Outlook allows incoming mail but not out going? Please help!
Post by wanttobeageek on Thu Jan 28, 2010 4:19 am
Task mail.comcast.net-sending & receiving reported error (0x800CCC78):
unable to send the message. Please verify the e-mail address in your account
properites. The server responded: ????????
The nest time I sent the message the same message but the last line said the server responded: 550 5.1.0 Authentication required' Not sure but maybe this has something connected to the fire wall?
wanttobeageek
Joined Joined : 2010-01-21
Points Points : 25114
Re: Outlook allows incoming mail but not out going? Please help!
Post by sweetride98 on Sun Jan 31, 2010 8:34 pm
are you using this at you home? is this a new configuration?
go here and make sure your configuration is correct
http://customer.comcast.com/Pages/FAQViewer.aspx?seoid=Setting-up-Outlook-2003&AspxAutoDetectCookieSupport=1
sweetride98
Posts Posts : 53
Joined Joined : 2010-01-30
OS OS : Windows 7 Ultimate
Points Points : 25554
XP last?
Post by bigfatorangecat on Thu Feb 11, 2010 10:45 pm
I had done all this before(more than once). I have set this up before, I then got internet security 2010 virus. I had to start all over by wiping H.D. I'm wondering if the XP last version needs to be verified authentic for Outlook to work properly?
bigfatorangecat
OS OS : XPlast
Points Points : 25120
Post by sweetride98 on Fri Feb 12, 2010 1:36 pm
if your XP is not authentic microsoft wont allow you to download security updates, It shouldnt have anything to do with Outlook sending or recieving e-mail. most likley its a configuration problem, make sure your port settings are correct and you have the ssl check boxes right if they need to be checked, if all else fails call comcast tech support. there is usually a wait but they will work with you untill it is working.
sweetride98
Posts Posts : 53
Post by makxp77 on Tue Feb 23, 2010 8:54 am
@bigfatorangecat wrote:I had done all this before(more than once). I have set this up before, I then got internet security 2010 virus. I had to start all over by wiping H.D. I'm wondering if the XP last version needs to be verified authentic for Outlook to work properly?
You should always use a legit copy of Windows due to the security issues and needed patches\updates you can get through Ms Update, though authentication for Windows and Office 2003 have nothing to do with each other!
MiKeY
makxp77
Posts Posts : 216
Joined Joined : 2009-08-06
OS OS : Windows 7 X64
Points Points : 29064
