New, please help with a connection problem.
Post by DemyxTime on Wed Dec 16, 2009 5:01 pm
Or, at least I THINK it's a connection problem x_X
Well, it started when I tried to run an Update on an MMO I play D:
I got an odd error and after trying to manual patch among other things, I decided to uninstall. Well, thats where the huge problems began. Ever since uninstalling, my internet has been bad. Every few minutes I get Problem Loading Page and Server Not Responding messages. I can't do practically anything now. Not only that, but when trying to re-download said game, it just sends everything into a frenzy. It stops at 6% and then says something about it being Unknown and stops downloading. I thought maybe I had a virus but I scanned and came up clean.
If anyone can help, that would be so appreciated!
DemyxTime
Joined Joined : 2009-12-16
OS OS : Windows Vista
Points Points : 25463
Re: New, please help with a connection problem.
Post by Jordan on Sun Dec 27, 2009 12:00 pm
@DemyxTime wrote:Or, at least I THINK it's a connection problem x_X
Ever since uninstalling what?
Jordan
Posts Posts : 29
Joined Joined : 2009-06-28
OS OS : Vista, XP, Linux, Mac (I got em all)
Points Points : 27275
Post by Nazzgull on Tue Dec 29, 2009 8:13 am
Hi, it's not caused by uninstalling game. You have some process which using your internet connection without your permission. Download and install Zone Alarm Security Suite, it's not free but i'm sure you can find it ;) It's Firewall and Program Control. Also, maybe you should scan your computer with HijackThis and post log file here.
Points Points : 40445
