Network Problems
Network Problems
Post by Ashton ClouD on 10th January 2010, 3:00 am
I have a network at my work. I have recently been hit with a virus and my firewall settings were reset. Now, the other computers on my server cannot connect to certain programs that are used for my company. They can share files with my main computer (which runs everything) and can access internet, but only this specific program cannot be used. It is a software program we bought to run our spa. Do you think there is some security that the company set that they need to reset for me to access this program from other computers? Or is there a way I can make an exception on my firewall to use this program? I already tried making an exception for these specific programs, but it didn't work. Please let me know. Sorry, I am using Windows XP.
Thank You!
Ashton ClouD
Posts Posts : 31
Joined Joined : 2010-01-08
Points Points : 25645
Re: Network Problems
Post by Doctor Inferno on 10th January 2010, 8:31 am
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
Post by Ashton ClouD on 11th January 2010, 5:19 pm
I tried all of the above and still is not working. The only way other computers can access the programs required is if my firewall is turned off. I also posted a problem for a virus issue that might be the problem.
Ashton ClouD
Posts Posts : 31
Post by Doctor Inferno on 12th January 2010, 4:12 am
Please wait till the virus problem is solved first.
