ie8 slow, locks up, redirects and audio advertisments
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
- BelahzurSite Admin
OS : 7 Home Premium x64
Rubies : 218217
Please download the OTMoveIt by OldTimer.
Please post the OTMoveIt log.
- Save it to your desktop.
- Please double-click OTM.exe to run it.
- Copy the bolded text below to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose Copy):
:files
c:\windows\Fsivogaz.dat
c:\windows\Stehozumahohewaz.bin - Return to OTMoveIt, right click in the "Paste instructions for items to be Moved" window (under the light blue bar) and choose Paste.
- Click the red Moveit! button.
- Copy everything in the Results window (under the green bar) to the clipboard by highlighting ALL of them and pressing CTRL + C (or, after highlighting, right-click and choose copy), and paste it in your next reply.
- Close OTMoveIt
Site Admin / Security Administrator
[Prework] - Please PM me if I fail to respond within 24hrs.
- Ragous111Novice
OS : windows vista
Rubies : 3473
========== FILES ==========
c:\windows\Fsivogaz.dat moved successfully.
c:\windows\Stehozumahohewaz.bin moved successfully.
OTM by OldTimer - Version 3.1.7.1 log created on 02022010_124550
Rubies : 218217
ComboFix /uninstall
ComboFix /uninstall
- Ragous111Novice
OS : windows vista
Rubies : 3473
The computer seems to be running much better i have not been redirected or had any other issues to speak of. What is the best way to keep this form happening again.
Rubies : 218217
Below I have included a number of recommendations for how to protect your computer in order to prevent future malware infections. Please take these recommendations seriously; these few simple steps can stave off the vast majority of spyware problems. As happy as we are to help you, for your sake we would rather not have repeat customers.
1) Please navigate to http://windowsupdate.microsoft.com and download all the "critical updates" for Windows. This can patch many of the security holes through which attackers can gain access to your computer.
Ad-Aware SE
A tutorial on using Ad-Aware to remove spyware from your computer may be found here.
Spybot-Search & Destroy
A tutorial on using Spybot to remove spyware from your computer may be found here. Please also remember to enable Spybot's "Immunize" and "TeaTimer" features.
SpywareBlaster
A tutorial on using SpywareBlaster to prevent spyware from ever installing on your computer may be found here.
SpywareGuard
A tutorial on using SpywareGuard for realtime protection against spyware and hijackers may be found here.
http://www.mozilla.org/products/firefox/
https://addons.mozilla.org/en-US/firefox/addon/722
https://addons.mozilla.org/en-US/firefox/addon/1865
https://addons.mozilla.org/en-US/firefox/addon/433
Update Checker
5) Finally, consider maintaining a firewall. Some good free firewalls are Kerio, or
Outpost
A tutorial on understanding and using firewalls may be found here.
Please also read Tony Klein's excellent article: How I got Infected in the First Place
The link can be found here.
Hopefully this should take care of your problems! Good luck.
Ad-Aware SE
SpywareBlaster
SpywareGuard
Update Checker
Outpost
- Ragous111Novice
OS : windows vista
Rubies : 3473
Thank you very much for you're help. It is greatly appricated. I would have to say the problem is solved.
Similar topics
Page 3 of 4
