Computer is freezing up and running slow
Page 1 of 3 1, 2, 3  Next
Post by Thebeast28 on 19th January 2010, 6:25 am
I have a problem with my computer freezing up and running slow. I am using windows xp and i start the computer up which takes a long time to load up. Then I go to open something up like spybot, my computer or anything and it takes forever to open then it will freeze up on me. Then I wait awhile and then it unfreezes and sometimes it doesn't. It takes a long time for it to unfreeze sometimes. If it doesn't unfreeze I have to shut of the computer manually by hand. I have a lot of virus and anti spyware programs. I don't know which ones to use if any will help my problem. I can't believe i am on the internet right now cause it freeze up to or want load up. So i hope someone can help fix my computer so it stops freezing up and running slow.
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
Post by Dr Jay on 19th January 2010, 10:15 am
Please visit this webpage for instructions for downloading and running ComboFix:
Post the log from ComboFix when you've accomplished that.
Posts Posts : 13810
Points Points : 302437
Post by Thebeast28 on 20th January 2010, 12:31 am
Internet keeps freezing up as I type I type a little then i have to wait forever to type again it keeps doing it on in on again. It freezes up after every word i type. It is taking me forever to send this message. Took me forever to run combofix and get the log and i was about to give up but didn't. So her is the log from Combofix.
ComboFix 10-01-19.01 - Jonathan Murray 01/19/2010 16:41:35.2.1 - x86
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.479.115 [GMT -5:00]
Running from: c:\program files\ComboFix.exe
AV: AVG Internet Security *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
FW: AVG Firewall *enabled* {8decf618-9569-4340-b34a-d78d28969b66}
c:\program files\Internet Explorer\SET53.tmp
c:\program files\Internet Explorer\SET59.tmp
c:\windows\system32\UACyrrmxelhfvykjsm.db
((((((((((((((((((((((((( Files Created from 2009-12-19 to 2010-01-19 )))))))))))))))))))))))))))))))
2010-01-18 02:53 . 2010-01-18 02:54 595499 ----a-w- c:\program files\Autoruns.zip
2010-01-17 05:50 . 2010-01-17 05:50 -------- d-----w- c:\documents and settings\Jonathan Murray\Local Settings\Application Data\Threat Expert
2010-01-16 19:51 . 2010-01-16 19:55 -------- d-----w- c:\program files\hpHosts
2010-01-16 19:50 . 2010-01-16 19:50 1026759 ----a-w- c:\program files\hpHosts-Setup-Win32.exe
2010-01-16 05:09 . 2010-01-16 05:09 800544 ----a-w- c:\program files\jre-6u17-windows-i586-iftw-rv.exe
2010-01-16 04:55 . 2010-01-16 04:59 27386256 ----a-w- c:\program files\AdbeRdr930_en_US.exe
2010-01-15 22:07 . 2010-01-15 22:07 843187 ----a-w- c:\program files\SecurityCheck.exe
2010-01-14 23:13 . 2010-01-14 23:13 2672312 ----a-w- c:\program files\esetsmartinstaller_enu.exe
2010-01-13 20:05 . 2010-01-19 20:14 3829479 ----a-r- c:\program files\ComboFix.exe
2010-01-13 02:56 . 2009-11-21 15:51 471552 -c----w- c:\windows\system32\dllcache\aclayers.dll
2010-01-11 04:40 . 2009-11-10 15:26 767952 ----a-w- c:\windows\BDTSupport.dll
2010-01-11 04:40 . 2009-11-10 15:28 149456 ----a-w- c:\windows\SGDetectionTool.dll
2010-01-11 04:40 . 2009-11-10 15:28 165840 ----a-w- c:\windows\PCTBDRes.dll
2010-01-11 04:40 . 2009-11-10 15:28 1640400 ----a-w- c:\windows\PCTBDCore.dll
2010-01-11 04:40 . 2009-10-28 06:36 1152444 ----a-w- c:\windows\UDB.zip
2010-01-11 04:40 . 2008-11-26 17:08 131 ----a-w- c:\windows\IDB.zip
2010-01-11 04:04 . 2010-01-11 04:08 34628432 ----a-w- c:\program files\sdsetup.exe
2010-01-10 23:40 . 2010-01-10 23:40 -------- d-----w- c:\documents and settings\Administrator.JONATHAN\Application Data\SUPERAntiSpyware.com
2010-01-10 22:03 . 2010-01-19 17:36 0 ----a-w- c:\documents and settings\Jonathan Murray\Local Settings\Application Data\prvlcl.dat
2010-01-07 21:39 . 2010-01-07 23:30 -------- d-----w- C:\$AVG
2010-01-07 21:38 . 2010-01-07 21:38 12464 ----a-w- c:\windows\system32\avgrsstx.dll
2010-01-07 21:38 . 2010-01-19 20:24 -------- d-----w- c:\windows\system32\drivers\Avg
2010-01-07 21:36 . 2010-01-07 21:36 25608 ----a-w- c:\windows\system32\drivers\AVGIDSxx.sys
2010-01-07 21:36 . 2010-01-07 21:36 161800 ----a-w- c:\windows\system32\drivers\avgrkx86.sys
2010-01-07 21:36 . 2010-01-07 21:36 360584 ----a-w- c:\windows\system32\drivers\avgtdix.sys
2010-01-07 21:36 . 2010-01-07 21:36 333192 ----a-w- c:\windows\system32\drivers\avgldx86.sys
2010-01-07 21:36 . 2010-01-07 21:36 28424 ----a-w- c:\windows\system32\drivers\avgmfx86.sys
2010-01-07 21:34 . 2010-01-07 21:34 50968 ----a-w- c:\windows\system32\avgfwdx.dll
2010-01-07 21:34 . 2010-01-07 21:34 30104 ----a-w- c:\windows\system32\drivers\avgfwdx.sys
2010-01-07 21:34 . 2010-01-07 21:34 -------- d-----w- c:\program files\AVG
2010-01-07 21:34 . 2010-01-11 13:17 -------- d-----w- c:\documents and settings\All Users\Application Data\avg9
2010-01-07 18:43 . 2010-01-07 20:25 163713 ----a-w- c:\windows\system32\drivers\sfi.dat
2010-01-07 18:34 . 2010-01-07 20:27 -------- d-----w- c:\program files\COMODO
2010-01-07 18:28 . 2010-01-07 18:33 40603920 ----a-w- c:\program files\CIS_Setup_3.13.125662.579_XP_Vista_x32.exe
2010-01-07 18:00 . 2010-01-07 18:00 891248 ----a-w- c:\program files\avg_free_stb_all_9_40_cnet.exe
2010-01-05 22:45 . 2010-01-05 22:45 -------- d-----w- c:\documents and settings\All Users\Application Data\SUPERAntiSpyware.com
2010-01-05 22:44 . 2010-01-05 22:45 -------- d-----w- c:\program files\SUPERAntiSpyware
2010-01-05 22:44 . 2010-01-05 22:44 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\SUPERAntiSpyware.com
2010-01-05 22:44 . 2010-01-05 22:44 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2010-01-05 22:42 . 2010-01-05 22:44 7451168 ----a-w- c:\program files\SUPERAntiSpywarePro.exe
2010-01-05 18:43 . 2010-01-05 18:43 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\Malwarebytes
2010-01-05 18:42 . 2010-01-07 21:07 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-01-05 18:42 . 2010-01-05 18:42 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2010-01-05 18:42 . 2010-01-07 21:07 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-01-05 18:42 . 2010-01-11 22:26 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-01-05 18:40 . 2010-01-05 18:41 5061520 ----a-w- c:\program files\mbam-setup.exe
2010-01-02 02:55 . 2010-01-05 05:20 8086544 ----a-w- c:\program files\Firefox Setup 3.5.6.exe
2009-12-23 08:35 . 2009-12-23 14:54 -------- d-----w- C:\a725013441aa0de15deab303a87e0b7b
2009-12-23 04:35 . 2009-12-23 07:19 -------- d-----w- C:\0b93e35ba6ecc3299040c52d
2009-12-23 02:14 . 2009-12-23 19:55 -------- d-----w- c:\program files\Unlocker
2009-12-22 06:42 . 2009-12-22 06:42 -------- d-s---w- c:\documents and settings\NetworkService\UserData
2010-01-19 17:43 . 2008-05-16 01:32 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2010-01-18 03:11 . 2004-03-25 03:00 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2010-01-16 05:12 . 2009-10-11 22:11 411368 ----a-w- c:\windows\system32\deploytk.dll
2010-01-16 05:12 . 2004-12-01 21:15 -------- d-----w- c:\program files\Java
2010-01-16 05:05 . 2004-03-24 01:01 -------- d-----w- c:\program files\Common Files\Adobe
2010-01-13 17:55 . 2008-05-16 23:20 -------- d-----w- c:\program files\Spyware Doctor
2010-01-13 05:24 . 2009-06-01 23:24 0 ----a-w- C:\qinfo.dat
2010-01-11 18:32 . 2005-01-08 16:28 -------- d-----w- c:\program files\Spybot - Search & Destroy
2010-01-11 18:21 . 2009-06-02 20:26 -------- d-----w- c:\program files\Spybot - Search & Destroy1
2010-01-05 05:49 . 2009-12-04 00:27 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\BitTorrent
2010-01-04 06:55 . 2009-08-31 05:12 -------- d-----w- c:\program files\WildGames
2010-01-04 06:29 . 2010-01-04 06:29 44024 ----a-w- c:\program files\bookmarks1-3-09.html
2009-12-31 05:26 . 2006-01-30 19:12 44240 ----a-w- c:\documents and settings\LocalService\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-23 20:28 . 2008-12-14 01:25 -------- d-----w- c:\documents and settings\All Users\Application Data\SmartSound Software Inc
2009-12-23 20:20 . 2004-03-23 22:31 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-12-23 19:32 . 2004-04-07 23:57 44240 ----a-w- c:\documents and settings\Jonathan Murray\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-23 15:22 . 2006-05-30 20:25 -------- d-----w- c:\documents and settings\All Users\Application Data\Sonic
2009-12-23 15:19 . 2006-05-30 20:25 -------- d-----w- c:\program files\Common Files\Sonic Shared
2009-12-23 15:18 . 2006-05-30 20:22 -------- d-----w- c:\program files\Common Files\Roxio Shared
2009-12-23 15:18 . 2006-05-30 20:23 -------- d-----w- c:\documents and settings\All Users\Application Data\Roxio
2009-12-05 07:42 . 2009-12-05 07:41 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\Nero
2009-12-05 07:41 . 2009-12-05 07:41 -------- d-----w- c:\documents and settings\All Users\Application Data\LightScribe
2009-12-05 07:41 . 2007-04-04 16:59 -------- d-----w- c:\program files\Common Files\LightScribe
2009-12-05 07:39 . 2009-12-05 07:20 -------- d-----w- c:\program files\Common Files\Nero
2009-12-05 07:38 . 2007-04-04 16:55 -------- d-----w- c:\program files\Nero
2009-12-05 07:25 . 2007-04-04 16:55 -------- d-----w- c:\documents and settings\All Users\Application Data\Nero
2009-12-05 06:33 . 2009-12-05 06:08 214167816 ----a-w- c:\program files\Nero-9.4.26.0_trial.exe
2009-12-04 23:36 . 2009-12-04 23:30 -------- d-----w- c:\program files\Cucusoft
2009-12-04 23:35 . 2009-12-04 23:35 2081039 ----a-w- c:\program files\dvd-author.exe
2009-12-04 23:29 . 2009-12-04 23:29 3119665 ----a-w- c:\program files\dvd-burner.exe
2009-12-04 23:26 . 2009-12-04 23:26 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\AnvSoft
2009-12-04 23:26 . 2009-12-04 23:26 -------- d-----w- c:\program files\AnvSoft
2009-12-04 23:26 . 2009-12-04 23:24 15672013 ----a-w- c:\program files\avc-free.exe
2009-12-04 23:23 . 2009-12-04 22:56 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\Vso
2009-12-04 23:23 . 2009-12-04 22:56 47360 ----a-w- c:\documents and settings\Jonathan Murray\Application Data\pcouffin.sys
2009-12-04 22:56 . 2009-12-04 22:56 47360 ------w- c:\windows\system32\drivers\pcouffin.sys
2009-12-04 22:54 . 2009-12-04 22:52 18026336 ----a-w- c:\program files\vsoConvertXtoDVD4_setup.exe
2009-12-04 22:22 . 2009-12-04 22:11 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\DivX
2009-12-04 19:53 . 2009-12-04 19:52 -------- d-----w- c:\program files\DivX
2009-12-04 19:52 . 2009-12-04 19:52 -------- d-----w- c:\program files\Common Files\DivX Shared
2009-12-04 19:51 . 2009-12-04 19:49 23804080 ----a-w- c:\program files\DivXInstaller.exe
2009-12-04 19:14 . 2009-12-04 19:14 6104788 ----a-w- c:\program files\burnaware_free242.exe
2009-12-04 00:26 . 2009-12-04 00:25 -------- d-----w- c:\program files\BitTorrent
2009-12-04 00:14 . 2009-12-04 00:13 3066744 ----a-w- c:\program files\BitTorrent-6.3c.exe
2009-12-02 23:12 . 2009-12-02 23:12 8084968 ----a-w- c:\program files\Firefox Setup 3.5.5.exe
2009-12-02 00:03 . 2008-01-06 17:12 -------- d-----w- c:\documents and settings\Jonathan Murray\Application Data\LimeWire
2009-11-21 15:51 . 2003-11-08 12:00 471552 ----a-w- c:\windows\AppPatch\aclayers.dll
2009-11-14 00:47 . 2009-11-14 00:47 90112 ------w- c:\windows\system32\dpl100.dll
2009-11-14 00:47 . 2009-11-14 00:47 856064 ------w- c:\windows\system32\divx_xx0c.dll
2009-11-14 00:47 . 2009-11-14 00:47 856064 ------w- c:\windows\system32\divx_xx07.dll
2009-11-14 00:47 . 2009-11-14 00:47 847872 ------w- c:\windows\system32\divx_xx0a.dll
2009-11-14 00:47 . 2009-11-14 00:47 843776 ------w- c:\windows\system32\divx_xx16.dll
2009-11-14 00:47 . 2009-11-14 00:47 839680 ------w- c:\windows\system32\divx_xx11.dll
2009-11-14 00:47 . 2009-11-14 00:47 696320 ------w- c:\windows\system32\DivX.dll
2009-11-09 16:20 . 2009-06-02 04:10 207792 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-11-05 06:03 . 2001-09-17 05:56 77607 ----a-w- c:\windows\PCHEALTH\HELPCTR\OfflineCache\index.dat
2009-10-30 16:11 . 2009-06-02 04:11 233136 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-10-29 05:38 . 2003-11-08 12:00 667136 ------w- c:\windows\system32\wininet.dll
2009-10-07 20:01 . 2009-10-07 20:01 3340064 ----a-w- c:\program files\UnityWebPlayer.exe
2009-10-04 17:12 . 2009-10-04 17:11 12541248 ----a-w- c:\program files\RLCSetup.exe
2009-09-15 19:44 . 2009-09-15 19:42 25685128 ----a-w- c:\program files\wordview_en-us.exe
2009-09-15 19:26 . 2009-09-15 19:26 13824 ----a-r- c:\program files\TRU_Unicru_92908.doc
2009-09-12 20:16 . 2009-09-12 20:16 4122416 ----a-w- c:\program files\freeclip.exe
2009-09-11 23:10 . 2009-09-11 22:55 52736 ----a-w- c:\program files\oown_resume_template.doc
2009-09-04 19:49 . 2009-09-04 19:47 11729274 ----a-w- c:\program files\installeasyjob.exe
2009-09-02 19:29 . 2009-09-02 19:29 8050536 ----a-w- c:\program files\Firefox Setup 3.5.2.exe
2009-07-07 23:46 . 2009-07-07 23:45 359656 ----a-w- c:\program files\msicuu2.exe
2009-02-17 01:18 . 2009-02-16 04:28 16939888 ----a-w- c:\program files\IE8-WindowsXP-x86-ENU.exe
2008-11-23 17:56 . 2008-11-23 17:56 25740144 ----a-w- c:\program files\wmp11-windowsxp-x86-enu.exe
2008-09-06 03:18 . 2005-01-03 03:29 1505160 ----a-w- c:\program files\install_easyshare.exe
2008-07-04 00:24 . 2008-07-04 00:21 1445888 ----a-w- c:\program files\WinsockxpFix.exe
2008-05-31 02:17 . 2008-05-31 02:07 9723880 ----a-w- c:\program files\spybotsd152.exe
2008-05-29 00:21 . 2008-05-29 00:21 1244712 ----a-w- c:\program files\SetupOneCare.exe
2008-05-28 03:12 . 2008-05-28 03:12 7608344 ----a-w- c:\program files\spyhunterFULL.exe
2008-05-09 13:47 . 2008-05-09 13:47 1206366 ----a-w- c:\program files\wrar371.exe
2008-05-09 13:43 . 2008-05-09 13:43 244784 ----a-w- c:\program files\gnie_s_dvd4-iml2iso.rar
2008-05-09 03:44 . 2008-05-09 03:44 10121656 ----a-w- c:\program files\Alcohol120_trial_1.9.7.6221.exe
2008-05-09 03:28 . 2008-05-09 03:28 1385051 ----a-w- c:\program files\cddvdgen.zip
2008-05-09 03:12 . 2008-05-09 03:12 899414 ----a-w- c:\program files\SetupDVDDecrypter_3.5.4.0.exe
2008-04-06 17:28 . 2008-04-06 17:28 569777 ----a-w- c:\program files\DVD43_4-2-0_Setup.exe
2008-01-05 18:20 . 2008-01-05 18:20 3381280 ----a-w- c:\program files\LimeWireWin.exe
2006-06-18 00:07 . 2006-06-18 00:07 1522527 ----a-w- c:\program files\dvdrip32572.exe
2006-06-12 18:48 . 2006-06-12 18:48 1160885 ----a-w- c:\program files\DVDRegionFree59.exe
2006-06-04 05:56 . 2006-06-04 05:56 302680 ----a-w- c:\program files\ac3filter_0_70b.exe
2006-06-04 05:50 . 2006-06-04 05:50 156181 ----a-w- c:\program files\MpegDecoder012.zip
2006-06-04 00:49 . 2006-06-04 00:49 6973792 ----a-w- c:\program files\iaplayer_2.60.12.0201_esd.exe
2006-06-03 21:08 . 2006-06-03 21:08 5753886 ----a-w- c:\program files\psp_video_express.exe
2006-05-15 00:22 . 2006-05-15 00:17 5779942 ----a-w- c:\program files\psp_movie_creator.exe
2006-05-14 21:15 . 2006-03-12 21:49 3457413 ----a-w- c:\program files\1clickdvdcopysetup.exe
2006-03-12 19:17 . 2006-03-12 19:17 521403 ----a-w- c:\program files\DVD43_3-7-0_Setup.exe
2006-03-12 16:38 . 2006-03-11 23:17 3878912 ----a-w- c:\program files\ICopyDVDs2_30DayTrial_EN_v4.1.0.2.exe
2006-01-30 01:05 . 2006-01-30 01:05 7391952 ----a-w- c:\program files\ewido-setup.exe
2005-11-03 23:52 . 2005-09-24 15:43 64 ---ha-w- c:\program files\AppUpdate.log
2005-09-25 14:31 . 2005-09-25 14:31 194835 ----a-w- c:\program files\ringtoneripper.exe
2005-09-24 02:14 . 2005-09-24 02:14 24265736 ----a-w- c:\program files\dotnetfx.exe
2005-03-03 23:40 . 2005-03-03 21:35 20798256 ----a-w- c:\program files\AdbeRdr70_enu_full.exe
2005-01-09 22:50 . 2005-01-09 22:39 2145414 ----a-w- c:\program files\OneTouch.exe
2005-01-08 02:48 . 2005-01-08 02:48 4354084 ----a-w- c:\program files\spybotsd13.exe
2004-02-20 07:38 . 2004-03-23 23:18 1760378 ----a-w- c:\program files\aaw6.exe
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe" [2006-12-23 143360]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-09-11 86960]
"HostManager"="c:\program files\Common Files\AOL\1155679928\ee\AOLSoftware.exe" [2006-09-26 50736]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2006-02-19 49152]
"LanguageShortcut"="c:\program files\CyberLink\PowerDVD\Language\Language.exe" [2006-12-06 54832]
"NeroFilterCheck"="c:\program files\Common Files\Ahead\Lib\NeroCheck.exe" [2006-01-12 155648]
"AVG9_TRAY"="c:\progra~1\AVG\AVG9\avgtray.exe" [2010-01-09 2033432]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-12-22 35760]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-12-11 948672]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2010-01-16 149280]
"tscuninstall"="c:\windows\system32\tscupgrd.exe" [2004-08-04 44544]
HP Digital Imaging Monitor.lnk.disabled [2006-12-23 1808]
HP Photosmart Premier Fast Start.lnk.disabled [2006-12-23 798]
NETGEAR WG311v3 Smart Wizard.lnk - c:\program files\NETGEAR\WG311v3\wlancfg5.exe [2006-1-26 1486848]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
2009-09-03 19:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\OneCareMP]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Kodak EasyShare software.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Kodak EasyShare software.lnk
backup=c:\windows\pss\Kodak EasyShare software.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Kodak software updater.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Kodak software updater.lnk
backup=c:\windows\pss\Kodak software updater.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Works Calendar Reminders.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Works Calendar Reminders.lnk
backup=c:\windows\pss\Microsoft Works Calendar Reminders.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
NvQTwk [X]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AOLDialer]
2006-10-23 12:50 71216 ----a-r- c:\program files\Common Files\AOL\ACS\AOLDial.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CARPService]
2002-01-03 03:06 4608 ------w- c:\windows\system32\carpserv.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\dvd43]
2008-03-01 19:49 826880 ----a-w- c:\program files\dvd43\DVD43_Tray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMEKRMIG6.1]
2001-08-18 22:00 44032 ----a-w- c:\windows\ime\imkr6_1\imekrmig.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMJPMIG8.1]
2004-08-04 05:31 208952 ----a-w- c:\windows\ime\imjp8_1\imjpmig.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISTray]
2009-11-18 17:47 1243088 ----a-w- c:\program files\Spyware Doctor\pctsTray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Works Portfolio]
2000-07-13 20:00 311350 ----a-w- c:\program files\Microsoft Works\wkssb.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Works Update Detection]
2000-07-13 20:00 28739 ----a-w- c:\program files\Microsoft Works\WkDetect.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Smapp]
2001-10-12 23:45 69632 ----a-w- c:\program files\Analog Devices\SoundMAX\SMTray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WorksFUD]
2000-07-13 20:00 24576 ----a-w- c:\program files\Microsoft Works\wkfud.exe
"MCVSRte"=2 (0x2)
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run-]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe"
R0 sptd;sptd;c:\windows\System32\Drivers\sptd.sys [2008-05-09 716272]
R2 msCMTSrvc;Content Monitoring Tool;c:\windows\system32\msCMTSrvc.exe [x]
R3 Avgfwfd;AVG network filter service;c:\windows\system32\DRIVERS\avgfwdx.sys [2010-01-07 30104]
R3 Roxio UPnP Renderer 11;Roxio UPnP Renderer 11;c:\program files\Roxio Creator 2009\Digital Home 11\RoxioUPnPRenderer11.exe [x]
R3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [2009-12-16 7408]
R3 sdAuxService;PC Tools Auxiliary Service;c:\program files\Spyware Doctor\pctsAuxs.exe [2009-10-30 359624]
R3 SWNC8U12;Sierra Wireless MUX NDIS Driver (UMTS12);c:\windows\system32\DRIVERS\swnc8u12.sys [2007-06-15 82432]
R3 swumx12;Sierra Wireless USB MUX Driver (UMTS12);c:\windows\system32\DRIVERS\swumx12.sys [2007-06-15 66304]
R3 USB-100;SMC Compact USB to Ethernet converter;c:\windows\system32\DRIVERS\SMC2208.SYS [2001-09-25 27519]
S0 AVGIDSErHrxpx;AVG9IDSErHr;c:\windows\System32\Drivers\AVGIDSxx.sys [2010-01-07 25608]
S0 AvgRkx86;avgrkx86.sys;c:\windows\System32\Drivers\avgrkx86.sys [2010-01-07 161800]
S0 PCTCore;PCTools KDS;c:\windows\system32\drivers\PCTCore.sys [2009-11-09 207792]
S1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\System32\Drivers\avgldx86.sys [2010-01-07 333192]
S1 AvgTdiX;AVG Network Redirector;c:\windows\System32\Drivers\avgtdix.sys [2010-01-07 360584]
S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV.SYS [2009-12-16 9968]
S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.sys [2009-12-16 74480]
S2 avg9emc;AVG E-mail Scanner;c:\program files\AVG\AVG9\avgemc.exe [2010-01-07 906520]
S2 avg9wd;AVG WatchDog;c:\program files\AVG\AVG9\avgwdsvc.exe [2010-01-09 285392]
S2 avgfws9;AVG Firewall;c:\program files\AVG\AVG9\avgfws9.exe [2010-01-15 2304192]
S2 AVGIDSAgent;AVG9IDSAgent;c:\program files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe AVGIDSAgent [x]
S2 Browser Defender Update Service;Browser Defender Update Service;c:\program files\Spyware Doctor\BDT\BDTUpdateService.exe [2009-11-10 112592]
S2 wwEngineSvc;Window Washer Engine;c:\program files\Webroot\Washer\WasherSvc.exe [2007-09-05 389448]
S3 Avgfwdx;Avgfwdx;c:\windows\system32\DRIVERS\avgfwdx.sys [2010-01-07 30104]
S3 AVGIDSDriverxpx;AVG9IDSDriver;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys [2010-01-07 122376]
S3 AVGIDSFilterxpx;AVG9IDSFilter;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys [2010-01-07 30216]
S3 AVGIDSShimxpx;AVG9IDSShim;c:\program files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys [2010-01-07 25736]
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
ylmolrez
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2009-08-20 18:24 451872 ----a-w- c:\program files\Common Files\LightScribe\LSRunOnce.exe
2010-01-19 c:\windows\Tasks\RegCure Program Check.job
- c:\program files\RegCure\RegCure.exe [2008-04-21 21:21]
2009-12-24 c:\windows\Tasks\RegCure.job
2004-03-28 c:\windows\Tasks\Registration reminder 1.job
- c:\windows\System32\OOBE\oobebaln.exe [2006-04-09 00:12]
2004-03-23 c:\windows\Tasks\Registration reminder 2.job
2004-04-08 c:\windows\Tasks\Registration reminder 3.job
mWindow Title =
uInternet Settings,ProxyServer = 168.94.74.68:8080
IE: &AOL Toolbar Search
DPF: DirectAnimation Java Classes - [You must be registered and logged in to see this link.]
DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} - [You must be registered and logged in to see this link.]
DPF: {2C8EEB84-6D60-11D4-BD64-0050048A82BF} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\
FF - prefs.js: browser.search.selectedEngine - Fast Browser Search
FF - component: c:\program files\AVG\AVG9\Firefox\components\avgssff.dll
FF - plugin: c:\program files\DivX\DivX Plus Web Player\npdivx32.dll
MSConfigStartUp-SunJavaUpdateSched - c:\program files\Java\j2re1.4.2_06\bin\jusched.exe
Rootkit scan 2010-01-19 16:58
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(1568)
Completion time: 2010-01-19 17:24:48
ComboFix-quarantined-files.txt 2010-01-19 22:24
ComboFix2.txt 2010-01-13 22:03
Pre-Run: 18,574,524,416 bytes free
Post-Run: 18,533,933,056 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
Current=7 Default=7 Failed=2 LastKnownGood=8 Sets=1,2,3,4,5,6,7,8
- - End Of File - - 832495A42EF3ED8A8F642B898A495317
Thebeast28
Posts Posts : 159
Post by Dr Jay on 20th January 2010, 3:30 am
Alternate link: [You must be registered and logged in to see this link.].
Posts Posts : 13810
Post by Thebeast28 on 20th January 2010, 5:53 am
Hey my computer is really slow know it took me an hour just to get here and post a reply. You told me to do all this stuff before in another post cause i had the WIN32/Cryptor virus. After doing everything my computer became slow and freezes up. Takes an hour to do anything then when i get there like right herewhere i am typing it freezes after every letter i type or when i scoll down. I don't know i might have the Win32/Crytor virus or something else. Let me get that log for you it might take a really long time for me to send it if i can. I can't believe i got on the internet cause it took me all day to. I even tried a system restore didn't help.
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 20th January 2010, 11:17 pm
Can't get on Firefox but i can get on internet explorer. why?
Database version: 3601
Internet Explorer 6.0.2900.5512
01/20/2010 2:05:13 PM
mbam-log-2010-01-20 (14-05-12).txt
Scan type: Full Scan (C:\|)
Objects scanned: 227037
Time elapsed: 4 hour(s), 8 minute(s), 49 second(s)
Files Infected: 8
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP23\A0014192.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP23\A0014132.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP23\A0014260.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP23\A0014412.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP24\A0015672.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP24\A0015741.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP24\A0015884.sys (Malware.Trace) -> Quarantined and deleted successfully.
C:\System Volume Information\_restore{8238BFE6-44BD-4B25-B0F7-CE65B3815CC9}\RP24\A0015808.sys (Malware.Trace) -> Quarantined and deleted successfully.
Thebeast28
Posts Posts : 159
Post by Dr Jay on 21st January 2010, 12:45 am
Let's do a diagnostic. This is a very small download.
Please download [You must be registered and logged in to see this link.], and save to your Desktop.
  • Double-click on vtool.zip, and extract the file to your Desktop.
  • Double-click on vtool.cmd to start.
  • !! IMPORTANT !!::: At each prompt ("Press any key to continue..."), wait 10 seconds before pressing a key. This tool needs time to process each prompt.
  • It will finish eventually and launch a log. Do NOT exit the tool. Allow it to finish. (vtool.txt)
  • Post the contents of it in your next reply.
Posts Posts : 13810
Post by Thebeast28 on 21st January 2010, 3:00 am
V-Tool by DragonMaster Jay
Username: Jonathan Murray - Date: 01/20/2010 - Time: 21:59:25 - Number of processors: 1 - Arch.: x86 SF:
((((( Security Software information )))))
((((( System File Verify )))))
c:\windows\system32\cngaudit.dll is missing! (If Vista/7)
((((( System File Enumeration )))))
Volume in drive C has no label.
Volume Serial Number is E487-EF02
Directory of C:\WINDOWS\$hf_mig$\KB968389\SP2QFE
netlogon.dll
1 File(s) 408,064 bytes
Directory of C:\WINDOWS\$hf_mig$\KB975467\SP2QFE
netlogon.dll
Directory of C:\WINDOWS\$NtServicePackUninstall$
scecli.dll atapi.sys netlogon.dll eventlog.dll
4 File(s) 738,432 bytes
Directory of C:\WINDOWS\$NtUninstallQ306583$
atapi.sys
1 File(s) 86,656 bytes
Directory of C:\WINDOWS\ERDNT\cache
scecli.dll beep.sys eventlog.dll
5 File(s) 745,344 bytes
Directory of C:\WINDOWS\ServicePackFiles\i386
4 File(s) 741,120 bytes
Directory of C:\WINDOWS\system32
scecli.dll netlogon.dll eventlog.dll
3 File(s) 644,608 bytes
Directory of C:\WINDOWS\system32\dllcache
beep.sys
1 File(s) 4,224 bytes
Directory of C:\WINDOWS\system32\drivers
atapi.sys beep.sys
2 File(s) 100,736 bytes
Total Files Listed:
22 File(s) 3,877,248 bytes
0 Dir(s) 18,327,846,912 bytes free
+++ End-of-file +++
Thebeast28
Posts Posts : 159
Post by Dr Jay on 21st January 2010, 11:13 pm
Please download [You must be registered and logged in to see this link.] and Save it to your desktop
  1. Double click it to start the tool.
  2. Click Scan.
  3. Eventually, a Notepad file containing the report will open, also found at C:\Rooter.txt. Post that log in your next reply.
Posts Posts : 13810
Post by Thebeast28 on 22nd January 2010, 4:30 am
Can open up Firefox but it want load anything but I can use internet explorer. It is slow sometimes, fast sometimes and freezes up and it doesn't even log on sometimes. It is fast right now and i can believe it.
Rooter.exe (v1.0.2) by Eric_71
SeDebugPrivilege granted successfully ...
Windows XP Home Edition (5.1.2600) Service Pack 3
[32_bits] - x86 Family 6 Model 6 Stepping 2, AuthenticAMD
[wscsvc] (Security Center) RUNNING (state:4)
[SharedAccess] STOPPED (state:1) : Windows Firewall -> Disabled !
Mozilla Firefox 3.5.6 (en-US)
A:\ [Removable]
C:\ [Fixed-NTFS] .. ( Total:74 Go - Free:17 Go )
D:\ [CD_Rom]
E:\ [CD_Rom]
F:\ [CD_Rom]
Scan : 23:27.52
Path : C:\Program Files\Rooter.exe
User : Jonathan Murray ( Administrator -> YES )
----------------------\\ Processes
Locked [System Process] (0)
______ System (4)
______ \SystemRoot\System32\smss.exe (1432)
______ \??\C:\WINDOWS\system32\csrss.exe (1580)
______ \??\C:\WINDOWS\system32\winlogon.exe (1608)
______ C:\WINDOWS\system32\services.exe (1652)
______ C:\WINDOWS\system32\lsass.exe (1664)
______ C:\WINDOWS\system32\svchost.exe (1828)
______ C:\WINDOWS\system32\svchost.exe (1872)
______ C:\WINDOWS\System32\svchost.exe (172)
______ C:\WINDOWS\System32\svchost.exe (284)
______ C:\Program Files\AVG\AVG9\avgchsvx.exe (352)
______ C:\Program Files\AVG\AVG9\avgrsx.exe (360)
______ C:\WINDOWS\system32\svchost.exe (428)
______ C:\Program Files\AVG\AVG9\avgcsrvx.exe (496)
______ C:\WINDOWS\system32\spoolsv.exe (652)
Locked AVGIDSAgent.exe (952)
______ C:\WINDOWS\Explorer.EXE (1100)
______ C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (1456)
______ C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe (1480)
______ C:\Program Files\HP\HP Software Update\HPWuSchd2.exe (1500)
______ C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe (1508)
______ C:\Program Files\Unlocker\UnlockerAssistant.exe (1552)
Locked avgtray.exe (1572)
______ C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe (1940)
______ C:\Program Files\Webroot\Washer\wwDisp.exe (1988)
______ C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe (264)
______ C:\Program Files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe (1312)
______ C:\Program Files\AVG\AVG9\Identity Protection\agent\bin\avgidsmonitor.exe (1024)
______ C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe (2776)
______ C:\WINDOWS\System32\svchost.exe (3684)
______ C:\WINDOWS\System32\alg.exe (3384)
______ C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe (3336)
Locked avgwdsvc.exe (2948)
Locked avgfws9.exe (3764)
______ C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe (912)
Locked avgam.exe (1912)
______ C:\Program Files\AVG\AVG9\avgnsx.exe (2616)
______ C:\Program Files\Common Files\LightScribe\LSSrvc.exe (1348)
______ C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe (3560)
______ C:\WINDOWS\System32\nvsvc32.exe (1628)
______ C:\Program Files\CyberLink\Shared Files\RichVideo.exe (1184)
______ C:\WINDOWS\System32\locator.exe (3356)
______ C:\WINDOWS\system32\slserv.exe (2436)
______ C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe (3116)
______ C:\WINDOWS\System32\svchost.exe (4040)
______ C:\Program Files\Webroot\Washer\WasherSvc.exe (2940)
______ C:\Program Files\AVG\AVG9\avgemc.exe (2600)
______ C:\Program Files\AVG\AVG9\avgcsrvx.exe (3800)
______ C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe (3700)
______ C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe (3380)
______ C:\WINDOWS\system32\wuauclt.exe (1804)
______ C:\Program Files\AVG\AVG9\avgcsrvx.exe (152)
______ C:\WINDOWS\System32\svchost.exe (3100)
______ C:\Program Files\Java\jre6\bin\jqs.exe (2292)
______ C:\Program Files\Internet Explorer\iexplore.exe (4756)
______ C:\Program Files\Rooter.exe (2348)
----------------------\\ Device\Harddisk0\
\Device\Harddisk0 [Sectors : 63 x 512 Bytes]
\Device\Harddisk0\Partition1 --[ MBR ]-- (Start_Offset:32256 | Length:80023233024)
----------------------\\ Scheduled Tasks
C:\WINDOWS\Tasks\desktop.ini
C:\WINDOWS\Tasks\RegCure Program Check.job
C:\WINDOWS\Tasks\RegCure.job
C:\WINDOWS\Tasks\Registration reminder 1.job
C:\WINDOWS\Tasks\Registration reminder 2.job
C:\WINDOWS\Tasks\Registration reminder 3.job
C:\WINDOWS\Tasks\SA.DAT
----------------------\\ Registry
----------------------\\ Files & Folders
----------------------\\ Scan completed at 23:28.45
C:\Rooter$\Rooter_1.txt - (21/01/2010 | 23:28.45)
Thebeast28
Posts Posts : 159
Post by Dr Jay on 22nd January 2010, 6:20 pm
Please create a Windows Restore Point!
  • Download [You must be registered and logged in to see this link.] by [You must be registered and logged in to see this link.].
  • Save the download to your Desktop. Then, double-click it and Extract all.
  • To Extract, click the Next button repeatedly. Then, it will finish.
  • Double-click the Folder, and then double-click QuickRestoreMaker.exe.
  • It will create a Windows Restore Point. Click Exit when done.
Please copy and paste the following in to Notepad:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"GlobalMaxTcpWindowSize"="256960"
"TcpWindowSize"="256960"
"DefaultTTL"="64"
"EnablePMTUDiscovery"="1"
"DisableTaskOffload"="0"
[HKEY_USERS.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings]
"MaxConnectionsPerServer"=dword:00000010
"MaxConnectionsPer1_0Server"=dword:00000010
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\RemoteComputer\NameSpace\{D6277990-4C6A-11CF-8D87-00AA0060F5BF}]
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanmanServer\Parameters]
"SizReqBuf"="16384"
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanmanWorkstation\Parameters]
"MaxCmds"=dword:00000064
"MaxThreads"=dword:00000064
"MaxCollectionCount"="65535"
Then click File > Save as
File name: internetFIX.reg
Save as type: All Files
Once saved, Exit Notepad, and double-click on internetFIX.reg and confirm the prompts.
Then, restart your computer.
Let me know if this works or not to make the browsers work better.
Posts Posts : 13810
Post by Thebeast28 on 23rd January 2010, 8:35 pm
My computer is still slow but not as slow as it was. Like when i go to start then click on my computer it still takes awhile to load up. It don't just load right up when i open it up That goes with every program. I still can't use Firefox Why? it opens up but want load up my homepage. I have to use Internet Explorer. It loads up but is slow and freezes up from time to time. I have hughes net satellite and it is suppose to be fast and is not. It takes awhile to load up internet. Is that cause my computer is slow? Why don't my programs open right up? It is faster then it was but they still don't open right up they have to load up and freeze up sometimes but not like it use to where i have to wait forever for it to unfreeze.
Thebeast28
Posts Posts : 159
Post by Dr Jay on 24th January 2010, 1:33 am
Seems like you still have a rootkit.
Please download the [You must be registered and logged in to see this link.]. Unzip it to your Desktop.
Before scanning, make sure all other running programs are closed and no other actions like a scheduled antivirus scan will occur while the scan is being performed. Do not use your computer for anything else during the scan.
Double-click gmer.exe. The program will begin to run.
**Caution**
These types of scans can produce false positives. Do NOT take any action on any
"<--- ROOKIT" entries unless advised!
If possible rootkit activity is found, you will be asked if you would like to perform a full scan.
  • Click NO
  • In the right panel, you will see a bunch of boxes that have been checked ... leave everything checked and ensure the Show all box is un-checked.
  • Now click the Scan button.
    Once the scan is complete, you may receive another notice about rootkit activity.
  • Click OK.
  • GMER will produce a log. Click on the [Save..] button, and in the File name area, type in "GMER.txt"
  • Save it where you can easily find it, such as your desktop.
Post the contents of GMER.txt in your next reply.
Posts Posts : 13810
Post by Thebeast28 on 25th January 2010, 5:08 am
GMER 1.0.15.15281 - [You must be registered and logged in to see this link.]
Rootkit scan 2010-01-24 20:13:32
Running: gmer.exe; Driver: C:\DOCUME~1\JONATH~1\LOCALS~1\Temp\fwrcypoc.sys
---- System - GMER 1.0.15 ----
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwCreateKey [0xF729AE52]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwCreateProcess [0xF727BCDE]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwCreateProcessEx [0xF727BED0]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwDeleteKey [0xF729B640]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwDeleteValueKey [0xF729B8F4]
SSDT speh.sys ZwEnumerateKey [0xF7387CA2]
SSDT speh.sys ZwEnumerateValueKey [0xF7388030]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwOpenKey [0xF7299B44]
SSDT \??\C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys (IDS Application Activity Monitor Loader Driver./AVG Technologies ) ZwOpenProcess [0xF77E8470]
SSDT speh.sys ZwQueryKey [0xF7388108]
SSDT speh.sys ZwQueryValueKey [0xF7387F88]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwRenameKey [0xF729BD60]
SSDT PCTCore.sys (PC Tools KDS Core Driver/PC Tools) ZwSetValueKey [0xF729B112]
SSDT \??\C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys (IDS Application Activity Monitor Loader Driver./AVG Technologies ) ZwTerminateProcess [0xF77E8520]
SSDT \??\C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys (IDS Application Activity Monitor Loader Driver./AVG Technologies ) ZwTerminateThread [0xF77E85C0]
SSDT \??\C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys (IDS Application Activity Monitor Loader Driver./AVG Technologies ) ZwWriteVirtualMemory [0xF77E8660]
INT 0x62 ? 8639DBF8
INT 0x73 ? 85FDABF8
INT 0x82 ? 8639DBF8
---- Kernel code sections - GMER 1.0.15 ----
? speh.sys The system cannot find the file specified. !
.text USBPORT.SYS!DllUnload F68CD8AC 5 Bytes JMP 85FDA1D8
.text aslhv33q.SYS F6645384 1 Byte [20]
.text aslhv33q.SYS F6645384 37 Bytes [20, 00, 00, 68, 00, 00, 00, ...]
.text aslhv33q.SYS F66453AA 24 Bytes [00, 00, 20, 00, 00, E0, 00, ...]
.text aslhv33q.SYS F66453C4 3 Bytes [00, 00, 00]
.text aslhv33q.SYS F66453C9 1 Byte [00]
.text ...
---- User code sections - GMER 1.0.15 ----
.text C:\Program Files\Webroot\Washer\wwDisp.exe[208] kernel32.dll!CreateThread + 1A 7C8106F1 4 Bytes CALL 0008F305 C:\Program Files\Webroot\Washer\wwDisp.exe (Window Washer Client Executable/Webroot Software, Inc.)
.text C:\WINDOWS\Explorer.EXE[1180] SHELL32.dll!SHFileOperationW 7CA70924 5 Bytes JMP 021A1102 C:\Program Files\Unlocker\UnlockerHook.dll
---- Kernel IAT/EAT - GMER 1.0.15 ----
IAT \WINDOWS\System32\Drivers\SCSIPORT.SYS[ntoskrnl.exe!DbgBreakPoint] 8639F2D8
IAT pci.sys[ntoskrnl.exe!IoDetachDevice] [F739A93C] speh.sys
IAT pci.sys[ntoskrnl.exe!IoAttachDeviceToDeviceStack] [F739A990] speh.sys
IAT atapi.sys[HAL.dll!READ_PORT_UCHAR] [F736B040] speh.sys
IAT atapi.sys[HAL.dll!READ_PORT_BUFFER_USHORT] [F736B13C] speh.sys
IAT atapi.sys[HAL.dll!READ_PORT_USHORT] [F736B0BE] speh.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_BUFFER_USHORT] [F736B7FC] speh.sys
IAT atapi.sys[HAL.dll!WRITE_PORT_UCHAR] [F736B6D2] speh.sys
IAT \SystemRoot\System32\DRIVERS\i8042prt.sys[HAL.dll!READ_PORT_UCHAR] [F737AD92] speh.sys
IAT \SystemRoot\System32\DRIVERS\USBPORT.SYS[ntoskrnl.exe!DbgBreakPoint] 85FDA2D8
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlInitUnicodeString] 000000A5
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!swprintf] 000000E5
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeSetEvent] 000000F1
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoCreateSymbolicLink] 00000071
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoGetConfigurationInformation] 000000D8
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoDeleteSymbolicLink] 00000031
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmFreeMappingAddress] 00000015
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoFreeErrorLogEntry] 00000004
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoDisconnectInterrupt] 000000C7
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmUnmapIoSpace] 00000023
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ObReferenceObjectByPointer] 000000C3
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IofCompleteRequest] 00000018
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlCompareUnicodeString] 00000096
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IofCallDriver] 00000005
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmAllocateMappingAddress] 0000009A
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAllocateErrorLogEntry] 00000007
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoConnectInterrupt] 00000012
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoDetachDevice] 00000080
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeWaitForSingleObject] 000000E2
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInitializeEvent] 000000EB
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeCancelTimer] 00000027
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlAnsiStringToUnicodeString] 000000B2
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlInitAnsiString] 00000075
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoBuildDeviceIoControlRequest] 00000009
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoQueueWorkItem] 00000083
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmMapIoSpace] 0000002C
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoInvalidateDeviceRelations] 0000001A
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoReportDetectedDevice] 0000001B
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoReportResourceForDetection] 0000006E
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlxAnsiStringToUnicodeSize] 0000005A
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!NlsMbCodePageTag] 000000A0
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!PoRequestPowerIrp] 00000052
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInsertByKeyDeviceQueue] 0000003B
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!PoRegisterDeviceForIdleDetection] 000000D6
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!sprintf] 000000B3
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmMapLockedPagesSpecifyCache] 00000029
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ObfDereferenceObject] 000000E3
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoGetAttachedDeviceReference] 0000002F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoInvalidateDeviceState] 00000084
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ZwClose] 00000053
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ObReferenceObjectByHandle] 000000D1
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ZwCreateDirectoryObject] 00000000
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoBuildSynchronousFsdRequest] 000000ED
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!PoStartNextPowerIrp] 00000020
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoCreateDevice] 000000FC
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlCopyUnicodeString] 000000B1
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAllocateDriverObjectExtension] 0000005B
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlQueryRegistryValues] 0000006A
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ZwOpenKey] 000000CB
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlFreeUnicodeString] 000000BE
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoStartTimer] 00000039
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInitializeTimer] 0000004A
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoInitializeTimer] 0000004C
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInitializeDpc] 00000058
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInitializeSpinLock] 000000CF
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoInitializeIrp] 000000D0
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ZwCreateKey] 000000EF
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlAppendUnicodeStringToString] 000000AA
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlIntegerToUnicodeString] 000000FB
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ZwSetValueKey] 00000043
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeInsertQueueDpc] 0000004D
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KefAcquireSpinLockAtDpcLevel] 00000033
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoStartPacket] 00000085
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KefReleaseSpinLockFromDpcLevel] 00000045
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoBuildAsynchronousFsdRequest] 000000F9
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoFreeMdl] 00000002
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmUnlockPages] 0000007F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoWriteErrorLogEntry] 00000050
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeRemoveByKeyDeviceQueue] 0000003C
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmMapLockedPagesWithReservedMapping] 0000009F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmUnmapReservedMapping] 000000A8
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeSynchronizeExecution] 00000051
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoStartNextPacket] 000000A3
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeBugCheckEx] 00000040
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeRemoveDeviceQueue] 0000008F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeSetTimer] 00000092
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!_allmul] 0000009D
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmProbeAndLockPages] 00000038
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!_except_handler3] 000000F5
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!PoSetPowerState] 000000BC
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoOpenDeviceRegistryKey] 000000B6
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlWriteRegistryValue] 000000DA
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlDeleteRegistryValue] 00000021
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!_aulldiv] 00000010
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!strstr] 000000FF
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!_strupr] 000000F3
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeQuerySystemTime] 000000D2
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoWMIRegistrationControl] 000000CD
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!KeTickCount] 0000000C
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAttachDeviceToDeviceStack] 00000013
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoDeleteDevice] 000000EC
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ExAllocatePoolWithTag] 0000005F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAllocateWorkItem] 00000097
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAllocateIrp] 00000044
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoAllocateMdl] 00000017
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmBuildMdlForNonPagedPool] 000000C4
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmLockPagableDataSection] 000000A7
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoGetDriverObjectExtension] 0000007E
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmUnlockPagableImageSection] 0000003D
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!ExFreePoolWithTag] 00000064
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoFreeIrp] 0000005D
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!IoFreeWorkItem] 00000019
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!InitSafeBootMode] 00000073
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!RtlCompareMemory] 00000060
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!PoCallDriver] 00000081
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!memmove] 0000004F
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[ntoskrnl.exe!MmHighestUserAddress] 000000DC
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KfAcquireSpinLock] 000000AD
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!READ_PORT_UCHAR] 000000D4
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KeGetCurrentIrql] 000000A2
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KfRaiseIrql] 000000AF
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KfLowerIrql] 0000009C
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!HalGetInterruptVector] 000000A4
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!HalTranslateBusAddress] 00000072
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KeStallExecutionProcessor] 000000C0
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!KfReleaseSpinLock] 000000B7
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!READ_PORT_BUFFER_USHORT] 000000FD
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!READ_PORT_USHORT] 00000093
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!WRITE_PORT_BUFFER_USHORT] 00000026
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[HAL.dll!WRITE_PORT_UCHAR] 00000036
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[WMILIB.SYS!WmiSystemControl] 000000F7
IAT \SystemRoot\System32\Drivers\aslhv33q.SYS[WMILIB.SYS!WmiCompleteRequest] 000000CC
---- User IAT/EAT - GMER 1.0.15 ----
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\ADVAPI32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\ADVAPI32.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\RPCRT4.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\RPCRT4.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\Secur32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\Secur32.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\MSVCRT.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\MSVCRT.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\ole32.dll [KERNEL32.dll!LoadLibraryA] [6BFA9979] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
IAT C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe[1500] @ C:\WINDOWS\system32\ole32.dll [KERNEL32.dll!SetUnhandledExceptionFilter] [6BFA9A27] C:\Program Files\Common Files\AOL\AOLDiag\tbdiag.dll (AOL Diagnostics/AOL LLC)
Device \FileSystem\Ntfs \Ntfs 8639C1F8
AttachedDevice \FileSystem\Ntfs \Ntfs AVGIDSFilter.sys (IDS Application Activity Monitor Filter Driver./AVG Technologies )
Device \FileSystem\Fastfat \FatCdrom 85ACA500
AttachedDevice \Driver\Tcpip \Device\Ip avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
Device \Driver\usbohci \Device\USBPDO-0 85FD91F8
Device \Driver\NetBT \Device\NetBT_Tcpip_{B55CF78A-CC5E-4CB4-BCA7-E07164A7A945} 85A5B500
Device \Driver\usbohci \Device\USBPDO-1 85FD91F8
Device \Driver\NetBT \Device\NetBT_Tcpip_{6322E818-AA14-4603-83D6-F456D22835CA} 85A5B500
AttachedDevice \Driver\Tcpip \Device\Tcp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
Device \Driver\Ftdisk \Device\HarddiskVolume1 8640D1F8
Device \Driver\Cdrom \Device\CdRom0 85FAE1F8
Device \Driver\Cdrom \Device\CdRom1 85FAE1F8
Device \Driver\atapi \Device\Ide\IdeDeviceP1T1L0-17 [F72C4B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
Device \Driver\atapi \Device\Ide\IdePort0 [F72C4B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
Device \Driver\atapi \Device\Ide\IdeDeviceP0T0L0-3 [F72C4B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
Device \Driver\atapi \Device\Ide\IdePort1 [F72C4B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
Device \Driver\atapi \Device\Ide\IdeDeviceP1T0L0-f [F72C4B40] atapi.sys[unknown section] {MOV EDX, [ESP+0x8]; LEA ECX, [ESP+0x4]; PUSH EAX; MOV EAX, ESP; PUSH EAX}
Device \Driver\Cdrom \Device\CdRom2 85FAE1F8
Device \Driver\NetBT \Device\NetBt_Wins_Export 85A5B500
Device \Driver\NetBT \Device\NetbiosSmb 85A5B500
Device \Driver\PCI_PNP4046 \Device\0000005b speh.sys
AttachedDevice \Driver\Tcpip \Device\Udp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
AttachedDevice \Driver\Tcpip \Device\RawIp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
Device \Driver\NetBT \Device\NetBT_Tcpip_{CB8F768E-CF4D-4E38-A96D-8B74D6A7078E} 85A5B500
Device \Driver\usbohci \Device\USBFDO-0 85FD91F8
Device \Driver\usbohci \Device\USBFDO-1 85FD91F8
Device \Driver\sptd \Device\220871546 speh.sys
Device \FileSystem\MRxSmb \Device\LanmanDatagramReceiver 85B0F500
Device \FileSystem\MRxSmb \Device\LanmanRedirector 85B0F500
Device \Driver\Ftdisk \Device\FtControl 8640D1F8
Device \Driver\USBSTOR \Device\0000007e 859651F8
Device \Driver\USBSTOR \Device\0000007f 859651F8
Device \Driver\aslhv33q \Device\Scsi\aslhv33q1 85D2F1F8
Device \Driver\aslhv33q \Device\Scsi\aslhv33q1Port2Path0Target0Lun0 85D2F1F8
Device \FileSystem\Fastfat \Fat 85ACA500
AttachedDevice \FileSystem\Fastfat \Fat fltmgr.sys (Microsoft Filesystem Filter Manager/Microsoft Corporation)
AttachedDevice \FileSystem\Fastfat \Fat AVGIDSFilter.sys (IDS Application Activity Monitor Filter Driver./AVG Technologies )
Device \FileSystem\Cdfs \Cdfs 85AAD500
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet001\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s1 771343423
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@s2 285507792
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg@h0 1
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40
Reg HKLM\SYSTEM\CurrentControlSet\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet003\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet004\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet005\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet006\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@p0 C:\Program Files\Alcohol Soft\Alcohol 120\
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@h0 0
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04@ujdew 0x16 0x1C 0x31 0xF9 ...
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@a0 0x20 0x01 0x00 0x00 ...
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001@ujdew 0x1B 0x11 0xAD 0x40 ...
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40 (not active ControlSet)
Reg HKLM\SYSTEM\ControlSet007\Services\sptd\Cfg\0D79C293C1ED61418462E24595C90D04\00000001\jdgg40@ujdew 0x4B 0xC6 0x4A 0x03 ...
---- EOF - GMER 1.0.15 ----
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
Post by Dr Jay on 25th January 2010, 4:37 pm
    :filefind
    ntoskrnl.exe
    aslhv33q.SYS
    speh.sys
    atapi.sys
Posts Posts : 13810
Points Points : 302437
Post by Thebeast28 on 26th January 2010, 2:58 am
SystemLook v1.0 by jpshortstuff (11.01.10)
Log created at 20:54 on 25/01/2010 by Jonathan Murray (Administrator - Elevation successful)
Searching for "ntoskrnl.exe"
C:\WINDOWS\$hf_mig$\KB840987\SP1QFE\ntoskrnl.exe --a--- 2051584 bytes [17:22 17/06/2004] [17:22 17/06/2004] F240DC474F8EDB2D95514D831DF069E5
C:\WINDOWS\$hf_mig$\KB914882\SP2QFE\ntoskrnl.exe --a--- 2180992 bytes [01:19 29/05/2008] [04:01 21/02/2006] DF4D09B676964646FA166A78C816B4C3
C:\WINDOWS\$hf_mig$\KB929338\SP2QFE\ntoskrnl.exe --a--- 2182016 bytes [16:51 19/12/2006] [16:51 19/12/2006] CEF243F6DEFD20BE4ADDE26C7ECACB54
C:\WINDOWS\$hf_mig$\KB931784\SP2QFE\ntoskrnl.exe --a--- 2182144 bytes [09:55 28/02/2007] [09:55 28/02/2007] 5A5C8DB4AA962C714C8371FBDF189FC9
C:\WINDOWS\$hf_mig$\KB956572\SP2QFE\ntoskrnl.exe --a--- 2186112 bytes [23:50 14/04/2009] [10:32 06/02/2009] 6A936E9D7BADAF3CAAEED1E1966EC1B0
C:\WINDOWS\$hf_mig$\KB956572\SP3GDR\ntoskrnl.exe --a--- 2189056 bytes [23:50 14/04/2009] [11:08 06/02/2009] 7A95B10A73737EBF24139AAA63F5212B
C:\WINDOWS\$hf_mig$\KB956572\SP3QFE\ntoskrnl.exe --a--- 2189184 bytes [23:35 07/02/2009] [23:35 07/02/2009] EFE8EACE83EAAD5849A7A548FB75B584
C:\WINDOWS\$hf_mig$\KB956841\SP2QFE\ntoskrnl.exe --a--- 2185984 bytes [23:47 14/10/2008] [09:57 14/08/2008] CE69DBD54221F2D40E49FF6DB77C6507
C:\WINDOWS\$hf_mig$\KB956841\SP3GDR\ntoskrnl.exe --a--- 2189184 bytes [23:47 14/10/2008] [10:11 14/08/2008] EEAF32F8E15A24F62BECB1BD403BB5C5
C:\WINDOWS\$hf_mig$\KB956841\SP3QFE\ntoskrnl.exe --a--- 2189184 bytes [20:11 14/08/2008] [20:11 14/08/2008] 31914172342BFF330063F343AC6958FE
C:\WINDOWS\$hf_mig$\KB971486\SP2QFE\ntoskrnl.exe --a--- 2185984 bytes [19:00 13/10/2009] [12:51 04/08/2009] 8DF112C341425F29DB4566B8D2A96A7F
C:\WINDOWS\$hf_mig$\KB971486\SP3GDR\ntoskrnl.exe --a--- 2189184 bytes [00:44 05/08/2009] [00:44 05/08/2009] 8415D9C7C050E7022AED8ABF281BE4A6
C:\WINDOWS\$hf_mig$\KB971486\SP3QFE\ntoskrnl.exe --a--- 2189312 bytes [19:00 13/10/2009] [13:56 04/08/2009] FDE779EA1A564EBFE16F4E0F82B61BAD
C:\WINDOWS\$NtServicePackUninstall$\ntoskrnl.exe -----c 2180352 bytes [05:41 05/11/2009] [14:00 04/08/2009] D6B537A639D623ED85B73AF3E3BE4B94
C:\WINDOWS\$NtUninstallKB840987$\ntoskrnl.exe --a--c 1879936 bytes [23:33 01/11/2004] [22:08 12/12/2002] DB499BE143D626FC8778BE7E18185EB3
C:\WINDOWS\$NtUninstallKB929338$\ntoskrnl.exe -----c 2179328 bytes [03:23 28/03/2007] [00:59 02/03/2005] 4D4CF2C14550A4B7718E94A6E581856E
C:\WINDOWS\$NtUninstallKB931784$\ntoskrnl.exe -----c 2180352 bytes [02:40 07/05/2007] [14:17 19/12/2006] 8F0DEAB1F81FB83F9C5995853CE48B9F
C:\WINDOWS\$NtUninstallKB956572$\ntoskrnl.exe -----c 2188928 bytes [06:13 05/11/2009] [19:27 13/04/2008] 0C89243C7C3EE199B96FCC16990E0679
C:\WINDOWS\$NtUninstallKB956572_0$\ntoskrnl.exe -----c 2180352 bytes [17:38 15/04/2009] [10:00 14/08/2008] 21C91DA9CB53AA8A37041BA9684A8458
C:\WINDOWS\$NtUninstallKB956841_0$\ntoskrnl.exe -----c 2180352 bytes [03:05 15/10/2008] [09:10 28/02/2007] 582A8DBAA58C3B1F176EB2817DAEE77C
C:\WINDOWS\$NtUninstallKB971486$\ntoskrnl.exe -----c 2189056 bytes [06:24 05/11/2009] [11:08 06/02/2009] 7A95B10A73737EBF24139AAA63F5212B
C:\WINDOWS\$NtUninstallKB971486_0$\ntoskrnl.exe -----c 2180480 bytes [03:07 14/10/2009] [17:24 06/02/2009] FACEBB0CA3154F77009CDFEE78A00BBB
C:\WINDOWS\$NtUninstallQ811493$\ntoskrnl.exe --a--c 1982208 bytes [14:31 16/10/2004] [06:24 18/08/2001] A29222D5281056E497408FCC9062F749
C:\WINDOWS\$xpsp1hfm$\Q811493\ntoskrnl.exe --a--c 1925760 bytes [14:30 16/10/2004] [12:57 24/04/2003] 97EC4AB4650DA6FC521CF16F8A6DDCB0
C:\WINDOWS\Driver Cache\i386\ntoskrnl.exe ------ 2189184 bytes [23:50 14/04/2009] [00:44 05/08/2009] 8415D9C7C050E7022AED8ABF281BE4A6
C:\WINDOWS\ERDNT\cache\ntoskrnl.exe --a--- 2189184 bytes [21:59 13/01/2010] [00:44 05/08/2009] 8415D9C7C050E7022AED8ABF281BE4A6
C:\WINDOWS\ServicePackFiles\i386\ntoskrnl.exe ------ 2188928 bytes [16:25 06/04/2006] [19:27 13/04/2008] 0C89243C7C3EE199B96FCC16990E0679
C:\WINDOWS\system32\dllcache\ntoskrnl.exe -----c 2189184 bytes [23:50 14/04/2009] [00:44 05/08/2009] 8415D9C7C050E7022AED8ABF281BE4A6
C:\WINDOWS\system32\ntoskrnl.exe ------ 2189184 bytes [12:00 08/11/2003] [00:44 05/08/2009] 8415D9C7C050E7022AED8ABF281BE4A6
Searching for "aslhv33q.SYS"
No files found.
Searching for "speh.sys"
No files found.
Searching for "atapi.sys"
C:\WINDOWS\$NtServicePackUninstall$\atapi.sys -----c 95360 bytes [05:42 05/11/2009] [02:59 04/08/2004] CDFE4411A69C224BD1D11B2DA92DAC51
C:\WINDOWS\$NtUninstallQ306583$\atapi.sys --a--- 86656 bytes [22:30 23/03/2004] [21:51 17/08/2001] A64013E98426E1877CB653685C5C0009
C:\WINDOWS\ERDNT\cache\atapi.sys --a--- 96512 bytes [21:59 13/01/2010] [18:40 13/04/2008] 9F3A2F5AA6875C72BF062C712CFA2674
C:\WINDOWS\ServicePackFiles\i386\atapi.sys ------ 96512 bytes [16:26 06/04/2006] [18:40 13/04/2008] 9F3A2F5AA6875C72BF062C712CFA2674
C:\WINDOWS\system32\drivers\atapi.sys ------ 96512 bytes [12:00 08/11/2003] [18:40 13/04/2008] 9F3A2F5AA6875C72BF062C712CFA2674
-=End Of File=-
Thebeast28
Posts Posts : 159
Post by Dr Jay on 26th January 2010, 3:49 am
Please go [You must be registered and logged in to see this link.]. Copy and paste the following file path in to the box.
Do the same for these two files:
C:\windows\system32\userinit.exe
Then click submit.
Please post the results (URL) to your next reply.
Note: re-scan the file. Do not get the past analysis.
Posts Posts : 13810
Post by Thebeast28 on 27th January 2010, 3:44 am
Srpski | Македонски | العربية | Suomi | ihMdI | | עברית | | Slovenščina | Dansk | Русский | Română | Türkçe | Nederlands | Ελληνικά | Français | Svenska | Português | Italiano | | | Magyar | Deutsch | Česky | Polski | Español
Virus Total
Virustotal is a service that analyzes suspicious files and facilitates the quick detection of viruses, worms, trojans, and all kinds of malware detected by antivirus engines. More information...
File ntoskrnl.exe received on 2010.01.27 02:13:04 (UTC)
Current status: Loading ... queued waiting scanning finished NOT FOUND STOPPED
Result: 0/40 (0%)
Loading server information...
Your file is queued in position: ___.
Estimated start time is between ___ and ___ .
Do not close the window until scan is complete.
The scanner that was processing your file is stopped at this moment, we are going to wait a few seconds to try to recover your result.
If you are waiting for more than five minutes you have to resend your file.
Your file is being scanned by VirusTotal in this moment,
results will be shown as they're generated.
Compact Compact
Print results Print results
Your file has expired or does not exists.
Service is stopped in this moments, your file is waiting to be scanned (position: ) for an undefined time.
You can wait for web response (automatic reload) or type your email in the form below and click "request" so the system sends you a notification when the scan is finished.
Email:
Antivirus Version Last Update Result
a-squared 4.5.0.50 2010.01.27 -
AhnLab-V3 5.0.0.2 2010.01.26 -
AntiVir 7.9.1.150 2010.01.26 -
Antiy-AVL 2.0.3.7 2010.01.26 -
Authentium 5.2.0.5 2010.01.27 -
Avast 4.8.1351.0 2010.01.26 -
AVG 9.0.0.730 2010.01.26 -
BitDefender 7.2 2010.01.27 -
CAT-QuickHeal 10.00 2010.01.25 -
ClamAV 0.94.1 2010.01.26 -
Comodo 3719 2010.01.26 -
DrWeb 5.0.1.12222 2010.01.27 -
eSafe 7.0.17.0 2010.01.26 -
eTrust-Vet 35.2.7262 2010.01.26 -
F-Prot 4.5.1.85 2010.01.26 -
F-Secure 9.0.15370.0 2010.01.27 -
Fortinet 4.0.14.0 2010.01.26 -
GData 19 2010.01.27 -
Ikarus T3.1.1.80.0 2010.01.27 -
Jiangmin 13.0.900 2010.01.26 -
K7AntiVirus 7.10.957 2010.01.26 -
Kaspersky 7.0.0.125 2010.01.27 -
McAfee 5873 2010.01.26 -
McAfee+Artemis 5873 2010.01.26 -
McAfee-GW-Edition 6.8.5 2010.01.27 -
Microsoft 1.5406 2010.01.27 -
NOD32 4808 2010.01.26 -
Norman 6.04.03 2010.01.26 -
nProtect 2009.1.8.0 2010.01.26 -
Panda 10.0.2.2 2010.01.26 -
PCTools 7.0.3.5 2010.01.27 -
Rising 22.32.02.01 2010.01.27 -
Sophos 4.50.0 2010.01.27 -
Sunbelt 3.2.1858.2 2010.01.27 -
Symantec 20091.2.0.41 2010.01.27 -
TheHacker 6.5.0.9.165 2010.01.27 -
TrendMicro 9.120.0.1004 2010.01.26 -
VBA32 3.12.12.1 2010.01.26 -
ViRobot 2010.1.26.2156 2010.01.26 -
VirusBuster 5.0.21.0 2010.01.26 -
Additional information
File size: 2189184 bytes
MD5...: 8415d9c7c050e7022aed8abf281be4a6
SHA1..: e65c2d02a59e46a8f0ce546edcb1681d914723a0
SHA256: c24359d6adc63a86de17f2029dbc0562ae420aed44554c290784ffbc554a1e8e
ssdeep: 24576:UgWyem2gqH4DOHMs65BCtm6Zc9NcoVI9b4GiXY8ACc7XHgQCI+E9IoeAKp
r9q97c:jAm2Lq58MCo7n7qgt0K1TVv
PEiD..: -
PEInfo: PE Structure information
( base data )
entrypointaddress.: 0x22c0
timedatestamp.....: 0x45665e64 (Fri Nov 24 02:52:20 2006)
machinetype.......: 0x14c (I386)
( 4 sections )
name viradd virsiz rawdsiz ntrpy md5
.text 0x1000 0x52150 0x52200 0.24 98d68cb0e4b7d1e2e7334dfe531532a2
.rdata 0x54000 0x27a 0x400 3.59 6af562d60151e9a0168453115d732018
.data 0x55000 0xcb700 0xcb800 7.18 e77379261f640943c5bb3f9dd41cdde8
.rsrc 0x121000 0x2780 0x2800 4.44 0d5268eb0a7801ae414ece54d4a212bd
( 1 imports )
> KERNEL32.dll: GetCurrentProcess, GetTickCount, GetVersion, GetCurrentThreadId, GetModuleHandleA, GetCommandLineA, GetLastError, GetCurrentProcessId, GetCurrentThread, GetCommandLineW, HeapAlloc, GetProcessHeap, GetSystemDefaultLangID, GetACP, GetFileType, FindFirstFileA, HeapDestroy, GetOEMCP, WaitForSingleObject, GetCPInfo, CreateProcessW, SetFileAttributesA
( 0 exports )
RDS...: NSRL Reference Data Set
pdfid.: -
sigcheck:
publisher....: Microsoft Corporation
copyright....: (c) Microsoft Corporation. All rights reserved.
product......: Microsoft_ Windows_ Operating System
description..: NT Kernel _ System
original name: ntoskrnl.exe
internal name: ntoskrnl.exe
file version.: 5.1.2600.5857 (xpsp_sp3_gdr.090804-1435)
comments.....: n/a
signers......: -
signing date.: -
verified.....: Unsigned
trid..: OS/2 Executable (generic) (52.8%)
Win32 Executable Generic (32.0%)
Generic Win/DOS Executable (7.5%)
DOS Executable Generic (7.5%)
Autodesk FLIC Image File (extensions: flc, fli, cel) (0.0%)
ATENTION ATTENTION: VirusTotal is a free service offered by Hispasec Sistemas. There are no guarantees about the availability and continuity of this service. Although the detection rate afforded by the use of multiple antivirus engines is far superior to that offered by just one product, these results DO NOT guarantee the harmlessness of a file. Currently, there is not any solution that offers a 100% effectiveness rate for detecting viruses and malware.
Scan another file
VirusTotal © Hispasec Sistemas - Blog - Contact: [You must be registered and logged in to see this link.] - Terms of Service & Privacy Policy
Virus Total
File userinit.exe received on 2010.01.27 02:18:19 (UTC)
Result: 0/41 (0%)
Compact Compact
Email:
Prevx 3.0 2010.01.27 -
File size: 26112 bytes
MD5...: a93aee1928a9d7ce3e16d24ec7380f89
SHA1..: 513f8bdf67a5a9e09803cfb61f590b39f2683853
SHA256: 944cd2135e171af338352568aa7fe1b8004733a4281395ad6723e0cf43d5f53f
ssdeep: 768:0RMJi8jDLIDSAaQFxfftjaLacmkLGKOq:0RMJbDMDSA7FxffJaLaSLG9q
PEiD..: -
( base data )
entrypointaddress.: 0x54ad
timedatestamp.....: 0x480251a8 (Sun Apr 13 18:32:08 2008)
( 3 sections )
.text 0x1000 0x520e 0x5400 5.95 099b53205ad3f1c3b853a5310d08a9b1
.data 0x7000 0x14c 0x200 1.86 0bb948f267e82975313a03d8c0e8a1cf
.rsrc 0x8000 0xb50 0xc00 3.27 bac832e39f87c4f5f640e5d5c6a1c2fc
( 9 imports )
> USER32.dll: CreateWindowExW, DestroyWindow, RegisterClassExW, DefWindowProcW, LoadRemoteFonts, wsprintfW, GetSystemMetrics, GetKeyboardLayout, SystemParametersInfoW, GetDesktopWindow, LoadStringW, MessageBoxW, ExitWindowsEx, CharNextW
> ADVAPI32.dll: RegOpenKeyExA, ReportEventW, RegisterEventSourceW, DeregisterEventSource, OpenProcessToken, RegCreateKeyExW, RegSetValueExW, GetUserNameW, RegQueryValueExW, RegOpenKeyExW, RegQueryInfoKeyW, RegCloseKey, RegQueryValueExA
> CRYPT32.dll: CryptProtectData
> WINSPOOL.DRV: SpoolerInit
> ntdll.dll: RtlLengthSid, RtlCopySid, _itow, RtlFreeUnicodeString, DbgPrint, wcslen, wcscpy, wcscat, wcscmp, RtlInitUnicodeString, NtOpenKey, NtClose, _wcsicmp, memmove, RtlConvertSidToUnicodeString, NtQueryInformationToken
> NETAPI32.dll: DsGetDcNameW, NetApiBufferFree
> WLDAP32.dll: -, -, -, -, -, -
> msvcrt.dll: __setusermatherr, _initterm, __getmainargs, _acmdln, _adjust_fdiv, _XcptFilter, _exit, _c_exit, __p__commode, __p__fmode, __set_app_type, _except_handler3, _controlfp, _cexit, exit
> KERNEL32.dll: CompareFileTime, LoadLibraryW, GetProcAddress, FreeLibrary, lstrcpyW, CreateProcessW, lstrlenW, GetVersionExW, LocalFree, LocalAlloc, GetEnvironmentVariableW, CloseHandle, lstrcatW, WaitForSingleObject, DelayLoadFailureHook, GetStartupInfoA, GetModuleHandleA, SetUnhandledExceptionFilter, UnhandledExceptionFilter, TerminateProcess, GetSystemTimeAsFileTime, GetCurrentThreadId, GetTickCount, QueryPerformanceCounter, LoadLibraryA, InterlockedCompareExchange, LocalReAlloc, GetSystemTime, lstrcmpW, GetCurrentThread, SetThreadPriority, ExpandEnvironmentStringsW, SearchPathW, GetLastError, CreateThread, GetFileAttributesExW, GetSystemDirectoryW, SetCurrentDirectoryW, FormatMessageW, lstrcmpiW, GetCurrentProcess, GetUserDefaultLangID, GetCurrentProcessId, SetEvent, OpenEventW, Sleep, SetEnvironmentVariableW
( 0 exports )
pdfid.: -
trid..: Win32 Executable MS Visual C++ (generic) (65.2%)
Win32 Executable Generic (14.7%)
Win32 Dynamic Link Library (generic) (13.1%)
Generic Win/DOS Executable (3.4%)
DOS Executable Generic (3.4%)
sigcheck:
description..: Userinit Logon Application
original name: USERINIT.EXE
internal name: userinit
file version.: 5.1.2600.5512 (xpsp.080413-2113)
comments.....: n/a
signers......: -
signing date.: -
Scan another file
_:
a:
Amazon
d:
Download Squad
f:
Facebook
g:
Digg
l:
Lifehacker
m:
Mashable
n:
NYTimes
r:
ReadWriteWeb
s:
MySpace
u:
YouTube
w:
Wikipedia
VirusTotal - Free Online Virus and Malware Scan - Result
File atapi.sys received on 2010.01.27 02:21:02 (UTC)
Result: 1/40 (2.5%)
Compact Compact
Email:
eSafe 7.0.17.0 2010.01.26 Win32.Rootkit
File size: 96512 bytes
MD5...: 9f3a2f5aa6875c72bf062c712cfa2674
SHA1..: a719156e8ad67456556a02c34e762944234e7a44
SHA256: b4df1d2c56a593c6b54de57395e3b51d288f547842893b32b0f59228a0cf70b9
ssdeep: 1536:MwXpkfV74F1D7yNEZIHRRJMohmus27G1j/XBoDQi7oaRMJfYHFktprll1Kb
DD0uu:MQ+N74vkEZIxMohjsimBoDTRMBwFktZu
PEiD..: -
( base data )
entrypointaddress.: 0x159f7
timedatestamp.....: 0x4802539d (Sun Apr 13 18:40:29 2008)
( 9 sections )
.text 0x380 0x97ba 0x9800 6.45 0d7d81391f33c6450a81be1e3ac8c7b7
NONPAGE 0x9b80 0x18e8 0x1900 6.48 c74a833abd81cc5d037de168e055ad29
.rdata 0xb480 0xa64 0xa80 4.31 8523651899e28819a14bf9415af25708
.data 0xbf00 0xd94 0xe00 0.45 3575b51634ae7a56f55f1ee0a6213834
PAGESCAN 0xcd00 0x157f 0x1580 6.20 dc4c309c4db9576daa752fdd125fccf9
PAGE 0xe280 0x61da 0x6200 6.46 40b83d4d552384e58a03517a98eb4863
INIT 0x14480 0x22be 0x2300 6.47 906462abc478368424ea462d5868d2e3
.rsrc 0x16780 0x3e0 0x400 3.36 8fd2d82e745b289c28bc056d3a0d62ab
.reloc 0x16b80 0xd20 0xd80 6.39 ce2b0898cc0e40b618e5df9099f6be45
( 3 imports )
> ntoskrnl.exe: RtlInitUnicodeString, swprintf, KeSetEvent, IoCreateSymbolicLink, IoGetConfigurationInformation, IoDeleteSymbolicLink, MmFreeMappingAddress, IoFreeErrorLogEntry, IoDisconnectInterrupt, MmUnmapIoSpace, ObReferenceObjectByPointer, IofCompleteRequest, RtlCompareUnicodeString, IofCallDriver, MmAllocateMappingAddress, IoAllocateErrorLogEntry, IoConnectInterrupt, IoDetachDevice, KeWaitForSingleObject, KeInitializeEvent, KeCancelTimer, RtlAnsiStringToUnicodeString, RtlInitAnsiString, IoBuildDeviceIoControlRequest, IoQueueWorkItem, MmMapIoSpace, IoInvalidateDeviceRelations, IoReportDetectedDevice, IoReportResourceForDetection, RtlxAnsiStringToUnicodeSize, NlsMbCodePageTag, PoRequestPowerIrp, KeInsertByKeyDeviceQueue, PoRegisterDeviceForIdleDetection, sprintf, MmMapLockedPagesSpecifyCache, ObfDereferenceObject, IoGetAttachedDeviceReference, IoInvalidateDeviceState, ZwClose, ObReferenceObjectByHandle, ZwCreateDirectoryObject, IoBuildSynchronousFsdRequest, PoStartNextPowerIrp, IoCreateDevice, RtlCopyUnicodeString, IoAllocateDriverObjectExtension, RtlQueryRegistryValues, ZwOpenKey, RtlFreeUnicodeString, IoStartTimer, KeInitializeTimer, IoInitializeTimer, KeInitializeDpc, KeInitializeSpinLock, IoInitializeIrp, ZwCreateKey, RtlAppendUnicodeStringToString, RtlIntegerToUnicodeString, ZwSetValueKey, KeInsertQueueDpc, KefAcquireSpinLockAtDpcLevel, IoStartPacket, KefReleaseSpinLockFromDpcLevel, IoBuildAsynchronousFsdRequest, IoFreeMdl, MmUnlockPages, IoWriteErrorLogEntry, KeRemoveByKeyDeviceQueue, MmMapLockedPagesWithReservedMapping, MmUnmapReservedMapping, KeSynchronizeExecution, IoStartNextPacket, KeBugCheckEx, KeRemoveDeviceQueue, KeSetTimer, _allmul, MmProbeAndLockPages, _except_handler3, PoSetPowerState, IoOpenDeviceRegistryKey, RtlWriteRegistryValue, RtlDeleteRegistryValue, _aulldiv, strstr, _strupr, KeQuerySystemTime, IoWMIRegistrationControl, KeTickCount, IoAttachDeviceToDeviceStack, IoDeleteDevice, ExAllocatePoolWithTag, IoAllocateWorkItem, IoAllocateIrp, IoAllocateMdl, MmBuildMdlForNonPagedPool, MmLockPagableDataSection, IoGetDriverObjectExtension, MmUnlockPagableImageSection, ExFreePoolWithTag, IoFreeIrp, IoFreeWorkItem, InitSafeBootMode, RtlCompareMemory, PoCallDriver, memmove, MmHighestUserAddress
> HAL.dll: KfAcquireSpinLock, READ_PORT_UCHAR, KeGetCurrentIrql, KfRaiseIrql, KfLowerIrql, HalGetInterruptVector, HalTranslateBusAddress, KeStallExecutionProcessor, KfReleaseSpinLock, READ_PORT_BUFFER_USHORT, READ_PORT_USHORT, WRITE_PORT_BUFFER_USHORT, WRITE_PORT_UCHAR
> WMILIB.SYS: WmiSystemControl, WmiCompleteRequest
( 0 exports )
pdfid.: -
trid..: Win32 Executable Generic (68.0%)
Generic Win/DOS Executable (15.9%)
DOS Executable Generic (15.9%)
sigcheck:
description..: IDE/ATAPI Port Driver
original name: atapi.sys
internal name: atapi.sys
file version.: 5.1.2600.5512 (xpsp.080413-2108)
comments.....: n/a
signers......: -
signing date.: -
packers (Kaspersky): PE_Patch
Thebeast28
Posts Posts : 159
Post by Dr Jay on 27th January 2010, 5:34 am
  1. Close any open browsers.
    FCopy::
    C:\WINDOWS\ServicePackFiles\i386\atapi.sys | C:\WINDOWS\system32\drivers\atapi.sys
Posts Posts : 13810
Post by Thebeast28 on 28th January 2010, 8:13 pm
Every time I drag CFScript into Combofix it says some installation files are currupt please dowload a fresh copy and retry the installation. I downloaded a new copy of Combofix and I drag CFScript into it and it still says the same thing. Why?
Thebeast28
Posts Posts : 159
Post by Dr Jay on 28th January 2010, 9:26 pm
Try to rename the download as blackpudding.bat
then try again.
Posts Posts : 13810
Post by Thebeast28 on 30th January 2010, 5:36 am
ComboFix 10-01-29.04 - Jonathan Murray 01/29/2010 19:20:02.2.1 - x86
Running from: C:\Documents and Settings\Jonathan Murray\Desktop\blackpudding.bat
Command switches used :: C:\Documents and Settings\Jonathan Murray\Desktop\CFScript.txt
AV: AVG Internet Security *On-access scanning disabled* (Updated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
FW: AVG Firewall *disabled* {8decf618-9569-4340-b34a-d78d28969b66}
PEV Error: ProgramsFolder
C:\WINDOWS\system32\SHELLLNK.TLB
C:\WINDOWS\ServicePackFiles\i386\atapi.sys --> C:\WINDOWS\system32\drivers\atapi.sys
((((((((((((((((((((((((( Files Created from 2009-12-28 to 2010-01-30 )))))))))))))))))))))))))))))))
2010-01-28 04:25:48 . 2010-01-29 22:41:10 -------- d-----w- C:\ComboFix
2010-01-22 04:28:45 . 2010-01-22 04:28:45 -------- d-----w- C:\Rooter$
2010-01-22 04:27:27 . 2010-01-22 04:27:40 173119 ----a-w- C:\Program Files\Rooter.exe
2010-01-21 04:56:28 . 2010-01-21 04:56:41 1956528 ----a-w- C:\Program Files\install_flash_player_ax.exe
2010-01-20 20:32:36 . 2010-01-20 20:32:36 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\Threat Expert
2010-01-20 03:55:20 . 2010-01-20 03:55:20 -------- d-----w- C:\WINDOWS\system32\wbem\Repository
2010-01-18 02:53:54 . 2010-01-18 02:54:10 595499 ----a-w- C:\Program Files\Autoruns.zip
2010-01-16 19:51:26 . 2010-01-20 03:53:25 -------- d-----w- C:\Program Files\hpHosts
2010-01-16 05:09:08 . 2010-01-16 05:09:16 800544 ----a-w- C:\Program Files\jre-6u17-windows-i586-iftw-rv.exe
2010-01-16 04:55:52 . 2010-01-16 04:59:17 27386256 ----a-w- C:\Program Files\AdbeRdr930_en_US.exe
2010-01-15 22:07:16 . 2010-01-15 22:07:17 843187 ----a-w- C:\Program Files\SecurityCheck.exe
2010-01-14 23:13:27 . 2010-01-14 23:13:47 2672312 ----a-w- C:\Program Files\esetsmartinstaller_enu.exe
2010-01-13 02:56:12 . 2009-11-21 15:51:04 471552 -c----w- C:\WINDOWS\system32\dllcache\aclayers.dll
2010-01-11 04:40:03 . 2009-11-10 15:26:26 767952 ----a-w- C:\WINDOWS\BDTSupport.dll
2010-01-11 04:40:02 . 2009-11-10 15:28:16 149456 ----a-w- C:\WINDOWS\SGDetectionTool.dll
2010-01-11 04:40:02 . 2009-11-10 15:28:10 165840 ----a-w- C:\WINDOWS\PCTBDRes.dll
2010-01-11 04:40:02 . 2009-11-10 15:28:10 1640400 ----a-w- C:\WINDOWS\PCTBDCore.dll
2010-01-11 04:40:02 . 2009-10-28 06:36:02 1152444 ----a-w- C:\WINDOWS\UDB.zip
2010-01-11 04:40:02 . 2008-11-26 17:08:42 131 ----a-w- C:\WINDOWS\IDB.zip
2010-01-11 04:04:27 . 2010-01-11 04:08:51 34628432 ----a-w- C:\Program Files\sdsetup.exe
2010-01-10 23:40:50 . 2010-01-10 23:40:50 -------- d-----w- C:\Documents and Settings\Administrator.JONATHAN\Application Data\SUPERAntiSpyware.com
2010-01-10 22:03:17 . 2010-01-29 22:36:54 0 ----a-w- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\prvlcl.dat
2010-01-07 21:39:08 . 2010-01-07 23:30:14 -------- d-----w- C:\$AVG
2010-01-07 21:38:08 . 2010-01-07 21:38:08 12464 ----a-w- C:\WINDOWS\system32\avgrsstx.dll
2010-01-07 21:38:07 . 2010-01-29 00:37:48 -------- d-----w- C:\WINDOWS\system32\drivers\Avg
2010-01-07 21:36:12 . 2010-01-07 21:36:12 25608 ----a-w- C:\WINDOWS\system32\drivers\AVGIDSxx.sys
2010-01-07 21:36:11 . 2010-01-07 21:36:11 161800 ----a-w- C:\WINDOWS\system32\drivers\avgrkx86.sys
2010-01-07 21:36:10 . 2010-01-07 21:36:10 360584 ----a-w- C:\WINDOWS\system32\drivers\avgtdix.sys
2010-01-07 21:36:09 . 2010-01-07 21:36:09 333192 ----a-w- C:\WINDOWS\system32\drivers\avgldx86.sys
2010-01-07 21:36:07 . 2010-01-07 21:36:08 28424 ----a-w- C:\WINDOWS\system32\drivers\avgmfx86.sys
2010-01-07 21:34:35 . 2010-01-07 21:34:35 50968 ----a-w- C:\WINDOWS\system32\avgfwdx.dll
2010-01-07 21:34:35 . 2010-01-07 21:34:35 30104 ----a-w- C:\WINDOWS\system32\drivers\avgfwdx.sys
2010-01-07 21:34:30 . 2010-01-07 21:34:30 -------- d-----w- C:\Program Files\AVG
2010-01-07 21:34:19 . 2010-01-11 13:17:28 -------- d-----w- C:\Documents and Settings\All Users\Application Data\avg9
2010-01-07 18:43:16 . 2010-01-07 20:25:38 163713 ----a-w- C:\WINDOWS\system32\drivers\sfi.dat
2010-01-07 18:34:49 . 2010-01-07 20:27:19 -------- d-----w- C:\Program Files\COMODO
2010-01-07 18:28:31 . 2010-01-07 18:33:07 40603920 ----a-w- C:\Program Files\CIS_Setup_3.13.125662.579_XP_Vista_x32.exe
2010-01-07 18:00:35 . 2010-01-07 18:00:36 891248 ----a-w- C:\Program Files\avg_free_stb_all_9_40_cnet.exe
2010-01-05 22:45:26 . 2010-01-05 22:45:26 -------- d-----w- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
2010-01-05 22:44:57 . 2010-01-05 22:45:02 -------- d-----w- C:\Program Files\SUPERAntiSpyware
2010-01-05 22:44:57 . 2010-01-05 22:44:57 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\SUPERAntiSpyware.com
2010-01-05 22:44:20 . 2010-01-05 22:44:20 -------- d-----w- C:\Program Files\Common Files\Wise Installation Wizard
2010-01-05 22:42:55 . 2010-01-05 22:44:08 7451168 ----a-w- C:\Program Files\SUPERAntiSpywarePro.exe
2010-01-05 18:43:02 . 2010-01-05 18:43:02 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\Malwarebytes
2010-01-05 18:42:48 . 2010-01-07 21:07:14 38224 ----a-w- C:\WINDOWS\system32\drivers\mbamswissarmy.sys
2010-01-05 18:42:45 . 2010-01-05 18:42:45 -------- d-----w- C:\Documents and Settings\All Users\Application Data\Malwarebytes
2010-01-05 18:42:36 . 2010-01-07 21:07:04 19160 ----a-w- C:\WINDOWS\system32\drivers\mbam.sys
2010-01-05 18:42:34 . 2010-01-11 22:26:27 -------- d-----w- C:\Program Files\Malwarebytes' Anti-Malware
2010-01-05 18:40:58 . 2010-01-05 18:41:23 5061520 ----a-w- C:\Program Files\mbam-setup.exe
2010-01-02 02:55:35 . 2010-01-05 05:20:43 8086544 ----a-w- C:\Program Files\Firefox Setup 3.5.6.exe
2010-01-29 22:30:21 . 2008-05-16 01:32:00 -------- d---a-w- C:\Documents and Settings\All Users\Application Data\TEMP
2010-01-28 00:54:09 . 2010-01-28 19:45:48 82 ----a-w- C:\Program Files\CFScript.txt
2010-01-20 23:29:08 . 2009-10-11 22:11:31 411368 ----a-w- C:\WINDOWS\system32\deploytk.dll
2010-01-20 23:24:20 . 2010-01-16 05:11:35 152576 ----a-w- C:\Documents and Settings\Jonathan Murray\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
2010-01-20 23:20:37 . 2010-01-16 05:09:29 79488 ----a-w- C:\Documents and Settings\Jonathan Murray\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2010-01-18 03:11:11 . 2004-03-25 03:00:15 -------- d-----w- C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
2010-01-16 05:12:27 . 2004-12-01 21:15:02 -------- d-----w- C:\Program Files\Java
2010-01-16 05:05:50 . 2004-03-24 01:01:29 -------- d-----w- C:\Program Files\Common Files\Adobe
2010-01-15 22:12:13 . 2010-01-09 19:44:53 1260800 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgfrw.exe
2010-01-15 22:12:11 . 2010-01-09 03:04:13 3777280 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\setup.exe
2010-01-13 17:55:02 . 2008-05-16 23:20:31 -------- d-----w- C:\Program Files\Spyware Doctor
2010-01-13 05:24:18 . 2009-06-01 23:24:26 0 ----a-w- C:\qinfo.dat
2010-01-11 22:15:20 . 2010-01-11 22:15:20 5115824 ----a-w- C:\Documents and Settings\All Users\Application Data\Malwarebytes\Malwarebytes' Anti-Malware\mbam-setup.exe
2010-01-11 18:32:45 . 2005-01-08 16:28:23 -------- d-----w- C:\Program Files\Spybot - Search & Destroy
2010-01-11 18:21:51 . 2009-06-02 20:26:14 -------- d-----w- C:\Program Files\Spybot - Search & Destroy1
2010-01-10 23:41:29 . 2010-01-10 23:41:29 117760 ----a-w- C:\Documents and Settings\Administrator.JONATHAN\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
2010-01-09 19:40:04 . 2010-01-09 03:04:04 3966744 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcorex.dll
2010-01-09 03:03:11 . 2010-01-09 03:04:17 4043544 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgui.exe
2010-01-09 03:01:11 . 2010-01-09 03:04:16 2033432 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgtray.exe
2010-01-09 02:56:27 . 2010-01-09 19:44:32 737560 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\axioo.dll
2010-01-09 02:56:22 . 2010-01-09 03:04:10 924952 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcfgx.dll
2010-01-09 02:50:53 . 2010-01-09 03:04:07 411928 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgresf.dll
2010-01-07 21:36:13 . 2010-01-09 19:44:24 404760 ----a-w- C:\Documents and Settings\All Users\Application Data\avg9\update\backup\fixcfg.exe
2010-01-05 22:50:36 . 2010-01-05 22:50:36 117760 ----a-w- C:\Documents and Settings\Jonathan Murray\Application Data\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
2010-01-05 05:49:31 . 2009-12-04 00:27:04 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\BitTorrent
2010-01-04 06:55:53 . 2009-08-31 05:12:07 -------- d-----w- C:\Program Files\WildGames
2010-01-04 06:29:30 . 2010-01-04 06:29:30 44024 ----a-w- C:\Program Files\bookmarks1-3-09.html
2009-12-31 05:26:06 . 2006-01-30 19:12:42 44240 ----a-w- C:\Documents and Settings\LocalService\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-23 20:28:35 . 2008-12-14 01:25:42 -------- d-----w- C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
2009-12-23 20:20:14 . 2004-03-23 22:31:30 -------- d--h--w- C:\Program Files\InstallShield Installation Information
2009-12-23 19:55:38 . 2009-12-23 02:14:32 -------- d-----w- C:\Program Files\Unlocker
2009-12-23 19:32:22 . 2004-04-07 23:57:07 44240 ----a-w- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-23 15:22:31 . 2006-05-30 20:25:16 -------- d-----w- C:\Documents and Settings\All Users\Application Data\Sonic
2009-12-23 15:19:34 . 2006-05-30 20:25:49 -------- d-----w- C:\Program Files\Common Files\Sonic Shared
2009-12-23 15:18:34 . 2006-05-30 20:22:29 -------- d-----w- C:\Program Files\Common Files\Roxio Shared
2009-12-23 15:18:13 . 2006-05-30 20:23:33 -------- d-----w- C:\Documents and Settings\All Users\Application Data\Roxio
2009-12-22 19:17:21 . 2009-12-22 19:17:21 10134 ----a-r- C:\Documents and Settings\Jonathan Murray\Application Data\Microsoft\Installer\{AF9E97C1-7431-426D-A8D5-ABE40995C0B1}\ARPPRODUCTICON.exe
2009-12-22 05:21:05 . 2003-11-08 12:00:00 667136 ----a-w- C:\WINDOWS\system32\wininet.dll
2009-12-22 05:20:58 . 2009-02-17 01:22:32 81920 ------w- C:\WINDOWS\system32\ieencode.dll
2009-12-05 07:42:35 . 2009-12-05 07:41:54 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\Nero
2009-12-05 07:41:57 . 2009-12-05 07:41:57 -------- d-----w- C:\Documents and Settings\All Users\Application Data\LightScribe
2009-12-05 07:41:57 . 2007-04-04 16:59:58 -------- d-----w- C:\Program Files\Common Files\LightScribe
2009-12-05 07:39:38 . 2009-12-05 07:20:38 -------- d-----w- C:\Program Files\Common Files\Nero
2009-12-05 07:38:45 . 2007-04-04 16:55:58 -------- d-----w- C:\Program Files\Nero
2009-12-05 07:25:33 . 2007-04-04 16:55:58 -------- d-----w- C:\Documents and Settings\All Users\Application Data\Nero
2009-12-05 06:33:38 . 2009-12-05 06:08:42 214167816 ----a-w- C:\Program Files\Nero-9.4.26.0_trial.exe
2009-12-04 23:36:03 . 2009-12-04 23:30:04 -------- d-----w- C:\Program Files\Cucusoft
2009-12-04 23:35:49 . 2009-12-04 23:35:40 2081039 ----a-w- C:\Program Files\dvd-author.exe
2009-12-04 23:29:21 . 2009-12-04 23:29:05 3119665 ----a-w- C:\Program Files\dvd-burner.exe
2009-12-04 23:26:39 . 2009-12-04 23:26:39 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\AnvSoft
2009-12-04 23:26:34 . 2009-12-04 23:26:34 -------- d-----w- C:\Program Files\AnvSoft
2009-12-04 23:26:02 . 2009-12-04 23:24:27 15672013 ----a-w- C:\Program Files\avc-free.exe
2009-12-04 23:23:11 . 2009-12-04 22:56:45 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\Vso
2009-12-04 23:23:09 . 2009-12-04 22:56:45 47360 ----a-w- C:\Documents and Settings\Jonathan Murray\Application Data\pcouffin.sys
2009-12-04 22:56:45 . 2009-12-04 22:56:45 47360 ------w- C:\WINDOWS\system32\drivers\pcouffin.sys
2009-12-04 22:54:18 . 2009-12-04 22:52:35 18026336 ----a-w- C:\Program Files\vsoConvertXtoDVD4_setup.exe
2009-12-04 22:22:39 . 2009-12-04 22:11:43 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\DivX
2009-12-04 19:53:59 . 2009-12-04 19:52:13 -------- d-----w- C:\Program Files\DivX
2009-12-04 19:52:48 . 2009-12-04 19:52:14 -------- d-----w- C:\Program Files\Common Files\DivX Shared
2009-12-04 19:51:21 . 2009-12-04 19:49:15 23804080 ----a-w- C:\Program Files\DivXInstaller.exe
2009-12-04 19:14:36 . 2009-12-04 19:14:00 6104788 ----a-w- C:\Program Files\burnaware_free242.exe
2009-12-04 00:26:00 . 2009-12-04 00:25:53 -------- d-----w- C:\Program Files\BitTorrent
2009-12-04 00:14:29 . 2009-12-04 00:13:28 3066744 ----a-w- C:\Program Files\BitTorrent-6.3c.exe
2009-12-02 23:12:17 . 2009-12-02 23:12:06 8084968 ----a-w- C:\Program Files\Firefox Setup 3.5.5.exe
2009-12-02 00:03:46 . 2008-01-06 17:12:37 -------- d-----w- C:\Documents and Settings\Jonathan Murray\Application Data\LimeWire
2009-11-21 15:51:04 . 2003-11-08 12:00:00 471552 ----a-w- C:\WINDOWS\AppPatch\aclayers.dll
2009-11-14 00:47:32 . 2009-11-14 00:47:32 90112 ------w- C:\WINDOWS\system32\dpl100.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 856064 ------w- C:\WINDOWS\system32\divx_xx0c.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 856064 ------w- C:\WINDOWS\system32\divx_xx07.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 847872 ------w- C:\WINDOWS\system32\divx_xx0a.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 843776 ------w- C:\WINDOWS\system32\divx_xx16.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 839680 ------w- C:\WINDOWS\system32\divx_xx11.dll
2009-11-14 00:47:28 . 2009-11-14 00:47:28 696320 ------w- C:\WINDOWS\system32\DivX.dll
2009-11-09 16:20:12 . 2009-06-02 04:10:32 207792 ----a-w- C:\WINDOWS\system32\drivers\PCTCore.sys
2009-11-05 06:03:07 . 2001-09-17 05:56:00 77607 ----a-w- C:\WINDOWS\PCHEALTH\HELPCTR\OfflineCache\index.dat
2009-10-07 20:01:34 . 2009-10-07 20:01:32 3340064 ----a-w- C:\Program Files\UnityWebPlayer.exe
2009-10-04 17:12:43 . 2009-10-04 17:11:46 12541248 ----a-w- C:\Program Files\RLCSetup.exe
2009-09-15 19:44:41 . 2009-09-15 19:42:01 25685128 ----a-w- C:\Program Files\wordview_en-us.exe
2009-09-15 19:26:52 . 2009-09-15 19:26:41 13824 ----a-r- C:\Program Files\TRU_Unicru_92908.doc
2009-09-12 20:16:28 . 2009-09-12 20:16:09 4122416 ----a-w- C:\Program Files\freeclip.exe
2009-09-11 23:10:58 . 2009-09-11 22:55:37 52736 ----a-w- C:\Program Files\oown_resume_template.doc
2009-09-04 19:49:38 . 2009-09-04 19:47:45 11729274 ----a-w- C:\Program Files\installeasyjob.exe
2009-09-02 19:29:27 . 2009-09-02 19:29:16 8050536 ----a-w- C:\Program Files\Firefox Setup 3.5.2.exe
2009-07-07 23:46:06 . 2009-07-07 23:45:58 359656 ----a-w- C:\Program Files\msicuu2.exe
2009-02-17 01:18:10 . 2009-02-16 04:28:41 16939888 ----a-w- C:\Program Files\IE8-WindowsXP-x86-ENU.exe
2008-11-23 17:56:59 . 2008-11-23 17:56:50 25740144 ----a-w- C:\Program Files\wmp11-windowsxp-x86-enu.exe
2008-09-06 03:18:00 . 2005-01-03 03:29:49 1505160 ----a-w- C:\Program Files\install_easyshare.exe
2008-07-04 00:24:37 . 2008-07-04 00:21:54 1445888 ----a-w- C:\Program Files\WinsockxpFix.exe
2008-05-31 02:17:18 . 2008-05-31 02:07:36 9723880 ----a-w- C:\Program Files\spybotsd152.exe
2008-05-29 00:21:48 . 2008-05-29 00:21:48 1244712 ----a-w- C:\Program Files\SetupOneCare.exe
2008-05-28 03:12:36 . 2008-05-28 03:12:30 7608344 ----a-w- C:\Program Files\spyhunterFULL.exe
2008-05-09 13:47:14 . 2008-05-09 13:47:14 1206366 ----a-w- C:\Program Files\wrar371.exe
2008-05-09 13:43:51 . 2008-05-09 13:43:39 244784 ----a-w- C:\Program Files\gnie_s_dvd4-iml2iso.rar
2008-05-09 03:44:36 . 2008-05-09 03:44:32 10121656 ----a-w- C:\Program Files\Alcohol120_trial_1.9.7.6221.exe
2008-05-09 03:28:46 . 2008-05-09 03:28:45 1385051 ----a-w- C:\Program Files\cddvdgen.zip
2008-05-09 03:12:54 . 2008-05-09 03:12:54 899414 ----a-w- C:\Program Files\SetupDVDDecrypter_3.5.4.0.exe
2008-04-06 17:28:37 . 2008-04-06 17:28:37 569777 ----a-w- C:\Program Files\DVD43_4-2-0_Setup.exe
2008-01-05 18:20:19 . 2008-01-05 18:20:19 3381280 ----a-w- C:\Program Files\LimeWireWin.exe
2006-06-18 00:07:59 . 2006-06-18 00:07:59 1522527 ----a-w- C:\Program Files\dvdrip32572.exe
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe" [2006-12-23 22:05:20 143360]
"AlcoholAutomount"="C:\Program Files\Alcohol Soft\Alcohol 120\axcmd.exe" [2008-03-20 16:46:18 217544]
"Window Washer"="C:\Program Files\Webroot\Washer\wwDisp.exe" [2007-09-05 20:43:14 1261384]
"ISUSScheduler"="C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe" [2006-09-11 09:40:34 86960]
"HostManager"="C:\Program Files\Common Files\AOL\1155679928\ee\AOLSoftware.exe" [2006-09-26 00:52:48 50736]
"HP Software Update"="C:\Program Files\HP\HP Software Update\HPWuSchd2.exe" [2006-02-19 07:41:10 49152]
"RemoteControl"="C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe" [2006-11-23 19:10:42 56928]
"LanguageShortcut"="C:\Program Files\CyberLink\PowerDVD\Language\Language.exe" [2006-12-06 02:55:32 54832]
"NeroFilterCheck"="C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe" [2006-01-12 19:40:44 155648]
"UnlockerAssistant"="C:\Program Files\Unlocker\UnlockerAssistant.exe" [2009-10-26 07:33:41 15872]
"AVG9_TRAY"="C:\PROGRA~1\AVG\AVG9\avgtray.exe" [2010-01-09 19:41:13 2033432]
"Adobe Reader Speed Launcher"="C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-12-22 06:57:28 35760]
"Adobe ARM"="C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-12-11 20:57:56 948672]
"SunJavaUpdateSched"="C:\Program Files\Java\jre6\bin\jusched.exe" [2010-01-20 23:29:12 149280]
"tscuninstall"="C:\WINDOWS\system32\tscupgrd.exe" [2004-08-04 02:59:28 44544]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
HP Digital Imaging Monitor.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe [2006-2-19 288472]
HP Photosmart Premier Fast Start.lnk - C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe [2006-2-10 73728]
NETGEAR WG311v3 Smart Wizard.lnk - C:\Program Files\NETGEAR\WG311v3\wlancfg5.exe [2006-1-26 1486848]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "C:\Program Files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 14:13:36 77824]
2009-09-03 19:21:42 548352 ----a-w- C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\OneCareMP]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=C:\WINDOWS\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Kodak EasyShare software.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Kodak EasyShare software.lnk
backup=C:\WINDOWS\pss\Kodak EasyShare software.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Kodak software updater.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Kodak software updater.lnk
backup=C:\WINDOWS\pss\Kodak software updater.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Works Calendar Reminders.lnk]
path=C:\Documents and Settings\All Users\Start Menu\Programs\Startup\Microsoft Works Calendar Reminders.lnk
backup=C:\WINDOWS\pss\Microsoft Works Calendar Reminders.lnkCommon Startup
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NvCplDaemon]
NvQTwk [X]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AOLDialer]
2006-10-23 12:50:37 71216 ----a-r- C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\CARPService]
2002-01-03 03:06:28 4608 ------w- C:\WINDOWS\system32\carpserv.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\dvd43]
2008-03-01 19:49:50 826880 ----a-w- C:\Program Files\dvd43\DVD43_Tray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMEKRMIG6.1]
2001-08-18 22:00:00 44032 ----a-w- C:\WINDOWS\ime\imkr6_1\imekrmig.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IMJPMIG8.1]
2004-08-04 05:31:59 208952 ----a-w- C:\WINDOWS\ime\imjp8_1\imjpmig.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISTray]
2009-11-18 17:47:14 1243088 ----a-w- C:\Program Files\Spyware Doctor\pctsTray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Works Portfolio]
2000-07-13 20:00:00 311350 ----a-w- C:\Program Files\Microsoft Works\wkssb.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Microsoft Works Update Detection]
2000-07-13 20:00:00 28739 ----a-w- C:\Program Files\Microsoft Works\WkDetect.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Smapp]
2001-10-12 23:45:06 69632 ----a-w- C:\Program Files\Analog Devices\SoundMAX\SMTray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SunJavaUpdateSched]
C:\Program Files\Java\j2re1.4.2_06\bin\jusched.exe [BU]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\WorksFUD]
2000-07-13 20:00:00 24576 ----a-w- C:\Program Files\Microsoft Works\wkfud.exe
"MCVSRte"=2 (0x2)
R0 AVGIDSErHrxpx;AVG9IDSErHr;C:\WINDOWS\system32\drivers\AVGIDSxx.sys [01/07/2010 4:36:12 PM 25608]
R0 AvgRkx86;avgrkx86.sys;C:\WINDOWS\system32\drivers\avgrkx86.sys [01/07/2010 4:36:11 PM 161800]
R1 AvgLdx86;AVG AVI Loader Driver x86;C:\WINDOWS\system32\drivers\avgldx86.sys [01/07/2010 4:36:09 PM 333192]
R1 AvgTdiX;AVG Network Redirector;C:\WINDOWS\system32\drivers\avgtdix.sys [01/07/2010 4:36:10 PM 360584]
R3 Avgfwdx;Avgfwdx;C:\WINDOWS\system32\drivers\avgfwdx.sys [01/07/2010 4:34:35 PM 30104]
R3 AVGIDSDriverxpx;AVG9IDSDriver;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys [01/07/2010 4:36:04 PM 122376]
R3 AVGIDSFilterxpx;AVG9IDSFilter;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys [01/07/2010 4:36:04 PM 30216]
R3 AVGIDSShimxpx;AVG9IDSShim;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys [01/07/2010 4:36:03 PM 25736]
S3 Avgfwfd;AVG network filter service;C:\WINDOWS\system32\drivers\avgfwdx.sys [01/07/2010 4:34:35 PM 30104]
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
ylmolrez
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
2009-08-20 18:24:06 451872 ----a-w- C:\Program Files\Common Files\LightScribe\LSRunOnce.exe
2010-01-29 C:\WINDOWS\Tasks\RegCure Program Check.job
- C:\Program Files\RegCure\RegCure.exe [2008-04-21 21:21:26 . 2008-04-21 21:21:26]
2010-01-21 C:\WINDOWS\Tasks\RegCure.job
2004-03-28 C:\WINDOWS\Tasks\Registration reminder 1.job
- C:\WINDOWS\System32\OOBE\oobebaln.exe [2006-04-09 04:54:16 . 2008-04-14 00:12:31]
2004-03-23 C:\WINDOWS\Tasks\Registration reminder 2.job
2004-04-08 C:\WINDOWS\Tasks\Registration reminder 3.job
mWindow Title =
uInternet Settings,ProxyServer = 168.94.74.68:8080
IE: &AOL Toolbar Search
DPF: DirectAnimation Java Classes - [You must be registered and logged in to see this link.]
DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} - [You must be registered and logged in to see this link.]
DPF: {2C8EEB84-6D60-11D4-BD64-0050048A82BF} - [You must be registered and logged in to see this link.]
FF - ProfilePath - C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\
FF - prefs.js: browser.search.selectedEngine - Fast Browser Search
FF - component: C:\Program Files\AVG\AVG9\Firefox\components\avgssff.dll
FF - plugin: C:\Program Files\DivX\DivX Plus Web Player\npdivx32.dll
FF - plugin: C:\Program Files\Viewpoint\Viewpoint Experience Technology\npViewpoint.dll
FF - hȋdden: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\DotNetAssistantExtension\
Thebeast28
Posts Posts : 159
Post by Dr Jay on 30th January 2010, 3:45 pm
You did not post a full ComboFix log. Please go to C:\combofix.txt and get a full log.
Posts Posts : 13810
Post by Thebeast28 on 31st January 2010, 12:14 am
I renamed Combofix to blackpudding.bat and dragged CFScript into and it worked. It gave me a log but I didn't find it at C:/Combofix.txt I found it in the folder blackpudding. So what do u want me to try and do?
Thebeast28
Posts Posts : 159
Post by Dr Jay on 31st January 2010, 2:35 am
Go ahead and post that log. That should be fine. Smile
Posts Posts : 13810
Post by Thebeast28 on 1st February 2010, 8:48 pm
ComboFix 10-01-29.09 - Jonathan Murray 01/31/2010 0:38:36.3.1 - x86
G:\Autorun.inf
---- Previous Run -------
((((((((((((((((((((((((( Files Created from 2009-12-28 to 2010-01-31 )))))))))))))))))))))))))))))))
2010-01-10 22:03:17 . 2010-01-31 00:36:39 0 ----a-w- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\prvlcl.dat
2010-01-07 21:38:07 . 2010-01-30 19:16:37 -------- d-----w- C:\WINDOWS\system32\drivers\Avg
2010-01-30 23:47:27 . 2008-05-16 01:32:00 -------- d---a-w- C:\Documents and Settings\All Users\Application Data\TEMP
2009-12-22 05:21:05 . 2003-11-08 12:00:00 667136 ------w- C:\WINDOWS\system32\wininet.dll
2006-06-12 18:48:46 . 2006-06-12 18:48:46 1160885 ----a-w- C:\Program Files\DVDRegionFree59.exe
2006-06-04 05:56:43 . 2006-06-04 05:56:43 302680 ----a-w- C:\Program Files\ac3filter_0_70b.exe
2006-06-04 05:50:49 . 2006-06-04 05:50:47 156181 ----a-w- C:\Program Files\MpegDecoder012.zip
2006-06-04 00:49:56 . 2006-06-04 00:49:56 6973792 ----a-w- C:\Program Files\iaplayer_2.60.12.0201_esd.exe
2006-06-03 21:08:02 . 2006-06-03 21:08:02 5753886 ----a-w- C:\Program Files\psp_video_express.exe
2006-05-15 00:22:56 . 2006-05-15 00:17:10 5779942 ----a-w- C:\Program Files\psp_movie_creator.exe
2006-05-14 21:15:28 . 2006-03-12 21:49:48 3457413 ----a-w- C:\Program Files\1clickdvdcopysetup.exe
2006-03-12 19:17:37 . 2006-03-12 19:17:32 521403 ----a-w- C:\Program Files\DVD43_3-7-0_Setup.exe
2006-03-12 16:38:41 . 2006-03-11 23:17:39 3878912 ----a-w- C:\Program Files\ICopyDVDs2_30DayTrial_EN_v4.1.0.2.exe
2006-01-30 01:05:42 . 2006-01-30 01:05:42 7391952 ----a-w- C:\Program Files\ewido-setup.exe
2005-11-03 23:52:41 . 2005-09-24 15:43:58 64 ---ha-w- C:\Program Files\AppUpdate.log
2005-09-25 14:31:51 . 2005-09-25 14:31:51 194835 ----a-w- C:\Program Files\ringtoneripper.exe
2005-09-24 02:14:15 . 2005-09-24 02:14:13 24265736 ----a-w- C:\Program Files\dotnetfx.exe
2005-03-03 23:40:21 . 2005-03-03 21:35:53 20798256 ----a-w- C:\Program Files\AdbeRdr70_enu_full.exe
2005-01-09 22:50:37 . 2005-01-09 22:39:22 2145414 ----a-w- C:\Program Files\OneTouch.exe
2005-01-08 02:48:05 . 2005-01-08 02:48:05 4354084 ----a-w- C:\Program Files\spybotsd13.exe
2004-02-20 07:38:18 . 2004-03-23 23:18:01 1760378 ----a-w- C:\Program Files\aaw6.exe
NvQTwk [X]
"MCVSRte"=2 (0x2)
R2 avg9emc;AVG E-mail Scanner;C:\Program Files\AVG\AVG9\avgemc.exe [2010-01-07 21:36:13 906520]
R2 msCMTSrvc;Content Monitoring Tool;C:\WINDOWS\system32\msCMTSrvc.exe [x]
R3 Avgfwfd;AVG network filter service;C:\WINDOWS\system32\DRIVERS\avgfwdx.sys [2010-01-07 21:34:35 30104]
R3 Roxio UPnP Renderer 11;Roxio UPnP Renderer 11;C:\Program Files\Roxio Creator 2009\Digital Home 11\RoxioUPnPRenderer11.exe [x]
R3 SASENUM;SASENUM;C:\Program Files\SUPERAntiSpyware\SASENUM.SYS [2009-12-16 21:27:00 7408]
R3 sdAuxService;PC Tools Auxiliary Service;C:\Program Files\Spyware Doctor\pctsAuxs.exe [2009-10-30 16:18:16 359624]
R3 SWNC8U12;Sierra Wireless MUX NDIS Driver (UMTS12);C:\WINDOWS\system32\DRIVERS\swnc8u12.sys [2007-06-15 20:35:30 82432]
R3 swumx12;Sierra Wireless USB MUX Driver (UMTS12);C:\WINDOWS\system32\DRIVERS\swumx12.sys [2007-06-15 20:35:30 66304]
R3 USB-100;SMC Compact USB to Ethernet converter;C:\WINDOWS\system32\DRIVERS\SMC2208.SYS [2001-09-25 18:02:18 27519]
R4 sptd;sptd;C:\WINDOWS\system32\Drivers\sptd.sys [2008-05-09 13:41:00 716272]
S0 AVGIDSErHrxpx;AVG9IDSErHr;C:\WINDOWS\System32\Drivers\AVGIDSxx.sys [2010-01-07 21:36:12 25608]
S0 AvgRkx86;avgrkx86.sys;C:\WINDOWS\System32\Drivers\avgrkx86.sys [2010-01-07 21:36:11 161800]
S0 PCTCore;PCTools KDS;C:\WINDOWS\system32\drivers\PCTCore.sys [2009-11-09 16:20:12 207792]
S1 AvgLdx86;AVG AVI Loader Driver x86;C:\WINDOWS\System32\Drivers\avgldx86.sys [2010-01-07 21:36:09 333192]
S1 AvgTdiX;AVG Network Redirector;C:\WINDOWS\System32\Drivers\avgtdix.sys [2010-01-07 21:36:10 360584]
S1 SASDIFSV;SASDIFSV;C:\Program Files\SUPERAntiSpyware\SASDIFSV.SYS [2009-12-16 21:26:58 9968]
S1 SASKUTIL;SASKUTIL;C:\Program Files\SUPERAntiSpyware\SASKUTIL.sys [2009-12-16 21:26:56 74480]
S2 avg9wd;AVG WatchDog;C:\Program Files\AVG\AVG9\avgwdsvc.exe [2010-01-09 19:40:46 285392]
S2 avgfws9;AVG Firewall;C:\Program Files\AVG\AVG9\avgfws9.exe [2010-01-15 22:12:06 2304192]
S2 AVGIDSAgent;AVG9IDSAgent;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe AVGIDSAgent [x]
S2 Browser Defender Update Service;Browser Defender Update Service;C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe [2009-11-10 15:28:08 112592]
S2 wwEngineSvc;Window Washer Engine;C:\Program Files\Webroot\Washer\WasherSvc.exe [2007-09-05 20:43:24 389448]
S3 Avgfwdx;Avgfwdx;C:\WINDOWS\system32\DRIVERS\avgfwdx.sys [2010-01-07 21:34:35 30104]
S3 AVGIDSDriverxpx;AVG9IDSDriver;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys [2010-01-07 21:36:04 122376]
S3 AVGIDSFilterxpx;AVG9IDSFilter;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys [2010-01-07 21:36:04 30216]
S3 AVGIDSShimxpx;AVG9IDSShim;C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys [2010-01-07 21:36:03 25736]
ylmolrez
2010-01-30 C:\WINDOWS\Tasks\RegCure Program Check.job
mWindow Title =
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 1st February 2010, 8:51 pm
Still can't get on firefox Sometimes it doesn't load, sometimes it freezes and is just slow. Sometimes it takes forever to load up firefox. Same thing goes for internet explorer
Thebeast28
Posts Posts : 159
Post by Dr Jay on 1st February 2010, 10:49 pm
  • Click Run Scan and let the program run uninterrupted.
Posts Posts : 13810
Post by Thebeast28 on 3rd February 2010, 4:00 am
OTL logfile created on: 02/02/2010 3:44:34 PM - Run 1
OTL by OldTimer - Version 3.1.27.1 Folder = C:\Documents and Settings\Jonathan Murray\Desktop
Internet Explorer (Version = 6.0.2900.5512)
Locale: 00000409 | Country: United States | Language: ENU | Date Format: MM/dd/yyyy
479.00 Mb Total Physical Memory | 168.00 Mb Available Physical Memory | 35.00% Memory free
1.00 Gb Paging File | 1.00 Gb Available in Paging File | 66.00% Paging File free
Paging file location(s): C:\pagefile.sys 1024 2048 [binary data]
Drive C: | 74.53 Gb Total Space | 16.12 Gb Free Space | 21.63% Space Free | Partition Type: NTFS
Drive G: | 74.51 Gb Total Space | 54.51 Gb Free Space | 73.16% Space Free | Partition Type: FAT32
Computer Name: JONATHAN
Current User Name: Jonathan Murray
Logged in as Administrator.
Current Boot Mode: Normal
Scan Mode: Current user
Company Name Whitelist: Off
Skip Microsoft Files: Off
File Age = 30 Days
Output = Standard
PRC - [2010/02/02 15:41:12 | 000,548,864 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jonathan Murray\Desktop\OTL.exe
PRC - [2010/01/20 18:29:12 | 000,149,280 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Java\jre6\bin\jusched.exe
PRC - [2010/01/20 18:29:11 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\Java\jre6\bin\jqs.exe
PRC - [2010/01/15 17:12:06 | 002,304,192 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgfws9.exe
PRC - [2010/01/09 14:41:13 | 002,033,432 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgtray.exe
PRC - [2010/01/09 14:40:46 | 000,285,392 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgwdsvc.exe
PRC - [2010/01/09 14:40:11 | 000,702,744 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgcsrvx.exe
PRC - [2010/01/07 16:37:52 | 001,055,000 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgchsvx.exe
PRC - [2010/01/07 16:37:51 | 000,600,344 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgnsx.exe
PRC - [2010/01/07 16:37:51 | 000,503,576 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgrsx.exe
PRC - [2010/01/07 16:36:13 | 000,906,520 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgemc.exe
PRC - [2010/01/07 16:36:07 | 000,827,160 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\avgam.exe
PRC - [2010/01/07 16:36:03 | 000,592,392 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSMonitor.exe
PRC - [2010/01/07 16:36:00 | 005,832,712 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe
PRC - [2009/11/10 10:28:08 | 000,112,592 | ---- | M] (Threat Expert Ltd.) -- C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe
PRC - [2009/10/26 02:33:41 | 000,015,872 | ---- | M] () -- C:\Program Files\Unlocker\UnlockerAssistant.exe
PRC - [2009/09/23 13:38:18 | 000,935,208 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe
PRC - [2009/08/20 13:34:04 | 000,073,728 | ---- | M] (Hewlett-Packard Company) -- C:\Program Files\Common Files\LightScribe\LSSrvc.exe
PRC - [2008/04/13 19:12:41 | 000,013,824 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\system32\wscntfy.exe
PRC - [2008/04/13 19:12:19 | 001,033,728 | ---- | M] (Microsoft Corporation) -- C:\WINDOWS\explorer.exe
PRC - [2007/09/05 15:43:24 | 000,389,448 | ---- | M] (Webroot Software, Inc.) -- C:\Program Files\Webroot\Washer\WasherSvc.exe
PRC - [2007/09/05 15:43:14 | 001,261,384 | ---- | M] (Webroot Software, Inc.) -- C:\Program Files\Webroot\Washer\wwDisp.exe
PRC - [2007/05/28 11:57:54 | 000,275,968 | ---- | M] (Rocket Division Software) -- C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe
PRC - [2006/12/23 17:05:20 | 000,143,360 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
PRC - [2006/12/23 17:04:42 | 000,905,216 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe
PRC - [2006/12/23 16:54:04 | 000,262,144 | ---- | M] (Nero AG) -- C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
PRC - [2006/11/23 14:10:42 | 000,056,928 | ---- | M] (Cyberlink Corp.) -- C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
PRC - [2006/10/23 07:50:35 | 000,046,640 | R--- | M] (AOL LLC) -- C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
PRC - [2006/09/25 19:52:48 | 000,050,736 | ---- | M] (America Online, Inc.) -- C:\Program Files\Common Files\AOL\1155679928\EE\aolsoftware.exe
PRC - [2006/09/11 04:40:34 | 000,086,960 | ---- | M] (Macrovision Corporation) -- C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe
PRC - [2006/02/19 05:24:52 | 000,239,320 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files\HP\Digital Imaging\bin\hpqste08.exe
PRC - [2006/02/19 04:21:22 | 000,288,472 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
PRC - [2006/02/19 02:41:10 | 000,049,152 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files\HP\HP Software Update\hpwuSchd2.exe
PRC - [2006/02/10 07:56:12 | 000,479,232 | ---- | M] (Hewlett-Packard Development Company, L.P.) -- C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
PRC - [2006/01/26 16:55:04 | 001,486,848 | ---- | M] () -- C:\Program Files\NETGEAR\WG311v3\wlancfg5.exe
PRC - [2005/08/07 07:54:00 | 000,167,936 | ---- | M] () -- C:\Program Files\CyberLink\Shared Files\RichVideo.exe
PRC - [2004/05/12 18:32:38 | 000,045,056 | ---- | M] ( ) -- C:\WINDOWS\system32\slserv.exe
PRC - [2002/03/09 13:53:00 | 000,061,440 | ---- | M] (NVIDIA Corporation) -- C:\WINDOWS\system32\nvsvc32.exe
MOD - [2010/02/02 15:41:12 | 000,548,864 | ---- | M] (OldTimer Tools) -- C:\Documents and Settings\Jonathan Murray\Desktop\OTL.exe
MOD - [2009/10/26 02:33:32 | 000,004,608 | ---- | M] () -- C:\Program Files\Unlocker\UnlockerHook.dll
SRV - File not found [On_Demand | Stopped] -- -- (Roxio UPnP Renderer 11)
SRV - File not found [Auto | Stopped] -- -- (msCMTSrvc)
SRV - [2010/01/20 18:29:11 | 000,153,376 | ---- | M] (Sun Microsystems, Inc.) [Auto | Running] -- C:\Program Files\Java\jre6\bin\jqs.exe -- (JavaQuickStarterService)
SRV - [2010/01/15 17:12:06 | 002,304,192 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgfws9.exe -- (avgfws9)
SRV - [2010/01/09 14:40:46 | 000,285,392 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgwdsvc.exe -- (avg9wd)
SRV - [2010/01/07 16:36:13 | 000,906,520 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\avgemc.exe -- (avg9emc)
SRV - [2010/01/07 16:36:00 | 005,832,712 | ---- | M] (AVG Technologies CZ, s.r.o.) [Auto | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Bin\AVGIDSAgent.exe -- (AVGIDSAgent)
SRV - [2009/11/10 10:28:08 | 000,112,592 | ---- | M] (Threat Expert Ltd.) [Auto | Running] -- C:\Program Files\Spyware Doctor\BDT\BDTUpdateService.exe -- (Browser Defender Update Service)
SRV - [2009/11/06 14:29:22 | 001,141,712 | ---- | M] (PC Tools) [On_Demand | Stopped] -- C:\Program Files\Spyware Doctor\pctsSvc.exe -- (sdCoreService)
SRV - [2009/10/30 11:18:16 | 000,359,624 | ---- | M] (PC Tools) [On_Demand | Stopped] -- C:\Program Files\Spyware Doctor\pctsAuxs.exe -- (sdAuxService)
SRV - [2009/09/23 13:38:18 | 000,935,208 | ---- | M] (Nero AG) [Auto | Running] -- C:\Program Files\Common Files\Nero\Nero BackItUp 4\NBService.exe -- (Nero BackItUp Scheduler 4.0)
SRV - [2009/08/20 13:34:04 | 000,073,728 | ---- | M] (Hewlett-Packard Company) [Auto | Running] -- C:\Program Files\Common Files\LightScribe\LSSrvc.exe -- (LightScribeService)
SRV - [2007/09/05 15:43:24 | 000,389,448 | ---- | M] (Webroot Software, Inc.) [Auto | Running] -- C:\Program Files\Webroot\Washer\WasherSvc.exe -- (wwEngineSvc)
SRV - [2007/05/28 11:57:54 | 000,275,968 | ---- | M] (Rocket Division Software) [Auto | Running] -- C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe -- (StarWindServiceAE)
SRV - [2007/01/05 12:41:10 | 000,774,144 | ---- | M] (Nero AG) [On_Demand | Stopped] -- C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe -- (NBService)
SRV - [2006/12/23 16:54:04 | 000,262,144 | ---- | M] (Nero AG) [On_Demand | Running] -- C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe -- (NMIndexingService)
SRV - [2006/10/23 07:50:35 | 000,046,640 | R--- | M] (AOL LLC) [Auto | Running] -- C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe -- (AOL ACS)
SRV - [2006/03/03 21:03:10 | 000,069,632 | ---- | M] (HP) [Unknown | Stopped] -- C:\WINDOWS\system32\HPZipm12.exe -- (Pml Driver HPZ12)
SRV - [2005/08/07 07:54:00 | 000,167,936 | ---- | M] () [Auto | Running] -- C:\Program Files\CyberLink\Shared Files\RichVideo.exe -- (RichVideo) Cyberlink RichVideo Service(CRVS)
SRV - [2005/05/20 10:37:12 | 000,081,920 | ---- | M] (Hewlett-Packard Company) [On_Demand | Stopped] -- C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBPRO.EXE -- (HP Port Resolver)
SRV - [2004/10/22 02:24:18 | 000,073,728 | ---- | M] (Macrovision Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe -- (IDriverT)
SRV - [2004/10/16 05:31:06 | 000,073,728 | ---- | M] (Hewlett-Packard Company) [On_Demand | Stopped] -- C:\WINDOWS\system32\spool\drivers\w32x86\3\HPBOID.EXE -- (HP Status Server)
SRV - [2004/05/12 18:32:38 | 000,045,056 | ---- | M] ( ) [Auto | Running] -- C:\WINDOWS\System32\slserv.exe -- (SLService)
SRV - [2003/07/28 11:28:22 | 000,089,136 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE -- (ose)
SRV - [2002/03/25 13:34:08 | 000,258,048 | ---- | M] (NeoPlanet) [Auto | Stopped] -- C:\Program Files\COMPAQ\Compaq Advisor\bin\compaq-rba.exe -- (Compaq_RBA)
SRV - [2002/03/09 13:53:00 | 000,061,440 | ---- | M] (NVIDIA Corporation) [Auto | Running] -- C:\WINDOWS\system32\nvsvc32.exe -- (NVSvc)
DRV - [2010/01/07 16:36:12 | 000,025,608 | ---- | M] (AVG Technologies ) [Kernel | Boot | Running] -- C:\WINDOWS\System32\Drivers\AVGIDSxx.sys -- (AVGIDSErHrxpx)
DRV - [2010/01/07 16:36:11 | 000,161,800 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | Boot | Running] -- C:\WINDOWS\System32\Drivers\avgrkx86.sys -- (AvgRkx86)
DRV - [2010/01/07 16:36:10 | 000,360,584 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgtdix.sys -- (AvgTdiX)
DRV - [2010/01/07 16:36:09 | 000,333,192 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | System | Running] -- C:\WINDOWS\System32\Drivers\avgldx86.sys -- (AvgLdx86)
DRV - [2010/01/07 16:36:08 | 000,028,424 | ---- | M] (AVG Technologies CZ, s.r.o.) [File_System | System | Running] -- C:\WINDOWS\System32\Drivers\avgmfx86.sys -- (AvgMfx86)
DRV - [2010/01/07 16:36:04 | 000,122,376 | ---- | M] (AVG Technologies ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSDriver.sys -- (AVGIDSDriverxpx)
DRV - [2010/01/07 16:36:04 | 000,030,216 | ---- | M] (AVG Technologies ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSFilter.sys -- (AVGIDSFilterxpx)
DRV - [2010/01/07 16:36:03 | 000,025,736 | ---- | M] (AVG Technologies ) [Kernel | On_Demand | Running] -- C:\Program Files\AVG\AVG9\Identity Protection\Agent\Driver\Platform_XP\AVGIDSShim.sys -- (AVGIDSShimxpx)
DRV - [2010/01/07 16:34:35 | 000,030,104 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\avgfwdx.sys -- (Avgfwfd)
DRV - [2010/01/07 16:34:35 | 000,030,104 | ---- | M] (AVG Technologies CZ, s.r.o.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\avgfwdx.sys -- (Avgfwdx)
DRV - [2009/12/16 16:27:00 | 000,007,408 | R--- | M] ( SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | On_Demand | Stopped] -- C:\Program Files\SUPERAntiSpyware\SASENUM.SYS -- (SASENUM)
DRV - [2009/12/16 16:26:58 | 000,009,968 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv.sys -- (SASDIFSV)
DRV - [2009/12/16 16:26:56 | 000,074,480 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\SASKUTIL.SYS -- (SASKUTIL)
DRV - [2009/12/04 17:56:45 | 000,047,360 | ---- | M] (VSO Software) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\pcouffin.sys -- (Pcouffin)
DRV - [2009/11/09 11:20:12 | 000,207,792 | ---- | M] (PC Tools) [Kernel | Boot | Running] -- C:\WINDOWS\system32\drivers\PCTCore.sys -- (PCTCore)
DRV - [2008/06/16 03:00:00 | 000,044,944 | ---- | M] (Sonic Solutions) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\PxHelp20.sys -- (PxHelp20)
DRV - [2008/05/09 08:41:00 | 000,716,272 | ---- | M] (Duplex Secure Ltd.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\system32\drivers\sptd.sys -- (sptd)
DRV - [2008/04/13 13:46:20 | 000,048,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\61883.sys -- (61883)
DRV - [2008/04/13 13:46:20 | 000,038,912 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\avc.sys -- (Avc)
DRV - [2008/04/13 13:46:09 | 000,051,200 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\msdv.sys -- (MSDV)
DRV - [2008/04/06 12:30:03 | 000,018,816 | ---- | M] (RIF) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\dvd43llh.sys -- (dvd43llh)
DRV - [2008/03/12 03:00:00 | 000,009,200 | ---- | M] (Sonic Solutions) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\cdralw2k.sys -- (Cdralw2k)
DRV - [2008/03/12 03:00:00 | 000,009,072 | ---- | M] (Sonic Solutions) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\cdr4_xp.sys -- (Cdr4_xp)
DRV - [2007/11/13 05:25:53 | 000,020,480 | ---- | M] (Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\secdrv.sys -- (Secdrv)
DRV - [2007/06/15 15:35:30 | 000,082,432 | ---- | M] (Sierra Wireless Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\swnc8u12.sys -- (SWNC8U12) Sierra Wireless MUX NDIS Driver (UMTS12)
DRV - [2007/06/15 15:35:30 | 000,066,304 | ---- | M] (Sierra Wireless Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\swumx12.sys -- (swumx12) Sierra Wireless USB MUX Driver (UMTS12)
DRV - [2007/06/14 13:59:26 | 000,032,160 | ---- | M] (PCTEL Inc.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\PCTINDIS5.sys -- (PCTINDIS5)
DRV - [2007/05/23 16:26:34 | 000,049,904 | ---- | M] (Avanquest Software) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\BVRPMPR5.SYS -- (BVRPMPR5)
DRV - [2006/10/20 10:28:04 | 000,026,368 | ---- | M] (Research in Motion Ltd) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\RimSerial.sys -- (RimVSerPort)
DRV - [2006/04/12 19:04:39 | 000,049,664 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\HPZid412.sys -- (HPZid412)
DRV - [2006/04/12 19:04:39 | 000,021,568 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\HPZius12.sys -- (HPZius12)
DRV - [2006/04/12 19:04:39 | 000,016,496 | ---- | M] (HP) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\HPZipr12.sys -- (HPZipr12)
DRV - [2006/04/03 18:40:53 | 000,023,600 | ---- | M] (EnTech Taiwan) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\TVICHW32.SYS -- (TVICHW32)
DRV - [2005/10/06 14:17:34 | 000,280,576 | ---- | M] (Marvell Semiconductor, Inc) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\WG311v3XP.sys -- (W8335XP) NETGEAR WG311v3 802.11g Wireless PCI Adapter for Windows XP (8335)
DRV - [2005/06/28 11:32:14 | 000,113,664 | ---- | M] (Mars Semiconductor Corp.) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mr7910.sys -- (mr7910)
DRV - [2004/09/25 00:39:08 | 000,289,792 | ---- | M] (Roxio) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\Cdudf_xp.sys -- (cdudf_xp)
DRV - [2004/09/25 00:38:32 | 000,023,936 | ---- | M] (Roxio) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\dvd_2k.sys -- (dvd_2K)
DRV - [2004/09/25 00:29:50 | 000,141,184 | ---- | M] (Windows (R) 2000 DDK provider) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\DVDVRRdr_xp.sys -- (DVDVRRdr_xp)
DRV - [2004/09/25 00:26:40 | 000,200,832 | ---- | M] (Roxio) [File_System | System | Running] -- C:\WINDOWS\system32\drivers\Udfreadr.sys -- (UDFReadr)
DRV - [2004/09/25 00:26:28 | 000,023,808 | ---- | M] (Roxio) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mmc_2k.sys -- (mmc_2K)
DRV - [2004/09/25 00:23:16 | 000,117,632 | ---- | M] (Roxio) [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\Pwd_2k.sys -- (pwd_2K)
DRV - [2004/08/03 21:41:40 | 000,180,360 | ---- | M] (Smart Link) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\ntmtlfax.sys -- (NtMtlFax)
DRV - [2004/08/03 21:29:50 | 000,019,455 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wvchntxx.sys -- (iAimFP4)
DRV - [2004/08/03 21:29:48 | 000,012,063 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wsiintxx.sys -- (iAimFP3)
DRV - [2004/08/03 21:29:46 | 000,023,615 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wch7xxnt.sys -- (iAimTV4)
DRV - [2004/08/03 21:29:44 | 000,033,599 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\watv04nt.sys -- (iAimTV3)
DRV - [2004/08/03 21:29:44 | 000,019,551 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\watv02nt.sys -- (iAimTV1)
DRV - [2004/08/03 21:29:42 | 000,029,311 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\watv01nt.sys -- (iAimTV0)
DRV - [2004/08/03 21:29:38 | 000,161,020 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\i81xnt5.sys -- (i81x)
DRV - [2004/08/03 21:29:38 | 000,012,415 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wadv01nt.sys -- (iAimFP0)
DRV - [2004/08/03 21:29:38 | 000,012,127 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wadv02nt.sys -- (iAimFP1)
DRV - [2004/08/03 21:29:38 | 000,011,775 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\wadv05nt.sys -- (iAimFP2)
DRV - [2004/05/12 17:41:32 | 000,652,360 | ---- | M] ( ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\slntamr.sys -- (Slntamr)
DRV - [2004/05/12 17:38:02 | 000,014,408 | ---- | M] ( ) [Kernel | Boot | Running] -- C:\WINDOWS\system32\DRIVERS\RecAgent.sys -- (RecAgent)
DRV - [2004/05/12 17:35:08 | 000,231,224 | ---- | M] ( ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mtlmnt5.sys -- (Mtlmnt5)
DRV - [2004/05/12 17:29:50 | 000,100,384 | ---- | M] ( ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\slnthal.sys -- (SlNtHal)
DRV - [2004/05/12 17:28:06 | 001,395,296 | ---- | M] ( ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\mtlstrm.sys -- (Mtlstrm)
DRV - [2004/05/12 17:21:18 | 000,013,232 | ---- | M] ( ) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\slwdmsup.sys -- (SlWdmSup)
DRV - [2004/01/06 14:57:24 | 000,887,431 | ---- | M] (Conexant) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\winachcf.sys -- (Winachcf)
DRV - [2003/11/08 07:00:00 | 000,032,640 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\System32\DRIVERS\symc8xx.sys -- (symc8xx)
DRV - [2003/11/08 07:00:00 | 000,028,384 | ---- | M] (LSI Logic) [Kernel | Disabled | Stopped] -- C:\WINDOWS\System32\DRIVERS\sym_hi.sys -- (sym_hi)
DRV - [2003/11/08 07:00:00 | 000,017,792 | ---- | M] (Parallel Technologies, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\ptilink.sys -- (Ptilink)
DRV - [2003/11/08 07:00:00 | 000,016,256 | ---- | M] (Symbios Logic Inc.) [Kernel | Disabled | Stopped] -- C:\WINDOWS\System32\DRIVERS\symc810.sys -- (symc810)
DRV - [2003/11/08 07:00:00 | 000,005,888 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\rootmdm.sys -- (ROOTMODEM)
DRV - [2003/05/15 18:41:16 | 000,019,072 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\point32.sys -- (Point32)
DRV - [2003/01/10 16:13:04 | 000,033,588 | ---- | M] (America Online, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wanatw4.sys -- (wanatw) WAN Miniport (ATW)
DRV - [2002/10/25 16:59:36 | 000,642,958 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\Intels51.sys -- (Intels51) Intel(R)
DRV - [2002/03/26 14:20:22 | 000,013,780 | ---- | M] (Padus, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\pfc.sys -- (pfc)
DRV - [2002/03/19 13:08:00 | 000,096,768 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\NVENET.sys -- (NVENET)
DRV - [2002/03/09 13:53:00 | 000,909,501 | ---- | M] (NVIDIA Corporation) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\nv4_mini.sys -- (nv)
DRV - [2002/01/16 13:43:54 | 000,415,400 | ---- | M] (Analog Devices, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\smwdm.sys -- (smwdm)
DRV - [2001/12/28 17:55:46 | 000,024,035 | ---- | M] (Compaq Computer Corp.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\eaps2kbd.sys -- (eaps2kbd) Compaq Easy Access PS2 Internet Keyboard (Win2K)
DRV - [2001/12/07 18:26:00 | 000,013,502 | ---- | M] (NVIDIA Corporation) [Kernel | Boot | Running] -- C:\WINDOWS\System32\DRIVERS\nv_agp.sys -- (nv_agp)
DRV - [2001/09/25 13:02:18 | 000,027,519 | ---- | M] (SMC2208USB/ETH) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\SMC2208.SYS -- (USB-100)
DRV - [2001/08/23 14:00:00 | 000,022,400 | ---- | M] () [Kernel | System | Running] -- C:\WINDOWS\system32\drivers\SbcpHid.sys -- (SbcpHid)
DRV - [2001/08/17 17:12:10 | 000,117,760 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\e100b325.sys -- (E100B) Intel(R)
DRV - [2001/08/17 12:57:38 | 000,016,128 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\WINDOWS\system32\drivers\MODEMCSA.sys -- (MODEMCSA)
DRV - [2001/08/09 21:26:02 | 000,022,608 | ---- | M] (America Online, Inc.) [Kernel | On_Demand | Running] -- C:\WINDOWS\system32\drivers\wandrv.sys -- (wandrv)
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search, =
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,CustomSearch = [You must be registered and logged in to see this link.]
IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Search,searched = 1
IE - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,XMLHTTP_UUID_Default = 26 E1 47 01 6E 3F 1E 4B A3 1B 45 C6 A1 C5 E3 BA [binary data]
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\CNNSI, = search.sportsillustrated.cnn.com/pages/search.jsp?query=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Dictionary, = dictionary.reference.com/search?q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Google, = google.com/search?q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\GoogleGroups, = groups-beta.google.com/groups?q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\GoogleImages, = images.google.com/images?hl=en&lr=&q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\GoogleNews, = news.google.com/news?tab=gn&hl=en&ie=UTF-8&q=%s&btnG=Search+News
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\KB, = support.microsoft.com/search/default.aspx?query=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\KBDLL, = support.microsoft.com/dllhelp/default.aspx?dlltype=file&l=55&alpha=%s&S=1
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Movies, = fandango.com/my_box_office.asp?searchby=2&txtCityZip=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\MSN, = search.msn.com/results.asp?q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Thesaurus, = thesaurus.reference.com/search?q=%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Weather, = weather.com/weather/local/%s
IE - HKCU\Software\Microsoft\Internet Explorer\SearchURL\Yahoo, = search.yahoo.com/search?p=%s
IE - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyServer" = 168.94.74.68:8080
========== FireFox ==========
FF - prefs.js..browser.search.defaultengine: "Ask.com"
FF - prefs.js..browser.search.defaultenginename: "Fast Browser Search"
FF - prefs.js..browser.search.order.1: "Fast Browser Search"
FF - prefs.js..browser.search.selectedEngine: "Fast Browser Search"
FF - prefs.js..browser.startup.homepage: "http://www.google.com/"
FF - prefs.js..extensions.enabledItems: {3f963a5b-e555-4543-90e2-c3908898db71}:9.0.0.716
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:1.2.4
FF - prefs.js..extensions.enabledItems: [You must be registered and logged in to see this link.]:2.1.4
FF - HKLM\software\mozilla\Firefox\Extensions\\{3f963a5b-e555-4543-90e2-c3908898db71}: C:\Program Files\AVG\AVG9\Firefox [2010/01/07 16:34:35 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.6\extensions\\Components: C:\Program Files\Mozilla Firefox\components [2010/01/05 00:21:31 | 000,000,000 | ---D | M]
FF - HKLM\software\mozilla\Mozilla Firefox 3.5.6\extensions\\Plugins: C:\Program Files\Mozilla Firefox\plugins [2010/01/22 20:27:50 | 000,000,000 | ---D | M]
[2009/06/01 18:59:34 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Extensions
[2010/02/02 15:40:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\extensions
[2009/09/22 21:43:41 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\extensions\personas@christopher.beard
[2009/10/12 14:23:54 | 000,000,000 | ---D | M] -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\extensions\smarterwiki@wikiatic.com
[2009/12/04 01:42:50 | 000,002,424 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\searchplugins\askcom.xml
[2009/09/14 14:16:46 | 000,009,941 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Application Data\Mozilla\Firefox\Profiles\2tis2day.default\searchplugins\mywebsearch.xml
[2010/02/02 15:40:42 | 000,000,000 | ---D | M] -- C:\Program Files\Mozilla Firefox\extensions
O1 HOSTS File: ([2010/01/12 18:49:22 | 003,781,711 | ---- | M]) - C:\WINDOWS\system32\drivers\etc\HOSTS
O1 - Hosts: 127.0.0.1 localhost #IPv4
O1 - Hosts: ::1 localhost # IPv6
O1 - Hosts: 127.0.0.1 0.gvt0.com
O1 - Hosts: 127.0.0.1 00.eatgoogle.345.pl
O1 - Hosts: 127.0.0.1 00.eatgoogle.bee.pl
O1 - Hosts: 127.0.0.1 00.eatgoogle.bij.pl
O1 - Hosts: 127.0.0.1 00.eatgoogle.orge.pl
O1 - Hosts: 127.0.0.1 00.eatgoogle.osa.pl
O1 - Hosts: 127.0.0.1 00.googleeat.345.pl
O1 - Hosts: 127.0.0.1 00.googleeat.bee.pl
O1 - Hosts: 127.0.0.1 00.googleeat.bij.pl
O1 - Hosts: 127.0.0.1 00.googleeat.orge.pl
O1 - Hosts: 127.0.0.1 00.googleeat.osa.pl
O1 - Hosts: 127.0.0.1 00.moregoogle.345.pl
O1 - Hosts: 127.0.0.1 00.moregoogle.bee.pl
O1 - Hosts: 127.0.0.1 00.moregoogle.bij.pl
O1 - Hosts: 127.0.0.1 00.moregoogle.osa.pl
O1 - Hosts: 127.0.0.1 00.w88w8w.cn
O1 - Hosts: 127.0.0.1 000.bbexe.cn
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-1-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-10-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-2-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-3-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-4-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 127.0.0.1 0-0-0-0-0-0-0-0-0-0-0-0-0-5-0-0-0-0-0-0-0-0-0-0-0-0-0.info
O1 - Hosts: 118651 more lines...
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - No CLSID value found.
O2 - BHO: (Adobe PDF Link Helper) - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll (Adobe Systems Incorporated)
O2 - BHO: (PC Tools Browser Guard BHO) - {2A0F3D1B-0909-4FF4-B272-609CCE6054E7} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll (Threat Expert Ltd.)
O2 - BHO: (AVG Safe Search) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll (AVG Technologies CZ, s.r.o.)
O2 - BHO: (no name) - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - No CLSID value found.
O2 - BHO: (Java(tm) Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll (Sun Microsystems, Inc.)
O2 - BHO: (JQSIEStartDetectorImpl Class) - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll (Sun Microsystems, Inc.)
O2 - BHO: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {0BF43445-2F28-4351-9252-17FE6E806AA0} - No CLSID value found.
O3 - HKLM\..\Toolbar: (PC Tools Browser Guard) - {472734EA-242A-422B-ADF8-83D1E48CC825} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll (Threat Expert Ltd.)
O3 - HKLM\..\Toolbar: (no name) - {DE9C389F-3316-41A7-809B-AA305ED9D922} - No CLSID value found.
O3 - HKLM\..\Toolbar: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No CLSID value found.
O3 - HKCU\..\Toolbar\ShellBrowser: (no name) - {4982D40A-C53B-4615-B15B-B5B5E98D167C} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {43F02779-6D88-4958-8AD3-83C12D86ADC7} - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (PC Tools Browser Guard) - {472734EA-242A-422B-ADF8-83D1E48CC825} - C:\Program Files\Spyware Doctor\BDT\PCTBrowserDefender.dll (Threat Expert Ltd.)
O4 - HKLM..\Run: [Adobe ARM] C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [Adobe Reader Speed Launcher] C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe (Adobe Systems Incorporated)
O4 - HKLM..\Run: [AVG9_TRAY] C:\Program Files\AVG\AVG9\avgtray.exe (AVG Technologies CZ, s.r.o.)
O4 - HKLM..\Run: [HostManager] C:\Program Files\Common Files\AOL\1155679928\EE\aolsoftware.exe (America Online, Inc.)
O4 - HKLM..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\hpwuSchd2.exe (Hewlett-Packard Development Company, L.P.)
O4 - HKLM..\Run: [ISUSScheduler] C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (Macrovision Corporation)
O4 - HKLM..\Run: [LanguageShortcut] C:\Program Files\CyberLink\PowerDVD\Language\Language.exe ()
O4 - HKLM..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe (Nero AG)
O4 - HKLM..\Run: [RemoteControl] C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe (Cyberlink Corp.)
O4 - HKLM..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre6\bin\jusched.exe (Sun Microsystems, Inc.)
O4 - HKLM..\Run: [UnlockerAssistant] C:\Program Files\Unlocker\UnlockerAssistant.exe ()
O4 - HKCU..\Run: [AlcoholAutomount] C:\Program Files\Alcohol Soft\Alcohol 120\axcmd.exe (Alcohol Soft Development Team)
O4 - HKCU..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe (Nero AG)
O4 - HKCU..\Run: [Window Washer] C:\Program Files\Webroot\Washer\wwDisp.exe (Webroot Software, Inc.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe (Hewlett-Packard Development Company, L.P.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\HP Photosmart Premier Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe (Hewlett-Packard Development Company, L.P.)
O4 - Startup: C:\Documents and Settings\All Users\Start Menu\Programs\Startup\NETGEAR WG311v3 Smart Wizard.lnk = C:\Program Files\NETGEAR\WG311v3\wlancfg5.exe ()
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoCDBurning = 0
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: DisableCAD = 0
O9 - Extra 'Tools' menuitem : Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - Reg Error: Key error. File not found
O10 - NameSpace_Catalog5\Catalog_Entries\000000000004 [] - C:\WINDOWS\system32\nwprovau.dll (Microsoft Corporation)
O15 - HKLM\..Trusted Domains: 1 domain(s) and sub-domain(s) not assigned to a zone.
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {193C772A-87BE-4B19-A7BB-445B226FE9A1} [You must be registered and logged in to see this link.] (ewidoOnlineScan Control)
O16 - DPF: {2C8EEB84-6D60-11D4-BD64-0050048A82BF} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {56762DEC-6B0D-4AB4-A8AD-989993B5D08B} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} [You must be registered and logged in to see this link.] (BDSCANONLINE Control)
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} [You must be registered and logged in to see this link.] (WUWebControl Class)
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} [You must be registered and logged in to see this link.] (MUWebControl Class)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} [You must be registered and logged in to see this link.] (Java Plug-in 1.6.0_17)
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: DirectAnimation Java Classes [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O16 - DPF: Microsoft XML Parser for Java [You must be registered and logged in to see this link.] (Reg Error: Key error.)
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
O18 - Protocol\Handler\http\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18 - Protocol\Handler\http\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18 - Protocol\Handler\https\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18 - Protocol\Handler\https\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18 - Protocol\Handler\ipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O18 - Protocol\Handler\lid {5C135180-9973-46D9-ABF4-148267CBB8BF} - Reg Error: Key error. File not found
O18 - Protocol\Handler\linkscanner {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll (AVG Technologies CZ, s.r.o.)
O18 - Protocol\Handler\msdaipp\0x00000001 {E1D2BF42-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
O18 - Protocol\Handler\msdaipp\oledb {E1D2BF40-A96B-11d1-9C6B-0000F875AC61} - Reg Error: Key error. File not found
O20 - Winlogon\Notify\!SASWinLogon: DllName - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll (SUPERAntiSpyware.com)
O20 - Winlogon\Notify\avgrsstarter: DllName - avgrsstx.dll - C:\WINDOWS\System32\avgrsstx.dll (AVG Technologies CZ, s.r.o.)
O24 - Desktop WallPaper: C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O24 - Desktop BackupWallPaper: C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
O28 - HKLM ShellExecuteHooks: {5AE067D3-9AFB-48E0-853A-EBB7F4A000DA} - C:\Program Files\SUPERAntiSpyware\SASSEH.DLL (SuperAdBlocker.com)
O32 - HKLM CDRom: AutoRun - 1
O32 - AutoRun File - [2006/04/01 22:04:18 | 000,000,000 | ---- | M] () - C:\AUTOEXEC.BAT -- [ NTFS ]
O32 - AutoRun File - [2006/08/08 09:59:46 | 000,000,000 | ---D | M] - G:\autorun -- [ FAT32 ]
O35 - comfile [open] -- "%1" %*
O35 - exefile [open] -- "%1" %*
[2010/02/02 15:40:55 | 000,548,864 | ---- | C] (OldTimer Tools) -- C:\Documents and Settings\Jonathan Murray\Desktop\OTL.exe
[2010/01/30 21:07:48 | 000,000,000 | ---D | C] -- C:\blackpudding
[2010/01/29 18:54:07 | 000,000,000 | RHSD | C] -- C:\cmdcons
[2010/01/29 17:44:17 | 000,161,792 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWREG.exe
[2010/01/29 17:44:17 | 000,031,232 | ---- | C] (NirSoft) -- C:\WINDOWS\NIRCMD.exe
[2010/01/29 17:44:16 | 000,136,704 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWSC.exe
[2010/01/29 17:44:15 | 000,212,480 | ---- | C] (SteelWerX) -- C:\WINDOWS\SWXCACLS.exe
[2010/01/27 23:25:48 | 000,000,000 | ---D | C] -- C:\ComboFix
[2010/01/21 23:28:45 | 000,000,000 | ---D | C] -- C:\Rooter$
[2010/01/21 23:27:27 | 000,173,119 | ---- | C] (Eric_71) -- C:\Program Files\Rooter.exe
[2010/01/20 23:56:28 | 001,956,528 | ---- | C] (Adobe Systems Incorporated) -- C:\Program Files\install_flash_player_ax.exe
[2010/01/20 18:30:35 | 000,073,728 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
[2010/01/20 18:30:34 | 000,149,280 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
[2010/01/20 18:30:34 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
[2010/01/20 18:30:34 | 000,145,184 | ---- | C] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
[2010/01/20 15:32:36 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\Threat Expert
[2010/01/16 14:51:26 | 000,000,000 | ---D | C] -- C:\Program Files\hpHosts
[2010/01/16 00:09:08 | 000,800,544 | ---- | C] (Sun Microsystems, Inc.) -- C:\Program Files\jre-6u17-windows-i586-iftw-rv.exe
[2010/01/16 00:05:47 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Adobe
[2010/01/15 23:55:52 | 027,386,256 | ---- | C] ( ) -- C:\Program Files\AdbeRdr930_en_US.exe
[2010/01/13 15:55:00 | 000,000,000 | ---D | C] -- C:\WINDOWS\ERDNT
[2010/01/13 15:15:07 | 000,000,000 | ---D | C] -- C:\Qoobox
[2010/01/12 21:56:12 | 000,471,552 | ---- | C] (Microsoft Corporation) -- C:\WINDOWS\System32\dllcache\aclayers.dll
[2010/01/10 23:40:02 | 001,640,400 | ---- | C] (Threat Expert Ltd.) -- C:\WINDOWS\PCTBDCore.dll
[2010/01/10 23:40:02 | 000,165,840 | ---- | C] (Threat Expert Ltd.) -- C:\WINDOWS\PCTBDRes.dll
[2010/01/10 23:40:02 | 000,149,456 | ---- | C] (PC Tools) -- C:\WINDOWS\SGDetectionTool.dll
[2010/01/10 23:04:27 | 034,628,432 | ---- | C] (PC Tools ) -- C:\Program Files\sdsetup.exe
[2010/01/07 16:39:08 | 000,000,000 | ---D | C] -- C:\$AVG
[2010/01/07 16:38:08 | 000,012,464 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgrsstx.dll
[2010/01/07 16:38:07 | 000,000,000 | ---D | C] -- C:\WINDOWS\System32\drivers\Avg
[2010/01/07 16:36:12 | 000,025,608 | ---- | C] (AVG Technologies ) -- C:\WINDOWS\System32\drivers\AVGIDSxx.sys
[2010/01/07 16:36:11 | 000,161,800 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgrkx86.sys
[2010/01/07 16:36:10 | 000,360,584 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/01/07 16:36:09 | 000,333,192 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgldx86.sys
[2010/01/07 16:36:07 | 000,028,424 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/01/07 16:34:35 | 000,050,968 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgfwdx.dll
[2010/01/07 16:34:35 | 000,030,104 | ---- | C] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgfwdx.sys
[2010/01/07 16:34:30 | 000,000,000 | ---D | C] -- C:\Program Files\AVG
[2010/01/07 16:34:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\avg9
[2010/01/07 16:27:42 | 000,000,000 | --SD | M] -- C:\Documents and Settings\NetworkService\Application Data\Microsoft
[2010/01/07 16:27:42 | 000,000,000 | --SD | M] -- C:\Documents and Settings\LocalService\Application Data\Microsoft
[2010/01/07 16:27:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft
[2010/01/07 16:27:42 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft
[2010/01/07 13:34:49 | 000,000,000 | ---D | C] -- C:\Program Files\COMODO
[2010/01/07 13:28:31 | 040,603,920 | ---- | C] (COMODO) -- C:\Program Files\CIS_Setup_3.13.125662.579_XP_Vista_x32.exe
[2010/01/07 13:00:35 | 000,891,248 | ---- | C] (AVG Technologies) -- C:\Program Files\avg_free_stb_all_9_40_cnet.exe
[2010/01/05 17:45:26 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\SUPERAntiSpyware.com
[2010/01/05 17:44:57 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jonathan Murray\Application Data\SUPERAntiSpyware.com
[2010/01/05 17:44:57 | 000,000,000 | ---D | C] -- C:\Program Files\SUPERAntiSpyware
[2010/01/05 17:44:20 | 000,000,000 | ---D | C] -- C:\Program Files\Common Files\Wise Installation Wizard
[2010/01/05 13:43:02 | 000,000,000 | ---D | C] -- C:\Documents and Settings\Jonathan Murray\Application Data\Malwarebytes
[2010/01/05 13:42:48 | 000,038,224 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/01/05 13:42:45 | 000,000,000 | ---D | C] -- C:\Documents and Settings\All Users\Application Data\Malwarebytes
[2010/01/05 13:42:36 | 000,019,160 | ---- | C] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/01/05 13:42:34 | 000,000,000 | ---D | C] -- C:\Program Files\Malwarebytes' Anti-Malware
[2010/01/05 13:40:58 | 005,061,520 | ---- | C] (Malwarebytes Corporation ) -- C:\Program Files\mbam-setup.exe
[2010/01/04 23:45:00 | 000,000,000 | RH-D | C] -- C:\Documents and Settings\Jonathan Murray\Recent
[2010/01/01 21:55:35 | 008,086,544 | ---- | C] (Mozilla) -- C:\Program Files\Firefox Setup 3.5.6.exe
[2009/12/05 01:08:42 | 214,167,816 | ---- | C] (Nero AG) -- C:\Program Files\Nero-9.4.26.0_trial.exe
[2009/12/04 18:35:40 | 002,081,039 | ---- | C] (Cucusoft, Inc. ) -- C:\Program Files\dvd-author.exe
[2009/12/04 18:29:05 | 003,119,665 | ---- | C] (Cucusoft, Inc. ) -- C:\Program Files\dvd-burner.exe
[2009/12/04 18:24:27 | 015,672,013 | ---- | C] (Any-Video-Converter.com ) -- C:\Program Files\avc-free.exe
[2009/12/04 17:56:45 | 000,047,360 | ---- | C] (VSO Software) -- C:\Documents and Settings\Jonathan Murray\Application Data\pcouffin.sys
[2009/12/04 17:52:35 | 018,026,336 | ---- | C] (VSO-Software ) -- C:\Program Files\vsoConvertXtoDVD4_setup.exe
[2009/12/04 14:49:15 | 023,804,080 | ---- | C] (DivX, Inc.) -- C:\Program Files\DivXInstaller.exe
[2009/12/04 14:14:00 | 006,104,788 | ---- | C] (Burnaware Technologies ) -- C:\Program Files\burnaware_free242.exe
[2009/12/02 18:12:06 | 008,084,968 | ---- | C] (Mozilla) -- C:\Program Files\Firefox Setup 3.5.5.exe
[2009/11/13 14:18:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Local Settings\Application Data\qqrcuppz
[2009/11/13 14:18:05 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Application Data\qqrcuppz
[2009/10/07 15:01:32 | 003,340,064 | ---- | C] (Unity Technologies ApS) -- C:\Program Files\UnityWebPlayer.exe
[2009/09/15 14:42:01 | 025,685,128 | ---- | C] (Microsoft Corporation) -- C:\Program Files\wordview_en-us.exe
[2009/09/04 14:47:45 | 011,729,274 | ---- | C] (AGBO Business Architecture S.L. ) -- C:\Program Files\installeasyjob.exe
[2009/09/02 14:29:16 | 008,050,536 | ---- | C] (Mozilla) -- C:\Program Files\Firefox Setup 3.5.2.exe
[2009/07/20 16:43:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Application Data\Macromedia
[2009/07/20 16:43:36 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Application Data\Adobe
[2009/07/07 18:45:58 | 000,359,656 | ---- | C] (Microsoft Corporation) -- C:\Program Files\msicuu2.exe
[2009/06/02 03:50:19 | 000,000,000 | ---D | M] -- C:\Documents and Settings\NetworkService\Application Data\Mozilla
[2009/02/15 23:28:41 | 016,939,888 | ---- | C] (Microsoft Corporation) -- C:\Program Files\IE8-WindowsXP-x86-ENU.exe
[2008/12/13 22:16:06 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Roxio
[2008/11/23 12:56:50 | 025,740,144 | ---- | C] (Microsoft Corporation) -- C:\Program Files\wmp11-windowsxp-x86-enu.exe
[2008/07/03 19:21:54 | 001,445,888 | ---- | C] (Option^Explicit Software Solutions) -- C:\Program Files\WinsockxpFix.exe
[2008/05/30 21:07:36 | 009,723,880 | ---- | C] (Safer Networking Limited ) -- C:\Program Files\spybotsd152.exe
[2008/05/28 19:21:48 | 001,244,712 | ---- | C] (Microsoft Corporation) -- C:\Program Files\SetupOneCare.exe
[2008/05/08 22:44:32 | 010,121,656 | ---- | C] (Alcohol Soft) -- C:\Program Files\Alcohol120_trial_1.9.7.6221.exe
[2008/04/06 12:28:37 | 000,569,777 | ---- | C] ( ) -- C:\Program Files\DVD43_4-2-0_Setup.exe
[2008/01/05 13:20:19 | 003,381,280 | ---- | C] (Lime Wire LLC) -- C:\Program Files\LimeWireWin.exe
[2007/10/18 18:12:13 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\McAfee
[2007/10/09 18:11:21 | 000,014,992 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\winddx.sys
[2007/10/08 18:22:30 | 001,395,296 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\mtlstrm.sys
[2007/10/08 18:22:30 | 000,652,360 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\slntamr.sys
[2007/10/08 18:22:30 | 000,231,224 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\mtlmnt5.sys
[2007/10/08 18:22:30 | 000,100,384 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\slnthal.sys
[2007/10/08 18:22:30 | 000,014,408 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\RecAgent.sys
[2007/10/08 18:22:30 | 000,013,232 | ---- | C] ( ) -- C:\WINDOWS\System32\drivers\slwdmsup.sys
[2006/12/02 11:03:27 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Local Settings\Application Data\AOL
[2006/06/12 13:48:46 | 001,160,885 | ---- | C] (Fengtao Software Inc. ) -- C:\Program Files\DVDRegionFree59.exe
[2006/05/09 21:34:43 | 000,000,000 | ---D | M] -- C:\Documents and Settings\LocalService\Application Data\Macromedia
[2006/03/12 16:49:48 | 003,457,413 | ---- | C] (LG Software Innovations ) -- C:\Program Files\1clickdvdcopysetup.exe
[2006/03/12 14:17:32 | 000,521,403 | ---- | C] ( ) -- C:\Program Files\DVD43_3-7-0_Setup.exe
[2005/09/23 21:14:13 | 024,265,736 | ---- | C] (Microsoft) -- C:\Program Files\dotnetfx.exe
[2005/03/03 16:35:53 | 020,798,256 | ---- | C] (Netopsystems AG ) -- C:\Program Files\AdbeRdr70_enu_full.exe
[2005/01/12 16:05:48 | 000,090,112 | ---- | C] ( ) -- C:\WINDOWS\System32\SCCD3X02.DLL
[2005/01/09 17:39:22 | 002,145,414 | ---- | C] (Kodak) -- C:\Program Files\OneTouch.exe
[2005/01/07 21:48:05 | 004,354,084 | ---- | C] (Safer Networking Limited ) -- C:\Program Files\spybotsd13.exe
[45 C:\WINDOWS\System32\*.tmp files -> C:\WINDOWS\System32\*.tmp -> ]
[361 C:\WINDOWS\*.tmp files -> C:\WINDOWS\*.tmp -> ]
[25 C:\WINDOWS\System32\dllcache\*.tmp files -> C:\WINDOWS\System32\dllcache\*.tmp -> ]
[1 C:\*.tmp files -> C:\*.tmp -> ]
[2010/02/02 15:36:31 | 000,000,000 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Local Settings\Application Data\prvlcl.dat
[2010/02/01 21:46:36 | 000,025,088 | ---- | M] () -- C:\neoLogitCore.lo_
[2010/02/01 21:43:47 | 000,000,458 | ---- | M] () -- C:\WINDOWS\tasks\RegCure Program Check.job
[2010/02/01 21:43:43 | 000,000,006 | -H-- | M] () -- C:\WINDOWS\tasks\SA.DAT
[2010/02/01 21:43:38 | 000,002,048 | --S- | M] () -- C:\WINDOWS\bootstat.dat
[2010/02/01 21:43:37 | 502,751,232 | -HS- | M] () -- C:\hiberfil.sys
[2010/02/01 14:22:10 | 054,966,920 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\incavi.avm
[2010/02/01 12:48:24 | 000,001,374 | ---- | M] () -- C:\WINDOWS\System32\wpa.dbl
[2010/01/31 01:35:18 | 000,000,240 | ---- | M] () -- C:\WINDOWS\system.ini
[2010/01/30 19:37:28 | 003,840,721 | R--- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\blackpudding.bat
[2010/01/30 00:49:47 | 007,946,240 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\ntuser.dat
[2010/01/30 00:49:05 | 000,000,178 | -HS- | M] () -- C:\Documents and Settings\Jonathan Murray\ntuser.ini
[2010/01/29 21:20:59 | 000,562,709 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\iavifw.avm
[2010/01/29 18:54:16 | 000,000,281 | RHS- | M] () -- C:\boot.ini
[2010/01/25 20:50:15 | 000,100,908 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\SystemLook.exe
[2010/01/24 17:32:53 | 502,788,096 | ---- | M] () -- C:\WINDOWS\MEMORY.DMP
[2010/01/24 14:04:55 | 000,284,915 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\gmer.zip
[2010/01/23 00:08:55 | 000,001,000 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\internetFIX.reg
[2010/01/23 00:00:14 | 000,390,438 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\QuickRestoreMaker.zip
[2010/01/21 23:27:40 | 000,173,119 | ---- | M] (Eric_71) -- C:\Program Files\Rooter.exe
[2010/01/21 03:00:05 | 000,000,392 | ---- | M] () -- C:\WINDOWS\tasks\RegCure.job
[2010/01/20 23:56:41 | 001,956,528 | ---- | M] (Adobe Systems Incorporated) -- C:\Program Files\install_flash_player_ax.exe
[2010/01/20 18:29:09 | 000,149,280 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaws.exe
[2010/01/20 18:29:09 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javaw.exe
[2010/01/20 18:29:09 | 000,145,184 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\java.exe
[2010/01/20 18:29:09 | 000,073,728 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\javacpl.cpl
[2010/01/20 18:29:08 | 000,411,368 | ---- | M] (Sun Microsystems, Inc.) -- C:\WINDOWS\System32\deploytk.dll
[2010/01/20 00:56:58 | 000,142,495 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\microavi.avg
[2010/01/17 21:54:10 | 000,595,499 | ---- | M] () -- C:\Program Files\Autoruns.zip
[2010/01/16 00:09:16 | 000,800,544 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files\jre-6u17-windows-i586-iftw-rv.exe
[2010/01/16 00:06:42 | 000,001,729 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Adobe Reader 9.lnk
[2010/01/15 23:59:17 | 027,386,256 | ---- | M] ( ) -- C:\Program Files\AdbeRdr930_en_US.exe
[2010/01/15 17:07:17 | 000,843,187 | ---- | M] () -- C:\Program Files\SecurityCheck.exe
[2010/01/14 18:13:47 | 002,672,312 | ---- | M] () -- C:\Program Files\esetsmartinstaller_enu.exe
[2010/01/13 12:54:09 | 000,000,354 | ---- | M] () -- C:\WINDOWS\wininit.ini
[2010/01/13 00:24:18 | 000,000,000 | ---- | M] () -- C:\qinfo.dat
[2010/01/12 23:24:07 | 000,001,374 | ---- | M] () -- C:\WINDOWS\imsins.BAK
[2010/01/12 18:49:22 | 003,781,711 | ---- | M] () -- C:\WINDOWS\System32\drivers\etc\HOSTS
[2010/01/11 13:32:44 | 000,000,933 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\Desktop\Spybot - Search & Destroy.lnk
[2010/01/10 23:15:46 | 000,001,637 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\Spyware Doctor.lnk
[2010/01/10 23:08:51 | 034,628,432 | ---- | M] (PC Tools ) -- C:\Program Files\sdsetup.exe
[2010/01/07 16:38:21 | 000,113,461 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\iavichjw.avm
[2010/01/07 16:38:09 | 000,001,507 | ---- | M] () -- C:\Documents and Settings\All Users\Desktop\AVG 9.0.lnk
[2010/01/07 16:38:08 | 000,012,464 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgrsstx.dll
[2010/01/07 16:38:07 | 006,061,540 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\avi7.avg
[2010/01/07 16:38:07 | 000,492,629 | ---- | M] () -- C:\WINDOWS\System32\drivers\Avg\miniavi.avg
[2010/01/07 16:36:12 | 000,025,608 | ---- | M] (AVG Technologies ) -- C:\WINDOWS\System32\drivers\AVGIDSxx.sys
[2010/01/07 16:36:11 | 000,161,800 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgrkx86.sys
[2010/01/07 16:36:10 | 000,360,584 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgtdix.sys
[2010/01/07 16:36:09 | 000,333,192 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgldx86.sys
[2010/01/07 16:36:08 | 000,028,424 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgmfx86.sys
[2010/01/07 16:34:35 | 000,050,968 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\avgfwdx.dll
[2010/01/07 16:34:35 | 000,030,104 | ---- | M] (AVG Technologies CZ, s.r.o.) -- C:\WINDOWS\System32\drivers\avgfwdx.sys
[2010/01/07 16:07:14 | 000,038,224 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbamswissarmy.sys
[2010/01/07 16:07:04 | 000,019,160 | ---- | M] (Malwarebytes Corporation) -- C:\WINDOWS\System32\drivers\mbam.sys
[2010/01/07 15:25:38 | 000,163,713 | ---- | M] () -- C:\WINDOWS\System32\drivers\sfi.dat
[2010/01/07 14:53:23 | 000,000,130 | ---- | M] () -- C:\WINDOWS\cfplogvw.INI
[2010/01/07 13:33:07 | 040,603,920 | ---- | M] (COMODO) -- C:\Program Files\CIS_Setup_3.13.125662.579_XP_Vista_x32.exe
[2010/01/07 13:00:36 | 000,891,248 | ---- | M] (AVG Technologies) -- C:\Program Files\avg_free_stb_all_9_40_cnet.exe
[2010/01/06 00:50:20 | 000,057,525 | ---- | M] () -- C:\Documents and Settings\Jonathan Murray\My Documents\the rev.jpg
[2010/01/05 17:45:03 | 000,000,780 | ---- | M] () -- C:\Documents and Settings\All
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 3rd February 2010, 4:01 am
OTL Extras logfile created on: 02/02/2010 3:44:34 PM - Run 1
File Age = 30 Days
Output = Standard
batfile [open] -- "%1" %*
cmdfile [open] -- "%1" %*
htmlfile [edit] -- "C:\Program Files\Microsoft Office\OFFICE11\msohtmed.exe" %1 (Microsoft Corporation)
htmlfile [open] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" -nohome (Microsoft Corporation)
htmlfile [opennew] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" %1 (Microsoft Corporation)
http [open] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" -nohome (Microsoft Corporation)
https [open] -- "C:\Program Files\Mozilla Firefox\firefox.exe" -requestPending -osint -url "%1" (Mozilla Corporation)
piffile [open] -- "%1" %*
scrfile [config] -- "%1"
scrfile [open] -- "%1" /S
Directory [cmd] -- cmd.exe /k "cd %L" (Microsoft Corporation)
Applications\iexplore.exe [open] -- "C:\Program Files\Internet Explorer\IEXPLORE.EXE" %1 (Microsoft Corporation)
CLSID\{871C5380-42A0-1069-A2EA-08002B30309D} [OpenHomePage] -- "%programfiles%\internet explorer\iexplore.exe" (Microsoft Corporation)
"UpdatesDisableNotify" = 0
"AntiVirusOverride" = 0
"FirewallOverride" = 0
"AntiVirusDisableNotify" = 0
"FirewallDisableNotify" = 0
"139:TCP" = 139:TCP:*:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:*:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:*:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:*:Enabled:@xpsp2res.dll,-22002
"1900:UDP" = 1900:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22007
"2869:TCP" = 2869:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22008
"139:TCP" = 139:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22004
"445:TCP" = 445:TCP:LocalSubNet:Enabled:@xpsp2res.dll,-22005
"137:UDP" = 137:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22001
"138:UDP" = 138:UDP:LocalSubNet:Enabled:@xpsp2res.dll,-22002
"{03CE1BCB-03F5-4C6A-B37E-69799AA3C544}" = SpyHunter
"{073F22CE-9A5B-4A40-A604-C7270AC6BF34}" = ESSSONIC
"{0A65A3BD-54B5-4d0d-B084-7688507813F5}" = SlideShow
"{0AB76F69-E761-4CFA-B9B0-A1906B4E9E4B}" = WD Diagnostics
"{121634B0-2F4B-11D3-ADA3-00C04F52DD52}" = Windows Installer Clean Up
"{13F3917B56CD4C25848BDC69916971BB}" = DivX Converter
"{14D4ED84-6A9A-45A0-96F6-1753768C3CB5}" = ESSPCD
"{15C0AF59-4877-49B6-B8C6-A61CE54515F5}" = cp_OnlineProjectsConfig
"{18D10072035C4515918F7E37EAFAACFC}" = AutoUpdate
"{1A9DEF19-760C-4e01-958F-D9B8E6C61B90}" = c5100_Help
"{1D53B6F9-E66E-42D8-A221-4FF8AC134FD7}" = Roxio Activation Module
"{1FBF6C24-C1FD-4101-A42B-0C564F9E8E79}" = DVD Suite
"{2070269D-EC38-49E6-8E3E-46B36DA8AE96}" = ArcSoft ShowBiz
"{2376813B-2E5A-4641-B7B3-A0D5ADB55229}" = HPPhotoSmartExpress
"{238B8820-011B-11D6-9C28-0080C85A0C2D}" = Microtek LightLid 35 Calibrator
"{24ED4D80-8294-11D5-96CD-0040266301AD}" = FinePixViewer Ver.3.2
"{26A24AE4-039D-4CA4-87B4-2F83216017FF}" = Java(TM) 6 Update 17
"{2B04D44F-1D1B-4E0E-8431-D04F87C21033}" = Nero 7 Essentials
"{2D03B6F8-DF36-4980-B7B6-5B93D5BA3A8F}" = essvatgt
"{2F58D60D-2BFD-4467-9B4D-64E7355C329D}" = Sonic_PrimoSDK
"{3383136B-4F86-4F05-8612-DD4BB16A1EAE}" = Roxio Creator 2009
"{33BF0960-DBA3-4187-B6CC-C969FCFA2D25}" = SkinsHP1
"{33CF58F5-48D8-4575-83D6-96F574E4D83A}" = Nero DriveSpeed
"{359CFC0A-BEB1-440D-95BA-CF63A86DA34F}" = Nero Recode
"{363790D2-DA98-41DD-9C9F-69FA36B169DE}" = PanoStandAlone
"{368BA326-73AD-4351-84ED-3C0A7A52CC53}" = Nero Rescue Agent
"{3AAA02DF-8638-4290-8BBC-83488C961D00}" = Ringtone Ripper
"{3F92ABBB-6BBF-11D5-B229-002078017FBF}" = NetWaiting
"{3FC7CBBC4C1E11DCA1A752EA55D89593}" = DivX Version Checker
"{41E776A5-9B12-416D-9A12-B4F7B044EBED}" = CP_Package_Basic1
"{42938595-0D83-404D-9F73-F8177FDD531A}" = ESScore
"{43E39830-1826-415D-8BAE-86845787B54B}" = Nero Vision
"{4537EA4B-F603-4181-89FB-2953FC695AB1}" = netbrdg
"{4A7FDA4D-F4D7-4A49-934A-066D59A43C7E}" = SmartSound Quicktracks Plugin
"{5316DFC9-CE99-4458-9AB3-E8726EDE0210}" = skin0001
"{53661815-565E-4553-9D1A-D0666336B1C9}" = ArcSoft Software Suite
"{53EE9E42-CECB-4C92-BF76-9CA65DAF8F1C}" = FullDPAppQFolder
"{546C7D0B-1E12-4573-BCD0-F5B0D3C66A74}" = ArcSoft PhotoImpression 4
"{5490882C-6961-11D5-BAE5-00E0188E010B}" = FUJIFILM USB Driver
"{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
"{5721A8EA-A30F-4F66-9046-3F40C43AE1DC}" = Driver Detective
"{595A3116-40BB-4E0F-A2E8-D7951DA56270}" = NeroExpress
"{5A06423A-210C-49FB-950E-CB0EB8C5CEC7}" = Roxio BackOnTrack
"{5E835305-63BB-4E55-BBB7-EEBBE67774DB}" = MyDVD
"{5EE7D259-D137-4438-9A5F-42F432EC0421}" = VC80CRTRedist - 8.0.50727.4053
"{605A4E39-613C-4A12-B56F-DEFBE6757237}" = SHASTA
"{60B2315F-680F-4EB3-B8DD-CCDC86A7CCAB}" = Roxio File Backup
"{62AC81F6-BDD3-4110-9D36-3E9EAAB40999}" = Nero CoverDesigner
"{643EAE81-920C-4931-9F0B-4B343B225CA6}" = ESSBrwr
"{66910000-8B30-4973-A159-6371345AFFA5}" = WebReg
"{6696D9A4-28A8-4F5A-8E9A-2E8974C8C39C}" = RandMap
"{6811CAA0-BF12-11D4-9EA1-0050BAE317E1}" = PowerDVD
"{68763C27-235D-4165-A961-FDEA228CE504}" = AiOSoftwareNPI
"{6909F917-5499-482e-9AA1-FAD06A99F231}" = Toolbox
"{69CBBEAC-4F50-4839-A5AF-58D5D6D46D4A}_is1" = Spyhunter Compact OS 1.0b
"{70014586-7BBA-4A92-A610-CDC896C48F8F}" = NETGEAR WG311v3 PCI Adapter
"{736C803C-DD3B-4015-BC51-AFB9E67B9076}" = Readme
"{7748AC8C-18E3-43BB-959B-088FAEA16FB2}" = Nero StartSmart
"{7829DB6F-A066-4E40-8912-CB07887C20BB}" = Nero BurnRights
"{7B63B2922B174135AFC0E1377DD81EC2}" = DivX Codec
"{7C03270C-4FAB-4F5C-B10D-52FEDA190790}" = DocumentViewerQFolder
"{7de0d388-613e-4175-be94-ae8f9cd0ee72}" = Nero 9 Trial
"{7E7B7865-6C80-4373-8BC1-C2EB9431F9DE}" = ProductContextNPI
"{8331C3EA-0C91-43AA-A4D4-27221C631139}" = Status
"{869200DB-287A-4DC0-B02B-2B6787FBCD4C}" = Nero DiscSpeed
"{870815CA-6B60-47B6-88DD-A67F42D2F03E}" = GPL MPEG-1/2 DirectShow Decoder Filter
"{87E2B986-07E8-477a-93DC-AF0B6758B192}" = DocProcQFolder
"{8943CE61-53BD-475E-90E1-A580869E98A2}" = staticcr
"{8A4CE7FD-9657-4B06-9943-E1819F3D5D67}" = DocProc
"{8A502E38-29C9-49FA-BCFA-D727CA062589}" = ESSTOOLS
"{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
"{8CE4E6E9-9D55-43FB-9DDB-688C976BFC05}" = Unload
"{8E92D746-CD9F-4B90-9668-42B74C14F765}" = ESSini
"{90850409-6000-11D3-8CFE-0150048383C9}" = Microsoft Office Word Viewer 2003
"{91517631-A9F3-4B7C-B482-43E0068FD55A}" = ESSgui
"{996512CF-F35B-48DE-9291-557FA5316967}" = ScannerCopy
"{999D43F4-9709-4887-9B1A-83EBB15A8370}" = VPRINTOL
"{9CB4FEE2-7F47-11D4-B6AD-00A0CC624550}" = ModemXpert
"{9E82B934-9A25-445B-B8DF-8012808074AC}" = Nero PhotoSnap
"{A0AF08BA-3630-4505-BFB2-A41F3837B0D0}" = SFR2
"{A209525B-3377-43F4-B886-32F6B6E7356F}" = Nero WaveEditor
"{A29800BA-0BF1-4E63-9F31-DF05A87F4104}" = InstantShareDevices
"{A8F2089B-1F79-4BF6-B385-A2C2B0B9A74D}" = ImagXpress
"{A96E97134CA649888820BCDE5E300BBD}" = H.264 Decoder
"{AA749D64-3741-4D5F-B804-B0BC05D179D1}" = Roxio CinePlayer
"{AAC389499AEF40428987B3D30CFC76C9}" = MKV Splitter
"{AB5D51AE-EBC3-438D-872C-705C7C2084B0}" = DeviceManagementQFolder
"{AC76BA86-7AD7-1033-7B44-A93000000001}" = Adobe Reader 9.3
"{ADB54615-A0E2-40F8-9C5E-FD8513472ED3}" = Compaq SetRefresh
"{AE1FA02D-E6A4-4EA0-8E58-6483CAC016DD}" = ESSCDBK
"{AEF9DC35ADDF4825B049ACBFD1C6EB37}" = AAC Decoder
"{AF9E97C1-7431-426D-A8D5-ABE40995C0B1}" = DirectX 9 Runtime
"{B13A7C41581B411290FBC0395694E2A9}" = DivX Converter
"{B162D0A6-9A1D-4B7C-91A5-88FB48113C45}" = OfotoXMI
"{B1ADF008-E898-4FE2-8A1F-690D9A06ACAF}" = DolbyFiles
"{B2157760-AA3C-4E2E-BFE6-D20BC52495D9}" = cp_PosterPrintConfig
"{B2EC4A38-B545-4A00-8214-13FE0E915E6D}" = Advertising Center
"{B3B9BC18-2A09-4728-9B46-12E85FF3F628}" = C5100
"{B4092C6D-E886-4CB2-BA68-FE5A88D31DE6}_is1" = Spybot - Search & Destroy
"{B4B44FE7-41FF-4DAD-8C0A-E406DDA72992}" = CCScore
"{B5C24E20-E776-4E5C-8EAD-CA5B7B895848}" = Hallmark Card Studio 2 Standard
"{B6286A44-7505-471A-A72B-04EC2DB2F442}" = CueTour
"{B69CFE29-FD03-4E0A-87A7-6ED97F98E5B3}" = CP_Panorama1Config
"{B7050CBDB2504B34BC2A9CA0A692CC29}" = DivX Plus Web Player
"{B78120A0-CF84-4366-A393-4D0A59BC546C}" = Menu Templates - Starter Kit
"{B7A0CE06-068E-11D6-97FD-0050BACBF861}" = PowerProducer
"{BB85ED9C-AFC9-43BD-B8DC-258C3C7DF72E}" = HP Software Update
"{BD5CA0DA-71AD-43DA-B19E-6EEE0C9ADC9A}" = Nero ControlCenter
"{BDBE2F3E-42DB-4d4a-8CB1-19BA765DBC6C}" = HP Photosmart, Officejet and Deskjet 7.0.A
"{C0A23442-6214-11D3-8CDF-0080C768385C}" = Encarta Online
"{C0FE37FA-0886-4B66-B01B-76CF70FB77AB}" = Roxio CinePlayer Decoder Pack
"{C1939820-A945-11D4-86F6-0001031E5712}" = InterVideo WinDVD
"{C1C6767D-B395-43CB-BF99-051B58B86DA6}" = PhotoGallery
"{C4C1AFCD-2C72-48B4-AE2E-A7354A525E87}" = Compaq Advisor
"{C5A7CB6C-E76D-408F-BA0E-85605420FE9D}" = SoundTrax
"{C8753E28-2680-49BF-BD48-DD38FD086EFE}" = AiO_Scan_CDA
"{CAAD3C25-8664-11D5-BEAF-0010B5557565}" = Ulead DVD PictureShow SE Basic
"{CC8E94A2-55C7-4460-953C-2A790180578C}" = LightScribe System Software
"{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware Professional
"{D025A639-B9C9-417D-8531-208859000AF8}" = NeroBurningROM
"{D32470A1-B10C-4059-BA53-CF0486F68EBC}" = Kodak EasyShare software
"{D3AA158A-9421-4883-8767-E771B0964A1D}" = ImageMixer VCD for FinePix
"{D9DCF92E-72EB-412D-AC71-3B01276E5F8B}" = Nero ShowTime
"{DB02F716-6275-42E9-B8D2-83BA2BF5100B}" = SFR
"{DBC20735-34E6-4E97-A9E5-2066B66B243D}" = TrayApp
"{E1B80DEE-A795-4258-8445-074C06AE3AB8}" = MarketResearch
"{E38E1721-7FE7-11D4-A898-0000E83DCDA6}" = Ulead Photo Explorer 7.0 SE
"{E498385E-1C51-459A-B45F-1721E37AA1A0}" = Movie Templates - Starter Kit
"{E79987F0-0E34-42CC-B8FF-6C860AEEB26A}" = tooltips
"{E8A80433-302B-4FF1-815D-FCC8EAC482FF}" = Nero Installer
"{ED2C557E-9C18-41FF-B58E-A05EEF0B3B5F}" = CP_CalendarTemplates1
"{F0A37341-D692-11D4-A984-009027EC0A9C}" = SoundMAX
"{F157460F-720E-482f-8625-AD7843891E5F}" = InstantShareDevicesMFC
"{F1BA3CD5-89DC-4273-8603-A75F33E9B335}" = Nokia Connectivity Adapter Cable DKU-5
"{F22C222C-3CE2-4A4B-A83F-AF4681371ABE}" = kgcbase
"{F3760724-B29D-465B-BC53-E5D72095BCC4}" = Scan
"{F4A2E7CC-60CA-4AFA-B67F-AD5E58173C3F}" = SKINXSDK
"{F6076EF9-08E1-442F-B6A2-BFB61B295A14}" = Fax_CDA
"{F8D0829C-9C6F-11D3-8080-00C04FA329AA}" = Microsoft Works 6.0
"{F9593CFB-D836-49BC-BFF1-0E669A411D9F}" = WIRELESS
"{FB15E224-67C3-491F-9F5C-F257BC418412}" = Destinations
"{FBB980B0-63F8-4B48-8D65-90F1D9F81D9F}" = NewCopy_CDA
"{FBCDFD61-7DCF-4E71-9226-873BA0053139}" = Nero InfoTool
"{FCDB1C92-03C6-4C76-8625-371224256091}" = ESSPDock
"{FE7E1DD7-EBCE-4696-ADE2-22BDBF2372DA}" = DocumentViewer
"AC3Filter" = AC3Filter (remove only)
"Ad-aware 6 Personal" = Ad-aware 6 Personal
"Adobe PhotoDeluxe Home Edition 4.0" = Adobe PhotoDeluxe Home Edition 4.0
"Any Video Converter_is1" = Any Video Converter 3.0.1
"AOL Uninstaller" = AOL Uninstaller (Choose which Products to Remove)
"AVG9Uninstall" = AVG 9.0
"AVP09" = AVP09
"BitTorrent" = BitTorrent
"Browser Defender_is1" = Browser Defender 2.0.6.11
"Canon PhotoStitch 3.1" = Canon Utilities PhotoStitch 3.1
"CANONBJ_Deinstall_CNMS300.CPD" = Canon S300
"CCleaner" = CCleaner (remove only)
"CD/DVD-ROM Generator" = CD/DVD-ROM Generator 1.20
"Cucusoft MPEG to DVD Author_is1" = Cucusoft MPEG to DVD Author 1.09
"DivX Plus DirectShow Filters" = DivX Plus DirectShow Filters
"DVD Decrypter" = DVD Decrypter (Remove Only)
"DVD43_is1" = DVD43 v4.2.0
"HP Document Viewer" = HP Document Viewer 7.0
"HP Imaging Device Functions" = HP Imaging Device Functions 7.0
"HP Photo & Imaging" = HP Photosmart Premier Software 6.5
"HPExtendedCapabilities" = HP Customer Participation Program 7.0
"HPOCR" = OCR Software by I.R.I.S 7.0
"InstallShield_{4A7FDA4D-F4D7-4A49-934A-066D59A43C7E}" = SmartSound Quicktracks Plugin
"InstallShield_{70014586-7BBA-4A92-A610-CDC896C48F8F}" = NETGEAR WG311v3 PCI Adapter
"InterActual Player" = InterActual Player
"LimeWire" = LimeWire 4.16.6
"M8 Free Multi Clipboard" = M8 Free Multi Clipboard
"Mozilla Firefox (3.5.6)" = Mozilla Firefox (3.5.6)
"mr7910_32bb2befe1e5d1d6012329af0300b36139b7b84a" = Windows Driver Package - (mr7910) Image 06/28/2005 1.3.0.0
"NVIDIA" = NVIDIA Windows 2000/XP Display Drivers
"RegCure" = RegCure 1.5.0.1
"RegistryBooster 2_is1" = Uniblue RegistryBooster 2
"SLAMRNTV" = Smart Link 56K Voice Modem
"Spybot - Search & Destroy_is1" = Spybot - Search & Destroy 1.3
"Spyware Doctor" = Spyware Doctor 7.0
"Unlocker" = Unlocker 1.8.8
"WIC" = Windows Imaging Component
"Window Washer" = Window Washer
"XpsEPSC" = XML Paper Specification Shared Components Pack 1.0
"ZoomBrowserEXDeInstall" = Canon Utilities ZoomBrowser EX
[ Application Events ]
Error - 01/27/2010 6:26:58 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (2628) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
for read / write access failed with system error 32 (0x00000020): "The process
cannot access the file because it is being used by another process. ". The open
file operation will fail with error -1032 (0xfffffbf8).
Error - 01/27/2010 6:27:33 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (1184) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
Error - 01/27/2010 6:28:05 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (2712) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
Error - 01/27/2010 6:28:37 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (3492) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
Error - 01/27/2010 6:29:08 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (4084) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
Error - 01/27/2010 6:29:43 PM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = wuauclt (2428) An attempt to open the file "C:\WINDOWS\SoftwareDistribution\DataStore\DataStore.edb"
Error - 01/27/2010 8:45:40 PM | Computer Name = JONATHAN | Source = MsiInstaller | ID = 11706
Description = Product: Roxio CinePlayer -- Error 1706. An installation package for
the product Roxio CinePlayer cannot be found. Try the installation again using
a valid copy of the installation package 'CP.MSI'.
Error - 01/27/2010 8:46:04 PM | Computer Name = JONATHAN | Source = MsiInstaller | ID = 11706
Description = Product: Roxio CinePlayer Decoder Pack -- Error 1706. An installation
package for the product Roxio CinePlayer Decoder Pack cannot be found. Try the
installation again using a valid copy of the installation package 'CPDP.msi'.
Error - 02/02/2010 2:32:00 AM | Computer Name = JONATHAN | Source = ESENT | ID = 490
Description = svchost (172) An attempt to open the file "C:\WINDOWS\system32\CatRoot2\edb.chk"
Error - 02/02/2010 2:32:00 AM | Computer Name = JONATHAN | Source = ESENT | ID = 439
Description = Catalog Database (172) Unable to write a shadowed header for file
C:\WINDOWS\system32\CatRoot2\edb.chk. Error -1032.
[ System Events ]
Error - 01/16/2010 12:26:03 AM | Computer Name = JONATHAN | Source = Service Control Manager | ID = 7023
Description = The Application Management service terminated with the following error:
%%126
%%126
Error - 01/16/2010 12:26:04 AM | Computer Name = JONATHAN | Source = Service Control Manager | ID = 7023
%%126
%%126
%%126
%%126
%%126
%%126
%%126
%%126
Thebeast28
Posts Posts : 159
Post by Dr Jay on 3rd February 2010, 3:46 pm
Please run OTL.exe.
    :otl
  • Close OTL.exe
Do you recognize this entry, proxy server:
If not, please copy the bolded line and place it in to the other ones above.
Posts Posts : 13810
Points Points : 302437
Post by Thebeast28 on 3rd February 2010, 11:17 pm
========== OTL ==========
Prefs.js: "Ask.com" removed from browser.search.defaultengine
Prefs.js: "Fast Browser Search" removed from browser.search.defaultenginename
Prefs.js: "Fast Browser Search" removed from browser.search.order.1
Prefs.js: "Fast Browser Search" removed from browser.search.selectedEngine
HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyServer| /E : value set successfully!
OTL by OldTimer - Version 3.1.27.1 log created on 02032010_181551
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 3rd February 2010, 11:19 pm
Is my computer going to work after doing all that you told me. Is going to stop freezing up and running slow. I'm I going to be able to get on the internet firefox without any problem like never loading, freezing or being slow?
Thebeast28
Posts Posts : 159
Post by Dr Jay on 4th February 2010, 3:27 am
Hopefully.
What antivirus software do you have installed? Any...
Posts Posts : 13810
Post by Thebeast28 on 4th February 2010, 10:13 pm
I got AVG 9.0 but its about to expire cause it is the free one. I also have AVP 2009 which I bought. Other programs I have Spybot Search and Destroy, Ad-ware 6.0, Malwarebytes' Anti-Malware, SUPERAntiSpyware Professional, Spyhunter but it is expired and Spyware Doctor. Which programs or what should i do to stop this from happening agian? My homepage still want load sometime.
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 4th February 2010, 10:14 pm
Is it safe to be using Limewire and BitTorrent to download?
Thebeast28
Posts Posts : 159
Post by Dr Jay on 5th February 2010, 12:55 am
Please remove Spyware Doctor, Spybot, and Ad-Aware.
Then, download an upgrade copy of AVG from [You must be registered and logged in to see this link.]
Please do a full scan with it and post a log if available.
Posts Posts : 13810
Post by Thebeast28 on 5th February 2010, 11:01 pm
So you want me to buy AVG 9.0 i don't have no money right now to buy it. I can unistall avg and download the free one again.
My Firefox internet is still slow it freezes up when i click on something then i have to wait awhile for it to unfreeze. I have satellite internet and my dad has it connected to his computer. I just running off of it with a router and my mom has a wi-fi laptop running off my router. For some reason like right now my moms laptop is on the internet and my computer is running fast. Is her laptop running off mine have anything to do with my internet running slow or does her laptop need to be connected to the internet for mine to be fast. She is running off of my router.
Thebeast28
Posts Posts : 159
Post by Dr Jay on 5th February 2010, 11:57 pm
No. If your "free" subscription ran out in AVG, it is usually because the version is out of date.
I want you to download the newest FREE version from the website FREE.avg.com
Posts Posts : 13810
Post by Thebeast28 on 6th February 2010, 9:37 pm
Can't install the new version of AVG or unistall the expired one. I get an error message.
Local machine: installation failed
Installation:
Error: Action failed for registry key HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows: creating registry key....
Access is denied.
Thebeast28
Posts Posts : 159
Post by Dr Jay on 7th February 2010, 4:08 am
Download and run avgremover.exe
For 32-Bit, Download: [You must be registered and logged in to see this link.]
Then, try to reinstall again. Let me know what you come up with.
Posts Posts : 13810
Post by Thebeast28 on 9th February 2010, 8:19 pm
2010-02-08 23:12:00,093 DEBUG Reading HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion:ProgramFilesDir (x86) value failed (error: e001003d)
2010-02-08 23:12:00,125 DEBUG AvgDir param set to C:\Program Files\AVG\AVG9.
2010-02-08 23:12:00,125 DEBUG AvgDataDir param set to C:\Documents and Settings\All Users\Application Data\avg9.
2010-02-08 23:12:16,203 INFO AvgRemover runs in attempt number 1
2010-02-08 23:12:16,234 INFO ***** Services *****
2010-02-08 23:12:16,234 INFO Processing service avg8emc
2010-02-08 23:12:16,250 INFO Service avg8emc is not installed
2010-02-08 23:12:16,250 DEBUG Service avg8emc RegCleanup
2010-02-08 23:12:16,250 DEBUG Registry keys for service avg8emc are not present
2010-02-08 23:12:16,250 INFO Processing service avgfws8
2010-02-08 23:12:16,250 INFO Service avgfws8 is not installed
2010-02-08 23:12:16,250 DEBUG Service avgfws8 RegCleanup
2010-02-08 23:12:16,250 DEBUG Registry keys for service avgfws8 are not present
2010-02-08 23:12:16,250 INFO Processing service avg8wd
2010-02-08 23:12:16,250 INFO Service avg8wd is not installed
2010-02-08 23:12:16,250 DEBUG Service avg8wd RegCleanup
2010-02-08 23:12:16,250 DEBUG Registry keys for service avg8wd are not present
2010-02-08 23:12:16,250 INFO Processing service AvgWFPx
2010-02-08 23:12:16,250 INFO Service AvgWFPx is not installed
2010-02-08 23:12:16,250 DEBUG Service AvgWFPx RegCleanup
2010-02-08 23:12:16,250 DEBUG Registry keys for service AvgWFPx are not present
2010-02-08 23:12:16,250 INFO Processing service AvgWFPa
2010-02-08 23:12:16,250 INFO Service AvgWFPa is not installed
2010-02-08 23:12:16,250 DEBUG Service AvgWFPa RegCleanup
2010-02-08 23:12:16,250 DEBUG Registry keys for service AvgWFPa are not present
2010-02-08 23:12:16,250 INFO Processing service AvgMfx86
2010-02-08 23:12:16,250 DEBUG Service AvgMfx86 Stop
2010-02-08 23:12:16,312 DEBUG Service AvgMfx86 Delete
2010-02-08 23:12:16,531 DEBUG Service AvgMfx86 RegCleanup
2010-02-08 23:12:17,390 INFO Processing service AvgMfx64
2010-02-08 23:12:17,859 INFO Service AvgMfx64 is not installed
2010-02-08 23:12:17,859 DEBUG Service AvgMfx64 RegCleanup
2010-02-08 23:12:17,859 DEBUG Registry keys for service AvgMfx64 are not present
2010-02-08 23:12:17,859 INFO Processing service AvgLdx86
2010-02-08 23:12:17,875 DEBUG Service AvgLdx86 Stop
2010-02-08 23:12:19,281 DEBUG Service AvgLdx86 Delete
2010-02-08 23:12:19,312 DEBUG Service AvgLdx86 RegCleanup
2010-02-08 23:12:19,328 INFO Processing service AvgLdx64
2010-02-08 23:12:19,328 INFO Service AvgLdx64 is not installed
2010-02-08 23:12:19,328 DEBUG Service AvgLdx64 RegCleanup
2010-02-08 23:12:19,328 DEBUG Registry keys for service AvgLdx64 are not present
2010-02-08 23:12:19,328 INFO Processing service AvgTdiX
2010-02-08 23:12:19,328 DEBUG Service AvgTdiX Stop
2010-02-08 23:12:19,328 DEBUG Service AvgTdiX Stop failed (error: c007041c), RESTART planned
2010-02-08 23:12:19,328 DEBUG Service AvgTdiX Delete
2010-02-08 23:12:19,328 DEBUG Service AvgTdiX Delete failed (error: c007041c)
2010-02-08 23:12:19,328 DEBUG Service AvgTdiX RegCleanup
2010-02-08 23:12:19,390 INFO Processing service AvgTdiA
2010-02-08 23:12:19,390 INFO Service AvgTdiA is not installed
2010-02-08 23:12:19,390 DEBUG Service AvgTdiA RegCleanup
2010-02-08 23:12:19,406 DEBUG Registry keys for service AvgTdiA are not present
2010-02-08 23:12:19,406 INFO Processing service AvgRkx86
2010-02-08 23:12:19,406 DEBUG Service AvgRkx86 Stop
2010-02-08 23:12:19,421 DEBUG Service AvgRkx86 Stop failed (error: c007041c), RESTART planned
2010-02-08 23:12:19,421 DEBUG Service AvgRkx86 Delete
2010-02-08 23:12:19,421 DEBUG Service AvgRkx86 Delete failed (error: c007041c)
2010-02-08 23:12:19,421 DEBUG Service AvgRkx86 RegCleanup
2010-02-08 23:12:19,562 INFO Processing service AvgRkx64
2010-02-08 23:12:19,562 INFO Service AvgRkx64 is not installed
2010-02-08 23:12:19,562 DEBUG Service AvgRkx64 RegCleanup
2010-02-08 23:12:19,562 DEBUG Registry keys for service AvgRkx64 are not present
2010-02-08 23:12:19,562 INFO Processing service avg9emc
2010-02-08 23:12:20,296 INFO Service avg9emc is not running
2010-02-08 23:12:20,296 DEBUG Service avg9emc Delete
2010-02-08 23:12:20,343 DEBUG Service avg9emc RegCleanup
2010-02-08 23:12:20,375 DEBUG Registry keys for service avg9emc are not present
2010-02-08 23:12:20,375 INFO Processing service avgfws9
2010-02-08 23:12:20,375 DEBUG Service avgfws9 Stop
2010-02-08 23:12:27,484 DEBUG Service avgfws9 Delete
2010-02-08 23:12:27,500 DEBUG Service avgfws9 RegCleanup
2010-02-08 23:12:27,656 DEBUG Delete registry keys for service avgfws9 failed (error: e001003d)
2010-02-08 23:12:27,656 DEBUG Service avgfws9 RegCleanup failed
2010-02-08 23:12:27,656 INFO Processing service avg9wd
2010-02-08 23:12:27,656 DEBUG Service avg9wd BeforeStop
2010-02-08 23:12:32,640 DEBUG Service avg9wd Stop
2010-02-08 23:12:39,187 DEBUG Service avg9wd Delete
2010-02-08 23:12:39,218 DEBUG Service avg9wd RegCleanup
2010-02-08 23:12:39,218 DEBUG Registry keys for service avg9wd are not present
2010-02-08 23:12:39,218 INFO Processing service AVGIDSAgent
2010-02-08 23:12:39,218 INFO Service AVGIDSAgent is not running
2010-02-08 23:12:39,218 DEBUG Service AVGIDSAgent Delete
2010-02-08 23:12:39,234 DEBUG Service AVGIDSAgent RegCleanup
2010-02-08 23:12:39,375 DEBUG Delete registry keys for service AVGIDSAgent failed (error: e001003d)
2010-02-08 23:12:39,375 DEBUG Service AVGIDSAgent RegCleanup failed
2010-02-08 23:12:39,375 INFO Processing service AVGIDSShimxpx
2010-02-08 23:12:39,375 DEBUG Service AVGIDSShimxpx Stop
2010-02-08 23:12:39,390 DEBUG Service AVGIDSShimxpx Stop failed (error: c007041b), RESTART planned
2010-02-08 23:12:39,406 DEBUG Service AVGIDSShimxpx Delete
2010-02-08 23:12:39,406 DEBUG Service AVGIDSShimxpx Delete failed (error: c007041b)
2010-02-08 23:12:39,406 DEBUG Service AVGIDSShimxpx RegCleanup
2010-02-08 23:12:39,421 INFO Processing service AVGIDSFilterxpx
2010-02-08 23:12:39,421 DEBUG Service AVGIDSFilterxpx Stop
2010-02-08 23:12:39,421 DEBUG Service AVGIDSFilterxpx Stop failed (error: c007041b), RESTART planned
2010-02-08 23:12:39,421 DEBUG Service AVGIDSFilterxpx Delete
2010-02-08 23:12:39,421 DEBUG Service AVGIDSFilterxpx Delete failed (error: c007041b)
2010-02-08 23:12:39,421 DEBUG Service AVGIDSFilterxpx RegCleanup
2010-02-08 23:12:39,453 INFO Processing service AVGIDSDriverxpx
2010-02-08 23:12:39,453 DEBUG Service AVGIDSDriverxpx Stop
2010-02-08 23:12:39,453 DEBUG Service AVGIDSDriverxpx Stop failed (error: c007041c), RESTART planned
2010-02-08 23:12:39,453 DEBUG Service AVGIDSDriverxpx Delete
2010-02-08 23:12:39,453 DEBUG Service AVGIDSDriverxpx Delete failed (error: c007041c)
2010-02-08 23:12:39,453 DEBUG Service AVGIDSDriverxpx RegCleanup
2010-02-08 23:12:39,468 INFO Processing service AVGIDSShimvtx
2010-02-08 23:12:39,484 INFO Service AVGIDSShimvtx is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSShimvtx RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSShimvtx are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSFiltervtx
2010-02-08 23:12:39,484 INFO Service AVGIDSFiltervtx is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSFiltervtx RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSFiltervtx are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSDrivervtx
2010-02-08 23:12:39,484 INFO Service AVGIDSDrivervtx is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSDrivervtx RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSDrivervtx are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSFiltervta
2010-02-08 23:12:39,484 INFO Service AVGIDSFiltervta is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSFiltervta RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSFiltervta are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSDrivervta
2010-02-08 23:12:39,484 INFO Service AVGIDSDrivervta is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSDrivervta RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSDrivervta are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSShimw7x
2010-02-08 23:12:39,484 INFO Service AVGIDSShimw7x is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSShimw7x RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSShimw7x are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSFilterw7x
2010-02-08 23:12:39,484 INFO Service AVGIDSFilterw7x is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSFilterw7x RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSFilterw7x are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSDriverw7x
2010-02-08 23:12:39,484 INFO Service AVGIDSDriverw7x is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSDriverw7x RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSDriverw7x are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSFilterw7a
2010-02-08 23:12:39,484 INFO Service AVGIDSFilterw7a is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSFilterw7a RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSFilterw7a are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSDriverw7a
2010-02-08 23:12:39,484 INFO Service AVGIDSDriverw7a is not installed
2010-02-08 23:12:39,484 DEBUG Service AVGIDSDriverw7a RegCleanup
2010-02-08 23:12:39,484 DEBUG Registry keys for service AVGIDSDriverw7a are not present
2010-02-08 23:12:39,484 INFO Processing service AVGIDSErHrxpx
2010-02-08 23:12:39,484 DEBUG Service AVGIDSErHrxpx Stop
2010-02-08 23:12:39,515 DEBUG Service AVGIDSErHrxpx Delete
2010-02-08 23:12:39,546 DEBUG Service AVGIDSErHrxpx RegCleanup
2010-02-08 23:12:39,562 INFO Processing service AVGIDSErHrvtx
2010-02-08 23:12:39,578 INFO Service AVGIDSErHrvtx is not installed
2010-02-08 23:12:39,578 DEBUG Service AVGIDSErHrvtx RegCleanup
2010-02-08 23:12:39,578 DEBUG Registry keys for service AVGIDSErHrvtx are not present
2010-02-08 23:12:39,578 INFO Processing service AVGIDSErHrvta
2010-02-08 23:12:39,578 INFO Service AVGIDSErHrvta is not installed
2010-02-08 23:12:39,578 DEBUG Service AVGIDSErHrvta RegCleanup
2010-02-08 23:12:39,578 DEBUG Registry keys for service AVGIDSErHrvta are not present
2010-02-08 23:12:39,578 INFO Processing service AVGIDSErHrw7x
2010-02-08 23:12:39,578 INFO Service AVGIDSErHrw7x is not installed
2010-02-08 23:12:39,578 DEBUG Service AVGIDSErHrw7x RegCleanup
2010-02-08 23:12:39,578 DEBUG Registry keys for service AVGIDSErHrw7x are not present
2010-02-08 23:12:39,578 INFO Processing service AVGIDSErHrw7a
2010-02-08 23:12:39,578 INFO Service AVGIDSErHrw7a is not installed
2010-02-08 23:12:39,578 DEBUG Service AVGIDSErHrw7a RegCleanup
2010-02-08 23:12:39,578 DEBUG Registry keys for service AVGIDSErHrw7a are not present
2010-02-08 23:12:39,578 DEBUG Restart is needed (restart counter: 5)
2010-02-08 23:12:39,578 INFO ***** Registry keys and values *****
2010-02-08 23:12:39,578 INFO Processing registry SOFTWARE\Mozilla\Firefox\Extensions
2010-02-08 23:12:39,578 DEBUG Value SOFTWARE\Mozilla\Firefox\Extensions:{3f963a5b-e555-4543-90e2-c3908898db71} Remove
2010-02-08 23:12:39,640 INFO Processing registry SOFTWARE\Mozilla\Firefox\Extensions
2010-02-08 23:12:39,640 DEBUG Value SOFTWARE\Mozilla\Firefox\Extensions:{1d5287d1-8a92-0001-1f31-1cec198018d8} Remove
2010-02-08 23:12:39,640 INFO Value SOFTWARE\Mozilla\Firefox\Extensions:{1d5287d1-8a92-0001-1f31-1cec198018d8} is not present
2010-02-08 23:12:39,640 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt
2010-02-08 23:12:39,640 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt ForceRemove
2010-02-08 23:12:39,640 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg8Alrt not found
2010-02-08 23:12:39,640 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg9Alrt
2010-02-08 23:12:39,640 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\Avg9Alrt ForceRemove
2010-02-08 23:12:39,687 INFO Processing registry SYSTEM\CurrentControlSet\Services\Eventlog\Application\AvgEms
2010-02-08 23:12:39,687 DEBUG Key SYSTEM\CurrentControlSet\Services\Eventlog\Application\AvgEms ForceRemove
2010-02-08 23:12:39,718 INFO Processing registry SYSTEM\CurrentControlSet\Services\Avg
2010-02-08 23:12:39,718 DEBUG Key SYSTEM\CurrentControlSet\Services\Avg ForceRemove
2010-02-08 23:12:39,734 INFO Processing registry SYSTEM\CurrentControlSet\Services\Avg
2010-02-08 23:12:39,734 DEBUG Key SYSTEM\CurrentControlSet\Services\Avg ForceRemove
2010-02-08 23:12:39,734 DEBUG Key SYSTEM\CurrentControlSet\Services\Avg not found
2010-02-08 23:12:39,734 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054}
2010-02-08 23:12:39,734 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054} ForceRemove
2010-02-08 23:12:39,734 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B2AF1721-312E-4B07-8B17-CEB780DCD054} not found
2010-02-08 23:12:39,734 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:39,734 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:39,734 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:39,734 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Toolbar
2010-02-08 23:12:39,734 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\Toolbar:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} Remove
2010-02-08 23:12:39,750 INFO Value SOFTWARE\Microsoft\Internet Explorer\Toolbar:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} is not present
2010-02-08 23:12:39,750 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:39,750 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:39,750 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:39,750 INFO Processing registry SOFTWARE\Microsoft\Exchange\Client\Extensions
2010-02-08 23:12:39,750 DEBUG Value SOFTWARE\Microsoft\Exchange\Client\Extensions:Outlook Setup Extension Remove
2010-02-08 23:12:39,750 INFO Value SOFTWARE\Microsoft\Exchange\Client\Extensions:Outlook Setup Extension is not present
2010-02-08 23:12:39,750 DEBUG Value SOFTWARE\Microsoft\Exchange\Client\Extensions:AVG Exchange Extension Remove
2010-02-08 23:12:39,765 INFO Value SOFTWARE\Microsoft\Exchange\Client\Extensions:AVG Exchange Extension is not present
2010-02-08 23:12:39,765 INFO Processing registry SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows
2010-02-08 23:12:39,765 DEBUG Value SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows:AppInit_DLLs Modify
2010-02-08 23:12:39,765 DEBUG Value SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows:AppInit_DLLs doesn't need to be modified
2010-02-08 23:12:39,765 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-02-08 23:12:39,765 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} Remove
2010-02-08 23:12:39,875 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-02-08 23:12:39,875 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} Remove
2010-02-08 23:12:39,875 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-460A-42C5-AE0C-81C61FFAEBC3} is not present
2010-02-08 23:12:39,875 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} Remove
2010-02-08 23:12:39,890 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved
2010-02-08 23:12:39,890 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} Remove
2010-02-08 23:12:39,890 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved:{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} is not present
2010-02-08 23:12:39,890 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Run
2010-02-08 23:12:39,890 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG8_TRAY Remove
2010-02-08 23:12:39,937 INFO Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG8_TRAY is not present
2010-02-08 23:12:39,937 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Run
2010-02-08 23:12:39,937 DEBUG Value SOFTWARE\Microsoft\Windows\CurrentVersion\Run:AVG9_TRAY Remove
2010-02-08 23:12:39,984 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
2010-02-08 23:12:39,984 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall ForceRemove
2010-02-08 23:12:39,984 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall not found
2010-02-08 23:12:39,984 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
2010-02-08 23:12:39,984 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall ForceRemove
2010-02-08 23:12:39,984 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall not found
2010-02-08 23:12:39,984 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall
2010-02-08 23:12:39,984 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG9Uninstall ForceRemove
2010-02-08 23:12:40,328 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-02-08 23:12:40,328 INFO Processing registry SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3 ForceRemove
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3 not found
2010-02-08 23:12:40,328 INFO Processing registry SOFTWARE\Classes\AvgDiagFile
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\AvgDiagFile ForceRemove
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\AvgDiagFile not found
2010-02-08 23:12:40,328 INFO Processing registry SOFTWARE\Classes\.avgdi
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\.avgdi ForceRemove
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\.avgdi not found
2010-02-08 23:12:40,328 INFO Processing registry SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-02-08 23:12:40,328 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\Classes\piffile\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-02-08 23:12:40,390 INFO Processing registry SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\Classes\Folder\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-02-08 23:12:40,390 INFO Processing registry SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension ForceRemove
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\Classes\*\shellex\ContextMenuHandlers\AVG8 Shell Extension not found
2010-02-08 23:12:40,390 INFO Processing registry SOFTWARE\AVG\Clients
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\AVG\Clients ForceRemove
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\AVG\Clients not found
2010-02-08 23:12:40,390 INFO Processing registry SOFTWARE\AVG\AVG8
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\AVG\AVG8 ForceRemove
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\AVG\AVG8 not found
2010-02-08 23:12:40,390 INFO Processing registry SOFTWARE\AVG\AVG9
2010-02-08 23:12:40,390 DEBUG Key SOFTWARE\AVG\AVG9 ForceRemove
2010-02-08 23:12:40,703 INFO Processing registry SOFTWARE\AVG\AVG IDS
2010-02-08 23:12:40,703 DEBUG Key SOFTWARE\AVG\AVG IDS ForceRemove
2010-02-08 23:12:40,781 INFO Processing registry SOFTWARE\AVG
2010-02-08 23:12:40,781 DEBUG Value SOFTWARE\AVG:DumpType Remove
2010-02-08 23:12:40,781 INFO Value SOFTWARE\AVG:DumpType is not present
2010-02-08 23:12:40,781 DEBUG Key SOFTWARE\AVG Remove
2010-02-08 23:12:40,828 INFO Processing registry SOFTWARE\AVG Security Toolbar
2010-02-08 23:12:40,828 DEBUG Key SOFTWARE\AVG Security Toolbar ForceRemove
2010-02-08 23:12:40,828 DEBUG Key SOFTWARE\AVG Security Toolbar not found
2010-02-08 23:12:40,828 INFO Processing registry SOFTWARE\AVG\AVG8
2010-02-08 23:12:40,828 DEBUG Key SOFTWARE\AVG\AVG8 ForceRemove
2010-02-08 23:12:40,828 DEBUG Key SOFTWARE\AVG\AVG8 not found
2010-02-08 23:12:40,828 INFO Processing registry SOFTWARE\AVG\AVG9
2010-02-08 23:12:40,828 DEBUG Key SOFTWARE\AVG\AVG9 ForceRemove
2010-02-08 23:12:41,000 INFO Processing registry SOFTWARE\AVG
2010-02-08 23:12:41,000 DEBUG Key SOFTWARE\AVG Remove
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\AVG Security Toolbar
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\AVG Security Toolbar ForceRemove
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\AVG Security Toolbar not found
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks
2010-02-08 23:12:41,015 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks:{A3BC75A2-1F87-4686-AA43-5347D756017C} Remove
2010-02-08 23:12:41,015 INFO Value SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks:{A3BC75A2-1F87-4686-AA43-5347D756017C} is not present
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser
2010-02-08 23:12:41,015 DEBUG Value SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} Remove
2010-02-08 23:12:41,015 INFO Value SOFTWARE\Microsoft\Internet Explorer\Toolbar\WebBrowser:{CCC7A320-B3CA-4199-B1A6-9F516DD69829} is not present
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:41,015 INFO Processing registry SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-02-08 23:12:41,015 DEBUG Key SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-02-08 23:12:41,015 INFO Processing registry aAvgAPI.AvgBro
2010-02-08 23:12:41,015 DEBUG Key aAvgAPI.AvgBro ForceRemove
2010-02-08 23:12:41,015 DEBUG Key aAvgAPI.AvgBro not found
2010-02-08 23:12:41,015 INFO Processing registry AVG.Office
2010-02-08 23:12:41,015 DEBUG Key AVG.Office ForceRemove
2010-02-08 23:12:41,015 DEBUG Key AVG.Office not found
2010-02-08 23:12:41,015 INFO Processing registry AVG.Office.8
2010-02-08 23:12:41,015 DEBUG Key AVG.Office.8 ForceRemove
2010-02-08 23:12:41,015 DEBUG Key AVG.Office.8 not found
2010-02-08 23:12:41,015 INFO Processing registry avgtoolbar.AVGTOOLBAR
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBAR ForceRemove
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBAR not found
2010-02-08 23:12:41,015 INFO Processing registry avgtoolbar.AVGTOOLBARMenu Button
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBARMenu Button ForceRemove
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBARMenu Button not found
2010-02-08 23:12:41,015 INFO Processing registry avgtoolbar.AVGTOOLBARToggle Button
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBARToggle Button ForceRemove
2010-02-08 23:12:41,015 DEBUG Key avgtoolbar.AVGTOOLBARToggle Button not found
2010-02-08 23:12:41,015 INFO Processing registry LinkScannerIE.NavFilter
2010-02-08 23:12:41,015 DEBUG Key LinkScannerIE.NavFilter ForceRemove
2010-02-08 23:12:41,281 INFO Processing registry LinkScannerIE.NavFilter.1
2010-02-08 23:12:41,281 DEBUG Key LinkScannerIE.NavFilter.1 ForceRemove
2010-02-08 23:12:41,296 INFO Processing registry CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA}
2010-02-08 23:12:41,296 DEBUG Key CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA} ForceRemove
2010-02-08 23:12:41,296 DEBUG Key CLSID\{04373D9C-5ED8-44f2-BA00-7895D6A5A2DA} not found
2010-02-08 23:12:41,296 INFO Processing registry CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A}
2010-02-08 23:12:41,296 DEBUG Key CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A} ForceRemove
2010-02-08 23:12:41,312 DEBUG Key CLSID\{18B30EBF-6B58-425E-AC54-831C05D91B5A} not found
2010-02-08 23:12:41,312 INFO Processing registry CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
2010-02-08 23:12:41,312 DEBUG Key CLSID\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} ForceRemove
2010-02-08 23:12:41,390 INFO Processing registry CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}
2010-02-08 23:12:41,390 DEBUG Key CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} ForceRemove
2010-02-08 23:12:41,453 INFO Processing registry CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3}
2010-02-08 23:12:41,453 DEBUG Key CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} ForceRemove
2010-02-08 23:12:41,453 DEBUG Key CLSID\{9F97547E-4609-42C5-AE0C-81C61FFAEBC3} not found
2010-02-08 23:12:41,453 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E2698E}
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698E} ForceRemove
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698E} not found
2010-02-08 23:12:41,453 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E2698F}
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698F} ForceRemove
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E2698F} not found
2010-02-08 23:12:41,453 INFO Processing registry CLSID\{A057A204-BACC-4D26-9990-79A187E26990}
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E26990} ForceRemove
2010-02-08 23:12:41,453 DEBUG Key CLSID\{A057A204-BACC-4D26-9990-79A187E26990} not found
2010-02-08 23:12:41,453 INFO Processing registry CLSID\{F274614C-63F8-47D5-A4D1-FBDDE494F8D1}
2010-02-08 23:12:41,453 DEBUG Key CLSID\{F274614C-63F8-47D5-A4D1-FBDDE494F8D1} ForceRemove
2010-02-08 23:12:41,468 INFO Processing registry CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7}
2010-02-08 23:12:41,468 DEBUG Key CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key CLSID\{9781B2D1-AF27-474F-A3A5-C0763FBDF3B7} not found
2010-02-08 23:12:41,484 INFO Processing registry CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C}
2010-02-08 23:12:41,484 DEBUG Key CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key CLSID\{A3BC75A2-1F87-4686-AA43-5347D756017C} not found
2010-02-08 23:12:41,484 INFO Processing registry CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:41,484 DEBUG Key CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key CLSID\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:41,484 INFO Processing registry Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D}
2010-02-08 23:12:41,484 DEBUG Key Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key Interface\{52261B0E-CA1A-4FA9-9805-4D01202DF09D} not found
2010-02-08 23:12:41,484 INFO Processing registry Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C}
2010-02-08 23:12:41,484 DEBUG Key Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key Interface\{8EA1F9F2-997A-4832-8E09-815E3D0C0A0C} not found
2010-02-08 23:12:41,484 INFO Processing registry Interface\{7F24AABF-C822-4C18-9432-21433208F4DC}
2010-02-08 23:12:41,484 DEBUG Key Interface\{7F24AABF-C822-4C18-9432-21433208F4DC} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key Interface\{7F24AABF-C822-4C18-9432-21433208F4DC} not found
2010-02-08 23:12:41,484 INFO Processing registry TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30}
2010-02-08 23:12:41,484 DEBUG Key TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30} ForceRemove
2010-02-08 23:12:41,484 DEBUG Key TypeLib\{3E536428-8E1A-4A2C-8463-4A8F74763C30} not found
2010-02-08 23:12:41,484 INFO Processing registry TypeLib\{5DAB1D4C-D020-41CD-936F-D63FF662E9F7}
2010-02-08 23:12:41,484 DEBUG Key TypeLib\{5DAB1D4C-D020-41CD-936F-D63FF662E9F7} ForceRemove
2010-02-08 23:12:41,593 INFO Processing registry TypeLib\{A0C8F0F1-DE25-4ADB-8F0B-508F6CA43DE9}
2010-02-08 23:12:41,593 DEBUG Key TypeLib\{A0C8F0F1-DE25-4ADB-8F0B-508F6CA43DE9} ForceRemove
2010-02-08 23:12:41,671 INFO Processing registry TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829}
2010-02-08 23:12:41,671 DEBUG Key TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} ForceRemove
2010-02-08 23:12:41,671 DEBUG Key TypeLib\{CCC7A320-B3CA-4199-B1A6-9F516DD69829} not found
2010-02-08 23:12:41,671 INFO ***** Files and folders *****
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\Scripts\IM\MSN
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Scripts\IM\MSN not found
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Scripts\IM not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\Scripts\Logging
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Scripts\Logging not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\Scripts\Dictionary
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Scripts\Dictionary not found
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Scripts not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\ToolbarIEcache
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\ToolbarIEcache not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\ToolbarFF\Chrome\cache
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\ToolbarFF\Chrome\cache not found
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\ToolbarFF\Chrome not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\ToolbarFF\Components
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\ToolbarFF\Components not found
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\ToolbarFF not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Program Files\AVG\AVG9\Exchange2007\Scripts
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Exchange2007\Scripts not found
2010-02-08 23:12:41,671 INFO Directory C:\Program Files\AVG\AVG9\Exchange2007 not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\Documents and Settings\Jonathan Murray\Application Data\AVGTOOLBAR
2010-02-08 23:12:41,671 INFO Directory C:\Documents and Settings\Jonathan Murray\Application Data\AVGTOOLBAR not found
2010-02-08 23:12:41,671 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.0
2010-02-08 23:12:41,703 INFO Directory C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.0 not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.0
2010-02-08 23:12:41,703 INFO Directory C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.0 not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.5
2010-02-08 23:12:41,703 INFO Directory C:\Documents and Settings\All Users\Start Menu\Programs\avg 8.5 not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.5
2010-02-08 23:12:41,703 INFO Directory C:\Documents and Settings\All Users\Start Menu\Programs\avg free 8.5 not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg 8.0.lnk
2010-02-08 23:12:41,703 INFO File C:\Documents and Settings\All Users\Desktop\avg 8.0.lnk not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg free 8.0.lnk
2010-02-08 23:12:41,703 INFO File C:\Documents and Settings\All Users\Desktop\avg free 8.0.lnk not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg 8.5.lnk
2010-02-08 23:12:41,703 INFO File C:\Documents and Settings\All Users\Desktop\avg 8.5.lnk not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg free 8.5.lnk
2010-02-08 23:12:41,703 INFO File C:\Documents and Settings\All Users\Desktop\avg free 8.5.lnk not found
2010-02-08 23:12:41,703 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:12:41,703 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP
2010-02-08 23:12:41,750 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP\AVGIDSDriver.sys deleted
2010-02-08 23:12:41,750 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP\AVGIDSFilter.sys deleted
2010-02-08 23:12:41,765 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP\AVGIDSShim.sys deleted
2010-02-08 23:12:42,031 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP\UniversalDD.sys deleted
2010-02-08 23:12:42,109 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_XP deleted
2010-02-08 23:12:42,109 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_Vista
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
Post by Thebeast28 on 9th February 2010, 8:20 pm
\Platform_Vista not found
2010-02-08 23:12:42,109 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_Vista64
2010-02-08 23:12:42,109 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_Vista64 not found
2010-02-08 23:12:42,109 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_WIN7
2010-02-08 23:12:42,109 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_WIN7 not found
2010-02-08 23:12:42,109 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_WIN764
2010-02-08 23:12:42,109 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver\Platform_WIN764 not found
2010-02-08 23:12:42,109 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\driver deleted
2010-02-08 23:12:42,109 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin
2010-02-08 23:12:42,171 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\AVGIDSAgent.exe deleted
2010-02-08 23:12:42,187 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\AVGIDSMonitor.exe deleted
2010-02-08 23:12:42,187 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\boost_log-vc71-mt-1_32.dll deleted
2010-02-08 23:12:42,234 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\boost_thread-vc71-mt-1_32.dll deleted
2010-02-08 23:12:42,250 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\msvcp71.dll deleted
2010-02-08 23:12:42,250 INFO File C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin\msvcr71.dll deleted
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent\bin deleted
2010-02-08 23:12:42,296 DEBUG Processing item C:\Program Files\AVG\AVG9\Identity Protection\Agent
2010-02-08 23:12:42,296 DEBUG Directory C:\Program Files\AVG\AVG9\Identity Protection\Agent not deleted (error c0070091)
2010-02-08 23:12:42,296 DEBUG Directory C:\Program Files\AVG\AVG9\Identity Protection not deleted (error c0070091)
2010-02-08 23:12:42,296 DEBUG Processing item C:\Program Files\AVG\AVG9\Exchange\Transport\Scripts
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Exchange\Transport\Scripts not found
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Exchange\Transport not found
2010-02-08 23:12:42,296 DEBUG Processing item C:\Program Files\AVG\AVG9\Exchange\VSAPI
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Exchange\VSAPI not found
2010-02-08 23:12:42,296 DEBUG Processing item C:\Program Files\AVG\AVG9\Exchange\Filters
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Exchange\Filters not found
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Exchange not found
2010-02-08 23:12:42,296 DEBUG Processing item C:\Program Files\AVG\AVG9\Sharepoint
2010-02-08 23:12:42,296 INFO Directory C:\Program Files\AVG\AVG9\Sharepoint not found
2010-02-08 23:12:42,296 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\chjw
2010-02-08 23:12:42,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\7d96f1df-4ad5-4aae-9d60-56e4156095a5.cm-2-p.dat deleted
2010-02-08 23:12:42,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\cm-0-p.dat deleted
2010-02-08 23:12:42,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\cm-1-p.dat deleted
2010-02-08 23:12:42,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\cm-2-i.dat deleted
2010-02-08 23:12:42,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\cm-2-p.dat deleted
2010-02-08 23:12:42,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\chjw\f5d66938-a38f-443e-a397-40ea6a22442d.cm-2-p.dat deleted
2010-02-08 23:12:42,640 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\chjw deleted
2010-02-08 23:12:42,640 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\chjw
2010-02-08 23:12:42,640 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\chjw not found
2010-02-08 23:12:42,656 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\chjw not found
2010-02-08 23:12:42,656 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\chjw
2010-02-08 23:12:42,656 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\quarantine
2010-02-08 23:12:42,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\quarantine\695d44d0-0000-1000-8000-000000000000.zip deleted
2010-02-08 23:12:42,828 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\quarantine deleted
2010-02-08 23:12:42,828 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile
2010-02-08 23:12:42,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__BLACKPUDDING_COMBOFIX-DOWNLOAD.CFXXE.ndb deleted
2010-02-08 23:12:42,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__BLACKPUDDING_COMBOFIX-DOWNLOAD.CFXXE.ndb_ndb.bak deleted
2010-02-08 23:12:42,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__BLACKPUDDING_PING.CFXXE.ndb deleted
2010-02-08 23:12:42,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__COMBOFIX_COMBOFIX-DOWNLOAD.CFXXE.ndb deleted
2010-02-08 23:12:42,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__COMBOFIX_COMBOFIX-DOWNLOAD.CFXXE.ndb_ndb.bak deleted
2010-02-08 23:12:42,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__COMBOFIX_PING.CFXXE.ndb deleted
2010-02-08 23:12:42,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_7ZS2D.TMP_STUB.EXE.ndb deleted
2010-02-08 23:12:42,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_7ZS2D.TMP_STUB.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:42,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_7ZS36.TMP_STUB.EXE.ndb deleted
2010-02-08 23:12:42,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_7ZS36.TMP_STUB.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:42,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_IS-CSNFL.TMP_SBSD162UPD.TMP.ndb deleted
2010-02-08 23:12:42,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_IS-ET49V.TMP_SETUP-SPYBOTSD162.TMP.ndb deleted
2010-02-08 23:12:42,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_IS-GNVUH.TMP_SDSETUP.TMP.ndb deleted
2010-02-08 23:12:42,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__DOCUMENTS AND SETTINGS_JONATHAN MURRAY_LOCAL SETTINGS_TEMP_IS-GNVUH.TMP_SDSETUP.TMP.ndb_ndb.bak deleted
2010-02-08 23:12:42,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_ALCOHOL SOFT_ALCOHOL 120_STARWIND_STARWINDSERVICEAE.EXE.ndb deleted
2010-02-08 23:12:42,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGCHSVX.EXE.ndb deleted
2010-02-08 23:12:43,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGCHSVX.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGCMGR.EXE.ndb deleted
2010-02-08 23:12:43,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGCMGR.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGCSRVX.EXE.ndb deleted
2010-02-08 23:12:43,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGEMC.EXE.ndb deleted
2010-02-08 23:12:43,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGEMC.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGFWS9.EXE.ndb deleted
2010-02-08 23:12:43,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGFWS9.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGTRAY.EXE.ndb deleted
2010-02-08 23:12:43,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGTRAY.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGUI.EXE.ndb deleted
2010-02-08 23:12:43,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGUI.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGUPD.EXE.ndb deleted
2010-02-08 23:12:43,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGUPD.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGWDSVC.EXE.ndb deleted
2010-02-08 23:12:43,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_AVG_AVG9_AVGWDSVC.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_BITTORRENT_BITTORRENT.EXE.ndb deleted
2010-02-08 23:12:43,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_BITTORRENT_BITTORRENT.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_COMMON FILES_AOL_1155679928_EE_AOLSOFTWARE.EXE.ndb deleted
2010-02-08 23:12:43,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_COMMON FILES_AOL_1155679928_EE_AOLSOFTWARE.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_COMPAQ_COMPAQ ADVISOR_BIN_COMPAQ-RBA.EXE.ndb deleted
2010-02-08 23:12:43,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_ENIGMA SOFTWARE GROUP_SPYHUNTER_SPYHUNTER3.EXE.ndb deleted
2010-02-08 23:12:43,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_ESETSMARTINSTALLER_ENU.EXE.ndb deleted
2010-02-08 23:12:43,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_ESET_ESET ONLINE SCANNER_ONLINECMDLINESCANNER.EXE.ndb deleted
2010-02-08 23:12:43,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_ESET_ESET ONLINE SCANNER_ONLINESCANNERAPP.EXE.ndb deleted
2010-02-08 23:12:43,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_HP_HP SOFTWARE UPDATE_HPWUCLI.EXE.ndb deleted
2010-02-08 23:12:43,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_HP_HP SOFTWARE UPDATE_HPWUCLI.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_INTERNET EXPLORER_IEXPLORE.EXE.ndb deleted
2010-02-08 23:12:43,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_INTERNET EXPLORER_IEXPLORE.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:43,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JAVAW.EXE.ndb deleted
2010-02-08 23:12:43,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JAVAW.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JQS.EXE.ndb deleted
2010-02-08 23:12:44,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JQS.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JUCHECK.EXE.ndb deleted
2010-02-08 23:12:44,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JUCHECK.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JUSCHED.EXE.ndb deleted
2010-02-08 23:12:44,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JAVA_JRE6_BIN_JUSCHED.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JRE-6U17-WINDOWS-I586-IFTW-RV.EXE.ndb deleted
2010-02-08 23:12:44,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_JRE-6U17-WINDOWS-I586-IFTW-RV.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_MALWAREBYTES' ANTI-MALWARE_MBAM.EXE.ndb deleted
2010-02-08 23:12:44,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_MALWAREBYTES' ANTI-MALWARE_MBAM.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_MOZILLA FIREFOX_FIREFOX.EXE.ndb deleted
2010-02-08 23:12:44,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_MOZILLA FIREFOX_FIREFOX.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_NETGEAR_WG311V3_WLANCFG5.EXE.ndb deleted
2010-02-08 23:12:44,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_NETGEAR_WG311V3_WLANCFG5.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_NOS_BIN_GETPLUSPLUS_ADOBE.EXE.ndb deleted
2010-02-08 23:12:44,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_NOS_BIN_GETPLUSPLUS_ADOBE.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_PC DRIVERS HEADQUARTERS_DRIVER DETECTIVE_DRIVERSHQ.DRIVERDETECTIVE.CLIENT.EXE.ndb deleted
2010-02-08 23:12:44,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_PC DRIVERS HEADQUARTERS_DRIVER DETECTIVE_DRIVERSHQ.DRIVERDETECTIVE.CLIENT.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_PC DRIVERS HEADQUARTERS_DRIVER DETECTIVE_DRIVERSHQ.DRIVERDETECTIVE.CLIENT.UPDATER.EXE.ndb deleted
2010-02-08 23:12:44,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPEEDYPC_SPEEDYPC.EXE.ndb deleted
2010-02-08 23:12:44,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPEEDYPC_SPEEDYPC.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYBOT - SEARCH & DESTROY1_SPYBOTSD.EXE.ndb deleted
2010-02-08 23:12:44,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYWARE DOCTOR_BDT_PCTBDUPDATE.EXE.ndb deleted
2010-02-08 23:12:44,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYWARE DOCTOR_PCTSSVC.EXE.ndb deleted
2010-02-08 23:12:44,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYWARE DOCTOR_PCTSSVC.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYWARE DOCTOR_UPDATE.EXE.ndb deleted
2010-02-08 23:12:44,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_SPYWARE DOCTOR_UPDATE.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__PROGRAM FILES_WEBROOT_WASHER_WWDISP.EXE.ndb deleted
2010-02-08 23:12:44,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_EXPLORER.EXE.ndb deleted
2010-02-08 23:12:44,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_EXPLORER.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_PCHEALTH_HELPCTR_BINARIES_HELPSVC.EXE.ndb deleted
2010-02-08 23:12:44,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_LSASS.EXE.ndb deleted
2010-02-08 23:12:44,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_LSASS.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_SSMARQUE.SCR.ndb deleted
2010-02-08 23:12:44,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_SSMARQUE.SCR.ndb_ndb.bak deleted
2010-02-08 23:12:44,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_SVCHOST.EXE.ndb deleted
2010-02-08 23:12:44,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_SVCHOST.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_WBEM_WMIPRVSE.EXE.ndb deleted
2010-02-08 23:12:44,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\C__WINDOWS_SYSTEM32_WBEM_WMIPRVSE.EXE.ndb_ndb.bak deleted
2010-02-08 23:12:44,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\globalLoadable.bak deleted
2010-02-08 23:12:44,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\globalLoadable.gdb deleted
2010-02-08 23:12:44,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\MalwareNetwork.bak deleted
2010-02-08 23:12:44,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\MalwareNetwork.xml deleted
2010-02-08 23:12:44,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\SYSTEM.ndb deleted
2010-02-08 23:12:44,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile\SYSTEM.ndb_ndb.bak deleted
2010-02-08 23:12:44,890 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\profile deleted
2010-02-08 23:12:44,890 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\0
2010-02-08 23:12:44,937 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\0 deleted
2010-02-08 23:12:44,937 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\1
2010-02-08 23:12:44,953 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\1 deleted
2010-02-08 23:12:44,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\2
2010-02-08 23:12:44,953 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\2 deleted
2010-02-08 23:12:44,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\3
2010-02-08 23:12:44,953 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\3 deleted
2010-02-08 23:12:44,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\4
2010-02-08 23:12:45,000 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\4 deleted
2010-02-08 23:12:45,000 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\5
2010-02-08 23:12:45,015 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\5 deleted
2010-02-08 23:12:45,015 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\6
2010-02-08 23:12:45,015 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\6 deleted
2010-02-08 23:12:45,015 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\7
2010-02-08 23:12:45,031 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\7 deleted
2010-02-08 23:12:45,031 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\8
2010-02-08 23:12:45,078 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\8 deleted
2010-02-08 23:12:45,078 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\9
2010-02-08 23:12:45,078 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox\9 deleted
2010-02-08 23:12:45,078 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\outbox deleted
2010-02-08 23:12:45,078 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\malwareprofile
2010-02-08 23:12:45,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\malwareprofile\backup.dat deleted
2010-02-08 23:12:45,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\malwareprofile\nodes.dat deleted
2010-02-08 23:12:45,234 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\malwareprofile deleted
2010-02-08 23:12:45,234 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\log
2010-02-08 23:12:45,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent.log deleted
2010-02-08 23:12:45,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent_boot.log deleted
2010-02-08 23:12:45,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent_graph.log deleted
2010-02-08 23:12:45,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent_malware.log deleted
2010-02-08 23:12:45,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent_node.log deleted
2010-02-08 23:12:45,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\log\AVGIDSAgent_removed.log deleted
2010-02-08 23:12:45,578 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\log deleted
2010-02-08 23:12:45,578 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\download
2010-02-08 23:12:45,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\download\messages.xml deleted
2010-02-08 23:12:45,687 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\download deleted
2010-02-08 23:12:45,687 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\EN_US
2010-02-08 23:12:45,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\EN_US\Characteristics.xml deleted
2010-02-08 23:12:45,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\EN_US\internalListStrings.xml deleted
2010-02-08 23:12:45,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\EN_US\reportableEvents.xml deleted
2010-02-08 23:12:45,812 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\EN_US deleted
2010-02-08 23:12:45,812 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config
2010-02-08 23:12:45,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\agentStartup.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\analyzerConfig.int deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\analyzerConfig.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\analyzerFilterConfig.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\BehavioralEventProcessors.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\BehavioralEvents.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\Classifiers.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\Correlations.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\downloadManager.xml deleted
2010-02-08 23:12:45,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\downloads.xml deleted
2010-02-08 23:12:45,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\ExecutableEvents.xml deleted
2010-02-08 23:12:45,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\FileCoverage.xml deleted
2010-02-08 23:12:45,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\globalConfig.xml deleted
2010-02-08 23:12:45,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\internalList.zip deleted
2010-02-08 23:12:45,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\internalList.zip.bak deleted
2010-02-08 23:12:45,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\messages.xml deleted
2010-02-08 23:12:45,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\NetworkEvents.xml deleted
2010-02-08 23:12:45,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\ProductParameters.xml deleted
2010-02-08 23:12:45,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\quarantinedList.zip deleted
2010-02-08 23:12:45,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\quarantinedList.zip.bak deleted
2010-02-08 23:12:45,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\RegistryCoverage.xml deleted
2010-02-08 23:12:45,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\Relationships.xml deleted
2010-02-08 23:12:45,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\ReportableEventMappings.xml deleted
2010-02-08 23:12:45,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\SelfProtection.xml deleted
2010-02-08 23:12:45,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\userList.zip deleted
2010-02-08 23:12:45,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config\userList.zip.bak deleted
2010-02-08 23:12:45,968 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS\Config deleted
2010-02-08 23:12:45,968 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\IDS
2010-02-08 23:12:46,015 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\IDS deleted
2010-02-08 23:12:46,015 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log
2010-02-08 23:12:46,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log\avgam_idp_SYSTEM.log deleted
2010-02-08 23:12:46,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log\avgfws9_idp_SYSTEM.log deleted
2010-02-08 23:12:46,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log\avgtray_idp_Jonathan Murray.log deleted
2010-02-08 23:12:46,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log\avgui_idp_Jonathan Murray.log deleted
2010-02-08 23:12:46,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log\avgwdsvc_idp_SYSTEM.log deleted
2010-02-08 23:12:46,125 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\log\IDP\log deleted
2010-02-08 23:12:46,125 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\log\IDP
2010-02-08 23:12:46,171 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\log\IDP deleted
2010-02-08 23:12:46,171 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Languages
2010-02-08 23:12:46,171 INFO Directory C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar\Languages not found
2010-02-08 23:12:46,171 INFO Directory C:\Documents and Settings\All Users\Application Data\AVG Security Toolbar not found
2010-02-08 23:12:46,171 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:12:46,296 INFO File C:\WINDOWS\System32\Drivers\\AVGIDSxx.sys deleted
2010-02-08 23:12:46,296 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg 9.0.lnk
2010-02-08 23:12:46,328 DEBUG File C:\Documents and Settings\All Users\Desktop\avg 9.0.lnk deleted
2010-02-08 23:12:46,328 DEBUG Processing item C:\Documents and Settings\All Users\Desktop\avg free 9.0.lnk
2010-02-08 23:12:46,328 INFO File C:\Documents and Settings\All Users\Desktop\avg free 9.0.lnk not found
2010-02-08 23:12:46,328 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:12:46,328 INFO File C:\Program Files\AVG\AVG9\avg.snu deleted
2010-02-08 23:12:46,359 INFO File C:\Program Files\AVG\AVG9\avg9us.chm deleted
2010-02-08 23:12:46,375 INFO File C:\Program Files\AVG\AVG9\avg9us.lng deleted
2010-02-08 23:12:46,468 INFO File C:\Program Files\AVG\AVG9\avgabout.dll deleted
2010-02-08 23:12:46,484 INFO File C:\Program Files\AVG\AVG9\avgam.exe deleted
2010-02-08 23:12:46,765 INFO File C:\Program Files\AVG\AVG9\avgameh.dll deleted
2010-02-08 23:12:46,796 INFO File C:\Program Files\AVG\AVG9\avgamnot.dll deleted
2010-02-08 23:12:46,796 INFO File C:\Program Files\AVG\AVG9\avgapix.dll deleted
2010-02-08 23:12:46,796 INFO File C:\Program Files\AVG\AVG9\avgar9us.chm deleted
2010-02-08 23:12:46,843 INFO File C:\Program Files\AVG\AVG9\avgas9us.chm deleted
2010-02-08 23:12:46,859 INFO File C:\Program Files\AVG\AVG9\avgaspmx.dll deleted
2010-02-08 23:12:46,984 INFO File C:\Program Files\AVG\AVG9\avgatend.stp deleted
2010-02-08 23:12:47,062 INFO File C:\Program Files\AVG\AVG9\avgatupd.stp deleted
2010-02-08 23:12:47,093 INFO File C:\Program Files\AVG\AVG9\avgbat.bav deleted
2010-02-08 23:12:47,125 INFO File C:\Program Files\AVG\AVG9\avgcclix.dll deleted
2010-02-08 23:12:47,203 INFO File C:\Program Files\AVG\AVG9\avgcertx.dll deleted
2010-02-08 23:12:47,531 INFO File C:\Program Files\AVG\AVG9\avgcfgex.exe deleted
2010-02-08 23:12:47,906 INFO File C:\Program Files\AVG\AVG9\avgcfgx.dll deleted
2010-02-08 23:12:47,968 INFO File C:\Program Files\AVG\AVG9\avgchclx.dll deleted
2010-02-08 23:12:48,046 INFO File C:\Program Files\AVG\AVG9\avgchjwx.dll deleted
2010-02-08 23:12:48,140 INFO File C:\Program Files\AVG\AVG9\avgchsvx.exe deleted
2010-02-08 23:12:48,734 INFO File C:\Program Files\AVG\AVG9\avgclitx.dll deleted
2010-02-08 23:12:48,812 INFO File C:\Program Files\AVG\AVG9\avgcmgr.exe deleted
2010-02-08 23:12:49,000 INFO File C:\Program Files\AVG\AVG9\avgcorex.dll deleted
2010-02-08 23:12:49,093 INFO File C:\Program Files\AVG\AVG9\avgcrlpx.dll deleted
2010-02-08 23:12:49,140 INFO File C:\Program Files\AVG\AVG9\avgcsrvx.exe deleted
2010-02-08 23:12:49,140 INFO File C:\Program Files\AVG\AVG9\avgdg9us.chm deleted
2010-02-08 23:12:49,281 INFO File C:\Program Files\AVG\AVG9\avgdiagex.exe deleted
2010-02-08 23:12:49,875 INFO File C:\Program Files\AVG\AVG9\avgdumpx.exe deleted
2010-02-08 23:12:50,015 INFO File C:\Program Files\AVG\AVG9\avgemc.exe deleted
2010-02-08 23:12:50,437 INFO File C:\Program Files\AVG\AVG9\avgfrw.exe deleted
2010-02-08 23:12:50,468 INFO File C:\Program Files\AVG\AVG9\avgfw9us.chm deleted
2010-02-08 23:12:50,546 INFO File C:\Program Files\AVG\AVG9\avgfws9.exe deleted
2010-02-08 23:12:50,718 INFO File C:\Program Files\AVG\AVG9\avgfwui.dll deleted
2010-02-08 23:12:50,843 INFO File C:\Program Files\AVG\AVG9\avgfwwiz.dll deleted
2010-02-08 23:12:51,734 INFO File C:\Program Files\AVG\AVG9\avgfwwiz.exe deleted
2010-02-08 23:12:51,765 INFO File C:\Program Files\AVG\AVG9\avgidp9us.chm deleted
2010-02-08 23:12:52,437 INFO File C:\Program Files\AVG\AVG9\avgidpsdkx.dll deleted
2010-02-08 23:12:52,625 INFO File C:\Program Files\AVG\AVG9\avginet.dll deleted
2010-02-08 23:12:52,750 INFO File C:\Program Files\AVG\AVG9\avgiproxy.exe deleted
2010-02-08 23:12:52,875 INFO File C:\Program Files\AVG\AVG9\avglngx.dll deleted
2010-02-08 23:12:58,734 DEBUG Removing file C:\Program Files\AVG\AVG9\avglogx.dll failed (error e0010058), planned for delete after restart
2010-02-08 23:12:58,843 INFO File C:\Program Files\AVG\AVG9\avglvex.dll deleted
2010-02-08 23:12:58,921 INFO File C:\Program Files\AVG\AVG9\avgmail.dll deleted
2010-02-08 23:12:58,953 INFO File C:\Program Files\AVG\AVG9\avgmtrapx.dll deleted
2010-02-08 23:12:58,984 INFO File C:\Program Files\AVG\AVG9\avgmvflx.dll deleted
2010-02-08 23:12:59,000 INFO File C:\Program Files\AVG\AVG9\avgmwdef_us.mht deleted
2010-02-08 23:12:59,312 INFO File C:\Program Files\AVG\AVG9\avgnsx.exe deleted
2010-02-08 23:12:59,468 INFO File C:\Program Files\AVG\AVG9\avgpp.dll deleted
2010-02-08 23:12:59,781 INFO File C:\Program Files\AVG\AVG9\avgresf.dll deleted
2010-02-08 23:12:59,859 INFO File C:\Program Files\AVG\AVG9\avgrktx.dll deleted
2010-02-08 23:12:59,890 INFO File C:\Program Files\AVG\AVG9\avgrsx.exe deleted
2010-02-08 23:12:59,953 INFO File C:\Program Files\AVG\AVG9\avgscanx.dll deleted
2010-02-08 23:13:00,203 INFO File C:\Program Files\AVG\AVG9\avgscanx.exe deleted
2010-02-08 23:13:00,250 INFO File C:\Program Files\AVG\AVG9\avgsched.dll deleted
2010-02-08 23:13:00,312 INFO File C:\Program Files\AVG\AVG9\avgse.dll deleted
2010-02-08 23:13:00,359 INFO File C:\Program Files\AVG\AVG9\avgspmui.dll deleted
2010-02-08 23:13:00,687 INFO File C:\Program Files\AVG\AVG9\avgsrmax.exe deleted
2010-02-08 23:13:00,812 INFO File C:\Program Files\AVG\AVG9\avgsrmx.dll deleted
2010-02-08 23:13:00,843 INFO File C:\Program Files\AVG\AVG9\avgssie.dll deleted
2010-02-08 23:13:00,843 INFO File C:\Program Files\AVG\AVG9\avgst9us.chm deleted
2010-02-08 23:13:00,890 INFO File C:\Program Files\AVG\AVG9\avgstrmx.exe deleted
2010-02-08 23:13:00,921 INFO File C:\Program Files\AVG\AVG9\avgsystx.exe deleted
2010-02-08 23:13:00,937 INFO File C:\Program Files\AVG\AVG9\avgtbas.tbp deleted
2010-02-08 23:13:01,093 INFO File C:\Program Files\AVG\AVG9\avgtray.exe deleted
2010-02-08 23:13:01,140 INFO File C:\Program Files\AVG\AVG9\avgui.exe deleted
2010-02-08 23:13:01,218 INFO File C:\Program Files\AVG\AVG9\avguiadv.dll deleted
2010-02-08 23:13:01,328 INFO File C:\Program Files\AVG\AVG9\avguires.dll deleted
2010-02-08 23:13:01,781 INFO File C:\Program Files\AVG\AVG9\avgupd.dll deleted
2010-02-08 23:13:01,921 INFO File C:\Program Files\AVG\AVG9\avgupd.exe deleted
2010-02-08 23:13:02,000 INFO File C:\Program Files\AVG\AVG9\avgvvx.dll deleted
2010-02-08 23:13:02,015 INFO File C:\Program Files\AVG\AVG9\avgwd.dll deleted
2010-02-08 23:13:02,046 INFO File C:\Program Files\AVG\AVG9\avgwdsvc.exe deleted
2010-02-08 23:13:02,156 INFO File C:\Program Files\AVG\AVG9\avgwdwsc.dll deleted
2010-02-08 23:13:02,234 INFO File C:\Program Files\AVG\AVG9\avgwebui.dll deleted
2010-02-08 23:13:02,265 INFO File C:\Program Files\AVG\AVG9\avgxpl.dll deleted
2010-02-08 23:13:02,265 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:02,265 INFO File C:\Program Files\AVG\AVG9\contacts_us.html deleted
2010-02-08 23:13:02,343 INFO File C:\Program Files\AVG\AVG9\dbghelp.dll deleted
2010-02-08 23:13:02,343 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:02,343 INFO File C:\Program Files\AVG\AVG9\dfncfg.dat deleted
2010-02-08 23:13:02,562 INFO File C:\Program Files\AVG\AVG9\imsdk32.dll deleted
2010-02-08 23:13:02,562 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:02,562 INFO File C:\Program Files\AVG\AVG9\license_us.htm deleted
2010-02-08 23:13:02,609 INFO File C:\Program Files\AVG\AVG9\libsasl.dll deleted
2010-02-08 23:13:02,609 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:02,640 INFO File C:\Program Files\AVG\AVG9\saslcrammd5.dll deleted
2010-02-08 23:13:02,671 INFO File C:\Program Files\AVG\AVG9\sasldigestmd5.dll deleted
2010-02-08 23:13:02,796 INFO File C:\Program Files\AVG\AVG9\sasllogin.dll deleted
2010-02-08 23:13:02,828 INFO File C:\Program Files\AVG\AVG9\saslplain.dll deleted
2010-02-08 23:13:02,828 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:02,843 INFO File C:\Program Files\AVG\AVG9\setup.dat deleted
2010-02-08 23:13:02,875 INFO File C:\Program Files\AVG\AVG9\setup.exe deleted
2010-02-08 23:13:02,937 INFO File C:\Program Files\AVG\AVG9\setupus.lns deleted
2010-02-08 23:13:02,937 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:03,062 INFO File C:\Program Files\AVG\AVG9\fixcfg.exe deleted
2010-02-08 23:13:03,062 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:03,093 INFO File C:\Program Files\AVG\AVG9\updatecomps.bak deleted
2010-02-08 23:13:03,093 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\winspamcatcher.dll deleted
2010-02-08 23:13:03,156 DEBUG Processing item C:\Program Files\AVG\AVG9
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\cf.dat deleted
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\ph.dat deleted
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\sb.dat deleted
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\sb.dat.xcd deleted
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\sb2.dat deleted
2010-02-08 23:13:03,156 INFO File C:\Program Files\AVG\AVG9\sc.dat deleted
2010-02-08 23:13:03,187 INFO File C:\Program Files\AVG\AVG9\sc.dat.xcd deleted
2010-02-08 23:13:03,187 DEBUG Processing item C:\Program Files\AVG\AVG9\Icons
2010-02-08 23:13:03,265 INFO File C:\Program Files\AVG\AVG9\Icons\background_middle_gray.gif deleted
2010-02-08 23:13:03,281 INFO File C:\Program Files\AVG\AVG9\Icons\background_middle_green.gif deleted
2010-02-08 23:13:03,281 INFO File C:\Program Files\AVG\AVG9\Icons\background_middle_orange.gif deleted
2010-02-08 23:13:03,281 INFO File C:\Program Files\AVG\AVG9\Icons\background_middle_red.gif deleted
2010-02-08 23:13:03,296 INFO File C:\Program Files\AVG\AVG9\Icons\background_middle_yellow.gif deleted
2010-02-08 23:13:03,296 INFO File C:\Program Files\AVG\AVG9\Icons\background_top_gray.gif deleted
2010-02-08 23:13:03,312 INFO File C:\Program Files\AVG\AVG9\Icons\background_top_green.gif deleted
2010-02-08 23:13:03,312 INFO File C:\Program Files\AVG\AVG9\Icons\background_top_orange.gif deleted
2010-02-08 23:13:03,343 INFO File C:\Program Files\AVG\AVG9\Icons\background_top_red.gif deleted
2010-02-08 23:13:03,343 INFO File C:\Program Files\AVG\AVG9\Icons\background_top_yellow.gif deleted
2010-02-08 23:13:03,359 INFO File C:\Program Files\AVG\AVG9\Icons\block-doc.gif deleted
2010-02-08 23:13:03,375 INFO File C:\Program Files\AVG\AVG9\Icons\blocked.gif deleted
2010-02-08 23:13:03,390 INFO File C:\Program Files\AVG\AVG9\Icons\border_bottom_gray.gif deleted
2010-02-08 23:13:03,390 INFO File C:\Program Files\AVG\AVG9\Icons\border_bottom_green.gif deleted
2010-02-08 23:13:03,406 INFO File C:\Program Files\AVG\AVG9\Icons\border_bottom_orange.gif deleted
2010-02-08 23:13:03,406 INFO File C:\Program Files\AVG\AVG9\Icons\border_bottom_red.gif deleted
2010-02-08 23:13:03,453 INFO File C:\Program Files\AVG\AVG9\Icons\border_bottom_yellow.gif deleted
2010-02-08 23:13:03,453 INFO File C:\Program Files\AVG\AVG9\Icons\border_top_gray.gif deleted
2010-02-08 23:13:03,453 INFO File C:\Program Files\AVG\AVG9\Icons\border_top_green.gif deleted
2010-02-08 23:13:03,453 INFO File C:\Program Files\AVG\AVG9\Icons\border_top_orange.gif deleted
2010-02-08 23:13:03,468 INFO File C:\Program Files\AVG\AVG9\Icons\border_top_red.gif deleted
2010-02-08 23:13:03,500 INFO File C:\Program Files\AVG\AVG9\Icons\border_top_yellow.gif deleted
2010-02-08 23:13:03,500 INFO File C:\Program Files\AVG\AVG9\Icons\box_bottom_red.gif deleted
2010-02-08 23:13:03,500 INFO File C:\Program Files\AVG\AVG9\Icons\box_top_red.gif deleted
2010-02-08 23:13:03,500 INFO File C:\Program Files\AVG\AVG9\Icons\caution.gif deleted
2010-02-08 23:13:03,531 INFO File C:\Program Files\AVG\AVG9\Icons\click_here_gray.gif deleted
2010-02-08 23:13:03,531 INFO File C:\Program Files\AVG\AVG9\Icons\click_here_green.gif deleted
2010-02-08 23:13:03,531 INFO File C:\Program Files\AVG\AVG9\Icons\click_here_orange.gif deleted
2010-02-08 23:13:03,531 INFO File C:\Program Files\AVG\AVG9\Icons\click_here_red.gif deleted
2010-02-08 23:13:03,562 INFO File C:\Program Files\AVG\AVG9\Icons\click_here_yellow.gif deleted
2010-02-08 23:13:03,562 INFO File C:\Program Files\AVG\AVG9\Icons\clock.gif deleted
2010-02-08 23:13:03,578 INFO File C:\Program Files\AVG\AVG9\Icons\close.gif deleted
2010-02-08 23:13:03,609 INFO File C:\Program Files\AVG\AVG9\Icons\icons_blocked.gif deleted
2010-02-08 23:13:03,609 INFO File C:\Program Files\AVG\AVG9\Icons\icons_caution.gif deleted
2010-02-08 23:13:03,625 INFO File C:\Program Files\AVG\AVG9\Icons\icons_close.gif deleted
2010-02-08 23:13:03,640 INFO File C:\Program Files\AVG\AVG9\Icons\icons_safe.gif deleted
2010-02-08 23:13:03,640 INFO File C:\Program Files\AVG\AVG9\Icons\icons_unknown.gif deleted
2010-02-08 23:13:03,640 INFO File C:\Program Files\AVG\AVG9\Icons\icons_warning.gif deleted
2010-02-08 23:13:03,640 INFO File C:\Program Files\AVG\AVG9\Icons\LS_Logo_Results.gif deleted
2010-02-08 23:13:03,656 INFO File C:\Program Files\AVG\AVG9\Icons\safe.gif deleted
2010-02-08 23:13:03,656 INFO File C:\Program Files\AVG\AVG9\Icons\unknown.gif deleted
2010-02-08 23:13:03,656 INFO File C:\Program Files\AVG\AVG9\Icons\warning.gif deleted
2010-02-08 23:13:03,671 INFO Directory C:\Program Files\AVG\AVG9\Icons deleted
2010-02-08 23:13:03,671 DEBUG Processing item C:\Program Files\AVG\AVG9\Firefox\Chrome
2010-02-08 23:13:03,671 INFO File C:\Program Files\AVG\AVG9\Firefox\Chrome\searchshield.jar deleted
2010-02-08 23:13:03,953 INFO Directory C:\Program Files\AVG\AVG9\Firefox\Chrome deleted
2010-02-08 23:13:03,953 DEBUG Processing item C:\Program Files\AVG\AVG9\Firefox\Components
2010-02-08 23:13:04,156 INFO File C:\Program Files\AVG\AVG9\Firefox\Components\avgssff.dll deleted
2010-02-08 23:13:04,156 INFO File C:\Program Files\AVG\AVG9\Firefox\Components\ISearchShield.xpt deleted
2010-02-08 23:13:04,281 INFO Directory C:\Program Files\AVG\AVG9\Firefox\Components deleted
2010-02-08 23:13:04,281 DEBUG Processing item C:\Program Files\AVG\AVG9\Firefox
2010-02-08 23:13:04,531 INFO File C:\Program Files\AVG\AVG9\Firefox\chrome.manifest deleted
2010-02-08 23:13:04,531 INFO File C:\Program Files\AVG\AVG9\Firefox\install.rdf deleted
2010-02-08 23:13:04,812 INFO Directory C:\Program Files\AVG\AVG9\Firefox deleted
2010-02-08 23:13:04,812 DEBUG Processing item C:\Program Files\AVG\AVG9\Drivers\avgfwd
2010-02-08 23:13:05,156 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwda.dll deleted
2010-02-08 23:13:05,218 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwda.sys deleted
2010-02-08 23:13:05,781 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwdx.dll deleted
2010-02-08 23:13:05,812 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwdx.sys deleted
2010-02-08 23:13:05,859 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwfd.cat deleted
2010-02-08 23:13:05,968 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfwfd.inf deleted
2010-02-08 23:13:06,203 INFO File C:\Program Files\AVG\AVG9\Drivers\avgfwd\avgfw_m.inf deleted
2010-02-08 23:13:06,203 INFO Directory C:\Program Files\AVG\AVG9\Drivers\avgfwd deleted
2010-02-08 23:13:06,218 DEBUG Processing item C:\Program Files\AVG\AVG9\Drivers\avgfwd6
2010-02-08 23:13:06,218 INFO Directory C:\Program Files\AVG\AVG9\Drivers\avgfwd6 not found
2010-02-08 23:13:06,328 INFO Directory C:\Program Files\AVG\AVG9\Drivers deleted
2010-02-08 23:13:06,328 DEBUG Processing item C:\Program Files\AVG\AVG9\Notification
2010-02-08 23:13:06,390 INFO File C:\Program Files\AVG\AVG9\Notification\update-payment-details-bkg.png deleted
2010-02-08 23:13:06,406 INFO File C:\Program Files\AVG\AVG9\Notification\update-payment-details-btn.png deleted
2010-02-08 23:13:06,406 INFO File C:\Program Files\AVG\AVG9\Notification\update-payment-details-style.css deleted
2010-02-08 23:13:06,406 INFO File C:\Program Files\AVG\AVG9\Notification\update-payment-details.htm deleted
2010-02-08 23:13:06,437 INFO Directory C:\Program Files\AVG\AVG9\Notification deleted
2010-02-08 23:13:06,437 DEBUG Processing item C:\Program Files\AVG\AVG9\Log
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Log deleted
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\content\html
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\content\html not found
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\content\Languages
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\content\Languages not found
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\content not found
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\skin
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome\skin not found
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41\chrome not found
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_41 not found
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\content\html
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\content\html not found
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\content\Languages
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\content\Languages not found
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\content not found
2010-02-08 23:13:06,765 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\skin
2010-02-08 23:13:06,765 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome\skin not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42\chrome not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\ch_42 not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\avg
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\avg not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\ex
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\ex not found
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 9th February 2010, 8:22 pm
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\html
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\html not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\Languages
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\Languages not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\libs
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\libs not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\libsex
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content\libsex not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\content not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\icons\default
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\icons\default not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\icons not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\skin
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome\skin not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\chrome not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared\components not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox\avg@igeared not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Firefox not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar\Update
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar\Update not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\content\html
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\content\html not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\content\Languages
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\content\Languages not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\content not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\skin
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome\skin not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41\chrome not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_41 not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\content\html
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\content\html not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\content\Languages
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\content\Languages not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\content not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\skin
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome\skin not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42\chrome not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\ch_42 not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\avg
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\avg not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\ex
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\ex not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\html
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\html not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\Languages
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\Languages not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\libs
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\libs not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\libsex
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content\libsex not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\content not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\icons\default
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\icons\default not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\icons not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\skin
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome\skin not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\chrome not found
2010-02-08 23:13:06,781 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\components
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared\components not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox\avg@igeared not found
2010-02-08 23:13:06,781 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Firefox not found
2010-02-08 23:13:06,796 DEBUG Processing item C:\Program Files\AVG\AVG9\Toolbar.old\Update
2010-02-08 23:13:06,796 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old\Update not found
2010-02-08 23:13:06,796 INFO Directory C:\Program Files\AVG\AVG9\Toolbar.old not found
2010-02-08 23:13:06,796 DEBUG Directory C:\Program Files\AVG\AVG9 not deleted (error c0070091)
2010-02-08 23:13:06,796 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\update\prepare
2010-02-08 23:13:06,937 DEBUG Directory C:\Documents and Settings\All Users\Application Data\avg9\update\prepare not deleted (error c0070091)
2010-02-08 23:13:06,937 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\update\backup
2010-02-08 23:13:07,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avg9us.lng deleted
2010-02-08 23:13:07,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgabout.dll deleted
2010-02-08 23:13:07,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgamnot.dll deleted
2010-02-08 23:13:07,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgapix.dll deleted
2010-02-08 23:13:07,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcclix.dll deleted
2010-02-08 23:13:07,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcfgex.exe deleted
2010-02-08 23:13:07,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcfgx.dll deleted
2010-02-08 23:13:07,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgclitx.dll deleted
2010-02-08 23:13:07,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcorex.dll deleted
2010-02-08 23:13:07,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcrlpx.dll deleted
2010-02-08 23:13:07,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgcsrvx.exe deleted
2010-02-08 23:13:08,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgdiagex.exe deleted
2010-02-08 23:13:08,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgdumpx.exe deleted
2010-02-08 23:13:08,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgfrw.exe deleted
2010-02-08 23:13:08,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgfws9.exe deleted
2010-02-08 23:13:08,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avglngx.dll deleted
2010-02-08 23:13:08,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avglogx.dll deleted
2010-02-08 23:13:08,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgmail.dll deleted
2010-02-08 23:13:08,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgmtrapx.dll deleted
2010-02-08 23:13:08,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgmvflx.dll deleted
2010-02-08 23:13:08,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgmwdef_us.mht deleted
2010-02-08 23:13:09,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgresf.dll deleted
2010-02-08 23:13:09,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgscanx.dll deleted
2010-02-08 23:13:09,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgscanx.exe deleted
2010-02-08 23:13:09,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgsched.dll deleted
2010-02-08 23:13:09,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgse.dll deleted
2010-02-08 23:13:09,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgsrmax.exe deleted
2010-02-08 23:13:09,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgsrmx.dll deleted
2010-02-08 23:13:09,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgtray.exe deleted
2010-02-08 23:13:09,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgui.exe deleted
2010-02-08 23:13:09,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avguiadv.dll deleted
2010-02-08 23:13:09,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avguilog.cfg deleted
2010-02-08 23:13:09,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avguires.dll deleted
2010-02-08 23:13:10,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgvvx.dll deleted
2010-02-08 23:13:10,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgwd.dll deleted
2010-02-08 23:13:10,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgwdsvc.exe deleted
2010-02-08 23:13:10,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\avgwdwsc.dll deleted
2010-02-08 23:13:10,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\axioo.dll deleted
2010-02-08 23:13:10,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\cfgexlog.cfg deleted
2010-02-08 23:13:10,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\cfglog.cfg deleted
2010-02-08 23:13:10,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\corelog.cfg deleted
2010-02-08 23:13:10,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\cty.cty deleted
2010-02-08 23:13:10,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\dfncfg.dat deleted
2010-02-08 23:13:10,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\fixcfg.exe deleted
2010-02-08 23:13:10,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\iavifw.avm deleted
2010-02-08 23:13:11,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\incavi.avm deleted
2010-02-08 23:13:11,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\ldrlog.cfg deleted
2010-02-08 23:13:11,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\lnglog.cfg deleted
2010-02-08 23:13:11,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\privlog.cfg deleted
2010-02-08 23:13:11,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\publog.cfg deleted
2010-02-08 23:13:11,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\rslog.cfg deleted
2010-02-08 23:13:11,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\sb.dat deleted
2010-02-08 23:13:11,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\sb.dat.xcd deleted
2010-02-08 23:13:11,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\sb2.dat deleted
2010-02-08 23:13:11,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\sc.dat deleted
2010-02-08 23:13:11,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\sc.dat.xcd deleted
2010-02-08 23:13:11,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\scanlog.cfg deleted
2010-02-08 23:13:11,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\schedlog.cfg deleted
2010-02-08 23:13:11,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\setup.dat deleted
2010-02-08 23:13:11,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\setup.exe deleted
2010-02-08 23:13:11,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\setupus.lns deleted
2010-02-08 23:13:12,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\srmlog.cfg deleted
2010-02-08 23:13:12,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\updlog.cfg deleted
2010-02-08 23:13:12,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\vaultlog.cfg deleted
2010-02-08 23:13:12,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\wdlog.cfg deleted
2010-02-08 23:13:12,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\backup\wdsvclog.cfg deleted
2010-02-08 23:13:12,796 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\update\backup deleted
2010-02-08 23:13:12,796 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\update\download\ads
2010-02-08 23:13:13,046 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\update\download\ads deleted
2010-02-08 23:13:13,046 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\update\download
2010-02-08 23:13:13,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\avg9infoavi.ctf deleted
2010-02-08 23:13:13,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\avg9infowin.ctf deleted
2010-02-08 23:13:13,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1836u1705ur.bin deleted
2010-02-08 23:13:13,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1837u1705yr.bin deleted
2010-02-08 23:13:13,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1838u17052u.bin deleted
2010-02-08 23:13:13,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1839u1705mt.bin deleted
2010-02-08 23:13:13,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1840u17056u.bin deleted
2010-02-08 23:13:13,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1841u1705qv.bin deleted
2010-02-08 23:13:13,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1842u1705av.bin deleted
2010-02-08 23:13:13,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1843u1705uw.bin deleted
2010-02-08 23:13:13,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1844u1705ez.bin deleted
2010-02-08 23:13:13,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1845u17057g.bin deleted
2010-02-08 23:13:13,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1846u1705ix.bin deleted
2010-02-08 23:13:13,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1849u1705n2.bin deleted
2010-02-08 23:13:13,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1850u17056z.bin deleted
2010-02-08 23:13:13,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1851u1705r1.bin deleted
2010-02-08 23:13:13,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1852u1705b0.bin deleted
2010-02-08 23:13:13,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1853u1705v0.bin deleted
2010-02-08 23:13:13,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1854u1705f2.bin deleted
2010-02-08 23:13:13,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1855u1705j3.bin deleted
2010-02-08 23:13:13,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7avi1856u17057.bin deleted
2010-02-08 23:13:13,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2606u2605qq.bin deleted
2010-02-08 23:13:14,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2608u2606us.bin deleted
2010-02-08 23:13:14,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2609u2608es.bin deleted
2010-02-08 23:13:14,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2610u2609ys.bin deleted
2010-02-08 23:13:14,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2611u2610it.bin deleted
2010-02-08 23:13:14,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2612u26112u.bin deleted
2010-02-08 23:13:14,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2613u2612mu.bin deleted
2010-02-08 23:13:14,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2614u2613wq.bin deleted
2010-02-08 23:13:14,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2615u26146v.bin deleted
2010-02-08 23:13:14,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2616u2615qv.bin deleted
2010-02-08 23:13:14,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2617u2616av.bin deleted
2010-02-08 23:13:14,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2618u2617uw.bin deleted
2010-02-08 23:13:14,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2619u2618ez.bin deleted
2010-02-08 23:13:14,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2620u2619yw.bin deleted
2010-02-08 23:13:14,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2621u26207g.bin deleted
2010-02-08 23:13:14,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2622u2621ix.bin deleted
2010-02-08 23:13:14,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2625u2620n4.bin deleted
2010-02-08 23:13:14,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2626u26256z.bin deleted
2010-02-08 23:13:14,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2627u2626r1.bin deleted
2010-02-08 23:13:14,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2628u2627b0.bin deleted
2010-02-08 23:13:14,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2629u2628v0.bin deleted
2010-02-08 23:13:14,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2631u2629ur.bin deleted
2010-02-08 23:13:14,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2632u2631j3.bin deleted
2010-02-08 23:13:14,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2633u26239.bin deleted
2010-02-08 23:13:14,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u7iavi2633u26327.bin deleted
2010-02-08 23:13:14,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2634u2633fp.bin deleted
2010-02-08 23:13:14,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2635u2634ck.bin deleted
2010-02-08 23:13:14,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2639u2634ep.bin deleted
2010-02-08 23:13:14,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2640u2639lh.bin deleted
2010-02-08 23:13:14,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2641u2640uq.bin deleted
2010-02-08 23:13:14,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2642u2641iy.bin deleted
2010-02-08 23:13:14,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2643u2642mu.bin deleted
2010-02-08 23:13:14,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2645u2643dl.bin deleted
2010-02-08 23:13:14,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2647u2645vn.bin deleted
2010-02-08 23:13:14,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2650u2645cx.bin deleted
2010-02-08 23:13:14,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2653u2650nt.bin deleted
2010-02-08 23:13:14,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2654u2653cx.bin deleted
2010-02-08 23:13:14,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2656u2654hm.bin deleted
2010-02-08 23:13:15,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2657u2656uc.bin deleted
2010-02-08 23:13:15,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2662u2657ft.bin deleted
2010-02-08 23:13:15,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2663u2662qe.bin deleted
2010-02-08 23:13:15,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2664u2663pt.bin deleted
2010-02-08 23:13:15,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2665u2664kj.bin deleted
2010-02-08 23:13:15,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2666u2665zo.bin deleted
2010-02-08 23:13:15,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2668u2666jb.bin deleted
2010-02-08 23:13:15,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2669u2668ym.bin deleted
2010-02-08 23:13:15,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9iavi2670u2669yc.bin deleted
2010-02-08 23:13:15,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9ifw52u51rg.bin deleted
2010-02-08 23:13:15,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9ifw53u52df.bin deleted
2010-02-08 23:13:15,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9ifw54u53ov.bin deleted
2010-02-08 23:13:15,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9ifw55u54gh.bin deleted
2010-02-08 23:13:15,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\u9ifw56u55uj.bin deleted
2010-02-08 23:13:15,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9core725b716dn.bin deleted
2010-02-08 23:13:15,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9core725er.bin deleted
2010-02-08 23:13:15,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9core729b725gn.bin deleted
2010-02-08 23:13:15,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9fc1717b716em.bin deleted
2010-02-08 23:13:15,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9fc1717pm.bin deleted
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
Post by Thebeast28 on 9th February 2010, 8:23 pm
2010-02-08 23:13:15,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9fc48q4.bin deleted
2010-02-08 23:13:15,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9fw726b713ii.bin deleted
2010-02-08 23:13:15,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9krnl720b716xh.bin deleted
2010-02-08 23:13:15,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9krnl720mc.bin deleted
2010-02-08 23:13:15,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9lng720bn.bin deleted
2010-02-08 23:13:15,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9lngus721b716fe.bin deleted
2010-02-08 23:13:15,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9lngus721po.bin deleted
2010-02-08 23:13:15,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9lngus726b721ot.bin deleted
2010-02-08 23:13:15,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9setup720b716nz.bin deleted
2010-02-08 23:13:15,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9setup720ub.bin deleted
2010-02-08 23:13:15,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9setup727b720fe.bin deleted
2010-02-08 23:13:16,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9setup733b727sx.bin deleted
2010-02-08 23:13:16,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9ui724b715rd.bin deleted
2010-02-08 23:13:16,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9ui724oh.bin deleted
2010-02-08 23:13:16,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9ui730b724hb.bin deleted
2010-02-08 23:13:16,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\w9ui733b730vd.bin deleted
2010-02-08 23:13:16,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_126zu.bin deleted
2010-02-08 23:13:16,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_1277x.bin deleted
2010-02-08 23:13:16,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_128k0.bin deleted
2010-02-08 23:13:16,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_129s2.bin deleted
2010-02-08 23:13:16,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_130g9.bin deleted
2010-02-08 23:13:16,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb2_131ob.bin deleted
2010-02-08 23:13:16,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_109vt.bin deleted
2010-02-08 23:13:16,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_1107x.bin deleted
2010-02-08 23:13:16,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_110d1097x.bin deleted
2010-02-08 23:13:16,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_111d110k0.bin deleted
2010-02-08 23:13:16,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_112d111s2.bin deleted
2010-02-08 23:13:16,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_113d112c8.bin deleted
2010-02-08 23:13:16,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_114d112g9.bin deleted
2010-02-08 23:13:16,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_114d113g9.bin deleted
2010-02-08 23:13:16,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_114g9.bin deleted
2010-02-08 23:13:16,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_115d114ka.bin deleted
2010-02-08 23:13:16,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_116d115hy.bin deleted
2010-02-08 23:13:16,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_117d1167m.bin deleted
2010-02-08 23:13:16,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsb_118d117jq.bin deleted
2010-02-08 23:13:16,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_165vt.bin deleted
2010-02-08 23:13:16,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_166d165o1.bin deleted
2010-02-08 23:13:16,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_167d166w3.bin deleted
2010-02-08 23:13:16,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_168d167o9.bin deleted
2010-02-08 23:13:16,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_169d168in.bin deleted
2010-02-08 23:13:16,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_170c8.bin deleted
2010-02-08 23:13:16,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_170d169c8.bin deleted
2010-02-08 23:13:16,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_171d170ob.bin deleted
2010-02-08 23:13:16,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_172d1714g.bin deleted
2010-02-08 23:13:16,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_173d1727m.bin deleted
2010-02-08 23:13:16,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_174d173ws.bin deleted
2010-02-08 23:13:16,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_175d174jq.bin deleted
2010-02-08 23:13:16,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_176d175nr.bin deleted
2010-02-08 23:13:17,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\update\download\x8xplsc_177d176rs.bin deleted
2010-02-08 23:13:17,953 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\update\download deleted
2010-02-08 23:13:17,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\update
2010-02-08 23:13:17,953 DEBUG Directory C:\Documents and Settings\All Users\Application Data\avg9\update not deleted (error c0070091)
2010-02-08 23:13:17,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Lsdb\Prev
2010-02-08 23:13:17,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Lsdb\Prev\prvcache.dat deleted
2010-02-08 23:13:18,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Lsdb\Prev\prvglbl.dat deleted
2010-02-08 23:13:18,156 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Lsdb\Prev deleted
2010-02-08 23:13:18,156 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Lsdb
2010-02-08 23:13:18,328 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Lsdb deleted
2010-02-08 23:13:18,328 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\scanlogs
2010-02-08 23:13:18,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000001.log deleted
2010-02-08 23:13:18,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000003.log deleted
2010-02-08 23:13:18,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000004.log deleted
2010-02-08 23:13:18,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000005.log deleted
2010-02-08 23:13:18,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000006.log deleted
2010-02-08 23:13:18,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000007.log deleted
2010-02-08 23:13:18,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000008.log deleted
2010-02-08 23:13:18,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000009.log deleted
2010-02-08 23:13:18,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\I_00000010.log deleted
2010-02-08 23:13:18,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\scanlogs\srm.idx deleted
2010-02-08 23:13:19,046 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\scanlogs deleted
2010-02-08 23:13:19,046 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\log
2010-02-08 23:13:19,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\amlog.cfg deleted
2010-02-08 23:13:19,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgam.log deleted
2010-02-08 23:13:19,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgam.log.lock deleted
2010-02-08 23:13:19,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcfg.log deleted
2010-02-08 23:13:19,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcfg.log.lock deleted
2010-02-08 23:13:19,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjw.log deleted
2010-02-08 23:13:19,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjw.log.1 deleted
2010-02-08 23:13:19,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjw.log.2 deleted
2010-02-08 23:13:19,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjw.log.3 deleted
2010-02-08 23:13:19,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjw.log.lock deleted
2010-02-08 23:13:19,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjwsrv.log deleted
2010-02-08 23:13:19,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjwsrv.log.1 deleted
2010-02-08 23:13:19,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgchjwsrv.log.lock deleted
2010-02-08 23:13:19,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log deleted
2010-02-08 23:13:19,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.1 deleted
2010-02-08 23:13:19,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.10 deleted
2010-02-08 23:13:20,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.2 deleted
2010-02-08 23:13:20,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.3 deleted
2010-02-08 23:13:20,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.4 deleted
2010-02-08 23:13:20,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.5 deleted
2010-02-08 23:13:20,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.6 deleted
2010-02-08 23:13:20,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.7 deleted
2010-02-08 23:13:20,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.8 deleted
2010-02-08 23:13:20,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.9 deleted
2010-02-08 23:13:20,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgcore.log.lock deleted
2010-02-08 23:13:20,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfrw.log deleted
2010-02-08 23:13:20,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfrw.log.lock deleted
2010-02-08 23:13:20,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log deleted
2010-02-08 23:13:20,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.1 deleted
2010-02-08 23:13:21,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.10 deleted
2010-02-08 23:13:21,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.2 deleted
2010-02-08 23:13:21,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.3 deleted
2010-02-08 23:13:21,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.4 deleted
2010-02-08 23:13:21,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.5 deleted
2010-02-08 23:13:21,453 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.6 deleted
2010-02-08 23:13:21,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.7 deleted
2010-02-08 23:13:21,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.8 deleted
2010-02-08 23:13:21,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.9 deleted
2010-02-08 23:13:21,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw.log.lock deleted
2010-02-08 23:13:21,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw8db.log deleted
2010-02-08 23:13:21,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw8db.log.lock deleted
2010-02-08 23:13:21,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw8u.log deleted
2010-02-08 23:13:21,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfw8u.log.lock deleted
2010-02-08 23:13:21,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfwui.log deleted
2010-02-08 23:13:21,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgfwui.log.lock deleted
2010-02-08 23:13:21,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgldr.log deleted
2010-02-08 23:13:21,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgldr.log.lock deleted
2010-02-08 23:13:21,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avglng.log deleted
2010-02-08 23:13:21,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avglng.log.lock deleted
2010-02-08 23:13:21,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log deleted
2010-02-08 23:13:21,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.1 deleted
2010-02-08 23:13:21,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.10 deleted
2010-02-08 23:13:21,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.2 deleted
2010-02-08 23:13:22,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.3 deleted
2010-02-08 23:13:22,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.4 deleted
2010-02-08 23:13:22,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.5 deleted
2010-02-08 23:13:22,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.6 deleted
2010-02-08 23:13:22,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.7 deleted
2010-02-08 23:13:22,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.8 deleted
2010-02-08 23:13:22,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.9 deleted
2010-02-08 23:13:22,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgns.log.lock deleted
2010-02-08 23:13:22,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log deleted
2010-02-08 23:13:22,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.1 deleted
2010-02-08 23:13:22,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.10 deleted
2010-02-08 23:13:22,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.2 deleted
2010-02-08 23:13:22,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.3 deleted
2010-02-08 23:13:22,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.4 deleted
2010-02-08 23:13:22,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.5 deleted
2010-02-08 23:13:22,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.6 deleted
2010-02-08 23:13:22,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.7 deleted
2010-02-08 23:13:22,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.8 deleted
2010-02-08 23:13:22,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.9 deleted
2010-02-08 23:13:22,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgrs.log.lock deleted
2010-02-08 23:13:22,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgscan.log deleted
2010-02-08 23:13:22,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgscan.log.lock deleted
2010-02-08 23:13:22,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log deleted
2010-02-08 23:13:23,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.1 deleted
2010-02-08 23:13:23,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.10 deleted
2010-02-08 23:13:23,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.2 deleted
2010-02-08 23:13:23,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.3 deleted
2010-02-08 23:13:23,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.4 deleted
2010-02-08 23:13:23,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.5 deleted
2010-02-08 23:13:23,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.6 deleted
2010-02-08 23:13:23,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.7 deleted
2010-02-08 23:13:23,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.8 deleted
2010-02-08 23:13:23,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.9 deleted
2010-02-08 23:13:23,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsched.log.lock deleted
2010-02-08 23:13:23,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrm.log deleted
2010-02-08 23:13:23,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrm.log.lock deleted
2010-02-08 23:13:23,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrmac.log deleted
2010-02-08 23:13:23,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrmac.log.lock deleted
2010-02-08 23:13:23,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrmacstat.log deleted
2010-02-08 23:13:23,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsrmacstat.log.lock deleted
2010-02-08 23:13:23,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log deleted
2010-02-08 23:13:23,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.1 deleted
2010-02-08 23:13:23,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.10 deleted
2010-02-08 23:13:23,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.2 deleted
2010-02-08 23:13:23,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.3 deleted
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 9th February 2010, 8:24 pm
2010-02-08 23:13:23,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.4 deleted
2010-02-08 23:13:23,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.5 deleted
2010-02-08 23:13:23,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.6 deleted
2010-02-08 23:13:23,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.7 deleted
2010-02-08 23:13:23,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.8 deleted
2010-02-08 23:13:23,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.9 deleted
2010-02-08 23:13:23,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgsystools.log.lock deleted
2010-02-08 23:13:23,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgtdi.log deleted
2010-02-08 23:13:23,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgtdi.log.lock deleted
2010-02-08 23:13:23,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgui.log deleted
2010-02-08 23:13:23,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgui.log.1 deleted
2010-02-08 23:13:23,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgui.log.lock deleted
2010-02-08 23:13:23,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avguilog.cfg deleted
2010-02-08 23:13:24,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgupd.log deleted
2010-02-08 23:13:24,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgupd.log.1 deleted
2010-02-08 23:13:24,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgupd.log.lock deleted
2010-02-08 23:13:24,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log deleted
2010-02-08 23:13:25,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.1 deleted
2010-02-08 23:13:25,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.10 deleted
2010-02-08 23:13:25,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.2 deleted
2010-02-08 23:13:25,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.3 deleted
2010-02-08 23:13:25,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.4 deleted
2010-02-08 23:13:25,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.5 deleted
2010-02-08 23:13:25,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.6 deleted
2010-02-08 23:13:25,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.7 deleted
2010-02-08 23:13:25,406 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.8 deleted
2010-02-08 23:13:25,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.9 deleted
2010-02-08 23:13:25,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwd.log.lock deleted
2010-02-08 23:13:25,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwdsvc.log deleted
2010-02-08 23:13:25,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\avgwdsvc.log.lock deleted
2010-02-08 23:13:25,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\cfgexlog.cfg deleted
2010-02-08 23:13:25,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\cfglog.cfg deleted
2010-02-08 23:13:26,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\chjwlog.cfg deleted
2010-02-08 23:13:26,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log deleted
2010-02-08 23:13:26,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.1 deleted
2010-02-08 23:13:26,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.10 deleted
2010-02-08 23:13:26,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.2 deleted
2010-02-08 23:13:26,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.3 deleted
2010-02-08 23:13:26,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.4 deleted
2010-02-08 23:13:26,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.5 deleted
2010-02-08 23:13:26,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.6 deleted
2010-02-08 23:13:26,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.7 deleted
2010-02-08 23:13:26,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.8 deleted
2010-02-08 23:13:26,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.9 deleted
2010-02-08 23:13:26,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpriv.log.lock deleted
2010-02-08 23:13:26,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpub.log deleted
2010-02-08 23:13:26,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\commonpub.log.lock deleted
2010-02-08 23:13:26,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\corelog.cfg deleted
2010-02-08 23:13:26,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\fixcfg.log deleted
2010-02-08 23:13:26,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\fixcfg.log.lock deleted
2010-02-08 23:13:26,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\fwlog.cfg deleted
2010-02-08 23:13:26,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\fwstats_2010_02_08_23_12.fwstats deleted
2010-02-08 23:13:26,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\history.xml deleted
2010-02-08 23:13:27,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\ldrlog.cfg deleted
2010-02-08 23:13:27,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\lnglog.cfg deleted
2010-02-08 23:13:27,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\nslog.cfg deleted
2010-02-08 23:13:27,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\privlog.cfg deleted
2010-02-08 23:13:27,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\publog.cfg deleted
2010-02-08 23:13:28,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\rslog.cfg deleted
2010-02-08 23:13:28,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\scanlog.cfg deleted
2010-02-08 23:13:29,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\schedlog.cfg deleted
2010-02-08 23:13:29,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\srmlog.cfg deleted
2010-02-08 23:13:29,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\systoolslog.cfg deleted
2010-02-08 23:13:29,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\tdilog.cfg deleted
2010-02-08 23:13:29,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\updlog.cfg deleted
2010-02-08 23:13:29,812 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\vault.log deleted
2010-02-08 23:13:29,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\vault.log.lock deleted
2010-02-08 23:13:30,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\vaultlog.cfg deleted
2010-02-08 23:13:30,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\wdlog.cfg deleted
2010-02-08 23:13:30,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\log\wdsvclog.cfg deleted
2010-02-08 23:13:30,296 DEBUG Directory C:\Documents and Settings\All Users\Application Data\avg9\log not deleted (error c0070091)
2010-02-08 23:13:30,296 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\active
2010-02-08 23:13:30,734 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\active deleted
2010-02-08 23:13:30,734 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\out
2010-02-08 23:13:31,046 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\out deleted
2010-02-08 23:13:31,046 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\temp
2010-02-08 23:13:31,390 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc\queue\temp deleted
2010-02-08 23:13:31,390 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc\queue
2010-02-08 23:13:31,656 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc\queue deleted
2010-02-08 23:13:31,656 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc\log
2010-02-08 23:13:31,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\emc\log\emc.log deleted
2010-02-08 23:13:31,953 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc\log deleted
2010-02-08 23:13:31,953 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\emc
2010-02-08 23:13:32,125 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\emc deleted
2010-02-08 23:13:32,125 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\dumps
2010-02-08 23:13:32,312 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\dumps deleted
2010-02-08 23:13:32,312 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Cfg\Avg7Fw
2010-02-08 23:13:32,312 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Cfg\Avg7Fw not found
2010-02-08 23:13:32,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\admin.cfg deleted
2010-02-08 23:13:32,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\aspam.cfg deleted
2010-02-08 23:13:32,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\changecfgreg.cfg deleted
2010-02-08 23:13:32,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\emssrv.cfg deleted
2010-02-08 23:13:32,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\idp.cfg deleted
2010-02-08 23:13:32,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\idpallow.cfg deleted
2010-02-08 23:13:33,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\krnl.cfg deleted
2010-02-08 23:13:33,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\mail.cfg deleted
2010-02-08 23:13:33,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\malrep.cfg deleted
2010-02-08 23:13:33,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\scan.cfg deleted
2010-02-08 23:13:33,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\sched.cfg deleted
2010-02-08 23:13:33,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\setup.cfg deleted
2010-02-08 23:13:33,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\update.cfg deleted
2010-02-08 23:13:33,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\updatecomps.cfg deleted
2010-02-08 23:13:33,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Cfg\user.cfg deleted
2010-02-08 23:13:33,703 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Cfg deleted
2010-02-08 23:13:33,703 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\AvgAm
2010-02-08 23:13:33,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\AvgAm\avgam.lck deleted
2010-02-08 23:13:34,031 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\AvgAm deleted
2010-02-08 23:13:34,031 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Antispam
2010-02-08 23:13:34,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\productid deleted
2010-02-08 23:13:34,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\rkd deleted
2010-02-08 23:13:34,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc1.bin deleted
2010-02-08 23:13:34,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc1.bin.full.2010.02.03.09.04.00 deleted
2010-02-08 23:13:34,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc1.bin.full.2010.02.03.09.04.00.lkr1 deleted
2010-02-08 23:13:34,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc1.bin.tmp deleted
2010-02-08 23:13:34,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc10.bin.full.2010.01.30.05.01.02 deleted
2010-02-08 23:13:34,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc10.bin.tmp deleted
2010-02-08 23:13:34,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc14.bin.full.2006.06.27.17.01.01 deleted
2010-02-08 23:13:34,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.full.2010.01.31.12.22.20 deleted
2010-02-08 23:13:34,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.full.2010.01.31.12.22.20.lkr1 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.14.01.02 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.14.01.02.lkr1 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.16.01.01 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.16.01.01.lkr1 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.17.01.01 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.17.01.01.lkr1 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.20.01.01 deleted
2010-02-08 23:13:34,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.20.01.01.lkr1 deleted
2010-02-08 23:13:34,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.22.01.03 deleted
2010-02-08 23:13:34,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.01.31.22.01.03.lkr1 deleted
2010-02-08 23:13:34,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.04.01.00 deleted
2010-02-08 23:13:34,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.04.01.00.lkr1 deleted
2010-02-08 23:13:34,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.05.00.59 deleted
2010-02-08 23:13:34,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.05.00.59.lkr1 deleted
2010-02-08 23:13:35,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.06.01.01 deleted
2010-02-08 23:13:35,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.06.01.01.lkr1 deleted
2010-02-08 23:13:35,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.07.01.01 deleted
2010-02-08 23:13:35,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.07.01.01.lkr1 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.08.01.00 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.08.01.00.lkr1 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.10.01.01 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.10.01.01.lkr1 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.13.01.00 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.13.01.00.lkr1 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.15.01.02 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.15.01.02.lkr1 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.16.01.00 deleted
2010-02-08 23:13:35,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.16.01.00.lkr1 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.18.01.01 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.18.01.01.lkr1 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.19.01.02 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.19.01.02.lkr1 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.20.01.01 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.20.01.01.lkr1 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.21.01.01 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.21.01.01.lkr1 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.22.01.01 deleted
2010-02-08 23:13:35,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.01.22.01.01.lkr1 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.01.01.03 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.01.01.03.lkr1 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.03.01.02 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.03.01.02.lkr1 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.05.01.00 deleted
2010-02-08 23:13:35,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.05.01.00.lkr1 deleted
2010-02-08 23:13:35,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.06.01.00 deleted
2010-02-08 23:13:35,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.06.01.00.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.07.01.01 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.07.01.01.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.08.01.00 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.08.01.00.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.09.01.01 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.09.01.01.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.10.01.00 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.10.01.00.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.13.00.59 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.13.00.59.lkr1 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.14.01.02 deleted
2010-02-08 23:13:35,359 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.14.01.02.lkr1 deleted
2010-02-08 23:13:35,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.15.01.01 deleted
2010-02-08 23:13:35,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.15.01.01.lkr1 deleted
2010-02-08 23:13:35,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.17.01.02 deleted
2
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 9th February 2010, 8:25 pm
010-02-08 23:13:35,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.17.01.02.lkr1 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.21.01.01 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.21.01.01.lkr1 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.22.01.01 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.02.22.01.01.lkr1 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.01.01.02 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.01.01.02.lkr1 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.02.01.00 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.02.01.00.lkr1 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.05.01.00 deleted
2010-02-08 23:13:35,593 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.05.01.00.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.06.01.00 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.06.01.00.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.07.01.00 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.07.01.00.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.08.00.59 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.08.00.59.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.10.01.01 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.10.01.01.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.12.01.00 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.12.01.00.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.14.01.01 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.14.01.01.lkr1 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.18.01.01 deleted
2010-02-08 23:13:35,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.03.18.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.00.01.01 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.00.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.01.00.59 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.01.00.59.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.02.01.01 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.02.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.03.01.01 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.03.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.06.01.01 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.06.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.08.01.01 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.08.01.01.lkr1 deleted
2010-02-08 23:13:35,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.09.01.01 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.09.01.01.lkr1 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.11.01.00 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.11.01.00.lkr1 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.12.00.59 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.12.00.59.lkr1 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.13.01.02 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.13.01.02.lkr1 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.14.01.00 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.14.01.00.lkr1 deleted
2010-02-08 23:13:36,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.16.01.01 deleted
2010-02-08 23:13:36,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.16.01.01.lkr1 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.17.01.01 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.17.01.01.lkr1 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.18.01.01 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.04.18.01.01.lkr1 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.00.01.01 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.00.01.01.lkr1 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.01.01.01 deleted
2010-02-08 23:13:36,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.01.01.01.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.03.01.00 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.03.01.00.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.05.01.01 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.05.01.01.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.06.01.00 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.06.01.00.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.07.01.02 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.07.01.02.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.08.01.01 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.08.01.01.lkr1 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.09.01.00 deleted
2010-02-08 23:13:36,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.09.01.00.lkr1 deleted
2010-02-08 23:13:36,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.10.01.01 deleted
2010-02-08 23:13:36,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.10.01.01.lkr1 deleted
2010-02-08 23:13:36,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.11.01.00 deleted
2010-02-08 23:13:36,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.11.01.00.lkr1 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.14.01.02 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.14.01.02.lkr1 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.16.01.00 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.16.01.00.lkr1 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.17.01.02 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.17.01.02.lkr1 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.18.01.00 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.18.01.00.lkr1 deleted
2010-02-08 23:13:36,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.21.01.01 deleted
2010-02-08 23:13:36,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.21.01.01.lkr1 deleted
2010-02-08 23:13:36,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.23.01.01 deleted
2010-02-08 23:13:36,859 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc17.bin.incr.2010.02.05.23.01.01.lkr1 deleted
2010-02-08 23:13:36,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc18.bin.full.2009.12.31.23.11.10 deleted
2010-02-08 23:13:36,906 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc18.bin.full.2009.12.31.23.11.10.lkr1 deleted
2010-02-08 23:13:36,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc18.bin.tmp1 deleted
2010-02-08 23:13:36,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc18.bin.tmp2 deleted
2010-02-08 23:13:36,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc19.bin.full.2010.02.05.01.51.49 deleted
2010-02-08 23:13:36,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc19.bin.full.2010.02.05.01.51.49.lkr1 deleted
2010-02-08 23:13:36,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc2.bin deleted
2010-02-08 23:13:36,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc2.bin.full.2005.02.11.04.44.13 deleted
2010-02-08 23:13:36,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc2.bin.full.2005.02.11.04.44.13.lkr1 deleted
2010-02-08 23:13:37,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc21.bin.full.2009.12.08.14.17.28 deleted
2010-02-08 23:13:37,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc21.bin.full.2009.12.08.14.17.28.lkr1 deleted
2010-02-08 23:13:37,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc6.bin.full.2009.11.05.22.36.04 deleted
2010-02-08 23:13:37,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc9.bin.full.2009.11.09.21.33.31 deleted
2010-02-08 23:13:37,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc9.bin.full.2009.11.09.21.33.31.lkr1 deleted
2010-02-08 23:13:37,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\sc9.bin.tmp deleted
2010-02-08 23:13:37,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\scdns.bin deleted
2010-02-08 23:13:37,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\scdns.bina03264 deleted
2010-02-08 23:13:37,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\scoffset.bin.incr deleted
2010-02-08 23:13:37,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\scopt.tmp deleted
2010-02-08 23:13:37,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Antispam\spamcatcher.conf deleted
2010-02-08 23:13:38,015 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Antispam deleted
2010-02-08 23:13:38,015 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Admincli
2010-02-08 23:13:38,375 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Admincli deleted
2010-02-08 23:13:38,375 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\AvgApi
2010-02-08 23:13:38,609 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\AvgApi deleted
2010-02-08 23:13:38,609 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\CfgAll
2010-02-08 23:13:38,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\CfgAll\falsealarm.cfg deleted
2010-02-08 23:13:38,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\CfgAll\fw.cfg deleted
2010-02-08 23:13:38,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\CfgAll\krnlall.cfg deleted
2010-02-08 23:13:38,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\CfgAll\srmall.cfg deleted
2010-02-08 23:13:38,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\CfgAll\updateall.cfg deleted
2010-02-08 23:13:39,062 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\CfgAll deleted
2010-02-08 23:13:39,062 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9\Temp
2010-02-08 23:13:39,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\00ca0c94-85c5-49f0-86c3-019a4687e599.tmp deleted
2010-02-08 23:13:39,203 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0162d088-4d66-419e-b8d7-6477fe58efeb.tmp deleted
2010-02-08 23:13:39,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\01f50ed5-7c00-48b7-bb58-f18bbd908d27-9e4-oopp.tmp deleted
2010-02-08 23:13:39,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0499c7a9-32ba-4785-aed5-29c792ed94aa-860-oopp.tmp deleted
2010-02-08 23:13:39,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\053ce570-e72b-4813-8cd0-a82744117267.tmp deleted
2010-02-08 23:13:39,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\088bafaa-3319-4489-adad-998368bce373-170-oopp.tmp deleted
2010-02-08 23:13:39,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\08aa9162-8e9f-4956-9333-7aa06fa9ba3c-144-oopp.tmp deleted
2010-02-08 23:13:39,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0903521b-50f5-4d3f-8628-4d6c18ea20eb-1b8-oopp.tmp deleted
2010-02-08 23:13:39,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0b679bd8-8486-4985-85ad-2d762b923c4c-188-oopp.tmp deleted
2010-02-08 23:13:39,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0b6f5758-5bae-408f-95a9-a8e7a763e916-608-oopp.tmp deleted
2010-02-08 23:13:39,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0d306558-7d01-4bde-be84-777d7b41e09c-168-oopp.tmp deleted
2010-02-08 23:13:39,500 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0eb589e1-d1cf-4a59-aa39-39a19fb33996-1b4-oopp.tmp deleted
2010-02-08 23:13:39,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\0f60ac7b-a93f-4b33-87d3-c55fed211ec9-808-oopp.tmp deleted
Thebeast28
Posts Posts : 159
Joined Joined : 2010-01-12
Points Points : 27679
Re: Computer is freezing up and running slow
Post by Thebeast28 on 9th February 2010, 8:26 pm
2010-02-08 23:13:39,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\14ea0644-88b5-40ec-9c94-4844b61edb34.tmp deleted
2010-02-08 23:13:39,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1a7e3942-a478-4d9a-b253-e83072cd0865-134-oopp.tmp deleted
2010-02-08 23:13:39,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1a967977-7e96-416a-96b8-cbd9ccd09f53-c70-oopp.tmp deleted
2010-02-08 23:13:39,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1b449bd2-653a-4108-8e1f-3310221d0380-fec-oopp.tmp deleted
2010-02-08 23:13:39,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1e91fddc-86a3-4f56-abbe-00bcb04b4952.tmp deleted
2010-02-08 23:13:39,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1eb7cba3-ce62-4c7f-8eeb-6a99f45e227b-808-oopp.tmp deleted
2010-02-08 23:13:39,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\1f6e970b-514a-4178-9f66-8926b29835a7.tmp deleted
2010-02-08 23:13:39,781 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\21c210c8-2725-4e1a-9091-90fdeb2e32ed-174-oopp.tmp deleted
2010-02-08 23:13:39,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2426fe91-7038-4251-b1b9-d6d5c55dc6aa.tmp deleted
2010-02-08 23:13:39,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2626bda6-90d5-400d-96cd-a4dca9d1e286.tmp deleted
2010-02-08 23:13:39,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\26e6bb71-5e5d-4067-b1ff-3ff5229d5810.tmp deleted
2010-02-08 23:13:39,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\27b9b461-6e3c-44e5-a50b-1a9cf57d9ebe.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2871a746-5265-459e-8a40-5a487fc65ebe.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2a4b6e23-9aa0-4075-8865-7d5b3c5935b8.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2b463595-1910-4500-80ab-134e77deb308-f94-oopp.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2c4fefe2-bf7a-480f-9cfe-e96087df1a94.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2cd5b99f-aa06-4cf8-8ae4-9766b34afcb2-78c-oopp.tmp deleted
2010-02-08 23:13:40,015 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\2d175901-74c6-4f39-8a89-e44099349f1c.tmp deleted
2010-02-08 23:13:40,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\318ebb98-4520-470b-95f4-10833e824b65.tmp deleted
2010-02-08 23:13:40,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\35aef5bc-801c-41d3-8cc1-b21f0cd826d6-3f4-oopp.tmp deleted
2010-02-08 23:13:40,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\35e096c1-07d0-4518-850d-bad6c32a9acd-a40-oopp.tmp deleted
2010-02-08 23:13:40,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\367c0645-2521-47b6-b9ec-494258836f57-7f4-oopp.tmp deleted
2010-02-08 23:13:40,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\36eabe24-3f37-46c8-82a2-8871d870ae96.tmp deleted
2010-02-08 23:13:40,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\389749f4-23b4-4469-bbbf-f8f38204dc68.tmp deleted
2010-02-08 23:13:40,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\39b8f835-f5fd-4de8-98a3-60fd1c88d861-128-oopp.tmp deleted
2010-02-08 23:13:40,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\3a67d5d9-4f18-40c4-a3a3-fb5a7efeab4d.tmp deleted
2010-02-08 23:13:40,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\3a6f600f-ee37-4ed9-8362-e102348da622-180-oopp.tmp deleted
2010-02-08 23:13:40,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\3c6f5ee9-77af-4bde-a2c8-f1d634689890.tmp deleted
2010-02-08 23:13:40,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\3e1926d4-37f6-4285-a27d-c8fe06259589.tmp deleted
2010-02-08 23:13:40,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\405f4fc3-0ee6-4157-afad-55648fba2842.tmp deleted
2010-02-08 23:13:40,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\41621086-9544-46b6-8245-f4b20c6e67d2-194-oopp.tmp deleted
2010-02-08 23:13:40,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\42c3dfdf-563a-4260-afd7-12796bd2dc33.tmp deleted
2010-02-08 23:13:40,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\47dc7940-0698-44eb-8169-66441886ed55.tmp deleted
2010-02-08 23:13:40,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\48eb8b03-bd9c-4914-ada6-2263b00cddb0-130-oopp.tmp deleted
2010-02-08 23:13:40,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\490b45ff-caef-4f27-b8b9-89ce146f87b9.tmp deleted
2010-02-08 23:13:40,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\4a507da8-c680-4589-b730-e9c0eb49c015.tmp deleted
2010-02-08 23:13:40,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\4aaa3f55-c7c6-4b32-b89c-3c63093aebfc.tmp deleted
2010-02-08 23:13:40,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\4c2e7838-ce7c-4399-95ab-f65b0d4aca16.tmp deleted
2010-02-08 23:13:40,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\4d45d473-a125-4570-9e14-e15f2446fe32.tmp deleted
2010-02-08 23:13:40,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\4d8c149e-cb56-440c-9e46-a533b22e8317-24c-oopp.tmp deleted
2010-02-08 23:13:40,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\503b1acb-3b0d-4567-b196-4cee2bb73a69.tmp deleted
2010-02-08 23:13:40,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\507d9b3f-8e61-4522-b24b-91be6849b535-1b4-oopp.tmp deleted
2010-02-08 23:13:40,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5090482a-158f-4449-9d02-a08f1676a88d-b00-oopp.tmp deleted
2010-02-08 23:13:40,625 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\516564a5-584e-4a8c-b5bf-7d5e9da9dd29.tmp deleted
2010-02-08 23:13:40,656 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\525d1bf3-1fb0-41c0-8bb2-541bae6f318e.tmp deleted
2010-02-08 23:13:40,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\53e5233c-67ae-4098-8676-ab70e37088b7.tmp deleted
2010-02-08 23:13:40,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\54b3413f-3e87-4ccf-bfb5-f0988541f5d5-1a0-oopp.tmp deleted
2010-02-08 23:13:40,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\552f0de2-05ec-4688-b4b4-56fb5f671f38.tmp deleted
2010-02-08 23:13:40,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\55aa30be-a568-4a71-a3ea-30f7ca0e7c32.tmp deleted
2010-02-08 23:13:40,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\577decaa-4234-4a67-b889-79750dcd62d9.tmp deleted
2010-02-08 23:13:40,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\595c7dcc-3993-4496-ac87-d4c3e07bc3d0-eb8-oopp.tmp deleted
2010-02-08 23:13:40,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5a6e98d9-0818-431e-ac17-c55cdff199f7-8a8-oopp.tmp deleted
2010-02-08 23:13:40,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5a7fa3b1-88ad-43f0-bd78-4e6ca2fbf13d.tmp deleted
2010-02-08 23:13:40,968 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5addee1f-d395-44a7-bd0c-1ce50eb357e8-728-oopp.tmp deleted
2010-02-08 23:13:40,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5b798ff2-0876-4cd9-b96e-ff2e2ef5fbcb-194-oopp.tmp deleted
2010-02-08 23:13:41,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5c9d1ffa-b552-4097-9d20-8673be571473-5a0-oopp.tmp deleted
2010-02-08 23:13:41,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\5eddbc74-0031-4e59-82d8-d39eb9e22d6d.tmp deleted
2010-02-08 23:13:41,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6152576e-a3c7-4094-8e2f-0de3fe0653ec-42c-oopp.tmp deleted
2010-02-08 23:13:41,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\61543653-df02-46f5-9454-ed84ce2e058f-180-oopp.tmp deleted
2010-02-08 23:13:41,078 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\62a359ba-3a42-45d7-bcea-3c66b9bc6934-fd4-oopp.tmp deleted
2010-02-08 23:13:41,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\62f1e2a2-5747-4d3f-b939-deb1a289d460.tmp deleted
2010-02-08 23:13:41,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\656166d8-b188-4fc7-a529-35782a98ef77-14c-oopp.tmp deleted
2010-02-08 23:13:41,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\66598d3c-ff31-491a-9e6a-6fd30156ebe2-16c-oopp.tmp deleted
2010-02-08 23:13:41,187 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6818db0c-3ae1-4730-96b3-a07f1efaee70.tmp deleted
2010-02-08 23:13:41,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\69e9e3b6-6e61-433e-bc06-4eb23e1fdabf.tmp deleted
2010-02-08 23:13:41,234 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6a3adb3b-09c1-4dac-8808-feaba5a6062f-2ac-oopp.tmp deleted
2010-02-08 23:13:41,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6abe8a40-7d97-48e8-a67f-a93cfd3e1eff-11c-oopp.tmp deleted
2010-02-08 23:13:41,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6ad02aab-ec8f-44da-8d63-7f0070f7cd3b.tmp deleted
2010-02-08 23:13:41,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6bc0078b-645e-417f-946a-d5435d944c38.tmp deleted
2010-02-08 23:13:41,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6bfc4fb0-34a3-4182-b28c-6b770b17cc90-12c-oopp.tmp deleted
2010-02-08 23:13:41,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6c6eb6e5-75e1-44a3-93be-7bf79bd567dc.tmp deleted
2010-02-08 23:13:41,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\6c82f2bc-807d-4b2e-9a1b-be15c157b665.tmp deleted
2010-02-08 23:13:41,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\70d5e8db-acaf-4425-80d6-8f6511f25022.tmp deleted
2010-02-08 23:13:41,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7169ee04-fbdb-4111-a89f-33002874f62e.tmp deleted
2010-02-08 23:13:41,703 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\71d8f030-8340-4bc4-88b2-4408033272b6-1a0-oopp.tmp deleted
2010-02-08 23:13:41,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\72f093c5-8ffd-4000-98f6-16f83d9d221a.tmp deleted
2010-02-08 23:13:41,734 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\748db3dd-bf69-48a6-ab0b-cf49b940d29b-a14-oopp.tmp deleted
2010-02-08 23:13:41,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\74b3fe3a-a1cc-4de3-95e0-0adddf1a96ca.tmp deleted
2010-02-08 23:13:41,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\75632337-2e20-46e2-8941-c2314458e2e2.tmp deleted
2010-02-08 23:13:41,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\759b9556-398b-489a-8890-2caa6dde0ee4-154-oopp.tmp deleted
2010-02-08 23:13:41,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\759e139b-3fca-4390-9d37-989c078c1eb9.tmp deleted
2010-02-08 23:13:41,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7986f5d5-d65f-4148-b07f-b12eadbb9fb9-1a0-oopp.tmp deleted
2010-02-08 23:13:41,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\79e49cf7-0e44-4e50-a848-5e671c7e08cb-154-oopp.tmp deleted
2010-02-08 23:13:41,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7a1820ce-26e5-4193-9cf7-709815b2d103-380-oopp.tmp deleted
2010-02-08 23:13:41,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7a261e70-3b46-4f6a-a3c8-995600129edf.tmp deleted
2010-02-08 23:13:41,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7c6c4471-b9a8-485f-9b40-31eef8468cdf.tmp deleted
2010-02-08 23:13:41,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7d6a3ce9-a980-4084-8141-0cf77c9022f2.tmp deleted
2010-02-08 23:13:42,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7e73b96b-f9d2-4b27-8a09-4a3e6c349051-ad8-oopp.tmp deleted
2010-02-08 23:13:42,031 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7f0b52e8-5148-4e79-a015-adef7b901084.tmp deleted
2010-02-08 23:13:42,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\7fe419f9-d01b-4a8d-b15d-4056c4992fd7.tmp deleted
2010-02-08 23:13:42,093 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\807b871f-1335-4464-893f-984ce624b8c4-a60-oopp.tmp deleted
2010-02-08 23:13:42,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\8577d167-270e-4345-9bc5-39b525dd8b2f-a38-oopp.tmp deleted
2010-02-08 23:13:42,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\871c21f4-43b2-412e-845e-aecfab0df73a-26c-oopp.tmp deleted
2010-02-08 23:13:42,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\8810e161-781a-4ef5-8750-29ef1dc42c0d-340-oopp.tmp deleted
2010-02-08 23:13:42,250 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\8caf6b3b-72c6-4ce7-bfa9-0652f660525f-188-oopp.tmp deleted
2010-02-08 23:13:42,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\8d3adab3-eb24-4728-9c25-4b4ce286d6de.tmp deleted
2010-02-08 23:13:42,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\8f13d0ed-0b00-46d5-9656-4364b554b8f9-61c-oopp.tmp deleted
2010-02-08 23:13:42,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\91571faa-d0bb-4043-89c7-8aba316ad09d.tmp deleted
2010-02-08 23:13:42,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\936c2a04-66dd-415d-af48-fec5e78e22bb-198-oopp.tmp deleted
2010-02-08 23:13:42,546 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\94060014-0128-4b7f-8af1-95cee4cf3679-9b4-oopp.tmp deleted
2010-02-08 23:13:42,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9662127b-c293-40a9-ae30-a54944cd33b1-16c-oopp.tmp deleted
2010-02-08 23:13:42,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\986714b2-1a8e-49f2-ab9f-56a977296d85.tmp deleted
2010-02-08 23:13:42,671 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\987915b7-e4d4-4ef0-8838-abfc7a59a247-1bc-oopp.tmp deleted
2010-02-08 23:13:42,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9945b482-7a58-4bb2-bed5-d0502b733c72-840-oopp.tmp deleted
2010-02-08 23:13:42,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9
Thebeast28
Posts Posts : 159
Post by Thebeast28 on 9th February 2010, 8:27 pm
\Temp\99bd3650-e333-4623-8e8c-83c012ad146b-2b4-oopp.tmp deleted
2010-02-08 23:13:42,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9b26aae1-6800-4ccc-a58e-64615e3e07a2-1c8-oopp.tmp deleted
2010-02-08 23:13:42,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9de006f5-77af-4bab-8d02-c7bc7f05f2dd-178-oopp.tmp deleted
2010-02-08 23:13:42,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9e44d028-d988-4b60-97e2-222c5add611b.tmp deleted
2010-02-08 23:13:42,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\9f1a209b-b536-42f7-ade7-991421ec6a43-a6c-oopp.tmp deleted
2010-02-08 23:13:42,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a118a030-3d4a-4147-9621-08eca5bf4ef8-15c-oopp.tmp deleted
2010-02-08 23:13:42,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a21605c2-9bcc-486c-972f-d19dd350ac90.tmp deleted
2010-02-08 23:13:42,828 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a4999e52-998d-487f-9747-7f6d972a673f-354-oopp.tmp deleted
2010-02-08 23:13:42,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a5caddd5-4613-4e3a-bff1-09e6d5a6cb41-148-oopp.tmp deleted
2010-02-08 23:13:42,875 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a63fb3c8-a761-433f-b520-ec165de71c34.tmp deleted
2010-02-08 23:13:42,921 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a64a75de-5975-49e7-9099-a1901f0b72ea.tmp deleted
2010-02-08 23:13:42,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a768956c-bf6f-48de-bc41-04b892587871-cc8-oopp.tmp deleted
2010-02-08 23:13:42,984 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a8309a09-a542-4c01-991e-16446823f13b.tmp deleted
2010-02-08 23:13:43,140 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\a987e06b-b40b-4d90-acab-a8f6e871e9b2-174-oopp.tmp deleted
2010-02-08 23:13:43,171 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ac2af145-0190-4cd1-8747-508c838cd53c.tmp deleted
2010-02-08 23:13:43,218 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ac752e38-2b0c-4295-98f8-10cc3ceffdd1-158-oopp.tmp deleted
2010-02-08 23:13:43,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ad2d9613-2445-4387-83b7-91d154f4cb92-184-oopp.tmp deleted
2010-02-08 23:13:43,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ad53033a-3709-4645-b664-8800628d03ed.tmp deleted
2010-02-08 23:13:43,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ae07d3d9-b4cc-46d4-97e7-e02bd6a6714d-194-oopp.tmp deleted
2010-02-08 23:13:43,265 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\aef4c172-4587-4087-9241-730fd13d92b5-e40-oopp.tmp deleted
2010-02-08 23:13:43,296 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\af59cb52-95f7-4143-91d9-dbf0d1826410.tmp deleted
2010-02-08 23:13:43,343 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b32ffc81-1fef-433c-8e83-1678ebfa09dc-890-oopp.tmp deleted
2010-02-08 23:13:43,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b36cc41d-2255-44ef-967b-f2098153dd2c-168-oopp.tmp deleted
2010-02-08 23:13:43,390 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b3ba04b8-d30a-41b6-bc6c-c37b0f4f0b10-11c-oopp.tmp deleted
2010-02-08 23:13:43,421 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b52e46e0-2222-4f3c-b2bb-93a457789a19.tmp deleted
2010-02-08 23:13:43,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b69c68fa-163d-42f4-92cb-15cb9b413909.tmp deleted
2010-02-08 23:13:43,468 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b6e7029a-4654-4827-a3f3-2ac273614386.tmp deleted
2010-02-08 23:13:43,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b7357c14-f394-477b-87b7-9e329058c5de.tmp deleted
2010-02-08 23:13:43,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b7a4624a-1751-4487-8fa3-5231becaf72c.tmp deleted
2010-02-08 23:13:43,484 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\b8a4f9dc-faff-4524-a632-0afa312c4bec.tmp deleted
2010-02-08 23:13:43,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\bbafb6aa-a367-40b7-b837-6c27d654a6fe.tmp deleted
2010-02-08 23:13:43,562 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\bbdb0365-5f01-4cba-bd08-dd316dfcb5ca-c8c-oopp.tmp deleted
2010-02-08 23:13:43,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\bbef9ce4-91af-4515-ac97-b4f1ec93c9d7.tmp deleted
2010-02-08 23:13:43,609 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\bc917319-f5ec-4462-964e-1dfd2a2ac68f-170-oopp.tmp deleted
2010-02-08 23:13:43,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\bfdab2e4-9077-4027-897e-c23d66cfd825-c38-oopp.tmp deleted
2010-02-08 23:13:43,718 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c4106378-fe46-442d-8504-65572ddab628.tmp deleted
2010-02-08 23:13:43,750 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c433f1c6-8a2a-4349-a621-6723b7507371-1b8-oopp.tmp deleted
2010-02-08 23:13:43,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c474b049-04ec-4a4b-bad9-2a5ad10785d3-194-oopp.tmp deleted
2010-02-08 23:13:43,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c50e22cc-10ae-4325-904b-58e7076d530b.tmp deleted
2010-02-08 23:13:43,765 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c92623e6-9af0-4c11-a2fe-2e83027dd272.tmp deleted
2010-02-08 23:13:43,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\c94ab034-3189-46af-820f-c639cb4093f2-130-oopp.tmp deleted
2010-02-08 23:13:43,796 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\cae23557-cf3d-43d4-8847-6621dc588bea-190-oopp.tmp deleted
2010-02-08 23:13:43,843 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\cc99d90f-b94d-4bd1-b2e5-f539440ca8e8-824-oopp.tmp deleted
2010-02-08 23:13:43,890 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\cdcbdf68-b290-4341-a585-6c0f5275fa8d.tmp deleted
2010-02-08 23:13:43,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ce595730-1d1d-493f-911f-dba24a8d8021.tmp deleted
2010-02-08 23:13:43,953 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ce966531-13cd-4d56-b302-53526eff0965-17c-oopp.tmp deleted
2010-02-08 23:13:44,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\cfe39ff2-1641-4aa2-8efe-051efadfeff3-164-oopp.tmp deleted
2010-02-08 23:13:44,000 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d12512bd-dad8-442d-ab46-22b4fdd81811-1cc-oopp.tmp deleted
2010-02-08 23:13:44,046 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d2302ca5-df6a-4e88-9cc7-424abbf7073d-834-oopp.tmp deleted
2010-02-08 23:13:44,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d3d2a23a-0dad-426b-96ff-36a7c3146228-948-oopp.tmp deleted
2010-02-08 23:13:44,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d3e964ea-e30a-4e87-8198-f4ec4dfd6204.tmp deleted
2010-02-08 23:13:44,062 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d6c6a03f-4f08-4d9e-baeb-7a5e6cbf407b.tmp deleted
2010-02-08 23:13:44,109 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\d83b5d02-2300-4d5b-8f1a-703d9aa3db26-e1c-oopp.tmp deleted
2010-02-08 23:13:44,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\db4bb4f9-9c91-43ed-a199-241d55733936-138-oopp.tmp deleted
2010-02-08 23:13:44,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\dba1fa60-8be3-431d-8e6b-76e49a6a4f11-dac-oopp.tmp deleted
2010-02-08 23:13:44,125 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\dbd8b323-7c63-4974-8fd8-a2054929b10d-198-oopp.tmp deleted
2010-02-08 23:13:44,156 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\dc1a0fd3-8993-44d0-9fed-8239a1f1da48.tmp deleted
2010-02-08 23:13:44,281 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ded44bcc-c9c7-4e8f-8e92-2f4a549372ef.tmp deleted
2010-02-08 23:13:44,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\df70ed99-1847-4adf-9236-878a8f87f652-1ac-oopp.tmp deleted
2010-02-08 23:13:44,312 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e062f892-a7f1-4541-b23f-2d153389e758.tmp deleted
2010-02-08 23:13:44,328 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e27ddaa6-4a36-49ea-be5d-5d36cd93cfe4-9e0-oopp.tmp deleted
2010-02-08 23:13:44,375 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e3397827-4420-40d2-97e8-499abfb594e4-18c-oopp.tmp deleted
2010-02-08 23:13:44,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e390fd48-e8f3-4d8d-8b76-f3eed40f4ac0-13c-oopp.tmp deleted
2010-02-08 23:13:44,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e684b3c0-bf7e-4260-b4dc-aa5aed7d668e.tmp deleted
2010-02-08 23:13:44,437 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\e716946c-9bd9-4ac8-aa7d-cdf6dbfc5974.tmp deleted
2010-02-08 23:13:44,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ea7b5593-2969-428a-b4b2-fa4c86363d53-1a4-oopp.tmp deleted
2010-02-08 23:13:44,515 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\eb41fdc1-fb6d-467a-b64c-dca93563553b.tmp deleted
2010-02-08 23:13:44,531 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\f40b411d-4412-4e56-b617-e2694caf1621-c6c-oopp.tmp deleted
2010-02-08 23:13:44,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\f74112c0-c14b-493c-b9e2-bca4f68f0bf1-1a8-oopp.tmp deleted
2010-02-08 23:13:44,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\f8057f23-3282-4a3e-aafc-6f4c47132675-9a4-oopp.tmp deleted
2010-02-08 23:13:44,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\fa208e94-bff6-4a7f-8f95-d452554a1f74.tmp deleted
2010-02-08 23:13:44,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\fb610292-b44a-4704-9f86-9647c3128fd0.tmp deleted
2010-02-08 23:13:44,578 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\fd8d9872-60d2-4d6c-bca2-1f0a95c0cb37.tmp deleted
2010-02-08 23:13:44,640 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\fda24513-3423-4e18-8e9d-892bc17c01c2.tmp deleted
2010-02-08 23:13:44,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ff86e266-bc08-49e3-9360-4facc6d3d1da-144-oopp.tmp deleted
2010-02-08 23:13:44,687 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\ff8e5e22-2f2e-4fe5-8784-524646e2aa2d-cb8-oopp.tmp deleted
2010-02-08 23:13:44,937 INFO File C:\Documents and Settings\All Users\Application Data\avg9\Temp\file9514.tmp deleted
2010-02-08 23:13:45,921 INFO Directory C:\Documents and Settings\All Users\Application Data\avg9\Temp deleted
2010-02-08 23:13:45,937 DEBUG Processing item C:\Documents and Settings\All Users\Application Data\avg9
2010-02-08 23:13:45,937 DEBUG Directory C:\Documents and Settings\All Users\Application Data\avg9 not deleted (error c0070091)
2010-02-08 23:13:45,937 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:13:46,078 INFO File C:\WINDOWS\System32\Drivers\\avgldx86.sys deleted
2010-02-08 23:13:46,078 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:13:46,187 INFO File C:\WINDOWS\System32\Drivers\\avgmfx86.sys deleted
2010-02-08 23:13:46,187 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:13:46,328 INFO File C:\WINDOWS\System32\Drivers\\avgrkx86.sys deleted
2010-02-08 23:13:46,343 DEBUG Processing item C:\WINDOWS\System32\Drivers
2010-02-08 23:13:46,421 INFO File C:\WINDOWS\System32\Drivers\\avgtdix.sys deleted
2010-02-08 23:13:46,421 DEBUG Processing item C:\WINDOWS\System32\Drivers\avg
2010-02-08 23:13:46,484 INFO File C:\WINDOWS\System32\Drivers\avg\avi7.avg deleted
2010-02-08 23:13:46,515 INFO File C:\WINDOWS\System32\Drivers\avg\iavichjw.avm deleted
2010-02-08 23:13:46,515 INFO File C:\WINDOWS\System32\Drivers\avg\iavifw.avm deleted
2010-02-08 23:13:46,546 INFO File C:\WINDOWS\System32\Drivers\avg\incavi.avm deleted
2010-02-08 23:13:46,593 INFO File C:\WINDOWS\System32\Drivers\avg\microavi.avg deleted
2010-02-08 23:13:46,625 INFO File C:\WINDOWS\System32\Drivers\avg\miniavi.avg deleted
2010-02-08 23:13:46,859 INFO Directory C:\WINDOWS\System32\Drivers\avg deleted
2010-02-08 23:13:46,859 DEBUG Processing item C:\WINDOWS\System32
2010-02-08 23:13:46,859 DEBUG Removing file C:\WINDOWS\System32\\avgrsstx.dll failed (error e0010058), planned for delete after restart
2010-02-08 23:13:46,859 DEBUG Processing item C:\Program Files\AVG
2010-02-08 23:13:46,859 DEBUG Directory C:\Program Files\AVG not deleted (error c0070091)
2010-02-08 23:13:46,859 DEBUG Missing ParentDir path for fileItem number 194
2010-02-08 23:13:46,859 DEBUG Restarting...
2010-02-08 23:18:12,046 DEBUG Avg9Uninstall\Directories key failed to open (error: e0010013)
2010-02-08 23:18:12,140 DEBUG Avg8Uninstall\Directories key failed to open (error: e0010013)
2010-02-08 23:18:12,140 DEBUG Reading HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion:ProgramFilesDir (x86) value failed (error: e001003d)
2010-02-08 23:18:12,140 INFO Command line: /run_number=2 /avgdir="C:\Program Files\AVG\AVG9" /avgdatadir="C:\Documents and Settings\All Users\Application Data\avg9" /ndis_nextstep=1
2010-02-08 23:18:12,156 DEBUG AvgDir param set to C:\Program Files\AVG\AVG9.
2010-02-08 23:18:12,156 DEBUG AvgDataDir param set to C:\Documents and Settings\All Users\Application Data\avg9.
2010-02-08 23:18:12,156 INFO AvgRemover runs in attempt number 2
2010-02-08 23:18:12,156 INFO ***** Services *****
2010-02-08 23:18:12,156 INFO Processing service avg8emc
2010-02-08 23:18:12,156 INFO Service avg8emc is not installed
2010-02-08 23:18:12,156 DEBUG Service avg8emc RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service avg8emc are not present
2010-02-08 23:18:12,156 INFO Processing service avgfws8
2010-02-08 23:18:12,156 INFO Service avgfws8 is not installed
2010-02-08 23:18:12,156 DEBUG Service avgfws8 RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service avgfws8 are not present
2010-02-08 23:18:12,156 INFO Processing service avg8wd
2010-02-08 23:18:12,156 INFO Service avg8wd is not installed
2010-02-08 23:18:12,156 DEBUG Service avg8wd RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service avg8wd are not present
2010-02-08 23:18:12,156 INFO Processing service AvgWFPx
2010-02-08 23:18:12,156 INFO Service AvgWFPx is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgWFPx RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgWFPx are not present
2010-02-08 23:18:12,156 INFO Processing service AvgWFPa
2010-02-08 23:18:12,156 INFO Service AvgWFPa is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgWFPa RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgWFPa are not present
2010-02-08 23:18:12,156 INFO Processing service AvgMfx86
2010-02-08 23:18:12,156 INFO Service AvgMfx86 is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgMfx86 RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgMfx86 are not present
2010-02-08 23:18:12,156 INFO Processing service AvgMfx64
2010-02-08 23:18:12,156 INFO Service AvgMfx64 is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgMfx64 RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgMfx64 are not present
2010-02-08 23:18:12,156 INFO Processing service AvgLdx86
2010-02-08 23:18:12,156 INFO Service AvgLdx86 is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgLdx86 RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgLdx86 are not present
2010-02-08 23:18:12,156 INFO Processing service AvgLdx64
2010-02-08 23:18:12,156 INFO Service AvgLdx64 is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgLdx64 RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgLdx64 are not present
2010-02-08 23:18:12,156 INFO Processing service AvgTdiX
2010-02-08 23:18:12,156 INFO Service AvgTdiX is not installed
2010-02-08 23:18:12,156 DEBUG Service AvgTdiX RegCleanup
2010-02-08 23:18:12,156 DEBUG Registry keys for service AvgTdiX are not present
2010-02-08 23:18:12,156 INFO Processing service AvgTdiA
2010-02-08 23:18:12,171 INFO Service AvgTdiA is not installed
2010-02-08 23:18:12,171 DEBUG Service AvgTdiA RegCleanup
2010-02-08 23:18:12,171 DEBUG Registry keys for service AvgTdiA are not present
2010-02-08 23:18:12,171 INFO Processing service AvgRkx86
2010-02-08 23:18:12,171 INFO Service AvgRkx86 is not installed
2010-02-08 23:18:12,171 DEBUG Service AvgRkx86 RegCleanup
2010-02-08 23:18:12,171 DEBUG Registry keys for service AvgRkx86 are not present
2010-02-08 23:18:12,171 INFO Processing service AvgRkx64
2010-02-08 23:18:12,171 INFO Service AvgRkx64 is not installed
2010-02-08 23:18:12,171 DEBUG Service AvgRkx64 RegCleanup
2010-02-08 23:18:12,171 DEBUG Registry keys for service AvgRkx64 are not present
2010-02-08 23:18:12,171 INFO Processing service avg9emc
2010-02-08 23:18:12,171 INFO Service avg9emc is not installed
2010-02-08 23:18:12,171 DEBUG Service avg9emc RegCleanup
2010-02-08 23:18:12,171 DEBUG Registry keys for service avg9emc are not present
2010-02-08 23:18:12,171 INFO Processing service avgfws9
2010-02-08 23:18:12,171 INFO Service avgfws9 is not installed
Thebeast28
Posts Posts : 159
Page 1 of 3 1, 2, 3  Next
