Stuck on welcome screen after I Think IS2010, please help!
Post by matnic on Sat Jan 09, 2010 4:21 pm
copied from another post cause I am having the exact same problem:
Got infected by IS 2010 today. Thought i caught it early; SuperAntiVirus had detected and asked to re-boot. However, after the computer restarted, it will not go boot past the Windows XP welcome/log-in screen. Prior to this, it never asked for log-in. It just keeps looping without getting anything further, even in Safe Mode. I can see the desktop picture briefly before the welcome screen comes up.
Since I can't even get to the command prompt, what else can I try at least get to command prompt?
Any advice will be greatly appreciated...
matnic
Posts Posts : 8
Joined Joined : 2010-01-09
Points Points : 25331
Re: Stuck on welcome screen after I Think IS2010, please help!
Post by Belahzur on Sat Jan 09, 2010 7:00 pm
Try this.
Avira AntiVir Rescue System is a Linux-based application that allows accessing computers that cannot be booted anymore.
  • Download The Avira AntiVir Rescue System from [You must be registered and logged in to see this link.].
  • Just double-click on the rescue system package to burn it to a CD/DVD.
  • Then please use that CD/DVD with Avira Rescue System to boot your computer.
You'll get a boot option to either boot from hard drive or AntiVir Rescue System.
Press the number 2 on your keyboard to boot into AntiVir Rescue System.
Please wait until drivers are loaded and Main menu shows. Then please select the second option “Scan your system with AntiVir” and hit Enter.
Under Configuration, please select Scan all files, Try to repair infected files and Rename files if they cannot be removed?.
Then please start the scan.
The Avira AntiVir Rescue System wil now
  • repair a damaged system,
  • rescue data,
  • scan the system for virus infections.
Points Points : 245059
Post by nb2010 on Sat Jan 09, 2010 7:45 pm
I'm the other poster... Running Avira rescue CD now, but feeling a bit uneasy about the two penguins that showed up before the Avira screen came up. Anyone knows if that's legit?
Also not sure if it's normal that the boot disc didn't run until I changed the boot sequence in BIOS.
Any input will be appreciated...
nb2010
Posts Posts : 13
OS OS : windows xp
Points Points : 25389
Post by Origin on Sat Jan 09, 2010 7:51 pm
[You must be registered and logged in to see this link.] wrote:I'm the other poster... Running Avira rescue CD now, but feeling a bit uneasy about the two penguins that showed up before the Avira screen came up. Anyone knows if that's legit?
Hello nb2010, please stick to your own topic and if you have any questions feel free to ask in your topic since replies from multiple members confuse us at times. Avira Rescue CD is legit if it didn't ask to boot when restarted it fine that you booted it via the BIOS.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by matnic on Mon Jan 11, 2010 1:30 pm
I ran the Avira CD and let it run, it found warnings and such, but nothing really major. Then I shut down, turned on, took out the CD, and the same problem, stuck on sign in screen, click my user, shows my desktop picture for a few seconds, then goes back to the signin screen. I had never had to sign in with this machine before this. Any other ideas?
ps I got the 2 penguins, too...I figured they were a part of the Avira starting up.
matnic
Posts Posts : 8
Post by matnic on Thu Jan 14, 2010 7:07 pm
bump
matnic
Posts Posts : 8
Post by Belahzur on Thu Jan 14, 2010 7:52 pm
Do you have your original XP disc?
