Starting problem
Starting problem
Post by TECHMAN22 on Sun Jan 03, 2010 8:37 pm
[b]Hello can anyone point me to a fix. I have a dell computer and using windows xp home got a virus of somekind. It will boot up and main screen loads but it will not lunch any programs comes up with a dll fail message. Also add and remove programs will not work either. Also restore do not take. Where should start. Thanks :sad:
TECHMAN22
Joined Joined : 2010-01-03
OS OS : xp pro
Points Points : 25293
Re: Starting problem
Post by Belahzur on Sun Jan 03, 2010 9:24 pm
Points Points : 245069
