Audio Driver issues
Audio Driver issues
Post by shockz13 on 14th January 2010, 1:04 am
Hey, I have a Realtek High definition Audio card and it doesn't work until I instal a driver. I installed the driver and it all worked great including the mic input, today I went on vent and wasn't getting any voice. I checked my settings and found:
I didn't touch my settings nor change my software configuration, it just stopped working. I tried reinstalling my driver and restarting my computer a few times and nothing works. It's not my mic cause I tested on another computer.
If anyone has any ideas that'd be great.
shockz13
Posts Posts : 57
Joined Joined : 2009-01-18
OS OS : Windows 7 Ultimate SP1
Points Points : 29232
Re: Audio Driver issues
Post by Doctor Inferno on 14th January 2010, 4:21 am
What type of mic are you using? What is the brand of your PC?
Points Points : 104630
Post by shockz13 on 14th January 2010, 6:12 am
its liek a crappy imego or something, sounds great though and its new, my PC is an ASUS. I didn't change out any parts since I got it so they should all be compatible and those controls are usually unlocked even when a mic isnt plugged in.
Edit: fixed itself? Booted today and it was all working again.
shockz13
Posts Posts : 57
