Malware Defense problems
Post by basher on Tue Jan 26, 2010 7:22 pm
hey so malware defense wont let me go onto certain websites that let me download stuff like TFC.exe. also, i cant delete that one file in the malware defense folder, mdext.dll
can someone help me? my antivirus programs wont start up either.
and i cant go on websites that involve getting rid of this virus.
basher
Posts Posts : 4
Joined Joined : 2010-01-26
Points Points : 25108
Re: Malware Defense problems
Post by Dr Jay on Tue Jan 26, 2010 8:13 pm
Please visit this webpage for instructions for downloading and running ComboFix:
Post the log from ComboFix when you've accomplished that.
Posts Posts : 13717
Points Points : 302127
Post by basher on Tue Jan 26, 2010 8:17 pm
malware defense will not allow me to visit that site.
basher
Posts Posts : 4
Post by Dr Jay on Tue Jan 26, 2010 8:37 pm
Alternate link: [You must be registered and logged in to see this link.].
Posts Posts : 13717
Post by basher on Tue Jan 26, 2010 8:48 pm
i already have Malwarebytes Anti-Malware but it wont start up.
basher
Posts Posts : 4
Post by Dr Jay on Tue Jan 26, 2010 8:50 pm
  1. As this infection deletes a core executable of Malwarebytes' we will need to download a new copy of it and put it in the C:\program files\Malwarebytes' Anti-Malware\ folder. To download the file please click on the following link: [You must be registered and logged in to see this link.]
    When your browser prompts you where to save it to, please save it to the C:\program files\Malwarebytes' Anti-Malware\ folder. When downloading the file, it will have a random filename. Please leave the filename the way it is as it is important that it is not changed. You may want to write down the name of the file as you will need to know the name in the next step.
  2. Once the file has been downloaded, open the C:\program files\Malwarebytes' Anti-Malware\ folder and double-click on the file you downloaded in step 8. MBAM will now start and you will be at the main program screen.
Posts Posts : 13717
Post by basher on Tue Jan 26, 2010 8:53 pm
i got an error opening the file up.
Error Code: 730 (0, 0)
basher
Posts Posts : 4
Post by Dr Jay on Wed Jan 27, 2010 5:00 am
Please visit this webpage for instructions for downloading and running SUPERAntiSpyware to scan and remove malware from your computer:
Post the log from SUPERAntiSpyware when you've accomplished that.
Posts Posts : 13717
