theme Manager
"All ATI Software" = ATI - Software Uninstall Utility
"ATI Display Driver" = ATI Display Driver
"AVG9Uninstall" = AVG Free 9.0
"ENTERPRISE" = Microsoft Office Enterprise 2007
"IrfanView" = IrfanView (remove only)
"lvdrivers_11.90" = Logitech QuickCam Driver Package
"Mozilla Firefox (3.6)" = Mozilla Firefox (3.6)
"ProInst" = Intel(R) PROSet/Wireless Software
"SMSERIAL" = Motorola SM56 Data Fax Modem
"Starcraft" = Starcraft
"Steam" = Steam
"SynTPDeinstKey" = Synaptics Pointing Device Driver
"Theme Manager" = Theme Manager
"VLC media player" = VideoLAN VLC media player 0.8.6a
"Winamp" = Winamp
"Yahoo! Software Update" = Yahoo! Software Update
"Move Media Player" = Move Media Player
"Octoshape add-in for Adobe Flash Player" = Octoshape add-in for Adobe Flash Player
"Warcraft III" = Warcraft III: All Products
[ Application Events ]
Error - 2/7/2010 8:43:49 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Description = Unable to open the Server service. Server performance data will not
be returned. Error code returned is in data DWORD 0.
Error - 2/7/2010 8:55:42 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/7/2010 9:31:38 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/7/2010 9:55:17 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/7/2010 10:50:53 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/7/2010 10:52:14 PM | Computer Name = JARED | Source = EventSystem | ID = 4614
Description = The COM+ Event System detected an inconsistency in its internal state.
The assertion "GetLastError() == 122L" failed at line 162 of d:\comxp_sp3\com\com1x\src\events\shared\sectools.cpp.
Please contact Microsoft Product Support Services to report this erro
Error - 2/7/2010 11:10:31 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/7/2010 11:30:29 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/8/2010 7:17:57 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
Error - 2/8/2010 7:55:55 PM | Computer Name = JARED | Source = PerfNet | ID = 2004
[ System Events ]
Error - 2/7/2010 10:55:01 PM | Computer Name = JARED | Source = Service Control Manager | ID = 7026
AvgLdx86 AvgMfx86 Fips intelppm IsDrv122
Error - 2/7/2010 11:09:10 PM | Computer Name = JARED | Source = DCOM | ID = 10005
Description = DCOM got error "%1084" attempting to start the service EventSystem
with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
Error - 2/7/2010 11:12:59 PM | Computer Name = JARED | Source = DCOM | ID = 10010
Description = The server {0228576F-6E6C-4E1A-B175-0E46A316AFE2} did not register
with DCOM within the required timeout.
Error - 2/7/2010 11:20:05 PM | Computer Name = JARED | Source = DCOM | ID = 10005
Error - 2/7/2010 11:20:29 PM | Computer Name = JARED | Source = Service Control Manager | ID = 7026
Error - 2/7/2010 11:29:08 PM | Computer Name = JARED | Source = DCOM | ID = 10005
Error - 2/7/2010 11:32:55 PM | Computer Name = JARED | Source = DCOM | ID = 10010
Error - 2/7/2010 11:45:25 PM | Computer Name = JARED | Source = DCOM | ID = 10005
Error - 2/7/2010 11:45:52 PM | Computer Name = JARED | Source = Service Control Manager | ID = 7026
Error - 2/8/2010 12:18:07 AM | Computer Name = JARED | Source = DCOM | ID = 10005
JaredK511
Posts Posts : 30
Post by JaredK511 on 9th February 2010, 12:45 am
I also just did a scan with Malwarebytes (in normal mode) and it detected/deleted 5 things.
This is the log before I deleted the stuff.
Database version: 3710
2/8/2010 7:31:55 PM
mbam-log-2010-02-08 (19-31-50).txt
Objects scanned: 131409
Time elapsed: 10 minute(s), 25 second(s)
Registry Keys Infected: 1
Registry Values Infected: 2
Files Infected: 2
HKEY_CURRENT_USER\Software\avsoft (Trojan.FakeAV) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\jhyygsck (Trojan.FakeAlert.Gen) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\jhyygsck (Trojan.FakeAlert.Gen) -> No action taken.
C:\Documents and Settings\Jared Kasan\Local Settings\Temp\igfB.exe (Trojan.FakeAlert) -> No action taken.
C:\Documents and Settings\Jared Kasan\Local Settings\Temporary Internet Files\Content.IE5\4LYB4TAV\eHf78c07aaV0100f036002R2732728f102Tbce34f93Q000002fd901801F002a000aJ11000601l0409Kca918b7430dP000601080[1] (Trojan.FakeAlert) -> No action taken.
What do you gather from all this? Thanks in advance btw Smile
JaredK511
Posts Posts : 30
Joined Joined : 2010-02-08
Points Points : 25334
Re: Antivirus Soft Help!
Post by Belahzur on 9th February 2010, 1:31 am
    Java(TM) 6 Update 2
    Java(TM) 6 Update 7
Post by JaredK511 on 9th February 2010, 1:52 am
Hi, I have just removed those programs. Are they why I got that virus? Am I in the clear now??
JaredK511
Posts Posts : 30
tied this and
Post by cr41584 on 9th February 2010, 2:04 am
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic.
cr41584
OS OS : windows xp
Points Points : 24965
Post by JaredK511 on 9th February 2010, 2:25 am
Yeah, you have to stop it from doing that. The way I did was when I started Windows I quickly went to start -> run -> msconfig -> startup and then I unchecked anything that looked suspicious. Read my posts above to see. After I did that nothing popped up and reboot and I was able to access my programs.
[You must be registered and logged in to see this link.] wrote:my computer won't even let me open up the add/remove programs now, this antivirus thing blocks it
    Java(TM) 6 Update 2
    Java(TM) 6 Update 7
[/quote]
JaredK511
Posts Posts : 30
Post by Belahzur on 9th February 2010, 7:09 pm
Points Points : 245091
Post by JaredK511 on 10th February 2010, 6:32 pm
Machine has been running great past two days Smile Seems like it's back to its good ol self! Thanks so much for your help!
JaredK511
Posts Posts : 30
