win32/Nuqel and BankerFox Removal help
Post by sarah1202 on 29th December 2009, 6:06 am
My computer has gone haywire! I keep getting pop ups about antivirus stuff. I tried to download HijackThis, I can get it to download, but cannot open it after that. Please help me fix it! Thanks!
sarah1202
Posts Posts : 17
Joined Joined : 2009-12-29
OS OS : windows xp
Points Points : 25623
Re: win32/Nuqel and BankerFox Removal help
Post by Dr Jay on 29th December 2009, 12:29 pm
Posts Posts : 14310
Points Points : 302971
Post by sarah1202 on 29th December 2009, 2:19 pm
Ok, I got it ComboFix to download, but it won't open. When I copied the code into the run menu, it popped up in the bottom left corner of the screen, but was only there for a second. Nothing happened after that.
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 29th December 2009, 10:48 pm
Delete your copy of ComboFix; grab a fresh copy, except before you download it, rename it to blackpudding.bat
Navigate to Start --> Run, and enter the following command exactly as shown:
"%userprofile%\desktop\blackpudding.bat" /killall
See if ComboFix will run now.
Posts Posts : 14310
Post by sarah1202 on 29th December 2009, 11:13 pm
Now it is saying that it can't find the file, unless I didn't delete combofix correctly. I can't access add/remove programs.
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by sarah1202 on 30th December 2009, 2:42 am
Still couldn't get ComboFix to run, but scanned with Malware and it caught 9 infections.
Here's the log:
Malwarebytes' Anti-Malware 1.42
Database version: 3289
12/29/2009 8:07:00 PM
mbam-log-2009-12-29 (20-07-00).txt
Objects scanned: 321281
Time elapsed: 1 hour(s), 50 minute(s), 28 second(s)
Memory Processes Infected: 1
Registry Keys Infected: 1
Registry Values Infected: 3
Files Infected: 2
C:\Documents and Settings\Owner\Local Settings\Application Data\oxukvl\iwlgsysguard.exe (Trojan.FakeAlert) -> Unloaded process successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\natobunod (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ylfimjpy (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ylfimjpy (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\UpdatesDisableNotify (Disabled.SecurityCenter) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell (Hijack.Shell) -> Bad: (Explorer.exe logon.exe) Good: (Explorer.exe) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\Local Settings\Application Data\oxukvl\iwlgsysguard.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Documents and Settings\Owner\My Documents\downloads\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 2:45 am
Please download [You must be registered and logged in to see this link.], and save to your Desktop.
  • Double-click on Cheetah-Anti-Rogue.bat to start.
  • It will finish quickly and launch a log.
  • Post the contents of it in your next reply.
Posts Posts : 14310
Post by sarah1202 on 30th December 2009, 4:19 am
Cheetah Anti-Rogue v1.0.5
by DragonMaster Jay
This is what came up when I ran it:
Tue 12/29/2009 22:18:40.77
-- Known infection --
If objects found, full virus scan or anti-malware scan necessary
EOF
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 5:25 am
Please download the Kaspersky AVP Tool from [You must be registered and logged in to see this link.].
  • Save it to your desktop.
  • Please reboot to Safe Mode (tap the F8 key just before Windows starts to load and select the Safe Mode option from the menu).
  • Click Next to continue.
  • It will by default install it to your desktop folder.Click Next.
  • Hit ok at the prompt for scanning in Safe Mode.
  • Under Automatic scan make sure these are checked:
    • System Memory
    • Startup Objects
    • Disk Boot Sectors.
    • My Computer.
After that click on Security level then choose Customize then click on the tab that says Heuristic Analyzer then choose Enable Deep rootkit search then choose ok.
Then choose OK again then you are back to the main screen.
  • Then click on Scan at the to right hand Corner.
  • It will automatically Neutralize any objects found.
  • If some objects are left un-neutralized then click the button that says Neutralize all
  • If it says it cannot be Neutralized then chooose The delete option when prompted.
  • After that is done click on the reports button at the bottom and save it to file name it Kas.
  • Save it somewhere convenient like your desktop and just post only the detected Virus\malware in the report it will be at the very top under Detected post those results in your next reply.
Posts Posts : 14310
Post by sarah1202 on 30th December 2009, 5:57 am
Ok, I got that to download, but can't boot in safe mode. I can click on safe mode, but then it scrolls though script and then automatically restarts.
Thanks a bunch for your help!
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 6:18 am
Download and run SafeBootKeyRepair-CF from: [You must be registered and logged in to see this link.]
It will take only a moment for it to run. If it produces a log, please post it in your next reply.
Does Safe Mode work now?
Posts Posts : 14310
Post by sarah1202 on 30th December 2009, 6:26 am
Ok, that's not running, just saying please wait. Apparently all I had to do was post this. lol
Here is the log from that. I will try to reboot in safe mode now.
Thanks again.
Reg export of SafeBoot key after repair:
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot]
"AlternateShell"="cmd.exe"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\AppMgmt]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Base]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Boot Bus Extender]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Boot file system]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\CryptSvc]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\DcomLaunch]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\dmadmin]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\dmboot.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\dmio.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\dmload.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\dmserver]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\EventLog]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\File system]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Filter]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\HelpSvc]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Netlogon]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\PCI Configuration]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\PEVSystemStart]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\PlugPlay]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\PNP Filter]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\Primary disk]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\procexp90.Sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\RpcSs]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\SCSI Class]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\sermouse.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\sr.sys]
@="FSFilter System Recovery"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\SRService]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\System Bus Extender]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\vds]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\vga.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\vgasave.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\WinMgmt]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{36FC9E60-C465-11CF-8056-444553540000}]
@="Universal Serial Bus controllers"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E965-E325-11CE-BFC1-08002BE10318}]
@="CD-ROM Drive"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E967-E325-11CE-BFC1-08002BE10318}]
@="DiskDrive"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E969-E325-11CE-BFC1-08002BE10318}]
@="Standard floppy disk controller"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E96A-E325-11CE-BFC1-08002BE10318}]
@="Hdc"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E96B-E325-11CE-BFC1-08002BE10318}]
@="Keyboard"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E96F-E325-11CE-BFC1-08002BE10318}]
@="Mouse"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E977-E325-11CE-BFC1-08002BE10318}]
@="PCMCIA Adapters"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E97B-E325-11CE-BFC1-08002BE10318}]
@="SCSIAdapter"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E97D-E325-11CE-BFC1-08002BE10318}]
@="System"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{4D36E980-E325-11CE-BFC1-08002BE10318}]
@="Floppy disk drive"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{533C5B84-EC70-11D2-9505-00C04F79DEAF}]
@="Volume shadow copy"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
@="Volume"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Minimal\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}]
@="Human Interface Devices"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\AFD]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\AppMgmt]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Base]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Boot Bus Extender]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Boot file system]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Browser]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\CryptSvc]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\DcomLaunch]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Dhcp]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\dmadmin]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\dmboot.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\dmio.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\dmload.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\dmserver]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\DnsCache]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\EventLog]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\File system]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Filter]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\HelpSvc]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\ip6fw.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\ipnat.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\LanmanServer]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\LanmanWorkstation]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\LmHosts]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Messenger]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NDIS]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NDIS Wrapper]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Ndisuio]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetBIOS]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetBIOSGroup]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetBT]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetDDEGroup]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Netlogon]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetMan]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Network]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NetworkProvider]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\NtLmSsp]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\PCI Configuration]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\PEVSystemStart]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\PlugPlay]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\PNP Filter]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\PNP_TDI]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Primary disk]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\procexp90.Sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\rdpcdd.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\rdpdd.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\rdpwd.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\rdsessmgr]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\RpcSs]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\SCSI Class]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\sermouse.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\sharedaccess]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\sr.sys]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\SRService]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Streams Drivers]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\System Bus Extender]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\Tcpip]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\TDI]
@="Driver Group"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\tdpipe.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\tdtcp.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\termservice]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\vga.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\vgasave.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\WinMgmt]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\WZCSVC]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{1a3e09be-1e45-494b-9174-d7385b45bbf5}]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{36FC9E60-C465-11CF-8056-444553540000}]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E965-E325-11CE-BFC1-08002BE10318}]
@="CD-ROM Drive"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E967-E325-11CE-BFC1-08002BE10318}]
@="DiskDrive"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E969-E325-11CE-BFC1-08002BE10318}]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E96A-E325-11CE-BFC1-08002BE10318}]
@="Hdc"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E96B-E325-11CE-BFC1-08002BE10318}]
@="Keyboard"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E96F-E325-11CE-BFC1-08002BE10318}]
@="Mouse"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E972-E325-11CE-BFC1-08002BE10318}]
@="Net"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E973-E325-11CE-BFC1-08002BE10318}]
@="NetClient"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E974-E325-11CE-BFC1-08002BE10318}]
@="NetService"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E975-E325-11CE-BFC1-08002BE10318}]
@="NetTrans"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E977-E325-11CE-BFC1-08002BE10318}]
@="PCMCIA Adapters"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E97B-E325-11CE-BFC1-08002BE10318}]
@="SCSIAdapter"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E97D-E325-11CE-BFC1-08002BE10318}]
@="System"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{4D36E980-E325-11CE-BFC1-08002BE10318}]
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
@="Volume"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\Network\{745A17A0-74D3-11D0-B6FE-00A0C90F57DA}]
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\minimal\PEVSystemStart
HKEY_LOCAL_MACHINE\system\currentcontrolset\control\safeboot\minimal\procexp90.Sys
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 6:28 am
Try shutting down all programs, and security software...what happens?
Posts Posts : 14310
Post by sarah1202 on 30th December 2009, 1:48 pm
Got it to scan in safe mode, but I couldn't get to the reports button. It did find and remove 4 infections.
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 8:42 pm
Ok. Good. Safe Mode fixed?
  • Click Start
  • Click Start
Posts Posts : 14310
Post by sarah1202 on 30th December 2009, 9:22 pm
Yes, safe mode works now. I tried to run the ESET Online Scanner, but it is saying it cannot get updates and asking if the proxy is configured.
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 30th December 2009, 9:59 pm
  • Click the big green Scan now button
  • If it wants to install an ActiveX component allow it
  • It will start downloading the files it requires for the scan (Note: It may take a couple of minutes)
  • Once the scan is completed, please hit the notepad icon next to the text Export to:
  • Save it to a convenient location such as your Desktop
  • Post the contents of the ActiveScan.txt in your next reply
Posts Posts : 14310
Post by sarah1202 on 31st December 2009, 3:29 am
Here are the results from the Panda ActiveScan:
ANALYSIS: 2009-12-30 21:27:18
PROTECTIONS: 1
MALWARE: 26
SUSPECTS: 12
PROTECTIONS
Description Version Active Updated
AVG Anti-Virus Free 8.5 Yes Yes
MALWARE
Id Description Type Active Severity Disinfectable Disinfected Location
00098265 Application/Starr.A HackTools No 0 Yes No c:\my backup -- 07-02-18 1029am\windows\system32\wsys.dll
00118607 Application/Starr.A HackTools No 0 Yes No c:\my backup -- 07-02-18 1029am\windows\system32\see32.dll
00152401 Cookie/Belnk TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\cookies\owner@belnk[1].txt
00162730 Cookie/Belnk TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\cookies\owner@dist.belnk[2].txt
00167642 Cookie/Com.com TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@com[1].txt
00167642 Cookie/Com.com TrackingCookie No 0 Yes No c:\documents and settings\owner\cookies\owner@com[1].txt
00167730 Cookie/Hitbox TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@ehg.hitbox[1].txt
00167747 Cookie/Azjmp TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\cookies\owner@azjmp[2].txt
00167749 Cookie/Toplist TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@toplist[2].txt
00167753 Cookie/Statcounter TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@statcounter[1].txt
00167760 Cookie/Hitslink TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@counter.hitslink[1].txt
00168061 Cookie/Apmebf TrackingCookie No 0 Yes No c:\documents and settings\owner\cookies\owner@apmebf[1].txt
00168097 Cookie/BurstBeacon TrackingCookie No 0 Yes No c:\documents and settings\owner\cookies\owner@[You must be registered and logged in to see this link.]
00168110 Cookie/Server.iad.Liveperson TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@server.iad.liveperson[1].txt
00169287 Cookie/Adrevolver TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@media.adrevolver[2].txt
00170495 Cookie/PointRoll TrackingCookie No 0 Yes No c:\documents and settings\owner\cookies\owner@ads.pointroll[1].txt
00170495 Cookie/PointRoll TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@ads.pointroll[1].txt
00182104 Cookie/Hitbox TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@phg.hitbox[2].txt
00194327 Cookie/Go TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\cookies\owner@go[1].txt
00262020 Cookie/Atwola TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@atwola[1].txt
00262020 Cookie/Atwola TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\cookies\owner@atwola[1].txt
00293517 Cookie/AdDynamix TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@ads.addynamix[2].txt
00325830 Cookie/Bridgetrack TrackingCookie No 0 Yes No c:\my backup -- 07-02-18 1029am\documents and settings\owner\cookies\owner@citi.bridgetrack[2].txt
00365124 Application/MyWebSearch HackTools No 0 Yes No c:\my backup -- 07-02-18 1029am\program files\mywebsearch\bar\1.bin\f3htmlmu.dll
00365129 Application/MyWebSearch HackTools No 0 Yes No c:\my backup -- 07-02-18 1029am\program files\mywebsearch\bar\1.bin\f3dtactl.dll
00447834 Adware/Lop Adware No 0 Yes No c:\my backup -- 07-02-18 1029am\program files\norton internet security\norton antivirus\quarantine\3a8c447e.vxd
00447834 Adware/Lop Adware No 0 Yes No c:\my backup -- 07-02-18 1029am\program files\norton internet security\norton antivirus\quarantine\5d67379c.vxd
00447834 Adware/Lop Adware No 0 Yes No c:\my backup -- 07-02-18 1029am\program files\norton internet security\norton antivirus\quarantine\6fac6453.exe
00950035 Cookie/RegistryDefender TrackingCookie No 0 Yes No c:\documents and settings\owner\cookies\owner@registrydefender[2].txt
00954094 Rootkit/Bagle.UV Virus/Worm Yes 2 Yes No c:\windows\system32\drivers\ute1mzqy.sys
03074964 Trj/CI.A Virus/Trojan No 0 No No c:\my backup -- 07-02-18 1029am\documents and settings\owner\local settings\temp\goldenpalaceen.cab[casino.exe]
SUSPECTS
Sent Location
No c:\32788r22fwjfw\pev.cfxxe
No c:\32788r22fwjfw\pev.exe
No c:\documents and settings\owner\local settings\temp\ehw4vxbn.exe.part[32788r22fwjfw\pev.exe]
No c:\documents and settings\owner\local settings\temp\eysbpjgo.exe.part[32788r22fwjfw\pev.exe]
No c:\documents and settings\owner\my documents\downloads\combofix(2).exe[32788r22fwjfw\pev.exe]
No c:\documents and settings\owner\my documents\downloads\commy.exe[32788r22fwjfw\pev.exe]
No c:\documents and settings\owner\desktop\rocket pro\mp3rocket-win-proz.exe
No c:\recycler\s-1-5-21-614831263-3347666270-4183326654-1006\dc446.exe[32788r22fwjfw\pev.exe]
No c:\system volume information\_restore{348db8ec-73a3-48fb-ade8-4bd3bbe539b1}\rp93\a0011015.exe[32788r22fwjfw\pev.exe]
No c:\system volume information\_restore{348db8ec-73a3-48fb-ade8-4bd3bbe539b1}\rp93\a0011016.exe[32788r22fwjfw\pev.exe]
No c:\system volume information\_restore{348db8ec-73a3-48fb-ade8-4bd3bbe539b1}\rp93\a0011017.exe[32788r22fwjfw\pev.exe]
No c:\system volume information\_restore{348db8ec-73a3-48fb-ade8-4bd3bbe539b1}\rp93\a0011082.exe[32788r22fwjfw\pev.exe]
VULNERABILITIES
Id Severity Description
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 31st December 2009, 4:22 am
Posts Posts : 14310
Post by sarah1202 on 31st December 2009, 4:25 am
I already have MalwareBytes installed, so I checked for updates as instructed, and got an error code.
Thanks again for your help!
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 31st December 2009, 4:28 am
Try the scan without updates. See what happens.
Posts Posts : 14310
Post by sarah1202 on 31st December 2009, 6:29 am
Here's the log from the scan.
Thanks!
12/31/2009 12:28:36 AM
mbam-log-2009-12-31 (00-28-36).txt
Objects scanned: 321845
Time elapsed: 1 hour(s), 44 minute(s), 15 second(s)
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 31st December 2009, 7:04 am
Please download the [You must be registered and logged in to see this link.]. Unzip it to your Desktop.
Before scanning, make sure all other running programs are closed and no other actions like a scheduled antivirus scan will occur while the scan is being performed. Do not use your computer for anything else during the scan.
Double-click gmer.exe. The program will begin to run.
**Caution**
These types of scans can produce false positives. Do NOT take any action on any
"<--- ROOKIT" entries unless advised!
If possible rootkit activity is found, you will be asked if you would like to perform a full scan.
  • Click NO
  • In the right panel, you will see a bunch of boxes that have been checked ... leave everything checked and ensure the Show all box is un-checked.
  • Now click the Scan button.
    Once the scan is complete, you may receive another notice about rootkit activity.
  • Click OK.
  • GMER will produce a log. Click on the [Save..] button, and in the File name area, type in "GMER.txt"
  • Save it where you can easily find it, such as your desktop.
Post the contents of GMER.txt in your next reply.
Posts Posts : 14310
Post by sarah1202 on 1st January 2010, 12:58 am
Here's the log from gmer. After I ran that everything on my computer is very slow.
GMER 1.0.15.15281 - [You must be registered and logged in to see this link.]
Rootkit scan 2009-12-31 18:36:57
Running: gmer.exe; Driver: C:\DOCUME~1\Owner\LOCALS~1\Temp\kfpyrkod.sys
---- Kernel code sections - GMER 1.0.15 ----
.text C:\WINDOWS\system32\DRIVERS\nv4_mini.sys section is writeable [0xB8CC3360, 0x1DE5ED, 0xE8000020]
init C:\WINDOWS\System32\Drivers\sunkfilt.sys entry point in "init" section [0xBA460300]
---- User IAT/EAT - GMER 1.0.15 ----
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!LoadLibraryExW] [63602B3E] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!LoadLibraryA] [63602A5B] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!GetProcAddress] [63602441] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\USER32.dll [KERNEL32.dll!LoadLibraryW] [63602AA2] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!LoadLibraryExW] [63602B3E] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!LoadLibraryA] [63602A5B] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!GetProcAddress] [63602441] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\GDI32.dll [KERNEL32.dll!LoadLibraryW] [63602AA2] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!LoadLibraryA] [63602A5B] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!LoadLibraryW] [63602AA2] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!GetProcAddress] [63602441] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!LoadLibraryExW] [63602B3E] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [KERNEL32.dll!LoadLibraryExA] [63602AE9] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!AnimateWindow] [63601740] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!TrackPopupMenuEx] [636015EF] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!DefWindowProcA] [6360208F] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!GetSysColor] [63601FC4] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!DefWindowProcW] [63602065] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHELL32.dll [USER32.dll!TrackPopupMenu] [636015C8] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!LoadLibraryExA] [63602AE9] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!LoadLibraryExW] [63602B3E] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!LoadLibraryW] [63602AA2] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!LoadLibraryA] [63602A5B] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [KERNEL32.dll!GetProcAddress] [63602441] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [USER32.dll!DefWindowProcA] [6360208F] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [USER32.dll!DefWindowProcW] [63602065] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [USER32.dll!GetSysColor] [63601FC4] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [USER32.dll!TrackPopupMenu] [636015C8] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
IAT C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe[2696] @ C:\WINDOWS\system32\SHLWAPI.dll [USER32.dll!TrackPopupMenuEx] [636015EF] C:\Program Files\Yahoo!\Shared\YbSkin2.dll (Yahoo! Skinning Object/Yahoo! Inc.)
AttachedDevice \Driver\Tcpip \Device\Ip avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
AttachedDevice \Driver\Tcpip \Device\Tcp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
AttachedDevice \Driver\Tcpip \Device\Udp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
AttachedDevice \Driver\Tcpip \Device\RawIp avgtdix.sys (AVG Network connection watcher/AVG Technologies CZ, s.r.o.)
AttachedDevice \FileSystem\Fastfat \Fat fltmgr.sys (Microsoft Filesystem Filter Manager/Microsoft Corporation)
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@DeviceNotSelectedTimeout 15
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@GDIProcessHandleQuota 10000
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@Spooler yes
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@swapdisk
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@TransmissionRetryTimeout 90
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@USERProcessHandleQuota 10000
Reg HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows@LoadAppInit_DLLs 1
---- Disk sectors - GMER 1.0.15 ----
Disk \Device\Harddisk0\DR0 sector 59: copy of MBR
---- EOF - GMER 1.0.15 ----
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 1st January 2010, 3:17 am
Please download [You must be registered and logged in to see this link.] to your desktop and run it.
  • When the first page comes up select Beginner Mode
  • On the next page select Save a binary .Run file (Recommended) then click Start full scan at the top.
  • At this time Runscanner.exe may request access to the Internet through your firewall please allow it to do so, it will then run for two or three minutes.
  • On completion it will ask for a location to save the file and a name. It will do this for both the .run file and the log file
  • Call the .run file "redScan" and save it to your desktop. You will see the .run file on your desktop. Open Notepad, then click File > Open - locate the redScan file and open it in Notepad. Finally, copy all the results, and paste them here in your next reply.
Posts Posts : 14310
Post by sarah1202 on 1st January 2010, 3:59 am
Runscanner logfile
* = signed file
- = file not found
General info
Computer name : YOUR-8B52AE5C26
Creation time : 12/31/2009 9:57:08 PM
Hosts <> 127.0.0.1 : 0
Hosts file location : %SystemRoot%\System32\drivers\etc
IE version : 8.0.6001.18702
OS : Microsoft Windows XP
OS Build : 2600
OS SP : Service Pack 3
RunScanner Version : 1.9.0.9
User Language : English (United States)
User rights : Administrator
Windows folder : C:\WINDOWS
Running processes
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe (Hewlett-Packard Co.)
* C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe (Apple Inc.)
* C:\WINDOWS\System32\alg.exe (Microsoft Corporation)
* C:\PROGRA~1\AVG\AVG8\avgemc.exe (AVG Technologies CZ, s.r.o.)
* C:\PROGRA~1\AVG\AVG8\avgnsx.exe (AVG Technologies CZ, s.r.o.)
* C:\PROGRA~1\AVG\AVG8\avgrsx.exe (AVG Technologies CZ, s.r.o.)
* C:\Program Files\AVG\AVG8\avgcsrvx.exe (AVG Technologies CZ, s.r.o.)
* C:\PROGRA~1\AVG\AVG8\avgtray.exe (AVG Technologies CZ, s.r.o.)
* C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe (AVG Technologies CZ, s.r.o.)
* C:\Program Files\Bonjour\mDNSResponder.exe (Apple Inc.)
* C:\WINDOWS\system32\csrss.exe (Microsoft Corporation)
* C:\WINDOWS\system32\dllhost.exe (Microsoft Corporation)
* C:\WINDOWS\system32\ctfmon.exe (Microsoft Corporation)
* C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation)
* C:\WINDOWS\system32\svchost.exe (Microsoft Corporation)
* C:\WINDOWS\System32\svchost.exe (Microsoft Corporation)
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe (Hewlett-Packard Co.)
* C:\Program Files\iPod\bin\iPodService.exe (Apple Inc.)
* C:\Program Files\iTunes\iTunesHelper.exe (Apple Inc.)
* C:\WINDOWS\system32\drivers\KodakCCS.exe (Eastman Kodak Company)
C:\Program Files\Kodak\Kodak EasyShare Software\bin\EasyShare.exe (Eastman Kodak Company)
C:\Program Files\Kodak\KODAK Software Updater\7288971\Program\Kodak Software Updater.exe
* C:\WINDOWS\system32\lsass.exe (Microsoft Corporation)
* C:\Program Files\McAfee Security Scan\1.0.150\SSScheduler.exe (McAfee, Inc.)
* C:\WINDOWS\ehome\mcrdsvc.exe (Microsoft Corporation)
* C:\WINDOWS\eHome\ehmsas.exe (Microsoft Corporation)
* C:\WINDOWS\eHome\ehRecvr.exe (Microsoft Corporation)
* C:\WINDOWS\eHome\ehSched.exe (Microsoft Corporation)
* C:\WINDOWS\ehome\ehtray.exe (Microsoft Corporation)
C:\Program Files\Common Files\Nikon\Monitor\NkMonitor.exe (Nikon Corporation)
* C:\WINDOWS\system32\notepad.exe (Microsoft Corporation)
* C:\WINDOWS\system32\nvsvc32.exe (NVIDIA Corporation)
C:\Program Files\Canon\Memory Card Utility\iP6600D\PDUiP6600DMon.exe (CANON INC.)
C:\WINDOWS\system32\HPZipm12.exe (HP)
C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS (New Boundary Technologies, Inc.)
C:\Program Files\QuickTime\QTTask.exe (Apple Inc.)
* C:\WINDOWS\system32\rundll32.exe (Microsoft Corporation)
* C:\Documents and Settings\Owner\Desktop\runscanner\RunScanner.exe (Runscanner.net)
* C:\WINDOWS\system32\services.exe (Microsoft Corporation)
C:\Program Files\fastrac software\X_metromatch.exe (Pantaray Research Ltd.)
C:\Program Files\Digital Media Reader\shwiconem.exe (Alcor Micro, Corp.)
* C:\WINDOWS\system32\spoolsv.exe (Microsoft Corporation)
* C:\WINDOWS\Explorer.EXE (Microsoft Corporation)
* C:\WINDOWS\system32\winlogon.exe (Microsoft Corporation)
* c:\windows\System32\smss.exe (Microsoft Corporation)
* C:\PROGRA~1\Yahoo!\MESSEN~1\ymsgr_tray.exe (Yahoo! Inc.)
Unrated items
002 C:\Program Files\Intel Audio Studio\IntelAudioStudio.exe (Intel Corporation)
002 C:\Program Files\Canon\Memory Card Utility\iP6600D\PDUiP6600DMon.exe (CANON INC.)
002 C:\Program Files\QuickTime\QTTask.exe (Apple Inc.)
002 C:\WINDOWS\SMINST\RECGUARD.EXE
002 C:\Program Files\Digital Media Reader\shwiconem.exe (Alcor Micro, Corp.)
004 C:\PROGRA~1\FASTRA~1\METROM~1.EXE (Pantaray Research Ltd.)
005 C:\PROGRA~1\HP\DIGITA~1\bin\hpqtra08.exe (Hewlett-Packard Co.)
005 C:\PROGRA~1\HP\DIGITA~1\bin\hpqthb08.exe (Hewlett-Packard Co.)
005 C:\PROGRA~1\Kodak\KODAKE~1\bin\EASYSH~1.EXE (Eastman Kodak Company)
005 C:\PROGRA~1\Kodak\KODAKS~1\7288971\Program\KODAKS~1.EXE
005 * C:\PROGRA~1\MCAFEE~1\10BCA1~1.150\SSSCHE~1.EXE (McAfee, Inc.)
005 C:\PROGRA~1\COMMON~1\Nikon\Monitor\NKMONI~1.EXE (Nikon Corporation)
010 C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe (InstallDriver Table Manager)
010 C:\WINDOWS\system32\HPZipm12.exe (Pml Driver HPZ12)
010 C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS (PrismXL)
011 C:\WINDOWS\System32\Drivers\sunkfilt.sys (Alcor Micro Corp Reader)
011 C:\WINDOWS\system32\Drivers\ute1mzqy.sys (AVZ Kernel Driver)
011 C:\WINDOWS\system32\drivers\Cdr4_xp.sys (Cdr4_xp)
011 C:\WINDOWS\system32\drivers\Cdralw2k.sys (Cdralw2k)
011 * C:\WINDOWS\system32\DRIVERS\GEARAspiWDM.sys (GEAR ASPI Filter Driver)
011 C:\WINDOWS\system32\DRIVERS\mhndrv.sys (MHN driver)
011 * C:\WINDOWS\system32\drivers\pavboot.sys (pavboot)
011 * C:\WINDOWS\System32\Drivers\PCASp50.sys (PCASp50 NDIS Protocol Driver)
011 * C:\WINDOWS\system32\DRIVERS\ssmdrv.sys (ssmdrv)
011 * c:\windows\System32\drivers\swmsflt.sys (swmsflt)
011 C:\WINDOWS\system32\Drivers\sydexfdd.sys (Sydex Diskette Driver)
031 C:\Program Files\Common Files\Microsoft Shared\Information Retrieval\msitss.dll (Microsoft Corporation) {0A9007C0-4076-11D3-8789-0000F8105754}
041 * C:\Program Files\AskBarDis\bar\bin\askBar.dll (Ask.com) {3041d03e-fd4b-44e0-b742-2d9b88305f98}
041 C:\Program Files\Canon\Easy-WebPrint\Toolband.dll {327C2873-E90D-4c37-AA9D-10AC9BABA46C}
045 * C:\Program Files\AskBarDis\bar\bin\askBar.dll (Ask.com) {3041D03E-FD4B-44E0-B742-2D9B88305F98}
061 C:\WINDOWS\system32\nvshell.dll (NVIDIA Corporation) {1CDB2949-8F65-4355-8456-263E7C208A5D}
061 C:\WINDOWS\system32\nvshell.dll (NVIDIA Corporation) {1E9B04FB-F9E5-4718-997B-B8DA88302A47}
061 C:\Program Files\Common Files\KODAK\IFSCore\kodakshx.dll (Eastman Kodak Company) {acb4a560-3606-11d3-aef4-00104bd0f92d}
061 C:\WINDOWS\system32\nvshell.dll (NVIDIA Corporation) {1E9B04FB-F9E5-4718-997B-B8DA88302A48}
061 C:\WINDOWS\system32\ShellvRTF.dll (XSS) {7F67036B-66F1-411A-AD85-759FB9C5B0DB}
061 * C:\Program Files\Real\RealPlayer\rpshell.dll (RealNetworks, Inc.) {F0CB00CD-5A07-4D91-97F5-A8C92CDA93E4}
062 C:\Program Files\Adobe\Acrobat 7.0\ActiveX\PDFShell.dll (Adobe Systems, Inc.) {F9DB5320-233E-11D1-9F84-707F02C10627}
100 ProxyServer HKCU : http=127.0.0.1:5555
100 Start Page HKCU : [You must be registered and logged in to see this link.]
104 C:\WINDOWS\Downloaded Program Files\ZIntro.ocx (Microsoft Corporation) {B8BE5E93-A60C-4D26-A2DC-220313175592}
104 C:\Program Files\Java\jre1.5.0_02\bin\npjpi150_02.dll (Sun Microsystems, Inc.) {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
105 &AOL Toolbar search : [You must be registered and logged in to see this link.] Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
105 &Yahoo! Search : [You must be registered and logged in to see this link.] Files\Yahoo!\Common/ycsrch.htm
105 E&xport to Microsoft Excel : [You must be registered and logged in to see this link.]
105 Easy-WebPrint Add To Print List : [You must be registered and logged in to see this link.] Files\Canon\Easy-WebPrint\Resource.dll/RC_AddToList.html
105 Easy-WebPrint High Speed Print : [You must be registered and logged in to see this link.] Files\Canon\Easy-WebPrint\Resource.dll/RC_HSPrint.html
105 Easy-WebPrint Preview : [You must be registered and logged in to see this link.] Files\Canon\Easy-WebPrint\Resource.dll/RC_Preview.html
105 Easy-WebPrint Print : [You must be registered and logged in to see this link.] Files\Canon\Easy-WebPrint\Resource.dll/RC_Print.html
105 Yahoo! &Dictionary : [You must be registered and logged in to see this link.] Files\Yahoo!\Common/ycdict.htm
105 Yahoo! &Maps : [You must be registered and logged in to see this link.] Files\Yahoo!\Common/ycmap.htm
105 Yahoo! &SMS : [You must be registered and logged in to see this link.] Files\Yahoo!\Common/ycsms.htm
107 C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
170 {0abe29f2-02af-11dd-b709-00038a000015} : L:\LaunchU3.exe -a
170 D : C:\WINDOWS\system32\RunDLL32.EXE Shell32.DLL,ShellExec_RunDLL Info.exe folder.htt 480 480
170 L : L:\WIN\setup.exe
223 * C:\Program Files\Malwarebytes' Anti-Malware\mbamext.dll (Malwarebytes Corporation) {57CE581A-0CB6-4266-9CA0-19364C90A0B3}
225 * C:\Program Files\Malwarebytes' Anti-Malware\mbamext.dll (Malwarebytes Corporation) {57CE581A-0CB6-4266-9CA0-19364C90A0B3}
229 C:\WINDOWS\system32\nvshell.dll (NVIDIA Corporation) {1E9B04FB-F9E5-4718-997B-B8DA88302A48}
231 C:\Program Files\Adobe\Acrobat 7.0\ActiveX\PDFShell.dll (Adobe Systems, Inc.) PDF Column Info
Missing files
011 C:\WINDOWS\system32\drivers\Abiosdsk.sys
011 C:\WINDOWS\system32\drivers\adfs.sys
011 C:\WINDOWS\system32\drivers\Atdisk.sys
011 C:\WINDOWS\system32\drivers\Changer.sys
011 C:\WINDOWS\system32\drivers\lbrtfdc.sys
011 C:\WINDOWS\system32\drivers\PCIDump.sys
011 C:\WINDOWS\system32\PCTINDIS5.SYS
011 C:\WINDOWS\system32\drivers\PDCOMP.sys
011 C:\WINDOWS\system32\drivers\PDFRAME.sys
011 C:\WINDOWS\system32\drivers\PDRELI.sys
011 C:\WINDOWS\system32\drivers\PDRFRAME.sys
011 C:\WINDOWS\system32\drivers\Simbad.sys
011 C:\WINDOWS\system32\drivers\WDICA.sys
011 C:\WINDOWS\system32\drivers\wntpport.sys
051 c:\windows\system32\paviligo.dll
060 c:\windows\system32\paviligo.dll
061 deskpan.dll
071 dalodawo.dll
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 1st January 2010, 4:19 am
Please uninstall Malwarebytes Anti-Malware, by using Control Panel > Add or Remove Programs.
Please download the new version of Malwarebytes Anti-Malware from [You must be registered and logged in to see this link.].
Update and run a Full Scan. Post a fresh log.
Posts Posts : 14310
Post by sarah1202 on 1st January 2010, 6:24 pm
Ok, I uninstalled Malwarebytes, but got an error code stating that it could not update. I did run it any way. Here is the log.
Malwarebytes' Anti-Malware 1.43
Database version: 3458
1/1/2010 12:22:33 AM
mbam-log-2010-01-01 (00-22-33).txt
Objects scanned: 324954
Time elapsed: 1 hour(s), 43 minute(s), 32 second(s)
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 1st January 2010, 10:46 pm
Final check:
Click the Settings button.
Set it to Maximum
Posts Posts : 14310
Post by sarah1202 on 2nd January 2010, 5:35 pm
Here's the GSI Parser report.
Thanks a bunch for your help! Happy New Year!
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 2nd January 2010, 8:50 pm
Please delete these four files:
=> C:\WINDOWS\system32\Marker32.exe
=> C:\WINDOWS\system32\Sp32w.dll
=> C:\WINDOWS\system32\Sx32w.dll
=> C:\WINDOWS\system32\VGASwitch.bat
Posts Posts : 14310
Post by sarah1202 on 2nd January 2010, 9:32 pm
Windows XP Service Pack 3
Antivirus/Firewall Check:
Windows Firewall Enabled!
AVG Free 8.5
Antivirus up to date!
CCleaner (remove only)
Java(TM) SE Runtime Environment 6 Update 1
Adobe Flash Player 10
Adobe Reader 7.0.9
Process Check:
objlist.exe by Laurent
AVG avgwdsvc.exe
AVG avgtray.exe
AVG avgrsx.exe
AVG avgnsx.exe
AVG avgemc.exe
AVG avgemc.exe
DNS Vulnerability Check:
sarah1202
Posts Posts : 17
OS OS : windows xp
Post by Dr Jay on 2nd January 2010, 9:37 pm
Software recommendations
Firewall
AntiSpyware
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Posts Posts : 14310
