hello and heres my current problem
Re: hello and heres my current problem
Post by paulsky on Wed Jan 27, 2010 4:41 pm
i got the restore point done and heres the screen317 report
Windows Vista Service Pack 2 (UAC is disabled!)
Antivirus/Firewall Check:
Windows Firewall Disabled!
AVG 9.0
WMIC entry does not exist for antivirus; attempting automatic update.
Java(TM) 6 Update 11
Java(TM) 6 Update 5
Out of date Java installed!
Adobe Flash Player 10
Adobe Reader 9.2
Process Check:
objlist.exe by Laurent
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
DNS Vulnerability Check:
paulsky
Posts Posts : 20
Joined Joined : 2010-01-15
OS OS : windows vista - home premium
Points Points : 25398
Post by Dr Jay on Wed Jan 27, 2010 9:47 pm
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13713
Points Points : 302059
Post by paulsky on Thu Jan 28, 2010 10:26 am
thanks for your help. im going to download some of these, i just ran a malware bytes scan and found 1 trojan though *sigh* this is growing tiresome
i took comodo spyware blaster and hp hosts, im currently using google chrome as well as having firefix installed, however firefox has an irritating tendancy to crash so im using google chrome at the moment
paulsky
Posts Posts : 20
