Problem with some malware
Post by Twizx on 5th January 2010, 4:48 am
Or at least I think it's malware. About a week ago I received some sort malware that brought up alerts all the time and tried to make me buy some antivirus service. My friend checked around my computer and he told me that it happened to him to, he'd seen one of the files (winupdate86.exe) before and just looked on the internet for instructions on how to remove it, told me to do the same. I looked online and it gave me a list of files to delete, which I did, and then use a certain program to reverse the lock on task manager, which I did. Now I have a problem where whenever I start up, I cannot see my desktop. I simply have a black screen, and I can see the mouse pointer.
I am able to start task manager and open things, which is how I'm here posting this, but i have no desktop or taskbar at all. I believed the malware was still on my computer, so I happened upon geekpolice.net and used your instructions on how to remove it(these ones: [You must be registered and logged in to see this link.] but everytime I open Malwarebytes after downloading, it instantly closes, even in safe mode.
Many thanks for reading, and any help or advice would be much appreciated.
Twizx
Posts Posts : 3
Joined Joined : 2010-01-05
OS OS : Windows Vista
Points Points : 25353
Re: Problem with some malware
Post by Dr Jay on 5th January 2010, 11:16 am
Posts Posts : 14317
Points Points : 303008
Post by Twizx on 9th January 2010, 11:22 pm
ComboFix 10-01-04.01 - Family 01/09/2010 16:52:14.1.2 - x86 NETWORK
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.1.1033.18.1982.1376 [GMT -6:00]
Running from: c:\users\Family\Desktop\Commy.exe.exe
AV: Norton Internet Security *On-access scanning disabled* (Outdated) {E10A9785-9598-4754-B552-92431C1C35F8}
FW: Norton Internet Security *enabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
SP: Norton Internet Security *enabled* (Outdated) {CBB7EE13-8244-4DAB-8B55-D5C7AA91E59A}
SP: Windows Defender *disabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
c:\$recycle.bin\S-1-5-21-3345150982-3443402610-4142067651-500
C:\desktop.ini
C:\install.exe
c:\program files\Mozilla Firefox\searchplugins\search.xml
c:\program files\Web Technologies
c:\program files\Web Technologies\myd.ico
c:\program files\Web Technologies\mym.ico
c:\program files\Web Technologies\myp.ico
c:\program files\Web Technologies\myv.ico
c:\program files\Web Technologies\ot.ico
c:\program files\Web Technologies\ts.ico
c:\programdata\2ACA5CC3-0F83-453D-A079-1076FE1A8B65
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Reset Cursor.lnk
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Zango Customer Support Center.lnk
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Zango Games!.lnk
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Zango Library.lnk
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Zango Screensavers!.lnk
c:\programdata\Microsoft\Windows\Start Menu\Programs\Zango\Zango Videos!.lnk
c:\programdata\ZangoSA
c:\programdata\ZangoSA\ZangoSA.dat
c:\programdata\ZangoSA\ZangoSA_kyf.dat
c:\programdata\ZangoSA\ZangoSAAbout.mht
c:\programdata\ZangoSA\ZangoSAau.dat
c:\programdata\ZangoSA\ZangoSAEula.mht
c:\users\Family\AppData\Roaming\WeatherDPA
c:\users\Family\AppData\Roaming\WeatherDPA\Weather\WeatherStartup.xml
c:\users\Family\AppData\Roaming\Zango
c:\users\Family\Documents\My Documents.url
c:\users\Family\FAVORI~1\setup.exe
c:\users\Family\Favorites\setup.exe
c:\windows\system32\11478.exe
c:\windows\system32\15724.exe
c:\windows\system32\16827.exe
c:\windows\system32\18467.exe
c:\windows\system32\19169.exe
c:\windows\system32\219725
c:\windows\system32\23281.exe
c:\windows\system32\24464.exe
c:\windows\system32\26500.exe
c:\windows\system32\26962.exe
c:\windows\system32\28145.exe
c:\windows\system32\29358.exe
c:\windows\system32\2995.exe
c:\windows\system32\41.exe
c:\windows\system32\491.exe
c:\windows\system32\5705.exe
c:\windows\system32\6334.exe
c:\windows\system32\9961.exe
c:\windows\system32\AVR10.exe
c:\windows\system32\gedesumi.dll
c:\windows\system32\jekatuji.dll
c:\windows\system32\lonafaze.dll
c:\windows\system32\masoyumu.dll
c:\windows\system32\wakepule.dll
c:\windows\system32\winhelper86.dll
((((((((((((((((((((((((( Files Created from 2009-12-09 to 2010-01-09 )))))))))))))))))))))))))))))))
2010-01-09 23:03 . 2010-01-09 23:10 -------- d-----w- c:\users\Family\AppData\Local\temp
2010-01-09 23:03 . 2010-01-09 23:03 -------- d-----w- c:\users\Default\AppData\Local\temp
2010-01-09 22:36 . 2010-01-09 22:37 -------- d-----w- c:\windows\system32\config\systemprofile\AppData\Roaming\Orbit
2010-01-05 04:07 . 2010-01-05 04:07 -------- d-----w- c:\users\Family\AppData\Roaming\Malwarebytes
2010-01-05 04:06 . 2009-12-30 20:55 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2010-01-05 04:06 . 2010-01-09 22:42 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2010-01-05 04:06 . 2010-01-05 04:06 -------- d-----w- c:\programdata\Malwarebytes
2010-01-05 04:06 . 2009-12-30 20:54 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2010-01-05 03:50 . 2010-01-05 03:50 -------- d-----w- c:\programdata\ZA_PreservedFiles
2009-12-25 22:30 . 2009-12-25 22:30 -------- d-----w- c:\windows\XSxS
2009-12-25 22:30 . 2009-12-25 22:30 -------- d-----w- c:\users\Family\AppData\Local\Re-Enable v2
2009-12-25 22:30 . 2009-12-25 22:30 -------- d-----w- c:\program files\Xenocode
2009-12-24 23:04 . 2009-12-24 23:04 22 ----a-w- c:\windows\system32\winzipper.zip
2009-12-24 21:53 . 2010-01-05 03:50 -------- d-----w- c:\users\Family\AppData\Roaming\CheckPoint
2009-12-24 21:53 . 2010-01-05 03:51 -------- d-----w- c:\program files\CheckPoint
2009-12-24 21:51 . 2009-12-24 21:51 -------- d-----w- c:\programdata\CheckPoint
2010-01-09 23:12 . 2007-08-21 19:16 -------- d-----w- c:\program files\Steam
2010-01-09 23:10 . 2008-12-07 23:43 -------- d-----w- c:\users\Family\AppData\Roaming\Software Informer
2010-01-09 23:10 . 2007-08-31 08:17 -------- d-----w- c:\users\Family\AppData\Roaming\OpenOffice.org2
2010-01-09 23:09 . 2009-01-09 04:26 -------- d-----w- c:\users\Family\AppData\Roaming\Orbit
2010-01-09 05:07 . 2009-05-11 20:29 1356 ----a-w- c:\users\Family\AppData\Local\d3d9caps.dat
2010-01-05 20:06 . 2010-01-05 20:06 658184 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2010-01-05 03:24 . 2008-07-20 18:29 -------- d-----w- c:\users\Family\AppData\Roaming\Spyware Terminator
2009-12-24 23:02 . 2008-07-20 18:29 -------- d-----w- c:\program files\Spyware Terminator
2009-12-24 21:28 . 2008-07-20 18:29 -------- d-----w- c:\programdata\Spyware Terminator
2009-12-16 22:14 . 2008-04-19 01:37 -------- d-----w- c:\users\Family\AppData\Roaming\Audacity
2009-12-10 02:25 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2009-12-07 20:54 . 2009-06-10 19:12 56816 ----a-w- c:\windows\system32\drivers\avgntflt.sys
2009-11-21 21:39 . 2007-08-18 07:31 -------- d-----w- c:\program files\Soulseek
2009-11-21 06:40 . 2009-12-09 16:48 916480 ----a-w- c:\windows\system32\wininet.dll
2009-11-21 06:34 . 2009-12-09 16:48 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-11-21 06:34 . 2009-12-09 16:48 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-11-21 04:59 . 2009-12-09 16:48 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-11-12 00:21 . 2009-11-12 00:21 -------- d-----w- c:\users\Family\AppData\Roaming\TeamViewer
2009-11-09 13:22 . 2009-12-10 02:07 24064 ----a-w- c:\windows\system32\nshhttp.dll
2009-11-09 13:20 . 2009-12-10 02:06 31232 ----a-w- c:\windows\system32\httpapi.dll
2009-11-09 11:04 . 2009-12-10 02:06 411136 ----a-w- c:\windows\system32\drivers\http.sys
2009-10-29 09:41 . 2009-11-26 02:05 2048 ----a-w- c:\windows\system32\tzres.dll
2009-05-01 21:02 . 2009-05-01 21:02 1044480 ----a-w- c:\program files\mozilla firefox\plugins\libdivx.dll
2009-05-01 21:02 . 2009-05-01 21:02 200704 ----a-w- c:\program files\mozilla firefox\plugins\ssldivx.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\bekoduya.dll
1601-01-01 00:03 . 1601-01-01 00:03 94208 --sha-w- c:\windows\System32\bupudofa.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\duduhahi.dll
1601-01-01 00:03 . 1601-01-01 00:03 93696 --sha-w- c:\windows\System32\dufisuzu.dll
1601-01-01 00:03 . 1601-01-01 00:03 93184 --sha-w- c:\windows\System32\dupejume.dll
1601-01-01 00:03 . 1601-01-01 00:03 93184 --sha-w- c:\windows\System32\fiyamepe.dll
1601-01-01 00:03 . 1601-01-01 00:03 61952 --sha-w- c:\windows\System32\gobewowi.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\gumiviho.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\hodaluho.dll
1601-01-01 00:03 . 1601-01-01 00:03 92672 --sha-w- c:\windows\System32\jehofoku.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\jileyemu.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\jopumeti.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\kivifivu.dll
1601-01-01 00:03 . 1601-01-01 00:03 93184 --sha-w- c:\windows\System32\ludotoja.dll
1601-01-01 00:03 . 1601-01-01 00:03 93184 --sha-w- c:\windows\System32\numuligi.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\pivojobe.dll
1601-01-01 00:03 . 1601-01-01 00:03 61440 --sha-w- c:\windows\System32\popiwoba.dll
1601-01-01 00:03 . 1601-01-01 00:03 61952 --sha-w- c:\windows\System32\reriviji.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\ronigofu.dll
1601-01-01 00:03 . 1601-01-01 00:03 39424 --sha-w- c:\windows\System32\tayijobu.dll
1601-01-01 00:03 . 1601-01-01 00:03 93696 --sha-w- c:\windows\System32\valopawi.dll
1601-01-01 00:03 . 1601-01-01 00:03 93696 --sha-w- c:\windows\System32\vawinaso.dll
1601-01-01 00:03 . 1601-01-01 00:03 93184 --sha-w- c:\windows\System32\wegagolu.dll
2007-08-16 08:05 . 2007-08-16 08:05 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
"WindowsWelcomeCenter"="oobefldr.dll" [2008-01-19 2153472]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-08-17 68856]
"MsnMsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-07-26 3883856]
"CTSyncU.exe"="c:\program files\Creative\Sync Manager Unicode\CTSyncU.exe" [2006-08-07 700416]
"Steam"="c:\program files\Steam\Steam.exe" [2009-10-27 1217808]
"Google Update"="c:\users\Family\AppData\Local\Google\Update\GoogleUpdate.exe" [2008-09-07 133104]
"Software Informer"="c:\program files\Software Informer\softinfo.exe" [2009-09-17 1933381]
"VeohPlugin"="c:\program files\Veoh Networks\VeohWebPlayer\veohwebplayer.exe" [2009-04-03 3558648]
"Messenger (Yahoo!)"="c:\program files\Yahoo!\Messenger\YahooMessenger.exe" [2009-05-27 4351216]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2008-01-19 202240]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-19 1008184]
"RtHDVCpl"="RtHDVCpl.exe" [2007-03-15 4390912]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-10-03 81920]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2007-01-10 115816]
"osCheck"="c:\program files\Norton Internet Security\osCheck.exe" [2006-12-03 22696]
"ECenter"="c:\dell\E-Center\EULALauncher.exe" [2007-03-16 17920]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2007-11-29 583048]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-05-03 13535776]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-05-03 92704]
"avgnt"="c:\program files\Avira\AntiVir Desktop\avgnt.exe" [2009-03-02 209153]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-08-11 149280]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-05-26 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-07-13 292128]
c:\users\Family\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
OpenOffice.org 2.2.lnk - c:\program files\OpenOffice.org 2.2\program\quickstart.exe [2007-2-2 393216]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-9-23 29696]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2007-8-15 50688]
Orbit.lnk - c:\program files\Orbitdownloader\orbitdm.exe [2009-1-8 1711304]
"EnableLUA"= 0 (0x0)
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"NoSearchFilesInStartMenu"= 0 (0x0)
"NoSearchProgramsInStartMenu"= 0 (0x0)
"NoSearchComputerLinkInStartMenu"= 0 (0x0)
"aux"=wdmaud.drv
"UacDisableNotify"=dword:00000001
"InternetSettingsDisableNotify"=dword:00000001
"AutoUpdateDisableNotify"=dword:00000001
R1 IDSvix86;Symantec Intrusion Prevention Driver;c:\progra~2\Symantec\DEFINI~1\SymcData\idsdefs\20070912.001\IDSvix86.sys [9/14/2007 5:29 PM 180272]
R1 sp_rsdrv2;Spyware Terminator Driver 2;c:\windows\System32\drivers\sp_rsdrv2.sys [7/20/2008 12:29 PM 141312]
R2 AntiVirSchedulerService;Avira AntiVir Scheduler;c:\program files\Avira\AntiVir Desktop\sched.exe [6/10/2009 1:11 PM 108289]
R3 SYMNDISV;SYMNDISV;c:\windows\System32\drivers\symndisv.sys [12/3/2006 5:26 PM 37008]
*NewlyCreated* - COMHOST
2010-01-08 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3345150982-3443402610-4142067651-1000Core.job
- c:\users\Family\AppData\Local\Google\Update\GoogleUpdate.exe [2008-09-07 16:31]
2010-01-09 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3345150982-3443402610-4142067651-1000UA.job
2010-01-09 c:\windows\Tasks\Norton Internet Security - Run Full System Scan - Family.job
- c:\progra~1\NORTON~1\NORTON~1\Navw32.exe [2006-12-03 23:23]
uStart Page = ABOUT:BLANK
mSearchMigratedDefaultURL = [You must be registered and logged in to see this link.]
mSearchURL = [You must be registered and logged in to see this link.]
IE: &Download by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/201
IE: &Grab video by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/204
IE: Do&wnload selected by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/203
IE: Down&load all by Orbit - c:\program files\Orbitdownloader\orbitmxt.dll/202
FF - ProfilePath - c:\users\Family\AppData\Roaming\Mozilla\Firefox\Profiles\jgfe6k72.default\
FF - plugin: c:\program files\Mozilla Firefox\plugins\npGoogleGadgetPluginFirefoxWin.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\NPTURNMED.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
FF - plugin: c:\program files\Windows Live\Photo Gallery\NPWLPG.dll
FF - plugin: c:\users\Family\AppData\Local\Google\Update\1.2.183.13\npGoogleOneClick8.dll
---- FIREFOX POLICIES ----
BHO-{3d7b4082-5428-468d-b4d9-396bad4bbe53} - wakepule.dll
HKCU-Run-fsm - (no file)
HKLM-Run-mojeyuwav - c:\windows\system32\gedesumi.dll
HKLM-Run-ISW - c:\program files\CheckPoint\ZAForceField\ForceField.exe
HKLM-Run-zevadiyuje - lonafaze.dll
SharedTaskScheduler-{663e814e-7e8c-4b42-9fd6-704be231c287} - c:\windows\system32\gedesumi.dll
SSODL-malugovis-{663e814e-7e8c-4b42-9fd6-704be231c287} - c:\windows\system32\gedesumi.dll
Rootkit scan 2010-01-09 17:07
Windows 6.0.6001 Service Pack 1 NTFS
scanning hȋdden processes ...
scanning hȋdden files ...
c:\users\Family\AppData\Roaming\Microsoft\Windows Live Call\Logs\msncalllog0.txt 882 bytes
c:\users\Family\AppData\Roaming\Microsoft\Windows Live Call\Logs\msncalllog1.txt 466 bytes
hȋdden files: 2
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0002\AllUserSettings]
- - - - - - - > 'Explorer.exe'(4444)
c:\program files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
c:\program files\SmartPopupBlocker\PopupBlockerBHO.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\SHCTMTP.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\AVSrcU.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\CTIntrfu.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\CTConfig.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\CtMtpRc.dll
c:\program files\Creative\Creative ZEN V Series (R2)\ZEN V Series Media Explorer\PicRc.dll
c:\windows\system32\nvvsvc.exe
c:\program files\Common Files\Symantec Shared\ccSvcHst.exe
c:\program files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
c:\program files\Avira\AntiVir Desktop\avguard.exe
c:\program files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
c:\windows\system32\CTsvcCDA.exe
c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
c:\program files\Spyware Terminator\sp_rsser.exe
c:\windows\system32\DRIVERS\xaudio.exe
c:\windows\RtHDVCpl.exe
c:\windows\System32\rundll32.exe
c:\windows\ehome\ehmsas.exe
c:\program files\OpenOffice.org 2.2\program\soffice.exe
c:\program files\Orbitdownloader\orbitnet.exe
c:\program files\OpenOffice.org 2.2\program\soffice.BIN
c:\program files\Yahoo!\Messenger\ymsgr_tray.exe
c:\program files\Windows Live\Contacts\wlcomm.exe
c:\program files\Windows Live\Messenger\wlcsdk.exe
c:\program files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
c:\windows\system32\vssvc.exe
c:\windows\servicing\TrustedInstaller.exe
c:\windows\system32\msiexec.exe
Completion time: 2010-01-09 17:19:26 - machine was rebooted
ComboFix-quarantined-files.txt 2010-01-09 23:19
Pre-Run: 128,041,283,584 bytes free
Post-Run: 130,297,679,872 bytes free
- - End Of File - - 257509141E3259696E0FAB091F3C0250
Twizx
Posts Posts : 3
Post by Twizx on 9th January 2010, 11:23 pm
Oh, and my desktop is now visible, which is nice. Big Grin
Twizx
Posts Posts : 3
Post by Dr Jay on 9th January 2010, 11:43 pm
Posts Posts : 14317
