power supply green light flashing
Post by magician on Mon 04 Jan 2010, 4:12 pm
HP Computer has a green flashing light on the power supply. I have reserched this and found that while the power supply is connected to an outlet. unplug the 20 pin power connection to the mainboard the power supply light will stay solid reconnecting the 20 pin back tothemain board will alow it to boot into the operating system
However after shutting down the PC I have to perform the same tasksas mentioned above. is there a perminant fix to this problem. I also installed a new compatable power supply and had the same results.
Operating System : XP
