Unremovable Wallpaper from AntiVirus System Pro
Re: Unremovable Wallpaper from AntiVirus System Pro
Post by Dr Jay on 9th January 2010, 3:21 am
Please copy and paste the following in to Notepad:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"NoDispAppearancePage"=-
"NoDispCPL"=-
"NoDispBackgroundPage"=-
"NoDispScrSavPage"=-
"NoDispSettingsPage"=-
"wallpaper"=-
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"wallpaper"=-
"NoDispCPL"=-
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System\ActiveDesktop]
"NoChangingWallPaper"="0"
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\ActiveDesktop]
Then click File > Save as
Save as wallpaperFIX.reg to your Desktop.
Choose Save as type: All Files.
Click Save.
Exit Notepad, then double-click on wallpaperFIX.reg to run the script.
After you have confirmed the prompts, please restart your computer.
Let me know if your wallpaper will cooperate now.
Posts Posts : 13757
Points Points : 302262
Post by SilverSonata on 9th January 2010, 3:43 am
When I rebooted my computer, I now have two annoying things pop up;
This one appears ar the very beggining after logging in;
And this one starts to load itself automatically after a minute or two and will not disappear unless I use the Ctrl + Alt + Delete Command (If I click Cancel a few times, it will only temporarily go away, and a minute later, it will automatically restart to load again);
Also, while my desktop was loading, before the virus, I usually see my wallpaper appear along with my icons, but ever since the virus, I only see the wallpaper and then the icons appear after 2 minutes (I timed it while waiting). The very same thing happened right now and since it's not like my usual, it's worrying me because it's the exact same behavior as the
Thank you for your patience and perseverance with me. I'm sorry for causing you so many inconveniences.
SilverSonata
Posts Posts : 53
Joined Joined : 2009-11-30
Protection Protection : Norton Internet Security
Points Points : 26335
Post by Dr Jay on 9th January 2010, 4:09 am
Don't worry.
Please go [You must be registered and logged in to see this link.]. Copy and paste the following file path in to the box.
C:\windows\explorer.exe
Then click submit.
Please post the results (URL) to your next reply.
Posts Posts : 13757
Post by SilverSonata on 9th January 2010, 4:12 am
SilverSonata
Posts Posts : 53
Post by Dr Jay on 9th January 2010, 4:20 am
I need for that file to be re-analyzed.
It was already analyzed, but a new analysis must be done.
Posts Posts : 13757
Post by SilverSonata on 9th January 2010, 4:22 am
I'm sorry, is this the right one now?
SilverSonata
Posts Posts : 53
Post by Dr Jay on 9th January 2010, 5:37 am
Ok. Good.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\ActiveDesktop]
"NoChangingWallPaper"=dword:00000000
"NoAddingComponents"=dword:00000000
"NoComponents"=dword:00000000
"NoDeletingComponents"=dword:00000000
"NoEditingComponents"=dword:00000000
"NoCloseDragDropBands"=dword:00000000
"NoMovingBands"=dword:00000000
"NoHTMLWallPaper"=dword:00000000
"NoDispBackgroundPage"=dword:00000000
"NoDispScrSavPage"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoActiveDesktopChanges"=hex:00,00,00,00
"NoActiveDesktop"=dword:00000000
"NoDispCPL"=dword:00000000
"NoSaveSettings"=dword:00000000
"ClassicShell"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer]
"NoFolderOptions"=dword:00000000
"NoSimpleStartMenu"=dword:00000000
"NoCDBurning"=dword:00000000
"NoComputersNearMe"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\run]
"Wallpaper"=-
"WallPaperStyle"=-
"NoVisualStyleChoice"=dword:00000001
"NoColorChoice"=dword:00000001
"NoSizeChoice"=dword:00000001
Save as wallFIX.reg to your Desktop.
Click Save.
Exit Notepad, then double-click on wallFIX.reg to run the script.
Posts Posts : 13757
Post by SilverSonata on 9th January 2010, 5:53 am
My wallpaper is doing very well now. Thank you very much!
But at the startup of my computer, I still have the 'Found New Hardware Wizard' as well as the other download CD.
As for all the suggested downloads you have asked me to download up to now, can I uninstall them? If so, how?
SilverSonata
Posts Posts : 53
Post by Dr Jay on 9th January 2010, 7:28 am
  • Double click OTC.exe.
  • Click the CleanUp! button.
Download WhoCrashed [You must be registered and logged in to see this link.]
This program checks for any drivers which may have been causing your computer to crash....
Click on the file you just downloaded and run it.
Put a tick in Accept then click on Next
Put a tick in the Don't create a start menu folder then click Next
Put a tick in Create a Desktop Icon then click on Install and make sure there is a tick in Launch Whocrashed before clicking Finish
Click Analyze
It will want to download the Debugger and install it Say Yes
WhoCrashed will create report but you have to scroll down to see it
Copy and paste it into your next reply
Posts Posts : 13757
Post by SilverSonata on 9th January 2010, 5:04 pm
Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Sun 20/12/2009 10:36:58 PM your computer crashed
This was likely caused by the following module: csrss.exe
Bugcheck code: 0xF4 (0x3, 0x8284FDA0, 0x8284FF14, 0x8060567E)
Error: CRITICAL_OBJECT_TERMINATION
Dump file: C:\WINDOWS\Minidump\Mini122009-02.dmp
file path: C:\WINDOWS\system32\csrss.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Client Server Runtime Process
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
On Sun 20/12/2009 10:32:14 PM your computer crashed
This was likely caused by the following module: kxloapog.sys
Bugcheck code: 0x10000050 (0xFAE9500B, 0x0, 0xEBF68F60, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini122009-01.dmp
On Tue 10/03/2009 02:29:17 AM your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x100000D1 (0xE1F09000, 0x2, 0x0, 0xEE83FD00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030909-01.dmp
file path: C:\WINDOWS\system32\ntoskrnl.exe
description: NT Kernel & System
On Sun 08/03/2009 04:47:35 PM your computer crashed
Bugcheck code: 0x100000D1 (0xE1F10000, 0x2, 0x0, 0xEED62D00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030809-01.dmp
On Sat 07/03/2009 04:48:47 PM your computer crashed
Bugcheck code: 0x100000D1 (0xE1EF8000, 0x2, 0x0, 0xEE809D00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030709-03.dmp
On Sat 07/03/2009 04:44:20 PM your computer crashed
This was likely caused by the following module: mpfp.sys
Bugcheck code: 0x1000008E (0xC0000005, 0xEE508295, 0xED7ED174, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Dump file: C:\WINDOWS\Minidump\Mini030709-02.dmp
file path: C:\WINDOWS\system32\drivers\mpfp.sys
product: McAfee Personal Firewall Plus
company: McAfee, Inc.
description: McAfee Personal Firewall Plus Driver
On Sat 07/03/2009 04:35:54 PM your computer crashed
Bugcheck code: 0x100000D1 (0xE1F2C000, 0x2, 0x0, 0xEE402D00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030709-01.dmp
On Fri 06/03/2009 10:50:22 PM your computer crashed
Bugcheck code: 0x100000D1 (0xE1ECD000, 0x2, 0x0, 0xEE82ED00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030609-02.dmp
On Fri 06/03/2009 10:39:47 PM your computer crashed
Bugcheck code: 0x100000D1 (0xE1EB6000, 0x2, 0x0, 0xEF26ED00)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini030609-01.dmp
On Wed 28/06/2006 04:59:13 PM your computer crashed
This was likely caused by the following module: dump_wmimmc.
Bugcheck code: 0x100000CE (0xEDDDFD2F, 0x0, 0xEDDDFD2F, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini062806-03.dmp
On Wed 28/06/2006 04:35:47 PM your computer crashed
Bugcheck code: 0x100000CE (0xEEC5FD2F, 0x0, 0xEEC5FD2F, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini062806-02.dmp
On Wed 28/06/2006 04:22:31 PM your computer crashed
Bugcheck code: 0x100000CE (0xEE678D2F, 0x0, 0xEE678D2F, 0x0)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini062806-01.dmp
On Sun 25/12/2005 02:41:33 PM your computer crashed
This was likely caused by the following module: ssrtln.sys
Bugcheck code: 0x100000D1 (0xF8136D9C, 0x2, 0x1, 0xF88B282F)
Error: Unknown
Dump file: C:\WINDOWS\Minidump\Mini122505-01.dmp
file path: C:\WINDOWS\system32\drivers\ssrtln.sys
company: Sonic Solutions
description: Shared Driver Component
Conclusion
13 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. nȯne it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
SilverSonata
Posts Posts : 53
Post by SilverSonata on 9th January 2010, 6:23 pm
I was just doing a scan on MBAM and the results were interesting;
Database version: 3527
Internet Explorer 7.0.5730.13
09/01/2010 01:20:29 PM
mbam-log-2010-01-09 (13-20-29).txt
Scan type: Full Scan (A:\|D:\|E:\|)
Objects scanned: 134139
Time elapsed: 7 minute(s), 42 second(s)
Registry Values Infected: 1
Files Infected: 1
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Desktop\General\wallpaper (Hijack.Wallpaper) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\warning.html (Trojan.FakeAlert) -> Quarantined and deleted successfully.
So that was the infection that covered my wallpaper? I should have scanned my A:\|D:\|E:\| Drives earlier. =/
SilverSonata
Posts Posts : 53
Post by Dr Jay on 9th January 2010, 11:40 pm
Must have been. We took care of it anyway, because we locked the keys, so you have control over the wallpaper only. At least you have wallpaper back.
Now let's find out what that driver is that keeps crashing a system file on your computer. Also, the culprit in those Found New Hardware popups.
Click the Settings button.
Set it to Maximum
Posts Posts : 13757
Post by SilverSonata on 10th January 2010, 6:25 am
Thank you very much for helping me. =)
SilverSonata
Posts Posts : 53
Post by Dr Jay on 10th January 2010, 10:20 am
The new hardware popup cannot be determined, because it is hard to tell what needs to be installed. In the GSI log, all I can see is an Unknown Device.
Your Windows Installer is not functioning properly. Do you know the version number of Windows Installer on your computer? It can be found in Add or Remove Programs (Control Panel).
Posts Posts : 13757
Post by SilverSonata on 10th January 2010, 4:52 pm
I'm sorry, but I'm having trouble finding out the number of my Windows Installer, what name is it under in the 'Add or Remove Programs' because I can't find it on the long list.
SilverSonata
Posts Posts : 53
Post by Dr Jay on 10th January 2010, 5:25 pm
No biggie. Big Grin
Posts Posts : 13757
Post by SilverSonata on 10th January 2010, 5:28 pm
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
McAfee SecurityCenter
Java(TM) 6 Update 5
Java 2 Runtime Environment, SE v1.4.2_03
Out of date Java installed!
Adobe Flash Player 10
Adobe Reader 8.1.2
Process Check:
objlist.exe by Laurent
McAfee VIRUSS~1 mcshield.exe
McAfee VIRUSS~1 mcsysmon.exe
DNS Vulnerability Check:
SilverSonata
Posts Posts : 53
Post by Dr Jay on 11th January 2010, 12:00 am
Lastly, see [You must be registered and logged in to see this link.] for more info about malware and prevention.
Posts Posts : 13757
Post by SilverSonata on 11th January 2010, 2:27 am
Thank you so very much for all the help and support you have given me.
SilverSonata
Posts Posts : 53
Post by SilverSonata on 11th January 2010, 2:49 am
When I read the article you suggested to me, I saw many free antiviruses that interested me.
Which antivirus would you suggest to me because my McAfee program is nearing it's expiration and I would like to consider all the posibilites. Should I wait for the expiration to come to a full end before I download these antiviruses?
Because I heard that having too many of them just causes them to clash with eachother.
Is there also a limit to the number of firewalls one can have on the computer?
Also, my father recently bought 'Webroot Internet Security Essentials 2010' is this program a antivirus with a firewall? It only came with the box and it's CD, and I browsed to check it's ratings, and they seem fine, but I would like to know your opinion if the Antiviruses and Firewall you suggest in the link are more effective than this program.
SilverSonata
Posts Posts : 53
Post by Dr Jay on 11th January 2010, 6:51 am
Webroot should be fine.
Only one firewall is necessary and will work.
Posts Posts : 13757
Post by SilverSonata on 12th January 2010, 2:14 am
I'm sorry to bother you again, but both 'Found New Hardware Wizard' and the 'Status' windows still appear at startup of my computer.
Is there any way to permenantly remove it?
SilverSonata
Posts Posts : 53
Post by Dr Jay on 12th January 2010, 3:24 am
As I said a little bit ago, it is not possible to find the root of the issue there, because I cannot tell from here the unknown device. If I knew the unknown device, it would be easier to configure it.
Posts Posts : 13757
Post by SilverSonata on 12th January 2010, 3:29 am
Ok, thank you very much for trying so hard to help me with all these problems. =)
SilverSonata
Posts Posts : 53
