Wireless network help pls
Post by NickNubcake on Wed Jan 27, 2010 7:11 pm
I recentally brought a new pc, i installed the operating system fine, and the new networking card aswell. i can connect to my router, but it says limited or no connectivity. Might this be a network card problem?
NickNubcake
Posts Posts : 12
Joined Joined : 2009-11-26
Points Points : 25777
Re: Wireless network help pls
Post by Doctor Inferno on Thu Jan 28, 2010 3:49 am
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
