Need help Bankerfox.a and Win32/Nuqel.E
Post by tinyskids on 24th December 2009, 5:56 am
I went to a site that I usually download from with no problem, except for today. I downloaded something that caused this to pop up. It tells me that (whatever file I try to open) is infected and asks if I want to activate my antivirus program. Well I have Mcafee loaded on my comp. Then it tells me that mcafee needs updating and does not let me run it. Then IE does not work it says that the site I want might be infected. I can get on the net through firefox (I am writing from my laptop) IE pops open with Porno sites and erectile dysfunction sites. It tells me that my comp is infected with spyware-34 and asks me again if I want to activate my antivirus software. A antivirus software program pops up (cant remember the name) but its the one that this program wants me to buy. Also my windows secruity tells me that my mcafee is off. I was able to run mcafee after I restarted the comp and started mcafee before the program turned on, but it did not detect anything. I can open programs only before this loads. It has a little icon on the bottom right hand corner next to the time and other programs. I tried running Smitfraud, malewarebytes anti-malware(I get a runtime error)housecall, even microsofts malicious software program. At one point the porno sites did not open. The site said that you are trying to open a porno site and asked if I wanted to open it or not.(something like that) But now they seem to be opening again.
Sorry for the long post but I wanted to give you as much information as possible. I really need help here.
tinyskids
Posts Posts : 81
Joined Joined : 2009-12-24
OS OS : windows xp
Points Points : 26580
Re: Need help Bankerfox.a and Win32/Nuqel.E
Post by Belahzur on 24th December 2009, 5:10 pm
Points Points : 245091
Post by Belahzur on 25th December 2009, 2:08 am
  3. Will IceSword open?
Post by tinyskids on 25th December 2009, 2:42 am
I tried downloading this but its not opening. Also its not saving to the file specified in the instructions. I am the original poster but did not post the above post. Should I download Ice Sword or should I try hijackthis in safe mode?
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by tinyskids on 25th December 2009, 2:47 am
I'm gonna restart my comp and try hijackthis on my comp before this virus loads. I will let you know what happens
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by tinyskids on 25th December 2009, 3:02 am
ok so I was able to download Hijackthis onto my comp( had to put it on my desktop and load it before the virus loaded on my comp. After it loaded I tried running it but it would not work. So I rebooted my comp (since the virus had already loaded) and am able to run hijackthis but it is not letting me open up notepad gonna try rebooting and opening notepad while running hijackthis
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by tinyskids on 25th December 2009, 3:11 am
So this worked and here is the log
Logfile of Trend Micro HijackThis v2.0.3 (BETA)
Scan saved at 22:07:16, on 12/24/2009
C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
C:\WINDOWS\zHotkey.exe
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Digital Media Reader\shwiconem.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
C:\WINDOWS\ALCWZRD.EXE
C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
C:\Program Files\Common Files\AOL\1127605169\ee\AOLSoftware.exe
C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
C:\WINDOWS\system32\bgsvcgen.exe
C:\PROGRA~1\VERIZO~1\HELPSU~1\VERIZO~1.EXE
C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
C:\WINDOWS\runservice.exe
C:\Program Files\TrendMicro\HiJackThis\HiJackThis.exe
C:\Program Files\Verizon\VSP\VerizonServicepoint.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\QuickTime\QTTask.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Documents and Settings\Owner\Local Settings\Application Data\msmvtx\nisdsysguard.exe
C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
C:\Documents and Settings\Owner\My Documents\RCA Detective\RCADetective.exe
C:\Program Files\OpenOffice.org 2.4\program\soffice.exe
C:\Program Files\OpenOffice.org 2.4\program\soffice.BIN
C:\WINDOWS\system32\notepad.exe
C:\Program Files\Microsoft SQL Server\MSSQL$SOSHOME22\Binn\sqlservr.exe
C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
C:\Program Files\Common Files\Verizon Online\ConnMgr\cmisrv.exe
c:\program files\common files\aol\1127605169\ee\services\antiSpywareApp\ver2_0_32_1\AOLSP Scheduler.exe
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: Lincmediaplayer - {fbaa6932-b59b-4854-8041-27a233394ba3} - C:\Program Files\Linksador\Lincmediaplayer\adxloader.dll
O2 - BHO: AOL Email Toolbar Loader - {fbea8524-8c72-4208-9d12-7fb73e9926eb} - C:\Program Files\AOL Email Toolbar\aolmailtb.dll
O3 - Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - (no file)
O3 - Toolbar: (no name) - {4E7BD74F-2B8D-469E-D0FC-E57AF4D5FA7D} - (no file)
O3 - Toolbar: (no name) - {b6bb2c0a-8d74-4664-a1cd-103bd9a69de9} - C:\Program Files\Linksador\Lincmediaplayer\adxloader.dll
O3 - Toolbar: AOL Email Toolbar - {a3704fa3-dbf6-46b5-b95e-0677dfd39577} - C:\Program Files\AOL Email Toolbar\aolmailtb.dll
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [CHotkey] zHotkey.exe
O4 - HKLM\..\Run: [ShowWnd] ShowWnd.exe
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [SunKistEM] C:\Program Files\Digital Media Reader\shwiconem.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [Microsoft Works Update Detection] C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1127605169\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [Pure Networks Port Magic] "C:\PROGRA~1\PURENE~1\PORTMA~1\PortAOL.exe" -Run
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [A Verizon App] C:\PROGRA~1\VERIZO~1\HELPSU~1\VERIZO~1.EXE
O4 - HKLM\..\Run: [SSBkgdUpdate] "C:\Program Files\Common Files\Scansoft Shared\SSBkgdUpdate\SSBkgdupdate.exe" -Embedding -boot
O4 - HKLM\..\Run: [PaperPort PTD] C:\Program Files\ScanSoft\PaperPort\pptd40nt.exe
O4 - HKLM\..\Run: [IndexSearch] C:\Program Files\ScanSoft\PaperPort\IndexSearch.exe
O4 - HKLM\..\Run: [BrMfcWnd] C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
O4 - HKLM\..\Run: [SetDefPrt] C:\Program Files\Brother\Brmfl06a\BrStDvPt.exe
O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
O4 - HKLM\..\Run: [VerizonServicepoint.exe] "C:\Program Files\Verizon\VSP\VerizonServicepoint.exe" /AUTORUN
O4 - HKLM\..\Run: [sehlwgon] C:\Documents and Settings\Owner\Local Settings\Application Data\msmvtx\nisdsysguard.exe
O4 - HKCU\..\Run: [EzineExpress] C:\Documents and Settings\Owner\My Documents\LivingBooksEXPRESS.exe -minimize
O4 - HKCU\..\Run: [I&F Viewer toolbar] "C:\Program Files\Photo Toolkit\ivbar\phototoolkitmem.exe" -start
O4 - HKCU\..\Run: [sehlwgon] C:\Documents and Settings\Owner\Local Settings\Application Data\msmvtx\nisdsysguard.exe
O4 - Startup: FAXRX.lnk = C:\Program Files\Brother\Brmfl06a\FAXRX.exe
O4 - Startup: OpenOffice.org 2.4.lnk = C:\Program Files\OpenOffice.org 2.4\program\quickstart.exe
O4 - Startup: RCA Detective.lnk = C:\Documents and Settings\Owner\My Documents\RCA Detective\RCADetective.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O4 - Global Startup: Service Manager.lnk = C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
O8 - Extra context menu item: &AOL Email Toolbar Search - C:\Documents and Settings\All Users\Application Data\AOL Email Toolbar\ieToolbar\resources\en-US\local\search.html
O8 - Extra context menu item: &Search - [You must be registered and logged in to see this link.]
O9 - Extra button: (no name) - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - (no file)
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.aol.com
O15 - Trusted Zone: *.west.com
O15 - Trusted Zone: *.workathomeagent.com
O15 - Trusted Zone: connect.workathomeagent.net
O15 - Trusted Zone: *.workathomeagent.net
O16 - DPF: {13149882-F480-4F6B-8C6A-0764F75B99ED} (CrazyTalk4 Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {195B4BBF-E1E4-4020-9773-0A8C6F65EA35} (CPlayFirstCookingDasControl Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - [You must be registered and logged in to see this link.]
O16 - DPF: {26E6B759-DEEB-42A1-A21C-78CD29098411} (CPlayFirstFitnessDasControl Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {37DF41B2-61DB-4CAC-A755-CFB3C7EE7F40} (AOL Content Update) - [You must be registered and logged in to see this link.]
O16 - DPF: {3EA4FA88-E0BE-419A-A732-9B79B87A6ED0} (CTVUAxCtrl Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} (Snapfish Activia) - [You must be registered and logged in to see this link.]
O16 - DPF: {4EC99A0B-E57C-4FBE-B9C4-8428424FBF88} (McciUtilsSpecialFolder Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {74C861A1-D548-4916-BC8A-FDE92EDFF62C} - [You must be registered and logged in to see this link.]
O16 - DPF: {7FE26BE2-B923-4B41-9834-E84DA1CC1F96} (Maid Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} (Shutterfly Picture Upload Plugin) - [You must be registered and logged in to see this link.]
O16 - DPF: {B7A59580-B39D-4BF9-B968-1BFA25156691} (TTS Engine Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {C606BA60-AB76-48B6-96A7-2C4D5C386F70} (PreQualifier Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {C6D25826-96AE-462F-A852-BB33B882B723} (SFImageUpload1_4.ImageUpload) - [You must be registered and logged in to see this link.]
O16 - DPF: {E7D2588A-7FB5-47DC-8830-832605661009} (Live Collaboration) - [You must be registered and logged in to see this link.]
O16 - DPF: {E9B80D94-D8BB-43CC-9138-75605A8D9666} (CPlayFirstWeddingDashControl Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {F135A813-7152-4532-AC8D-28AC2136DFC7} (CPlayFirstParkingDasControl Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {F89EF74A-956B-4BD3-A066-4F23DF891982} (Drag and Drop Uploader Control) - [You must be registered and logged in to see this link.]
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
O23 - Service: B's Recorder GOLD Library General Service (bgsvcgen) - B.H.A Corporation - C:\WINDOWS\system32\bgsvcgen.exe
O23 - Service: GameConsoleService - Unknown owner - C:\Program Files\WildGames\Game Console - WildGames\GameConsoleService.exe (file missing)
O23 - Service: LicCtrl Service (LicCtrlService) - Unknown owner - C:\WINDOWS\runservice.exe
O23 - Service: MBackMonitor - McAfee - C:\Program Files\McAfee\MBK\MBackMonitor.exe
O23 - Service: PrismXL - New Boundary Technologies, Inc. - C:\Program Files\Common Files\New Boundary\PrismXL\PRISMXL.SYS
End of file - 14553 bytes
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by tinyskids on 25th December 2009, 3:50 am
If I save my files to a disk will this virus be copied to the disk also? If so is there anyway to clean the virus off of the disk before installing to my desktop?
THANK YOU SO MUCH FOR YOUR HELP.
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by Belahzur on 26th December 2009, 9:06 pm
    In Internet Explorer
    In Firefox
Post by tinyskids on 27th December 2009, 3:28 am
ok here is the log for mbam
Malwarebytes' Anti-Malware 1.42
Database version: 3436
12/26/2009 10:26:54 PM
mbam-log-2009-12-26 (22-26-54).txt
Objects scanned: 130492
Time elapsed: 18 minute(s), 55 second(s)
Registry Keys Infected: 21
Registry Values Infected: 2
Files Infected: 2
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{56256a51-b582-467e-b8d4-7786eda79ae0} (Trojan.Vundo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b64f4a7c-97c9-11da-8bde-f66bad1e3f3a} (Rogue.WinAntiVirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{549b5ca7-4a86-11d7-a4df-000874180bb3} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Media\WMSDK\Sources\f3popularscreensavers (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform\funwebproducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\25EQCRfv.exe.a_a (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\8gn7D6p3.exe.a_a (Trojan.Agent) -> Quarantined and deleted successfully.
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by Belahzur on 27th December 2009, 3:37 pm
Post by tinyskids on 27th December 2009, 6:06 pm
I will download these either tonight or tomorrow and post the logs. So far so sign of the malware on the comp. Thanks so much
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by Belahzur on 28th December 2009, 1:39 pm
Standing by.
Post by tinyskids on 28th December 2009, 11:30 pm
DDS (Ver_09-12-01.01) - NTFSx86
Run by Owner at 18:25:29.20 on Mon 12/28/2009
Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_14
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.502.110 [GMT -5:00]
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
svchost.exe
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Common Files\Verizon Online\AppMgr\vzOpenUIServer.exe
c:\PROGRA~1\mcafee\msc\mcupdui.exe
C:\Documents and Settings\Owner\Desktop\dds.scr
BHO: Adobe PDF Reader Link Helper: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 7.0\activex\AcroIEHelper.dll
BHO: RealPlayer Download and Record Plugin for Internet Explorer: {3049c3e9-b461-4bc5-8870-4c09146192ca} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files\mcafee\virusscan\scriptsn.dll
BHO: Lincmediaplayer: {fbaa6932-b59b-4854-8041-27a233394ba3} - c:\program files\linksador\lincmediaplayer\adxloader.dll
BHO: AOL Email Toolbar Loader: {fbea8524-8c72-4208-9d12-7fb73e9926eb} - c:\program files\aol email toolbar\aolmailtb.dll
TB: N/A: {b6bb2c0a-8d74-4664-a1cd-103bd9a69de9} - c:\program files\linksador\lincmediaplayer\adxloader.dll
TB: AOL Email Toolbar: {a3704fa3-dbf6-46b5-b95e-0677dfd39577} - c:\program files\aol email toolbar\aolmailtb.dll
TB: {4E7BD74F-2B8D-469E-D0FC-E57AF4D5FA7D} - No File
TB: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No File
uRun: [EzineExpress] c:\documents and settings\owner\my documents\LivingBooksEXPRESS.exe -minimize
uRun: [I&F Viewer toolbar] "c:\program files\photo toolkit\ivbar\phototoolkitmem.exe" -start
mRun: [Recguard] c:\windows\sminst\RECGUARD.EXE
mRun: [CHotkey] zHotkey.exe
mRun: [ShowWnd] ShowWnd.exe
mRun: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
mRun: [NeroFilterCheck] c:\windows\system32\NeroCheck.exe
mRun: [IgfxTray] c:\windows\system32\igfxtray.exe
mRun: [HotKeysCmds] c:\windows\system32\hkcmd.exe
mRun: [SunKistEM] c:\program files\digital media reader\shwiconem.exe
mRun: []
mRun: [SoundMan] SOUNDMAN.EXE
mRun: [AlcWzrd] ALCWZRD.EXE
mRun: [Alcmtr] ALCMTR.EXE
mRun: [Microsoft Works Update Detection] c:\program files\common files\microsoft shared\works shared\WkUFind.exe
mRun: [HostManager] c:\program files\common files\aol\1127605169\ee\AOLSoftware.exe
mRun: [Pure Networks Port Magic] "c:\progra~1\purene~1\portma~1\PortAOL.exe" -Run
mRun: [AOLDialer] c:\program files\common files\aol\acs\AOLDial.exe
mRun: [A Verizon App] c:\progra~1\verizo~1\helpsu~1\VERIZO~1.EXE
mRun: [SSBkgdUpdate] "c:\program files\common files\scansoft shared\ssbkgdupdate\SSBkgdupdate.exe" -Embedding -boot
mRun: [PaperPort PTD] c:\program files\scansoft\paperport\pptd40nt.exe
mRun: [IndexSearch] c:\program files\scansoft\paperport\IndexSearch.exe
mRun: [BrMfcWnd] c:\program files\brother\brmfcmon\BrMfcWnd.exe /AUTORUN
mRun: [SetDefPrt] c:\program files\brother\brmfl06a\BrStDvPt.exe
mRun: [ControlCenter3] c:\program files\brother\controlcenter3\brctrcen.exe /autorun
mRun: [VerizonServicepoint.exe] "c:\program files\verizon\vsp\VerizonServicepoint.exe" /AUTORUN
mRun: [mcagent_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
mRun: [Easy Dock]
StartupFolder: c:\docume~1\owner\startm~1\programs\startup\faxrx.lnk - c:\program files\brother\brmfl06a\FAXRX.exe
StartupFolder: c:\docume~1\owner\startm~1\programs\startup\openof~1.lnk - c:\program files\openoffice.org 2.4\program\quickstart.exe
StartupFolder: c:\docume~1\owner\startm~1\programs\startup\rcadet~1.lnk - c:\documents and settings\owner\my documents\rca detective\RCADetective.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\adober~1.lnk - c:\program files\adobe\acrobat 7.0\reader\reader_sl.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office10\OSA.EXE
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\servic~1.lnk - c:\program files\microsoft sql server\80\tools\binn\sqlmangr.exe
IE: &AOL Email Toolbar Search - c:\documents and settings\all users\application data\aol email toolbar\ietoolbar\resources\en-us\local\search.html
IE: E&xport to Microsoft Excel - c:\progra~1\micros~3\office10\EXCEL.EXE/3000
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE}
Trusted Zone: internet
Trusted Zone: mcafee.com
Trusted Zone: microsoft.com\*.update
Trusted Zone: microsoft.com\update
Trusted Zone: west.com
Trusted Zone: windowsupdate.com\download
Trusted Zone: workathomeagent.com
Trusted Zone: workathomeagent.net
Trusted Zone: workathomeagent.net\connect
DPF: {02BCC737-B171-4746-94C9-0D8A0B2C0089} - [You must be registered and logged in to see this link.]
DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} - [You must be registered and logged in to see this link.]
DPF: {13149882-F480-4F6B-8C6A-0764F75B99ED} - [You must be registered and logged in to see this link.]
DPF: {195B4BBF-E1E4-4020-9773-0A8C6F65EA35} - [You must be registered and logged in to see this link.]
DPF: {26E6B759-DEEB-42A1-A21C-78CD29098411} - [You must be registered and logged in to see this link.]
DPF: {31435657-9980-0010-8000-00AA00389B71} - [You must be registered and logged in to see this link.]
DPF: {37DF41B2-61DB-4CAC-A755-CFB3C7EE7F40} - [You must be registered and logged in to see this link.]
DPF: {3EA4FA88-E0BE-419A-A732-9B79B87A6ED0} - [You must be registered and logged in to see this link.]
DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - [You must be registered and logged in to see this link.]
DPF: {4EC99A0B-E57C-4FBE-B9C4-8428424FBF88} - [You must be registered and logged in to see this link.]
DPF: {7FE26BE2-B923-4B41-9834-E84DA1CC1F96} - [You must be registered and logged in to see this link.]
DPF: {9600F64D-755F-11D4-A47F-0001023E6D5A} - [You must be registered and logged in to see this link.]
DPF: {B7A59580-B39D-4BF9-B968-1BFA25156691} - [You must be registered and logged in to see this link.]
DPF: {C606BA60-AB76-48B6-96A7-2C4D5C386F70} - [You must be registered and logged in to see this link.]
DPF: {C6D25826-96AE-462F-A852-BB33B882B723} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} - [You must be registered and logged in to see this link.]
DPF: {E7D2588A-7FB5-47DC-8830-832605661009} - [You must be registered and logged in to see this link.]
DPF: {E9B80D94-D8BB-43CC-9138-75605A8D9666} - [You must be registered and logged in to see this link.]
DPF: {F135A813-7152-4532-AC8D-28AC2136DFC7} - [You must be registered and logged in to see this link.]
DPF: {F89EF74A-956B-4BD3-A066-4F23DF891982} - [You must be registered and logged in to see this link.]
Handler: cdo - {CD00020A-8B95-11D1-82DB-00C04FB1625D} - c:\program files\common files\microsoft shared\web folders\PKMCDO.DLL
Notify: igfxcui - igfxsrvc.dll
FF - ProfilePath - c:\docume~1\owner\applic~1\mozilla\firefox\profiles\ee1z34lm.default\
FF - component: c:\program files\real\realplayer\browserrecord\firefox\ext\components\nprpffbrowserrecordext.dll
FF - plugin: c:\documents and settings\owner\application data\move networks\plugins\npqmp071503000010.dll
FF - plugin: c:\documents and settings\owner\application data\move networks\plugins\npqmp071505000010.dll
FF - plugin: c:\documents and settings\owner\application data\move networks\plugins\npqmp071701000002.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npdnu.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npmozax.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npqtplugin8.dll
FF - plugin: c:\program files\mozilla firefox\plugins\npunagi2.dll
FF - plugin: c:\program files\quicktime\plugins\npqtplugin8.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
FF - hȋdden: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
R1 mfehidk;McAfee Inc. mfehidk;c:\windows\system32\drivers\mfehidk.sys [2008-11-7 214664]
R2 LicCtrlService;LicCtrl Service;c:\windows\Runservice.exe [2006-7-18 2560]
R3 mfeavfk;McAfee Inc. mfeavfk;c:\windows\system32\drivers\mfeavfk.sys [2008-11-7 79816]
R3 mfebopk;McAfee Inc. mfebopk;c:\windows\system32\drivers\mfebopk.sys [2008-11-7 35272]
R3 mfesmfk;McAfee Inc. mfesmfk;c:\windows\system32\drivers\mfesmfk.sys [2008-11-7 40552]
S3 CA500AI;D-Link, WDM Still Image Capture, Version 1.00;c:\windows\system32\drivers\minbulk.sys --> c:\windows\system32\drivers\MinBULK.sys [?]
S3 CA500AV;D-Link, WDM Video Capture;c:\windows\system32\drivers\ca500av.sys --> c:\windows\system32\drivers\CA500AV.SYS [?]
S3 mferkdk;McAfee Inc. mferkdk;c:\windows\system32\drivers\mferkdk.sys [2008-11-7 34248]
2009-12-27 03:03:24 0 d-----w- c:\docume~1\owner\applic~1\Malwarebytes
2009-12-25 02:51:43 0 d-----w- c:\program files\TrendMicro
2009-12-24 03:42:51 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-12-24 03:42:50 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-12-24 03:42:49 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-12-24 03:42:49 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-12-23 23:20:33 4952 ----a-w- c:\windows\system32\tmp.reg
2009-12-15 17:28:47 0 d-sh--w- c:\documents and settings\owner\IECompatCache
2009-12-28 23:10:58 2169 --sha-w- c:\windows\system32\mmf.sys
2009-12-03 03:15:14 256 ----a-w- c:\documents and settings\owner\pool.bin
2009-11-18 01:00:02 4210 ----a-w- c:\docume~1\owner\applic~1\wklnhst.dat
2009-10-29 07:45:38 916480 ----a-w- c:\windows\system32\wininet.dll
2009-10-21 06:00:55 75776 ----a-w- c:\windows\system32\strmfilt.dll
2009-10-21 06:00:55 25088 ----a-w- c:\windows\system32\httpapi.dll
2009-10-13 10:53:29 266752 ----a-w- c:\windows\system32\oakley.dll
2009-10-12 13:54:17 69632 ----a-w- c:\windows\system32\raschap.dll
2009-10-12 13:54:17 112128 ----a-w- c:\windows\system32\rastls.dll
============= FINISH: 18:27:09.39 ===============
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by tinyskids on 28th December 2009, 11:31 pm
Install Date: 6/9/2005 12:52:45 AM
System Uptime: 12/28/2009 6:10:03 PM (0 hours ago)
Motherboard: Intel Corporation | | D915GAG
Processor: Intel(R) Pentium(R) 4 CPU 3.06GHz | | 3066/533mhz
C: is FIXED (NTFS) - 145 GiB total, 99.475 GiB free.
D: is FIXED (FAT32) - 4 GiB total, 1.615 GiB free.
E: is CDROM ()
F: is CDROM ()
G: is Removable
H: is Removable
I: is Removable
J: is Removable
No restore point in system.
3ivx D4 4.5.1 Decoder (remove only)
Adobe Acrobat 5.0
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Flash Player 9 ActiveX
Adobe Reader 7.1.0
Adobe Shockwave Player
Adobe Shockwave Player 11.5
Adobe® Photoshop® Album Starter Edition 3.2
Amazon MP3 Downloader 1.0.5
AOL Coach Version 1.0(Build:20040229.1 en)
AOL Coach Version 2.0(Build:20041026.5 en)
AOL Deskbar
AOL Email Toolbar
AOL Uninstaller (Choose which Products to Remove)
AOL You've Got Pictures Screensaver
Apple Mobile Device Support
Apple Software Update
Basic Facts Worksheet Factory
BlackBerry Desktop Software 4.3
BlackBerry Device Software v4.5.0 for the BlackBerry 8330 smartphone
Bonjour
Brother HL-5250DN
Brother MFL-Pro Suite
CombiMovie Version 1.31
DebugMode Wink
Diner Dash Hometown Hero - Gourmet
DivX Web Player
Doggie Dash
Download Updater (AOL LLC)
Film Factory
First Step Guide
getPlus(R)_ocx
GIMP 2.4.5
HiJackThis
Homeschool Tracker Basic
Hotfix for Windows Media Format SDK (KB902344)
Hotfix for Windows XP (KB909394)
Hotfix for Windows XP (KB914440)
Hotfix for Windows XP (KB915865)
Hotfix for Windows XP (KB926239)
Hotfix for Windows XP (KB935448)
I Can Animate
IKEA Home Planner
Intel(R) PRO Network Adapters and Drivers
InterActual Player
iTunes
IVCsoft\Internet Video Converter 1.41
J2SE Runtime Environment 5.0 Update 11
J2SE Runtime Environment 5.0 Update 4
J2SE Runtime Environment 5.0 Update 9
Java 2 Runtime Environment, SE v1.4.2
Java(TM) 6 Update 14
Java(TM) 6 Update 5
Java(TM) SE Runtime Environment 6 Update 1
Lincmediaplayer
McAfee SecurityCenter
MetaFrame Presentation Server Web Client for Win32
Microsoft .NET Framework 1.1
Microsoft Money 2004
Microsoft Money 2004 System Pack
Microsoft Office Excel Viewer 2003
Microsoft Office Live Meeting 2007
Microsoft Office Word Viewer 2003
Microsoft Office XP Professional with FrontPage
Microsoft Picture It! Photo Premium 9
Microsoft Reader
Microsoft Silverlight
Microsoft SQL Server Desktop Engine (SOSHOME22)
Microsoft Works
Move Media Player
Mozilla Firefox (3.5.6)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
MSXML 6 Service Pack 2 (KB973686)
Multimedia Keyboard Driver
Nero BurnRights
Nero OEM
Netflix Movie Viewer
oggcodecs 0.71.0946
oobeFlagNetscape0
OpenOffice.org 2.4
OverDrive Media Console
PaperPort
PDFCreator
Photo Story 3 for Windows
Photo Viewer 2.3
PlayLinc
Powerbullet Presenter
Quarter Mile Math DEMO
QuickTime
QuickTime for Windows (32-bit)
RapidPlayer v4.0 ActiveX Control
RCA Detective™ 2.0.0.99
RCA easyRip 2.1.7.0
RCA easyRip™ 1.4.6.0
RealPlayer
RealProducer Basic 11
ResumeMaker
Robinson Curriculum
RTC Client API v1.2 Setup
RUMBA SecureRedirector Client
Samsung USB Driver (MCCI 4.34) WHQL v3.4
Security Advisor
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB974455)
Security Update for Windows Internet Explorer 8 (KB976325)
Security Update for Windows XP (KB883939)
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896422)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896424)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB896688)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899588)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901190)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB903235)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB905915)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB908531)
Security Update for Windows XP (KB911280)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911567)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB912812)
Security Update for Windows XP (KB912919)
Security Update for Windows XP (KB913446)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB916281)
Security Update for Windows XP (KB917159)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB917422)
Security Update for Windows XP (KB917953)
Security Update for Windows XP (KB918118)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB918899)
Security Update for Windows XP (KB919007)
Security Update for Windows XP (KB920213)
Security Update for Windows XP (KB920214)
Security Update for Windows XP (KB920670)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB921398)
Security Update for Windows XP (KB921503)
Security Update for Windows XP (KB921883)
Security Update for Windows XP (KB922616)
Security Update for Windows XP (KB922760)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB923191)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB923694)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB924191)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB924667)
Security Update for Windows XP (KB925454)
Security Update for Windows XP (KB925486)
Security Update for Windows XP (KB925902)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB928090)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB929123)
Security Update for Windows XP (KB929969)
Security Update for Windows XP (KB930178)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB931768)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB933566)
Security Update for Windows XP (KB933729)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB937143)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB939653)
Security Update for Windows XP (KB941202)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB941693)
Security Update for Windows XP (KB942615)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB945553)
Security Update for Windows XP (KB946026)
Security Update for Windows XP (KB948590)
Security Update for Windows XP (KB948881)
Security Update for Windows XP (KB950749)
Security Update for Windows XP (KB958470)
Security Update for Windows XP (KB970430)
Security Update for Windows XP (KB973904)
Security Update for Windows XP (KB974318)
Security Update for Windows XP (KB974392)
Showoff Home Design 1.0
Sibelius Scorch (ActiveX Only)
SoftV92 Data Fax Modem with SmartCP
Sony USB Driver
SopCast 1.1.2
StartWrite
StudyDog Basic Class - Level 1
Switched-On Schoolhouse 2007 - Home Edition
Update for Windows Internet Explorer 7 (KB976749)
Update for Windows Internet Explorer 8 (KB975364)
Update for Windows Internet Explorer 8 (KB976749)
Update for Windows XP (KB894391)
Update for Windows XP (KB896727)
Update for Windows XP (KB900485)
Update for Windows XP (KB904942)
Update for Windows XP (KB910437)
Update for Windows XP (KB916595)
Update for Windows XP (KB920872)
Update for Windows XP (KB922582)
Update for Windows XP (KB925720)
Update for Windows XP (KB927891)
Update for Windows XP (KB929338)
Update for Windows XP (KB930916)
Update for Windows XP (KB931836)
Update for Windows XP (KB932823-v3)
Update for Windows XP (KB933360)
Update for Windows XP (KB936357)
Update for Windows XP (KB938828)
Update for Windows XP (KB942763)
Update for Windows XP (KB942840)
Update for Windows XP (KB946627)
Update for Windows XP (KB971737)
Verizon Broadband Toolbar
Verizon Online Help & Support
Verizon Servicepoint 1.5.20
Verizon SmartCall
Viewpoint Manager (Remove Only)
Viewpoint Media Player
WebFldrs XP
Wedding Dash
Wild Things! by Wild Ginger Software, Inc.
WildTangent Games
Windows Backup Utility
Windows Driver Package - Microsoft Corporation (usbvideo) Image (05/25/2007 1.0.3656.0)
Windows Imaging Component
Windows Media Player 10 Hotfix - KB894476
Windows XP Hotfix - KB873333
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB885250
Windows XP Hotfix - KB885295
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB885884
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB887742
Windows XP Hotfix - KB888113
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB890175
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB890923
Windows XP Hotfix - KB891781
Windows XP Hotfix - KB893066
Windows XP Hotfix - KB893086
XML Paper Specification Shared Components Pack 1.0
12/26/2009 9:37:46 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Windows Installer service to connect.
12/26/2009 9:37:46 PM, error: Service Control Manager [7000] - The Windows Installer service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
12/26/2009 9:37:45 PM, error: DCOM [10005] - DCOM got error "%1053" attempting to start the service MSIServer with arguments "" in order to run the server: {000C101C-0000-0000-C000-000000000046}
12/26/2009 9:05:37 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the IMAPI CD-Burning COM Service service to connect.
12/26/2009 9:05:37 PM, error: Service Control Manager [7000] - The IMAPI CD-Burning COM Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
12/26/2009 10:33:21 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: abp480n5 adpu160m agp440 agpCPQ Aha154x aic78u2 aic78xx AliIde alim1541 amdagp amsint asc asc3350p asc3550 cbidf cd20xrnt CmdIde Cpqarray dac2w2k dac960nt dpti2o hpn i2omp ini910u IntelIde mraid35x perc2 perc2hib ql1080 Ql10wnt ql12160 ql1240 ql1280 sisagp Sparrow symc810 symc8xx sym_hi sym_u3 TosIde ultra viaagp ViaIde
12/23/2009 9:15:18 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
12/23/2009 9:13:46 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service StiSvc with arguments "" in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
12/23/2009 9:11:40 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service McNASvc with arguments "" in order to run the server: {24F616A1-B755-4053-8018-C3425DC8B68A}
12/23/2009 9:11:39 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service McShield with arguments "" in order to run the server: {DC7EF8E1-824F-4110-AB43-1604DA9B4F40}
12/23/2009 8:24:45 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service wuauserv with arguments "" in order to run the server: {E60687F7-01A1-40AA-86AC-DB1CBF673334}
12/23/2009 7:54:49 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: Fips intelppm mfehidk
12/23/2009 7:38:45 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service netman with arguments "" in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
12/23/2009 7:07:57 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AFD Fips intelppm IPSec mfehidk MPFP MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip
12/23/2009 7:07:57 PM, error: Service Control Manager [7001] - The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:57 PM, error: Service Control Manager [7001] - The Bonjour Service service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:57 PM, error: Service Control Manager [7001] - The Apple Mobile Device service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:56 PM, error: Service Control Manager [7001] - The TCP/IP NetBIOS Helper service depends on the AFD service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:56 PM, error: Service Control Manager [7001] - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:56 PM, error: Service Control Manager [7001] - The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
12/23/2009 7:07:45 PM, error: atapi [9] - The device, \Device\Ide\IdePort1, did not respond within the timeout period.
12/23/2009 6:54:02 PM, error: System Error [1003] - Error code 00000024, parameter1 001902fe, parameter2 f8b0fb6c, parameter3 f8b0f868, parameter4 f850a6d4.
12/23/2009 6:00:02 PM, error: Schedule [7901] - The At43.job command failed to start due to the following error: %%2147942402
12/23/2009 6:00:02 PM, error: Schedule [7901] - The At19.job command failed to start due to the following error: %%2147942402
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by Belahzur on 28th December 2009, 11:33 pm
    Java(TM) 6 Update 5
  • Download combofix from here
Post by tinyskids on 29th December 2009, 2:35 am
should I make a back up copy of my files before downloading and running combofix. Please advise.
tinyskids
Posts Posts : 81
OS OS : windows xp
Post by Belahzur on 29th December 2009, 5:56 pm
It would be wise to, yes.
Post by tinyskids on 1st January 2010, 11:20 pm
After I finish copying my files I will download combifix
tinyskids
Posts Posts : 81
OS OS : windows xp
