IS2010 ongoing problems.
Post by elporco on Tue Jan 05, 2010 10:48 am
Several days ago it became clear i had a false AV program which would not allow me to connect to the web or launch any .exe programs. i had a small window after restarting the PC to launch a program this let me run MBAM which found several problems and seem to delete them without a problem. this then let me update and run AVG and MBAM again which returned no problems found. shortly after i notice my internet was having touble accesing certain sites (gmail, wikipedia etc) but others were fine. continued to run scans with mbam and AVG..mbam would find a trojan then report it clean and AVG would always say system was clean.
my internet now redirects to random shopping sites other search sites etc on nearly all attempts so its clear i had something else. i was told to try Microsoft security essentials isntead so i removed AVG and ran MSE it started to scan and immediatly found a severe threat it then stopped scanning and now refuses to turn on for longer than 5 seconds or so.
i was going to write this post with a hijack this report but any attempt to do a google search for hijack this redirects me to either a fake system scanner or some bogus shopping/search sites.
im currently running XP PRO SP3 and have 2x 200gb HDD's one for system one for software.
thanks for reading this and for any help i can get!!
elporco
Posts Posts : 31
Joined Joined : 2009-08-12
OS OS : XP PRO SP3
Protection Protection : MBAM, MSE & PC Tools+
Points Points : 27043
Re: IS2010 ongoing problems.
Post by Dr Jay on Tue Jan 05, 2010 11:18 am
Posts Posts : 13713
Points Points : 302059
Post by elporco on Tue Jan 05, 2010 11:41 am
here we go!!
ComboFix 10-01-04.01 - Stu 05/01/2010 11:26:39.1.2 - x86
Microsoft Windows XP Professional 5.1.2600.3.1252.44.1033.18.3327.2923 [GMT 0:00]
Running from: c:\documents and settings\Stu\desktop\commy.exe
c:\program files\InternetSecurity2010
c:\recycler\S-1-5-21-2863378544-2620313549-3492353547-500
c:\windows\system32\drivers\ohqeer.sys
c:\recycler\S-1-5-21-2863378544-2620313549-3492353547-500\desktop.ini
c:\recycler\S-1-5-21-2863378544-2620313549-3492353547-500\INFO2
C:\s
c:\windows\system32\15724.exe
c:\windows\system32\18467.exe
c:\windows\system32\19169.exe
c:\windows\system32\26500.exe
c:\windows\system32\6334.exe
c:\windows\system32\kbdsock.dll
c:\windows\system32\mshlps.dll
-------\Legacy_ohqeer
-------\Service_ohqeer
((((((((((((((((((((((((( Files Created from 2009-12-05 to 2010-01-05 )))))))))))))))))))))))))))))))
2010-01-03 18:56 . 2010-01-03 18:56 -------- d-----w- c:\documents and settings\Stu\Application Data\e frontier
2010-01-03 18:38 . 2010-01-03 18:38 691696 ----a-w- c:\windows\system32\drivers\sptd.sys
2010-01-03 18:37 . 2010-01-03 18:51 -------- d-----w- c:\documents and settings\Stu\Application Data\DAEMON Tools Lite
2010-01-03 18:37 . 2010-01-03 18:38 -------- d-----w- c:\documents and settings\All Users\Application Data\DAEMON Tools Lite
2010-01-03 18:15 . 2010-01-03 18:15 -------- d-----w- c:\documents and settings\Stu\Application Data\AdobeUM
2010-01-03 09:34 . 2010-01-03 12:18 -------- d-----w- c:\documents and settings\Stu\Local Settings\Application Data\yfpqrn
2010-01-02 22:44 . 2010-01-02 22:44 -------- d-----w- c:\program files\Common Files\Adobe AIR
2010-01-02 22:43 . 2010-01-02 22:43 -------- d-----w- c:\documents and settings\LocalService\Application Data\WTablet
2010-01-02 22:28 . 2010-01-02 22:33 -------- d-----w- c:\documents and settings\All Users\Application Data\FLEXnet
2010-01-02 22:27 . 2010-01-02 22:43 38784 ----a-w- c:\documents and settings\Stu\Application Data\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2010-01-02 22:21 . 2010-01-02 22:21 -------- d-----w- c:\program files\Adobe Media Player
2010-01-02 22:13 . 2010-01-02 22:13 -------- d-----w- c:\program files\Common Files\Macrovision Shared
2010-01-02 19:02 . 2010-01-02 19:02 -------- d-----w- c:\documents and settings\All Users\Application Data\Azureus
2010-01-02 19:02 . 2010-01-04 18:56 -------- d-----w- c:\documents and settings\Stu\Application Data\Azureus
2010-01-02 18:53 . 2010-01-02 18:53 -------- d-----w- c:\documents and settings\Stu\Application Data\.BitTornado
2010-01-02 12:17 . 2010-01-02 12:17 -------- d-----w- c:\documents and settings\Stu\Local Settings\Application Data\Identities
2009-12-25 07:44 . 2009-12-25 07:44 -------- d-----w- c:\documents and settings\Stu\Application Data\Ambient Design
2009-12-25 07:28 . 2010-01-05 11:34 -------- d-----w- c:\documents and settings\Stu\Application Data\WTablet
2009-12-25 07:28 . 2009-12-25 07:28 -------- d-----w- c:\documents and settings\Stu\Application Data\WTouch
2009-12-25 07:28 . 2009-07-15 16:13 220968 ------w- c:\windows\system32\Touch_Tablet.dll
2009-12-25 07:28 . 2009-12-25 07:28 -------- d-----w- c:\program files\WTouch
2009-12-25 07:27 . 2007-02-16 00:11 11440 ----a-w- c:\windows\system32\drivers\WacomVKHid.sys
2009-12-25 07:27 . 2007-02-16 19:12 11312 ----a-w- c:\windows\system32\drivers\wacommousefilter.sys
2009-12-25 07:27 . 2009-05-20 19:54 13736 ----a-w- c:\windows\system32\drivers\wacomvhid.sys
2009-12-25 07:27 . 2009-12-25 07:27 -------- d-----w- c:\windows\system32\WTablet
2009-12-25 07:27 . 2009-07-15 16:13 392488 ------w- c:\windows\system32\Pen_Tablet.dll
2009-12-25 07:27 . 2009-07-15 16:07 284672 ------w- c:\windows\system32\Wintab32.dll
2009-12-25 07:27 . 2009-07-15 16:13 4408616 ------w- c:\windows\system32\Pen_Tablet.exe
2009-12-25 07:27 . 2009-12-25 07:28 -------- d-----w- c:\program files\Tablet
2009-12-24 09:25 . 2010-01-02 22:17 -------- d-----w- c:\documents and settings\Stu\Local Settings\Application Data\Adobe
2009-12-23 23:26 . 2008-04-14 00:12 26624 ----a-w- c:\documents and settings\LocalService\Application Data\Microsoft\UPnP Device Host\upnphost\udhisapi.dll
2009-12-23 23:22 . 2009-12-23 23:22 -------- d-----w- c:\program files\Windows Media Connect 2
2009-12-23 23:21 . 2009-12-23 23:21 -------- d-----w- c:\windows\system32\drivers\UMDF
2009-12-23 19:04 . 2009-12-23 19:04 -------- d-----w- c:\program files\TeamSpeak 3 Client
2009-12-20 19:51 . 2009-12-20 19:52 -------- d-----w- c:\documents and settings\Stu\Application Data\Ventrilo
2009-12-20 13:30 . 2009-12-20 14:02 -------- d-----w- c:\documents and settings\Stu\Local Settings\Application Data\Deployment
2009-12-20 13:19 . 2009-12-20 13:19 -------- d-----r- C:\AHCache
2009-12-20 13:00 . 2009-12-20 13:00 -------- d-----w- c:\documents and settings\Stu\Application Data\CyberLink
2009-12-18 23:19 . 2009-12-18 23:19 -------- d-----w- c:\documents and settings\Stu\Local Settings\Application Data\Blizzard Entertainment
2009-12-18 21:37 . 2009-12-18 21:37 -------- d-----w- c:\documents and settings\All Users\Application Data\Blizzard Entertainment
2009-12-16 19:50 . 2009-12-23 23:21 -------- d-----w- c:\windows\system32\LogFiles
2009-12-15 23:00 . 2008-04-13 18:45 60032 ----a-w- c:\windows\system32\drivers\USBAUDIO.sys
2009-12-15 23:00 . 2008-04-13 18:45 60032 ----a-w- c:\windows\system32\dllcache\usbaudio.sys
2009-12-15 22:40 . 2009-12-15 22:40 -------- d-sh--w- c:\documents and settings\Administrator\IETldCache
2009-12-15 22:17 . 2009-12-15 22:17 -------- d-----w- c:\documents and settings\All Users\Application Data\Blizzard
2009-12-15 22:04 . 2009-12-15 22:04 -------- d-sh--w- c:\documents and settings\NetworkService\IETldCache
2009-12-15 21:59 . 2009-12-15 21:59 -------- d-----w- c:\documents and settings\LocalService\Local Settings\Application Data\nagasoft
2009-12-15 20:46 . 2008-04-13 18:45 26368 ----a-w- c:\windows\system32\dllcache\usbstor.sys
2009-12-15 20:45 . 2001-08-17 22:36 5632 ----a-w- c:\windows\system32\ptpusb.dll
2009-12-15 20:45 . 2008-04-13 18:45 15104 ----a-w- c:\windows\system32\drivers\usbscan.sys
2009-12-15 20:45 . 2008-04-13 18:45 15104 ----a-w- c:\windows\system32\dllcache\usbscan.sys
2009-12-15 20:45 . 2008-04-14 00:12 159232 ----a-w- c:\windows\system32\ptpusd.dll
2009-12-15 19:39 . 2009-12-15 19:39 -------- d-----w- c:\windows\system32\nagasoft
2009-12-15 19:32 . 2009-12-15 19:32 1956528 ----a-w- c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\install_flash_player_ax.exe
2009-12-15 19:32 . 2009-12-15 21:59 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
2009-12-15 07:15 . 2009-11-02 20:42 195456 ------w- c:\windows\system32\MpSigStub.exe
2009-12-15 07:15 . 2010-01-02 22:28 51816 ----a-w- c:\documents and settings\Stu\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-15 07:15 . 2009-12-15 07:15 -------- d-----w- c:\program files\Windows Defender
2009-12-15 07:11 . 2009-12-15 07:11 -------- d-sh--w- c:\documents and settings\Stu\PrivacIE
2009-12-15 03:16 . 2009-12-15 03:16 -------- d-sh--w- c:\documents and settings\Stu\IETldCache
2009-12-14 23:16 . 2009-10-29 07:45 12800 ------w- c:\windows\system32\dllcache\xpshims.dll
2009-12-14 23:16 . 2009-10-29 07:45 594432 ------w- c:\windows\system32\dllcache\msfeeds.dll
2009-12-14 23:16 . 2009-10-29 07:45 55296 ------w- c:\windows\system32\dllcache\msfeedsbs.dll
2009-12-14 23:16 . 2009-10-29 07:45 246272 ------w- c:\windows\system32\dllcache\ieproxy.dll
2009-12-14 23:16 . 2009-10-29 07:45 1985536 ------w- c:\windows\system32\dllcache\iertutil.dll
2009-12-14 23:16 . 2009-10-29 07:45 11069952 ------w- c:\windows\system32\dllcache\ieframe.dll
2009-12-14 23:16 . 2009-12-14 23:16 -------- d-----w- c:\windows\ie8updates
2009-12-14 23:15 . 2009-10-02 04:44 92160 ------w- c:\windows\system32\dllcache\iecompat.dll
2009-12-14 23:14 . 2009-12-14 23:15 -------- dc-h--w- c:\windows\ie8
2009-12-14 23:06 . 2010-01-05 11:33 -------- d-----w- c:\program files\Steam
2009-12-14 22:51 . 2009-12-14 22:51 -------- d-----w- c:\windows\system32\scripting
2009-12-14 22:51 . 2009-12-14 22:51 -------- d-----w- c:\windows\l2schemas
2009-12-14 22:51 . 2009-12-14 22:51 -------- d-----w- c:\windows\system32\en
2009-12-14 22:51 . 2009-12-14 22:51 -------- d-----w- c:\windows\system32\bits
2009-12-14 22:01 . 2009-12-16 23:58 -------- d-----w- c:\program files\Common Files\Blizzard Entertainment
2009-12-14 21:59 . 2009-12-14 21:59 -------- d-----w- C:\passwords
2009-12-14 20:35 . 2009-12-14 22:48 -------- d-----w- c:\windows\ServicePackFiles
2009-12-14 20:33 . 2009-12-14 20:33 -------- d-----w- c:\program files\MSXML 4.0
2009-12-14 20:27 . 2009-12-14 20:27 -------- d-----w- c:\program files\AVG
2009-12-14 20:25 . 2009-12-14 20:25 -------- d--h--w- c:\windows\I386
2009-12-14 20:23 . 2009-12-14 20:23 -------- d-----w- C:\PNP
2009-12-14 20:20 . 2005-01-06 11:09 206 ----a-w- c:\windows\myClean.bat
2009-12-14 20:15 . 2009-12-14 22:34 -------- d-----w- C:\DRIVERS
2009-12-14 20:15 . 2009-12-14 19:44 -------- d-----w- C:\DIVTOOLS
2009-12-14 20:13 . 2009-12-14 19:44 -------- d-----w- C:\APPS
2009-12-14 20:08 . 2009-12-14 20:07 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-12-14 20:07 . 2009-12-14 20:07 152576 ----a-w- c:\documents and settings\Stu\Application Data\Sun\Java\jre1.6.0_17\lzma.dll
2009-12-14 20:07 . 2009-12-14 20:07 79488 ----a-w- c:\documents and settings\Stu\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2009-12-14 20:06 . 2008-06-13 11:05 272128 ------w- c:\windows\system32\drivers\bthport.sys
2009-12-14 20:06 . 2008-06-13 11:05 272128 ------w- c:\windows\system32\dllcache\bthport.sys
2009-12-14 20:04 . 2009-06-21 21:44 153088 ------w- c:\windows\system32\dllcache\triedit.dll
2009-12-14 20:03 . 2008-05-08 14:02 203136 ------w- c:\windows\system32\dllcache\rmcast.sys
2009-12-14 20:03 . 2008-10-24 11:21 455296 ------w- c:\windows\system32\dllcache\mrxsmb.sys
2009-12-14 20:03 . 2008-12-11 10:57 333952 ------w- c:\windows\system32\dllcache\srv.sys
2009-12-14 20:03 . 2008-05-01 14:33 331776 ------w- c:\windows\system32\dllcache\msadce.dll
2009-12-14 20:02 . 2009-07-10 13:27 1315328 ------w- c:\windows\system32\dllcache\msoe.dll
2009-12-14 20:02 . 2009-12-15 07:13 -------- d-----w- C:\security
2009-12-14 20:02 . 2008-04-11 19:04 691712 ------w- c:\windows\system32\dllcache\inetcomm.dll
2009-12-14 20:01 . 2009-06-10 09:19 2066432 ------w- c:\windows\system32\dllcache\mstscax.dll
2009-12-14 20:00 . 2008-10-15 16:34 337408 ------w- c:\windows\system32\dllcache\netapi32.dll
2009-12-14 20:00 . 2009-07-31 04:35 1172480 ------w- c:\windows\system32\dllcache\msxml3.dll
2009-12-14 20:00 . 2008-05-03 11:55 2560 ------w- c:\windows\system32\xpsp4res.dll
2009-12-14 20:00 . 2008-04-21 12:08 215552 ------w- c:\windows\system32\dllcache\wordpad.exe
2009-12-14 19:58 . 2009-12-14 19:58 -------- d-sh--w- c:\documents and settings\Stu\UserData
2009-12-14 19:58 . 2008-04-14 00:12 221184 ----a-w- c:\windows\system32\wmpns.dll
2009-12-14 19:47 . 2010-01-05 11:34 -------- d-----w- c:\windows\system32\Lang
2009-12-14 19:46 . 2009-12-14 20:20 -------- d-----w- c:\documents and settings\All Users\Application Data\Network Associates
2009-12-14 19:46 . 2009-12-14 19:46 -------- d-----w- c:\program files\McAfee
2009-12-14 19:45 . 2009-12-14 19:46 -------- d-----w- c:\program files\Microsoft Works
2009-12-14 19:45 . 2009-12-14 19:45 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\PowerCinema
2009-12-14 19:45 . 2009-12-20 13:00 -------- d-----w- c:\documents and settings\All Users\Application Data\CyberLink
2009-12-14 19:43 . 2009-12-14 19:43 -------- d-----w- c:\documents and settings\All Users\Application Data\QuickTime
2009-12-14 19:42 . 2009-12-14 19:42 -------- d-----w- c:\program files\Common Files\SureThing Shared
2009-12-14 19:42 . 2009-12-14 19:42 -------- d-----w- c:\program files\Sonic
2009-12-14 19:38 . 2009-12-14 20:07 -------- d-----w- c:\program files\Java
2009-12-14 19:38 . 2009-12-14 19:38 -------- d-----w- c:\program files\Common Files\Java
2009-12-14 19:38 . 2009-12-14 19:38 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\{7148F0A6-6813-11D6-A77B-00B0D0142050}
2009-12-14 19:33 . 2009-12-14 19:33 -------- d-----w- c:\windows\nview
2009-12-14 19:33 . 2005-05-07 00:14 176128 ----a-w- c:\windows\system32\nvudisp.exe
2009-12-14 19:33 . 2005-05-07 01:28 176128 ----a-w- c:\windows\system32\NVUNINST.EXE
2009-12-14 19:33 . 2009-12-14 19:44 -------- d-----w- c:\program files\Common Files\InstallShield
2009-12-14 19:32 . 2009-12-14 19:32 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\ApplicationHistory
2009-12-14 19:31 . 2009-12-14 19:31 -------- d-----w- c:\windows\system32\URTTemp
2009-12-14 19:28 . 2008-04-14 00:11 7168 ----a-w- c:\windows\system32\hccoin.dll
2009-12-14 19:28 . 2008-04-13 18:45 30208 ----a-w- c:\windows\system32\drivers\usbehci.sys
2010-01-02 22:22 . 2009-12-14 19:44 -------- d-----w- c:\program files\Common Files\Adobe
2010-01-02 22:01 . 2010-01-02 22:01 5 ----a-w- c:\windows\system32\CoLe.tmp
2009-12-20 13:27 . 2009-12-20 13:27 -------- d-----w- c:\program files\MSBuild
2009-12-20 13:27 . 2009-12-20 13:27 -------- d-----w- c:\program files\Reference Assemblies
2009-12-14 22:54 . 2004-08-11 12:49 86327 ----a-w- c:\windows\pchealth\helpctr\OfflineCache\index.dat
2009-12-14 21:58 . 2009-12-14 19:43 -------- d-----w- c:\program files\Common Files\AOL
2009-12-14 21:58 . 2009-12-14 19:43 -------- d-----w- c:\documents and settings\All Users\Application Data\AOL
2009-12-14 20:12 . 2009-12-14 20:12 -------- d-----w- c:\documents and settings\Stu\Application Data\Malwarebytes
2009-12-14 20:12 . 2009-12-14 20:12 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-12-14 20:12 . 2009-12-14 20:12 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-12-14 20:12 . 2009-12-14 20:12 -------- d-----w- c:\program files\CCleaner
2009-12-14 19:44 . 2009-12-14 19:44 -------- d-----w- c:\program files\CyberLink
2009-12-14 19:44 . 2009-12-14 19:35 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-12-14 19:44 . 2009-12-14 19:57 -------- d-----w- c:\documents and settings\Stu\Application Data\You've Got Pictures Screensaver
2009-12-14 19:44 . 2009-12-14 19:44 -------- d-----w- c:\program files\Learn2.com
2009-12-14 19:44 . 2009-12-14 19:44 -------- d-----w- c:\documents and settings\Administrator\Application Data\You've Got Pictures Screensaver
2009-12-14 19:44 . 2009-12-14 19:44 -------- d-----w- c:\program files\Viewpoint
2009-12-14 19:44 . 2009-12-14 19:44 -------- d-----w- c:\documents and settings\All Users\Application Data\Viewpoint
2009-12-14 19:44 . 2009-12-14 19:43 -------- d-----w- c:\program files\QuickTime
2009-12-14 19:43 . 2009-12-14 19:43 -------- d-----w- c:\program files\Common Files\Nullsoft
2009-12-14 19:43 . 2009-12-14 19:43 8552 ----a-w- c:\windows\system32\drivers\asctrm.sys
2009-12-14 19:43 . 2009-12-14 19:43 -------- d-----w- c:\program files\Common Files\Real
2009-12-14 19:43 . 2009-12-14 19:43 -------- d-----w- c:\program files\Real
2009-12-14 19:43 . 2009-12-14 19:43 335 ----a-w- c:\windows\nsreg.dat
2009-12-14 19:35 . 2009-12-14 19:35 -------- d-----w- c:\program files\Realtek
2009-12-03 16:14 . 2009-12-14 20:12 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-03 16:13 . 2009-12-14 20:12 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-29 07:45 . 2004-08-11 12:29 916480 ----a-w- c:\windows\system32\wininet.dll
2009-10-21 05:38 . 2004-08-11 12:29 75776 ----a-w- c:\windows\system32\strmfilt.dll
2009-10-21 05:38 . 2004-08-11 12:28 25088 ----a-w- c:\windows\system32\httpapi.dll
2009-10-20 16:20 . 2004-08-03 23:00 265728 ----a-w- c:\windows\system32\drivers\http.sys
2009-10-13 10:30 . 2004-08-11 12:29 270336 ----a-w- c:\windows\system32\oakley.dll
2009-10-12 13:38 . 2004-08-11 12:29 149504 ----a-w- c:\windows\system32\rastls.dll
2009-10-12 13:38 . 2004-08-11 12:29 79872 ----a-w- c:\windows\system32\raschap.dll
"Steam"="c:\program files\Steam\Steam.exe" [2009-12-14 1217808]
"UserFaultCheck"="c:\windows\system32\dumprep 0 -u" [X]
"IMJPMIG8.1"="c:\windows\IME\imjp8_1\IMJPMIG.EXE" [2004-08-04 208952]
"PHIME2002ASync"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"PHIME2002A"="c:\windows\system32\IME\TINTLGNT\TINTSETP.EXE" [2004-08-04 455168]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2005-05-07 5562368]
"nwiz"="nwiz.exe" [2005-05-07 1495040]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2005-05-07 86016]
"High Definition Audio Property Page Shortcut"="HDAShCut.exe" [2005-01-07 61952]
"AzMixerSel"="c:\program files\Realtek\InstallShield\AzMixerSel.exe" [2005-06-08 57344]
"RTHDCPL"="RTHDCPL.EXE" [2005-06-29 14720000]
"PCMService"="c:\apps\Powercinema\PCMService.exe" [2005-01-28 110740]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2006-11-03 866584]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-12-14 98304]
"AdobeCS4ServiceManager"="c:\program files\Common Files\Adobe\CS4ServiceManager\CS4ServiceManager.exe" [2008-08-14 611712]
"CTFMON.EXE"="c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
"c:\\APPS\\Powercinema\\PowerCinema.exe"=
"c:\\Program Files\\Steam\\Steam.exe"=
"d:\\Program Files\\World of Warcraft\\Launcher.exe"=
"d:\\wow files for patching\\World of Warcraft\\WoW-3.1.3.9947-to-3.2.0.10192-enGB-downloader.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\left 4 dead 2\\left4dead2.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\left 4 dead\\left4dead.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\evil genius\\EvilGeniusLauncher.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\time gentlemen, please!\\TGP.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\time gentlemen, please!\\winsetup.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\ben there, dan that!\\BTDT.exe"=
"c:\\Program Files\\Steam\\steamapps\\common\\ben there, dan that!\\winsetup.exe"=
"c:\\Program Files\\Common Files\\Adobe\\CS4ServiceManager\\CS4ServiceManager.exe"=
"5353:TCP"= 5353:TCP:Adobe CSI CS4
R0 sptd;sptd;c:\windows\system32\drivers\sptd.sys [03/01/2010 18:38 691696]
R2 TabletServicePen;TabletServicePen;c:\windows\system32\Pen_Tablet.exe [25/12/2009 07:27 4408616]
R2 WinDefend;Windows Defender;c:\program files\Windows Defender\MsMpEng.exe [03/11/2006 19:19 13592]
R2 WTouchService;WTouch Service;c:\program files\WTouch\WTouchService.exe [25/12/2009 07:28 112936]
S0 eaecevi;eaecevi;c:\windows\system32\drivers\vaksst.sys --> c:\windows\system32\drivers\vaksst.sys [?]
vvdsvc REG_MULTI_SZ vvdsvc
2010-01-05 c:\windows\Tasks\MP Scheduled Scan.job
- c:\program files\Windows Defender\MpCmdRun.exe [2006-11-03 19:20]
IE: &AOL Toolbar search - c:\program files\AOL Toolbar\toolbar.dll/SEARCH.HTML
Rootkit scan 2010-01-05 11:34
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
Stealth MBR rootkit/Mebroot/Sinowal detector 0.3.7 by Gmer, [You must be registered and logged in to see this link.]
device: opened successfully
user: MBR read successfully
called modules: ntkrnlpa.exe CLASSPNP.SYS disk.sys ACPI.sys hal.dll atapi.sys spfc.sys >>UNKNOWN [0x8AFDE938]<<
kernel: MBR read successfully
detected MBR rootkit hooks:
\Driver\Disk -> CLASSPNP.SYS @ 0xba96cf28
\Driver\ACPI -> ACPI.sys @ 0xba674cb8
\Driver\atapi -> atapi.sys @ 0xba4e4b40
\Driver\iaStor -> iaStor.sys @ 0xba2c8b10
IoDeviceObjectType -> DeleteProcedure -> ntkrnlpa.exe @ 0x805836a8
ParseProcedure -> ntkrnlpa.exe @ 0x805827e8
\Device\Harddisk0\DR0 -> DeleteProcedure -> ntkrnlpa.exe @ 0x805836a8
NDIS: Realtek RTL8139 Family PCI Fast Ethernet NIC -> SendCompleteHandler -> NDIS.sys @ 0xba3bbbd4
PacketIndicateHandler -> NDIS.sys @ 0xba3c7a21
SendHandler -> NDIS.sys @ 0xba3bbd44
user & kernel MBR OK
malicious code @ sector 0x017499F03 !
PE file found in sector at 0x017499F19 !
- - - - - - - > 'winlogon.exe'(576)
c:\program files\Common Files\Adobe\Adobe Drive CS4\AdobeDriveCS4_NP.dll
- - - - - - - > 'explorer.exe'(556)
c:\program files\WTouch\WTouchUser.exe
c:\apps\Powercinema\Kernel\TV\CLCapSvc.exe
c:\apps\Powercinema\Kernel\TV\CLSched.exe
c:\program files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
c:\program files\CyberLink\Shared Files\CLML_NTService\CLMLService.exe
c:\windows\system32\RUNDLL32.EXE
c:\windows\RTHDCPL.EXE
c:\windows\system32\WTablet\Pen_TabletUser.exe
Completion time: 2010-01-05 11:38:40 - machine was rebooted
ComboFix-quarantined-files.txt 2010-01-05 11:38
Pre-Run: 166,685,929,472 bytes free
Post-Run: 166,657,769,472 bytes free
- - End Of File - - 8A0DD2DBB996F56B40DDA0D61FFB12DF
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Tue Jan 05, 2010 12:54 pm
Please download [You must be registered and logged in to see this link.], and save to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.zip, and extract the file to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.cmd to start.
  • It will finish quickly and launch a log.
  • Post the contents of it in your next reply.
Posts Posts : 13713
Post by elporco on Tue Jan 05, 2010 1:04 pm
Cheetah Anti-Rogue v1.0.22
by DragonMaster Jay
05/01/2010 13:03:47.82
-- Known infection --
If objects found, full virus scan or anti-malware scan necessary
EOF
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Tue Jan 05, 2010 1:42 pm
Posts Posts : 13713
Post by elporco on Tue Jan 05, 2010 2:39 pm
here is the MBAM log:
Malwarebytes' Anti-Malware 1.43
Database version: 3495
05/01/2010 14:37:44
mbam-log-2010-01-05 (14-37-44).txt
Objects scanned: 187489
Time elapsed: 33 minute(s), 24 second(s)
Files Infected: 3
C:\Qoobox\Quarantine\C\WINDOWS\system32\kbdsock.dll.vir (Spyware.Passwords) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\mshlps.dll.vir (Spyware.Passwords) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\drivers\ohqeer.sys.vir (Rootkit.Agent) -> Quarantined and deleted successfully.
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Tue Jan 05, 2010 8:13 pm
  • Click Start
  • Click Start
Posts Posts : 13713
Post by elporco on Tue Jan 05, 2010 9:48 pm
log file:
# version=7
# iexplore.exe=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# api_version=3.0.2
# EOSSerial=fff59a2792fae84eb03f3dd4a342ac47
# end=finished
# remove_checked=true
# archives_checked=false
# unwanted_checked=true
# unsafe_checked=false
# antistealth_checked=true
# utc_time=2010-01-05 09:47:08
# local_time=2010-01-05 09:47:08 (+0000, GMT Standard Time)
# country="United Kingdom"
# lang=1033
# compatibility_mode=1024 16777215 100 0 1907038 1907038 0 0
# compatibility_mode=6143 16777215 0 0 0 0 0 0
# compatibility_mode=8192 67108863 100 0 3843 3843 0 0
# scanned=107713
# found=0
# cleaned=0
# scan_time=2122
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Wed Jan 06, 2010 2:56 am
Click the Settings button.
Set it to Maximum
Posts Posts : 13713
Post by elporco on Wed Jan 06, 2010 6:33 pm
Sorry about the wait, been at work. Here is the URL
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Wed Jan 06, 2010 9:36 pm
Posts Posts : 13713
Post by elporco on Wed Jan 06, 2010 10:54 pm
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
ESET Online Scanner v3
WMIC entry does not exist for antivirus; attempting automatic update.
Windows Defender
CCleaner
Java(TM) 6 Update 17
Java 2 Runtime Environment, SE v1.4.2_05
Adobe Flash Player 10
Adobe Reader 7.0
Process Check:
objlist.exe by Laurent
Windows Defender MSMpEng.exe
DNS Vulnerability Check:
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Thu Jan 07, 2010 6:30 am
Software recommendations
Antivirus/Antispyware
  • [You must be registered and logged in to see this link.]: this is Microsoft's free antivirus/antispyware program. It equips you with protection against viruses, spyware, trojans, rootkits, and worms. It is also light on the computer's performance. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
  • [You must be registered and logged in to see this link.]: this is one of the most powerful, and easiest to use security software. The free version equips you with protection against viruses, spyware, trojans, rootkits, worms, and rogue software. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
Firewall
Note: Please keep ALL of these programs up-to-date and run them whenever you suspect a problem to prevent malware problems.
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 13713
Post by elporco on Thu Jan 07, 2010 7:32 pm
thanks for everything Jay, machine is running like a champ again and i have done all the updates as per above...and finally bit the bullet and made the move to Firefox...
fingers crossed this is the last time you hear from me...for all our sakes hehehe!!
elporco
Posts Posts : 31
OS OS : XP PRO SP3
Post by Dr Jay on Thu Jan 07, 2010 11:24 pm
Ok. Take care. Smile
Posts Posts : 13713
