HP DV6000 with vista startup problems...help please!
Post by chadlytle on 20th January 2010, 5:24 am
Alrighty I have a HP DV6000 laptop. It runs a Vista OS. Here is the problem...
I open the laptop and press the power button. The computer does its things and starts making the usual sounds but 1 out of 6 times the screen just stays blank. When the screen does work and everything goes right it will go to the main windows display with start menu and then 5 seconds later it goes to a blank screen and seems like the computer is trying to restart over and over again but the screen is still blank for all the attempted restarts. I can run the computer is safe mode and it works just fine but only certain programs are available of course.
I have tried the "trick" where you take out the battery and unplug everything, hold the power button for 30-60 seconds then retry and nothing.
I have tried pressing "fn" and "f6" buttons at startup and still nothing.
I hope its not anything serious to where I would have to take it into a shop for repair but if anyone has any suggestions or know what exactly the problem is, I would appreciate the pointers.
Thanks and hope to have this problem resolved soon! Thank You!
chadlytle
Posts Posts : 5
Joined Joined : 2010-01-20
OS OS : Windows Vista
Points Points : 25173
Re: HP DV6000 with vista startup problems...help please!
Post by Doctor Inferno on 20th January 2010, 5:42 am
The "unusual sounds" you are referring to, does your computer beep at intervals?
Points Points : 104610
Post by chadlytle on 20th January 2010, 5:51 am
Oh sorry I should have specified that...no beeping sounds. I was just refering to the standard startup with the fans turning on and what not. Nothing out of the ordinary.
chadlytle
Posts Posts : 5
Post by Doctor Inferno on 20th January 2010, 5:58 am
Could you try a system restore and see if it works?
Post by chadlytle on 21st January 2010, 12:59 am
I didnt have a restore point so I went ahead and reformated the computer to factory condition. I am getting all the updates right now so perhaps that will include some driver updates and take care of all further problems. I will keep you posted. Big Grin
chadlytle
Posts Posts : 5
Post by chadlytle on 21st January 2010, 3:15 am
Hmm looks as if I have a whopping 97 important updates to do, they are installing now...think that will help a little bit?
chadlytle
Posts Posts : 5
Post by Doctor Inferno on 21st January 2010, 3:25 am
Yeah, install all the updates, they will include security patches etc. I think all should be good now.
Post by chadlytle on 21st January 2010, 3:40 am
Sure hope so! Thanks Doc.
chadlytle
Posts Posts : 5
