System security help
Post by qwerty8520 on Tue Feb 02, 2010 2:06 am
recently got the system security virus. did a malware bytes scan and removed the infected files. what else should i do? here is the log:
Database version: 3675
Internet Explorer 7.0.5730.13
2/1/2010 7:47:37 PM
mbam-log-2010-02-01 (19-47-37).txt
Objects scanned: 109783
Time elapsed: 12 minute(s), 36 second(s)
Registry Keys Infected: 5
Folders Infected: 3
Files Infected: 12
HKEY_CLASSES_ROOT\CLSID\{c73fd00d-a099-405c-92b4-8997710d187d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c73fd00d-a099-405c-92b4-8997710d187d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{c73fd00d-a099-405c-92b4-8997710d187d} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\PersonalSec (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servises (Malware.Trace) -> Quarantined and deleted successfully.
C:\Program Files\PersonalSec (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Program Files\Common Files\PersonalSecUninstall (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\win32extension.dll (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Documents and Settings\Randi Henk\Local Settings\Temporary Internet Files\Content.IE5\5CUHNTDU\Setup_40s1[1].exe (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Program Files\PersonalSec\psecurity.exe (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Computer Scan.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Help.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Personal Security.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Registration.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Security Center.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Settings.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Start Menu\PersonalSec\Update.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Program Files\Common Files\PersonalSecUninstall\Uninstall.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
C:\Documents and Settings\Randi Henk\Application Data\Microsoft\Internet Explorer\Quick Launch\PersonalSec.lnk (Rogue.PersonalSecurity) -> Quarantined and deleted successfully.
qwerty8520
OS : XP
Re: System security help
Post by Dr Jay on Tue Feb 02, 2010 3:18 am
Please download [You must be registered and logged in to see this link.], and save to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.zip, and extract the file to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.cmd to start.
  • It will finish quickly and launch a log.
  • Post the contents of it in your next reply.
OS : Windows 10 Home & Pro
Post by qwerty8520 on Thu Feb 04, 2010 2:31 am
Cheetah-Anti-Rogue v1.2.15
by DragonMaster Jay
Date: 02/03/2010 - Time: 20:31:06 - Arch.: x86
-- Malware tools check --
-- Known infection --
C:\Documents and Settings\Randi Henk\Application Data\Microsoft\Internet Explorer\Desktop.htt (Trj.FakeAlert)
Extra message: Detection only.
EOF
qwerty8520
OS : XP
Post by Dr Jay on Thu Feb 04, 2010 3:46 am
  • Click NEXT
  • Enter a name e.g. Clean
  • Click CREATE
  • Click OK
  • Double click OTC.exe.
  • Click the CleanUp! button.
  • Click the Start
