Have Wireless Connection But Can't Connect To IE
Solved Have Wireless Connection But Can't Connect To IE
Post by yogibear_007 on 10th January 2010, 5:24 am
I have a Dell Mini laptop that my friend gave me about a week ago so all I have is the laptop itself and the charger. It has wireless connection and I can connect to Linksys Wireless Network but when I click on the Internet Explorer icon, it loads but says that it can't display the webpage. I had a friend look at it and they told me the internet could have been deleted. He says it will connect with a phone line but not wirelessly. And Linksys works perfectly on my desktop. I'm clueless when it comes to computer tech and i wouldn't know where to begin trying to fix this problem..
yogibear_007
Posts Posts : 4
Joined Joined : 2010-01-10
Points Points : 25296
Solved Re: Have Wireless Connection But Can't Connect To IE
Post by Doctor Inferno on 10th January 2010, 8:32 am
Please start Internet Explorer, and when the program is open, click on the Tools menu and then select Internet Options.
  • Now click on the Connections tab and then the Lan Settings button
  • Under the Proxy Server section, please uncheck the checkbox labeled Use a proxy server for your LAN.
  • Click the OK button to close this screen. Then press the Apply button and then the OK button to close the Internet Options screen. Now that you have disabled the proxy server you will be able to browse the web again with Internet Explorer.
If it doesn't work, open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
Points Points : 104650
Post by yogibear_007 on 10th January 2010, 9:35 am
The CMD did the trick. I'm so excited that I have internet on my laptop again. Thanks for your help.
yogibear_007
Posts Posts : 4
Post by Doctor Inferno on 10th January 2010, 9:46 am
No prob, glad I could help. Smile
