Nuqel.e problem
Nuqel.e problem
Post by gbottje on Sun Jan 17, 2010 11:38 pm
One laptop got infected. Similar symptoms as others that you have helped - Multiple popups, unable to launch any pgms, Internet Explorer 7 only goes to the Antivirus Pro site, then if left a while, launches new tabs with Porno.org, and a couple of other porn-looking sites.
Found your site by searching on a different computer. Saw recommendations from other sites, so decided to trust your work. I couldn't turn off the Proxy Server as you instructed another to do, until I rebooted into Safe Mode. From Safe Mode, I also downloaded ComboFix and ran it (as you instructed many others to do). One thing that concerns me is that it detected Symantec Antivirus Corp Edition running, but I couldn't figure out how to end it. there were no icons in the systray (still in Safe Mode), and there were only 18 processes running in Task Manager, nȯne of which I could identify as Symantec AV. So, I took a chance and continued. It completed, and rebooted the machine. I let it boot in normal mode. ComboFix ran and eventually created a log.txt file in Notepad.
Things seem to be running normally again, but I am concerned that it may not be completely eradicated. Do you have any suggestions for ways I can check, or any other steps I should take? I will follow the good advice that you gave to Louise Townsend on general steps to protect my computer. Thanks in advance.
gbottje
Posts Posts : 6
Joined Joined : 2010-01-17
Points Points : 25218
Re: Nuqel.e problem
Post by Belahzur on Sun Jan 17, 2010 11:46 pm
Points Points : 245059
Re: Nuqel.e problem
Post by gbottje on Mon Jan 18, 2010 12:03 am
This used to be a corporate computer, so needed to alter some of the text to protect identity. Hope that doesn't make it difficult.
Logfile of Trend Micro HijackThis v2.0.3 (BETA)
Scan saved at 5:52:41 PM, on 1/17/2010
MSIE: Internet Explorer v7.00 (7.00.6000.16945)
C:\WINDOWS\System32\ibmpmsvc.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\system32\brsvc01a.exe
C:\WINDOWS\system32\brss01a.exe
C:\Program Files\Barns\reenLock\BreenLock.exe
C:\PROGRA~1\Marimba\CASTAN~1\Tuner.exe
C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
C:\Program Files\Symantec AntiVirus\DefWatch.exe
C:\Program Files\IBM\IBM Rapid Restore Ultra\rrpcsb.exe
C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
C:\WINDOWS\System32\QCONSVC.EXE
C:\Program Files\Symantec AntiVirus\SavRoam.exe
C:\Program Files\Symantec AntiVirus\Rtvscan.exe
C:\Program Files\Timbuktu Pro\tb2launch.exe
C:\WINDOWS\system32\TpKmpSVC.exe
C:\Program Files\uphclean\uphclean.exe
C:\Program Files\Timbuktu Pro\tb2pro.exe
C:\PROGRA~1\SYMANT~1\VPTray.exe
C:\WINDOWS\system32\TpShocks.exe
C:\PROGRA~1\ThinkPad\PkgMgr\HOTKEY\TPHKMGR.exe
C:\Program Files\ThinkPad\PkgMgr\HOTKEY\TPONSCR.exe
C:\Program Files\ThinkPad\PkgMgr\HOTKEY_1\TpScrex.exe
C:\Program Files\Timbuktu Pro\tb2logon.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\Program Files\ThinkPad\UltraNav Wizard\UNavTray.EXE
C:\PROGRA~1\ThinkPad\CONNEC~1\QCWLIcon.exe
C:\progra~1\scansoft\paperp~1\pptd40nt.exe
C:\Program Files\Orchestria\Active Policy Management\client\wgncm.exe
C:\PROGRA~1\SBCSEL~1\SMARTB~1\MotiveSB.exe
C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPMon32.exe
C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPClient.exe
C:\IBMTOOLS\UTILS\ibmprc.exe
C:\Program Files\Timbuktu Pro\TNOTIFY.EXE
C:\PROGRA~1\ThinkPad\UTILIT~1\EzEjMnAp.Exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\WINDOWS\system32\rundll32.exe
C:\PROGRA~1\ThinkPad\CONNEC~1\QCTray.exe
C:\Program Files\Button\The Button.exe
C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe
c:\program files\outlookconfiguration\MailCheck.exe
C:\WINDOWS\explorer.exe
C:\Documents and Settings\gbottje\Local Settings\Application Data\Yahoo!\BrowserPlus\2.4.21\BrowserPlusCore.exe
C:\WINDOWS\system32\msiexec.exe
C:\Program Files\TrendMicro\HiJackThis\HiJackThis.exe
O2 - BHO: Canon Easy Web Print Helper - {68F9551E-0411-48E4-9AAF-4BC42A6A46BE} - C:\Program Files\Canon\Easy-WebPrint\EWPBrowseLoader.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.1.1309.3572\swg.dll
O3 - Toolbar: Easy-WebPrint - {327C2873-E90D-4c37-AA9D-10AC9BABA46C} - C:\Program Files\Canon\Easy-WebPrint\Toolband.dll
O4 - HKLM\..\Run: [zie_user_config] C:\Program Files\Internet Explorer\ie_user_config.EXE /s
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\SYMANT~1\VPTray.exe
O4 - HKLM\..\Run: [UpdateManager] "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
O4 - HKLM\..\Run: [UC_Start] C:\Program Files\IBM\Updater\\ucstartup.exe
O4 - HKLM\..\Run: [TpShocks] TpShocks.exe
O4 - HKLM\..\Run: [TPKMAPHELPER] C:\Program Files\ThinkPad\Utilities\TpKmapAp.exe -helper
O4 - HKLM\..\Run: [TPHOTKEY] C:\PROGRA~1\ThinkPad\PkgMgr\HOTKEY\TPHKMGR.exe
O4 - HKLM\..\Run: [TP4EX] tp4ex.exe
O4 - HKLM\..\Run: [TLogonPath] "C:\Program Files\Timbuktu Pro\tb2logon.exe"
O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
O4 - HKLM\..\Run: [Synchronization Manager] %SystemRoot%\system32\mobsync.exe /logon
O4 - HKLM\..\Run: [savsetup] c:\program files\marimba\castanet tuner\tuner -start [You must be registered and logged in to see this link.]
O4 - HKLM\..\Run: [S3TRAY2] S3Tray2.exe
O4 - HKLM\..\Run: [QCWLIcon] C:\PROGRA~1\ThinkPad\CONNEC~1\QCWLIcon.exe
O4 - HKLM\..\Run: [PaperPort PTD] c:\progra~1\scansoft\paperp~1\pptd40nt.exe
O4 - HKLM\..\Run: [OutlookDisclaimerAdd-in] C:\WINDOWS\ODP.EXE
O4 - HKLM\..\Run: [Orchestria APM Client] C:\Program Files\Orchestria\Active Policy Management\client\wgncm.exe
O4 - HKLM\..\Run: [Motive SmartBridge] C:\PROGRA~1\SBCSEL~1\SMARTB~1\MotiveSB.exe
O4 - HKLM\..\Run: [IPInSightMonitor 02] "C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPMon32.exe"
O4 - HKLM\..\Run: [IPInSightLAN 02] "C:\Program Files\Visual Networks\Visual IP InSight\SBC\IPClient.exe" -l
O4 - HKLM\..\Run: [IBMPRC] C:\IBMTOOLS\UTILS\ibmprc.exe
O4 - HKLM\..\Run: [Flash User Config] C:\WINDOWS\system32\Macromed\Shockwave 10\Xtras\Flash_user_config.EXE
O4 - HKLM\..\Run: [EZEJMNAP] C:\PROGRA~1\ThinkPad\UTILIT~1\EzEjMnAp.Exe
O4 - HKLM\..\Run: [Client Access Service] "C:\Program Files\IBM\Client Access\cwbsvstr.exe"
O4 - HKLM\..\Run: [Client Access PC5250 Sound] "C:\Program Files\IBM\Client Access\Emulator\pcssnd.exe"
O4 - HKLM\..\Run: [Client Access Help Update] "C:\Program Files\IBM\Client Access\cwbinhlp.exe"
O4 - HKLM\..\Run: [Client Access Express Welcome] "C:\Program Files\IBM\Client Access\cwbwlwiz.exe"
O4 - HKLM\..\Run: [Client Access Check Version] "C:\Program Files\IBM\Client Access\cwbckver.exe" LOGIN
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [BMMMONWND] rundll32.exe C:\PROGRA~1\ThinkPad\UTILIT~1\BatInfEx.dll,BMMAutonomicMonitor
O4 - HKLM\..\Run: [BMMLREF] C:\Program Files\ThinkPad\Utilities\BMMLREF.EXE
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [QCTray] C:\PROGRA~1\ThinkPad\CONNEC~1\QCTray.exe
O4 - HKLM\..\Run: [TheButton] "C:\Program Files\Button\The Button.exe"
O4 - HKLM\..\Run: [Outlook Mail Check] "C:\Program Files\OutlookConfiguration\Auto.vbs"
O4 - HKLM\..\Run: [MediaPlager User Config] C:\Program Files\Windows Media Player\WMP_USER_CONFIG.EXE /s
O4 - HKCU\..\Run: [EasyLinkAdvisor] "C:\Program Files\Linksys EasyLink Advisor\LinksysAgent.exe" /startup
O11 - Options group: [JAVA_IBM] Java (IBM)
O15 - Trusted Zone: *.*.ad.bne.net
O15 - Trusted Zone: *.*.ad.jase.com
O15 - Trusted Zone: *.*.bne.net
O15 - Trusted Zone: *.*.cse.com
O15 - Trusted Zone: *.*.exchad.jse.net
O15 - Trusted Zone: *.*.jse.com
O15 - Trusted Zone: *.*.se.net
O15 - Trusted Zone: *.*.an.com
O15 - Trusted Zone: *.*.se.com
O15 - Trusted Zone: *.*.ad.bne.net (HKLM)
O15 - Trusted Zone: *.*.ad.orgae.com (HKLM)
O15 - Trusted Zone: *.*.ba.net (HKLM)
O15 - Trusted Zone: *.*.ase.com (HKLM)
O15 - Trusted Zone: *.*.exchad.jse.net (HKLM)
O15 - Trusted Zone: *.*.j.com (HKLM)
O15 - Trusted Zone: *.*.jse.net (HKLM)
O15 - Trusted Zone: *.*.an.com (HKLM)
O15 - Trusted Zone: *.*.e.com (HKLM)
O16 - DPF: {05D96F71-87C6-11D3-9BE4-00902742D6E0} (QuickPlace Class) -
O16 - DPF: {74FFE28D-2378-11D5-990C-006094235084} (IBM Access Support) - [You must be registered and logged in to see this link.]
O16 - DPF: {98C53984-8BF8-4D11-9B1C-C324FCA9CADE} (Loader Class v3) - [You must be registered and logged in to see this link.]
O16 - DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} (GpcContainer Class) - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = bsna.bsroot.r.com
O17 - HKLM\Software\..\Telephony: DomainName = bsna.bsroot.r.com
O17 - HKLM\System\CCS\Services\Tcpip\..\{86FDF813-AD1B-4E9B-9158-D75FCB40B64F}: NameServer = 165.168.214.10,165.168.214.50
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = bsna.bsroot.r.com
O17 - HKLM\System\CS3\Services\Tcpip\Parameters: Domain = bsna.bsroot.r.com
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: BreenLock - - C:\Program Files\Brns\BeeenLock\BreenLock.exe
O23 - Service: Br Tuner (rTuner) - Marimba, Inc. - C:\PROGRA~1\Marimba\CASTAN~1\Tuner.exe
O23 - Service: BrSplService (Brother XP spl Service) - brother Industries Ltd - C:\WINDOWS\system32\brsvc01a.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
O23 - Service: Cisco Systems, Inc. VPN Service (CVPND) - Cisco Systems, Inc. - C:\Program Files\Cisco Systems\VPN Client\cvpnd.exe
O23 - Service: iSeries Access for Windows Remote Command (Cwbrxd) - IBM Corporation - C:\WINDOWS\CWBRXD.EXE
O23 - Service: Symantec AntiVirus Definition Watcher (DefWatch) - Symantec Corporation - C:\Program Files\Symantec AntiVirus\DefWatch.exe
O23 - Service: Google Update Service (gupdate1c9ae76645b3752) (gupdate1c9ae76645b3752) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: IBM Rapid Restore Ultra Service - Unknown owner - C:\Program Files\IBM\IBM Rapid Restore Ultra\rrpcsb.exe
O23 - Service: IBM PM Service (IBMPMSVC) - Unknown owner - C:\WINDOWS\System32\ibmpmsvc.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: Intuit Update Service (IntuitUpdateService) - Intuit Inc. - C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
O23 - Service: IBM PSA Access Driver Control (PsaSrv) - Unknown owner - C:\WINDOWS\system32\PsaSrv.exe (file missing)
O23 - Service: QCONSVC - IBM Corp. - C:\WINDOWS\System32\QCONSVC.EXE
O23 - Service: SAVRoam (SavRoam) - symantec - C:\Program Files\Symantec AntiVirus\SavRoam.exe
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
O23 - Service: Symantec AntiVirus - Symantec Corporation - C:\Program Files\Symantec AntiVirus\Rtvscan.exe
O23 - Service: Tb2 Launch (Tb2Launch) - Netopia, Inc. - C:\Program Files\Timbuktu Pro\tb2launch.exe
O23 - Service: IBM KCU Service (TpKmpSVC) - Unknown owner - C:\WINDOWS\system32\TpKmpSVC.exe
O23 - Service: Orchestria APM Infrastructure (WGNINFRA) - Orchestria - C:\Program Files\Orchestria\Active Policy Management\system\wgninfra.exe
End of file - 14247 bytes
gbottje
Posts Posts : 6
Re: Nuqel.e problem
Post by Belahzur on Mon Jan 18, 2010 10:37 pm
    In Internet Explorer
    In Firefox
Re: Nuqel.e problem
Post by gbottje on Thu Jan 21, 2010 12:40 pm
It found 3 items. Here's the log:
Database version: 3606
Internet Explorer 7.0.5730.11
1/21/2010 6:39:30 AM
mbam-log-2010-01-21 (06-39-30).txt
Objects scanned: 170614
Time elapsed: 15 minute(s), 1 second(s)
Registry Values Infected: 2
Files Infected: 1
HKEY_CURRENT_USER\Control Panel\Desktop\convertedwallpaper (Hijack.Wallpaper) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Control Panel\Desktop\originalwallpaper (Hijack.Wallpaper) -> Quarantined and deleted successfully.
C:\WINDOWS\ESUGRegEx.exe (Trojan.Generic) -> Quarantined and deleted successfully.
gbottje
Posts Posts : 6
Re: Nuqel.e problem
Post by Belahzur on Thu Jan 21, 2010 5:24 pm
Re: Nuqel.e problem
Post by gbottje on Fri Jan 22, 2010 12:03 pm
Attach.txt log
DDS (Ver_09-12-01.01)
Microsoft Windows XP Professional
Install Date: 3/2/2005 5:10:46 PM
System Uptime: 1/21/2010 1:35:06 PM (16 hours ago)
Motherboard: IBM | | 2373S89
Processor: Intel(R) Pentium(R) M processor 1.70GHz | nȯne | 798/400mhz
C: is FIXED (NTFS) - 33 GiB total, 4.825 GiB free.
D: is CDROM ()
F: is NetworkDisk (*NT5CSC) - 33 GiB total, 4.825 GiB free.
Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
Description: Cisco Systems VPN Adapter
Device ID: ROOT\NET\0000
Manufacturer: Cisco Systems
Name: Cisco Systems VPN Adapter
PNP Device ID: ROOT\NET\0000
Service: CVirtA
RP619: 12/25/2009 8:36:57 PM - System Checkpoint
RP620: 12/27/2009 7:18:46 AM - System Checkpoint
RP621: 1/1/2010 9:16:29 AM - System Checkpoint
RP622: 1/2/2010 9:31:13 AM - System Checkpoint
RP623: 1/3/2010 1:54:36 PM - System Checkpoint
RP624: 1/4/2010 10:14:56 PM - System Checkpoint
RP625: 1/6/2010 6:03:39 AM - System Checkpoint
RP626: 1/9/2010 11:12:50 AM - System Checkpoint
RP627: 1/15/2010 7:18:40 PM - System Checkpoint
RP628: 1/16/2010 3:00:51 AM - Software Distribution Service 3.0
RP629: 1/17/2010 1:35:17 PM - System Checkpoint
RP630: 1/17/2010 5:50:25 PM - Installed HiJackThis
RP631: 1/18/2010 7:18:19 PM - System Checkpoint
RP632: 1/19/2010 10:50:25 PM - System Checkpoint
RP633: 1/20/2010 11:07:03 PM - System Checkpoint
RP634: 1/22/2010 5:41:34 AM - Software Distribution Service 3.0
Access IBM
Access IBM Message Center
Acopia Registry FIX
Adobe Flash Player 10 ActiveX
Adobe Reader 8.1.6
AnswerWorks 5.0 English Runtime
ATI - Software Uninstall Utility
ATI Control Panel
ATI Display Driver
ATI HYDRAVISION
ar Stearns Marimba Tuner
BNS VM
BNSLogViewer
BNSROE
BNSTradingLimits
Brother Extensions for Paperport
Brother MFL Pro Suite
Canon BJC-3000 (BJRSTR)
Canon iP4300
Canon iP4300 User Registration
Canon My Printer
Canon Setup Utility 2.3
Canon Utilities Easy-PhotoPrint
Client Simulator
Coupon Printer for Windows
Default mail setup
Drivers Install For Linksys Easylink Advisor
Easy-WebPrint
Environment Changer
Freedom Scientific Document Server
Freedom Scientific Synthesizer Eloquence
Freedom Scientific Talking Installer 8.0
Freedom Scientific Video Intercept
getPlus(R)_ocx
Google Earth
Google Update Helper
Google Updater
GPL MPEG-1/2 DirectShow Decoder Filter
hBSC Outlook Configuration 1 (R5)
HiJackThis
IBM 32-bit Runtime Environment for Java 2, v1.4.1
IBM Access Connections
IBM Accessibility Speech Interface v1.2
IBM Active Protection System
IBM DLA
IBM Integrated 56K Modem
IBM iSeries Access for Windows
IBM Lotus Sametime Connect 7.5.1
IBM RecordNow!
IBM Rescue and Recovery with Rapid Restore
IBM Themes
IBM ThinkPad Battery MaxiMiser and Power Management Features
IBM ThinkPad Configuration
IBM ThinkPad EasyEject Utility
IBM ThinkPad Keyboard Customizer Utility
IBM ThinkPad Power Management Driver
IBM ThinkPad Presentation Director
IBM ThinkPad UltraNav Driver
IBM ThinkPad UltraNav Wizard
IBM ThinkVantage Technologies Welcome Message
IBM TrackPoint Accessibility Features
IBM Update Connector
IBM ViaVoice TTS Runtime v6.740 - US English
Intel(R) PRO Network Adapters and Drivers
InterVideo WinDVD
ItsDeductible Express
Java 2 Runtime Environment Standard Edition v1.3.1_02
Java 2 Runtime Environment, SE v1.4.2_18
Java Web Start
Java(TM) 6 Update 15
KB906681 RE-ISSUE installed on 12/06/06 5:58:15
KB918899 RE-ISSUE installed on 09/22/06 21:26:59
Linksys EasyLink Advisor 1.6 (0042)
LiveUpdate 2.6 (Symantec Corporation)
Macromedia Shockwave Player
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Outlook 2007
Microsoft Office Professional Edition 2003
Microsoft Office Project Professional 2003
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Office Visio Standard 2003
Microsoft Software Update for Web Folders (English) 12
Microsoft Text-to-Speech Engine 4.0 (English)
Microsoft XML Parser
mp
mpmri
MSIforZfS
MSN Music Assistant
MSXML 4.0 SP2 (KB925672)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
MSXML 4.0 SP2 Parser and SDK
MSXML 6.0 Parser (KB933579)
Niku 6 Workbench Client
Outlook JPMC Addin 1 (R4)
Outlook No Automatic Junk Mail Filtering Policy (R1)
Outlook Web Access Icon (R1)
PaperPort 6.5
PC-Doctor for Windows
PeregrineServiceCenter 6.12 R2
Performance Navigator 12.0
Performance Navigator 13
Print Server Utilities
PrintServerUpdate
QuickPlace 7.0.0 (R1)
QuickTime
QuickVerse 2007
RealPlayer
Remedy User 6.3
Right Fax Client
RUMBA
SBC Self Support Tool
SBC Yahoo! DSL Activation
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for Microsoft Office Outlook 2007 (KB972363)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Word 2007 (KB969604)
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB931768)
Security Update for Windows Internet Explorer 7 (KB976325)
Security Update for Windows Internet Explorer 7 (KB978207)
Security Update for Windows Media Player 9 (KB911565)
Security Update for Windows Media Player 9 (KB917734)
Security Update for Windows XP (KB953155)
Security Update for Windows XP (KB970430)
Security Update for Windows XP (KB972270)
Security Update for Windows XP (KB973904)
Security Update for Windows XP (KB974318)
Security Update for Windows XP (KB974392)
Set Default Mail Client (R1)
Sonic Update Manager
Supervisory Tools
Symantec AntiVirus
Symantec Vault For Outlook 7.5 (R2)
The Button 3.1 (R1)
The Concord Study Package
ThinkPad FullScreen Magnifier
ThinkPad Software Installer
Timbuktu Pro
TurboTax 2008
TurboTax 2008 WinPerFedFormset
TurboTax 2008 WinPerProgramHelp
TurboTax 2008 WinPerReleaseEngine
TurboTax 2008 WinPerTaxSupport
TurboTax 2008 WinPerUserEducation
TurboTax 2008 wrapper
TurboTax Basic 2006
TurboTax Basic 2007
Update for Outlook 2007 Junk Email Filter (kb977839)
Update for Windows Internet Explorer 7 (KB976749)
Update for Windows XP (KB955759)
Update for Windows XP (KB971737)
User Profile Hive Cleanup Service
Visual IP InSight(SBC)
VPN Client
Wallpapers
Web-based System Manager Remote Client
WebEx
WebFldrs XP
Windows Genuine Advantage v1.3.0254.0
Windows Imaging Component
Windows Media Format Runtime
Windows XP Service Pack 3
WinZip
WordWeb
XML Paper Specification Shared Components Pack 1.0
Yahoo! BrowserPlus
ZipMail for MS Outlook and Outlook Express
1/17/2010 6:15:17 AM, error: NETLOGON [5719] - No Domain Controller is available for domain BSNA due to the following: There are currently no logon servers available to service the logon request. . Make sure that the computer is connected to the network and try again. If the problem persists, please contact your domain administrator.
1/17/2010 3:15:59 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: ANC eeCtrl Fips IBMTPCHK intelppm SAVRT SAVRTPEL ShockMgr Smapint TDSMAPI TPHKDRV TPPWR TSMAPIP
1/17/2010 3:15:53 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service StiSvc with arguments "" in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
1/17/2010 3:15:12 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
1/16/2010 7:29:03 AM, error: Service Control Manager [7016] - The BrSplService service has reported an invalid current state 0.
1/16/2010 7:20:42 AM, error: Service Control Manager [7024] - The Orchestria APM Infrastructure service terminated with service-specific error 2147942526 (0x8007007E).
1/16/2010 7:18:43 AM, error: Print [6161] - The document Test Page owned by GBottje failed to print on printer Cher-Brother. Data type: NT EMF 1.008. Size of the spool file in bytes: 74868. Number of bytes printed: 0. Total number of pages in the document: 1. Number of pages printed: 0. Client machine: \\BS128681. Win32 error code returned by the print processor: 2 (0x2).
1/15/2010 6:44:03 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the HTTP SSL service to connect.
1/15/2010 6:44:03 PM, error: Service Control Manager [7000] - The HTTP SSL service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
DDS.txt log
DDS (Ver_09-12-01.01) - NTFSx86
Run by GBottje at 5:49:35.98 on Fri 01/22/2010
Internet Explorer: 7.0.5730.11
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.511.197 [GMT -6:00]
AV: Symantec AntiVirus Corporate Edition *On-access scanning enabled* (Outdated) {FB06448E-52B8-493A-90F3-E43226D3305C}
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Brns\BrScreenLock\BreenLock.exe
C:\WINDOWS\System32\svchost.exe -k imgsvc
C:\WINDOWS\System32\svchost.exe -k HTTPFilter
C:\Temp\Temporary Internet Files\Content.IE5\Q8WV0D36\dds[1].scr
BHO: EWPBrowseObject Class: {68f9551e-0411-48e4-9aaf-4bc42a6a46be} - c:\program files\canon\easy-webprint\EWPBrowseLoader.dll
BHO: Google Toolbar Notifier BHO: {af69de43-7d58-4638-b6fa-ce66b5ad205d} - c:\program files\google\googletoolbarnotifier\5.1.1309.3572\swg.dll
TB: Easy-WebPrint: {327c2873-e90d-4c37-aa9d-10ac9baba46c} - c:\program files\canon\easy-webprint\Toolband.dll
TB: {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No File
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} -
EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
uRun: [EasyLinkAdvisor] "c:\program files\linksys easylink advisor\LinksysAgent.exe" /startup
uRun: [swg] c:\program files\google\googletoolbarnotifier\GoogleToolbarNotifier.exe
mRun: [zie_user_config] c:\program files\internet explorer\ie_user_config.EXE /s
mRun: [vptray] c:\progra~1\symant~1\VPTray.exe
mRun: [UpdateManager] "c:\program files\common files\sonic\update manager\sgtray.exe" /r
mRun: [UC_Start] c:\program files\ibm\updater\\ucstartup.exe
mRun: [TpShocks] TpShocks.exe
mRun: [TPKMAPHELPER] c:\program files\thinkpad\utilities\TpKmapAp.exe -helper
mRun: [TPHOTKEY] c:\progra~1\thinkpad\pkgmgr\hotkey\TPHKMGR.exe
mRun: [TP4EX] tp4ex.exe
mRun: [TLogonPath] "c:\program files\timbuktu pro\tb2logon.exe"
mRun: [SynTPLpr] c:\program files\synaptics\syntp\SynTPLpr.exe
mRun: [SynTPEnh] c:\program files\synaptics\syntp\SynTPEnh.exe
mRun: [Synchronization Manager] %SystemRoot%\system32\mobsync.exe /logon
mRun: [savsetup] c:\program files\marimba\castanet tuner\tuner -start [You must be registered and logged in to see this link.]
mRun: [S3TRAY2] S3Tray2.exe
mRun: [QCWLIcon] c:\progra~1\thinkpad\connec~1\QCWLIcon.exe
mRun: [PaperPort PTD] c:\progra~1\scansoft\paperp~1\pptd40nt.exe
mRun: [OutlookDisclaimerAdd-in] c:\windows\ODP.EXE
mRun: [Orchestria APM Client] c:\program files\orchestria\active policy management\client\wgncm.exe
mRun: [Motive SmartBridge] c:\progra~1\sbcsel~1\smartb~1\MotiveSB.exe
mRun: [IPInSightMonitor 02] "c:\program files\visual networks\visual ip insight\sbc\IPMon32.exe"
mRun: [IPInSightLAN 02] "c:\program files\visual networks\visual ip insight\sbc\IPClient.exe" -l
mRun: [IBMPRC] c:\ibmtools\utils\ibmprc.exe
mRun: [Flash User Config] c:\windows\system32\macromed\shockwave 10\xtras\Flash_user_config.EXE
mRun: [EZEJMNAP] c:\progra~1\thinkpad\utilit~1\EzEjMnAp.Exe
mRun: [dla] c:\windows\system32\dla\tfswctrl.exe
mRun: [Client Access Service] "c:\program files\ibm\client access\cwbsvstr.exe"
mRun: [Client Access PC5250 Sound] "c:\program files\ibm\client access\emulator\pcssnd.exe"
mRun: [Client Access Help Update] "c:\program files\ibm\client access\cwbinhlp.exe"
mRun: [Client Access Express Welcome] "c:\program files\ibm\client access\cwbwlwiz.exe"
mRun: [Client Access Check Version] "c:\program files\ibm\client access\cwbckver.exe" LOGIN
mRun: [ccApp] "c:\program files\common files\symantec shared\ccApp.exe"
mRun: [BMMMONWND] rundll32.exe c:\progra~1\thinkpad\utilit~1\BatInfEx.dll,BMMAutonomicMonitor
mRun: [BMMLREF] c:\program files\thinkpad\utilities\BMMLREF.EXE
mRun: [ATIPTA] c:\program files\ati technologies\ati control panel\atiptaxx.exe
mRun: [QCTray] c:\progra~1\thinkpad\connec~1\QCTray.exe
mRun: [TheButton] "c:\program files\button\The Button.exe"
mRun: [Outlook Mail Check] "c:\program files\outlookconfiguration\Auto.vbs"
mRun: [MediaPlager User Config] c:\program files\windows media player\WMP_USER_CONFIG.EXE /s
mPolicies-explorer: NoStrCmpLogical = 1 (0x1)
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office11\EXCEL.EXE/3000
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~2\office11\REFIEBAR.DLL
Trusted Zone: *.ad.one.net
Trusted Zone: *.ad.jpase.com
Trusted Zone: *.one.net
Trusted Zone: *.ase.com
Trusted Zone: *.exchad.ase.net
Trusted Zone: *.hase.com
Trusted Zone: *.hase.net
Trusted Zone: *.rgan.com
Trusted Zone: *.jnchase.com
Trusted Zone: ar.com
Trusted Zone: ear.com\chhmc1a.is
Trusted Zone: turbotax.com
Trusted Zone: whesupport1
Trusted Zone: *.ad.jhase.com
Trusted Zone: *.jhase.com
DPF: {05D96F71-87C6-11D3-9BE4-00902742D6E0} -
DPF: {74FFE28D-2378-11D5-990C-006094235084} - [You must be registered and logged in to see this link.]
DPF: {98C53984-8BF8-4D11-9B1C-C324FCA9CADE} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} - [You must be registered and logged in to see this link.]
DPF: {E06E2E99-0AA1-11D4-ABA6-0060082AA75C} - [You must be registered and logged in to see this link.]
TCP: {86FDF813-AD1B-4E9B-9158-D75FCB40B64F} = 165.168.214.10,165.168.214.50
Notify: AtiExtEvent - Ati2evxx.dll
Notify: NavLogon - c:\windows\system32\NavLogon.dll
Notify: QConGina - QConGina.dll
Notify: Timbuktu Pro - c:\program files\timbuktu pro\Hook32.dll
R0 ppa;Iomega Parallel Port Filter Driver;c:\windows\system32\drivers\ppa.sys [2005-4-17 17792]
R1 SAVRT;SAVRT;c:\program files\symantec antivirus\savrt.sys [2006-5-31 337592]
R1 SAVRTPEL;SAVRTPEL;c:\program files\symantec antivirus\Savrtpel.sys [2006-5-31 54968]
R1 Tb2Device;TB2 Remote Control Driver;NetopiaRC\Tb2Device.sys --> NetopiaRC\Tb2Device.sys [?]
R1 Tb2MirrorSys;TB2 Remote Control Mirror Driver;NetopiaRC\Tb2MirrorSys.sys --> NetopiaRC\Tb2MirrorSys.sys [?]
R1 TPPWR;TPPWR;c:\windows\system32\drivers\TPPWR.SYS [2005-3-2 16384]
R2 BreenLock;BreenLock;c:\program files\ar stearns\bcreenlock\BreenLock.exe [2004-11-23 36864]
R2 arTunerear Tuner;c:\progra~1\marimba\castan~1\Tuner.exe [2005-3-4 32871]
R2 ccEvtMgr;Symantec Event Manager;c:\program files\common files\symantec shared\ccEvtMgr.exe [2006-5-31 186016]
R2 ccSetMgr;Symantec Settings Manager;c:\program files\common files\symantec shared\ccSetMgr.exe [2006-5-31 177824]
R2 SavRoam;SAVRoam;c:\program files\symantec antivirus\SavRoam.exe [2006-5-31 169200]
R2 Symantec AntiVirus;Symantec AntiVirus;c:\program files\symantec antivirus\Rtvscan.exe [2006-5-31 1764592]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [2009-12-3 102448]
R3 NAVENG;NAVENG;c:\progra~1\common~1\symant~1\virusd~1\20091202.006\naveng.sys [2009-12-3 84912]
R3 NAVEX15;NAVEX15;c:\progra~1\common~1\symant~1\virusd~1\20091202.006\navex15.sys [2009-12-3 1323568]
R3 PCX504;Cisco Systems Wireless LAN Adapter Driver;c:\windows\system32\drivers\PCX504.sys [1980-1-1 119296]
S0 vfdafqa;vfdafqa;c:\windows\system32\drivers\ovxllbm.sys --> c:\windows\system32\drivers\ovxllbm.sys [?]
S2 gupdate1c9ae76645b3752;Google Update Service (gupdate1c9ae76645b3752);c:\program files\google\update\GoogleUpdate.exe [2009-3-26 133104]
S2 WGNINFRA;Orchestria APM Infrastructure;c:\program files\orchestria\active policy management\system\wgninfra.exe [2006-10-18 553030]
S3 brfilt;Brother MFC Filter Driver;c:\windows\system32\drivers\BrFilt.sys [2006-9-11 2944]
S3 BrSerWDM;Brother Serial driver;c:\windows\system32\drivers\BrSerWdm.sys [2006-9-11 60416]
S3 BrUsbMdm;Brother MFC USB Fax Only Modem;c:\windows\system32\drivers\BrUsbMdm.sys [2006-9-11 11008]
S3 BrUsbScn;Brother MFC USB Scanner driver;c:\windows\system32\drivers\BrUsbScn.sys [2006-9-11 10368]
S3 ccPwdSvc;Symantec Password Validation;c:\program files\common files\symantec shared\ccPwdSvc.exe [2006-5-31 83616]
S3 QCNDISIF;QCNDISIF;c:\windows\system32\drivers\qcndisif.sys [2005-3-2 12288]
S3 RMBS;RMBS;c:\windows\system32\drivers\rmbs.sys [2005-2-15 17828]
S3 TWXWD;TWXWD;c:\windows\system32\drivers\TwxWD.sys [2005-2-15 26964]
S3 vsdatant;vsdatant;c:\windows\system32\vsdatant.sys [2006-10-12 280344]
============== File Associations ===============
vbefile\shell\open2\command=%SystemRoot%\System32\CScript.exe "%1" %*
vbsfile\shell\open2\command=%SystemRoot%\System32\CScript.exe "%1" %*
jsefile\shell\open2\command=%SystemRoot%\System32\CScript.exe "%1" %*
2010-01-22 11:49:30 0 d-----w- c:\temp\A5.tmp
2010-01-22 11:42:00 1266 ----a-w- c:\temp\qcontmp25.vbs
2010-01-22 04:30:25 28 ----a-w- c:\temp\ExchangePerflog_8484fa31c8b5e1abcfcccd43.dat
2010-01-22 03:34:08 16384 ----atw- c:\temp\Perflib_Perfdata_670.dat
2010-01-21 12:53:44 46640 ----a-w- c:\windows\system32\msln.exe
2010-01-21 04:37:52 0 d-----w- c:\docume~1\gbottje\applic~1\Malwarebytes
2010-01-21 04:37:42 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-01-21 04:37:38 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2010-01-21 04:37:37 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-01-21 04:37:36 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-01-19 11:42:50 1266 ----a-w- c:\temp\qcontmp24.vbs
2010-01-17 23:50:27 0 d-----w- c:\program files\TrendMicro
2010-01-17 22:59:45 94208 ----a-w- c:\temp\PSKILL.EXE
2010-01-17 21:52:27 0 d-sha-r- C:\cmdcons
2010-01-17 21:47:38 98816 ----a-w- c:\windows\sed.exe
2010-01-17 21:47:38 77312 ----a-w- c:\windows\MBR.exe
2010-01-17 21:47:38 261632 ----a-w- c:\windows\PEV.exe
2010-01-17 21:47:38 161792 ----a-w- c:\windows\SWREG.exe
2010-01-17 12:25:18 0 d-----w- C:\found.000
2010-01-16 01:00:04 471552 ------w- c:\windows\system32\dllcache\aclayers.dll
2009-12-31 15:33:06 70656 ------w- c:\windows\system32\dllcache\ie4uinit.exe
2009-12-31 15:33:06 13824 ------w- c:\windows\system32\dllcache\ieudinit.exe
2009-12-18 13:05:43 634648 ------w- c:\windows\system32\dllcache\iexplore.exe
2009-12-18 13:04:09 161792 ------w- c:\windows\system32\dllcache\ieakui.dll
2009-10-29 07:46:59 832512 ------w- c:\windows\system32\wininet.dll
2006-07-17 20:35:36 139 ----a-w- c:\program files\wsmjunk.txt
============= FINISH: 5:50:49.42 ===============
Thanks very much for your help.
gbottje
Posts Posts : 6
Re: Nuqel.e problem
Post by Belahzur on Fri Jan 22, 2010 8:56 pm
  • Save it to your desktop.
    :services
    vfdafqa
    :files
    c:\temp\A5.tmp
    C:\found.***
  • Close OTMoveIt
Please post the OTMoveIt log.
Re: Nuqel.e problem
Post by gbottje on Sat Jan 23, 2010 6:11 pm
MoveIt Results
========== SERVICES/DRIVERS ==========
Service vfdafqa stopped successfully!
Service vfdafqa deleted successfully!
========== FILES ==========
File/Folder c:\temp\A5.tmp not found.
c:\temp\qcontmp25.vbs moved successfully.
c:\temp\qcontmp24.vbs moved successfully.
C:\found.000\dir0003.chk folder moved successfully.
C:\found.000\dir0002.chk folder moved successfully.
C:\found.000\dir0001.chk folder moved successfully.
C:\found.000\dir0000.chk folder moved successfully.
C:\found.000 folder moved successfully.
c:\program files\wsmjunk.txt moved successfully.
File/Folder c:\windows\system32\msln.exe not found.
OTM by OldTimer - Version 3.1.6.0 log created on 01232010_120906
gbottje
Posts Posts : 6
Re: Nuqel.e problem
Post by Belahzur on Sat Jan 23, 2010 7:37 pm
We can remove OTMoveIt now.
  • Please double-click OTM.exe to run it again.
  • Press the green CleanUp! button.
  • Press Yes cleanup process prompt, do the same for the reboot prompt.
Re: Nuqel.e problem
Post by gbottje on Thu Jan 28, 2010 2:11 am
Running great. No sign of the infection. Thank you very much. I appreciate your professionalism and technical solutions. All your instructions were crystal clear and (obviously) worked. I've sent a donation. Thanks again.
gbottje
Posts Posts : 6
Re: Nuqel.e problem
Post by Belahzur on Thu Jan 28, 2010 5:33 pm
    Java Web Start
Updating Java:
  • Select the second option where it says "This special release provides a few key fixes.".
  • In the Window that opens, select your platform, check the "agree" box, and click Continue.
  • Then from your desktop double-click on jre-6u17-windows-i586.exe that you downloaded to install the newest version.
