AUDIO DEVICE PROBLEM
Post by cycleconnection on 28th December 2009, 5:22 am
I have a gateway laptop mx6455 and then sound beeps through the speakers but when i try play video or music it says "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly." i tried to download ac97 driver from the paretlogic thier scan said there was a problem and gave them 35.00 and still no luck
cycleconnection
Posts Posts : 5
Joined Joined : 2009-12-27
Points Points : 25421
device cannot code 10
Post by cycleconnection on 28th December 2009, 5:57 am
i tried to remove and reinstall realtek ac97 and the wizard went through it process and then flashed device cannot start code 10
cycleconnection
Posts Posts : 5
Re: AUDIO DEVICE PROBLEM
Post by Doctor Inferno on 28th December 2009, 4:32 pm
Please try to install the driver from Gateway instead:
http://support.gateway.com/support/drivers/dlcenter.asp
Post by cycleconnection on 2nd January 2010, 5:34 am
that was no luck i treid clicking on the sync to look for another device it says no device found but in device manager it has a yellow question mark
the speakers beep on start up but that is it .....is the sound card replaceable in a laptop?
cycleconnection
Posts Posts : 5
