help please system tool remove not sucessful
Post by annoyedmummy on Fri Dec 25, 2009 7:38 pm
hi i have tried to remove this from my computer after following your advice but i cant even get the software you reccomended to open and work its developign that quickly i cant do a restore i cant open your sotftware and i am running out of options its closing down windows that can help i cant get to windows security sheild and norton isnt picking it up also there is a programm that has appeared on my computer called mahjong titans any ideas short of throwing the laptop out of the window?????????
annoyedmummy
OS : windows vista
Re: help please system tool remove not sucessful
Post by Dr Jay on Sat Dec 26, 2009 3:49 am
OS : Windows 10 Home & Pro
