Need help with removing Antivirus Live
Post by diggerboggs on Thu Dec 17, 2009 6:38 pm
Help! I'm new to this site too and my first posting. This rouge virus seems to be very intelligent about protecting itself from removal. The problem I am having following any of the removal instructions I've seen posted are as follows:
1. When trying to disable proxy settings under the LAN tab you can press the as many times as you want but the key has been disabled or at least will not highlite and the use proxy server cannot be unchecked.
2. nȯne of the antivirus programs can be accessed to be downloaded NOR can I install from a flashdrive. This F'kr is very territorial!
3. I cannot open ANY security, system tools, or any other programs to be able to block, delete, isolate, etc. I see the cleaner suggestions but I'm not sure how to get to the registry>
4. This happened to an HP Netbook through a Belkin Wireless router. No antimalware, antispyware or any type antivirus was active on the this Windows XP system. I foolishly thought the Wireless Firewall would protect us.
PLEASE HELP!
Thanks for your support!
diggerboggs
diggerboggs
Posts Posts : 4
Joined Joined : 2009-12-17
OS OS : windows XP
Points Points : 25513
Re: Need help with removing Antivirus Live
Post by Belahzur on Thu Dec 17, 2009 6:40 pm
Points Points : 245059
Post by diggerboggs on Thu Dec 17, 2009 6:53 pm
Can this be accomplished through a flashdrive? since i cannot open or download anything through the infected computer
diggerboggs
Posts Posts : 4
OS OS : windows XP
Post by Belahzur on Thu Dec 17, 2009 6:54 pm
Yeah, it should be able to, OTL doesn't need to install, just double click and run.
Post by diggerboggs on Thu Dec 17, 2009 7:11 pm
Ok, that seems to have worked but now don't I risk bringing the infected files from the netbook onto my desktop through the flashdrive???
diggerboggs
Posts Posts : 4
OS OS : windows XP
Post by Belahzur on Thu Dec 17, 2009 7:14 pm
Not really, autorun infections have different signs.
