problem ... please help
Post by Nightstocker on 1st February 2010, 8:23 pm
PC turns on but nothing happens
Nightstocker
Posts Posts : 8
Joined Joined : 2009-12-30
Points Points : 25412
Re: problem ... please help
Post by mike90t09 on 1st February 2010, 9:16 pm
Do all the fans spin? Is your monitor plugged in? Is everything plugged in? Please give more detail. Did you build this PC yourself? Just take us through step by step so we can identify the problem.
mike90t09
Posts Posts : 21
Joined Joined : 2010-01-28
OS OS : Windows 7 Home-Premium
Points Points : 25417
Post by amir20001 on 18th February 2010, 2:44 am
i'm gonna assume u mean ur computer turns on but ur monitor dose not get a signal. check the cable to see if both sides are connected properly , try a different monitor. try reseating ur ram.
that is the best guess i can make form the info provided
amir20001
Posts Posts : 83
Joined Joined : 2008-08-08
Points Points : 30831
