Vundo.JD removal. Help!
Post by RobertCampbell7979 on 9th January 2010, 12:17 am
I have a trojan horse Vundo.JD that my AVG detects but cannot remove. Can you help? Thanks.
Robert
RobertCampbell7979
Joined Joined : 2010-01-09
Points Points : 25243
Re: Vundo.JD removal. Help!
Post by Belahzur on 9th January 2010, 1:34 am
Points Points : 245079
