wireless is saying it is connected, but internet will not work !!
Post by bethhull on 22nd December 2009, 6:25 pm
Hello
For some reason when i try and go on the wireless on my laptop, it is saying that is connected and that it has excellent strength. Yet when i open internet explorer it just wont work and says it can not display the webpage?
I have no clue what to do next, any help would be appreciated !!
bethhull
Posts Posts : 3
Joined Joined : 2009-12-09
Points Points : 25591
Re: wireless is saying it is connected, but internet will not work !!
Post by Doctor Inferno on 23rd December 2009, 3:28 am
Open CMD, Reset WINSOCK entries to installation defaults by typing: netsh winsock reset catalog
Restart your PC.
If it doesn't work, download Winsock XP Fix from here, save it to your Desktop.
See if you can connect now.
Points Points : 104630
