Win32/Nuqel.E and BankerFox.A removal need help please
Post by butchieboss on Wed Dec 30, 2009 6:17 am
My laptop is not working right, I have a virus. I cannot connect to the internet using internet explorer, but I can connect using Firefox. I cannot run any apps, have pop ups, computer is freezing. I downloaded Avenger, but it will not let me run it. It says it's infected and cannot be ran. If I try to open any other programs like add/remove it says the same thing. Do not know what to do. PLEASE HELP!!!
butchieboss
Posts Posts : 7
Joined Joined : 2009-12-30
Points Points : 25423
Re: Win32/Nuqel.E and BankerFox.A removal need help please
Post by Dr Jay on Wed Dec 30, 2009 6:27 am
Posts Posts : 13717
Points Points : 302127
Post by butchieboss on Thu Dec 31, 2009 1:23 am
ComboFix 09-12-29.06 - davi2807 12/30/2009 19:54:34.1.2 - x86 NETWORK
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1014.670 [GMT -5:00]
Running from: c:\documents and settings\davi2807\Desktop\commy.exe
AV: AVG Anti-Virus Network Edition *On-access scanning enabled* (Outdated) {17DDD097-36FF-435F-9E1B-52D74245D6BF}
c:\documents and settings\davi2807\Local Settings\Application Data\fouqxu
c:\documents and settings\davi2807\Local Settings\Application Data\fouqxu\egeesysguard.exe
c:\recycler\S-1-5-21-1453792206-2000060499-842820122-500
c:\recycler\S-1-5-21-2388196101-4162543526-2493488983-500
c:\recycler\S-1-5-21-3652250942-741021395-2200178515-500
c:\recycler\S-1-5-21-3726039340-1955672276-3039341588-500
c:\recycler\S-1-5-21-4240074935-2429360420-984205450-500
c:\recycler\S-1-5-21-4282068166-3347816414-3832364116-500
c:\recycler\S-1-5-21-909447240-978035807-2044221565-500
c:\windows\system32\Thumbs.db
D:\Autorun.inf
((((((((((((((((((((((((( Files Created from 2009-11-28 to 2009-12-31 )))))))))))))))))))))))))))))))
2009-12-29 05:20 . 2009-12-29 05:20 -------- d-----w- c:\documents and settings\All Users\Application Data\GameHouse
2009-12-17 22:01 . 2009-12-17 22:01 -------- d-----w- c:\documents and settings\davi2807\Local Settings\Application Data\Temp
2009-12-10 18:58 . 2009-12-21 16:03 2066200 ----a-w- c:\documents and settings\All Users\Application Data\avg8\update\backup\avgcorex.dll
2009-12-06 02:21 . 2009-12-06 02:21 -------- d-----w- c:\program files\Graboid
2009-12-04 14:19 . 2009-12-04 14:19 -------- d-----w- c:\program files\Microsoft CAPICOM 2.1.0.2
2009-12-04 14:18 . 2009-12-04 14:18 -------- d-sh--w- c:\documents and settings\NetworkService\IETldCache
2009-12-04 14:09 . 2009-12-04 14:09 -------- d-sh--w- c:\documents and settings\Default User\IETldCache
2009-12-03 17:17 . 2009-06-21 21:44 153088 -c----w- c:\windows\system32\dllcache\triedit.dll
2009-12-03 17:15 . 2009-10-29 07:45 12800 -c----w- c:\windows\system32\dllcache\xpshims.dll
2009-12-03 17:15 . 2009-10-29 07:45 246272 -c----w- c:\windows\system32\dllcache\ieproxy.dll
2009-12-03 16:57 . 2009-07-10 13:27 1315328 -c----w- c:\windows\system32\dllcache\msoe.dll
2009-12-03 15:14 . 2009-08-07 00:23 215920 ----a-w- c:\windows\system32\muweb.dll
2009-12-03 15:14 . 2009-08-07 00:23 274288 ----a-w- c:\windows\system32\mucltui.dll
2009-12-31 00:30 . 2008-08-12 18:35 17408 ----a-w- c:\windows\system32\rpcnetp.exe
2009-12-31 00:28 . 2009-02-26 16:57 12 ----a-w- c:\windows\bthservsdp.dat
2009-12-31 00:07 . 2008-08-12 18:51 56680 ----a-w- c:\windows\system32\rpcnet.dll
2009-12-31 00:07 . 2008-08-12 18:45 17408 ----a-w- c:\windows\system32\rpcnetp.dll
2009-12-30 04:14 . 2009-09-19 15:40 70016 ----a-w- c:\documents and settings\davi2807\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-12-30 04:03 . 2008-08-12 19:11 -------- d-----w- c:\documents and settings\All Users\Application Data\avg8
2009-12-30 00:36 . 2009-11-28 17:16 79488 ----a-w- c:\documents and settings\davi2807\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
2009-12-29 05:57 . 2009-11-27 21:46 -------- d-----w- c:\program files\RealArcade
2009-12-09 14:47 . 2008-08-12 18:52 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-12-04 20:14 . 2008-08-12 18:54 -------- d-----w- c:\program files\Microsoft Works
2009-11-27 22:10 . 2009-11-27 22:10 -------- d-----w- c:\documents and settings\davi2807\Application Data\ElementalsTheMagicKey
2009-11-27 21:54 . 2009-11-27 21:54 -------- d-----w- c:\documents and settings\davi2807\Application Data\PlayFirst
2009-11-27 21:54 . 2009-11-27 21:54 -------- d-----w- c:\documents and settings\All Users\Application Data\PlayFirst
2009-11-27 21:53 . 2009-11-27 21:53 -------- d-----w- c:\documents and settings\All Users\Application Data\Trymedia
2009-11-27 21:53 . 2008-08-12 18:40 -------- d-----w- c:\program files\Google
2009-11-22 23:13 . 2009-11-22 23:13 -------- d-----w- c:\program files\Unity
2009-11-15 20:50 . 2009-11-15 20:50 -------- d-----w- c:\program files\DivX
2009-11-15 20:50 . 2009-11-15 20:50 -------- d-----w- c:\program files\Common Files\DivX Shared
2009-11-11 22:10 . 2009-09-08 19:40 -------- d-----w- c:\program files\SaversPlanet
2009-10-29 07:45 . 2006-06-22 21:07 916480 ----a-w- c:\windows\system32\wininet.dll
2009-10-21 16:45 . 2008-10-10 14:57 33792 ----a-w- c:\windows\system32\identprv.dll
2009-10-21 05:38 . 2006-06-22 21:06 75776 ----a-w- c:\windows\system32\strmfilt.dll
2009-10-21 05:38 . 2006-06-22 21:06 25088 ----a-w- c:\windows\system32\httpapi.dll
2009-10-20 16:20 . 2004-08-04 06:00 265728 ----a-w- c:\windows\system32\drivers\http.sys
2009-10-13 10:30 . 2006-06-22 21:06 270336 ----a-w- c:\windows\system32\oakley.dll
2009-10-12 13:38 . 2006-06-22 21:06 149504 ----a-w- c:\windows\system32\rastls.dll
2009-10-12 13:38 . 2006-06-22 21:06 79872 ----a-w- c:\windows\system32\raschap.dll
2009-05-01 21:02 . 2009-05-01 21:02 1044480 ----a-w- c:\program files\mozilla firefox\plugins\libdivx.dll
2009-05-01 21:02 . 2009-05-01 21:02 200704 ----a-w- c:\program files\mozilla firefox\plugins\ssldivx.dll
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\URLSearchHooks]
"{d930602d-a752-4287-828b-ef0b1f48825c}"= "c:\program files\SaversPlanet\tbSav1.dll" [2009-11-11 2166296]
[HKEY_CLASSES_ROOT\clsid\{d930602d-a752-4287-828b-ef0b1f48825c}]
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{d930602d-a752-4287-828b-ef0b1f48825c}]
2009-11-11 22:10 2166296 ----a-w- c:\program files\SaversPlanet\tbSav1.dll
"{D930602D-A752-4287-828B-EF0B1F48825C}"= "c:\program files\SaversPlanet\tbSav1.dll" [2009-11-11 2166296]
"Power2GoExpress"="NA" [X]
"TabletWizard"="c:\windows\help\SplshWrp.exe" [2008-04-14 16384]
"TabletTip"="c:\program files\Common Files\microsoft shared\ink\tabtip.exe" [2008-04-14 271872]
"Snippet"="c:\program files\Microsoft Experience Pack\Snipping Tool\SnippingTool.exe" [2005-02-26 68296]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2005-01-12 32768]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2007-01-05 827392]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-04-04 138008]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-04-04 162584]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-04-04 138008]
"AGRSMMSG"="AGRSMMSG.exe" [2006-08-30 89542]
"Recguard"="c:\windows\SMINST\RECGUARD.EXE" [2002-09-14 212992]
"AVG8_TRAY"="c:\progra~1\AVG\AVG8\avgtray.exe" [2009-12-10 2043160]
"BluetoothAuthenticationAgent"="bthprops.cpl" [2008-04-14 110592]
"Ad-Watch"="c:\program files\Lavasoft\Ad-Aware\AAWTray.exe" [2009-05-27 518488]
"Synchronization Manager"="c:\windows\system32\mobsync.exe" [2008-04-14 143360]
1-Click Answers.lnk - c:\program files\1-Click Answers\answers.exe [2008-11-26 806912]
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\system]
"HideLogonscripts"= 1 (0x1)
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
"DisablePersonalDirChange"= 1 (0x1)
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\avgrsstarter]
2009-09-03 19:27 11952 ----a-w- c:\windows\system32\avgrsstx.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\loginkey]
2008-04-14 00:11 47104 ----a-w- c:\program files\Common Files\Microsoft Shared\Ink\loginkey.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\TabBtnWL]
2002-08-29 17:41 11776 ----a-w- c:\windows\system32\tabbtnwl.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\tpgwlnotify]
2008-04-14 00:12 32256 ----a-w- c:\windows\system32\tpgwlnot.dll
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\group policy\state\S-1-5-21-932917755-891632697-413896786-7379\scripts\Logon\0\0]
"script"=\\CRBC\SysVol\CRBC\Policies\{F9B93C00-7C81-49DC-AA28-CCD2129785B0}\User\scripts\Logon\NewJStudentHomeDirectory.bat
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Lavasoft Ad-Aware Service]
"c:\\Program Files\\AVG\\AVG8\\avgemc.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgupd.exe"=
"c:\\Program Files\\AVG\\AVG8\\avgnsx.exe"=
R0 AvgRkx86;avgrkx86.sys;c:\windows\system32\drivers\avgrkx86.sys [8/12/2008 2:11 PM 12552]
R0 Lbd;Lbd;c:\windows\system32\drivers\Lbd.sys [2/26/2009 12:18 PM 64160]
R1 AvgTdiX;AVG8 Network Redirector;c:\windows\system32\drivers\avgtdix.sys [8/12/2008 2:11 PM 108552]
R2 Lavasoft Ad-Aware Service;Lavasoft Ad-Aware Service;c:\program files\Lavasoft\Ad-Aware\AAWService.exe [1/18/2009 4:34 PM 1005904]
R3 MSTabBtn;Quanta Computer Tablet PC Buttons HID Driver;c:\windows\system32\drivers\mstabbtn.sys [8/12/2008 1:24 PM 10496]
R3 WacomPen;Wacom Serial Pen HID Driver;c:\windows\system32\drivers\wacompen.sys [8/12/2008 1:37 PM 14208]
S1 AvgLdx86;AVG AVI Loader Driver x86;c:\windows\system32\drivers\avgldx86.sys [8/12/2008 2:11 PM 335240]
S2 avg8emc;AVG8 E-mail Scanner;c:\progra~1\AVG\AVG8\avgemc.exe [2/26/2009 11:48 AM 908056]
S2 avg8wd;AVG8 WatchDog;c:\progra~1\AVG\AVG8\avgwdsvc.exe [2/26/2009 11:48 AM 297752]
S2 gupdate1ca66354569d406;Google Update Service (gupdate1ca66354569d406);c:\program files\Google\Update\GoogleUpdate.exe [11/15/2009 3:50 PM 133104]
S2 rpcnetp;rpcnetp;c:\windows\system32\rpcnetp.exe [8/12/2008 1:35 PM 17408]
*NewlyCreated* - RPCNETP
2009-12-17 c:\windows\Tasks\Ad-Aware Update (Weekly).job
- c:\program files\Lavasoft\Ad-Aware\Ad-AwareAdmin.exe [2009-01-18 15:34]
2009-12-31 c:\windows\Tasks\GoogleUpdateTaskMachineCore.job
- c:\program files\Google\Update\GoogleUpdate.exe [2009-11-15 20:50]
2009-12-30 c:\windows\Tasks\GoogleUpdateTaskMachineUA.job
2008-08-12 c:\windows\Tasks\ISP signup reminder 1.job
- c:\windows\system32\OOBE\oobebaln.exe [2006-06-23 00:12]
2008-08-12 c:\windows\Tasks\ISP signup reminder 2.job
2008-08-12 c:\windows\Tasks\ISP signup reminder 3.job
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office12\EXCEL.EXE/3000
IE: Google Sidewiki... - c:\program files\Google\Google Toolbar\Component\GoogleToolbarDynamic_mui_en_60D6097707281E79.dll/cmsidewiki.html
DPF: {3B0EA9E6-7003-4B38-B398-9B1B6DF439C5} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\davi2807\Application Data\Mozilla\Firefox\Profiles\rkvi6x10.default\
FF - component: c:\program files\AVG\AVG8\Firefox\components\avgssff.dll
FF - plugin: c:\program files\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\Unity\WebPlayer\loader\npUnity3D32.dll
HKCU-Run-uwkpffel - c:\documents and settings\davi2807\Local Settings\Application Data\fouqxu\egeesysguard.exe
HKLM-Run-uwkpffel - c:\documents and settings\davi2807\Local Settings\Application Data\fouqxu\egeesysguard.exe
Notify-NavLogon - (no file)
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files:
- - - - - - - > 'winlogon.exe'(816)
Completion time: 2009-12-30 19:59:40
ComboFix-quarantined-files.txt 2009-12-31 00:59
Pre-Run: 58,179,448,832 bytes free
Post-Run: 58,469,175,296 bytes free
- - End Of File - - 9D1809A1298A3CA3D5582DE5DC3C32B4
butchieboss
Posts Posts : 7
Post by Dr Jay on Thu Dec 31, 2009 3:15 am
Posts Posts : 13717
Post by butchieboss on Mon Jan 04, 2010 7:53 pm
sorry it took me so long to reply was out of town didn't have access to laptop.Malwarebyte will not update error code 732(12029,0) contact support team.I scan anyway log below
Malwarebytes' Anti-Malware 1.43
Database version: 3458
1/4/2010 2:43:37 PM
mbam-log-2010-01-04 (14-43-37).txt
Objects scanned: 185715
Time elapsed: 42 minute(s), 30 second(s)
butchieboss
Posts Posts : 7
Post by Dr Jay on Mon Jan 04, 2010 7:54 pm
  • Click Start
  • Click Start
Posts Posts : 13717
Post by butchieboss on Mon Jan 04, 2010 8:17 pm
internet explorer is not working im using firefox so i had to download it. i agreed to term then tries to download components and stop and says can't get update.tried several times.
butchieboss
Posts Posts : 7
Post by Dr Jay on Mon Jan 04, 2010 8:23 pm
Use Firefox for a [You must be registered and logged in to see this link.]
  • Please check I agree with the Terms and Conditions and click Start Here
  • You will need to allow an Add-on install for Bitdefender QuickScanner for the scan to run.
  • Leave the scanning options at default and click Start Scan
Please post the results in your next reply.
Posts Posts : 13717
Post by butchieboss on Mon Jan 04, 2010 8:40 pm
ran scan three time fail all three time at 90% here is the log of what it scanned
BitDefender QuickScan Beta 32-bit v0.9.8.9
Scan date: Mon Jan 04 15:29:51 2010
Machine ID: B017346F
Scan failed! Couldn't access QuickScan server.
Processes
Answers 752 C:\Program Files\1-Click Answers\answers.exe
Microsoft® Visual Studio .NET 644 C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
PowerDVD 3584 C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
PrismXL Software Family 872 C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
ScreenScraper SDK 2128 C:\Program Files\1-Click Answers\agtserv.exe
Ad-Aware Service Application 1632 C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
Ad-Aware Tray Application 3964 C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
Agere Soft Modem Call Progress Service 428 C:\WINDOWS\system32\agrsmsvc.exe
Agere SoftModem Messaging Applet 3712 C:\WINDOWS\AGRSMMSG.exe
ATI External Event Utility for Windows 264 C:\WINDOWS\system32\Ati2evxx.exe
ATI External Event Utility for Windows 1144 C:\WINDOWS\system32\Ati2evxx.exe
AVG Internet Security 1364 C:\Program Files\AVG\AVG8\avgam.exe
AVG Internet Security 804 C:\Program Files\AVG\AVG8\avgcsrvx.exe
AVG Internet Security 1568 C:\Program Files\AVG\AVG8\avgemc.exe
AVG Internet Security 1460 C:\Program Files\AVG\AVG8\avgnsx.exe
AVG Internet Security 1408 C:\Program Files\AVG\AVG8\avgrsx.exe
AVG Internet Security 464 C:\Program Files\AVG\AVG8\avgwdsvc.exe
Firefox 2072 C:\Program Files\Mozilla Firefox\firefox.exe
Installation/Management Application 1340 C:\WINDOWS\system32\rpcnet.exe
Intel(R) Common User Interface 3664 C:\WINDOWS\system32\hkcmd.exe
Intel(R) Common User Interface 3672 C:\WINDOWS\system32\igfxpers.exe
Intel(R) Common User Interface 3692 C:\WINDOWS\system32\igfxsrvc.exe
Java(TM) Platform SE 6 U11 560 C:\Program Files\Java\jre6\bin\jqs.exe
Microsoft Distributed Transaction Coordinator 340 C:\WINDOWS\system32\msdtc.exe
Microsoft® Windows® Operating System 528 C:\Program Files\Common Files\Microsoft Shared\Ink\KeyboardSurrogate.exe
Microsoft® Windows® Operating System 3600 C:\Program Files\Common Files\Microsoft Shared\Ink\TabTip.exe
Microsoft® Windows® Operating System 3268 C:\Program Files\Common Files\Microsoft Shared\Ink\TCServer.exe
Microsoft® Windows® Operating System 2848 C:\WINDOWS\Explorer.EXE
Microsoft® Windows® Operating System 2252 C:\WINDOWS\System32\alg.exe
Microsoft® Windows® Operating System 884 C:\WINDOWS\system32\csrss.exe
Microsoft® Windows® Operating System 2924 C:\WINDOWS\system32\ctfmon.exe
Microsoft® Windows® Operating System 964 C:\WINDOWS\system32\lsass.exe
Microsoft® Windows® Operating System 3924 C:\WINDOWS\system32\rundll32.exe
Microsoft® Windows® Operating System 952 C:\WINDOWS\system32\services.exe
Microsoft® Windows® Operating System 824 C:\WINDOWS\System32\smss.exe
Microsoft® Windows® Operating System 1696 C:\WINDOWS\system32\spoolsv.exe
Microsoft® Windows® Operating System 1424 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 1392 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 1276 C:\WINDOWS\System32\svchost.exe
Microsoft® Windows® Operating System 1236 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 1164 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 256 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 480 C:\WINDOWS\system32\svchost.exe
Microsoft® Windows® Operating System 2216 C:\WINDOWS\system32\wbem\unsecapp.exe
Microsoft® Windows® Operating System 2380 C:\WINDOWS\system32\wbem\wmiprvse.exe
Microsoft® Windows® Operating System 908 C:\WINDOWS\system32\winlogon.exe
Microsoft® Windows® Operating System 2580 C:\WINDOWS\SYSTEM32\WISPTIS.EXE
Synaptics Pointing Device Driver 3648 C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
Tablet PC 2768 C:\WINDOWS\System32\tabbtnu.exe
Network activity
Process avgnsx.exe (1460) connected on port 80 (HTTP) - a69-192-156-20.deploy.akamaitechnologies.com
Process avgnsx.exe (1460) connected on port 80 (HTTP) - vx-in-f101.1e100.net
Process svchost.exe (1236) listens on ports: 135 (RPC)
Autoruns and critical files
Answers C:\Program Files\1-Click Answers\answers.exe
PowerDVD C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
Recguard Application C:\WINDOWS\SMINST\RECGUARD.EXE
Ad-Aware Admin Application C:\Program Files\Lavasoft\Ad-Aware\Ad-AwareAdmin.exe
Ad-Aware Tray Application C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
Agere SoftModem Messaging Applet C:\WINDOWS\AGRSMMSG.exe
ATI External Event Utility for Windows C:\WINDOWS\system32\ati2evxx.dll
AVG Internet Security C:\Program Files\AVG\AVG8\avgtray.exe
AVG Internet Security C:\WINDOWS\system32\avgrsstx.dll
Google Update C:\Program Files\Google\Update\GoogleUpdate.exe
Intel(R) Common User Interface C:\WINDOWS\system32\hkcmd.exe
Intel(R) Common User Interface C:\WINDOWS\system32\igfxdev.dll
Intel(R) Common User Interface C:\WINDOWS\system32\igfxpers.exe
Intel(R) Common User Interface C:\WINDOWS\system32\igfxtray.exe
Malwarebytes' Anti-Malware C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe
Microsoft Snipping Tool C:\Program Files\Microsoft Experience Pack\Snipping Tool\SnippingTool.exe
Microsoft Synchronization Manager C:\WINDOWS\system32\mobsync.exe
Microsoft® Windows® Operating System C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll
Microsoft® Windows® Operating System C:\Program Files\Common Files\Microsoft Shared\Ink\TabTip.exe
Microsoft® Windows® Operating System C:\WINDOWS\help\SplshWrp.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\browseui.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\bthprops.cpl
Microsoft® Windows® Operating System C:\WINDOWS\system32\crypt32.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\cryptnet.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\cscdll.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\ctfmon.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\dimsntfy.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\logonui.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\OOBE\oobebaln.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\sclgntfy.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\shell32.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\stobject.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\tpgwlnot.dll
Microsoft® Windows® Operating System c:\windows\system32\userinit.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\wlnotify.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\WPDShServiceObj.dll
Shockwave C:\WINDOWS\system32\Adobe\SHOCKW~1\SWHELP~1.EXE
Synaptics Pointing Device Driver C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
Tablet PC C:\WINDOWS\system32\tabbtnwl.dll
Windows® Internet Explorer C:\WINDOWS\system32\webcheck.dll
Browser plugins
AnswersInstaller.exe C:\WINDOWS\Downloaded Program Files\AnswersInstaller.exe
Browser Address Error Redirector c:\windows\system32\bae.dll
Java(TM) Platform SE 6 U11 c:\program files\java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
Shockwave for Director C:\WINDOWS\system32\Adobe\Director\np32dsw.dll
The OpenSSL Toolkit C:\Program Files\Mozilla Firefox\plugins\libdivx.dll
The OpenSSL Toolkit C:\Program Files\Mozilla Firefox\plugins\ssldivx.dll
Unity Player C:\Program Files\Unity\WebPlayer\loader\npUnity3D32.dll
2007 Microsoft Office system C:\Program Files\Mozilla Firefox\plugins\NPOFF12.DLL
AcroIEHelperShim Library c:\program files\common files\adobe\acrobat\activex\acroiehelpershim.dll
Adobe Acrobat C:\Program Files\Internet Explorer\plugins\nppdf32.dll
Adobe Acrobat C:\Program Files\Mozilla Firefox\plugins\nppdf32.dll
AVG Internet Security c:\program files\avg\avg8\avgssie.dll
BitDefender QuickScan C:\Documents and Settings\davi2807\Application Data\Mozilla\Firefox\Profiles/rkvi6x10.default\extensions\{e001c731-5e37-4538-a5cb-8168736a2360}\components\bdqscan.dll
BitDefender QuickScan C:\Documents and Settings\davi2807\Application Data\Mozilla\Firefox\Profiles/rkvi6x10.default\extensions\{e001c731-5e37-4538-a5cb-8168736a2360}\plugins\npqscan.dll
Conduit Toolbar c:\program files\saversplanet\tbsav1.dll
DivX Web Player C:\Program Files\DivX\DivX Web Player\npdivx32.dll
DivX Web Player C:\Program Files\Mozilla Firefox\plugins\npdivx32.dll
Google Toolbar for Internet Explorer c:\program files\google\google toolbar\googletoolbar_32.dll
Google Update C:\Program Files\Google\Update\1.2.183.13\npGoogleOneClick8.dll
GoogleToolbarNotifier c:\program files\google\googletoolbarnotifier\5.4.4525.1752\swg.dll
Java(TM) Platform SE 6 U11 c:\program files\java\jre6\bin\ssv.dll
Java(TM) Platform SE 6 U11 C:\Program Files\Mozilla Firefox\plugins\npdeploytk.dll
Messenger C:\Program Files\Messenger\msmsgs.exe
Microsoft® Windows® Operating System C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
Microsoft® Windows® Operating System C:\WINDOWS\system32\mswsock.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\rsvpsp.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\winrnr.dll
Microsoft® Windows® Operating System C:\WINDOWS\system32\wshbth.dll
Mozilla Default Plug-in C:\Program Files\Mozilla Firefox\plugins\npnul32.dll
NPSWF32.dll C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
Spybot - Search & Destroy c:\program files\spybot - search & destroy\sdhelper.dll
Windows Presentation Foundation c:\WINDOWS\Microsoft.NET\Framework\v3.5\Windows Presentation Foundation\NPWPF.dll
Windows® Internet Explorer C:\WINDOWS\system32\ieframe.dll
Yahoo! Toolbar c:\program files\yahoo!\companion\installs\cpn\yt.dll
Missing files
File not found: NA
referenced in: HKCU\Software\Microsoft\Windows\CurrentVersion\Run\"Power2GoExpress"
Scan
Scan finished - communication took 2 sec
Total traffic - 0.00 MB sent, 0.00 KB recvd
Scanned 1163 files and modules - 69 seconds
butchieboss
Posts Posts : 7
Post by Dr Jay on Mon Jan 04, 2010 11:07 pm
Please start Internet Explorer, and when the program is open, click on the Tools menu and then select Internet Options.
  • Now click on the Connections tab and then the Lan Settings button
  • Under the Proxy Server section, please uncheck the checkbox labeled Use a proxy server for your LAN. Then press the OK button to close this screen. Then press the Apply button and then the OK button to close the Internet Options screen. Now that you have disabled the proxy server you will be able to browse the web again with Internet Explorer.
Let me know if you can use it.
Posts Posts : 13717
Post by butchieboss on Tue Jan 05, 2010 12:35 am
yes internet explorer is working now
butchieboss
Posts Posts : 7
Post by Dr Jay on Tue Jan 05, 2010 1:22 am
Good.
Please download [You must be registered and logged in to see this link.], and save to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.zip, and extract the file to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.cmd to start.
  • It will finish quickly and launch a log.
  • Post the contents of it in your next reply.
Posts Posts : 13717
Post by butchieboss on Tue Jan 05, 2010 1:41 am
aAnti-Rogue v1.0.15
by DragonMaster Jay
Mon 01/04/2010 20:40:23.23
-- Known infection --
If objects found, full virus scan or anti-malware scan necessary
EOF
butchieboss
Posts Posts : 7
Post by Dr Jay on Tue Jan 05, 2010 3:50 am
Please run the [You must be registered and logged in to see this link.]
  • Follow the Instruction [You must be registered and logged in to see this link.] for installation.
  • Accept the License Agreement.
  • Once the ActiveX installs,Click Full System Scan
  • Once the download completes,the scan will begin automatically.
  • The scan will take some time to finish,so please be patient.
  • When the scan completes, click the Automatic cleaning (recommended) button.
  • Click the Show Report button and Copy&Paste the entire report in your next reply.
Posts Posts : 13717
